mydeardiary Posted June 24, 2023 Posted June 24, 2023 (edited) Hi, guys. Finally got mxq4 Fleco booting with Armbian, but the internal wifi chip (r8723as) is not working. The wifi chip is identified as 02c4:8723. No hdmi output with hdmi-to-usb device. Didn't test other hdmi devices. Overlays applied: emmc, led-conf2. Leds are working, with blue led shining when the device boots with Armbian. Tried patching the kernel to add the device id to r8723bs driver with result the interface wlan0 without the ability to bring up the interface. Someone has done this similar work before. Attached is the dts from Android tv, kernel 3.10 and system diagnosis information. device-tree-mxq4k.dts Edited June 24, 2023 by mydeardiary Added system diagnosis and hdmi status 0 Quote
RaptorSDS Posted June 24, 2023 Posted June 24, 2023 (edited) On 6/24/2023 at 4:15 AM, mydeardiary said: Tried patching the kernel to add the device id to r8723bs Expand But RTL8723as is not 8723bs , you should not mix them . 8723as has definitive a diffirent firmware than bs https://kernel.googlesource.com/pub/scm/linux/kernel/git/jes/linux/+/rtl8xxxu-8188eu/drivers/net/wireless/realtek/rtl8xxxu/rtl8xxxu.h many of the RTL 8723xx are part of Kernel 5 , it should be detect by linux automaticly with the right firmware/driver combination have you check the chip by open the box ? maybe its a 8723ds (bs and ds have same format and pinout ) ,8723as has a diffirent board format so its very unusal that this board have another print extra for this 8723as format Edited June 24, 2023 by RaptorSDS 1 Quote
jock Posted June 24, 2023 Author Posted June 24, 2023 @mydeardiary hello, as @RaptorSDS said, rtl8723as and rtl8723bs are two different chips and require different drivers and firmwares. rtl8723as driver is not in the linux kernel and looks like quite difficult to find a suitable driver. Libreelec folks did some adaptation for the rtl8723au: https://github.com/dtechsrv/LibreELEC-AML/pull/24 1 Quote
tommy Posted June 25, 2023 Posted June 25, 2023 (edited) On 6/23/2023 at 10:13 PM, ArkhanLK said: On 10/16/2021 at 4:44 AM, tommy said: Your cutting edge armbian can achieve PSX full 60fps speed in retroarch Expand Hello Tommy! Did you achieve this through retroarch on linux, or through a lakka-self-compited-img...? It's been almost 2 years, lol, so I don't know if you made any progress but in any case, would you be willing to share whatever image you have working best? I am working with the k5.15 and it's been great for many things. Retroarch doesn't seem to be one of them, tho. Maybe I need to tweak it a lot and should not expect it to work great at install, tho... Thanks! Expand Quote At the current stage of this RK332X armbian, PSX emulator could achieve 60 fps on the current/edge kernel because of the great work of Jock, contributors, and Linux graphic library devs. Kernel 5.15 may be work but you need to update your system first. It is best to try on current / edge build. Ubuntu seems to be a little better than Debian. 1. use "armbian-config" command to freeze your kernel update and config max cpu freq. to 1.3 GHz (or more if has any) 2. $ sudo apt update , $ sudo apt upgrade 3. install retroarch to get the necessary library is the easiest way. $ sudo apt install retroarch 4. build or download aarch64 cores. It is best to build your own core by https://github.com/libretro/libretro-super 5. Retroarch config video renders multi-core and fullscreen to increase speed. 6. PSX core on aarch64 needs the new build to have neon 64bit to be fast. Hope you enjoy gaming on this amazing armbian tv box. Expand Sorry, I thought it is RK33xx, but this forum is RK322X. It is 32bit arm CPU. RK32xx is a slower than 33xx. I'm not use 32xx box anymore. For 32xx, the legacy 4.X kernel is faster for this CPU but it hard to find require library now. I'm not test current kernel on 322x that could archive 60 fps. You may try the above instruction but arm 32bit core instead that may be work for you. Edit: I just tested it on my 322x box. Ubuntu Edge kernel works. Retroarch with pcsx-rearmed armv7 core plays PSX game for 60 fps without problem. Edited June 25, 2023 by tommy RK322X not RK33XX 0 Quote
jock Posted June 25, 2023 Author Posted June 25, 2023 On 6/25/2023 at 1:44 AM, tommy said: Edit: I just tested it on my 322x box. Ubuntu Edge kernel works. Retroarch with pcsx-rearmed armv7 core plays PSX game for 60 fps without problem. Expand Sorry, just to be clear (I'm curious...): you tried the latest Ubuntu Lunar with edge 6.3 kernel you can download from https://github.com/armbian/community ? 0 Quote
tommy Posted June 25, 2023 Posted June 25, 2023 On 6/25/2023 at 9:42 PM, jock said: On 6/25/2023 at 1:44 AM, tommy said: Edit: I just tested it on my 322x box. Ubuntu Edge kernel works. Retroarch with pcsx-rearmed armv7 core plays PSX game for 60 fps without problem. Expand Sorry, just to be clear (I'm curious...): you tried the latest Ubuntu Lunar with edge 6.3 kernel you can download from https://github.com/armbian/community ? Expand Yes, it is. This link -> https://github.com/armbiankappa/os/releases/download/23.8.0-trunk.56/Armbian_23.8.0-trunk.56_Rk322x-box_lunar_edge_6.3.8_xfce_desktop.img.xz 0 Quote
ArkhanLK Posted June 26, 2023 Posted June 26, 2023 (edited) On 6/25/2023 at 1:44 AM, tommy said: Edit: I just tested it on my 322x box. Ubuntu Edge kernel works. Retroarch with pcsx-rearmed armv7 core plays PSX game for 60 fps without problem. Expand Ok, so just like out of the blue, you burned that img, installed retroarch, and pcsx ran 60fps? Damn. Edit: if you changed anything, I'd like to know your settings. Would you share? Edited June 26, 2023 by ArkhanLK 0 Quote
mydeardiary Posted June 26, 2023 Posted June 26, 2023 On 6/24/2023 at 6:03 AM, RaptorSDS said: But RTL8723as is not 8723bs , you should not mix them . 8723as has definitive a diffirent firmware than bs https://kernel.googlesource.com/pub/scm/linux/kernel/git/jes/linux/+/rtl8xxxu-8188eu/drivers/net/wireless/realtek/rtl8xxxu/rtl8xxxu.h many of the RTL 8723xx are part of Kernel 5 , it should be detect by linux automaticly with the right firmware/driver combination have you check the chip by open the box ? maybe its a 8723ds (bs and ds have same format and pinout ) ,8723as has a diffirent board format so its very unusal that this board have another print extra for this 8723as format Expand I don't have a clue, but the driver used within Android os is 8723as. Here is the photo of wifi chip. Reveal hidden contents On 6/24/2023 at 8:46 PM, jock said: Libreelec folks did some adaptation for the rtl8723au: https://github.com/dtechsrv/LibreELEC-AML/pull/24 Expand Great. There is still a hope to get this 8723as wifi chip works within Armbian. 0 Quote
RaptorSDS Posted June 26, 2023 Posted June 26, 2023 On 6/26/2023 at 3:44 AM, mydeardiary said: Here is the photo of wifi chip. Expand thank you , i also found also lwfinger https://github.com/lwfinger/rtl8723au there are also some AS mention also some fork but kernel 4.4 https://github.com/instantaphex/rtl8723as/tree/master 0 Quote
mydeardiary Posted June 27, 2023 Posted June 27, 2023 On 6/24/2023 at 8:46 PM, jock said: Libreelec folks did some adaptation for the rtl8723au: https://github.com/dtechsrv/LibreELEC-AML/pull/24 Expand Got no success compiling rtl8723AU driver from the mentioned pull request inside linux 6.3.8 source tree with arm gnueabihf toolchain 11.3 from developer.arm.com website. Reveal hidden contents builder@buildserver ~/playground/linux-6.3.8/drivers/staging/rtl8723AU $ time make CONFIG_RTL8723AU=m -C $KSRC M=$PWD make: Entering directory '/home/builder/playground/linux-6.3.8' CC [M] /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/core/rtw_cmd.o In file included from /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/core/rtw_cmd.c:23: /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/include/osdep_service.h: In function ‘_init_timer’: /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/include/osdep_service.h:959:15: error: ‘_timer’ {aka ‘struct timer_li st’} has no member named ‘data’ 959 | ptimer->data = (unsigned long)cntx; | ^~ /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/include/osdep_service.h:960:9: error: implicit declaration of functio n ‘init_timer’; did you mean ‘_init_timer’? [-Werror=implicit-function-declaration] 960 | init_timer(ptimer); | ^~~~~~~~~~ | _init_timer /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/core/rtw_cmd.c: In function ‘rtw_cmd_thread’: /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/include/osdep_service.h:850:31: error: implicit declaration of functi on ‘complete_and_exit’ [-Werror=implicit-function-declaration] 850 | #define thread_exit() complete_and_exit(NULL, 0) | ^~~~~~~~~~~~~~~~~ /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/core/rtw_cmd.c:595:9: note: in expansion of macro ‘thread_exit’ 595 | thread_exit(); | ^~~~~~~~~~~ /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/core/rtw_cmd.c:597:1: error: control reaches end of non-void function [-Werror=return-type] 597 | } | ^ cc1: some warnings being treated as errors make[1]: *** [scripts/Makefile.build:252: /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU/core/rtw_cmd.o] Error 1 make: *** [Makefile:2025: /home/builder/playground/linux-6.3.8/drivers/staging/rtl8723AU] Error 2 make: Leaving directory '/home/builder/playground/linux-6.3.8' The source driver is attached. Any help is appreciated. rtl8723AU-pr24.tar.gzFetching info... 0 Quote
baryon Posted June 27, 2023 Posted June 27, 2023 Hello friends, There was some interest in running Retropie on this box in this thread. I've done some basic work getting one of the boxes I own to run Retropie, and have a basic patch that helps Retropie identify that the CPU is ARM. https://retropie.org.uk/forum/topic/34337/rk322x-box-armbian-build-report-collab If there are tests / whatever folks here might find helpful, let me know. I'm not sure how long I'll be keeping this box. 2 Quote
G4B33 Posted June 28, 2023 Posted June 28, 2023 Hello guys! I have this H96 Mini V8 RK3228A tv box without an SD card slot. I flashed the newest armbian on it. It worked, but every time the screen updated I got these weird green line flashing. So I figured maybe it's just some driver issue because somebody successfully used armbian with this board, so I tried flashing older versions. Older versions still had this issue, but now I got a bigger problem: I can't flash anything else now, because the button doesn't boot it into maskrom mode, and I'm stuck on some old minimal version armbian that can't even boot up properly! It seems my only option left is to find the clock pin on the emmc if that's possible, or to erase the emmc completely with that broken Linux. I already tried fdisk and mkfs commands to try to erase it, it just say command not found. This is where I need your help guys. Here are some photos of the emmc chip and of the board. By the way I already figured out the green line issue, it only does this at 4k resolution, if I plug in the HDMI after powering it on, it starts at a lower resolution 0 Quote
ArkhanLK Posted June 29, 2023 Posted June 29, 2023 On 6/27/2023 at 2:16 PM, baryon said: Retropie on this box in this thread Expand Hey, that's very nice! I am trying exactly to have it as an option for retro games. I have tried libreelec/kodi with IAGL, but not much luck there. I am trying Retroarch on itself but still am struggling... So, for me to try the retropie, do you have a compiled image? Or how would I got about it? Thanks once more! 0 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 (edited) @jock help stuck on Write LBA from file (76%) then I retry flashing now all img says "Write LBA failed!" I have rk3229 device. specs: 8gb storage 1gb ram img file name I flashed: Armbian_23.05.0-trunk-e33842ef2_Rk322x-box_lunar_edge_6.2.9_minimal.img code I used: ./rkdeveloptool wl 0x0 image.img my device on lsusb: Bus 001 Device 003: ID 2207:320b Fuzhou Rockchip Electronics Company RK3228/RK3229 in Mask ROM mode edit: I think if I remember correctly at first I'm in loader mode but I think after flashing I am now in maskrom mode and now I don't need to toothpick the reset button. edit 2: I replaced my rk322x_loader_v1.10.238_256.bin which I got from different source and replaced it with the loader provided in page 1 it has the same size 185kb but I can flash again now any img file to 100% but now when I power my device only black screen. edit 3: I am not sure if I have nand, emmc or emcp so I attached these images. atm I can only unscrew 2 screws. Edited July 2, 2023 by mcs 0 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 (edited) update: I was able to cut the plastic where the screw is attached and now managed to open the back cover. hey guys here I attached my device's front and back with each including zoomed view. I also Included here it's lsusb information. I hope in this way I can contribute to the rk322x community. I found out that my device is actually rk3228a says on a sticker on the board and not rk3229 but in lsusb it says RK3228/RK3229 edit: the board is R329Q _ V3.1 Edited July 2, 2023 by mcs 0 Quote
jock Posted July 2, 2023 Author Posted July 2, 2023 On 7/2/2023 at 12:56 AM, mcs said: edit 3: I am not sure if I have nand, emmc or emcp so I attached these images. atm I can only unscrew 2 screws. Expand This is essential, since nand is supported only with legacy 4.4 kernel. That's clearly and boldly stated in the first page. That board is perfectly supported, but probably it is more convenient for you to run a fresh mainline kernel from sd card than an ancient legacy kernel from nand. 1 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 (edited) okay so I currently don't have an SD card to use but I have usb flash drive so @jock do I have emmc or nand base on my board? I am unsure so I skipped the Nand bootloader upgrade as per your instruction and did the Installation (without SD card, board with eMMC) I tried to use USB flash drive at first - flashed the multitool in the first page and some images but won't work. I am completely new and still trying to understand and learn everything. I really don't have an idea on what to do next. Edited July 2, 2023 by mcs 0 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 summary of what I've done: Installation (via SD card): Flashed using etcher - USB flash drive: multitool.img tried flashing lunar edge -both didn't work Installation (without SD card, board with eMMC): rkdeveloptool db: rk322x_loader_v1.10.238_256 rkdeveloptool wl 0x0: Armbian_23.05.0-trunk-e33842ef2_Rk322x-box_lunar_edge_6.2.9_minimal.img Armbian_22.02.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img Armbian_23.5.1_Rk322x-box_bookworm_current_6.1.30_minimal.img -All Write LBA from file (100%) but black screen 0 Quote
fabiobassa Posted July 2, 2023 Posted July 2, 2023 @mcs You have nand and ddr3 Must use miltitool and stepNand with LEGACY image 1 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 @fabiobassa okay so these are images provided by jock the ones with legacy like the bullseye_legacy and focal_legacy right? 0 Quote
fabiobassa Posted July 2, 2023 Posted July 2, 2023 @mcs Yes follow the link on 1st post This board Is very powerfull 1 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 I tried to find legacy images in the nightly builds trunks but couldn't find. Thanks @jock for the legacy builds. 0 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 (edited) hello @fabiobassa based on jock's reply just above I just want to confirm for what I understood I can use main kernel images on SD card and legacy only on the internal storage. I just found an SD card and jock suggested to run the mainline kernels than the legacy kernels which are ancient. also I don't need to flash the u-boot-main.img if I have sdcard right? Edited July 2, 2023 by mcs 0 Quote
baryon Posted July 2, 2023 Posted July 2, 2023 On 6/29/2023 at 3:35 AM, ArkhanLK said: Or how would I got about it? Expand https://retropie.org.uk/docs/Manual-Installation/ -- use this process, build takes 4-5 hours, and has the bonus of giving you a free stress test to see how it will handle the most intensive games https://retropie.org.uk/forum/topic/34337/rk322x-box-armbian-build-report-collab -- you have to patch/edit a couple files to get it to build right, as this is a new hardware config Still poking around seeing how Dreamcast works. Been having some compile issues. 0 Quote
ilmich Posted July 2, 2023 Posted July 2, 2023 (edited) @mcs I've same board.. erase nand with rkdeveloptool and use sdcard with modern armbian Edited July 2, 2023 by ilmich 0 Quote
mcs Posted July 2, 2023 Posted July 2, 2023 haha thanks @ilmich I will install on USB for now the SD only has 2gb 0 Quote
mcs Posted July 3, 2023 Posted July 3, 2023 hey guys is "Install Jump start on NAND" in multitool the same as flashing u-boot-main.img.xz the method without SD card? "installing u-boot-main.img makes the installed system unbootable because it is missing the NAND driver." is that bad? also in the alternative instructions on NAND: Choose "Install Jump Start for Armbian" menu option is it the same with "Install Jump Start on NAND"? 0 Quote
mcs Posted July 3, 2023 Posted July 3, 2023 I was also able to create a backup today from multitool 286mb in size. 0 Quote
im_chc Posted July 3, 2023 Posted July 3, 2023 (edited) On 11/30/2022 at 6:03 PM, jock said: But from the photos I see that your stick has a SPI flash memory. It has never been tested and I don't think any image could even boot there because both u-boot and kernel must be aware of that hardware, and in current images they aren't. Expand Hi @jock, it's been a while...I know...😅 Correct me if I'm wrong, if I use an SD card drive for the dongle, does that mean that I can use a uboot and kernel that supports SD cards to boot it up? I mean, just to install uboot and kernel and the distribution to the SD card, ignoring the SPI storage. But there is one more problem, the dongle has only one usb port, and after I plugged in a card drive, there will be no free usb port left for power. Do I need some special cables like those that has one single male connector at one end, and one male connector + one female connector on the other? Edited July 5, 2023 by im_chc tag recipient's account 0 Quote
mcs Posted July 4, 2023 Posted July 4, 2023 hello @fabiobassa I did jump start on NAND burned my jammy_current image with etcher to usb stick and inserted it to otg port it's not booting but multitool still works. I did dmesg in bash shell in multitool and it detects my usb stick... 0 Quote
