ebin-dev Posted May 28, 2018 Share Posted May 28, 2018 On 5/23/2018 at 11:02 PM, howudodat said: I still need some help understanding eth0 Have a look at this article. 0 Quote Link to comment Share on other sites More sharing options...
nurF Posted June 6, 2018 Share Posted June 6, 2018 Does anyone know, what is causing the following error message? sdhci_transfer_data: Error detected in status(0x2008000)! Error reading cluster ** Unable to read file armada-3720-espressobin.dtb ** 0 Quote Link to comment Share on other sites More sharing options...
Pavel Odintsov Posted June 10, 2018 Share Posted June 10, 2018 Hello! Any plans about 4.17? I just booted my ARM64 Cavium Thunder with this kernel and it was quite challenging But this kernel has number of nice additions for ARM boards! 0 Quote Link to comment Share on other sites More sharing options...
umiddelb Posted June 10, 2018 Share Posted June 10, 2018 8 hours ago, Pavel Odintsov said: Hello! Any plans about 4.17? I just booted my ARM64 Cavium Thunder with this kernel and it was quite challenging But this kernel has number of nice additions for ARM boards! You may try to build it by yourself or download an archive containing the image. 0 Quote Link to comment Share on other sites More sharing options...
briaeros Posted June 15, 2018 Share Posted June 15, 2018 Hello, First, thanks for your time in creating and managing armbian :) It will be great if cryptsetup work "out of the box" (without rebuilding your own kernel) (at least in devel ;)). At the present time, I can't mount any encrypted partition because some options are missing in the kernel. I think the kernel option "CONFIG_CRYPTO_USER_API_SKCIPHER" is needed. The module dm_mod.ko is also needed but I can't find which option(s) creates it (it's the device mapper module). It will be also great if we can try the CESA code since the option seems here (CONFIG_CRYPTO_DEV_MARVELL_CESA) , so we can test it :) I paste below the results of my simple tests. Quote root@espressobin:~# uname -a Linux espressobin 4.16.15-mvebu64 #152 SMP PREEMPT Tue Jun 12 01:48:50 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux root@espressobin:~# cryptsetup benchmark # Tests are approximate using memory only (no storage IO). PBKDF2-sha1 121362 iterations per second PBKDF2-sha256 74898 iterations per second PBKDF2-sha512 68337 iterations per second PBKDF2-ripemd160 108683 iterations per second PBKDF2-whirlpool 24380 iterations per second Required kernel crypto interface not available. Ensure you have algif_skcipher kernel module loaded. root@espressobin:~# dd if=/dev/zero of=/run/test bs=1M count=10 10+0 records in 10+0 records out 10485760 bytes (10 MB, 10 MiB) copied, 0.0315174 s, 333 MB/s root@espressobin:~# cryptsetup open --type plain /run/test test Enter passphrase: Cannot initialize device-mapper. Is dm_mod kernel module loaded? root@espressobin:~# cryptsetup luksFormat --type luks2 /run/test WARNING! ======== This will overwrite data on /run/test irrevocably. Are you sure? (Type uppercase yes): YES Enter passphrase: Verify passphrase: Cannot initialize device-mapper. Is dm_mod kernel module loaded? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 16, 2018 Share Posted June 16, 2018 (edited) 17 hours ago, briaeros said: First, thanks for your time in creating and managing armbian It will be great if cryptsetup work "out of the box" (without rebuilding your own kernel) (at least in devel ;)). Thank you! But only together we can manage with the complexity If any kernel config changes are needed, we urge people to send PR against build engine. You can find Espressobin, kernel family mvebu64, configurations here: https://github.com/armbian/build/tree/master/config/kernel ... and general howto here: https://docs.armbian.com/Process_Contribute/ Changes lands to the beta.armbian.com package repository in less than 24h if all kernels building succeeded. Try. Edited June 16, 2018 by Igor typo 0 Quote Link to comment Share on other sites More sharing options...
ebin-dev Posted June 17, 2018 Share Posted June 17, 2018 On 6/15/2018 at 8:01 PM, briaeros said: It will be also great if we can try the CESA code since the option seems here (CONFIG_CRYPTO_DEV_MARVELL_CESA) , so we can test it :) The 5Gbps Security Engine of the Espressoin is not CESA compatible. It needs a specific driver implemented by Bootlin in kernel 4.16: Quote The driver currently supports: Hashes: sha1, hmac(sha1), sha224, sha256. Ciphers: ecb(aes), cbc(aes). This allows to offload some IPsec connexions, depending on the configuration, as these algs can be combined by the crypto layer. More algs are coming, but there is no schedule for them. 0 Quote Link to comment Share on other sites More sharing options...
briaeros Posted June 17, 2018 Share Posted June 17, 2018 4 hours ago, ebin-dev said: The 5Gbps Security Engine of the Espressoin is not CESA compatible. It needs a specific driver implemented by Bootlin in kernel 4.16: Thanks for the correction. I don't remember where I read that it was CESA. An untrustworthy source certainly. safeexecel is already compiled as a module. I will then try to make it works with my espresso ;) 0 Quote Link to comment Share on other sites More sharing options...
arthurlutz Posted June 25, 2018 Share Posted June 25, 2018 Hi, This read is getting a bit too long and thus it is getting hard to find information in it. Am up for helping on extracting some of the information here and compiling it in a wiki or other type of shared document to help the espressobin community. Anyone else think this is a good idea ? And maybe new threads per subject could be openned ? Does this forum have a habit of using the lock feature on posts that are too long ? By the way, I've asked a question about "[Espressobin] Transparent monitoring switch - ethernet bridge and hardware questions" that might interest some of the espressobin owners. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 25, 2018 Share Posted June 25, 2018 10 minutes ago, arthurlutz said: This read is getting a bit too long and thus it is getting hard to find information in it. It's planned to create a separate forum for Armada powered devices, it's planned to upgrade a kernel for Espresso ... but we extremely lack time/resources for that. If you volunteer to get this forum mess in order by taking moderator duties and move topics into new subforum/in order ... this problem might be already solved. The offer contains editorial rights for this: https://www.armbian.com/espressobin/ 0 Quote Link to comment Share on other sites More sharing options...
lampra Posted July 2, 2018 Share Posted July 2, 2018 On Armbian_5.50_Espressobin_Debian_stretch_next_4.17.3 (either clean install or upgrade) , there is an issue with the network when both lan ports are connected to the same router. This was not the case in the previous (5.44) image. Demsg is flooded with: br0: received packet on lan1 with own address as source address (addr:XX:XX:XX:XX:XX:XX, vlan:0) br0: received packet on lan0 with own address as source address (addr:XX:XX:XX:XX:XX:XX, vlan:0) and the bridge does not come up. By the way, has anyone any working bonding setup for lan0 & lan1? 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted July 3, 2018 Author Share Posted July 3, 2018 You're effectively introducing a layer2 switch loop when plugging them both in. It was mostly good fortune when it worked previously. Unfortunately because of the way the espressobin's onboard switch connects to the cpu (sgmi) peak network io to cpu would be 1 gig. There's dialog about the espressobin's network limitations earlier in the thread. Its kind of a bummer for sure. On Armbian_5.50_Espressobin_Debian_stretch_next_4.17.3 (either clean install or upgrade) , there is an issue with the network when both lan ports are connected to the same router. This was not the case in the previous (5.44) image. Demsg is flooded with:br0: received packet on lan1 with own address as source address (addr:XX:XX:XX:XX:XX:XX, vlan:0)br0: received packet on lan0 with own address as source address (addr:XX:XX:XX:XX:XX:XX, vlan:0) and the bridge does not come up. By the way, has anyone any working bonding setup for lan0 & lan1? Sent from my SM-G950U using Tapatalk 0 Quote Link to comment Share on other sites More sharing options...
Tazz Posted July 9, 2018 Share Posted July 9, 2018 For those who want to run at 1.2ghz, if you have not noticed you need this: https://marc.info/?l=linux-arm-kernel&m=152941191324122&w=2 2 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 9, 2018 Share Posted July 9, 2018 1 hour ago, Tazz said: For those who want to run at 1.2ghz, if you have not noticed you need this: https://marc.info/?l=linux-arm-kernel&m=152941191324122&w=2 apt update & upgrade will also do https://github.com/armbian/upload/commit/553477df85dfdd33810d1536409d62bd3a4cb789 Thanks. 2 Quote Link to comment Share on other sites More sharing options...
Tazz Posted July 9, 2018 Share Posted July 9, 2018 0 Quote Link to comment Share on other sites More sharing options...
y52 Posted July 10, 2018 Share Posted July 10, 2018 I've discovered more bugs in the current Armbian build, which, I believe, was inherited from Debian 9 and the network card buggy driver. 1) is related with the segmentation-offload, which is pretty well reproducible : root@espressobin:~# tcpdump -ni any -s100 -vvv port 53 27.49.62.17.52256 > 212.27.40.240.53: [bad udp cksum 0x5932 -> 0x332d!] 33775+% [1au] DS? akamaiedge.net. ar: . OPT UDPsize=4096 DO (43) 2) was very difficult to figure out, and the solution is not yet clear. It appears, that systemd-network is not properly handling the ipv4 and ipv6 renewals, which results in the wan network access failure periodically on the ISP ip lease renewal. It was very annoying and caused serious argues with the ISP support. The last working hypothesis is that the ipv6 Router Advertisement causes the networkd-[iface] service to fail and therefore the dhcpv4 client is killed too. 3) I also experienced the trouble with the wan interface automatic start up at boot time. Many experience it as well, which also looks to be a systemd-network trouble. It should work out of the box, but at the current state, the end-user has to adjust those setbacks with additional custom-made services or rc.local commads. 0 Quote Link to comment Share on other sites More sharing options...
y52 Posted July 10, 2018 Share Posted July 10, 2018 On 7/9/2018 at 7:18 PM, Igor said: For those who want to run at 1.2ghz, if you have not noticed you need this: https://marc.info/?l=linux-arm-kernel&m=152941191324122&w=2 apt update & upgrade will also do https://github.com/armbian/upload/commit/553477df85dfdd33810d1536409d62bd3a4cb789 This is quite encouraging to finally get the so much advertised CPU clocking. Has this patch been implemented to the legacy kernel as well? Should the u-boot flash be updated at the same time? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 11, 2018 Share Posted July 11, 2018 7 hours ago, y52 said: Has this patch been implemented to the legacy kernel as well? No. I am not sure we want to waste time with that kernel. Feel free to test and submit a patch. I can't. 7 hours ago, y52 said: Should the u-boot flash be updated at the same time? (correct) U-boot (for your board) should be updated in any case. 0 Quote Link to comment Share on other sites More sharing options...
y52 Posted July 11, 2018 Share Posted July 11, 2018 23 minutes ago, Igor said: >Has this patch been implemented to the legacy kernel as well? No. I am not sure we want to waste time with that kernel. Feel free to test and submit a patch. I can't. This is sad. My board just doesn't stay stable with the "-next" kernel, although I wanted to migrate to it. In my case, the board stability also depends significantly on the .dtb file as well. It appears, that the only stable configuration is the legacy kernel and the # DTB submitted by GlobalScaleTech. Stable. setenv fdt_name_a boot/dtb/marvell/armada-3720-community-v5.dtb # DTB submitted by Armbian. Unstable. #setenv fdt_name_a boot/dtb/marvell/armada-3720-community.dtb Anyway, I can still try the "-next" kernel again with the new patch. Should I understand it correctly, that the "1.2ghz" is already implemented in the "next tree" ? Pls confirm the algorithm to migrate from the legacy tree to the "next tree" under "1.2ghz". If I understand it, the following procedure should be applied: 1. apt update & upgrade with the current legacy 4.4.138-mvebu64 kernel 2. armbian-config -> system -> switch to alternative kernel -> next 3. 1200 Mhz u-boot flashing 4. reboot with 1200 Mhz CPU clock under the "next tree" kernel. Should anything else be done? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 11, 2018 Share Posted July 11, 2018 2 minutes ago, y52 said: This is sad. My board just doesn't stay stable with the "-next" kernel I am also sad, but for other reasons. Remember. This is not a professional support service and I need to save our resources to be able to work on things that make us happy. The same you need to do on a legacy kernel: https://github.com/armbian/build/commit/5823d40016d2fd522dba5f75af2ec14bfc6986a3 But implementation might be different and perhaps you will need to adjust patches. Then you need to build and test. One could lose an hour or a day. If you are unable to do this, hire someone. 8 minutes ago, y52 said: Should anything else be done? 1 & 2 yes 3 & 4 follow the procedure written at the download page. Flash u-boot with correct numbers. 1200Mhz tells me nothing at this point. Just don't go with higher numbers than what you have now and expect that the board will boot and be stable. 0 Quote Link to comment Share on other sites More sharing options...
Jens Bauer Posted July 14, 2018 Share Posted July 14, 2018 On 4/15/2018 at 7:11 PM, ebin-dev said: Debian server - mainline kernel - make sure you are on the stable branch and update your system with 'apt-get update && apt-get upgrade'. Using Ubuntu, I just found out during the last three days that if I do a fresh install of 5.50 on my EspressoBIN and as the first thing issue apt-get update && apt-get upgrade, followed by a reboot, then the network will never come up and I'll have to log in using a serial console. 0 Quote Link to comment Share on other sites More sharing options...
ebin-dev Posted July 14, 2018 Share Posted July 14, 2018 1 hour ago, Jens Bauer said: Using Ubuntu, I just found out during the last three days that if I do a fresh install of 5.50 on my EspressoBIN and as the first thing issue apt-get update && apt-get upgrade, followed by a reboot, then the network will never come up and I'll have to log in using a serial console. Do you have the same problem with Debian - mainline/stable ? If not - then the issue is very likely caused by the systemd-networkd implementation chosen by Ubuntu ... 0 Quote Link to comment Share on other sites More sharing options...
Jens Bauer Posted July 14, 2018 Share Posted July 14, 2018 5 hours ago, ebin-dev said: Do you have the same problem with Debian - mainline/stable ? If not - then the issue is very likely caused by the systemd-networkd implementation chosen by Ubuntu ... I haven't tried debian - and I do not have much time on my hand, because my server needs to be set up completely within a few days, as I'm going back home. Sadly, it seems the Ubuntu I'm running does not allow me to "reboot" without hanging, so I can't maintain much via SSH from home (because it'll cost me 6 hours to travel each way plus around $200, which I currently cannot afford). -I just thought I'd like to mention this, so that others will have fewer problems and the maintainers may know about it. 0 Quote Link to comment Share on other sites More sharing options...
Jens Bauer Posted July 14, 2018 Share Posted July 14, 2018 5 hours ago, ebin-dev said: Do you have the same problem with Debian - mainline/stable ? If not - then the issue is very likely caused by the systemd-networkd implementation chosen by Ubuntu ... Yesterday, I recorded the commands and the outputs ... Spoiler $ uname -a Linux espressobin 4.17.3-mvebu64 #7 SMP PREEMPT Thu Jun 28 18:21:11 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux # apt-get update ... (network is still alive) ... # reboot ... (network is still alive) ... # apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: apt apt-transport-https apt-utils cpp-5 dnsmasq-base g++-5 gcc-5 gcc-5-base libapt-inst2.0 libapt-pkg5.0 libasan2 libatomic1 libcc1-0 libgcc-5-dev libgomp1 libitm1 libpng12-0 libsoup2.4-1 libstdc++-5-dev libstdc++6 libubsan0 linux-dtb-next-mvebu64 linux-image-next-mvebu64 linux-libc-dev ntp rfkill 26 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 35.1 MB of archives. After this operation, 177 kB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://apt.armbian.com xenial/main arm64 linux-dtb-next-mvebu64 arm64 5.51 [9,844 B] Get:2 http://ports.ubuntu.com xenial-security/main arm64 libgomp1 arm64 5.4.0-6ubuntu1~16.04.10 [45.9 kB] Get:3 http://apt.armbian.com xenial/main arm64 linux-image-next-mvebu64 arm64 5.51 [13.8 MB] Get:4 http://ports.ubuntu.com xenial-security/main arm64 libitm1 arm64 5.4.0-6ubuntu1~16.04.10 [23.9 kB] Get:5 http://ports.ubuntu.com xenial-security/main arm64 libatomic1 arm64 5.4.0-6ubuntu1~16.04.10 [6,384 B] Get:6 http://ports.ubuntu.com xenial-security/main arm64 libasan2 arm64 5.4.0-6ubuntu1~16.04.10 [229 kB] Get:7 http://ports.ubuntu.com xenial-security/main arm64 libubsan0 arm64 5.4.0-6ubuntu1~16.04.10 [84.4 kB] Get:8 http://ports.ubuntu.com xenial-security/main arm64 g++-5 arm64 5.4.0-6ubuntu1~16.04.10 [4,928 kB] Get:9 http://ports.ubuntu.com xenial-security/main arm64 gcc-5 arm64 5.4.0-6ubuntu1~16.04.10 [5,278 kB] Get:10 http://ports.ubuntu.com xenial-security/main arm64 cpp-5 arm64 5.4.0-6ubuntu1~16.04.10 [4,537 kB] Get:11 http://ports.ubuntu.com xenial-security/main arm64 libcc1-0 arm64 5.4.0-6ubuntu1~16.04.10 [27.2 kB] Get:12 http://ports.ubuntu.com xenial-security/main arm64 libstdc++-5-dev arm64 5.4.0-6ubuntu1~16.04.10 [1,380 kB] Get:13 http://ports.ubuntu.com xenial-security/main arm64 libgcc-5-dev arm64 5.4.0-6ubuntu1~16.04.10 [490 kB] Get:14 http://ports.ubuntu.com xenial-security/main arm64 gcc-5-base arm64 5.4.0-6ubuntu1~16.04.10 [17.4 kB] Get:15 http://ports.ubuntu.com xenial-security/main arm64 libstdc++6 arm64 5.4.0-6ubuntu1~16.04.10 [362 kB] Get:16 http://ports.ubuntu.com xenial-updates/main arm64 libapt-pkg5.0 arm64 1.2.27 [652 kB] Get:17 http://ports.ubuntu.com xenial-updates/main arm64 libapt-inst2.0 arm64 1.2.27 [54.4 kB] Get:18 http://ports.ubuntu.com xenial-updates/main arm64 apt arm64 1.2.27 [1,017 kB] Get:19 http://ports.ubuntu.com xenial-updates/main arm64 apt-utils arm64 1.2.27 [188 kB] Get:20 http://ports.ubuntu.com xenial-security/main arm64 ntp arm64 1:4.2.8p4+dfsg-3ubuntu5.9 [465 kB] Get:21 http://ports.ubuntu.com xenial-security/main arm64 libpng12-0 arm64 1.2.54-1ubuntu1.1 [106 kB] Get:22 http://ports.ubuntu.com xenial-updates/main arm64 apt-transport-https arm64 1.2.27 [24.5 kB] Get:23 http://ports.ubuntu.com xenial-security/main arm64 dnsmasq-base arm64 2.75-1ubuntu0.16.04.5 [265 kB] Get:24 http://ports.ubuntu.com xenial-security/main arm64 libsoup2.4-1 arm64 2.52.2-1ubuntu0.3 [224 kB] Get:25 http://ports.ubuntu.com xenial-security/main arm64 linux-libc-dev arm64 4.4.0-130.156 [838 kB] Get:26 http://ports.ubuntu.com xenial-updates/main arm64 rfkill arm64 0.5-1ubuntu3.1 [8,374 B] Fetched 35.1 MB in 3s (9,688 kB/s) (Reading database ... 28772 files and directories currently installed.) Preparing to unpack .../libgomp1_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libgomp1:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libitm1_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libitm1:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libatomic1_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libatomic1:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libasan2_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libasan2:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libubsan0_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libubsan0:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../g++-5_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking g++-5 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../gcc-5_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking gcc-5 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../cpp-5_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking cpp-5 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libcc1-0_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libcc1-0:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libstdc++-5-dev_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libstdc++-5-dev:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../libgcc-5-dev_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libgcc-5-dev:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Preparing to unpack .../gcc-5-base_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking gcc-5-base:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for man-db (2.7.5-1) ... Setting up gcc-5-base:arm64 (5.4.0-6ubuntu1~16.04.10) ... (Reading database ... 28772 files and directories currently installed.) Preparing to unpack .../libstdc++6_5.4.0-6ubuntu1~16.04.10_arm64.deb ... Unpacking libstdc++6:arm64 (5.4.0-6ubuntu1~16.04.10) over (5.4.0-6ubuntu1~16.04.9) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libstdc++6:arm64 (5.4.0-6ubuntu1~16.04.10) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 28772 files and directories currently installed.) Preparing to unpack .../libapt-pkg5.0_1.2.27_arm64.deb ... Unpacking libapt-pkg5.0:arm64 (1.2.27) over (1.2.26) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Setting up libapt-pkg5.0:arm64 (1.2.27) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 28772 files and directories currently installed.) Preparing to unpack .../libapt-inst2.0_1.2.27_arm64.deb ... Unpacking libapt-inst2.0:arm64 (1.2.27) over (1.2.26) ... Preparing to unpack .../archives/apt_1.2.27_arm64.deb ... Unpacking apt (1.2.27) over (1.2.26) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for man-db (2.7.5-1) ... Setting up apt (1.2.27) ... Installing new version of config file /etc/apt/apt.conf.d/01autoremove ... Processing triggers for libc-bin (2.23-0ubuntu10) ... (Reading database ... 28772 files and directories currently installed.) Preparing to unpack .../apt-utils_1.2.27_arm64.deb ... Unpacking apt-utils (1.2.27) over (1.2.26) ... Preparing to unpack .../ntp_1%3a4.2.8p4+dfsg-3ubuntu5.9_arm64.deb ... Unpacking ntp (1:4.2.8p4+dfsg-3ubuntu5.9) over (1:4.2.8p4+dfsg-3ubuntu5.8) ... Preparing to unpack .../libpng12-0_1.2.54-1ubuntu1.1_arm64.deb ... Unpacking libpng12-0:arm64 (1.2.54-1ubuntu1.1) over (1.2.54-1ubuntu1) ... Preparing to unpack .../apt-transport-https_1.2.27_arm64.deb ... Unpacking apt-transport-https (1.2.27) over (1.2.26) ... Preparing to unpack .../dnsmasq-base_2.75-1ubuntu0.16.04.5_arm64.deb ... Unpacking dnsmasq-base (2.75-1ubuntu0.16.04.5) over (2.75-1ubuntu0.16.04.4) ... Preparing to unpack .../libsoup2.4-1_2.52.2-1ubuntu0.3_arm64.deb ... Unpacking libsoup2.4-1:arm64 (2.52.2-1ubuntu0.3) over (2.52.2-1ubuntu0.2) ... Preparing to unpack .../linux-dtb-next-mvebu64_5.51_arm64.deb ... Unpacking linux-dtb-next-mvebu64 (5.51) over (5.50) ... Preparing to unpack .../linux-image-next-mvebu64_5.51_arm64.deb ... update-initramfs: Deleting /boot/initrd.img-4.17.3-mvebu64 Removing obsolete file uInitrd-4.17.3-mvebu64 Unpacking linux-image-next-mvebu64 (5.51) over (5.50) ... Preparing to unpack .../linux-libc-dev_4.4.0-130.156_arm64.deb ... Unpacking linux-libc-dev:arm64 (4.4.0-130.156) over (4.4.0-128.154) ... Preparing to unpack .../rfkill_0.5-1ubuntu3.1_arm64.deb ... Unpacking rfkill (0.5-1ubuntu3.1) over (0.5-1ubuntu3) ... Processing triggers for man-db (2.7.5-1) ... Processing triggers for systemd (229-4ubuntu21.2) ... Processing triggers for ureadahead (0.100.0-19) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... Processing triggers for dbus (1.10.6-1ubuntu3.3) ... Setting up libgomp1:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up libitm1:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up libatomic1:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up libasan2:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up libubsan0:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up cpp-5 (5.4.0-6ubuntu1~16.04.10) ... Setting up libcc1-0:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up libgcc-5-dev:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up gcc-5 (5.4.0-6ubuntu1~16.04.10) ... Setting up libstdc++-5-dev:arm64 (5.4.0-6ubuntu1~16.04.10) ... Setting up g++-5 (5.4.0-6ubuntu1~16.04.10) ... Setting up libapt-inst2.0:arm64 (1.2.27) ... Setting up apt-utils (1.2.27) ... Setting up ntp (1:4.2.8p4+dfsg-3ubuntu5.9) ... Setting up libpng12-0:arm64 (1.2.54-1ubuntu1.1) ... Setting up apt-transport-https (1.2.27) ... Setting up dnsmasq-base (2.75-1ubuntu0.16.04.5) ... Setting up libsoup2.4-1:arm64 (2.52.2-1ubuntu0.3) ... Setting up linux-dtb-next-mvebu64 (5.51) ... Setting up linux-image-next-mvebu64 (5.51) ... update-initramfs: Generating /boot/initrd.img-4.17.5-mvebu64 update-initramfs: Converting to u-boot format Setting up linux-libc-dev:arm64 (4.4.0-130.156) ... Setting up rfkill (0.5-1ubuntu3.1) ... Processing triggers for libc-bin (2.23-0ubuntu10) ... ... (network is still alive) ... # ifconfig -a | grep addr bond0 Link encap:Ethernet HWaddr 8e:60:4a:5a:7b:5b br0 Link encap:Ethernet HWaddr ca:cb:1d:1d:a2:c3 inet addr:10.0.2.202 Bcast:10.0.255.255 Mask:255.255.0.0 inet6 addr: fe80::c8cb:1dff:fe1d:a2c3/64 Scope:Link dummy0 Link encap:Ethernet HWaddr 7a:1f:6e:9b:f7:ef eth0 Link encap:Ethernet HWaddr f0:ad:4e:03:64:7f inet6 addr: fe80::f2ad:4eff:fe03:647f/64 Scope:Link lan0 Link encap:Ethernet HWaddr f0:ad:4e:03:64:7f lan1 Link encap:Ethernet HWaddr f0:ad:4e:03:64:7f inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host wan Link encap:Ethernet HWaddr f0:ad:4e:03:64:7f ... (network is still alive) ... # reboot ... (network never comes online, I have to log in via serial console and re-install armbian) ... $ uname -a Linux espressobin 4.17.3-mvebu64 #7 SMP PREEMPT Thu Jun 28 18:21:11 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux -All I can see about systemd is 'processing triggers for systemd', so I'm not sure systemd is at fault directly. I can see a lot of library updates, so I would expect that this could be caused by an updated library that systemd is using. -only a simple guess, though. 0 Quote Link to comment Share on other sites More sharing options...
y52 Posted July 14, 2018 Share Posted July 14, 2018 6 hours ago, Jens Bauer said: the issue is very likely caused by the systemd-networkd implementation systemd remains quite buggy. I try finding workarounds for it's different issues. I suggest modifying as follows the /lib/systemd/system/systemd-networkd.service [Service] Type=notify Restart=on-failure RestartSec=0 # https://www.toradex.com/community/questions/1144/weird-behavior-when-restarting-networkd.html ExecStartPre=/sbin/ip addr flush dev wan ExecStartPre=/sbin/ip link set wan down ExecStartPre=/sbin/ip link set wan up ExecStart=!!/lib/systemd/systemd-networkd There is also a bad behavior in inability acquiring the DHCPv6 lease when hot restarting the systemd-networkd without rebooting. Where could kernel configs (for mainline and legacy trees) be found to double check if the following settings are similar as below ? -# CONFIG_IPV6_MULTIPLE_TABLES is not set +CONFIG_IPV6_MULTIPLE_TABLES=y -# CONFIG_IPV6_MROUTE_MULTIPLE_TABLES is not set +CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y 0 Quote Link to comment Share on other sites More sharing options...
lampra Posted July 17, 2018 Share Posted July 17, 2018 Am I missing something? I tried to install wireguard in the prebuild images but i failed using the linux-headers-next-mvebu64 package. Today I compiled a mainline image with headers installed but I still fail to install wireguard. Here is the log Spoiler root@espressobin:cat /var/lib/dkms/wireguard/0.0.20180708-1/build/make.log DKMS make.log for wireguard-0.0.20180708-1 for kernel 4.17.7-mvebu64 (aarch64) Τετ 18 Ιούλ 2018 02:22:32 πμ EEST make: Entering directory '/usr/src/linux-headers-4.17.7-mvebu64' Makefile:637: arch//Makefile: No such file or directory make: *** No rule to make target 'arch//Makefile'. Stop. make: Leaving directory '/usr/src/linux-headers-4.17.7-mvebu64' I have read in this that we need to call make scripts. Here is the output Spoiler root@espressobin:/usr/src/linux-headers-4.17.7-mvebu64# make scripts CHK scripts/mod/devicetable-offsets.h root@espressobin:/usr/src/linux-headers-4.17.7-mvebu64# make prepare scripts CHK include/config/kernel.release UPD include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h UPD include/generated/utsrelease.h scripts/Kbuild.include:103: warning: overriding recipe for target '.cache.mk' scripts/Kbuild.include:103: warning: ignoring old recipe for target '.cache.mk' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/gettimeofday.S', needed by 'arch/arm64/kernel/vdso/gettimeofday.o'. Stop. arch/arm64/Makefile:163: recipe for target 'vdso_prepare' failed make: *** [vdso_prepare] Error 2 Edit: Diagnostics 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 18, 2018 Share Posted July 18, 2018 Try without DKMS.Wrote on mobile 0 Quote Link to comment Share on other sites More sharing options...
lampra Posted July 18, 2018 Share Posted July 18, 2018 9 hours ago, Igor said: Try without DKMS. Compilation from source also not working: Spoiler dlaptop@espressobin:~/Downloads/WireGuard/src$ make debug test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \ echo >&2; \ echo >&2 " ERROR: Kernel configuration is invalid."; \ echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\ echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; root@espressobin:/usr/src/linux-headers-4.17.7-mvebu64# make oldconfig && make prepare scripts/kconfig/conf --oldconfig Kconfig # # configuration written to .config # scripts/kconfig/conf --syncconfig Kconfig CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h scripts/Kbuild.include:103: warning: overriding recipe for target '.cache.mk' scripts/Kbuild.include:103: warning: ignoring old recipe for target '.cache.mk' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/gettimeofday.S', needed by 'arch/arm64/kernel/vdso/gettimeofday.o'. Stop. arch/arm64/Makefile:163: recipe for target 'vdso_prepare' failed make: *** [vdso_prepare] Error 2 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted July 18, 2018 Share Posted July 18, 2018 3 minutes ago, lampra said: Compilation from source also not working: Headers are not source. We pack kernel source but don't upload it to the repository due to space limits. So far I don't see any problem on Armbian side except DKMS might be broken ... but that is not essential to compile a module. 0 Quote Link to comment Share on other sites More sharing options...
lampra Posted July 18, 2018 Share Posted July 18, 2018 3 minutes ago, Igor said: Headers are not source. We pack kernel source but don't upload it to the repository due to space limits. So far I don't see any problem on Armbian side except DKMS might be broken ... but that is not essential to compile a module. Well the module is compiled and installation finishes but when I am trying to use wireguard it fails and the output seems to point to wrong or missing kernel headers # wg-quick up wg0 [#] ip link add wg0 type wireguard RTNETLINK answers: Operation not supported Unable to access interface: Protocol not supported What i noticed is that after installation, a new folder is created in /lib/modules/ where wireguard.ko is placed $ ls /lib/modules/ 4.17.7 4.17.7-mvebu64 $ ls /lib/modules/4.17.7/extra/ wireguard.ko 0 Quote Link to comment Share on other sites More sharing options...
