Mickynuts Posted October 1, 2024 Posted October 1, 2024 (edited) Hello, sorry for the tag (no odroid m1 tag) and if I'm in the wrong place. I downloaded the image Armbian_24.8.3_ordoidm1_jammy_current_6.6.51_kde-neon-kisak-desktop The image does not start without pressing rcy, so far normal. After flashing the mtd with armbian-installer and copying to SSD. The image still does not start. No display. After trying several things and without success, I decided to try an old image: Armbian_24.2.1_ordoidm1_jammy_current_6.6.16_xfce_desktop. I here rcy boot, install, copy to SSD, flash mtd and reboot. And it works. So I tried image 6.6.51 kde Again. But without flashing the mtd. And there it boots without problems and no need for rcy. So it seems that the last image and also the 24.2. 4 that I tried. We have a probably corrupted uboot. I have the odroid m1 8gb. I hope this will allow others not to waste hours trying because of a corrupted uboot. (This was my first attempt with armbian on this card. Before I had petitboot.) Sorry for my bad English. I used Google translate. PS: I tried to make a bug report form. But you have to provide an armbianmonitor -u output or something like that. And that doesn't match the fact. The card doesn't even boot. Edited October 1, 2024 by Mickynuts 0 Quote
usual user Posted October 1, 2024 Posted October 1, 2024 6 hours ago, Mickynuts said: I tried to make a bug report form. But you have to provide an armbianmonitor -u output or something like that. And that doesn't match the fact. The card doesn't even boot. To get help, you have to provide proper logs. In case of boot problems, these are serial console logs. https://debug.armbian.de 0 Quote
Solution Mickynuts Posted October 1, 2024 Author Solution Posted October 1, 2024 29 minutes ago, usual user said: To get help, you have to provide proper logs. In case of boot problems, these are serial console logs. I don't need help anymore. As said. I used the uboot present in an earlier version. I didn't try the serial, because there weren't even any screens (I thought there wouldn't be a serial either). The card seemed to just do a reboot Every 5 seconds (depending on the LEDs on the network card and the LEDs on the SSD which flash 1x. I'm not going to try again now that I have a working installation. I just wanted to share with you Other beginners who are not used to this kind of tools and not have the serial cable. 0 Quote
usual user Posted October 1, 2024 Posted October 1, 2024 (edited) On 10/1/2024 at 9:06 PM, Mickynuts said: I don't need help anymore. As said. I used the uboot present in an earlier version. Ok, then no further action needs to be taken and your solution can be used by others in the future. I also don't need any other firmware because my current one works according to my needs. And for an update, I know how to build and debug it if necessary. In the meantime, I've moved to 2025.01 with HDMI support enabled, so I no longer need the serial console to interact with the firmware. And boot menus easily allow the free choice of which option should currently be booted. Edited January 19, 2025 by usual user 0 Quote
iav Posted January 29, 2025 Posted January 29, 2025 I did kind of manual bisect by commits to config/boards/odroidm1.conf U-Boot 2024.04-armbian (Jan 29 2025 - 02:13:41 +0000) commit 3215bf9f3699c2ee4bc741efe82065315e4ff46f linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.04-S2504-P3b44-Haddb-V73be-B4f92-R448a.deb is GOOD, U-Boot 2024.07-armbian-2024.07-S3f77-P7e9c-Hfb3e-V8f4f-Bb66d-R448a (Jan 29 2025 - 02:30:21 +0000) commit 268c2e85960978c90025bc18cf7d5f8e5cfbdab6 linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.07-S3f77-P7e9c-Hfb3e-V8f4f-Bb66d-R448a.deb is BAD then I fix my Odroid M1 by doing sudo apt install ./linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.04-S2504-P3b44-Haddb-V73be-B4f92-R448a.deb then armbian-install → Install/Update the bootloader on MTD Flash 0 Quote
usual user Posted January 29, 2025 Posted January 29, 2025 Ok, judging by your information, the regression takes place during the transition from U-Boot 2024.04 to 2024.07. Since mainline U-Boot works perfect for me up to until 2025.01, it must be because of how it's built or what additional patches are applied. Since it cannot be ruled out that it is due to a incompatible bootflow, it may be interesting to try it with my build. If this also fails, it is possible to get more information from the HDMI output, even if access to the serial console is not available. For the test it is perfectly sufficient to start the firmware from a prepared microSD card via RCY button. The existing setup can stay completely unchanged. 0 Quote
antatarmbian Posted February 27, 2025 Posted February 27, 2025 I installed v2025.2.2 on sdcard and then performed armbian-install boot from spi + system on nvme. Without any error-messages system could afterwards not be booted without sdcard inserted. I assume I could remedy the situation with the linux-u-boot-odroidm1-edge_24.8.0-trunk_arm64__2024.04-S2504-P3b44-Haddb-V73be-B4f92-R448a.deb mentioned above and wonder, if anybody could provide that. 0 Quote
Mickynuts Posted February 28, 2025 Author Posted February 28, 2025 11 hours ago, antatarmbian said: if anybody could provide that I searched without finding. Did you try to do as I did. By flashing a uboot of a previous version via an old image? 0 Quote
antatarmbian Posted February 28, 2025 Posted February 28, 2025 if I look into the archive for older Versions https://armbian.atomonetworks.com/archive/odroidm1/archive/ then the oldest Version is 24.8.1, which to my knowledge is too new 0 Quote
Werner Posted February 28, 2025 Posted February 28, 2025 There is also oldarchive: https://fi.mirror.armbian.de/oldarchive/odroidm1/archive/ 0 Quote
antatarmbian Posted February 28, 2025 Posted February 28, 2025 (edited) Hmm.. after Werner's hint I used Armbian_24.2.1_Odroidm1_jammy_current_6.6.16.img.xz from oldarchive but after armbian-install → Install/Update the bootloader on MTD Flash no change of behavior, i.e. system does not boot without sd-card inserted. I did not perform Boot from MTD flash - system on Sata ... again, since the desired system is already on nvme. Just for clarification: is my expectation correct, that system should boot without sd-card inserted (since bootloader is in MTD-flash), or is the effect of flashing MTD merely, that the system can use the bootloader of the sd-card without pressing RCY button? Although I ordered a usb-serial adapter in order to be able to debug the situation, I would very much appreciate if the bootmenu could appear on hdmi Console - I wonder how this could be achieved - what build does Usual User refer to with "my build"? Edited February 28, 2025 by antatarmbian 0 Quote
Mickynuts Posted February 28, 2025 Author Posted February 28, 2025 (edited) 58 minutes ago, antatarmbian said: clarification Yes no need to rcy normally. I took out the info from my m1 and a copy with cat of the mtd partitions. Maybe it will be useful to you (at your own risk) Maybe wait for a confirmation if the command I made is functional. I made a backup of the partitions with cat /dev/mtd* > name.bin (once for each partition) In info you will find what I have as version and kernel. If it can help you. Moderator, the 16mb overall is too heavy to insert directly (error uploading). I hope the cloud link is not a problem here. (valid for 48 hours) https://quickshare.samsungcloud.com/cu9Cj7XDCZwy Edited February 28, 2025 by Mickynuts 0 Quote
Werner Posted February 28, 2025 Posted February 28, 2025 1 hour ago, antatarmbian said: bootmenu could appear on hdmi Console Having HDMI or video output work in U-Boot is more an exception rather than standard. While I don't know the reason I guess it is just too much effort to port such drivers into U-Boot while using the debug serial console is dirt cheap and always works. 0 Quote
usual user Posted February 28, 2025 Posted February 28, 2025 5 hours ago, antatarmbian said: what build does Usual User refer to with "my build"? This one. 0 Quote
antatarmbian Posted March 1, 2025 Posted March 1, 2025 (edited) Thanks - now I get the booloader menu from SPI on hdmi Console. I wanted to experiment with efi-grub boot and installed the following image on sd https://dl.armbian.com/uefi-arm64/Bookworm_current_cinnamon-backported-mesa and it boots without problem, showing the grub-menu. I then did armbian-install -> nvme01 Install UEFI system with grub to transfer system + /boot/efi to nvme. But still I cannot boot the system after removing the sd-card. the bootloader says sth like nvme 0 no img found. So as workaround I performed an update-grub, so that at least the option to boot the system on nvme appears (and works) in sdcard grub-menu. Any hint how I can render the nvme directly bootable from spi bootloader menu without the sdcard? Edited March 1, 2025 by antatarmbian 0 Quote
usual user Posted March 2, 2025 Posted March 2, 2025 8 hours ago, antatarmbian said: But still I cannot boot the system after removing the sd-card. EXIT to the U-Boot console and report the output of the following command: bootflow scan -l nvme 8 hours ago, antatarmbian said: I then did armbian-install -> nvme01 Install UEFI system I don't know what the armbian-install does, but does it make a difference if you dd the same unmodified image to the NVME as you do to the microSD? 0 Quote
antatarmbian Posted March 2, 2025 Posted March 2, 2025 via dd img->nvme did the trick. One slight problem is the identical uuids of sdcard and nvme but it does not make much sense anyway to use identical images on 2 devices plugged in at the same time. Next step now will be populating the nvme with additional images so thanks a lot for your helping hands 0 Quote
m1zfs Posted January 6 Posted January 6 # cat /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both extraargs=cma=256M overlay_prefix=rockchip-rk3568-hk fdtfile=rockchip/rk3568-odroid-m1.dtb rootdev=UUID=0a9f09a7-bbb5-493f-a7af-b0e62f4aff8e rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u It seems the UUID can be changed in `/boot/armbianEnv.txt`. 0 Quote
Igor Posted January 6 Posted January 6 Current way of installing is as written on the download pages. It was verified with latest v24.11.2 image. 0 Quote
m1zfs Posted Saturday at 11:51 AM Posted Saturday at 11:51 AM (edited) I can confirm that booting Odroid M1 from SD card does not work with U-Boot versions newer than 2024.04. Many thanks to IAV for providing a workaround. Perhaps most people are booting from NVMe now, so this issue has flown under the radar? # Install U-Boot 24.5.1 (maps to upstream v2024.04) apt-get install -y linux-u-boot-odroidm1-edge=24.5.1 # Freeze the package at that version "printf 'linux-u-boot-odroidm1-edge hold\n' | sudo dpkg --set-selections" # Flash SPI directly from the package artifacts (or via armbian-install) flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img /dev/mtd0 flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb /dev/mtd2 # Confirm strings /dev/mtd0 | grep -m1 "U-Boot" # U-Boot SPL 2024.04 (Jan 10 2026 - 10:54:44 +0100) strings /dev/mtd2 | grep -m1 "U-Boot" # FIT image for U-Boot with bl31 (TF-A) Now I can boot from sdcard again w/o RCY button. To use only ZFS on my system I compiled zfs into U-Boot. That worked but the problem was still with U-Boot's handling of the mmc1 somehow. Even though zfsls/zfsload were present in the SPI-flashed U-Boot, that build immediately reinitialized mmc1 in HS200 (1.8 V) mode and hit the “Card did not respond to voltage select! : -110” failure before the boot script could run. So the inability to boot the ZFS v28 pool was due to the SPI U-Boot’s bad MMC tuning, not the ZFS commands themselves. For future reference I’ll leave here on how to built U-Boot with ZFS support from the upstream sources: # Workspace & Dependencies apt install git gcc-aarch64-linux-gnu bison flex device-tree-compiler libssl-dev make python3 ninja-build build-essential mkdir -p ~/work/u-boot && cd ~/work/u-boot # Upstream U-Boot git clone --depth=1 --branch v2024.04 https://source.denx.de/u-boot/u-boot.git # Firmare blobs git clone --depth=1 https://github.com/rockchip-linux/rkbin.git # Prepare .config cd u-boot cp configs/odroid-m1-rk3568_defconfig .config scripts/config --file .config --enable CONFIG_CMD_ZFS yes "" | olddefconfig # Compile make -j$(nproc) \ BL31=../rkbin/bin/rk35/rk3568_bl31_v1.45.elf \ ROCKCHIP_TPL=../rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.23.bin # Flash SPI directly from the package artifacts (or via armbian-install) cp spl/u-boot-spl.bin /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img cp u-boot.itb /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/idbloader.img /dev/mtd0 flashcp -v /usr/lib/linux-u-boot-edge-odroidm1/u-boot.itb /dev/mtd2 Edited Saturday at 12:38 PM by m1zfs 1 Quote
