Using Armbian 5.30 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i
Linux orangepipc 3.4.113-sun8i #16 SMP PREEMPT Tue Jun 13 14:15:57 CEST 2017 armv7l armv7l armv7l GNU/Linux
Just updated my chromium from the pre-installed version 58.0.3029.110-0ubuntu0.16.04.1281 which worked fine to 59.0.3071.109-0ubuntu0.16.04.1289 which fails to start for some reason. You can see the window open up for a brief moment, then it crashes with the following error:
Received signal 4 <unknown> 0000b472df76
#0 0x0000b5381d12 base::debug::StackTrace::StackTrace()
#1 0x0000b5381952 base::debug::StackTrace::StackTrace()
#2 0x0000b5381ffc <unknown>
#3 0x0000b0783270 <unknown>
[end of stack trace]
Calling _exit(1). Core file will not be generated.
Received signal 4 <unknown> 0000b475ff76
#0 0x0000b53b3d12 base::debug::StackTrace::StackTrace()
#1 0x0000b53b3952 base::debug::StackTrace::StackTrace()
#2 0x0000b53b3ffc <unknown>
#3 0x0000b07b5270 <unknown>
can you reproduce the error in a fresh build?? if not then it is not a software issue (bad sd card???)
reproduce the error on a fresh build using another GOOD sd card.
if you can reproduce the error, post logs, make of sd card, make of psu...so on
give the folks here the help they need to help you.
Chromium for ARM has history of instability and lately it was working quite OK which was one of points that we start using it. I doubt it's related to any changes within Armbian. First we need to reproduce this error on other builds: Pine64, C2, ... than if the problem manifest there to, contact package maintainer. We don't have any intention or resources to fix Chromium bugs.
If this is so, I would suggest rolling this package back or upgrade to fixed version when available.
I have the same problem,
on the fresh Armbian the chrome-browser works OK
but after the apt update && apt upgrade I can't start chromium anymore
tested on OPI PC+ and on OPI Zero Plus H3
any clue how to do this "rolling back"?
thx
Yes, I actually reported the problem only after doing a fresh install on another card first. So vanilla Armbian_5.30_Orangepipc_Ubuntu_xenial_default_3.4.113_desktop.img with single updated package as stated above.
Sure thing. What logs do you need, specifically? Nothing in syslog or systemd journal though. I'm not aware of any logging done by chromium, but I'm sure you can point me in the right direction there.
For the actual error message, see above. Card is a 16GB Sandisk Ultra UHC-I card I took from another SBC. PSU is the old Xunlong 3A one.
How so? Apt-get tells me
E: Version '58.0.3029.110-0ubuntu0.16.04.1281' for 'chromium-browser' was not found
I'm running a fairly fresh install of the desktop version of Armbian for the tinkerboard, and I'm running into a problem launching chromium-browser.  I have successfully downloaded and installed Firefox, but chromium is still defeating me. If I try to launch from the terminal I get;
nick@tinkerboard:~$ chromium-browser
[4393:4435:0707/193722.332119:ERROR:data_store_impl.cc(131)] Failed to open Data Reduction Proxy DB: 3
[4393:4428:0707/193722.500948:ERROR:zygote_host_impl_linux.cc(254)] Failed to adjust OOM score of renderer with pid 4451: Permission denied
Received signal 4 <unknown> 0000b6243f76
#0 0x0000b6e97d12 base::debug::StackTrace::StackTrace()
#1 0x0000b6e97952 base::debug::StackTrace::StackTrace()
#2 0x0000b6e97ffc <unknown>
#3 0x0000b228c270 <unknown>
[4393:4428:0707/193722.881072:ERROR:zygote_host_impl_linux.cc(254)] Failed to adjust OOM score of renderer with pid 4464: Permission denied
[4449:4449:0707/193724.605459:ERROR:sandbox_linux.cc(343)] InitializeSandbox() called with multiple threads in process gpu-process.
[4393:4430:0707/193724.616051:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[4393:4430:0707/193724.616265:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[4393:4430:0707/193724.616399:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[4393:4430:0707/193724.616523:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
[4393:4430:0707/193724.616663:ERROR:browser_gpu_channel_host_factory.cc(103)] Failed to launch GPU process.
Received signal 4 <unknown> 0000b627af76
#0 0x0000b6eced12 base::debug::StackTrace::StackTrace()
#1 0x0000b6ece952 base::debug::StackTrace::StackTrace()
#2 0x0000b6eceffc <unknown>
#3 0x0000b22c3270 <unknown>
Background -
- I have been running an very old version of Armbian for tinkerboard which I downloaded from a nightly several months ago. That also failed to run chromium, but I didn't attempt to launch it from the terminal.
- Tinkerboard is powered from the gpio pins
- This build installed today using etcher to a good quality microSD. The image was downloaded via a torrent a week ago.
I'm not very good at diagnosis and fixing, but can follow instructions if more information is needed.
Thanks for reading.
I have confirmed the issue, the window attempts to render then crashes to desktop on 4.12.
Which kernel are you running?
nick@tinkerboard:~$ uname -a
Linux tinkerboard 4.4.73-rockchip #10 SMP Fri Jun 23 20:34:42 CEST 2017 armv7l armv7l armv7l GNU/Linux
It is definitely problem in the new chromium.
But no fix/solution so far. The workaround that I'm using:
1. on the fresh armbian before apt update && apt upgrade
2. sudo apt install synaptic
3. in synaptic lock the current chromium version (58.0.3029.110-0ubuntu0.16.04.1281)
4. apt update && apt upgrade
So there's no way to downgrade once you have the broken version?
$ sudo apt-get install chromium-browser=58.0.3029.110-0ubuntu0.16.04.1281
Do you have to change apt repositories for that to work?
You can download the older deb
http://launchpadlibrarian.net/319181475/chromium-browser_58.0.3029.110-0ubuntu0.14.04.1176_armhf.deb
But it also requires the exact chromium-codecs-ffmpeg-extra package
I did somehting along the lines of this...
sudo apt remove chromium-browser
mkdir tempforinstall
cd tempforinstall
wget http://launchpadlibrarian.net/319181475/chromium-browser_58.0.3029.110-0ubuntu0.14.04.1176_armhf.deb
wget http://launchpadlibrarian.net/319181477/chromium-codecs-ffmpeg-extra_58.0.3029.110-0ubuntu0.14.04.1176_armhf.deb
sudo dpkg -i *.deb
sudo -s
echo chromium-browser hold | dpkg --set-selections
This removes the 59 version, downloads 58 versions, installs them and then locks the browser so it doesn't get upgraded. I'm sure someone could do this in less lines but it worked for me.
I don't get the Lock option in synaptic for some reason.
From the Ubuntu forum...
1) Start Chromium on the command line with:
chromium-browser --disable-extensions
2) Type this into the address bar of Chromium:
chrome://flags
3) Press ctrl-F and Search for "media router", then set it to "Disabled".
Source: Ubuntu Bug 1702407 | Comment 19.
This bug was fixed in the package chromium-browser - 59.0.3071.109-0ubuntu0.16.04.1291
chromium-browser (59.0.3071.109-0ubuntu0.16.04.1291) xenial; urgency=medium
  * debian/patches/fix-argument-evaluation-order.patch: added (LP: #1702407)
 -- Olivier Tilloy <email address hidden> Fri, 07 Jul 2017 10:53:25 +0200
Friends, I downloaded the latest version of Armbian for Orange Pi Plus 2E desktop version 5.30, did the whole installation procedure without update and everything was working. I did an update and Chromium does not work anymore it tries to open and close. I upgraded to version 5.31 and continue with the same problem. Does anyone know what's going on?
Rob Tieger's solution works - i tried it, and now chromium works with no problem.  The next post says the bug was fixed, but i have not tried that yet.  If anyone else knows that is true, let me know.   if this is the latest then the others who had the problem wouldn't have!
cd tempforinstall
sudo dpkg -i *.deb
sudo -s
  • Igor unpinned this topic
