btw. how can I delete one of my posts (like this one)?
Ask a moderator to delete
Sent from my iPad using Tapatalk
12 hours ago, M@rtin said:
debian runs stable
There is no Debian for this board: https://www.google.com/search?q=site.www.debian.org+bananapi+m3 Kernel 3.4.38 that is glued to Debian rootfs by Banana people stable? Hmm ... will not discus that ;)
I heard, that for many read/write processes a sd-card is not the best media (only seen from hardware-side). That's why I changed from raspbian to bananapi.
Saving your SD card is a stock feature of Armbian and can also be implemented on Raspberry Pi / Raspbian.
Best would be a singleboard-computer with a native ssd slot
https://www.armbian.com/nanopc-t4/
Images are the same on all but each board has different boot loader, kernel and optimization package. We also have a difference between 32 and 64bit package base. But for end user Armbian is the same on all boards.
Hi Igor,
I only knew the RockPi 4 and wondered about the strange mounting option for the SSD (by cable and an extra board). The NanoPC-T4 looks great. I'll order it and try it out. Thanks so much.
8 hours ago, Shadow3561 said:
is it possible to get 1wire over gpio to run with the m3 and armbian?
Did you try adding "w1-gpio" overlay along with it "param_w1_pin" parameter in /boot/armbianEnv.txt ?
Yes.
My armbianEnv.txt look so
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-a83t
rootdev=UUID=180fa47b-6f2e-4289-9297-a0ffd4752601
rootfstype=ext4
overlays=w1-gpio
param_w1_pin=PH20
param_w1_pin_int_pullup=1
but has no effect.
lsmod doesnt show any w1 module.
I also have edited the sun8i-a83t-bananapi-m3.dtb and paste
w1_pins: w1_pins {
allwinner,pins = "PH10";
allwinner,function = "gpio_in"; // in (initially)
allwinner,pull = <0>; // off };
and
w1: onewire@0 {
compatible = "w1-gpio";
pinctrl-names = "default";
pinctrl-0 = <&w1_pins>;
gpios = <&pio 3 10 0>; // PH10
status = "okay"; };
this also have no effect
I think the reason is that there is no overlays with that prefix ...
Just to give it a try, change this to "overlay_prefix=sun8i-h3" !
unfortunately no success
root@bananapim3:/sys/bus/w1/devices# dmesg | grep w1
[    6.072060] w1-gpio onewire@0: gpio_request (pin) failed
[    6.072150] w1-gpio: probe of onewire@0 failed with error -22
i have modified another overlayfile to that
/dts-v1/;
    compatible = "allwinner,sun8i-a83t";
    fragment@0 {
        target = <0xffffffff>;
        __overlay__ {
            w1_pins {
                pins = "PL10";
                phandle = <0x1>;
    fragment@1 {
        target-path = [2f 00];
        __overlay__ {
            onewire@0 {
                pinctrl-0 = <0x1>;
                gpios = <0xffffffff 0x8 0xf 0x0>;
                status = "okay";
    __symbols__ {
        w1_pins = "/fragment@0/__overlay__/w1_pins";
    __fixups__ {
        pio = "/fragment@0:target:0", "/fragment@1/__overlay__/onewire@0:gpios:0";
    __local_fixups__ {
        fragment@1 {
            __overlay__ {
                onewire@0 {
                    pinctrl-0 = <0x0>;
then the output of  dmesg | grep w1 is
root@bananapim3:~# dmesg | grep w1
[    8.324815] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
and  cat /sys/kernel/debug/gpio shows me
gpiochip1: GPIOs 0-255, parent: platform/1c20800.pinctrl, 1c20800.pinctrl:
 gpio-120 (                    |usb1-vbus           ) out hi
 gpio-166 (                    |cd                  ) in  lo
 gpio-234 (                    |soc:onewire@0       ) in  hi
gpiochip0: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl:
gpiochip2: GPIOs 414-415, parent: platform/axp20x-gpio, axp20x-gpio, can sleep:
 gpio-414 (                    |bananapi-m3:green:us) out lo
 gpio-415 (                    |bananapi-m3:blue:usr) out lo
in the device/tree of w1 i have devices like 00-400000000000  00-c00000000000  w1_bus_master1
but the device numbers changes every minute
Try adding an external pull-up and/or try another GPIO instead of PL10
The result is the same as above.
Are you sure it was connected to proper GPIO ?
Try "cat /sys/kernel/debug/gpio" to see if the proper GPIO is used ...
Yes, iam sure that is a 1wire temp sensor (DS18b20 incl. 4,7kOhm resistor) connected.
The output of  cat /sys/kernel/debug/gpio is
 gpio-234 (                    |soc:onewire@0       ) out lo
So, connected on PH10 ...
I don't have other idea ... When I've faced such randomness issue, it was pointing to another floating GPIO.
w1 works Armbian_5.83_Bananapim3_Debian_stretch_next_4.19.38.img
@nkahl
onewire@0 {
            gpios = <&pio 4 4 0>; /* PE4 */
            status = "okay"; };
can anyone help me how to use uart2  PB0,PB1 and uart3 PG10,PG11
uart0 works PB9, PB10
all serialpots is enabled in xxx.dtb "okay" but not work
edit:
all uarts works now
5 minutes ago, JerryPenguin said:
I will wait for a new image and try again a new and fresh installation.
It might take several months before someone fixes the problem. I tried twice and will not try again.
18 minutes ago, JerryPenguin said:
That's sad.
You are supporting support with nothing. Indeed it is sad that you expect that someone will fix and fix and fix this cheap hardware which was anyway never officially supported.
1. I only asked one question and didn't ask for support or immediate bug fixing, because I know it's an OpenSource project and I'm thankful that Armbian exists.
2. I support other projects and know how difficult and pointless this is. I cannot actively support every project I use.
3. It is sad, but I have not made a demand or a bad word about this fact.
4. I've already looked around the download pages for supported hardware but can't find a suitable alternative for my requirement.
Maybe you can recommend a hardware (which is supported) that meets the following requirements:
- EMMC (>=8GB)
- 64bit (if already then)
- Memory (>= 2GB)
- 1000mbit Ethernet
- passive cooling, no fan
primarily for use as Wireguard Gateway and Pi-Hole.
I would be grateful for a tip :-)
Greetings
I have seen others asking for something similar. Do some forum / site searching.
Why on earth you need 2GB for this?
We are going off topic so please find another more appropriate topic to continue with.
First of all thanks for your patience.
I have also just taken the chance to ask you the last question for a tip, I know it officially does not belong in this thread, so just forget it.
Maybe Munin will come up with the newly planned SBC, and why shouldn't I take this into account when buying new hardware?
Greetings and thank you very much.
Hello Folks,
So, I have a bananapi m3 too, and I tried armbian focal and buster succesfully from a sd card but I couldn't boot from emmc... I used nand-stata-install,  dd and all the things aroung with no success... the output from uart from emmc is this:
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
rtc[1] value = 0x00010000
rtc[2] value = 0x00020000
rtc[3] value = 0x00030000
DRAM DRIVE INFO: V1.1
DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM normal_mode value: 00000001
DRAM CLK =672 MHZ
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1200 mv
ID CHECK VERSION: V0.2
using ic A83T
using axp AXP813
DRAM zq value: 00003bfb
dram size =2048
card boot number = 2
card no is 2
sdcard 2 line count 8
[mmc]: mmc driver ver 2015-04-13 16:05:39
[mmc]: ***Try SD card 2***
[mmc]: mmc 2 cmd 8 err 00000100
[mmc]: mmc 2 send if cond failed
[mmc]: mmc 2 cmd 55 err 00000100
[mmc]: mmc 2 send app cmd failed
[mmc]: ***Try MMC card 2***
[mmc]: mmc re-update_phase
[mmc]: 8bit ddr!!!
[mmc]: MMC ver 5.0
[mmc]: SD/MMC Card: 8bit, capacity: 7456MB
[mmc]: vendor: Man 00150100 Snr 0032bbf4
[mmc]: product: 8WPD3
[mmc]: revision: 5.2
[mmc]: ***SD/MMC 2 init OK!!!***
sdcard 2 init ok
ERROR! NOT find the head of uboot.
read all u-boot blk failed
Ready to disable icache.
PD: thanks for your great job with this
On 6/30/2020 at 2:08 AM, Adrián Rivelli said:
Hello Folks,
DRAM CLK =672 MHZ
PMU: AXP81X
using ic A83T
using axp AXP813
dram size =2048
card no is 2
[mmc]: 8bit ddr!!!
[mmc]: MMC ver 5.0
sdcard 2 init ok
I'm have exactly the same problem and I have solve it.
The problem is in bootloader on eMMC. It's locked by default and armbian-config does not unlock it while install on emmc. And the old BOOT0 bootloader can't load new kernel. But we have new bootloader in armbian image. It located in /usr/lib/linux-u-boot-current-bananapim3_20.08.1_armhf/u-boot-sunxi-with-spl.bin in my case. Check your image and fix pathces in further instruction before wiping anything!
So:
1. Flash armbian image to SD, boot normaly and log in (through SSH or phisycal keyboard and monitor - does not matter).
2. We have two boot section on eMMC (mmcblk1boot0 and mmcblk1boot1). I don't know "who is who", so I flash both of them.
Unlock it: echo 0 | sudo tee /sys/block/mmcblk1boot0/force_ro && echo 0 | sudo tee /sys/block/mmcblk1boot1/force_ro
Two zeros in output says it unlocked.
3. Wipe it: sudo dd if=/dev/zero of=/dev/mmcblk1boot0 bs=1k count=1023 seek=1 status=noxfer && sudo dd if=/dev/zero of=/dev/mmcblk1boot1 bs=1k count=1023 seek=1 status=noxfer
4. Now flash new u-boot bootloader into boot partitions:
sudo dd if=/usr/lib/linux-u-boot-current-bananapim3_20.08.1_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1boot0 bs=1024 seek=8 status=noxfer && sudo dd if=/usr/lib/linux-u-boot-current-bananapim3_20.08.1_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1boot1 bs=1024 seek=8 status=noxfer
5. Run "sudo armbian-config" and go to: System>Install>Install/Update the bootloader on SD/eMMC (just in case)
Now you can install armbian through armbian-config as usual. After reboot bootloader partition lock by itself. You can check it's blocked by typing: cat /sys/block/mmcblk1boot0/force_ro && cat /sys/block/mmcblk1boot1/force_ro
Output must be like "1 1" in two lines.
Edited by WidHorn
Typos. Sorry, but my English is terrible.
Looks like meanwhile the M3 entered a matured state , at least from " compile.sh " menu - did not notice till recent.
Anyway was wondering if things improved running kernel 5.8 and onwards , mainly in terms of " A83T chip isn’t SATA capable and therefore the SATA port is provided by a (very) slow GL830 USB-to-SATA-bridge "
So therefore still worth buying a separate USB-to-SATA bridge if you want to connect a hard disk? bummer it is "just" 2.0 but what to expect as board is being produced from somewhere 2015 I believe.
In terms of octa core systems ( 1,8Ghz ) this looks still a nice pick
On 10/24/2020 at 12:42 AM, dolphs said:
Hi
This is what I have figured out thus far for the Banana Pi M3 development board.
I have compiled one of the three supported images via Armbian build system (./compile.sh) on my PC for my BPI M3 (v1.2) board (21.04 hirsute 5.10.43), but there are kernel modules and/or drivers missing to get it fully operational. Mainly AXP813 supply / audio codec SoC drivers, but also gpio pin control, CSI and MIPI (all related to the AXP813 I think)
When compilation is going on you can see it is using linux-mainline-orangepi-5.10, this is the reason why for example gpio readall reads and shows only 26 pins instead of 40 pins, and the AXP813 is not fully operational because the analog-codec / hdmi won't work (ALSA won't detect any sound card/driver), dmesg shows a lot of failures.
So who knows how to compile these modules and/or drivers for these hardware problems? Where to start? Every little info/detail or hint is welcome.
Thanks.
Same here, no sound card found, but there is no support for BPI M3 at all.
I dont know how to find a solution, every hint would be great.
How did you install gpio for command gpio readall ?
Didnt work for me.
sudo apt install wiringpi or sudo apt-get install wiringpi
ps. if you write this latest image (armbian_21.08.1_bpim3_hirsute_edge_5.13.12.img) on a microsd card at least one thing has changed, that HDMI audio is now supported (did not test it) aplay -l shows a HDMI audio ALSA driver. In the pavucontrol (if you have installed xorg and xfce4 desktop) mixer it shows a mono output.
http://armbian.hosthatch.com/archive/bananapim3/archive/Armbian_21.08.1_Bananapim3_hirsute_edge_5.13.12.img.xz
