Few simple steps to install docker and docker compose on clean Armbian_20.05.4_Odroidxu4_focal_current_5.4.41 ODROID-HC1
Thanks to official docs https://docs.docker.com/engine/install/ubuntu/
    curl -fsSL https://download.docker.com/linux/ubuntu/gpg | apt-key add -
    # Verify that you now have the key with the fingerprint 9DC8 5822 9FC7 DD38 854A  E2D8 8D81 803C 0EBF CD88 - you may skip this
    apt-key fingerprint 0EBFCD88
    # add-apt-repository "deb [arch=armhf] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
    add-apt-repository "deb [arch=armhf] https://download.docker.com/linux/ubuntu bionic stable" # there is no repository for focal :(
    apt-get update
    apt-get install docker-ce docker-ce-cli containerd.io
    docker run --rm hello-world # test - you may skip
    docker --version
    apt install python3-pip
    apt install python3-dev
    apt install libffi-dev
    apt install libssl-dev
    pip3 install docker-compose
    docker-compose --version
That's all, enjoy
Sorry for necroposting
As the documentation is now marked as obsolete, what is the correct way to install Docker on a recent Armbian Buster?
  ___                             ____  _   _  _
 / _ \ _ __ __ _ _ __   __ _  ___|  _ \(_) | || |
| | | | '__/ _` | '_ \ / _` |/ _ \ |_) | | | || |_
| |_| | | | (_| | | | | (_| |  __/  __/| | |__   _|
 \___/|_|  \__,_|_| |_|\__, |\___|_|   |_|    |_|
                       |___/
Welcome to Armbian 20.08.17 Buster with Linux 5.8.17-rockchip64
I think at one time, it was available in armbian-config, but I may be wrong.. And I'm trying that on an unsupported board (OrangePi4).
Here is what I have done:
sudo apt-get remove docker docker-engine docker.io containerd runc
sudo apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add -
sudo apt-key fingerprint 0EBFCD88
sudo add-apt-repository "deb [arch=arm64] https://download.docker.com/linux/debian $(lsb_release -cs) stable"
sudo apt update
sudo apt-get install docker-ce docker-ce-cli containerd.io
sudo docker run hello-world
Thanks.
the distro natively packaged versions are new enough for my use these days.. I just do apt install docker.io
Thanks for the tip.
I will try it on another machine with a fresh install, as I get :
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 docker.io : Depends: runc (>= 1.0.0~rc6~)
E: Unable to correct problems, you have held broken packages.
Hi. I am attempting to install  docker and I've hit a snag in the installation. I followed the instructions here: https://docs.docker.com/engine/install/ubuntu/
For some reason the docker service did not start. Here is the error from installation and the systemctl status:
Setting up docker-ce (5:20.10.18~3-0~ubuntu-jammy) ...
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xeu docker.service" for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
     Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
     Active: activating (auto-restart) (Result: exit-code) since Mon 2022-10-10 19:40:40 EDT; 39ms ago
TriggeredBy: ● docker.socket
       Docs: https://docs.docker.com
    Process: 15936 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
   Main PID: 15936 (code=exited, status=1/FAILURE)
        CPU: 367ms
dpkg: error processing package docker-ce (--configure):
 installed docker-ce package post-installation script subprocess returned error exit status 1
Processing triggers for man-db (2.10.2-1) ...
Errors were encountered while processing:
 docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
admin@lepotato:~$ sudo systemctl status docker.service
× docker.service - Docker Application Container Engine
     Active: failed (Result: exit-code) since Mon 2022-10-10 19:40:49 EDT; 2min 0s ago
TriggeredBy: × docker.socket
    Process: 16057 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
   Main PID: 16057 (code=exited, status=1/FAILURE)
        CPU: 473ms
Oct 10 19:40:49 lepotato systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Oct 10 19:40:49 lepotato systemd[1]: Stopped Docker Application Container Engine.
Oct 10 19:40:49 lepotato systemd[1]: docker.service: Start request repeated too quickly.
Oct 10 19:40:49 lepotato systemd[1]: docker.service: Failed with result 'exit-code'.
Oct 10 19:40:49 lepotato systemd[1]: Failed to start Docker Application Container Engine.
I have the same issue than ajkelsey with installation of Docker on an Orange Pi zero2 under Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318.
I tried the two methods described in the official documentation (https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-run-docker), but the docker service refuses to load.
Is there anything I'm missing? I was planning to try it on a fresh Armbian installation. I did not try to install Docker on Jammy and Bookworm because wifi does not work properly with these systems (available at https://www.armbian.com/orange-pi-zero-2/)
Docker needs some kernel stuff that has been introduced after 4.9.y was released. So the only way is to run a more recent kernel which probably does not support all hw features the board has to offer.
Thanks, Werner!
The official Armbian documentation states that the version should be 20.08.17 or newer, with Kernel 3.10 or higher.
I thought I was in the clear with Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318.
Perhaps this requirement applies to an older version of Docker. I'm considering trying a 1-2-year-old version of Docker to see if it works. Not sure if it makes sense.
I've attempted to install three different versions of Bullseye (edge and current) with a kernel >4.9 (5.15.x or 6.2), but none of them boot up on the Orange Pi Zero 2. Unfortunately, The only versions that boot up have kernel 4.9.
Edited by Alligator427
The only solution for legacy images is to downgrade to cgroups v1 with kernel parameter
You add this in armbianEnv.txt
extraargs=systemd.unified_cgroup_hierarchy=0
To use cgroup v2, you need to have kernel 4.15 or later https://github.com/opencontainers/runc/blob/v1.0.0-rc95/docs/cgroup-v2.md#host-requirements.
Other requirements you might need to set iptables debian os
The docker installer uses iptables for nat. Unfortunately Debian uses nftables.
You can convert the entries over to nftables or just setup Debian to use the legacy iptables.
sudo update-alternatives --set iptables /usr/sbin/iptables-legacy
sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy
As for non booting zero2 images please check latest, builds are working fine for me at this point, although I will check, (limited time atm, also 'not sure about mirrors synching').
Wow! Thanks ALIGMSTEN! This solve the issue completely. The last docker version is now working on Armbian bullseye kernel 4.9 on Orange pi zero2.
Thanks for your help and for what you are doing!
Here is the detailed procedure for the people that may experience the same issue.
-Fresh install of Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318.img.xz
http://xogium.performanceservers.nl/archive/orangepizero2/archive/Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318.img.xz
sudo apt-get update
sudo apt-get upgrade
-add the following to /boot/armbianEnv.txt
-return to prompt
-reboot
-install docker according to https://docs.docker.com/engine/install/debian/ (below)
sudo apt-get update
sudo apt-get install ca-certificates curl gnupg
sudo install -m 0755 -d /etc/apt/keyrings
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
sudo chmod a+r /etc/apt/keyrings/docker.gpg
-Then
echo \
  "deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian \
  "$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" | \
  sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin
sudo reboot
-Test docker with
Hi there,
I revived my BananaPi M1 (ARM7 32bit) last week. I installed a fresh armbian and just docker like this:
sudo apt-get update
sudo curl -fsSL https://download.docker.com/linux/debian/gpg -o /etc/apt/keyrings/docker.asc
sudo chmod a+r /etc/apt/keyrings/docker.asc
echo   "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/debian \
    $(. /etc/os-release && echo "$VERSION_CODENAME") stable" |   sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
sudo gpasswd -a $USER docker
newgrp docker
The "Hello world" worked.
But when I tried to run anything useful things failed. Seafile installed okay, but calling the UI timed out. Paperless-ngx complained that paperless-webserver cannot find route to redis. Stuff like this. I just want to use the machine in my internal Network at home.
To investigate further I installed a simple httpd docker to see if I can reach that one. No luck. Neither from another machine in my LAN, nor via lynx  on BananaPi calling localhost. The request goes out as the port seems to be open, but it never reaches the daemon inside the container or cannot respond. Same commands on my "production box" (a HP t630 with debian bookworm) work fine.
So my conclusion is that it must be something in the OS.
I compared iptables on BananaPi and t630 and checked the output of 'sudo /usr/sbin/sysctl -a | grep forwarding | grep ipv4' - they are the same.
I'm a little bit clueless where to check, what commands to use as I'm quite new to docker. Do you have any suggestions?
Thanks, Peter.
This means Docker works.
Minimal Armbian images comes with very minimal systemd-networking since several weeks. This brought much smaller OS images, but could cause this kind of troubles.
Try to do some research into this direction.
For anyone struggling with Docker connectivity issues on latest Arbian minimal images, I've found solution (although, can't say if it's a good or bad solution, I'm not a sysops wizard or whatever) which does seem to work fine for my use case.
Tested on "Armbian_community 24.8.0-trunk.399 Bookworm with Linux 6.6.36-current-sunxi64"
By following this stackoverflow answer (https://stackoverflow.com/a/76440642/951007), I've modified netplan's default configuration file (currently "/etc/netplan/10-dhcp-all-interfaces.yaml" file) from:
all-eth-interfaces:
  match:
to
all-eth-interfaces:
  match:
and restarted the entire SBC.
With this change applied, docker network adapters changed their SETUP from "configuring" to "unmanaged", as it apparently should be in the first place (although please do note that other adapters have been changed as well, so proceed with caution):
$ sudo networkctl list
IDX LINK            TYPE     OPERATIONAL SETUP
  1 lo              loopback carrier     unmanaged
  2 end0            ether    routable    configured
  3 wlan0           wlan     off         unmanaged
  4 docker0         bridge   no-carrier  unmanaged
  5 br-xxxxxxxxxxxx bridge   no-carrier  unmanaged
  6 br-xxxxxxxxxxxy bridge   no-carrier  unmanaged
After that, Docker was able to communicate with the outside world:
$ docker run busybox ping -c 1 1.1.1.1
PING 1.1.1.1 (1.1.1.1): 56 data bytes
64 bytes from 1.1.1.1: seq=0 ttl=57 time=4.741 ms
and was able to communicate with other docker-based services in the same network - in my case, a Spoolman instance was not able to communicate with Postgresql instance started using one docker compose file.
Again, please do note that I'm no expert in this regard, so if you decide to follow this solution, I would recommend verifying whether other services (that require connectivity in any way) still work as expected.
5 hours ago, dziekon said:
minimal
netplan
I wonder how this works out since AFAIK there is no netplan installed on minimal images.
I am going to go back to basics, so apologies if this is too obvious.
Are you guys opening ports between the container and the host?
I am still learning Docker myself, but isn't the default to limit containers to their own little Docker network, where they can only reach each other?
For example, when I started running Home Assistant as a Docker container, I had to allow `--net=host` option (well, the equivalent in my `docker-compose` file, but you get the idea).
