Helios4 doesn't boot after upgrading to linux-6.6.71 (linux-image-current-mvebu_25.2.0-trunk.343)
Go to solution Solved by Josua-SR,
Hello,
After upgrading helios4 I encountered this problem after rebooting:
U-Boot SPL 2019.04-armbian (Jul 03 2024 - 12:20:37 +0000)
High speed PHY - Version: 2.0
Detected Device ID 6828
board SerDes lanes topology details:
 | Lane #  | Speed |  Type       |
 |   0    |  6   |  SATA0	|
 |   1    |  5   |  USB3 HOST0	|
 |   2    |  6   |  SATA1	|
 |   3    |  6   |  SATA3	|
 |   4    |  6   |  SATA2	|
 |   5    |  5   |  USB3 HOST1	|
High speed PHY - Ended Successfully
mv_ddr: mv_ddr-armada-18.09.2
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR Training Sequence - Start scrubbing
DDR3 Training Sequence - End scrubbing
mv_ddr: completed successfully
Trying to boot from MMC1
U-Boot 2019.04-armbian (Jul 03 2024 - 12:20:37 +0000)
SoC:   MV88F6828-A0 at 1600 MHz
DRAM:  2 GiB (800 MHz, 32-bit, ECC enabled)
MMC:   mv_sdh: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Model: Helios4
Board: Helios4
SCSI:  MVEBU SATA INIT
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net:
Warning: ethernet@70000 (eth1) using random MAC address - e2:6d:a3:83:7f:e1
eth1: ethernet@70000
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2996 bytes read in 381 ms (6.8 KiB/s)
## Executing script at 03000000
Boot script loaded from mmc
158 bytes read in 369 ms (0 Bytes/s)
28834 bytes read in 691 ms (40 KiB/s)
11165487 bytes read in 2303 ms (4.6 MiB/s)
8551104 bytes read in 1847 ms (4.4 MiB/s)
Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
starting USB...
USB0:   MVEBU XHCI INIT controller @ 0xf10f4000
Register 2000120 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   MVEBU XHCI INIT controller @ 0xf10fc000
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
Device 0: device type unknown
... is now current device
I guess the most important part is this:
This happened when linux-image was upgraded from 24.11.0-trunk.403 to 25.2.0-trunk.316 (25.2.0-trunk.343 doesn't work either). To get it working again I unpacked previous kernel and I'm back to 24.11.0-trunk.403. I noticed that this topic
has similar problem. I still got some ideas about how to debug this but I before that I wanted to ask if anyone has encountered this on this board? Did the initrd changed format during upgrade and I have to upgrade uboot (I noticed that FORCE_UBOOT_UPDATE is set to null so I guess installing linux-u-boot-helios4-current_25.2.0-trunk.316_armhf.deb doesn't dd bootloader onto sdcard.
Thanks in advance!
  • Solution
Posted (edited)
I can confirm that Armbian_community_25.5.0-trunk.4_Helios4_noble_current_6.6.75.img.xz does not boot on Helios-4 with the same error described above:
I spent the weekend investigating a similar issue with upstream Debian and upstream u-boot that turned out to be after a certain size of mmc access data would be corrupted. Disabling the SDHCI_SDMA function in u-boot helped:
https://lore.kernel.org/r/20250208-a388-kerneladdr-v2-1-17c01313eba2@solid-run.com
Finally I pushed this and other changes to the SolidRun vendor fork for the Armada 388 System on Module (as used on Helios-4), and attempted booting the same armbian image again. This time boot succeeded:
BootROM - 1.73
Booting from SPI flash
U-Boot SPL 2024.04 (Feb 08 2025 - 13:12:00 +0000)
 |   0    |   6   | SATA0       |
 |   2    |   6   | SATA1       |
 |   3    |   6   | SATA3       |
 |   4    |   6   | SATA2       |
mv_ddr: 14.0.0
Trying to boot from SPI
U-Boot 2024.04 (Feb 08 2025 - 13:12:00 +0000)
Core:  30 devices, 20 uclasses, devicetree: separate
MMC:   mv_sdh: 0
Loading Environment from SPIFlash... SF: Detected w25q32 with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
Model: Helios4
Board: Helios4
Net:
Warning: ethernet@70000 (eth1) using random MAC address - 86:69:49:e4:c6:90
Scanning mmc 0:1...
2996 bytes read in 17 ms (171.9 KiB/s)
## Executing script at 00200000
158 bytes read in 13 ms (11.7 KiB/s)
28834 bytes read in 32 ms (879.9 KiB/s)
8146813 bytes read in 807 ms (9.6 MiB/s)
8550096 bytes read in 850 ms (9.6 MiB/s)
Working FDT set to 100000
Kernel image @ 0x800000 [ 0x000000 - 0x8276d0 ]
## Loading init Ramdisk from Legacy Image at 01800000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8146749 Bytes = 7.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 00100000
   Booting using the fdt blob at 0x100000
   Loading Ramdisk to 0f83b000, end 0fffff3d ... OK
   Loading Device Tree to 0f7cb000, end 0f83afff ... OK
Working FDT set to f7cb000
Starting kernel ...
Loading, please wait...
Starting systemd-udevd version 255.4-1ubuntu8.5
Binaries for reference:
https://images.solid-run.com/A38X/U-Boot/v2024.04/2025-02-08_695f767/u-boot-helios-4-sd.kwb
https://images.solid-run.com/A38X/U-Boot/v2024.04/2025-02-08_695f767/u-boot-helios-4-spi.kwb
Edited by Josua-SR
Great news, thanks!
I wasn't able to download u-boot from the links that you provided so I build it myself and "dd" it to sdcard.
For some reason that particular kernel that caused this problem isn't available in apt repository, but that doesn't matter for now. At least I know that during next upgrade it'll work.
Thanks @Josua-SR!
I tried with self made and this binary - we have some troubles with kernel I guess.
=> boot
Scanning mmc 0:1...
2996 bytes read in 15 ms (194.3 KiB/s)
158 bytes read in 12 ms (12.7 KiB/s)
28834 bytes read in 27 ms (1 MiB/s)
11476654 bytes read in 1086 ms (10.1 MiB/s)
8546328 bytes read in 843 ms (9.7 MiB/s)
Working FDT set to 2040000
Kernel image @ 0x2080000 [ 0x000000 - 0x826818 ]
Loading Boot0000 'mmc 0' failed
EFI boot manager: Cannot load any image
Quote
Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid
What is the right Ramdisk format?
I build fresh Armbian-unofficial_25.02.0-trunk_Helios4_plucky_edge_6.10.14 from armbian trunk (1f697206562).
Image boots successfuly.
Why?
Posted (edited)
Hi all,
Today I upgraded armbian on my Helios 4. I wish I hadn't. The system won't boot anymore. Received the "Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid" message.
Any hints on trying to recover from this? To be honest, I'm stuck at the moment.
I recovered from this through the following steps:
  • Get the 'original' image (although dated) from the Helios site (https://wiki.kobol.io/helios4/)
  • Created another sd card
  • Booted
  • And had access again.
  • The hardest part was recoving the old lukskey for opening the encrypted partitions from the raid array.
Edited by Dee2022
Same here: "No boot after upgrade to Armbian 25.2.2".
Same message:
The very "unfriendly" behaviour was the unattended-upgrade. Therefore I had no chance first to make an update of my 24.11 system with Linux 6.6.63-current-mvebu (see signature). I had to use for recovery  the backup from 24.8 immediately before 24.11 in the pipeline. The recovered system is now Armbian 24.8 with Linux 6.6.47-current-mvebu.
Any chance to get 24.11 again?
@Igor
Is a new update to 25.2 for Helios4 planned of the kernel binaries ? If so, when can this be expected? If not, what can I do?
The post of @Josua-SR is marked as solution. But I have no idea what to do with the *.kwb files from SolidRun. In particular I never made a custom build.
Posted (edited)
@Mangix
Thank you, that was simple.
@Dee2022
What I did:
  1. Download of the 1st SolidRun image (... sd.kwb)
  2. Copy the image to SDcard containing unbootable Armbian 25.2 (on my Linux desktop using dd, SDcard available here at /dev/sdf)
    sudo dd if=u-boot-helios-4-sd.kwb of=/dev/sdf bs=512 seek=1 status=noxfer
    sudo sync
  3. Boot Helios4. Voilà.
Edited by FredK
Nothing is planned unfortunately. It was a try if I can bring this from the dead in a couple of hours. I spent all the time I could afford to. In order to not go into the self-destruction path, we set a rules to ourselves: https://docs.armbian.com/User-Guide_Board-Support-Rules/
I can't maintain this board. It is one out of (perhaps 500 that are on the market, and one out of 100 that has some user base behind). If someone will help, and step up, to match the board support rules, this board can be lifted to standard support. It was dropped to community support about a year ago https://github.com/armbian/build/pull/6654 as we haven't heard it from its maintainer for a long time. We don't have any other alternative.
I hope someone will take a look and integrate those changes into the build framework. Then we will at least a device into automated testing for early problem detections. They will certainly pop up in the future as they always does :(
Posted (edited)
@Igor
After @Mangix's post I was able to fix my installation patching the bootloader.
I'm aware that Helios4 is a dead-end and I plan to switch to a 64bit-SBC providing 4 or 5 SATA-ports (but I don't find a suitable board up to now).
Edited by FredK
We have many of such boards in the system ;) Armbian mission is trying to keep them alive as long as possible. We invest a lot of efforts to keep them build-able, but there is just too many things that can go wrong in the u-boot / kernel area. Boards are constantly collapsing - if we want to keep them aligned with a modern kernel. The task is simply too big for our small team. We encourage people, owners of those (old) boards to step up and integrate those findings to the builds system, so this solution is available for everyone.
We are running one mirror on Radxa ITX with success:
https://www.armbian.com/newsflash/armbian-v24-11/
Software wise we are covering it well.
I got bitten by this and in the end rolled back to Armbian 24.2.1 with kernel 6.6.16 which seems to work fine (with zfs and omv 7). Can anyone comment as to how much work would be required to fix this issue in the 25.x development and how much time would be required to bring this board up to be supported again ?
I estimate few days, a week, if focusing just into this problem. "Officially supported" also needs someone to act as a maintainer https://docs.armbian.com/User-Guide_Board-Support-Rules/#standard-support On a long term, not just fixing current issue. Every kernel (boot-loader) change can break features partially or completely (boot failure).
I just hit this problem today after an update to kernel 6.6.80. Thanks to @Dee2022 for the solution to fix it, but I'll add that I also needed to edit `/boot/armbianEnv.txt` on the sdcard to adjust the `rootdev=UUID=xxx` line so that the correct root device to boot from could be found.
If you folks come across a low power arm board with 4xsata headers which can function as a home nas, I'd appreciate recommendations as the Helios4 is getting a little old now.
Without really having understood the underlying problem:
I updated the sd card with the provided image via dd. Will this be a one time thing? Or which part of the upgrade process will break it again, i.e. which packages should not be updated?
Thank you
This automated installation of the kernel did put the love to the ARM based devices to an end..  Was working solid.. but without display connector it is really diffucuilt to troubleshoot what is wrong with it.
After the installation of OMV over the Armbian in the newest version network stops working and I cannot see why.. Time to sell this fine HELIOS4 to someone..
Updating to the current kernel immediately breaks everything.. Also the copy command of the copying u-boot-helios-4-sd.kwb is not helping in this case.. The device is not booting anymore..
Unpacking linux-image-current-mvebu (25.2.3) over (24.2.1) ...
Armbian 'linux-image-current-mvebu' for '6.6.16-current-mvebu': 'postrm' starting.
Armbian 'linux-image-current-mvebu' for '6.6.16-current-mvebu': 'postrm' finishing.
Setting up libtext-iconv-perl:armhf (1.7-8) ...
Setting up linux-image-current-mvebu (25.2.3) ...
Armbian 'linux-image-current-mvebu' for '6.6.84-current-mvebu': 'postinst' starting                          .
dkms: autoinstall for kernel 6.6.84-current-mvebu was skipped since the kernel head                          ers for this kernel do not seem to be installed.
update-initramfs: Generating /boot/initrd.img-6.6.84-current-mvebu
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.84-curren                          t-mvebu
Image Name:   uInitrd
Created:      Sat Mar 29 15:48:16 2025
Data Size:    14351524 Bytes = 14015.16 KiB = 13.69 MiB
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.84-current-mvebu to /boot/u                          Initrd
'/boot/uInitrd' -> 'uInitrd-6.6.84-current-mvebu'
update-initramfs: Armbian: done.
Remove unused generated file: /boot/initrd.img-6.6.16-current-mvebu
Remove unused generated file: /boot/uInitrd-6.6.16-current-mvebu
Armbian: update last-installed kernel symlink to 'zImage'...
'/boot/zImage' -> 'vmlinuz-6.6.84-current-mvebu'
Armbian: Debian compat: linux-update-symlinks install 6.6.84-current-mvebu boot/vml                          inuz-6.6.84-current-mvebu
I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.6.84-current-mvebu
I: /initrd.img.old is now a symlink to boot/initrd.img-6.6.84-current-mvebu
I: /vmlinuz is now a symlink to boot/vmlinuz-6.6.84-current-mvebu
I: /initrd.img is now a symlink to boot/initrd.img-6.6.84-current-mvebu
Armbian 'linux-image-current-mvebu' for '6.6.84-current-mvebu': 'postinst' finishin                          g.
Setting up armbian-zsh (25.2.3) ...
cp: cannot create directory '/home/download/.oh-my-zsh': No such file or directory
cp: cannot create regular file '/home/download/.zshrc': No such file or directory
chown: cannot access '/home/download/.oh-my-zsh': No such file or directory
chown: cannot access '/home/download/.zshrc': No such file or directory
Setting up armbian-config (25.5.0-trunk.5.0206.155506) ...
Setting up armbian-bsp-cli-helios4-current (25.2.3) ...
Installing new version of config file /usr/lib/armbian/armbian-apt-updates ...
Armbian 'armbian-bsp-cli-helios4-current' for '1-PCbbd5-V6a77-H6710-B6e44-R7697': '                          postinst' starting.
'/boot/boot.cmd' -> '/usr/share/armbian/boot.cmd-1743259697'
NOTE: You can find previous bootscript versions in /usr/share/armbian !
Recreating boot script
'/usr/share/armbian/boot.cmd' -> '/boot/boot.cmd'
update-initramfs: deferring update (trigger activated)
Armbian 'armbian-bsp-cli-helios4-current' for '1-PCbbd5-V6a77-H6710-B6e44-R7697': '                          postinst' finishing.
Setting up armbian-firmware (25.2.3) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for initramfs-tools (0.142+deb12u1) ...
Image Name:   uInitrd
Created:      Sat Mar 29 15:48:45 2025
Data Size:    14378902 Bytes = 14041.90 KiB = 13.71 MiB
I solved the problems with the updates by completely disabling the kernel and firmware updates.. the board is alive and running great with OpenMediaVault .. All unattended updates were disabled completely. I hope the will be a stable kernel for this device in the future. Running it with 6.6.16 kernel which came with the image..
