wite_k Posted January 23 Posted January 23 Hello, After upgrading helios4 I encountered this problem after rebooting: U-Boot SPL 2019.04-armbian (Jul 03 2024 - 12:20:37 +0000) High speed PHY - Version: 2.0 Detected Device ID 6828 board SerDes lanes topology details: | Lane # | Speed | Type | -------------------------------- | 0 | 6 | SATA0 | | 1 | 5 | USB3 HOST0 | | 2 | 6 | SATA1 | | 3 | 6 | SATA3 | | 4 | 6 | SATA2 | | 5 | 5 | USB3 HOST1 | -------------------------------- High speed PHY - Ended Successfully mv_ddr: mv_ddr-armada-18.09.2 DDR3 Training Sequence - Switching XBAR Window to FastPath Window DDR Training Sequence - Start scrubbing DDR3 Training Sequence - End scrubbing mv_ddr: completed successfully Trying to boot from MMC1 U-Boot 2019.04-armbian (Jul 03 2024 - 12:20:37 +0000) SoC: MV88F6828-A0 at 1600 MHz DRAM: 2 GiB (800 MHz, 32-bit, ECC enabled) MMC: mv_sdh: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** Model: Helios4 Board: Helios4 SCSI: MVEBU SATA INIT Target spinup took 0 ms. SATA link 1 timeout. AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode flags: 64bit ncq led only pmp fbss pio slum part sxs Net: Warning: ethernet@70000 (eth1) using random MAC address - e2:6d:a3:83:7f:e1 eth1: ethernet@70000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2996 bytes read in 381 ms (6.8 KiB/s) ## Executing script at 03000000 Boot script loaded from mmc 158 bytes read in 369 ms (0 Bytes/s) 28834 bytes read in 691 ms (40 KiB/s) 11165487 bytes read in 2303 ms (4.6 MiB/s) 8551104 bytes read in 1847 ms (4.4 MiB/s) Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... starting USB... USB0: MVEBU XHCI INIT controller @ 0xf10f4000 Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: MVEBU XHCI INIT controller @ 0xf10fc000 Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: device type unknown ... is now current device I guess the most important part is this: Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... This happened when linux-image was upgraded from 24.11.0-trunk.403 to 25.2.0-trunk.316 (25.2.0-trunk.343 doesn't work either). To get it working again I unpacked previous kernel and I'm back to 24.11.0-trunk.403. I noticed that this topic has similar problem. I still got some ideas about how to debug this but I before that I wanted to ask if anyone has encountered this on this board? Did the initrd changed format during upgrade and I have to upgrade uboot (I noticed that FORCE_UBOOT_UPDATE is set to null so I guess installing linux-u-boot-helios4-current_25.2.0-trunk.316_armhf.deb doesn't dd bootloader onto sdcard. Thanks in advance! 0 Quote
Solution Josua-SR Posted February 8 Solution Posted February 8 (edited) I can confirm that Armbian_community_25.5.0-trunk.4_Helios4_noble_current_6.6.75.img.xz does not boot on Helios-4 with the same error described above: Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... I spent the weekend investigating a similar issue with upstream Debian and upstream u-boot that turned out to be after a certain size of mmc access data would be corrupted. Disabling the SDHCI_SDMA function in u-boot helped: https://lore.kernel.org/r/20250208-a388-kerneladdr-v2-1-17c01313eba2@solid-run.com Finally I pushed this and other changes to the SolidRun vendor fork for the Armada 388 System on Module (as used on Helios-4), and attempted booting the same armbian image again. This time boot succeeded: BootROM - 1.73 Booting from SPI flash U-Boot SPL 2024.04 (Feb 08 2025 - 13:12:00 +0000) High speed PHY - Version: 2.0 Detected Device ID 6828 board SerDes lanes topology details: | Lane # | Speed | Type | -------------------------------- | 0 | 6 | SATA0 | | 1 | 5 | USB3 HOST0 | | 2 | 6 | SATA1 | | 3 | 6 | SATA3 | | 4 | 6 | SATA2 | | 5 | 5 | USB3 HOST1 | -------------------------------- High speed PHY - Ended Successfully mv_ddr: 14.0.0 DDR3 Training Sequence - Switching XBAR Window to FastPath Window DDR Training Sequence - Start scrubbing DDR3 Training Sequence - End scrubbing mv_ddr: completed successfully Trying to boot from SPI U-Boot 2024.04 (Feb 08 2025 - 13:12:00 +0000) SoC: MV88F6828-A0 at 1600 MHz DRAM: 2 GiB (800 MHz, 32-bit, ECC enabled) Core: 30 devices, 20 uclasses, devicetree: separate MMC: mv_sdh: 0 Loading Environment from SPIFlash... SF: Detected w25q32 with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment Model: Helios4 Board: Helios4 Net: Warning: ethernet@70000 (eth1) using random MAC address - 86:69:49:e4:c6:90 eth1: ethernet@70000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2996 bytes read in 17 ms (171.9 KiB/s) ## Executing script at 00200000 Boot script loaded from mmc 158 bytes read in 13 ms (11.7 KiB/s) 28834 bytes read in 32 ms (879.9 KiB/s) 8146813 bytes read in 807 ms (9.6 MiB/s) 8550096 bytes read in 850 ms (9.6 MiB/s) Working FDT set to 100000 Kernel image @ 0x800000 [ 0x000000 - 0x8276d0 ] ## Loading init Ramdisk from Legacy Image at 01800000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 8146749 Bytes = 7.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 00100000 Booting using the fdt blob at 0x100000 Working FDT set to 100000 Loading Ramdisk to 0f83b000, end 0fffff3d ... OK Loading Device Tree to 0f7cb000, end 0f83afff ... OK Working FDT set to f7cb000 Starting kernel ... Loading, please wait... Starting systemd-udevd version 255.4-1ubuntu8.5 Binaries for reference: https://images.solid-run.com/A38X/U-Boot/v2024.04/2025-02-08_695f767/u-boot-helios-4-sd.kwb https://images.solid-run.com/A38X/U-Boot/v2024.04/2025-02-08_695f767/u-boot-helios-4-spi.kwb Edited February 8 by Josua-SR 3 Quote
wite_k Posted February 9 Author Posted February 9 Great news, thanks! I wasn't able to download u-boot from the links that you provided so I build it myself and "dd" it to sdcard. For some reason that particular kernel that caused this problem isn't available in apt repository, but that doesn't matter for now. At least I know that during next upgrade it'll work. 0 Quote
Igor Posted February 9 Posted February 9 Thanks @Josua-SR! I tried with self made and this binary - we have some troubles with kernel I guess. => boot switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2996 bytes read in 15 ms (194.3 KiB/s) ## Executing script at 03000000 Boot script loaded from mmc 158 bytes read in 12 ms (12.7 KiB/s) 28834 bytes read in 27 ms (1 MiB/s) 11476654 bytes read in 1086 ms (10.1 MiB/s) 8546328 bytes read in 843 ms (9.7 MiB/s) Working FDT set to 2040000 Kernel image @ 0x2080000 [ 0x000000 - 0x826818 ] Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... Loading Boot0000 'mmc 0' failed EFI boot manager: Cannot load any image 0 Quote
Igor Posted February 9 Posted February 9 Quote Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid What is the right Ramdisk format? 0 Quote
iav Posted February 13 Posted February 13 I build fresh Armbian-unofficial_25.02.0-trunk_Helios4_plucky_edge_6.10.14 from armbian trunk (1f697206562). Image boots successfuly. Why? 0 Quote
Dee2022 Posted February 25 Posted February 25 (edited) Hi all, Today I upgraded armbian on my Helios 4. I wish I hadn't. The system won't boot anymore. Received the "Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid" message. Any hints on trying to recover from this? To be honest, I'm stuck at the moment. I recovered from this through the following steps: Get the 'original' image (although dated) from the Helios site (https://wiki.kobol.io/helios4/) Created another sd card Booted And had access again. The hardest part was recoving the old lukskey for opening the encrypted partitions from the raid array. Edited February 25 by Dee2022 0 Quote
FredK Posted February 25 Posted February 25 Same here: "No boot after upgrade to Armbian 25.2.2". Same message: Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid The very "unfriendly" behaviour was the unattended-upgrade. Therefore I had no chance first to make an update of my 24.11 system with Linux 6.6.63-current-mvebu (see signature). I had to use for recovery the backup from 24.8 immediately before 24.11 in the pipeline. The recovered system is now Armbian 24.8 with Linux 6.6.47-current-mvebu. Any chance to get 24.11 again? 0 Quote
FredK Posted February 26 Posted February 26 @Igor Is a new update to 25.2 for Helios4 planned of the kernel binaries ? If so, when can this be expected? If not, what can I do? The post of @Josua-SR is marked as solution. But I have no idea what to do with the *.kwb files from SolidRun. In particular I never made a custom build. 0 Quote
Dee2022 Posted February 26 Posted February 26 (edited) @FredK Same here. I didn't know what to do with the .kwb images. Edited February 26 by Dee2022 0 Quote
Mangix Posted February 27 Posted February 27 This is the command to flash the bootloader onto the SD card: https://wiki.kobol.io/helios4/uboot/#on-development-pc As you can tell, it's basically offset by 1 on the SD card. kernel 6.6.79 boots now. 2 Quote
FredK Posted February 27 Posted February 27 (edited) @Mangix Thank you, that was simple. @Dee2022 What I did: Download of the 1st SolidRun image (... sd.kwb) Copy the image to SDcard containing unbootable Armbian 25.2 (on my Linux desktop using dd, SDcard available here at /dev/sdf) sudo dd if=u-boot-helios-4-sd.kwb of=/dev/sdf bs=512 seek=1 status=noxfer sudo sync Boot Helios4. Voilà. Edited February 27 by FredK 1 Quote
Igor Posted February 27 Posted February 27 On 2/26/2025 at 10:29 AM, FredK said: Is a new update to 25.2 for Helios4 planned of the kernel binaries ? Nothing is planned unfortunately. It was a try if I can bring this from the dead in a couple of hours. I spent all the time I could afford to. In order to not go into the self-destruction path, we set a rules to ourselves: https://docs.armbian.com/User-Guide_Board-Support-Rules/ I can't maintain this board. It is one out of (perhaps 500 that are on the market, and one out of 100 that has some user base behind). If someone will help, and step up, to match the board support rules, this board can be lifted to standard support. It was dropped to community support about a year ago https://github.com/armbian/build/pull/6654 as we haven't heard it from its maintainer for a long time. We don't have any other alternative. I hope someone will take a look and integrate those changes into the build framework. Then we will at least a device into automated testing for early problem detections. They will certainly pop up in the future as they always does 0 Quote
FredK Posted February 27 Posted February 27 (edited) @Igor After @Mangix's post I was able to fix my installation patching the bootloader. I'm aware that Helios4 is a dead-end and I plan to switch to a 64bit-SBC providing 4 or 5 SATA-ports (but I don't find a suitable board up to now). Edited February 27 by FredK 0 Quote
Igor Posted February 27 Posted February 27 1 hour ago, FredK said: I'm aware that Helios4 is a dead-end We have many of such boards in the system Armbian mission is trying to keep them alive as long as possible. We invest a lot of efforts to keep them build-able, but there is just too many things that can go wrong in the u-boot / kernel area. Boards are constantly collapsing - if we want to keep them aligned with a modern kernel. The task is simply too big for our small team. We encourage people, owners of those (old) boards to step up and integrate those findings to the builds system, so this solution is available for everyone. 1 hour ago, FredK said: providing 4 or 5 SATA-ports We are running one mirror on Radxa ITX with success: https://www.armbian.com/newsflash/armbian-v24-11/ Software wise we are covering it well. 0 Quote
dacmot Posted February 28 Posted February 28 (edited) @FredK thank you so much for the instructions. They allowed me to boot up my helios4 again. If I may, don't buy anything ARM-based if you don't want e-waste in 5 years because there's no software support. When my helios4 finally gives up I'll get an odroid-h4+ (https://www.hardkernel.com/shop/odroid-h4-plus/) or whatever equivalent they have at that time. Edited February 28 by dacmot 1 Quote
SymbiosisSystems Posted March 3 Posted March 3 I got bitten by this and in the end rolled back to Armbian 24.2.1 with kernel 6.6.16 which seems to work fine (with zfs and omv 7). Can anyone comment as to how much work would be required to fix this issue in the 25.x development and how much time would be required to bring this board up to be supported again ? 0 Quote
Dee2022 Posted March 4 Posted March 4 @Mangix Thank you @FredK same to you. I'm now running Armbian 24.2.1 Bookworm with Linux 6.6.16-current-mvebu. And really am in a doubt to perform: sudo apt upgrade.... 0 Quote
Igor Posted March 5 Posted March 5 On 3/3/2025 at 11:42 AM, SymbiosisSystems said: how much time would be required to bring this board up to be supported again ? I estimate few days, a week, if focusing just into this problem. "Officially supported" also needs someone to act as a maintainer https://docs.armbian.com/User-Guide_Board-Support-Rules/#standard-support On a long term, not just fixing current issue. Every kernel (boot-loader) change can break features partially or completely (boot failure). 0 Quote
thermalz Posted March 7 Posted March 7 I just hit this problem today after an update to kernel 6.6.80. Thanks to @Dee2022 for the solution to fix it, but I'll add that I also needed to edit `/boot/armbianEnv.txt` on the sdcard to adjust the `rootdev=UUID=xxx` line so that the correct root device to boot from could be found. If you folks come across a low power arm board with 4xsata headers which can function as a home nas, I'd appreciate recommendations as the Helios4 is getting a little old now. 0 Quote
helios4user12 Posted March 24 Posted March 24 Without really having understood the underlying problem: I updated the sd card with the provided image via dd. Will this be a one time thing? Or which part of the upgrade process will break it again, i.e. which packages should not be updated? Thank you 0 Quote
Vodalex Posted March 24 Posted March 24 This automated installation of the kernel did put the love to the ARM based devices to an end.. Was working solid.. but without display connector it is really diffucuilt to troubleshoot what is wrong with it. After the installation of OMV over the Armbian in the newest version network stops working and I cannot see why.. Time to sell this fine HELIOS4 to someone.. 0 Quote
FredK Posted March 29 Posted March 29 @helios4user12 > I updated the sd card with the provided image via dd. Will this be a one time thing? Yes. In the meantime there were further updates and my Helios4 is still going strong. 0 Quote
Vodalex Posted March 29 Posted March 29 Updating to the current kernel immediately breaks everything.. Also the copy command of the copying u-boot-helios-4-sd.kwb is not helping in this case.. The device is not booting anymore.. Unpacking linux-image-current-mvebu (25.2.3) over (24.2.1) ... Armbian 'linux-image-current-mvebu' for '6.6.16-current-mvebu': 'postrm' starting. Armbian 'linux-image-current-mvebu' for '6.6.16-current-mvebu': 'postrm' finishing. Setting up libtext-iconv-perl:armhf (1.7-8) ... Setting up linux-image-current-mvebu (25.2.3) ... Armbian 'linux-image-current-mvebu' for '6.6.84-current-mvebu': 'postinst' starting . dkms: autoinstall for kernel 6.6.84-current-mvebu was skipped since the kernel head ers for this kernel do not seem to be installed. update-initramfs: Generating /boot/initrd.img-6.6.84-current-mvebu update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.84-curren t-mvebu Image Name: uInitrd Created: Sat Mar 29 15:48:16 2025 Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 14351524 Bytes = 14015.16 KiB = 13.69 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.84-current-mvebu to /boot/u Initrd '/boot/uInitrd' -> 'uInitrd-6.6.84-current-mvebu' update-initramfs: Armbian: done. Remove unused generated file: /boot/initrd.img-6.6.16-current-mvebu Remove unused generated file: /boot/uInitrd-6.6.16-current-mvebu Armbian: update last-installed kernel symlink to 'zImage'... '/boot/zImage' -> 'vmlinuz-6.6.84-current-mvebu' Armbian: Debian compat: linux-update-symlinks install 6.6.84-current-mvebu boot/vml inuz-6.6.84-current-mvebu I: /vmlinuz.old is now a symlink to boot/vmlinuz-6.6.84-current-mvebu I: /initrd.img.old is now a symlink to boot/initrd.img-6.6.84-current-mvebu I: /vmlinuz is now a symlink to boot/vmlinuz-6.6.84-current-mvebu I: /initrd.img is now a symlink to boot/initrd.img-6.6.84-current-mvebu Armbian 'linux-image-current-mvebu' for '6.6.84-current-mvebu': 'postinst' finishin g. Setting up armbian-zsh (25.2.3) ... cp: cannot create directory '/home/download/.oh-my-zsh': No such file or directory cp: cannot create regular file '/home/download/.zshrc': No such file or directory chown: cannot access '/home/download/.oh-my-zsh': No such file or directory chown: cannot access '/home/download/.zshrc': No such file or directory Setting up armbian-config (25.5.0-trunk.5.0206.155506) ... Setting up armbian-bsp-cli-helios4-current (25.2.3) ... Installing new version of config file /usr/lib/armbian/armbian-apt-updates ... Armbian 'armbian-bsp-cli-helios4-current' for '1-PCbbd5-V6a77-H6710-B6e44-R7697': ' postinst' starting. '/boot/boot.cmd' -> '/usr/share/armbian/boot.cmd-1743259697' NOTE: You can find previous bootscript versions in /usr/share/armbian ! Recreating boot script '/usr/share/armbian/boot.cmd' -> '/boot/boot.cmd' update-initramfs: deferring update (trigger activated) Armbian 'armbian-bsp-cli-helios4-current' for '1-PCbbd5-V6a77-H6710-B6e44-R7697': ' postinst' finishing. Setting up armbian-firmware (25.2.3) ... Processing triggers for man-db (2.11.2-2) ... Processing triggers for initramfs-tools (0.142+deb12u1) ... update-initramfs: Generating /boot/initrd.img-6.6.84-current-mvebu update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.84-curren t-mvebu Image Name: uInitrd Created: Sat Mar 29 15:48:45 2025 Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 14378902 Bytes = 14041.90 KiB = 13.71 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.84-current-mvebu to /boot/u Initrd '/boot/uInitrd' -> 'uInitrd-6.6.84-current-mvebu' update-initramfs: Armbian: done. 0 Quote
Vodalex Posted March 30 Posted March 30 I solved the problems with the updates by completely disabling the kernel and firmware updates.. the board is alive and running great with OpenMediaVault .. All unattended updates were disabled completely. I hope the will be a stable kernel for this device in the future. Running it with 6.6.16 kernel which came with the image.. 0 Quote
Bendito999 Posted April 12 Posted April 12 Fred K's February 27 instructions worked great for me as well. It rescued my Helios4 using OMV without any data loss. Thank you! Someone had mentioned that they had trouble downloading https://images.solid-run.com/A38X/U-Boot/v2024.04/2025-02-08_695f767/u-boot-helios-4-sd.kwb I had trouble as well, but how was able to get it was go to the parent folder in that URL, then click on the u-boot-helios-4-sd.kwd file shown there, and that downloaded perfectly fine for me (not sure why the direct link didn't want to work). 0 Quote
djurny Posted 5 hours ago Posted 5 hours ago (edited) Hi there, Some other solution that I have not been able to make "permanent" yet. Thanks @FredK@Josua-SR and @Igor for allowing me to have some fun building U-Boot once more (have not built a U-Boot since i think 2006!), it for sure did bring back some good memories 🙂 Unfortunately the built U-Boot (with SDHCI_SDMA disabled) did not solve my issue. Then i decided to revert back to the previous release (*-6.6.87-current-mvebu => *-6.6.43-current-mvebu) by moving the symlinks in /boot around, which at least allowed the kernel and some userspace to boot. But due to lacking kernel modules (the 6.6.43 were removed during upgrade to 6.6.87) the box itself did not really work. After some inspection, based on the remarks from @Josua-SR about memory corruption, i decided to check if this might not be just a simple overlapping issue with the images, e.g. kernel image partially occupying where the initrd is loaded. Kernel image Size Size (hex) vmlinuz-6.6.43-current-mvebu 7170736 0x6d6ab0 vmlinuz-6.6.87-current-mvebu 8858728 0x872c68 Loading of files is done as follows: fdt (dtb) 0x2040000 (0x840000 max size) ramdisk (uInit) 0x2880000 kernel (vmlinuz) 0x2080000 (0x7fffff max size) You can already spot that the kernel image will not fit into the area that U-Boot has designated for it: 0x872c68 > 0x7fffff. whereas the 6.6.43 kernel should fit fine: 0x6d6ab0 < 0x7fffff. Some testing showed that when setting ramdisk_addr_r to a higher value - which should fit the bigger kernel image - things started to boot again: => setenv ramdisk_addr_r 2980000 => boot switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2996 bytes read in 210 ms (13.7 KiB/s) ## Executing script at 03000000 Boot script loaded from mmc 176 bytes read in 201 ms (0 Bytes/s) 28834 bytes read in 424 ms (66.4 KiB/s) 11504908 bytes read in 2562 ms (4.3 MiB/s) 8858728 bytes read in 2218 ms (3.8 MiB/s) ## Loading init Ramdisk from Legacy Image at 02980000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11504844 Bytes = 11 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 02040000 Booting using the fdt blob at 0x2040000 Loading Ramdisk to 0f507000, end 0ffffccc ... OK reserving fdt memory region: addr=2040000 size=6d000 Loading Device Tree to 0f497000, end 0f506fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 Next is to try and figure out how I could change ramdisk_addr_r (the initial spot where U-Boot wants to load the ramdisk into), as I prefer not to have to type this at the U-Boot prompt every single time i reboot the box. Hope this helps someone out there with similar issue. Update: I built a U-Boot from the Kobol repo (https://wiki.kobol.io/helios4/uboot/#u-boot-2018) with the SDHCI_SDMA option disabled, and different memory load addresses for the ramdisk, script and efi stuff, see attached. Note i had some issues with the scripts/dtb, some yylloc variable had to be defined as external due to some linker error. in "scripts/dtc/dtc-lexer.lex.c" i had to change line 618 to: extern YYLTYPE yylloc; To update the memory load addresses, in "include/configs/helios4.h": #define KERNEL_ADDR_R __stringify(0x2080000) #define FDT_ADDR_R __stringify(0x2040000) #define RAMDISK_ADDR_R __stringify(0x3000000) #define SCRIPT_ADDR_R __stringify(0x4000000) #define PXEFILE_ADDR_R __stringify(0x4100000) Essentially moved RAMDISK_ADDR_R from 0x0288'0000 to 0x0300'0000 to allow for larger kernel image and moved SCRIPT_ADDR_R (a.o.) to make room for the ramdisk image, from 0x0300'0000 to 0x0400'0000. Then to write the U-Boot single page loader image out to the SDcard: sudo dd if=u-boot-spl.kwb of=/dev/mmcblk0 seek=1 bs=512 Groetjes, PS Warranty until the door for the attached U-Boot.... u-boot-spl.kwb Edited 4 hours ago by djurny added built U-Boot SPL image with change memory load addresses 0 Quote
