abcd567 Posted Tuesday at 04:10 PM Posted Tuesday at 04:10 PM WiFi is missing in "Armbian_25.5.0-trunk.428_Rpi4b_trixie_current_6.12.22_minimal.img" Solved by following commands ``` sudo apt update sudo apt install firmware-brcm80211 --fix-broken sudo reboot ``` 0 Quote
Werner Posted Tuesday at 04:29 PM Posted Tuesday at 04:29 PM Maybe related https://github.com/armbian/build/pull/8087 0 Quote
Igor Posted 19 hours ago Posted 19 hours ago Trixie ... let me check and fix this. I only tested Bookworm. 0 Quote
abcd567 Posted 10 hours ago Author Posted 10 hours ago Upgrading: pi@pi-1-Armbian-trixie:~$ apt list --upgradable armbian-bsp-cli-rpi4b-current/trixie 25.5.0-trunk.438 arm64 [upgradable from: 2> linux-dtb-current-bcm2711/trixie 25.5.0-trunk.438 arm64 [upgradable from: 25.5.> linux-image-current-bcm2711/trixie 25.5.0-trunk.438 arm64 [upgradable from: 25.> When issued command "sudo apt upgrade", upgrade did take place, but when it reached finishing stage, got following errors: Armbian 'linux-image-current-bcm2711' for '6.12.22-current-bcm2711': 'postinst' starting. update-initramfs: Generating /boot/initrd.img-6.12.22-current-bcm2711 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 ERROR: Unsupported initramfs version (6.12.22-current-bcm2711) ERROR: Unsupported kernel version (6.12.22-current-bcm2711) update-initramfs: Generating /boot/initrd.img-6.12.22-current-bcm2711 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 ERROR: Unsupported initramfs version (6.12.22-current-bcm2711) 0 Quote
Igor Posted 5 hours ago Posted 5 hours ago Warnings are safe to ignore, happens on other platforms too, but it looks like also error. CONFIG_USB_RTL8152=y -> m should probably do. I will make a config change: https://github.com/armbian/build/pull/8116 I have noticed the initramfs error too, but it doesn't looks it breaks anything. Need to be investigated. 0 Quote
abcd567 Posted 5 hours ago Author Posted 5 hours ago Thanks @Igor for your prompt attention and help. Yes, you are right. The error messages I posted in my last post do NOT break anything, but these are very irritating. 0 Quote
abcd567 Posted 59 minutes ago Author Posted 59 minutes ago (edited) Off-topic, but related to "trixie / sid" on RPi4 On a freshly written 64-bit raspberrypi os bookworm (Lite) image, replaced word "bookworm" by "trixie" in following two files: "/etc/apt/sources.list" and "/etc/apt/sources.list.d/raspi.list" . After above modifications, ran following commands: sudo apt update sudo apt full-upgrade sudo apt autoremove sudo apt autoclean sudo reboot The upgrade command took about half an hour to complete, and upgraded 470 packages. No issues during & after upgrade. Everything is OK. Edited 50 minutes ago by abcd567 0 Quote
