walt22 Posted October 15, 2017 Share Posted October 15, 2017 Hello, will there be a dedicated Armbian version for NanoPi Duo? I have tried Armbian_5.33.171013_Nanopineo_Ubuntu_xenial_next_4.13.5.img, which worked on the Duo. Mosquitto, Node-RED and WiringOR could be installed without problems. One thing doesnt work until now is WLAN, which is not recognized by nmcli dev. Would be fine to get a validated Duo version. Regards, Walter Link to comment Share on other sites More sharing options...
chwe Posted October 15, 2017 Share Posted October 15, 2017 There you go.... (second post by searchengine below your post). Link to comment Share on other sites More sharing options...
walt22 Posted October 16, 2017 Author Share Posted October 16, 2017 Thanks chwe for your comment. What I understood until now: - There is no dedicated Armbian for NanoPi Duo. - In case one use the Neo version, the XR819 WiFi driver must be installed manually. I have made an inquiry, but cannot interprete it: root@nanopineo:~# modinfo xradio_wlan filename: /lib/modules/4.13.5-sunxi/kernel/drivers/net/wireless/xradio/xradio_wlan.ko alias: xradio_core license: GPL description: XRadioTech WLAN driver core author: XRadioTech alias: sdio:c*v0020d2281* depends: mac80211,cfg80211 intree: Y name: xradio_wlan vermagic: 4.13.5-sunxi SMP mod_unload ARMv7 thumb2 p2v8 root@nanopineo:~# No hint on XR819. Regards Walter Link to comment Share on other sites More sharing options...
Igor Posted October 16, 2017 Share Posted October 16, 2017 1 hour ago, walt22 said: No hint on XR819 The driver is present but you need to apply proper board settings. Link to comment Share on other sites More sharing options...
walt22 Posted October 17, 2017 Author Share Posted October 17, 2017 The driver is present but you need to apply proper board settings. Thanks Igor, is there a docu available for the proper board settings? Regards, Walter Link to comment Share on other sites More sharing options...
Larry Bank Posted October 17, 2017 Share Posted October 17, 2017 3 hours ago, walt22 said: The driver is present but you need to apply proper board settings. Thanks Igor, is there a docu available for the proper board settings? Regards, Walter I've been hitting similar issues trying new builds on various boards. I find it much less stressful to just use a USB wifi dongle when doing these kinds of tests. I'm running Armbian with a 4.13 kernel built for the Orange Pi Zero on my NanoPi Duo and with a USB wifi dongle, it works fine: The Linux build provided by FriendlyElec has a super slow SPI driver, so I went in search of a way to see if it was a hardware or software bug. Running the OPZ build of Armbian on the Duo shows that it's purely a software bug. 1 Link to comment Share on other sites More sharing options...
raschid Posted October 17, 2017 Share Posted October 17, 2017 6 hours ago, walt22 said: is there a docu available for the proper board settings? Mainline linux uses a "device tree" data structure to represent specific properties of board hardware (such as wlan chips). Device tree files are usually part of the kernel building process - and at the moment there is no such file for the NanoPi Duo in the armbian kernel build environment (it would be called something like <sun8i-h2-plus-nanopi-duo.dts>). Alternatively there is a mechanism to adapt device tree entries for an existing kernel referred to as device tree overlays. An example for such an overlay explicitly for integrating an xradio wlan chip (for an orange pi zero) can be found at https://github.com/karabek/xradio/ (see file <xradio-mrk1.dts> in directory <dts>. Link to comment Share on other sites More sharing options...
walt22 Posted October 18, 2017 Author Share Posted October 18, 2017 @Larry and Raschid, Many thanks for your hints. I will try the OrangePi zero version either with dongle and XR819 driver. Best regards Walter Link to comment Share on other sites More sharing options...
raschid Posted October 31, 2017 Share Posted October 31, 2017 @walt22/ @Larry Bankthere is a "community supported" armbian config for the NanoPi Duo now, supporting the Xradio WLAN chip - gives me 20-22Mbit/s over 1,5m. To build the kernel you have to specify the board in the compile command ("compile.sh BOARD=nanopi-duo") in the armbian dev environment. Link to comment Share on other sites More sharing options...
Igor Posted November 1, 2017 Share Posted November 1, 2017 I upload an image: https://dl.armbian.com/nanopiduo/nightly/. Boot logs: http://sprunge.us/OhHi ... besides WiFi and ethernet, USB ports are up. I did not test header functions ... mSATA in the position as on picture is not recognized. I am not sure this part is powered at all. Link to comment Share on other sites More sharing options...
tkaiser Posted November 1, 2017 Share Posted November 1, 2017 23 minutes ago, Igor said: mSATA in the position as on picture is not recognized Your lsusb output looks like USB DT overlays are missing... Link to comment Share on other sites More sharing options...
Igor Posted November 1, 2017 Share Posted November 1, 2017 mSATA works when enabling other USB ports http://sprunge.us/AffX Link to comment Share on other sites More sharing options...
raschid Posted November 1, 2017 Share Posted November 1, 2017 All pins of the DUO module are routed the the shield's GPIOs (or audio components), except for the tweo USB lines (2&3). So I guess one USB line feeds into a 4xhub for the shields USB ports and the other drives the mSATA converter. Link to comment Share on other sites More sharing options...
tkaiser Posted November 1, 2017 Share Posted November 1, 2017 10 minutes ago, raschid said: So I guess one USB line feeds into a 4xhub for the shields USB ports and the other drives the mSATA converter. usb0 is OTG and IIRC Armbian's next kernel still not enables this port (TBC -- should be easy trying out the Micro USB port) usb3 is activated in sun8i-h3-nanopi.dtsi and this is obviously the port the Terminus USB hub is connected to So overlays=usbhost1 usbhost2 should be sufficient for 'Shield operation' (though no idea whether both are needed and if only one which one -- @Igor can you do two reboots and find out?) Edit: Should be usbhost2 since @raschid wrote 'USB lines (2&3)' above. Link to comment Share on other sites More sharing options...
raschid Posted November 1, 2017 Share Posted November 1, 2017 It is usbhost2. I don't have the shield, but I checked the USB ports on the DUO. No port 1 there ... Link to comment Share on other sites More sharing options...
Igor Posted November 1, 2017 Share Posted November 1, 2017 usbhost2 is needed for mSATA http://sprunge.us/HWEa Link to comment Share on other sites More sharing options...
tkaiser Posted November 1, 2017 Share Posted November 1, 2017 IMO we should consider shipping with overlays=usbhost2 added to /boot/armbianEnv.txt by default for this board since zero disadvantages but only avoiding support efforts and 'reviews' ('With Armbian mSATA does not work'). Users don't read the fineprint, so let's fix this now and not later. On a related note: I did some tests with zram and vm.swappiness=100 and this really looks promising. Could be a real improvement on those boards with low memory where we can ensure that no legacy kernels will be used. Edit: Or maybe it's better to add ohci2/ehci2 nodes to the DT patch since referencing sun8i-h3-nanopi.dtsi there and activating usb3 by default can already be considered 'wrong' from a kernel dev's perspective (for reasons unknown to me these guys want to reduce 'user experience') 1 Link to comment Share on other sites More sharing options...
Igor Posted November 1, 2017 Share Posted November 1, 2017 13 minutes ago, tkaiser said: IMO we should consider shipping with Yes. And not just here. We discussed this briefly here https://github.com/armbian/build/issues/798 but it was off topic and we didn't continue. 13 minutes ago, tkaiser said: On a related note: I did some tests with zram and vm.swappiness=100 and this really looks promising. Could be a real improvement on those boards with low memory where we can ensure that no legacy kernels will be used. 2 Shall we simply add this to armbian-config? 1 Link to comment Share on other sites More sharing options...
guidol Posted November 1, 2017 Share Posted November 1, 2017 1 hour ago, tkaiser said: IMO we should consider shipping with overlays=usbhost2 added to /boot/armbianEnv.txt by default for this board since zero disadvantages but only avoiding support efforts and 'reviews' ('With Armbian mSATA does not work'). Users don't read the fineprint, so let's fix this now and not later. http://wiki.friendlyarm.com/wiki/index.php/Mini_Shield_for_NanoPi_Duo The mini shield has an onboard JMS567 USB to SATA IC and an mSATA interface. The Duo also uses the same JMS567 USB3.0 to SATA Chip as the "1-bay NAS Kit v1.2 for NanoPi NEO&NEO2":http://www.friendlyarm.com/index.php?route=product/product&product_id=192 So it would be fine if the NanoPi Neo(2) with 1-bay NAS Kit can benefit from the NanoPi Duo version Maybe also for the missing frontright USB-Port of the Case? Could it be the Neo(2) NAS version ofhttp://wiki.friendlyarm.com/wiki/index.php/Mini_Shield_for_NanoPi_Duo The mini shield has an onboard FE1.1s which extends four USB Host ports. - so that has to be activated? PS: on a old page for the Neo(2) NAS v1.2 they do write about the former JM20329 USB2.0 to SATA Chip version:http://wiki.friendlyarm.com/wiki/index.php/1-bay_NAS_Dock_v1.2_for_NanoPi_NEO/NEO2 Link to comment Share on other sites More sharing options...
tkaiser Posted November 1, 2017 Share Posted November 1, 2017 3 minutes ago, guidol said: So it would be fine if the NanoPi Neo(2) with 1-bay NAS Kit can benefit from the NanoPi Duo version Maybe also for the missing frontright USB-Port of the Case? Huh? I don't get what you're talking about. The issue we're talking here about is that some small H3 and H5 boards by default expose only 2 USB ports (usb0 == OTG/MicroUSB and usb1 on OrangePi Zero variants while it's usb3 NanoPi NEO/NEO2/NEO Plus 2 -- man, how I hate these shitty names!). So all that's needed is either first line (for Orange Pi Zeroes or NanoPi Duo) or 2nd line for NanoPi NEO variants: overlays=usbhost2 usbhost3 overlays=usbhost1 usbhost2 And as @zador.blood.stained explained over there an USB gadget driver is needed for usb0 to work with mainline kernel. In other words: Using USB on these little gems with stinky Allwinner legacy kernel is a nice and flawless experience while with mainline kernel it's just PITA since kernel devs decided so (IMO there's a reason why Apple as company is successful: since there product development is not driven by engineers trying to solve technical problems but folks who think about stuff from the 'user perspective') Link to comment Share on other sites More sharing options...
tkaiser Posted November 2, 2017 Share Posted November 2, 2017 On 1.11.2017 at 10:34 AM, Igor said: Shall we simply add this to armbian-config? Will never work since average users don't give a shit about improving things. And if they enabled zram via armbian-config everything bad that will happen within the next 3 months (eg. SD card dying) will lead to zram being blamed. Let's continue discussion over there. Link to comment Share on other sites More sharing options...
raschid Posted November 5, 2017 Share Posted November 5, 2017 @Igor Very small issue: The DUO is a H2+ device. Any specific reason why it is flagged a a H3 board on the armbian dowload page? People will not find it when they hit the <H2+> button on the download page ... Link to comment Share on other sites More sharing options...
Igor Posted November 5, 2017 Share Posted November 5, 2017 Thank you. Fixed. Link to comment Share on other sites More sharing options...
