Jeedom Cassivet Posted 10 hours ago Posted 10 hours ago (edited) Armbianmonitor: https://paste.armbian.com/alokoquduw Hello. It seems there is an issue with iptables in the 6.18.10-current-meson64 kernel. I can't start Docker because of this. ``` ~# iptables -L modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.18.10-current-meson64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. ``` As I run a docker version 28.X.X, it does not support nftable. (Cannot upgrade at the moment). What can I do to solve the problem ? Thanks Edited 8 hours ago by Jeedom Cassivet 0 Quote
Werner Posted 6 hours ago Posted 6 hours ago https://github.com/armbian/build/blob/b8eab09ef561f2d03956098d26351d323a3b2d7b/config/kernel/linux-meson64-current.config#L355 Check your /lib/modules directory if it is present. It should be. 0 Quote
Jeedom Cassivet Posted 6 hours ago Author Posted 6 hours ago (edited) Thanks for your answer. I very sorry to ask you one more things please. How can I check if module is present. In modules files in "/lib/modules/6.18.10-current-meson64" ? I tried to do this : # cd /lib/modules/6.18.10-current-meson64 # grep -r "iptables" . Answer grep: ./net/ipv4/netfilter/ipt_rpfilter.ko : fichiers binaires correspondent grep: ./net/bridge/br_netfilter.ko : fichiers binaires correspondent I not an expert PS : I'am on Minimal / IOT version. Maybe it's the reason ? Thanks Edited 6 hours ago by Jeedom Cassivet 0 Quote
Igor Posted 1 hour ago Posted 1 hour ago 8 hours ago, Jeedom Cassivet said: It seems there is an issue with iptables in the 6.18.10-current-meson64 kernel. Did you perhaps upgrade kernel and forgot to reboot? 0 Quote
