It seems like all the OS available for the A64 (for me specifically the orangepi winplus) are using the 3.10 kernel that has reached the EOL.  I have been advised against using this kernel but I don't see any other options.  I did find and armbian for the winplus that used 4.11 but it crumbled after upgrade every time.  Does anyone have any advice for me?
Thanks
you'll need to stick with 3.10 for the moment. 4.xx has several issues which will be fixed but not yet.
not much you can do
  On 4/18/2018 at 5:41 AM, Hannes Worst said:
As an experiment i tried running Arch Linux on my NanoPi a64 with 4.15.0-rc5. It's a pine64 image . To my total surprise it works. But it's no Armbian though...
Expand
Any idea why a Arch pine64 image does start on the NanoPi A64 and why the armbian pine64 image doesnt/shouldnt start?
I also got a NanoPi A64 at home, but using it with  NanoPi A64 Ubuntu Xenial Xerus 16.04 LXDE OS Image
Kernel version 3.10.105 with Blue Led (heartbeat)
https://github.com/avafinger/nanopi-a64-firmware
BTW: does the Xfce4 Desktop start on the NanoPi A64?
Actually, I have no idea why armbian won't boot on the nanopi A64. I can see some u-boot-activity but after that the board goes to a halt. It has to be a kernel issue in my perspective but I have no serial cable so I can't check anything. Sorry that I can't be of more help in this.
The arch-linux image boots fine, gives a fully functional xfce-desktop, automatically in the proper resolution (for me currently 1440x900). I had only to attach a wifi dongle for internet. Sound works flawless to.
Expand
I do have a serial cable. If i do find the time this evening I'll check the output AND I'll test the arch-linux :)
I hadnt to install the serial cable :) (but see complete u-boot messages above at the second spoiler)
I did download and flash to uSD: Armbian_5.43.180417_Pine64_Debian_stretch_next_4.14.34-7z
After some short U-Boot Messages at the HDMI screen I did get a flashing cursor for about 10 seconds and then I did see the logon screen from armbian:
Debian GNU/Linux 9 pine64 tty1
pine64 login:
 ARMBIAN 5.43.180417 nightly Debian GNU/Linux 9 (stretch) 4.14.34-sunxi64
Linux nanopi-a64 4.14.34-sunxi64 #9 SMP Tue Apr 17 13:49:33 CEST 2018 aarch64 GNU/Linux
there is a error message for eth0 in u-boot for the follwing device: dwmac-sun8i 1c30000.ethernet eth0
erros in dmesg:
  Reveal hidden contents
and aplay didnt found any soundcard
aplay: device_list:270: no soundcards found...
For getting a network interface I used a USB-Ethernet-device
armbian doesnt seem to know the RTL8211E-Ethernet device
neither with firmware-realtek nor with armbian-firmware-full
armbianmonitor -u
System diagnosis information will now be uploaded to http://ix.io/187P
but for you and maybe others I connected the serial port for the u-boot messages:
1GB memory is recognized :)
Couldnt change keyboard to german via dpkg-reconfigure keyboard-configuration or armbian-config.
OK I could change, but allways did get US-keyboard :(
  On 4/18/2018 at 6:52 PM, Hannes Worst said:
That's great! You did manage to get further than I did last time. It's time I try again. :) Thank you!
Expand
Yes :) but also the WiFi RTL8189ETV isnt recognized (and no loadable module) :(
The CPU is running VERY COOL ;)
armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
22:11:48:   ---      0.00   0%   0%   0%   0%   0%   0% -6171°C
22:11:53:   ---      0.00   0%   0%   0%   0%   0%   0% -6534°C
for testing I did try the Banana Pi M64 (work in progress) Image
( https://dl.armbian.com/bananapim64/Debian_stretch_next_nightly.7z )
on the NanoPi A64, because the BPi M64 also should have the RTL8211E Ethernet-Chip.
But RTL8211E isnt recognized and a USB-Ethernet doesnt work after configuration.
Only a USB-WiFi Dongle did work to connect to the net.
So the BPi M64 image isnt as much useable as the one for the Pine64 on the NanoPi A64
next try :)
today I did try the -at this time- actual image for the Banana Pi M64 on the NanoPi A64:
Armbian_5.59_Bananapim64_Debian_stretch_next_4.14.65
OK - I knew the image isnt made for the NanoPi A64 - but as information to @Igor I got sometimes the same boot error as I did seen the last week with another systems here in the forum (which had boot problems after the update). I will attach the image here in this message.
With an active hub from D-Link the system doenst came up wit the Keyboard-Dongle/USB-Ethernet and USB-Soundcard.
After I removed the USB-Soundcard from the active Hub the NanoPi A64 did boot.
After initial getting the boot error the system booted with a blinking cursor to the login prompt.
Like the 5.41 image before onboard-eth0 / leds nor the onboard-soundcard isnt recognized.
First I did try like before a USB-Ethernet adapter - but I had to find out that only the lower USB-port is working
(in the first try I got a wireless USB-Keyboard at the lower USB-port and the USB-Network at the upper USB-port) - so the network wasnt found.
After I did try the keyboard in the upper port and seeing that it isnt recognized I did put a passive USB-Hub in the lower USB-port and now I can use the USB-Keyboard and the USB-Network-Dongle :)
The image 5.59 has been updated to
root@nanopi-m64(192.168.6.64):~# dpkg -l|grep 5.60
ii  armbian-config                      5.60                           all          Armbian configuration utility
ii  armbian-firmware                    5.60                           all          Linux firmware
ii  armbian-tools-stretch               5.60                           arm64        Armbian tools, Cubie bt utils
ii  hostapd                             3:2.6-99~armbian5.60+1         arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
ii  linux-dtb-next-sunxi64              5.60                           arm64        Linux DTB, version 4.14.70-sunxi64
ii  linux-image-next-sunxi64            5.60                           arm64        Linux kernel, version 4.14.70-sunxi64
ii  sunxi-tools                         1.4.2-2~armbian5.60+1          arm64        tools for working with Allwinner (sunxi) ARM processors
but Welcome-Message did show 5.59
ARMBIAN 5.59 testing Debian GNU/Linux 9 (stretch) 4.14.70-sunxi64
Linux nanopi-m64 4.14.70-sunxi64 #274 SMP Wed Sep 19 12:09:30 CEST 2018 aarch64 GNU/Linux
System diagnosis information has been uploaded to http://ix.io/1nAF
Expand
That's due to package 'linux-stretch-root-next-bananapim64' remaining at 5.59.
I don't understand this since years. The mechanism is broken, confuses users and generates unnecessary support requests. Why not fixing it or at least always update this package too with version bumps?
Expand
With the latest update, it should be 5.60 ... but perhaps after reboot/logout/login?
Well, perhaps it's time to enforce some already proposed naming for a version of Armbian and use this numbering only for our internal process.
Armbian 2018.10
Armbian 18.04
Armbian Some_Generic_Names
Let's make a separate topic or attach to existing for those changes.
Expand
With the "latest update" - just a few seconds before..... I did get
arm64 armbian-config all 5.61
but the "root"-package is at 5.59:    linux-stretch-root-next-bananapim64 5.59
Maybe because of ARMBIAN 5.59 testing Debian GNU/Linux 9 (stretch) 4.14.70-sunxi64 ?
Expand
Probably because it is still .wip and packages are made only for .conf ... not 100% sure but possible.
  On 6/16/2018 at 9:10 PM, guidol said:
not for the NanoPi A64 with armbian - but somebody is working on a kernel 4.4.111 at
http://www.friendlyarm.com/Forum/viewtopic.php?f=53&t=1543
Expand
Thanks to @lex I could test a version of this image:
Ubuntu 18.04.1 LTS (GNU/Linux 4.4.117-a64 aarch64)
Linux nanopi-a64 4.4.117-a64 #1 SMP PREEMPT Wed Sep 26 19:23:53 -03 2018 aarch64 aarch64 aarch64 GNU/Linux
where eth0, Wifi and HDMI-Sound does work :)
For his image I did create a NanoPi A64 Boot-Logo (visible because of Android kernel) - here as attachment :)
  On 10/15/2018 at 8:58 PM, rocka said:
Can I test this image? Is it available?
Expand
you have to ask @lex here in the forum or in the thread of the friendlyarm-forum,
because at this time it seems that this image isnt public
