AndrewDB Posted February 27, 2019 Posted February 27, 2019 1 hour ago, borygo77 said: Thank you for your reply Andrew. But this is not answer I was looking for 😉 What I'm asking is if there's a way to format/change partition tables on Nand from armbian 😊 Of course there is a way. 1. Load the NAND driver. 2. Use fdisk. 3. Pray the gods of hacking that everything goes smoothly. Remember that if you brick your TV box, you can always restore it using the SD card method. 😎
borygo77 Posted February 27, 2019 Posted February 27, 2019 Think I will give it a go then 😉 Just wondering if there is some sensitive part of box or partition I need to leave untouched like boot partition ? Sorry but got no idea how it boots if I'm booting from sd card 🙈
AndrewDB Posted February 27, 2019 Posted February 27, 2019 1 hour ago, borygo77 said: Think I will give it a go then 😉 Just wondering if there is some sensitive part of box or partition I need to leave untouched like boot partition ? Sorry but got no idea how it boots if I'm booting from sd card 🙈 Like for any other Android TV box, before you go writing the NAND, install TWRP and make a complete backup, or test the SD card recovery / USB cable methods first. In other words, test that you can unbrick it before you do anything that might brick it. 1
borygo77 Posted February 27, 2019 Posted February 27, 2019 There is no TWRP for my box Couldn't find one which I could install or boot from sd... Got img file with android which works using USB Burning tool so I think that's enough. Even if I brick it I'm not gonna cry as it was bought in 2016 so it's time for new box
talraash Posted February 27, 2019 Posted February 27, 2019 2 hours ago, AndrewDB said: Remember that if you brick your TV box, you can always restore it using the SD card method. 😎 Not always. If you break the u-boot being in nand there may be problems. If the u-boot in nand is broken, it was possible to restore the operation of the box only by closing the nand contacts and writing the correct u-boot or full image.
AndrewDB Posted February 27, 2019 Posted February 27, 2019 3 minutes ago, talraash said: Not always. If you break the u-boot being in nand there may be problems. Earlier in the case of not just deleting, but the u-boot failures in nand, it was possible to restore the work of the box only by closing the nand contacts and write correct u-boot or full image. I stand corrected, thank you talraash. And yes, sometimes you have to go and short some pins on the NAND to be able to flash it.
Reddwarf Posted February 28, 2019 Posted February 28, 2019 On 2/26/2019 at 3:34 PM, balbes150 said: New image 5.76 kernel 5.0 . "No support for the cards voltage", unable to boot on S905 (MiniMxIII/MiniM8S).
balbes150 Posted February 28, 2019 Author Posted February 28, 2019 8 minutes ago, Reddwarf said: "No support for the cards voltage", unable to boot on S905 (MiniMxIII/MiniM8S). Now checked on Tronsmart Vega S95 Telos (S905). The system starts normally and works with SD card or USB flash drive. Works USB, wired network, sound, test video plays without problems. Either you have a defective Sd card or card reader on the TV box, or not the correct DTB. Or the image is incorrectly written.
Reddwarf Posted February 28, 2019 Posted February 28, 2019 12 hours ago, balbes150 said: Now checked on Tronsmart Vega S95 Telos (S905). The system starts normally and works with SD card or USB flash drive. Works USB, wired network, sound, test video plays without problems. Either you have a defective Sd card or card reader on the TV box, or not the correct DTB. Or the image is incorrectly written. Cardreader is not defective, SD card tests fine on other computers. I'm using the p200 dtb.
balbes150 Posted March 1, 2019 Author Posted March 1, 2019 9 hours ago, Reddwarf said: Cardreader is not defective, SD card tests fine on other computers. I'm using the p200 dtb. gxbb-vega-s95-*.dtb
balbes150 Posted March 1, 2019 Author Posted March 1, 2019 Pay attention, many S905 is used with legacy u-boot. Therefore, do not try to install the latest versions in eMMC. The regular u-boot will be destroyed and you will need to restore the firmware via a USB cable or from a bootable SD card. 1
Sparkx Posted March 1, 2019 Posted March 1, 2019 On 2/27/2019 at 10:58 AM, balbes150 said: What is currently installed in eMMC ? Hi Balbes, It was a previous build (also yours) with debian.
balbes150 Posted March 1, 2019 Author Posted March 1, 2019 5 hours ago, Sparkx said: It was a previous build (also yours) with debian. Show the whole output when you run the script "/root/install.sh".
borygo77 Posted March 2, 2019 Posted March 2, 2019 19 hours ago, balbes150 said: Show the whole output when you run the script "/root/install.sh". root@aml:~# /root/install.sh Start script create MBR and filesystem Start backup u-boot default dd: failed to open '/dev/mmcblk1': No such file or directory Start create MBR and partittion Error: Could not stat device /dev/mmcblk1 - No such file or directory. Error: Could not stat device /dev/mmcblk1 - No such file or directory. Error: Could not stat device /dev/mmcblk1 - No such file or directory. Start restore u-boot dd: failed to open '/boot/u-boot-default.img': No such file or directory dd: failed to open '/boot/u-boot-default.img': No such file or directory Done Start copy system for eMMC. Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24) mkfs.vfat: unable to open /dev/mmcblk1p1: No such file or directory done. mount: /ddbr/install: special device /dev/mmcblk1p1 does not exist. Cppying BOOT...done. Edit init config...done. umount: /ddbr/install: not mounted. Formatting ROOT partition... The file /dev/mmcblk1p2 does not exist and no size was specified. e2fsck 1.44.1 (24-Mar-2018) e2fsck: No such file or directory while trying to open /dev/mmcblk1p2 Possibly non-existent device? done. Copying ROOTFS. mount: /ddbr/install: special device /dev/mmcblk1p2 does not exist. Copy BIN Create DEV Copy ETC Copy HOME Copy LIB Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR tar: var/log/syslog: file changed as we read it tar: var/log/kern.log: file changed as we read it Copy fstab umount: /ddbr/install: not mounted. ******************************************* Complete copy OS to eMMC ******************************************* I do have nand box and count't see any device except dev/sda usb drive with armbian installed using fdisk -l
balbes150 Posted March 2, 2019 Author Posted March 2, 2019 55 minutes ago, borygo77 said: I do have nand box and count't see any device except dev/sda usb drive with armbian installed using fdisk -l If you have NAND, you will not be able to install new versions with kernel 4 and 5 in NAND. These kernels only work with eMMC. 1
borygo77 Posted March 2, 2019 Posted March 2, 2019 That's what I tought Where do I download 3.14 kernel version ?
Reddwarf Posted March 2, 2019 Posted March 2, 2019 On 3/1/2019 at 7:49 AM, balbes150 said: gxbb-vega-s95-*.dtb Ok, so it runs with the gxbb-vega-s95 dtb's, which begs the question: Is the p200 dtb not properly configured? It is, after all, a p200 board... Anyway, WiFi and ethernet works, video plays fairly fine, neither sound nor BT works. (BT works with external dongle), but picture does not come back after screen has been switched off due to inactivity.
borygo77 Posted March 2, 2019 Posted March 2, 2019 40 minutes ago, balbes150 said: If you have NAND, you will not be able to install new versions with kernel 4 and 5 in NAND. These kernels only work with eMMC. Is this the one with 3.14 kernel ? Armbian_5.34_S9xxx_Ubuntu_xenial_4.9.40_server_20171112.img
balbes150 Posted March 2, 2019 Author Posted March 2, 2019 10 minutes ago, borygo77 said: 4.9.40 kernel 4
borygo77 Posted March 2, 2019 Posted March 2, 2019 1 minute ago, balbes150 said: kernel 4 can you point me to proper one please ?
guidol Posted March 2, 2019 Posted March 2, 2019 1 minute ago, borygo77 said: can you point me to proper one please ? take a look here: https://yadi.sk/d/pHxaRAs-tZiei/5.37 kernel 3.14.29 1
JonSmith Posted March 3, 2019 Posted March 3, 2019 Hi, I downloaded this image here: https://yadi.sk/d/srrtn6kpnsKz2/Linux/ARMBIAN/5.76/S905/4.20/Armbian_5.76_Aml-s905_Ubuntu_bionic_default_4.20.5_desktop_20190224.img.xz However the screen resolution is only 720p. How do I change it? The previous information about a hdmi.sh file is no longer valid (the file does not exist).
Reddwarf Posted March 3, 2019 Posted March 3, 2019 2 hours ago, JonSmith said: Hi, I downloaded this image here: https://yadi.sk/d/srrtn6kpnsKz2/Linux/ARMBIAN/5.76/S905/4.20/Armbian_5.76_Aml-s905_Ubuntu_bionic_default_4.20.5_desktop_20190224.img.xz However the screen resolution is only 720p. How do I change it? The previous information about a hdmi.sh file is no longer valid (the file does not exist). Have you tried Settings - display? (in Armbian)
JonSmith Posted March 3, 2019 Posted March 3, 2019 Thanks, after adding the correct resolution with xrandr I was able to change it via the settings menu.
balbes150 Posted March 5, 2019 Author Posted March 5, 2019 The new version of the image with the kernel 5.76 5-rc8. Please note that the image files have replaced the previous versions of the files on the site. The new kernel adds support for BT on VIM2 (S912), but the BT audio output does not work yet (the sound stutters, you need to change the settings and perhaps the firmware file). Also fixed DTB files for Vega S95 (s905). Tested on Tronsmart Vega S95 Telos. The system starts normally and works with external media (wired network, sound, BT).
wsgtrsys Posted March 5, 2019 Posted March 5, 2019 thanks balbes150! i am use version : Quote root@aml:/proc# uname -a Linux aml 5.0.0-rc7-aml-s905-gb5aa11ceb-dirty #5.76 SMP PREEMPT Wed Feb 27 14:53:05 MSK 2019 aarch64 GNU/Linux i have a usb Astrometa DVB-T2: https://www.linuxtv.org/wiki/index.php/Astrometa_DVB-T2 the kernel can't driver it. run lsusb command output: Quote root@aml:/proc# lsusb Bus 002 Device 002: ID 15f4:0131 HanfTek Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 1915:0174 Nordic Semiconductor ASA Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Hope you add dvb_usb_rtl28xxu and MN88473 driver at compile time in the new version thank you.
Turgus Posted March 5, 2019 Posted March 5, 2019 ..is it right, that the images in 905-folder are named 912?! 10 hours ago, balbes150 said: The new version of the image with the kernel 5.76 5-rc8.
balbes150 Posted March 6, 2019 Author Posted March 6, 2019 12 hours ago, Turgus said: ..is it right, that the images in 905-folder are named 912?! fix
