jernej Posted June 14, 2016 Posted June 14, 2016 Ah, ok. I thought that AP6210 is used mostly because all FW files in Android image reference it as AP6210 and extracted fex file has secondary UART enabled with flow control, which is usually used by bcmdhd for bluetooth. @markbirss, so nothing to test then.
tkaiser Posted June 15, 2016 Posted June 15, 2016 To sum it up: no BT therefore it's ok to disable the UARTs not used (it's not an SBC and only uart0 is accessible through soldering anyway) does the bcmdhd driver now need additional parameters to correctly load the firmware? If so we should think about jernej's suggestion no firmware .deb means upgraded installations don't get more recent Wi-Fi firmwares. Would be nice if we could fix that line787 in the fex file should be changed to 0 (otherwise average load will always be 1 or above) Something I missed?
markbirss Posted June 15, 2016 Posted June 15, 2016 Hi @tkaiser and others i found that by default the bcmdhd module requires a config.txt and nvram.txt file present in /lib/firmware/ap6212 unless you specify them specifically with modprobe modprobe bcmdhd nvram_path=/lib/firmware/ap6212/nvram_ap6210.txt conf_path=/lib/firmware/ap6212/myconfig.txt nvram.txt is the nvram_ap6210.txt config.txt (not sure) provided the firmware files (fw_bcm40181a2.bin) is also in /lib/firmware/ap6212 and been added to /etc/modules the wifi works What about getting the IR remote controller working ?
tkaiser Posted June 15, 2016 Posted June 15, 2016 After module is rebuild, we could load bcmdhd based on board with only modprobe bcmdhd nvram_path=/lib/firmware/bcmdhd/nvram_ap6210.txt for example... Noob question: Do you think we're able to use bcmdhd driver for both BPi M2+ and Beelink X2 without adding any module parameters to /etc/modules? Background: https://github.com/igorpecovnik/lib/commit/c13fe2e59c1fc5f561db0e281d856097c2291f38#commitcomment-17875420
tkaiser Posted June 15, 2016 Posted June 15, 2016 What about getting the IR remote controller working ? What's not working? Pin mapping is identical to Orange Pi [1] so jernej's backported IR driver should work like on any Orange Pi. Never dealt with that so not sure which module to load. In case you figure it out please report back so that we can add this to the board config to be enabled (or commented) in /etc/modules. [1] https://github.com/igorpecovnik/lib/blob/master/config/fex/beelinkx2.fex#L1021vs. https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepipc.fex#L675
markbirss Posted June 15, 2016 Posted June 15, 2016 Maybe, i don't have BPi M2+ but i passed no module parameters in /etc/modules for bmdhd module, left the 2 text files in the /lib/firmnware/ap6212 folder (don't know if the same nvram_ap6210.txt works for both devices) Noob question: Do you think we're able to use bcmdhd driver for both BPi M2+ and Beelink X2 without adding any module parameters to /etc/modules? Background: https://github.com/igorpecovnik/lib/commit/c13fe2e59c1fc5f561db0e281d856097c2291f38#commitcomment-17875420
markbirss Posted June 15, 2016 Posted June 15, 2016 Ah, ok, thank you, when i have time will have a look What's not working? Pin mapping is identical to Orange Pi [1] so jernej's backported IR driver should work like on any Orange Pi. Never dealt with that so not sure which module to load. In case you figure it out please report back so that we can add this to the board config to be enabled (or commented) in /etc/modules. [1] https://github.com/igorpecovnik/lib/blob/master/config/fex/beelinkx2.fex#L1021vs. https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepipc.fex#L675
jernej Posted June 15, 2016 Posted June 15, 2016 FYI, backported driver completely ignores IR settings in fex file. They are used only for resuming from sleep, IIRC.
Eng-Shien Wu Posted June 15, 2016 Posted June 15, 2016 Is the SPDIF working? It was working on the 5.11 builds. I have not checked the latest builds, but it should still be working.
manuti Posted June 15, 2016 Posted June 15, 2016 It was working on the 5.11 builds. I have not checked the latest builds, but it should still be working. OK, thanks for the info. My Beelink X2 is ordered! Incredible work guys!
tkaiser Posted June 20, 2016 Posted June 20, 2016 FYI, backported driver completely ignores IR settings in fex file. They are used only for resuming from sleep, IIRC. Thx for the reminder. But fortunately the same pin mapping is used. I just did this root@beelinkx2:/home/tk# modprobe sunxi-cir root@beelinkx2:/home/tk# ir-keytable -p NEC,RC-5,RC-6,JVC,SONY,LIRC,OTHER ; ir-keytable -c ; ir-keytable -t Invalid parameter(s) ir-keytable: -p: (PROGRAM ERROR) Option should have been recognized!? Try `ir-keytable --help' or `ir-keytable --usage' for more information. Old keytable cleared Testing events. Please, press CTRL-C to abort. 1466427392.393181: event type EV_MSC(0x04): scancode = 0x03 1466427392.393209: event type EV_SYN(0x00). 1466427392.837740: event type EV_MSC(0x04): scancode = 0x03 1466427392.837767: event type EV_SYN(0x00). 1466427393.983779: event type EV_MSC(0x04): scancode = 0x02 1466427393.983808: event type EV_SYN(0x00). 1466427397.780964: event type EV_MSC(0x04): scancode = 0x48 1466427397.780994: event type EV_SYN(0x00). 1466427398.716936: event type EV_MSC(0x04): scancode = 0x48 1466427398.716964: event type EV_SYN(0x00). 1466427401.090401: event type EV_MSC(0x04): scancode = 0x14 1466427401.090431: event type EV_SYN(0x00). 1466427402.939626: event type EV_MSC(0x04): scancode = 0x5c 1466427402.939656: event type EV_SYN(0x00). 1466427403.581513: event type EV_MSC(0x04): scancode = 0x5c 1466427403.581539: event type EV_SYN(0x00). 1466427407.404387: event type EV_MSC(0x04): scancode = 0x0b 1466427407.404416: event type EV_SYN(0x00). 1466427411.510339: event type EV_MSC(0x04): scancode = 0x58 1466427411.510367: event type EV_SYN(0x00). 1466427412.160997: event type EV_MSC(0x04): scancode = 0x58 1466427412.161022: event type EV_SYN(0x00). So IR also works. Since Beelink X2 ships with a remote someone a bit familiar with this stuff could start now (read as: before we release Armbian 5.15) to add an appropriate config file we could then integrate into the build (but I have to admit that I'm such a NOOB regarding IR that I don't know how to deal with the information from this thread where I found how to check the scancodes) On a related note. The on/off button on Beelink X2 also uses the correct pin mapping. After installation of the acpid package this is possible: root@beelinkx2:/home/tk# acpi_listen button/power PBTN 00000080 00000000 So all we need to do is to define a shutdown action for the 'button/power' event, in the most simple form as follows: echo -e 'event=button/power\naction=/etc/acpi/check-and-shutdown.sh' >/etc/acpi/events/powerbtn echo -e '#!/bin/bash\nshutdown -h now' >/etc/acpi/check-and-shutdown.sh chmod 755 /etc/acpi/check-and-shutdown.sh Then the simple press of the power button executes the script code in /etc/acpi/check-and-shutdown.sh (in the aforementioned example without a check -- but on an Orange Pi Lite I currently use as a backup device I added some code to check whether a backup is currently running delaying the shutdown until the task is finished). Of course anything else can also happen when the power button is pressed, it's just the execution of some script code (and the same applies to each and every Orange Pi out there too) 1
tkaiser Posted June 20, 2016 Posted June 20, 2016 Hmm... an alternative to shutting the device down can also be suspend to RAM. Then /etc/acpi/check-and-shutdown.sh might look like this: #!/bin/bash echo none >/sys/class/leds/*green*/trigger echo default-on >/sys/class/leds/*red*/trigger echo mem >/sys/power/state Then pressing the power button sends the device to sleep but wake up from sleep (also through power button) wasn't that reliable and I also don't know which hook to use to switch led colors back.
tkaiser Posted June 20, 2016 Posted June 20, 2016 FYI: This recent commit to Armbian enables the USB port on the back of the device (H3's OTG port available as type A receptacle like on Pine64 for example, used by us as host port by default) and I also tweaked IRQ distribution a bit since Beelink X2 is somewhat different here compared to other H3 devices.
jernej Posted June 20, 2016 Posted June 20, 2016 Then pressing the power button sends the device to sleep but wake up from sleep (also through power button) wasn't that reliable and I also don't know which hook to use to switch led colors back. systemd service works, for example: [Unit] Description=h3 suspend service Before=sleep.target StopWhenUnneeded=yes [Service] Type=oneshot RemainAfterExit=yes ExecStart=-/bin/sh -c "echo 1 > /sys/class/leds/green_led/brightness; echo 1 > /sys/class/leds/red_led/brightness" ExecStop=-/bin/sh -c "echo 0 > /sys/class/leds/green_led/brightness; echo 0 > /sys/class/leds/red_led/brightness" [Install] WantedBy=sleep.target ExecStart will execute at suspend and ExecStop will execute at resume. Please note that above example is taken from OpenELEC, which has slightly different LED settings, but principle is the same.
tkaiser Posted June 20, 2016 Posted June 20, 2016 systemd service works, for example -- ExecStart will execute at suspend and ExecStop will execute at resume. Please note that above example is taken from OpenELEC, which has slightly different LED settings, but principle is the same. Ah, that's nice. And also works with power button? BTW: I would recommend changing these led adjustments to this style since it will survive switch between legacy and mainline kernel (at least with H3 devices based on .dts contents for Oranges): echo none >/sys/class/leds/*green*/trigger echo default-on >/sys/class/leds/*red*/trigger And currently we treat the blue led on Beelink X2 as green (name in fex file) since otherwise we would've to differentiate again between different sunxi devices (NanoPi M1 for example has a blue led instead of the red one with same pin mapping)
jernej Posted June 20, 2016 Posted June 20, 2016 Ah, that's nice. And also works with power button? That's the point. BTW: I would recommend changing these led adjustments to this style since it will survive switch between legacy and mainline kernel (at least with H3 devices based on .dts contents for Oranges): I will probably leave it as is. A lot will change anyway and I can't switch so quickly, because a lot of drivers still missing.
manuti Posted July 1, 2016 Posted July 1, 2016 About the Wi-Fi, when I try in ARMBIAN 5.14 jessie desktop 3.4.112-sun8i: sudo modprobe bcmdhd modprobe: ERROR: could not insert 'bcmdhd': No such device I need to do something more? in /etc/modules I have: # /etc/modules: kernel modules to load at boot time. # # This file contains the names of kernel modules that should be loaded # at boot time, one per line. Lines beginning with "#" are ignored. #gpio_sunxi bcmdhd sndspdif sunxi_sndspdif sunxi_spdif sunxi_spdma And when I do lsmod obtain: Module Size Used by mali_drm 2732 1 drm 178255 2 mali_drm mali 123208 0 ump 29379 3 mali sunxi_spdma 3703 1 sunxi_spdif 7037 1 sunxi_sndspdif 3885 0 sndspdif 2743 1 8189es 1076034 0 hid_logitech_dj 10040 0 I need to do something more to have the internal Wi-Fi working? Thanks in advance.
slinde Posted July 1, 2016 Posted July 1, 2016 I need to do something more to have the internal Wi-Fi working? You need to follow the instructions in this posting http://forum.armbian.com/index.php/topic/872-beelink-x2-with-armbian-possible/page-2#entry10698
manuti Posted July 1, 2016 Posted July 1, 2016 Hi slinde, the firmware is missing, can somebody upload and share? Thanks.
slinde Posted July 1, 2016 Posted July 1, 2016 Hi slinde, the firmware is missing, can somebody upload and share? Thanks. I put the firmware file on my webserver http://www.itgubben.eu/files/ 1
manuti Posted July 4, 2016 Posted July 4, 2016 I put the firmware file on my webserver http://www.itgubben.eu/files/ Thanks a lot. This evening I will give it a try. But I'm thinking in wait to the v5.15 release.
manuti Posted July 4, 2016 Posted July 4, 2016 I put the firmware file on my webserver http://www.itgubben.eu/files/ Hi slinde, inside the firmware file there is no bcmdhd.bin file. When I do a: sudo modprobe bcmdhd firmware_path=/lib/firmware/ap6210/bcmdhd.bin nvram_path=/lib/firmware/ap6210/nvram.txt I have a message like this: modprobe: ERROR: could not insert 'bcmdhd': No such device And the dmesg shows me: [ 1004.060351] failed to power up DHD generic adapter, 0 retry left Any help?
Igor Posted July 5, 2016 Posted July 5, 2016 All those firmware files should be in package armbian-firmware which should come by default in latest image. I am getting a Belink X2 probably today, so I'll check and fix if something needed a fix
manuti Posted July 5, 2016 Posted July 5, 2016 All those firmware files should be in package armbian-firmware which should come by default in latest image. I am getting a Belink X2 probably today, so I'll check and fix if something needed a fix Thanks a million Igor.
slinde Posted July 5, 2016 Posted July 5, 2016 I will check the file and fix it when I get back home in a few days.
manuti Posted July 5, 2016 Posted July 5, 2016 I will check the file and fix it when I get back home in a few days. Thanks slinde.
slinde Posted July 9, 2016 Posted July 9, 2016 Hi slinde, inside the firmware file there is no bcmdhd.bin file. When I do a: sudo modprobe bcmdhd firmware_path=/lib/firmware/ap6210/bcmdhd.bin nvram_path=/lib/firmware/ap6210/nvram.txt I have a message like this: modprobe: ERROR: could not insert 'bcmdhd': No such device And the dmesg shows me: [ 1004.060351] failed to power up DHD generic adapter, 0 retry left Any help? Hi manuti, I tested this once more today and it works for me as earlier described and with the file I uploaded to my web server. See the full logfile for details: root@beelinkx2:~# lsmod Module Size Used by sunxi_spdma 3703 1 sunxi_spdif 7037 1 sunxi_sndspdif 3885 0 sndspdif 2743 1 bcmdhd 648477 0 root@beelinkx2:~# wget http://www.itgubben.eu/files/ap6210.tar.xz --2016-07-09 15:55:33-- http://www.itgubben.eu/files/ap6210.tar.xz Resolving www.itgubben.eu (www.itgubben.eu)... 2001:470:27:75b::2, 83.209.13.109 Connecting to www.itgubben.eu (www.itgubben.eu)|2001:470:27:75b::2|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 225284 (220K) [application/x-xz] Saving to: ‘ap6210.tar.xz’ ap6210.tar.xz 100%[=====================>] 220.00K 1.19MB/s in 0.2s 2016-07-09 15:55:33 (1.19 MB/s) - ‘ap6210.tar.xz’ saved [225284/225284] root@beelinkx2:~# cd /lib/firmware/ root@beelinkx2:/lib/firmware# tar xvf ~/ap6210.tar.xz ap6210/ ap6210/fw_bcm40181a2_p2p.bin ap6210/nvram.txt ap6210/fw_bcm40181a2_apsta.bin ap6210/fw_bcm40181a2.bin root@beelinkx2:/lib/firmware# cd root@beelinkx2:~# lsmod Module Size Used by sunxi_spdma 3703 1 sunxi_spdif 7037 1 sunxi_sndspdif 3885 0 sndspdif 2743 1 bcmdhd 648477 0 root@beelinkx2:~# rmmod bcmdhd root@beelinkx2:~# modprobe bcmdhd firmware_path=/lib/firmware/ap6210/bcmdhd.bin nvram_path=/lib/firmware/ap6210/nvram.txt root@beelinkx2:~# lsmod Module Size Used by bcmdhd 648477 0 sunxi_spdma 3703 1 sunxi_spdif 7037 1 sunxi_sndspdif 3885 0 sndspdif 2743 1 root@beelinkx2:~# ifconfig wlan0 up root@beelinkx2:~# iwlist wlan0 scan wlan0 Scan completed : Cell 01 - Address: 14:CC:20:CB:A4:72 ESSID:"XXXXXXX" Mode:Managed Frequency:2.437 GHz (Channel 6) Quality:5/5 Signal level:-40 dBm Noise level:-82 dBm... This test was done with a Beelink X2 and the file Armbian_5.14_Beelinkx2_Debian_jessie_3.4.112.7z downloaded today. I agree there is no file called "bcmdhd.bin" in the ap6210.tar.xz file but somehow it seems to work anyhow. If I look in the /var/syslog file I see that the driver finds the correct paths: Jul 9 15:59:45 localhost kernel: [ 498.139371] dhd_bus_devreset: == WLAN ON == Jul 9 15:59:45 localhost kernel: [ 498.139671] F1 signature read @0x18000000=0x1591a962 Jul 9 15:59:45 localhost kernel: [ 498.140467] dhd_conf_set_hw_oob_intr: Enable HW OOB for 43362 Jul 9 15:59:45 localhost kernel: [ 498.146815] F1 signature OK, socitype:0x1 chip:0xa962 rev:0x1 pkg:0x9 Jul 9 15:59:45 localhost kernel: [ 498.149117] DHD: dongle ram size is set to 245760(orig 245760) at 0x0 Jul 9 15:59:45 localhost kernel: [ 498.152761] dhd_conf_read_config: Ignore config file /lib/firmware/ap6212/config.txt Jul 9 15:59:45 localhost kernel: [ 498.152836] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/ap6210/fw_bcm40181a2.bin Jul 9 15:59:45 localhost kernel: [ 498.152888] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin Jul 9 15:59:45 localhost kernel: [ 498.152925] Final nv_path=/lib/firmware/ap6210/nvram.txt Jul 9 15:59:45 localhost kernel: [ 498.152959] Final conf_path=/lib/firmware/ap6212/config.txt Jul 9 15:59:45 localhost kernel: [ 498.197314] NVRAM version: AP6210_NVRAM_V1.3_08182013
jernej Posted July 10, 2016 Posted July 10, 2016 I agree there is no file called "bcmdhd.bin" in the ap6210.tar.xz file but somehow it seems to work anyhow. Yeah, bcmdhd driver has some strange things inside the code. It seems mandatory to have some file specified, but later on it gets replaced with correct FW name based on chip id. If you check driver source, you can see a lot of different FW file names. 2
