Beelink X2 with armbian possible?
Not that much. Can you please post a picture of the DRAM chips or even better post the description written on here?
It seems Beelink X2 comes with different flavours of DRAM and our default 624 MHz DRAM clock might be too high for some of the modules. It might sound weird but you could try out our image for NanoPi NEO and report back (since there DRAM is clocked very low -- since you have UART workinf you could at least report whether board boots or not).
Please get back to us with an update.
RAM is PE029(PRN256M16V00HG8GNF), in evening i will try image for NanoPi NEO, I successfully running laboris linux (Debian_jessie_mini.img.xz),
Link to post
Share on other sites
Donate and support the project!
It was confirmed that with prehistoric stock Allwinner u-boot works, but we can't and won't switch to it.
We started with 576 MHz and totally different DRAM settings: https://github.com/igorpecovnik/lib/commit/8dfa86b7e1f08bfb67cb723121a6bf7e6a1a82a2#commitcomment-17832143
Using a loboris image means DRAM initialization is done by boot0 and DRAM clockspeed is 672 MHz and several people reported that 648 or even 672 MHz with mainline u-boot aren't a problem. But maybe we should simply revert back to the settings above (or at least reduce DRAM clock to 576 MHz? Let's wait for the test with NEO image...
Link to post
I assume you have a home network and a router?
When the Beelink X2 boots it tries to get an IP-address from your router. You can enter the routers menu and check which IP-address is assigned to the Beelink X2. Check for DHCP client list or similar in the router menu.
When you know the IP-address of the Beelink X2 you can try to reach it from another computer in your home network for example your desktop PC. Ping is a command that checks if there is network connectivity between two computers. Ssh is a way of remotely logging in to another computer. Armbian is by default configured so that you can connect to it via ssh.
Right I understand - Have connected the device to the router, unfortunately their is nothing displayed by my router regarding the device
Link to post
I get same error from NEO image
U-Boot SPL 2016.09-armbian (Sep 15 2016 - 05:55:51)
DRAM: 0 MiB
### ERROR ### Please RESET the board ###
Link to post
That's just weird. And there's also not that much we could do now since the device already fails early in u-boot. The mainline u-boot guys would be happy to hold your device in their hands since AFAIK they still look into DRAM calibration issues (this is the main/only difference here compared to loboris images: they all use Allwinner's old u-boot version where a proprietary blob does DRAM initialization while we use code that has been written from scratch by linux-sunxi community)
Edit: Are you able to measure the voltage provided by the PSU at the device (including potential voltage drops caused by cable and contact resistance)?
Background: I tested through a few SBC days ago and one of the boards that only features a crappy Micro USB connector for DC-IN (a so called Roseapple Pi) showed strange behaviour as long as I did not increase the supplied voltage up to 5.4V. When the voltage was below 5.0V it simply did not boot, between 5.1V and 5.3V I experienced random freezes and u-boot sometimes showed 1 GiB and sometimes the real 2 GiB.
Just an idea to rule out PSU issues (no idea how mainline u-boot and Allwinner's boot0 BLOB might differ here. At least H3 devices are not accompanied by a PMIC -- power management IC -- and on most boards all voltage regulators just divide the input voltage so strange things might happen when voltage is not sufficient)
Link to post
Ok, mainline u-boot devs join the party: https://irclog.whitequark.org/linux-sunxi/2016-09-19#17606820;
So you're asked to boot again with loboris image with serial console connected, then stop u-boot's autoboot by pressing any key and then do a
md 0x01c62000 0x800
and post the results back. Are you able to then overwrite a few sectors of an Armbian image if I provide you with a patched u-boot-sunxi-with-spl.bin? Or do you need a whole new image?
Link to post
in my native power block I get 5.2V, I have another one 5.4V but same result.
I tried it with my older X2 yesterday and it properly booted with just 4.3V (4.2V no go, but as soon as I increased voltage by 0.1V it worked). BTW: I was talking about real voltage available to the device and not PSU ratings (cable/contact resistance can lead to severe voltage drops).
Anyway: I built a specially crafted Armbian image for you: http://213.179.157.5/orders/Armbian_5.20_Beelinkx2_Ubuntu_xenial_3.4.112.7z
Please download within 24 hours and provide output from serial console. A patch is applied that should print out the stuff you manually collected before even if u-boot will not start. Please provide the output in this thread inside spoiler tags. Thanks!
Link to post
now about new image, I cannot get any message from beelink via UART. it's only turn on purple led and freeze
Hmm... it should look like this (just tried it out with exactly that image):
U-Boot SPL 2016.09-armbian (Sep 20 2016 - 10:21:02)
DRAM:01c62000: 004319e4 000009f4 0e400800 00000000
01c62010: 0200000d 00800100 06000009 01000400
01c62020: 0200000d 00600100 0100000d 00200080
01c62030: 07000009 01000640 0100000d 00200080
01c62040: 01000009 00400080 0100000d 00400080
01c62050: 0100000d 00400080 04000009 00400100
01c62060: 2000030d 04001800 04000009 00400120
01c62070: 00000000 00000000 00000000 00000000
01c62080: 00000000 00000000 00000000 00000000
01c62090: 00010190 ffffffff 00000001 0030d402
01c620a0: 00000000 00000000 00000000 00000000
01c620b0: 00000000 00000000 00000000 00000000
01c620c0: 80000000 00000000 00000000 00000000
01c620d0: 00103040 00000000 00000000 00000000
01c620e0: 00000000 00000000 00000000 00000000
01c620f0: 00000000 00000000 00000000 00000000
01c62100: 00000000 00000000 00000000 00000080
01c62110: 00000000 00000000 00000000 00000000
01c62120: 00000000 00000000 00000000 00000000
01c62130: 00000000 00000000 00000000 00000000
01c62140: 00000000 00000000 00000000 00000000
01c62150: 00000000 00000000 00000000 00000000
01c62160: 00000000 00000000 00000000 00000000
01c62170: 00000000 00000000 00000000 00000000
01c62180: 00000000 00000000 00000000 00000000
01c62190: 00000000 00000000 00000000 00000000
01c621a0: 00000000 00000000 00000000 00000000
01c621b0: 00000000 00000000 00000000 00000000
01c621c0: 00000000 00000000 00000000 00000000
01c621d0: 00000000 00000000 00000000 00000000
01c621e0: 00000000 00000000 00000000 00000000
01c621f0: 00000000 00000000 00000000 00000000
01c62200: 00000000 00000000 00000000 00000000
01c62210: 00000000 00000000 00000000 00000000
01c62220: 00000000 00000000 00000000 00000000
01c62230: 00000000 00000000 00000000 00000000
01c62240: 00000000 00000000 00000000 00000000
01c62250: 00000000 00000000 00000000 00000000
01c62260: 00000000 00000000 00000000 00000000
01c62270: 00000000 00000000 00000000 00000000
01c62280: 00000000 00000000 00000000 00000000
01c62290: 00000000 00000000 00000000 00000000
01c622a0: 00000000 00000000 00000000 00000000
01c622b0: 00000000 00000000 00000000 00000000
01c622c0: 00000000 00000000 00000000 00000000
01c622d0: 00000000 00000000 00000000 00000000
01c622e0: 00000000 00000000 00000000 00000000
01c622f0: 00000000 00000000 00000000 00000000
01c62300: 00000000 00000000 00000000 00000000
01c62310: 00000000 00000000 00000000 00000000
01c62320: 00000000 00000000 00000000 00000000
01c62330: 00000000 00000000 00000000 00000000
01c62340: 00000000 00000000 00000000 00000000
01c62350: 00000000 00000000 00000000 00000000
01c62360: 00000000 00000000 00000000 00000000
01c62370: 00000000 00000000 00000000 00000000
01c62380: 00000000 00000000 00000000 00000000
01c62390: 00000000 00000000 00000000 00000000
01c623a0: 00000000 00000000 00000000 00000000
01c623b0: 00000000 00000000 00000000 00000000
01c623c0: 00000000 00000000 00000000 00000000
01c623d0: 00000000 00000000 00000000 00000000
01c623e0: 00000000 00000000 00000000 00000000
01c623f0: 00000000 00000000 00000000 00000000
01c62400: 00000000 00000000 00000000 00000000
01c62410: 00000000 00000000 00000000 00000000
01c62420: 00000000 00000000 00000000 00000000
01c62430: 00000000 00000000 00000000 00000000
01c62440: 00000000 00000000 00000000 00000000
01c62450: 00000000 00000000 00000000 00000000
01c62460: 00000000 00000000 00000000 00000000
01c62470: 00000000 00000000 00000000 00000000
01c62480: 00000000 00000000 00000000 00000000
01c62490: 00000000 00000000 00000000 00000000
01c624a0: 00000000 00000000 00000000 00000000
01c624b0: 00000000 00000000 00000000 00000000
01c624c0: 00000000 00000000 00000000 00000000
01c624d0: 00000000 00000000 00000000 00000000
01c624e0: 00000000 00000000 00000000 00000000
01c624f0: 00000000 00000000 00000000 00000000
01c62500: 00000000 00000000 00000000 00000000
01c62510: 00000000 00000000 00000000 00000000
01c62520: 00000000 00000000 00000000 00000000
01c62530: 00000000 00000000 00000000 00000000
01c62540: 00000000 00000000 00000000 00000000
01c62550: 00000000 00000000 00000000 00000000
01c62560: 00000000 00000000 00000000 00000000
01c62570: 00000000 00000000 00000000 00000000
01c62580: 00000000 00000000 00000000 00000000
01c62590: 00000000 00000000 00000000 00000000
01c625a0: 00000000 00000000 00000000 00000000
01c625b0: 00000000 00000000 00000000 00000000
01c625c0: 00000000 00000000 00000000 00000000
01c625d0: 00000000 00000000 00000000 00000000
01c625e0: 00000000 00000000 00000000 00000000
01c625f0: 00000000 00000000 00000000 00000000
01c62600: 00000000 00000000 00000000 00000000
01c62610: 00000000 00000000 00000000 00000000
01c62620: 00000000 00000000 00000000 00000000
01c62630: 00000000 00000000 00000000 00000000
01c62640: 00000000 00000000 00000000 00000000
01c62650: 00000000 00000000 00000000 00000000
01c62660: 00000000 00000000 00000000 00000000
01c62670: 00000000 00000000 00000000 00000000
01c62680: 00000000 00000000 00000000 00000000
01c62690: 00000000 00000000 00000000 00000000
01c626a0: 00000000 00000000 00000000 00000000
01c626b0: 00000000 00000000 00000000 00000000
01c626c0: 00000000 00000000 00000000 00000000
01c626d0: 00000000 00000000 00000000 00000000
01c626e0: 00000000 00000000 00000000 00000000
01c626f0: 00000000 00000000 00000000 00000000
01c62700: 00000000 00000000 00000000 00000000
01c62710: 00000000 00000000 00000000 00000000
01c62720: 00000000 00000000 00000000 00000000
01c62730: 00000000 00000000 00000000 00000000
01c62740: 00000000 00000000 00000000 00000000
01c62750: 00000000 00000000 00000000 00000000
01c62760: 00000000 00000000 00000000 00000000
01c62770: 00000000 00000000 00000000 00000000
01c62780: 00000000 00000000 00000000 00000000
01c62790: 00000000 00000000 00000000 00000000
01c627a0: 00000000 00000000 00000000 00000000
01c627b0: 00000000 00000000 00000000 00000000
01c627c0: 00000000 00000000 00000000 00000000
01c627d0: 00000000 00000000 00000000 00000000
01c627e0: 00000000 00000000 00000000 00000000
01c627f0: 00000000 00000000 00000000 00000000
01c62800: 00000000 00000000 00000000 00000000
01c62810: 00000000 00000000 00000000 00000000
01c62820: 00000000 00000000 00000000 00000000
01c62830: 00000000 00000000 00000000 00000000
01c62840: 00000000 00000000 00000000 00000000
01c62850: 00000000 00000000 00000000 00000000
01c62860: 00000000 00000000 00000000 00000000
01c62870: 00000000 00000000 00000000 00000000
01c62880: 00000000 00000000 00000000 00000000
01c62890: 00000000 00000000 00000000 00000000
01c628a0: 00000000 00000000 00000000 00000000
01c628b0: 00000000 00000000 00000000 00000000
01c628c0: 00000000 00000000 00000000 00000000
01c628d0: 00000000 00000000 00000000 00000000
01c628e0: 00000000 00000000 00000000 00000000
01c628f0: 00000000 00000000 00000000 00000000
01c62900: 00000000 00000000 00000000 00000000
01c62910: 00000000 00000000 00000000 00000000
01c62920: 00000000 00000000 00000000 00000000
01c62930: 00000000 00000000 00000000 00000000
01c62940: 00000000 00000000 00000000 00000000
01c62950: 00000000 00000000 00000000 00000000
01c62960: 00000000 00000000 00000000 00000000
01c62970: 00000000 00000000 00000000 00000000
01c62980: 00000000 00000000 00000000 00000000
01c62990: 00000000 00000000 00000000 00000000
01c629a0: 00000000 00000000 00000000 00000000
01c629b0: 00000000 00000000 00000000 00000000
01c629c0: 00000000 00000000 00000000 00000000
01c629d0: 00000000 00000000 00000000 00000000
01c629e0: 00000000 00000000 00000000 00000000
01c629f0: 00000000 00000000 00000000 00000000
01c62a00: 00000000 00000000 00000000 00000000
01c62a10: 00000000 00000000 00000000 00000000
01c62a20: 00000000 00000000 00000000 00000000
01c62a30: 00000000 00000000 00000000 00000000
01c62a40: 00000000 00000000 00000000 00000000
01c62a50: 00000000 00000000 00000000 00000000
01c62a60: 00000000 00000000 00000000 00000000
01c62a70: 00000000 00000000 00000000 00000000
01c62a80: 00000000 00000000 00000000 00000000
01c62a90: 00000000 00000000 00000000 00000000
01c62aa0: 00000000 00000000 00000000 00000000
01c62ab0: 00000000 00000000 00000000 00000000
01c62ac0: 00000000 00000000 00000000 00000000
01c62ad0: 00000000 00000000 00000000 00000000
01c62ae0: 00000000 00000000 00000000 00000000
01c62af0: 00000000 00000000 00000000 00000000
01c62b00: 00000000 00000000 00000000 00000000
01c62b10: 00000000 00000000 00000000 00000000
01c62b20: 00000000 00000000 00000000 00000000
01c62b30: 00000000 00000000 00000000 00000000
01c62b40: 00000000 00000000 00000000 00000000
01c62b50: 00000000 00000000 00000000 00000000
01c62b60: 00000000 00000000 00000000 00000000
01c62b70: 00000000 00000000 00000000 00000000
01c62b80: 00000000 00000000 00000000 00000000
01c62b90: 00000000 00000000 00000000 00000000
01c62ba0: 00000000 00000000 00000000 00000000
01c62bb0: 00000000 00000000 00000000 00000000
01c62bc0: 00000000 00000000 00000000 00000000
01c62bd0: 00000000 00000000 00000000 00000000
01c62be0: 00000000 00000000 00000000 00000000
01c62bf0: 00000000 00000000 00000000 00000000
01c62c00: 00000000 00000000 00000000 00000000
01c62c10: 00000000 00000000 00000000 00000000
01c62c20: 00000000 00000000 00000000 00000000
01c62c30: 00000000 00000000 00000000 00000000
01c62c40: 00000000 00000000 00000000 00000000
01c62c50: 00000000 00000000 00000000 00000000
01c62c60: 00000000 00000000 00000000 00000000
01c62c70: 00000000 00000000 00000000 00000000
01c62c80: 00000000 00000000 00000000 00000000
01c62c90: 00000000 00000000 00000000 00000000
01c62ca0: 00000000 00000000 00000000 00000000
01c62cb0: 00000000 00000000 00000000 00000000
01c62cc0: 00000000 00000000 00000000 00000000
01c62cd0: 00000000 00000000 00000000 00000000
01c62ce0: 00000000 00000000 00000000 00000000
01c62cf0: 00000000 00000000 00000000 00000000
01c62d00: 00000000 00000000 00000000 00000000
01c62d10: 00000000 00000000 00000000 00000000
01c62d20: 00000000 00000000 00000000 00000000
01c62d30: 00000000 00000000 00000000 00000000
01c62d40: 00000000 00000000 00000000 00000000
01c62d50: 00000000 00000000 00000000 00000000
01c62d60: 00000000 00000000 00000000 00000000
01c62d70: 00000000 00000000 00000000 00000000
01c62d80: 00000000 00000000 00000000 00000000
01c62d90: 00000000 00000000 00000000 00000000
01c62da0: 00000000 00000000 00000000 00000000
01c62db0: 00000000 00000000 00000000 00000000
01c62dc0: 00000000 00000000 00000000 00000000
01c62dd0: 00000000 00000000 00000000 00000000
01c62de0: 00000000 00000000 00000000 00000000
01c62df0: 00000000 00000000 00000000 00000000
01c62e00: 00000000 00000000 00000000 00000000
01c62e10: 00000000 00000000 00000000 00000000
01c62e20: 00000000 00000000 00000000 00000000
01c62e30: 00000000 00000000 00000000 00000000
01c62e40: 00000000 00000000 00000000 00000000
01c62e50: 00000000 00000000 00000000 00000000
01c62e60: 00000000 00000000 00000000 00000000
01c62e70: 00000000 00000000 00000000 00000000
01c62e80: 00000000 00000000 00000000 00000000
01c62e90: 00000000 00000000 00000000 00000000
01c62ea0: 00000000 00000000 00000000 00000000
01c62eb0: 00000000 00000000 00000000 00000000
01c62ec0: 00000000 00000000 00000000 00000000
01c62ed0: 00000000 00000000 00000000 00000000
01c62ee0: 00000000 00000000 00000000 00000000
01c62ef0: 00000000 00000000 00000000 00000000
01c62f00: 00000000 00000000 00000000 00000000
01c62f10: 00000000 00000000 00000000 00000000
01c62f20: 00000000 00000000 00000000 00000000
01c62f30: 00000000 00000000 00000000 00000000
01c62f40: 00000000 00000000 00000000 00000000
01c62f50: 00000000 00000000 00000000 00000000
01c62f60: 00000000 00000000 00000000 00000000
01c62f70: 00000000 00000000 00000000 00000000
01c62f80: 00000000 00000000 00000000 00000000
01c62f90: 00000000 00000000 00000000 00000000
01c62fa0: 00000000 00000000 00000000 00000000
01c62fb0: 00000000 00000000 00000000 00000000
01c62fc0: 00000000 00000000 00000000 00000000
01c62fd0: 00000000 00000000 00000000 00000000
01c62fe0: 00000000 00000000 00000000 00000000
01c62ff0: 00000000 00000000 00000000 00000000
01c63000: 00000000 00000000 01000000 0000c00e
01c63010: 8000005f 40000000 00000001 00000000
01c63020: 00000000 00000000 00000000 00000000
01c63030: 00001c70 00000040 00000018 00000000
01c63040: 0001c000 42c21590 d05612c0 00083def
01c63050: 0e14c2c1 2711e781 0b10180c 00030411
01c63060: 0406050a 0000400c 05020405 05050403
01c63070: 02020005 00000202 90006610 0c000400
01c63080: 02040102 00000404 00000009 00200010
01c63090: 004c006e 00000000 00000010 00000000
01c630a0: 00000000 00000000 00000000 00000000
01c630b0: 00000000 00000000 00000000 00f00000
01c630c0: 81003087 00000000 00000008 00000010
01c630d0: 00000018 dd22ee11 7788bb44 ffffff00
01c630e0: 00ffffff 0000ffff 00141054 0103aaaa
01c630f0: 00000000 00000000 00000000 00000000
01c63100: 04000400 4680c620 000026c0 00aa0060
01c63110: 00000000 00000000 02201800 c408041f
01c63120: 00000201 c2000040 02000100 00000000
01c63130: 00000000 00000000 00000000 00000000
01c63140: 80333333 80000000 1a180b0a 04070b0a
01c63150: 04070b0a 00000000 00000000 00000000
01c63160: 00000000 00000000 00000000 00000000
01c63170: 00000000 00000000 00000000 00000000
01c63180: 00000000 00000000 00000000 00000000
01c63190: 00000000 00000000 00000000 00000000
01c631a0: 00000000 00000000 00000000 00000000
01c631b0: 00000000 00000000 00000000 00000000
01c631c0: 0f802f05 000000ff 0f0000ff 000000ff
01c631d0: 0f0000ff 000000ff 0f0000ff 00000000
01c631e0: 00000000 00000000 00000000 00000000
01c631f0: 00000000 00000000 00000000 00000000
01c63200: 00504747 00000000 0000034a 00000000
01c63210: 00000000 00000000 00000000 00000000
01c63220: 00000000 00000000 00000000 00000000
01c63230: 00000000 00000000 00000000 00000000
01c63240: 00000000 00000000 00000000 00000000
01c63250: 00000000 00000000 00000000 00000000
01c63260: 00000000 00000000 00000000 00000000
01c63270: 00000000 00000000 00000000 00000000
01c63280: 00000000 00000000 00000000 00000000
01c63290: 00000000 00000000 00000000 00000000
01c632a0: 00000000 00000000 00000000 00000000
01c632b0: 00000000 00000000 00000000 00000000
01c632c0: 00000000 00000000 00000000 00000000
01c632d0: 00000000 00000000 00000000 00000000
01c632e0: 00000000 00000000 00000000 00000000
01c632f0: 00000000 00000000 00000000 00000000
01c63300: 00504646 00000000 00232323 0000009b
01c63310: 00000012 00000012 00000012 00000012
01c63320: 00000012 00000012 00000012 00000012
01c63330: 00000012 00000a00 00000000 00000000
01c63340: 00005001 7c000281 00ffff80 00000000
01c63350: 00000000 00000000 00000000 00000000
01c63360: 00000000 00000000 00000000 00000000
01c63370: 00000000 00000000 00000000 00000000
01c63380: 00464747 00000000 00232323 0000009b
01c63390: 0000000e 0000000e 0000000e 0000000e
01c633a0: 0000000e 0000000e 0000000e 0000000e
01c633b0: 0000000e 00000a00 00000000 00000000
01c633c0: 00005001 7c000281 00ffff80 00000000
01c633d0: 00000000 00000000 00000000 00000000
01c633e0: 00000000 00000000 00000000 00000000
01c633f0: 00000000 00000000 00000000 00000000
01c63400: 00504545 00000000 00232323 0000009b
01c63410: 00000012 00000012 00000012 00000012
01c63420: 00000012 00000012 00000012 00000012
01c63430: 00000012 00000a00 00000000 00000000
01c63440: 00005001 7c000281 00ffff80 00000000
01c63450: 00000000 00000000 00000000 00000000
01c63460: 00000000 00000000 00000000 00000000
01c63470: 00000000 00000000 00000000 00000000
01c63480: 00464747 00000000 00232223 0000009b
01c63490: 0000000e 0000000e 0000000e 0000000e
01c634a0: 0000000e 0000000e 0000000e 0000000e
01c634b0: 0000000e 00000600 00000000 00000000
01c634c0: 00005001 7c000281 00ffff80 00000000
01c634d0: 00000000 00000000 00000000 00000000
01c634e0: 00000000 00000000 00000000 00000000
01c634f0: 00000000 00000000 00000000 00000000
01c63500: 00000000 00000000 00000000 00000000
01c63510: 00000000 00000000 00000000 00000000
01c63520: 00000000 00000000 00000000 00000000
01c63530: 00000000 00000000 00000000 00000000
01c63540: 00000000 00000000 00000000 00000000
01c63550: 00000000 00000000 00000000 00000000
01c63560: 00000000 00000000 00000000 00000000
01c63570: 00000000 00000000 00000000 00000000
01c63580: 00000000 00000000 00000000 00000000
01c63590: 00000000 00000000 00000000 00000000
01c635a0: 00000000 00000000 00000000 00000000
01c635b0: 00000000 00000000 00000000 00000000
01c635c0: 00000000 00000000 00000000 00000000
01c635d0: 00000000 00000000 00000000 00000000
01c635e0: 00000000 00000000 00000000 00000000
01c635f0: 00000000 00000000 00000000 00000000
01c63600: 00000000 00000000 00000000 00000000
01c63610: 00000000 00000000 00000000 00000000
01c63620: 00000000 00000000 00000000 00000000
01c63630: 00000000 00000000 00000000 00000000
01c63640: 00000000 00000000 00000000 00000000
01c63650: 00000000 00000000 00000000 00000000
01c63660: 00000000 00000000 00000000 00000000
01c63670: 00000000 00000000 00000000 00000000
01c63680: 00000000 00000000 00000000 00000000
01c63690: 00000000 00000000 00000000 00000000
01c636a0: 00000000 00000000 00000000 00000000
01c636b0: 00000000 00000000 00000000 00000000
01c636c0: 00000000 00000000 00000000 00000000
01c636d0: 00000000 00000000 00000000 00000000
01c636e0: 00000000 00000000 00000000 00000000
01c636f0: 00000000 00000000 00000000 00000000
01c63700: 00000000 00000000 00000000 00000000
01c63710: 00000000 00000000 00000000 00000000
01c63720: 00000000 00000000 00000000 00000000
01c63730: 00000000 00000000 00000000 00000000
01c63740: 00000000 00000000 00000000 00000000
01c63750: 00000000 00000000 00000000 00000000
01c63760: 00000000 00000000 00000000 00000000
01c63770: 00000000 00000000 00000000 00000000
01c63780: 00000000 00000000 00000000 00000000
01c63790: 00000000 00000000 00000000 00000000
01c637a0: 00000000 00000000 00000000 00000000
01c637b0: 00000000 00000000 00000000 00000000
01c637c0: 00000000 00000000 00000000 00000000
01c637d0: 00000000 00000000 00000000 00000000
01c637e0: 00000000 00000000 00000000 00000000
01c637f0: 00000000 00000000 00000000 00000000
01c63800: 00000000 00000000 00000000 00000000
01c63810: 00000000 00000000 00000000 00000000
01c63820: 00000000 00000000 00000000 00000000
01c63830: 00000000 00000000 00000000 00000000
01c63840: 00000000 00000000 00000000 00000000
01c63850: 00000000 00000000 00000000 00000000
01c63860: 00000000 00000000 00000000 00000000
01c63870: 00000000 00000000 00000000 00000000
01c63880: 00000000 00000000 00000000 00000000
01c63890: 00000000 00000000 00000000 00000000
01c638a0: 00000000 00000000 00000000 00000000
01c638b0: 00000000 00000000 00000000 00000000
01c638c0: 00000000 00000000 00000000 00000000
01c638d0: 00000000 00000000 00000000 00000000
01c638e0: 00000000 00000000 00000000 00000000
01c638f0: 00000000 00000000 00000000 00000000
01c63900: 00000000 00000000 00000000 00000000
01c63910: 00000000 00000000 00000000 00000000
01c63920: 00000000 00000000 00000000 00000000
01c63930: 00000000 00000000 00000000 00000000
01c63940: 00000000 00000000 00000000 00000000
01c63950: 00000000 00000000 00000000 00000000
01c63960: 00000000 00000000 00000000 00000000
01c63970: 00000000 00000000 00000000 00000000
01c63980: 00000000 00000000 00000000 00000000
01c63990: 00000000 00000000 00000000 00000000
01c639a0: 00000000 00000000 00000000 00000000
01c639b0: 00000000 00000000 00000000 00000000
01c639c0: 00000000 00000000 00000000 00000000
01c639d0: 00000000 00000000 00000000 00000000
01c639e0: 00000000 00000000 00000000 00000000
01c639f0: 00000000 00000000 00000000 00000000
01c63a00: 00000000 00000000 00000000 00000000
01c63a10: 00000000 00000000 00000000 00000000
01c63a20: 00000000 00000000 00000000 00000000
01c63a30: 00000000 00000000 00000000 00000000
01c63a40: 00000000 00000000 00000000 00000000
01c63a50: 00000000 00000000 00000000 00000000
01c63a60: 00000000 00000000 00000000 00000000
01c63a70: 00000000 00000000 00000000 00000000
01c63a80: 00000000 00000000 00000000 00000000
01c63a90: 00000000 00000000 00000000 00000000
01c63aa0: 00000000 00000000 00000000 00000000
01c63ab0: 00000000 00000000 00000000 00000000
01c63ac0: 00000000 00000000 00000000 00000000
01c63ad0: 00000000 00000000 00000000 00000000
01c63ae0: 00000000 00000000 00000000 00000000
01c63af0: 00000000 00000000 00000000 00000000
01c63b00: 00000000 00000000 00000000 00000000
01c63b10: 00000000 00000000 00000000 00000000
01c63b20: 00000000 00000000 00000000 00000000
01c63b30: 00000000 00000000 00000000 00000000
01c63b40: 00000000 00000000 00000000 00000000
01c63b50: 00000000 00000000 00000000 00000000
01c63b60: 00000000 00000000 00000000 00000000
01c63b70: 00000000 00000000 00000000 00000000
01c63b80: 00000000 00000000 00000000 00000000
01c63b90: 00000000 00000000 00000000 00000000
01c63ba0: 00000000 00000000 00000000 00000000
01c63bb0: 00000000 00000000 00000000 00000000
01c63bc0: 00000000 00000000 00000000 00000000
01c63bd0: 00000000 00000000 00000000 00000000
01c63be0: 00000000 00000000 00000000 00000000
01c63bf0: 00000000 00000000 00000000 00000000
01c63c00: 00000000 00000000 00000000 00000000
01c63c10: 00000000 00000000 00000000 00000000
01c63c20: 00000000 00000000 00000000 00000000
01c63c30: 00000000 00000000 00000000 00000000
01c63c40: 00000000 00000000 00000000 00000000
01c63c50: 00000000 00000000 00000000 00000000
01c63c60: 00000000 00000000 00000000 00000000
01c63c70: 00000000 00000000 00000000 00000000
01c63c80: 00000000 00000000 00000000 00000000
01c63c90: 00000000 00000000 00000000 00000000
01c63ca0: 00000000 00000000 00000000 00000000
01c63cb0: 00000000 00000000 00000000 00000000
01c63cc0: 00000000 00000000 00000000 00000000
01c63cd0: 00000000 00000000 00000000 00000000
01c63ce0: 00000000 00000000 00000000 00000000
01c63cf0: 00000000 00000000 00000000 00000000
01c63d00: 00000000 00000000 00000000 00000000
01c63d10: 00000000 00000000 00000000 00000000
01c63d20: 00000000 00000000 00000000 00000000
01c63d30: 00000000 00000000 00000000 00000000
01c63d40: 00000000 00000000 00000000 00000000
01c63d50: 00000000 00000000 00000000 00000000
01c63d60: 00000000 00000000 00000000 00000000
01c63d70: 00000000 00000000 00000000 00000000
01c63d80: 00000000 00000000 00000000 00000000
01c63d90: 00000000 00000000 00000000 00000000
01c63da0: 00000000 00000000 00000000 00000000
01c63db0: 00000000 00000000 00000000 00000000
01c63dc0: 00000000 00000000 00000000 00000000
01c63dd0: 00000000 00000000 00000000 00000000
01c63de0: 00000000 00000000 00000000 00000000
01c63df0: 00000000 00000000 00000000 00000000
01c63e00: 00000000 00000000 00000000 00000000
01c63e10: 00000000 00000000 00000000 00000000
01c63e20: 00000000 00000000 00000000 00000000
01c63e30: 00000000 00000000 00000000 00000000
01c63e40: 00000000 00000000 00000000 00000000
01c63e50: 00000000 00000000 00000000 00000000
01c63e60: 00000000 00000000 00000000 00000000
01c63e70: 00000000 00000000 00000000 00000000
01c63e80: 00000000 00000000 00000000 00000000
01c63e90: 00000000 00000000 00000000 00000000
01c63ea0: 00000000 00000000 00000000 00000000
01c63eb0: 00000000 00000000 00000000 00000000
01c63ec0: 00000000 00000000 00000000 00000000
01c63ed0: 00000000 00000000 00000000 00000000
01c63ee0: 00000000 00000000 00000000 00000000
01c63ef0: 00000000 00000000 00000000 00000000
01c63f00: 00000000 00000000 00000000 00000000
01c63f10: 00000000 00000000 00000000 00000000
01c63f20: 00000000 00000000 00000000 00000000
01c63f30: 00000000 00000000 00000000 00000000
01c63f40: 00000000 00000000 00000000 00000000
01c63f50: 00000000 00000000 00000000 00000000
01c63f60: 00000000 00000000 00000000 00000000
01c63f70: 00000000 00000000 00000000 00000000
01c63f80: 00000000 00000000 00000000 00000000
01c63f90: 00000000 00000000 00000000 00000000
01c63fa0: 00000000 00000000 00000000 00000000
01c63fb0: 00000000 00000000 00000000 00000000
01c63fc0: 00000000 00000000 00000000 00000000
01c63fd0: 00000000 00000000 00000000 00000000
01c63fe0: 00000000 00000000 00000000 00000000
01c63ff0: 00000000 00000000 00000000 00000000
 1024 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC1
U-Boot 2016.09-armbian (Sep 20 2016 - 10:21:02 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC Plus
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2886 bytes read in 155 ms (17.6 KiB/s)
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
0 bytes read in 112 ms (0 Bytes/s)
** File not found /boot/.next **
** File not found .next **
35256 bytes read in 279 ms (123 KiB/s)
3368093 bytes read in 436 ms (7.4 MiB/s)
5025176 bytes read in 622 ms (7.7 MiB/s)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    3368029 Bytes = 3.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun8i (root@armbian) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #38 SMP PREEMPT Tue Sep 20 10:22:06
[    0.000000] cma: CMA: reserved 256 MiB at 50000000
<7[    0.000000] PERCPU: Embedded 8 pages/cpu @c1473000 s11968 r8192 d12608 u32768
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_me7
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 2097152 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 1024MB = 1024MB total
[    0.000000] Memory: 758460k/758460k available, 290116k reserved, 270336K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc095bce8   (9552 kB)
[    0.000000]       .init : 0xc095c000 - 0xc09aeec0   ( 332 kB)
[    0.000000]       .data : 0xc09b0000 - 0xc0a29750   ( 486 kB)
[    0.000000]        .bss : 0xc0a29f04 - 0xc0b5cf90   (1229 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.002447] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.002610] pid_max: default: 32768 minimum: 301
[    0.003425] Mount-cache hash table entries: 512
[    0.005636] Initializing cgroup subsys cpuacct
[    0.005721] Initializing cgroup subsys memory
[    0.005870] Initializing cgroup subsys devices
[    0.005944] Initializing cgroup subsys freezer
[    0.006015] Initializing cgroup subsys blkio
[    0.006112] Initializing cgroup subsys perf_event
[    0.006340] CPU: Testing write buffer coherency: ok
[    0.006484] ftrace: allocating 25740 entries in 76 pages
[    0.080499] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.080585] [sunxi_smp_prepare_cpus] enter
[    0.080683] Setting up static identity map for 0x40691938 - 0x40691990
[    0.082726] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.082880] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.090973] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.100332] Brought up 4 CPUs
[    0.100510] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.102097] devtmpfs: initialized
[    0.114773] wakeup src cnt is : 2.
[    0.114995] sunxi pm init
[    0.115317] pinctrl core: initialized pinctrl subsystem
[    0.137712] NET: Registered protocol family 16
[    0.139726] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.139726] script_sysfs_init success
[    0.139726] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.140251] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.142417] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.142510] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.143004] script config pll_video to 297 Mhz
[    0.143076] script config pll_de to 864 Mhz
[    0.143168] script config pll_ve to 402 Mhz
[    0.160528] bio: create slab <bio-0> at 0
[    0.160743] [ARISC] :sunxi-arisc driver v1.04
[    0.180067] [ARISC] :arisc version: [v0.1.58]
[    0.267356] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.270975] SCSI subsystem initialized
[    0.271460] usbcore: registered new interface driver usbfs
[    0.271685] usbcore: registered new interface driver hub
[    0.271777] usbcore: registered new device driver usb
[    0.271777] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.271777] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.271777] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.271867] Linux video capture interface: v2.00
[    0.272417] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.274063] cfg80211: Calling CRDA to update world regulatory domain
[    0.281213] Switching to clocksource arch_sys_counter
[    0.311320] FS-Cache: Loaded
[    0.311890] CacheFiles: Loaded
[    0.338404] NET: Registered protocol family 2
[    0.366050] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.367440] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.371899] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.374548] TCP: Hash tables configured (established 131072 bind 65536)
[    0.374614] TCP: reno registered
[    0.374669] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.374799] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.375639] NET: Registered protocol family 1
[    0.376496] RPC: Registered named UNIX socket transport module.
[    0.376569] RPC: Registered udp transport module.
[    0.376620] RPC: Registered tcp transport module.
[    0.376671] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.377096] Trying to unpack rootfs image as initramfs...
[    0.893655] Freeing initrd memory: 3288K
[    0.894927] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.895234] sunxi_reg_init enter
[    0.897161] audit: initializing netlink socket (disabled)
[    0.897292] type=2000 audit(0.890:1): initialized
[    0.902022] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.904146] NFS: Registering the id_resolver key type
[    0.905009] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.905087] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.906780] NTFS driver 2.1.30 [Flags: R/W].
[    0.907523] fuse init (API version 7.18)
[    0.909344] Btrfs loaded
[    0.909419] msgmni has been set to 1471
[    0.912745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.912841] io scheduler noop registered
[    0.912890] io scheduler deadline registered
[    0.913077] io scheduler cfq registered (default)
[    0.913999] [DISP]disp_module_init
[    0.914713] cmdline,init_disp=
[    0.914805] cmdline,disp=
[    0.932006] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.972236] Console: switching to colour frame buffer device 160x45
[    1.015602] [DISP]disp_module_init finish
[    1.016357] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    1.017392] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    1.017832] sw_uart_pm()890 - uart0 clk is already enable
[    1.018230] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    1.120264] console [ttyS0] enabled
[    1.341777] brd: module loaded
[    1.351285] loop: module loaded
[    1.594820] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    1.594850] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    1.594920] tun: Universal TUN/TAP device driver, 1.6
[    1.594938] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.597061] PPP generic driver version 2.4.2
[    1.597535] PPP BSD Compression module registered
[    1.597557] PPP Deflate Compression module registered
[    1.603069] PPP MPPE Compression module registered
[    1.603097] NET: Registered protocol family 24
[    1.603220] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.623401] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.623471] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.775636] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    2.180135] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    2.455362] hub 1-0:1.0: USB hub found
[    2.720636] hub 1-0:1.0: 1 port detected
[    3.042220] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.326497] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    3.421153] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    3.460094] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    3.480513] hub 2-0:1.0: USB hub found
[    3.497136] hub 2-0:1.0: 1 port detected
[    3.534523] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.556082] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    3.578176] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    3.610114] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    3.630487] hub 3-0:1.0: USB hub found
[    3.647133] hub 3-0:1.0: 1 port detected
[    3.684519] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.706019] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    3.728331] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    3.760112] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    3.780604] hub 4-0:1.0: USB hub found
[    3.797455] hub 4-0:1.0: 1 port detected
[    3.815347] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.855118] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    3.876620] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    3.897961] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    3.975285] hub 5-0:1.0: USB hub found
[    3.992049] hub 5-0:1.0: 1 port detected
[    4.029619] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    4.050811] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    4.071771] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    4.155321] hub 6-0:1.0: USB hub found
[    4.171978] hub 6-0:1.0: 1 port detected
[    4.209485] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    4.230967] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    4.252327] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    4.335377] hub 7-0:1.0: USB hub found
[    4.352143] hub 7-0:1.0: 1 port detected
[    4.389848] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    4.411410] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    4.432868] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    4.515333] hub 8-0:1.0: USB hub found
[    4.532247] hub 8-0:1.0: 1 port detected
[    4.549776] Initializing USB Mass Storage driver...
[    4.568160] usbcore: registered new interface driver usb-storage
[    4.587416] USB Mass Storage support registered.
[    4.605236] usbcore: registered new interface driver ums-alauda
[    4.624693] usbcore: registered new interface driver ums-cypress
[    4.644231] usbcore: registered new interface driver ums-datafab
[    4.663319] usbcore: registered new interface driver ums_eneub6250
[    4.682382] usbcore: registered new interface driver ums-freecom
[    4.701069] usbcore: registered new interface driver ums-isd200
[    4.719563] usbcore: registered new interface driver ums-jumpshot
[    4.738052] usbcore: registered new interface driver ums-karma
[    4.756213] usbcore: registered new interface driver ums-onetouch
[    4.774354] usbcore: registered new interface driver ums-realtek
[    4.792174] usbcore: registered new interface driver ums-sddr09
[    4.809679] usbcore: registered new interface driver ums-sddr55
[    4.827128] usbcore: registered new interface driver ums-usbat
[    4.845950] mousedev: PS/2 mouse device common for all mice
[    4.863256] sunxikbd_init failed.
[    4.878407] ls_fetch_sysconfig_para: type err  device_used = -1073060220.
[    4.896702] =========script_get_err============
[    4.912980] [RTC] WARNING: Rtc time will be wrong!!
[    4.929068] [RTC] WARNING: use *internal OSC* as clock source
[    4.946667] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    4.965030] i2c /dev entries driver
[    4.980817] IR RC5(x) protocol handler initialized
[    4.997974] twi_start()434 - [i2c0] START can't sendout!
[    5.014839] twi_start()434 - [i2c0] START can't sendout!
[    5.031530] twi_start()434 - [i2c0] START can't sendout!
[    5.047905] twi_start()434 - [i2c0] START can't sendout!
[    5.064201] twi_start()434 - [i2c0] START can't sendout!
[    5.080105] twi_start()434 - [i2c0] START can't sendout!
[    5.095767] twi_start()434 - [i2c0] START can't sendout!
[    5.111206] twi_start()434 - [i2c0] START can't sendout!
[    5.126388] twi_start()434 - [i2c0] START can't sendout!
[    5.141494] twi_start()434 - [i2c0] START can't sendout!
[    5.156224] twi_start()434 - [i2c0] START can't sendout!
[    5.170714] twi_start()434 - [i2c0] START can't sendout!
[    5.184977] twi_start()434 - [i2c0] START can't sendout!
[    5.198980] twi_start()434 - [i2c0] START can't sendout!
[    5.212895] twi_start()434 - [i2c0] START can't sendout!
[    5.226453] twi_start()434 - [i2c0] START can't sendout!
[    5.239829] twi_start()434 - [i2c0] START can't sendout!
[    5.252927] twi_start()434 - [i2c0] START can't sendout!
[    5.265756] twi_start()434 - [i2c0] START can't sendout!
[    5.278495] twi_start()434 - [i2c0] START can't sendout!
[    5.291028] twi_start()434 - [i2c0] START can't sendout!
[    5.303295] twi_start()434 - [i2c0] START can't sendout!
[    5.315292] twi_start()434 - [i2c0] START can't sendout!
[    5.327033] twi_start()434 - [i2c0] START can't sendout!
[    5.338727] twi_start()434 - [i2c0] START can't sendout!
[    5.350377] twi_start()434 - [i2c0] START can't sendout!
[    5.361967] twi_start()434 - [i2c0] START can't sendout!
[    5.373507] twi_start()434 - [i2c1] START can't sendout!
[    5.384994] twi_start()434 - [i2c1] START can't sendout!
[    5.396435] twi_start()434 - [i2c1] START can't sendout!
[    5.407838] twi_start()434 - [i2c1] START can't sendout!
[    5.419192] twi_start()434 - [i2c1] START can't sendout!
[    5.430556] twi_start()434 - [i2c1] START can't sendout!
[    5.441843] twi_start()434 - [i2c1] START can't sendout!
[    5.453102] twi_start()434 - [i2c1] START can't sendout!
[    5.464325] twi_start()434 - [i2c1] START can't sendout!
[    5.475290] twi_start()434 - [i2c1] START can't sendout!
[    5.486010] twi_start()434 - [i2c1] START can't sendout!
[    5.496417] twi_start()434 - [i2c1] START can't sendout!
[    5.506510] twi_start()434 - [i2c1] START can't sendout!
[    5.516381] twi_start()434 - [i2c1] START can't sendout!
[    5.526082] twi_start()434 - [i2c1] START can't sendout!
[    5.535478] twi_start()434 - [i2c1] START can't sendout!
[    5.544568] twi_start()434 - [i2c1] START can't sendout!
[    5.553446] twi_start()434 - [i2c1] START can't sendout!
[    5.562096] twi_start()434 - [i2c1] START can't sendout!
[    5.570720] twi_start()434 - [i2c1] START can't sendout!
[    5.579308] twi_start()434 - [i2c1] START can't sendout!
[    5.587951] twi_start()434 - [i2c1] START can't sendout!
[    5.596576] twi_start()434 - [i2c1] START can't sendout!
[    5.605202] twi_start()434 - [i2c1] START can't sendout!
[    5.613839] twi_start()434 - [i2c1] START can't sendout!
[    5.622465] twi_start()434 - [i2c1] START can't sendout!
[    5.631140] twi_start()434 - [i2c1] START can't sendout!
[    5.639569] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    5.649728] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    5.661947] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    5.675909] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    5.686071] timeout_to_interv, line 167
[    5.694396] interv_to_timeout, line 189
[    5.702828] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    5.717709] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    5.732938] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    5.759088] no blue_led, ignore it!
[    5.767142] no led_0, ignore it!
[    5.774395] no led_1, ignore it!
[    5.781667] no led_2, ignore it!
[    5.788890] no led_3, ignore it!
[    5.796146] no led_4, ignore it!
[    5.803411] no led_5, ignore it!
[    5.810678] no led_6, ignore it!
[    5.817947] no led_7, ignore it!
[    5.826451] usbcore: registered new interface driver usbhid
[    5.836696] usbhid: USB HID core driver
[    5.851279] asoc: sndcodec <-> sunxi-codec mapping ok
[    5.862483] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    5.869775] mmc0: new high speed SDHC card at address aaaa
[    5.870505] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    5.872108]  mmcblk0: p1
[    5.872827] mmcblk mmc0:aaaa: Card claimed for testing.
[    5.872847] mmc0:aaaa: SL08G 7.40 GiB
[    5.872871] *******************sd init ok*******************
[    5.938315] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    5.954111] [DAUDIO0] driver not init,just return.
[    5.971763] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    5.985878] oprofile: using arm/armv7-ca7
[    5.996891] u32 classifier
[    6.006216]     Performance counters on
[    6.016922]     input device check on
[    6.027515]     Actions configured
[    6.038132] IPv4 over IPv4 tunneling driver
[    6.050447] TCP: bic registered
[    6.060747] TCP: cubic registered
[    6.071255] TCP: westwood registered
[    6.082156] TCP: highspeed registered
[    6.093228] TCP: hybla registered
[    6.103937] TCP: htcp registered
[    6.114633] TCP: vegas registered
[    6.125473] TCP: veno registered
[    6.136060] TCP: scalable registered
[    6.146828] TCP: lp registered
[    6.156805] TCP: yeah registered
[    6.166840] TCP: illinois registered
[    6.177180] Initializing XFRM netlink socket
[    6.188808] NET: Registered protocol family 10
[    6.201528] mmc1: new high speed DDR MMC card at address 0001
[    6.201932] NET: Registered protocol family 17
[    6.201973] NET: Registered protocol family 15
[    6.202035] Registering the dns_resolver key type
[    6.246857] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    6.250407] mmcblk1: mmc1:0001 NCard  7.21 GiB
[    6.273149] ThumbEE CPU extension supported.
[    6.273207] mmcblk1boot0: mmc1:0001 NCard  partition 1 4.00 MiB
[    6.297541] Registering SWP/SWPB emulation handler
[    6.297601] mmcblk1boot1: mmc1:0001 NCard  partition 2 4.00 MiB
[    6.299332]  mmcblk1: p1
[    6.302440]  mmcblk1boot1: unknown partition table
[    6.305023]  mmcblk1boot0: unknown partition table
[    6.305387] mmcblk mmc1:0001: Card claimed for testing.
[    6.305406] mmc1:0001: NCard  7.21 GiB
[    6.305433] *******************mmc init ok *******************
[    6.394481] registered taskstats version 1
[    6.406254] cmdline,disp=
[    6.446830] ths_fetch_sysconfig_para: type err  device_used = 1.
[    6.462110] CPU Budget:corekeeper enabled
[    6.473537] CPU Budget:Register notifier
[    6.484410] CPU Budget:register Success
[    6.494952] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    6.516612] ALSA device list:
[    6.526338]   #0: audiocodec
[    6.535813]   #1: sndhdmi
[    6.546082] Freeing init memory: 328K
[    7.050140] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    7.421388] vmouse_input_dev_open
[    7.520413] vmouse_input_dev_close
[    8.543352] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    9.094711] systemd[1]: System time before build time, advancing clock.
[    9.580401] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +X)
[    9.619069] systemd[1]: Detected architecture arm.
[    9.670130] systemd[1]: Set hostname to <beelinkx2>.
[   10.172033] systemd[1]: Listening on udev Kernel Socket.
[   10.197175] systemd[1]: Listening on Journal Socket.
[   10.221553] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.249686] systemd[1]: Reached target Encrypted Volumes.
[   10.275975] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.306967] systemd[1]: Listening on Syslog Socket.
[   10.332910] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.360439] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   10.389254] systemd[1]: Listening on udev Control Socket.
[   10.416517] systemd[1]: Reached target Remote File Systems (Pre).
[   10.445004] systemd[1]: Reached target Remote File Systems.
[   10.472602] systemd[1]: Reached target Swap.
[   10.499372] systemd[1]: Created slice User and Session Slice.
[   10.527971] systemd[1]: Listening on Journal Audit Socket.
[   10.555770] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.585386] systemd[1]: Created slice System Slice.
[   10.720922] systemd[1]: Starting Load Kernel Modules...
[   10.921004] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.069204] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   11.121042] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.187909] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[   11.205932] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   11.224249] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   11.243472] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[   11.277251] mmc2: new high speed SDIO card at address 0001
[   11.294101] *******************sdio init ok*******************
[   11.300969] systemd[1]: Starting Restore / save the current clock...
[   11.359518] asoc: sndspdif <-> spdif0 mapping ok
[   11.380503] Registered IR keymap rc-empty
[   11.396058] rc0: sunxi-ir as /devices/virtual/rc/rc0
[   11.413243] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[   11.441012] systemd[1]: Starting Set console keymap...
[   11.530543] systemd[1]: Mounting POSIX Message Queue File System...
[   11.630474] systemd[1]: Mounting Debug File System...
[   11.670727] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   11.790567] systemd[1]: Starting Nameserver information manager...
[   11.817408] systemd[1]: Reached target Slices.
[   11.842356] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.974652] systemd[1]: Mounted POSIX Message Queue File System.
[   12.001738] systemd[1]: Mounted Debug File System.
[   12.120189] systemd[1]: Started Load Kernel Modules.
[   12.290189] systemd[1]: Started Remount Root and Kernel File Systems.
[   12.430169] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   12.580187] systemd[1]: Started Restore / save the current clock.
[   12.720161] systemd[1]: Started Set console keymap.
[   13.056052] systemd[1]: Time has been changed
[   13.200857] systemd[1]: Started Nameserver information manager.
[   13.390940] systemd[1]: Starting Create Static Device Nodes in /dev...
[   13.580948] systemd[1]: Starting udev Coldplug all Devices...
[   13.700902] systemd[1]: Starting Load/Save Random Seed...
[   13.850563] systemd[1]: Mounting FUSE Control File System...
[   14.000805] systemd[1]: Starting Apply Kernel Variables...
[   14.040612] systemd[1]: Mounted FUSE Control File System.
Ubuntu 16.04.1 LTS beelinkx2 ttyS0
beelinkx2 login:
And if I understood Jens correctly then the dump at the beginning should appear in any case even if u-boot then fails.
BTW: checksums to ensure integrity:
MD5 (Armbian_5.20_Beelinkx2_Ubuntu_xenial_3.4.112.7z) = a4a880cd9cce84070144ccc9d09b98d6
MD5 (Armbian_5.20_Beelinkx2_Ubuntu_xenial_3.4.112.img) = 1d04a1fb5366529a1acc3f2e64bd8874
And BTW: I'll never burn images again without Etcher since it's so much fun (just kidding, since it always does a verify after burning -- sometimes I'm too lazy or in a hurry, don't do it and waste huge amounts of time with corrupted SD cards)
Link to post
thanks for testing, though it didn't work as expected because I missed something...
Try this version instead please, it should be the last one before we get something working if my guess is correct.
Since I can't seem to attach something in this forum, I've put it on some filehoster, I hope you don't mind:
http://s000.tinyupload.com/index.php?file_id=08531390628113315299
MD5 sums:
f5603a2decf1f1225a2f618e67ea0508  beelink-x2-test.img.bz2
3f46675f5a70c3c8231f51088c9eb6bf  beelink-x2-test.img
Link to post
Thanks.
So here is a new spl-only image which should work now. If it does, I'll send a patch to u-boot list soon. Please post it's output again, to verify it matches the expected results.
attachicon.gifbeelink-x2-spl.img.zip
Source: https://github.com/jemk/u-boot/commits/h3-rev-a-dram-zq
now I can see dram )))
U-Boot SPL 2016.09-dirty (Sep 21 2016 - 16:08:07)
DRAM:01c63140: 017b3bfb c0444444 09090a0a 07070a0a
01c63150: 07070a0a 00000000 00000000 00000000
 1024 MiB
Link to post
Ha, good. Output matches the one you posted on monday too, so everything is fine.
You can try to integrate this into an armbian sdcard if you still have one (dd if=beelink-x2-spl.img of=/dev/your-sd-card bs=1024 skip=8 seek=8), or you'll have to wait for a new complete image, I don't use armbian myself.
Link to post
Great!
@Armen Hovhannisyan: Can you please give http://213.179.157.5/orders/Armbian_5.20_Beelinkx2_Ubuntu_xenial_3.4.112.img.bz2  a try? You can burn it directly with Etcher without decompressing first. Please report back then :)
(it's just a console image but at least we know then that I applied jemk's patch correctly to Armbian -- after your confirmation we can roll out new images soon since it seems not only Beelink X2 is affected but other 'Rev A' H3 devices too)
Edit: Nope, Etcher can not deal with this compressed archive, therefore uncompressing first is necessary.
Edit 2: md5sums below (image contains both patches so also spits out the dump before it should resume with a normal boot)
MD5 (Armbian_5.20_Beelinkx2_Ubuntu_xenial_3.4.112.img) = a701e4748f28d873b1a72d351fc4dd6e
MD5 (Armbian_5.20_Beelinkx2_Ubuntu_xenial_3.4.112.img.bz2) = 4962f66d9d8904e7afd82a5bb86cae9d
Link to post
Thanks, at least it boots and hardware seems to be recognized correctly (a few USB ports too much but hey...). I built the image without external applications so it's not that useful anyway (quick&dirty since all we needed was Jens' help here).
@Igor: would be great if you could at least rebuild both legacy images for X2 with the patch now applied and encourage the affected users to try them out so that we get more useful feedback. Thx.
Link to post
confirm: All USB, WIFI, Ethernet, HDMI working correctly.
if I can help I will do it
Link to post
it also ends up stopping with this on screen
This is now the so called login prompt. Now you should login as root with pwd 1234, then change root pwd and so on. It seems your console gets spammed with some warnings so this might get hard doing interactively with keyboard and display. Aren't you able to simply login through SSH? Then the messages won't bother you and you can do the initial setup remotely.
Link to post
