guidol Posted September 6, 2020 Author Share Posted September 6, 2020 @5kft @Hannes Worst it seems that current 5.8.7 is missing some modules for the analog audio (or they are named in a other way) than legacy 5.4.63, because with the legacy image analog-audio does work. I do see much more sound-modules loaded than in current 5.8.7: Module Size Used by sun50i_codec_analog 28672 1 sun8i_codec 28672 1 snd_soc_simple_card_utils 20480 1 snd_soc_simple_card sun4i_i2s 24576 4 sun8i_drm_hdmi 24576 0 snd_soc_core 176128 7 sun4i_i2s,snd_soc_spdif_tx,snd_soc_hdmi_codec,sun50i_codec_analog,sun8i_codec,snd_soc_simple_card_utils,snd_soc_simple_card dw_hdmi 40960 2 sun8i_drm_hdmi,dw_hdmi_i2s_audio ac97_bus 16384 1 snd_soc_core snd_pcm_dmaengine 16384 1 snd_soc_core cec 69632 2 dw_hdmi_cec,dw_hdmi snd_pcm 110592 5 sun4i_i2s,snd_soc_hdmi_codec,sun8i_codec,snd_soc_core,snd_pcm_dmaengine snd_timer 40960 1 snd_pcm snd 86016 8 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm soundcore 16384 1 snd sun4i_drm 20480 0 sun4i_frontend 16384 1 sun4i_drm sun4i_tcon 32768 1 sun4i_drm sun8i_mixer 40960 0 sun8i_tcon_top 16384 3 sun8i_drm_hdmi,sun4i_tcon,sun4i_drm dwmac_sun8i 28672 0 mdio_mux 16384 1 dwmac_sun8i 0 Quote Link to comment Share on other sites More sharing options...
5kft Posted September 6, 2020 Share Posted September 6, 2020 16 minutes ago, guidol said: @5kft @Hannes Worst it seems that current 5.8.7 is missing some modules for the analog audio (or they are named in a other way) than legacy 5.4.63, because with the legacy image analog-audio does work. I do see much more sound-modules loaded than in current 5.8.7: Part of this difference could be that in the newer kernel more audio modules built in. What I'm seeing is that when I try analog audio it works fine - e.g., I don't see the "no soundcards" error, and I can play audio, etc. (e.g., I tested on a NEO Core2 but don't get any audio errors on any of the other boards either). So it seems that there is something different for the A64, and I agree with you it's likely the DT configuration. 0 Quote Link to comment Share on other sites More sharing options...
Hannes Worst Posted September 6, 2020 Share Posted September 6, 2020 This shows cards are detected on the kernel 5.7.15. dmesg|grep -i sound [ 8.338780] asoc-simple-card sound: sun8i-codec-aif1 <-> 1c22c00.dai mapping ok [ 9.015640] asoc-simple-card hdmi-sound: i2s-hifi <-> 1c22800.i2s mapping ok 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted September 6, 2020 Author Share Posted September 6, 2020 2 minutes ago, Hannes Worst said: It works on the kernel 5.7.15. dmesg|grep -i sound [ 8.338780] asoc-simple-card sound: sun8i-codec-aif1 <-> 1c22c00.dai mapping ok [ 9.015640] asoc-simple-card hdmi-sound: i2s-hifi <-> 1c22800.i2s mapping ok got this dmesg-output alos in 5.8.7, but no output from analog-audio from the NPi A64 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted October 26, 2020 Author Share Posted October 26, 2020 On 9/6/2020 at 5:16 PM, 5kft said: Part of this difference could be that in the newer kernel more audio modules built in. So it seems that there is something different for the A64, and I agree with you it's likely the DT configuration. @5kft @Hannes Worst @@lex somebody did hear us the analog sound is back in dev kernel/dtb 5.9.1 and now - I think - we have found the missing link: sound was playing but we didnt hear anything on analog-audio because - as I remember right - the option AIF1 Slot 0 Digital DAC was missing. So it couldnt be enabled Now the option is back and the DAC could now enabled again - so no more silence anymore BUT be advised to set AIF DA0 not higher than 17, because then the sound will very fast be distorted/overdriven So here is my kernel-information als alsamixer-setting for analog-audio (sun50i-a64-audio): _ _ ____ _ _ __ _ _ | \ | | _ \(_) / \ / /_ | || | | \| | |_) | | / _ \| '_ \| || |_ | |\ | __/| | / ___ \ (_) |__ _| |_| \_|_| |_| /_/ \_\___/ |_| Welcome to Debian GNU/Linux 10 (buster) with Linux 5.9.1-sunxi64 No end-user support: built from trunk package bsp-kernel[20.11.0-trunk] u-boot[20.11.0-trunk] dtb [20.11.0-trunk] firmware [20.11.0-trunk] config[20.11.0-trunk] branch[dev] root@npi-a64-116(192.168.6.116):~# uname -a Linux npi-a64-116 5.9.1-sunxi64 #trunk SMP Mon Oct 26 18:14:55 +03 2020 aarch64 GNU/Linux root@npi-a64-116(192.168.6.116):~# more /etc/os-release PRETTY_NAME="Debian GNU/Linux 10 (buster)" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" root@npi-a64-116(192.168.6.116):~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: sun50ia64audio [sun50i-a64-audio], device 0: 1c22c00.dai-sun8i-codec-aif1 sun8i-codec-aif1-0 [1c22c00.dai-sun8i-codec-aif1 sun8i-codec-aif1-0] Subdevices: 0/1 Subdevice #0: subdevice #0 card 1: sun50ia64hdmi [sun50i-a64-hdmi], device 0: 1c22800.i2s-i2s-hifi i2s-hifi-0 [1c22800.i2s-i2s-hifi i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 root@npi-a64-116(192.168.6.116):~# alsamixer Card: sun50i-a64-audio Value: Item: 83 Headphone [dB gain: -8.00] Mixer Headphone Source [Mixer] 15 AIF1 DA0 [dB gain: -24.00, -24.00] Stereo AIF1 DA0 Stereo [Stereo] Enable AIF1 Slot 0 Digital DAC 82 DAC [dB gain: 18.75, 18.75] Enable DAC Reversed 1 Quote Link to comment Share on other sites More sharing options...
Hannes Worst Posted November 1, 2020 Share Posted November 1, 2020 Great, Guidol! Thank you very much for this good news. I wil try it out! Thanks for the one that solved the problem. 1 Quote Link to comment Share on other sites More sharing options...
Levent Erenler Posted November 6, 2020 Share Posted November 6, 2020 On 11/1/2020 at 5:08 PM, Hannes Worst said: Great, Guidol! Thank you very much for this good news. I wil try it out! Thanks for the one that solved the problem. Hi, do you have a chance to test it? I could not get sound from audio jack. Could you share your dts if the analog audio working? Thank you 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted November 7, 2020 Author Share Posted November 7, 2020 14 hours ago, Levent Erenler said: Hi, do you have a chance to test it? I could not get sound from audio jack. Could you share your dts if the analog audio working? Thank you For me it does work, but I dont know if @Hannes Worst did had success Here are the "warnings" while decompiling the .dtb to .dts (see attachment) : root@npi-a64-116(192.168.6.116):/boot/dtb/allwinner# dtc -I dtb -O dts /boot/dtb/allwinner/sun50i-a64-nanopi-a64.dtb -o /boot/dtb/allwinner/sun50i-a64-nanopi-a64_kernel_591.dts /boot/dtb/allwinner/sun50i-a64-nanopi-a64_kernel_591.dts: Warning (unit_address_vs_reg): /sound/simple-audio-card,dai-link@0: node has a unit name, but no reg property /boot/dtb/allwinner/sun50i-a64-nanopi-a64_kernel_591.dts: Warning (avoid_unnecessary_addr_size): /sound: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property /boot/dtb/allwinner/sun50i-a64-nanopi-a64_kernel_591.dts: Warning (avoid_unnecessary_addr_size): /soc/dsi@1ca0000: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property I dont know if this .dts will work with lower kernel numbers root@npi-a64-116(192.168.6.116):/boot# uname -a Linux npi-a64-116 5.9.1-sunxi64 #trunk SMP Mon Oct 26 18:14:55 +03 2020 aarch64 GNU/Linux OR Linux npi-a64-116 5.10.0-rc2-sunxi64 #trunk SMP Sat Nov 7 14:11:13 +03 2020 aarch64 GNU/Linux sun50i-a64-nanopi-a64_kernel_591.dts sun50i-a64-nanopi-a64_kernel_510rc2.dts 0 Quote Link to comment Share on other sites More sharing options...
Levent Erenler Posted November 7, 2020 Share Posted November 7, 2020 (edited) Thanks @guidol I am testing with pine64+ A64 kernel 5.9.5 i have same warnings in original dtb. I try many things but i could not figure whats wrong! I try to compare my dts file with yours.Do you have source, i mean dts files before compiled(easy to read) or is that https://github.com/megous/linux/tree/orange-pi-5.9 Thank you i try to gave more information UPDATE: I found a solution Edited November 11, 2020 by Levent Erenler solution 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted November 7, 2020 Author Share Posted November 7, 2020 2 hours ago, Levent Erenler said: i try to gave more information @Levent Erenler I did give you an information in your thread to unmute your headphone in alsamixer - there in the picture its muted. 0 Quote Link to comment Share on other sites More sharing options...
Hannes Worst Posted November 14, 2020 Share Posted November 14, 2020 @guidolI wasn't able yet to try out the 5.9 kernel. I tested the dts file you posted as a dtb file on the present (lower) 5.8 kernel and found out it doesn't work to activate analog sound. aplay -l **** List of PLAYBACK Hardware Devices **** card 0: sun50ia64hdmi [sun50i-a64-hdmi], device 0: 1c22800.i2s-i2s-hifi i2s-hifi-0 [1c22800.i2s-i2s-hifi i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio] Subdevices: 0/1 Subdevice #0: subdevice #0 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted August 12, 2021 Author Share Posted August 12, 2021 I compiled Hirsute Hippo [edge] for the NanoPi A64 and got out of the compile a Kernel 5.12.x There was analog-audio but no control for the blue led. After updateing I got the Kernel 5.13.9 - now there was a control for the blue led, but no analog audio So I did decompile the .dtb to .dts /edited it/recompiled the .dts to .dtb - now analog audio is working again Spoiler sound { status = "okay"; i2s@1c22000 { status = "okay"; dai@1c22c00 { status = "okay"; codec@1c22e00 { status = "okay"; codec-analog@1f015c0 { status = "okay"; _ _ ____ _ _ __ _ _ | \ | | _ \(_) / \ / /_ | || | | \| | |_) | | / _ \| '_ \| || |_ | |\ | __/| | / ___ \ (_) |__ _| |_| \_|_| |_| /_/ \_\___/ |_| Welcome to Armbian 21.08.0-trunk Hirsute with bleeding edge Linux 5.13.9-sunxi64 No end-user support: built from trunk package bsp-kernel[21.08.0-trunk.114] u-boot[21.08.1] dtb [21.08.0-trunk.114] firmware [21.08.0-trunk] config[21.08.0-trunk] branch[edge] uname -a Linux npi-a64-116 5.13.9-sunxi64 #trunk.114 SMP Sun Aug 8 22:12:23 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux aplay -l **** List of PLAYBACK Hardware Devices **** card 0: sun50ia64audio [sun50i-a64-audio], device 0: 1c22c00.dai-sun8i-codec-aif1 sun8i-codec-aif1-0 [1c22c00.dai-sun8i-codec-aif1 sun8i-codec-aif1-0] Subdevices: 0/1 Subdevice #0: subdevice #0 card 1: sun9ihdmi [sun9i-hdmi], device 0: SUN9I-HDMI PCM i2s-hifi-0 [SUN9I-HDMI PCM i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 sun50i-a64-nanopi-a64.dtb_5_13_9_analog_audio_enabled sun50i-a64-nanopi-a64.dtb_5_13_9_org sun50i-a64-nanopi-a64.dts 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted September 7, 2022 Author Share Posted September 7, 2022 (edited) Here is a working (USB-ports & analog Sound) patched sun50i-a64-nanopi-a64 .DTS/.DTB for Kernel 5.18.15 under armbian bullseye Dont know why these arent automatically configured at armbian/kernel-compile _ _ ____ _ _ __ _ _ | \ | | _ \(_) / \ / /_ | || | | \| | |_) | | / _ \| '_ \| || |_ | |\ | __/| | / ___ \ (_) |__ _| |_| \_|_| |_| /_/ \_\___/ |_| Welcome to Armbian 22.08.0-trunk Bullseye with Linux 5.18.15-sunxi64 No end-user support: community creations System load: 2% Up time: 16 min Local users: 2 Memory usage: 14% of 984M IP: 192.168.6.116 CPU temp: 27°C Usage of /: 24% of 15G RX today: 23.9 MiB [ General system configuration (beta): armbian-config ] Last login: Wed Sep 7 14:05:25 2022 from 192.168.6.17 root@npi-a64-116:~# uname -a Linux npi-a64-116 5.18.15-sunxi64 #trunk SMP Thu Aug 4 12:51:25 +03 2022 aarch64 GNU/Linux root@npi-a64-116:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: sun50ia64audio [sun50i-a64-audio], device 0: 1c22c00.dai-sun8i-codec-aif1 sun8i-codec-aif1-0 [1c22c00.dai-sun8i-codec-aif1 sun8i-codec-aif1-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: sun9ihdmi [sun9i-hdmi], device 0: SUN9I-HDMI PCM i2s-hifi-0 [SUN9I-HDMI PCM i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 sun50i-a64-nanopi-a64_5_18_15.zip DTS_Changes_NPI_A64.doc DTS_Changes_NPi_A64.pdf Edited September 7, 2022 by guidol 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 7, 2022 Share Posted September 7, 2022 39 minutes ago, guidol said: Dont know why these arent automatically configured This is the diff between your device tree and the one shipped with (latest 5.19.y) kernel: Spoiler @@ -172,7 +172,7 @@ simple-audio-card,name = "sun50i-a64-audio"; simple-audio-card,aux-devs = <0x10>; simple-audio-card,routing = "Left DAC\0DACL\0Right DAC\0DACR\0ADCL\0Left ADC\0ADCR\0Right ADC"; - status = "disabled"; + status = "okay"; phandle = <0x4f>; simple-audio-card,dai-link@0 { @@ -661,8 +661,8 @@ phys = <0x2c 0x00>; phy-names = "usb"; extcon = <0x2c 0x00>; - dr_mode = "otg"; - status = "disabled"; + dr_mode = "host"; + status = "okay"; phandle = <0x68>; }; @@ -963,7 +963,7 @@ resets = <0x02 0x27>; dma-names = "rx\0tx"; dmas = <0x30 0x03 0x30 0x03>; - status = "disabled"; + status = "okay"; phandle = <0x7d>; }; @@ -1005,7 +1005,7 @@ resets = <0x02 0x24>; dmas = <0x30 0x0f 0x30 0x0f>; dma-names = "rx\0tx"; - status = "disabled"; + status = "okay"; phandle = <0x12>; }; @@ -1016,7 +1016,7 @@ interrupts = <0x00 0x1c 0x04>; clocks = <0x02 0x38 0x02 0x6b>; clock-names = "bus\0mod"; - status = "disabled"; + status = "okay"; phandle = <0x13>; }; @@ -1232,7 +1232,7 @@ }; pwm@1c21400 { - compatible = "allwinner,sun50i-a64-pwm\0allwinner,sun5i-a13-pwm"; + compatible = "allwinner,sun50i-a64-pwm"; reg = <0x1c21400 0x400>; clocks = <0x2d>; pinctrl-names = "default"; @@ -1401,7 +1401,7 @@ codec-analog@1f015c0 { compatible = "allwinner,sun50i-a64-codec-analog"; reg = <0x1f015c0 0x04>; - status = "disabled"; + status = "okay"; phandle = <0x10>; }; @@ -1431,7 +1431,7 @@ }; pwm@1f03800 { - compatible = "allwinner,sun50i-a64-pwm\0allwinner,sun5i-a13-pwm"; + compatible = "allwinner,sun50i-a64-pwm"; reg = <0x1f03800 0x400>; clocks = <0x2d>; pinctrl-names = "default"; @@ -1767,7 +1767,7 @@ hdmi-connector { compatible = "hdmi-connector"; - type = "a"; + type = [61 00]; port { Everything is there, just disabled by default. Don't we have overlays for enabling this via armbian-config -> system -> hardware? 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted September 7, 2022 Author Share Posted September 7, 2022 (edited) Maybe I could create (a) overlay(s), but at this time only the following hardware can be toggled via armbian-config -> system -> hardware: Edited September 7, 2022 by guidol 0 Quote Link to comment Share on other sites More sharing options...
