herken Posted May 6, 2019 Posted May 6, 2019 (edited) I have been running Armbian_5.83.190502_Orangepi3_Ubuntu_bionic_dev_5.0.10.img since it was released and have no problems so far. I wrote it to the EMMC and everything seems to work apart from the Wi-Fi. Running cp /lib/firmware/brcm/brcmfmac4356-sdio.bin /lib/firmware/brcm/brcmfmac43456-sdio.bin cp /lib/firmware/brcm/brcmfmac4356-sdio.txt /lib/firmware/brcm/brcmfmac43456-sdio.txt fixes the Wi-Fi for both 2.4 and 5 GHz. However, the bit rates do not seem to be higher than 54 Mb/s (802.11g). Iperf3 benchmark had 941 Mb/s on the ethernet port (might be capped also by my router or laptop ethernet adapter). EMMC gets around 81 MB/s read speed. Edited May 6, 2019 by herken
chwe Posted May 6, 2019 Posted May 6, 2019 1 hour ago, Erfan said: And also the display, does it work with the current 5.0.7? display means HDMI? 1 hour ago, Erfan said: When will the 5.1 image come? The kernel was released yesterday whenever someone fixes all the patches which might need an adjustment & proves that the board is actually booting. It probably not top priority to move to 5.1.
Chuck_Norris Posted May 7, 2019 Posted May 7, 2019 Hi Guys... Very nice work indeed. Never thought the board would make it so far. Just resurrected it from beeing paper weight... Unfortunately it came to my attention that mdadm (RAID5 support to be more specific) is still not activated to the Kernel. By any chance: There is noone with a compiling environment around able plus willing to compile one with raid activated? Cheers! Chuck
ilchenko Evgeny Posted May 7, 2019 Posted May 7, 2019 2 hours ago, Chuck_Norris said: Hi Guys... Very nice work indeed. Never thought the board would make it so far. Just resurrected it from beeing paper weight... Unfortunately it came to my attention that mdadm (RAID5 support to be more specific) is still not activated to the Kernel. By any chance: There is noone with a compiling environment around able plus willing to compile one with raid activated? Cheers! Chuck back of the queue my firend hdmi sound in the priority)))
GeorgeP Posted May 7, 2019 Posted May 7, 2019 2 hours ago, Chuck_Norris said: Unfortunately it came to my attention that mdadm (RAID5 support to be more specific) is still not activated to the Kernel. By any chance: There is noone with a compiling environment around able plus willing to compile one with raid activated? Are you really considering building an madm RAID with USB drives? Technically it is possible but I doubt you'll get anything but problems with reliability. It's easier than you may think to compile yourself - check out https://docs.armbian.com/Developer-Guide_Build-Preparation/ If you're looking to 'play' with mdadm as a learning exercise then fine, but if you really value your data I'd suggest you should build a 'proper' raid using an x86 board and good quality SATA drives. On budget SoC boards I'd just rsync my precious data across several physical drives. 1
flybytim Posted May 7, 2019 Posted May 7, 2019 Is it correct to say that PCIe does not work on the Allwinner H6?
martinayotte Posted May 7, 2019 Posted May 7, 2019 25 minutes ago, flybytim said: Is it correct to say that PCIe does not work on the Allwinner H6? Right ! Details explained here : http://linux-sunxi.org/H6
flybytim Posted May 7, 2019 Posted May 7, 2019 14 minutes ago, martinayotte said: Right ! Details explained here : http://linux-sunxi.org/H6 Yes I read that yesterday. From the wording is seems like it would never be supported?
martinayotte Posted May 7, 2019 Posted May 7, 2019 5 minutes ago, flybytim said: From the wording is seems like it would never be supported? Right ! ... maybe some people will do their own driver modifications according to their needs, but it will not become mainlined ... Hoping AllWinner won't repeat their mistake in any future SoC ...
flybytim Posted May 7, 2019 Posted May 7, 2019 6 minutes ago, martinayotte said: Right ! ... maybe some people will do their own driver modifications according to their needs, but it will not become mainlined ... Hoping AllWinner won't repeat their mistake in any future SoC ... The one selling point for the orange pi 3 is the PICe what where they thinking.. Oh well any recommendations for an sbc pcie?
martinayotte Posted May 7, 2019 Posted May 7, 2019 7 minutes ago, flybytim said: Oh well any recommendations for an sbc pcie? There are many, I don't know all of them since I've never used their PCIe, but according to some reading, the RockPro64 seems to be a good one.
data Posted May 8, 2019 Posted May 8, 2019 On 5/6/2019 at 2:13 PM, Igor said: Non working ones were removed. Saving your time and support expense. Since there is a new nightly for OPi lite2 now, is it working again?
martinayotte Posted May 8, 2019 Posted May 8, 2019 16 minutes ago, data said: Since there is a new nightly for OPi lite2 now, is it working again? It should !
Chuck_Norris Posted May 8, 2019 Posted May 8, 2019 22 hours ago, GeorgeP said: Are you really considering building an madm RAID with USB drives? I do and I already did so. I really appreciate building stuff of things I already have around. Plus RAID5 proofed itself as reliable option for me. And please keep in mind: I'm talking about RAID5 and not backup options (when it comes to valuable data). I just thought some guys here already do have a compilation environment around, able to check "RAID" next time they compile. Just a "pretty, pretty please with sugar on top" question... Regards Chuck
data Posted May 8, 2019 Posted May 8, 2019 1 hour ago, martinayotte said: It should ! Great, thank you! I am just about to update my device. In case it fails I'll let you know...
martinayotte Posted May 8, 2019 Posted May 8, 2019 3 minutes ago, data said: Great, thank you! I am just about to update my device. In case it fails I'll let you know... I've just tested, and I think I found something ... But it will be fixed soon ... @Igor , it seems that the following missing since a commit from 10 days ago : +&cpu0 { + cpu-supply = <®_dcdca>; +}; +
data Posted May 8, 2019 Posted May 8, 2019 I made a fresh install of the 0423 nightly. Then # apt update # apt upgrade # reboot -> fubar. Is this caused by the missing cpu0 reference mentioned above?
martinayotte Posted May 8, 2019 Posted May 8, 2019 55 minutes ago, data said: -> fubar. What do you mean ?
martinayotte Posted May 8, 2019 Posted May 8, 2019 1 hour ago, data said: It does not boot. OrangePiLite2, right ? I've fixed few things and commited them. Try later tomorrow's build ...
data Posted May 8, 2019 Posted May 8, 2019 Thank you again. Will flash the upcoming nightly tomorrow then and let you know.
may Posted May 8, 2019 Posted May 8, 2019 I have compiled the latest commit b79c38c86ca27c2112dfd0d8274cb3963aadb2f8 it boots failed. see bootlog serial Quote [ 4.673040] Kernel panic - not syncing: Fatal exception in interrupt [ 4.679386] SMP: stopping secondary CPUs [ 5.724968] SMP: failed to stop secondary CPUs 0-1,3 [ 5.729924] Kernel Offset: disabled [ 5.733405] CPU features: 0x002,20002004 [ 5.737319] Memory Limit: none [ 5.740370] Rebooting in 10 seconds.. [ 15.984039] SMP: stopping secondary CPUs [ 17.029621] SMP: failed to stop secondary CPUs 0-1,3
HannesH Posted May 9, 2019 Posted May 9, 2019 Really greatful for the latest debian strech version you've made for orange pi 3. Installed openmediavault on it and almost everything works perfect. Only thing is I can't make raid on it. When I insterted "mdadm --create /dev/md/name /dev/sda /dev/sdb --level=1 --raid-devices=2" it says: mdadm unexpected failure opening /dev/md127 After a bit of research about the meaning of it, I found out that probably it does not have the RAID subsystem loaded in to the kernel. Would really really appreciate if next version would include that too
flybytim Posted May 9, 2019 Posted May 9, 2019 cat: /dev/ttyS1: Input/output error How do I enable UART?
martinayotte Posted May 9, 2019 Posted May 9, 2019 17 minutes ago, flybytim said: How do I enable UART? Overlays in /boot/armbianEnv.txt, edit and reboot : overlays=uart1
flybytim Posted May 9, 2019 Posted May 9, 2019 23 minutes ago, martinayotte said: Overlays in /boot/armbianEnv.txt, edit and reboot : overlays=uart1 Thank you I got UART3 working but do you happen to know what "S-UART" is?
martinayotte Posted May 9, 2019 Posted May 9, 2019 1 hour ago, flybytim said: but do you happen to know what "S-UART" is? It is not actually provided in any DT nodes ... I will add it in the following days, directly in main DT, without any needs for overlay. Then, you will need to take a new nightly image ... 1
Nedo Posted May 9, 2019 Posted May 9, 2019 Hi, i have joined for testing your build in Orangepi3. Thanks for your work!
martinayotte Posted May 9, 2019 Posted May 9, 2019 6 hours ago, flybytim said: but do you happen to know what "S-UART" is? Job done ! R_UART added, but it need an overlay loaded dynamically using the following code, otherwise it will take place of /dev/ttyS0, preventing using the debug UART since it will be shifted to /dev/ttyS1 ... mkdir /sys/kernel/config/device-tree/overlays/ruart/ cat /boot/dtb/allwinner/overlay/sun50i-h6-ruart.dtbo > /sys/kernel/config/device-tree/overlays/ruart/dtbo
data Posted May 9, 2019 Posted May 9, 2019 What if ttyS1 already exists? And is the ttyS1 uart1 overlay available and working with the new nightly now?
