20 minutes ago, 5kft said:
Sure, but it is rather difficult to solve a problem if you don't try to debug it ;)  Why not put a little more effort into this, it certainly is an interesting and strange problem...!
If you read this thread, you already see that I put some effort into it. Given that there is no documentation about the source of the overlay and u-boot files in Armbian, there is little to debug. It should be easy for you to tell me e.g. which u-boot patches your image uses or at least which git ref you build
Maybe, but you are mixing symptoms and issues and refuse to do what we suggested ...
As I said twice, and now a third time, did you do :
If you re-run "nand-sata-install", does it provide the option "Install/Update the bootloader on SD/eMMC" ? If Yes, simply give it a try ...
If the RootFS on eMMC is Ok, and only refuse to boot directly from eMMC, then it is U-Boot that needs to be recovered ...
Indeed...it's a very odd problem!  There's actually a lot you can try to debug, but you'll have to figure some things out.  You can start where I started last year:  https://docs.armbian.com/Developer-Guide_Build-Preparation/.  If you follow the build process (see the "How to start?" section) you'll end up with everything you need locally - all source, all patches, etc. will be present in the "build" tree.  This is truly one of the awesome things about Armbian - give it a try, it's very cool!
I did that ~25 times using 4 different Armbian builds without success however the year old OrangePI Ubuntu image does successfully install to eMMC *and* boot after. After checking the eMMC integrity successfully, there are two possibilities left:
A. It never worked with Armbian
B. It worked in an old Armbian release which is not available anymore.
C. something changed in BROM (or whatver this is called with Allwinner) with my late 2018 board. This is very unlikely because the year old OrangePI image works.
If A): Ok, I'll accept and stop
If B): Tell me which version worked so I can do a bisect manually and debug.
Thanks
5 hours ago, rmoriz said:
Has someone of you actually managed to get a full eMMC based installation working with nand-sata-install on the Orange Pi Zero Plus2 H5?
as I now recall I had problems with the transfer to eMMC with the latest DEV build, but only because I used a old/slow and maybe defective 16GB SanDIsk Ultra.
The problem was that after 53% of transfer the system doenst answered and disconnected the SSH-session.
After that I used my 32GB Sandisk Extreme and it worked in the 1st try.
Did you try to install/transfer to eMM with another (more speedy) card?
The "defective" 16GB Card could formatted without problems and I could write the image with ecther without no problem (incl. verify),
but I do see this strange time-leaks while setting up the inital password and adding the first user after root.
I hope you don't use the same method used for installing eMMC  using a Non-Armbian image with Armbian one which is "nand-sata-install".
As I said earlier, on my OPiZeroPlus2-H5, I've installed Armbian on eMMC successfully several times since years and last time was 2 weeks ago with 4.20.y.
Did you have done what I suggested, first :
To see more verbosity, edit /boot/armbianEnv.txt, make sure that "verbosity=7" and "console=serial" instead of "console=both".
Then, for the fourth time, did you have done :
If really Yes, what was the results ? When rebooting without SDCard inserted, do you see any u-boot activity ? Is it starting booting the kernel ? if Yes, what is the output just before it abort and reboot in loop ?
Does it says that it can't find RootFS with proper UUID ? Did you check if UUID are properly set in both /boot/armbianEnv.txt and /etc/fstab of the eMMC (not the one from SDCard) ?
None of the above, since it works for all of us, and you seems to be the only one to get such failure ...
To be sure I did compile this evening the actual (of today) DEV-version:
Armbian_5.73_Orangepizeroplus2-h5_Debian_stretch_dev_4.20.2.img
Flashed it to sdcard via etcher - and after a little bit configuring - I transfered it (using a Samsung EVO 32GB) to the eMMC
without problems:
ARMBIAN 5.73 user-built Debian GNU/Linux 9 (stretch) 4.20.2-sunxi64
Linux opi-zero-plus2-h5 4.20.2-sunxi64 #5.73 SMP Mon Jan 28 20:12:49 +03 2019 aarch64 GNU/Linux
Dateisystem    1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
udev              178024       0    178024    0% /dev
tmpfs              49292    2308     46984    5% /run
/dev/mmcblk2p1   7370336 1268920   5707308   19% /
tmpfs             246448       0    246448    0% /dev/shm
tmpfs               5120       4      5116    1% /run/lock
tmpfs             246448       0    246448    0% /sys/fs/cgroup
tmpfs             246448       4    246444    1% /tmp
/dev/zram0         49584    3136     42864    7% /var/log
tmpfs              49288       0     49288    0% /run/user/0
I know, I posted a lot, so I'll summarize it quickly for you:
The remaining issue with Armbian is the "CPU reset" loop after a nand-sata-install immediately after power-up. There is no need to increase kernel verbosity because the kernel gets never loaded. U-Boot is broken.
without problems:
Did you remove the SD card? Does it boot without the SD-Card?
What brings you that "U-Boot is broken." ? Many people here are trying to help you, but you're jumping to wrong conclusion ...
If you don't want to increase verbosity, which is quite simple task, you don't even know why causing the kernel reboot in loop during this famous 44secs . I bet it is a UUID issue !!!
If you don't do what we are asking for, no one will be able to help you !!! Simple is that !!!
9 hours ago, martinayotte said:
Of course @guidol will say YES ! (but I will leave him to say it by himself ...)
YES ;) after the transfer to eMMC I did "poweroff" and remove the sdcard.
At next poweron the Plus2 H5 did boot without problems from eMMC.
I've built a custom image using the docker method (result was named Armbian_5.73_Orangepizeroplus2-h5_Ubuntu_bionic_next_4.19.17.img), etched it to SD, booted and installed it to eMMC.
Result:
U-Boot SPL 2018.11-armbian (Jan 28 2019 - 23:02:45 +0000)
DRAM: 512 MiB
Trying to boot from MMC2
(hangs, no LED, serial output)
compared to the behaviour of the release image (as mentioned in my opening post already)
U-Boot SPL 2018.05-armbian (Jan 12 2019 - 18:49:16 +0100)
DRAM: 512 MiB
(looping)
"Synchronous Abort" handler, esr 0x8a000000
elr: 0000000000016895 lr : 0000000000016895
x 0: 0000000000017718 x 1: 0000000000000500
x 2: 0000000000000001 x 3: ffffff80ffffffc8
x 4: 0000000000000001 x 5: 000000000000004a
x 6: 000000004fdffba8 x 7: 000000000000000a
x 8: 0000000000000044 x 9: 800303d600000000
x10: 9419820400000000 x11: 000000000000000c
x12: 4028177e0007fffe x13: 02042420a1fe8820
x14: 1c4401836c41c200 x15: 0012010004200000
x16: 102520254a2c0844 x17: 0c03fc405001bb46
x18: 000000004fdffe80 x19: 0000000000000022
x20: 00000000ffffffc8 x21: 000000004fdff0f0
x22: 000000000001717b x23: 000000000001717b
x24: 000000004fdff0b0 x25: 000000004fdff5f1
x26: 000000004fdff0b1 x27: 0000000000000030
x28: 5e0f2289281c052c x29: 000000004fdff410
Resetting CPU ...
resetting ...
(/looping)
PS: Yes, I've set verbosity=7 and console=both as before, by manually mounting the emmc filesystem and chaging /boot/armbianEnv.txt. There is sadly no change in outcome/output.
Thanks for the effort ! Sorry if I've been rude earlier ...
Strange issue ... Could you provide picture of the eMMC ?
If it differ from the one on all forum members's boards, like mine, it is maybe a new eMMC chip not supported yet by U-Boot, but still strange since it is working on a already booted kernel.
I will search in U-Boot forums, mailing list, and IIRC to see if a U-Boot dev already have a fix, but I doubt since Armbian is already using v2018.11, which is quite recent ...
47 minutes ago, martinayotte said:
Strange issue ... Could you provide picture of the eMMC ?If it differ from the one on all forum members's boards, like mine, it is maybe a new eMMC chip not supported yet by U-Boot, but still strange since it is working on a already booted kernel.
I think this is the eMMC:
IMG_1088.thumb.jpg.b95f5b296101bbebd93de4cdf214bbb9.jpgIMG_1097.thumb.jpg.08d8966c9260dc323e16abac1cbe98b5.jpg
upper side just for reference (says V 1.0)
Thanks!
Interesting...my Plus2 H5 boards all use Samsung KLM8G1WEPD-B031 parts (eMMC 5.0); @rmoriz's board uses a KLM8G1GETF-B041 (eMMC 5.1).  I wonder if there might be an issue with eMMC 5.1 compatibility perhaps?
2 hours ago, rmoriz said:
Thanks!
Right ! The eMMC is the one on the bottom side ...
Yours is KLM8G1GETF, mine is KLM8G1WEPD .
Can any other OPiZeroPlus2-H5 can tell what are their eMMC chip number ?
I've also a OPiZeroPlus2-H3, and it has also WEPD version ...
That must be the culprit ...
EDIT : @Igor , if you get in touch with Steven from Xunlong in a near future, can you confirm with him about chip change ?
Still, I don't know what need to be tweak in u-boot ... I will try to compare between u-boot and kernel drivers ...
EDIT2 : @Igor , can you ask Steven to send me new OPiZeroPlus2-H5 so I can debug this issue ?
2 minutes ago, martinayotte said:
Right ! The eMMC is the one on the bootom side ...
Yes, mine use WEPD, and my NEO Core2 boards all have WEPD.  However, I have an new/not-yet-used NEO Plus2 that has a GETF part (same as @rmoriz).  I'll try flashing it and see how it goes.
 @rmoriz are you willing to do another build ? it seems that there are few commit in u-boot mainline since v2018.11 ...
In your Armbian build scripts, edit this line https://github.com/armbian/build/blob/master/config/sources/sunxi64_common.inc#L7 and change u-boot tag to v2019.01, it is almost hot from the oven ... :P
Hoping this will fix the issue, but no warranty ...
@martinayotte, for what it's worth, my NEO Plus2 running from the eMMC flash part KLM8G1GETF-B041 works great...:
U-Boot SPL 2018.11-armbian (Jan 28 2019 - 12:38:34 +0100)
DRAM: 1024 MiB
NOTICE:  BL31: v2.0(debug):bc15388
NOTICE:  BL31: Built : 12:32:31, Jan 28 2019
NOTICE:  BL31: Detected Allwinner H5 SoC (1718)
NOTICE:  BL31: Found U-Boot DTB at 0x40843b8, model: FriendlyARM NanoPi NEO Plus 2
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
NOTICE:  BL31: PMIC: Defaulting to PortL GPIO according to H5 reference design.
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2018.11-armbian (Jan 28 2019 - 12:38:34 +0100) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi NEO Plus 2
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Loading Environment from EXT4... MMC: no card present
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3042 bytes read in 5 ms (593.8 KiB/s)
## Executing script at 4fc00000
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
194 bytes read in 2 ms (94.7 KiB/s)
28823 bytes read in 13 ms (2.1 MiB/s)
504 bytes read in 15 ms (32.2 KiB/s)
Applying kernel provided DT overlay sun50i-h5-usbhost1.dtbo
Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo
4155 bytes read in 12 ms (337.9 KiB/s)
Applying kernel provided DT fixup script (sun50i-h5-fixup.scr)
## Executing script at 44000000
5329311 bytes read in 262 ms (19.4 MiB/s)
14245896 bytes read in 697 ms (19.5 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    5329247 Bytes = 5.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
EHCI failed to shut down host controller.
   Loading Ramdisk to 49aea000, end 49fff15f ... OK
   reserving fdt memory region: addr=4fa00000 size=6d000
   Loading Device Tree to 0000000049a7a000, end 0000000049ae9fff ... OK
Starting kernel ...
Loading, please wait...
starting version 232
done.
Begin: Will now check root file system ... fsck from util-linux 2.29.2
[/sbin/fsck.ext4 (1) -- /dev/mmcblk2p1] fsck.ext4 -a -C0 /dev/mmcblk2p1
/dev/mmcblk2p1: clean, 37821/472352 files, 359379/1888624 blocks
done.
done.
Welcome to Debian GNU/Linux 9 (stretch)!
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on Journal Socket.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Swap.
[  OK  ] Created slice System Slice.
         Starting Remount Root and Kernel File Systems...
[  OK  ] Listening on udev Control Socket.
         Mounting Debug File System...
[  OK  ] Reached target Network is Online.
         Starting LSB: Start NTP daemon...
         Starting /etc/rc.local Compatibility...
         Starting LSB: Advanced IEEE 802.11 management daemon...
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Getty on tty1.
[  OK  ] Started LSB: Start NTP daemon.
Debian GNU/Linux 9 nanopineoplus2 ttyS0
nanopineoplus2 login: root
Password:
Last login: Wed Jan 30 01:59:48 UTC 2019 on ttyS0
 _   _ ____  _   _   _              ____  _             ____
| \ | |  _ \(_) | \ | | ___  ___   |  _ \| |_   _ ___  |___ \
|  \| | |_) | | |  \| |/ _ \/ _ \  | |_) | | | | / __|   __) |
| |\  |  __/| | | |\  |  __/ (_) | |  __/| | |_| \__ \  / __/
|_| \_|_|   |_| |_| \_|\___|\___/  |_|   |_|\__,_|___/ |_____|
Welcome to ARMBIAN 5.73 stable Debian GNU/Linux 9 (stretch) 4.19.17-sunxi64
System load:   0.48 0.13 0.04   Up time:       0 min
Memory usage:  7 % of 993MB     IP:            192.168.1.191
CPU temp:      51�‹C
Usage of /:    18% of 7.1G
root@nanopineoplus2:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            430M     0  430M   0% /dev
tmpfs           100M  3.0M   97M   3% /run
/dev/mmcblk2p1  7.1G  1.2G  5.5G  18% /
tmpfs           497M     0  497M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           497M     0  497M   0% /sys/fs/cgroup
tmpfs           497M  4.0K  497M   1% /tmp
/dev/zram0       49M  1.4M   44M   3% /var/log
tmpfs           100M     0  100M   0% /run/user/0
root@nanopineoplus2:~# hdparm -tT /dev/mmcblk2
/dev/mmcblk2:
 Timing cached reads:   1004 MB in  2.00 seconds = 501.26 MB/sec
 Timing buffered disk reads: 132 MB in  3.01 seconds =  43.85 MB/sec
root@nanopineoplus2:~# apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stretch InRelease
Hit:4 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
Hit:5 http://cdn-fastly.deb.debian.org/debian stretch-backports InRelease
Hit:6 http://cdn-fastly.deb.debian.org/debian stretch Release
Hit:3 https://apt.armbian.com stretch InRelease
Reading package lists... Done
root@nanopineoplus2:~# apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Given this, I don't think it's an issue with the flash part version/type...  Maybe there a different/subtle H/W change in the new Orange Pi Zero Plus2 H5?
I talked with Xunlong about this - they are saying to contact them and provide order records. Keep reference on this topics.
Confirmed. "we have changed the EMMC about one year ago" "KLM8G1WEPD-B031 part: this module is out of the market" "We sell products with KLM8G1GETF-B041 (eMMC 5.1) for almost one year."
It's possible, yes. Shell I told him?
Wow - and now we got the "first" Plus2 (H5) which has problems installing to a v5.1 eMMc?
It seems that there are many v5.0 eMMC boards around...
@martinayotte custom built Armbian_5.74_Orangepizeroplus2-h5_Ubuntu_bionic_next_4.19.17.img with U-Boot 2019.01 sadly hangs at the same point as the 2018.11 release:
U-Boot SPL 2019.01-armbian (Jan 30 2019 - 13:08:51 +0000)
DRAM: 512 MiB
@Igor I've contacted "zhao_steven" via mail today at 13:05 UTC providing a screenshot of my AliExpress order and a summary of the thread including a link.
It's definitely odd...I'm wondering if the eMMC part version is a red herring, unless there is a subtle configuration difference between the bootloaders for these boards?  This would be worth checking.  Both of my NEO Plus2s use the newer v5.1 GETF eMMC part and they work fine.  Granted it's a completely different board than the OPi, but the major H/W parts are the same.  It'll be interesting to try another OPi Plus2 with this part to see if the problem is reproducible.
16 minutes ago, martinayotte said:
Yes ! This will help to figured out the issue ...
OK. There is only one problem left. Chinese holidays starts tomorrow. I sent request, but it might took +two weeks to get there.
