Banana Pi M1 nand sata install not working armbian 5.75 ubuntu bionic and debian with kernel 4.20
alien
U-Boot SPL 2018.11-armbian (Feb 08 2019 - 08:51:22 +0100)
DRAM: 1024 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
Trying to boot from MMC1
U-Boot 2018.11-armbian (Feb 08 2019 - 08:51:22 +0100) Allwinner Technology
CPU:   Allwinner A20 (SUN7I)
Model: LeMaker Banana Pi
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Setting up a 720x576i composite-pal console (overscan 32x20)
In:    serial
Out:   vga
Err:   vga
SCSI:  SATA link 0 timeout.
AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net:   eth0: ethernet@1c50000
230454 bytes read in 22 ms (10 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 13 ms (285.2 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
202 bytes read in 10 ms (19.5 KiB/s)
8129025 bytes read in 467 ms (16.6 MiB/s)
7323200 bytes read in 424 ms (16.5 MiB/s)
40331 bytes read in 70 ms (562.5 KiB/s)
5845 bytes read in 102 ms (55.7 KiB/s)
Applying kernel provided DT fixup script (sun7i-a20-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    8128961 Bytes = 7.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 4983f000, end 49fff9c1 ... OK
   reserving fdt memory region: addr=43000000 size=70000
   Loading Device Tree to 497cc000, end 4983efff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[   47.579146] reboot: Restarting system
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
In:    serial
Out:   vga
Err:   vga
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
Scanning mmc 0:1...
40331 bytes read in 69 ms (570.3 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
Banana Pi M1 nand sata install not working armbian 5.75 ubuntu bionic and debian with kernel 4.20. Install . I'm installing on a pendrive. It is constantly restarting.
Armbian Xenial desktop legacy kernel 3.4.y nand sata install working properly.
Link to post
Share on other sites
Donate and support the project!
Make sure you have "console=serial" in /boot/armbianEnv.txt, then watch the boot log with USB-TTL Serial dongle which will be more verbose.
You will probably see that it try to mount the rootfs from the wrong partition, if so, adjust /etc/fstab accordingly to what pendrive is reported in "blkid".
Link to post
fstab in sdcard:
UUID=52362a95-0375-421e-aa81-047eacb65728 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
fstab in pendrive:
tmpfs						/tmp		tmpfs	defaults,nosuid							0	0
UUID=52362a95-0375-421e-aa81-047eacb65728	/media/mmcboot	ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
/media/mmcboot/boot  				/boot		none	bind								0       0
UUID=6bfb12b9-ccbf-44b4-bd02-fb9b1a845835	/		ext4	defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
Change serial=both to serial=console
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
In:    serial
Out:   vga
Err:   vga
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
Scanning mmc 0:1...
204 bytes read in 10 ms (19.5 KiB/s)
8129025 bytes read in 468 ms (16.6 MiB/s)
40331 bytes read in 61 ms (645.5 KiB/s)
5845 bytes read in 89 ms (63.5 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
Loading, please wait...
starting version 237
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  UUID=6bfb12b9-ccbf-44b4-bd02-fb9b1a845835 does not exist.  Dropping to a shell!
Rebooting automatically due to panic= boot argument
Link to post
What "blkid" is reporting if you boot a normal image ...
Another workaround is to have direct device naming in /etc/fstab such as (assuming that pendrive is /dev/sda1) :
/dev/sda1	/		ext4	defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
Link to post
/dev/mmcblk0p1: UUID="52362a95-0375-421e-aa81-047eacb65728" TYPE="ext4" PARTUUID="bc752536-01"
/dev/zram0: LABEL="log2ram" UUID="4a3f553f-bbf8-4b67-a9a5-422883bbac80" TYPE="ext4"
/dev/mmcblk0: PTUUID="bc752536" PTTYPE="dos"
/dev/zram1: UUID="496dd411-8421-47bb-b94c-0d9b07e110df" TYPE="swap"
/dev/zram2: UUID="a9f85b29-2bc2-44d8-bccc-2bffa73b0660" TYPE="swap"
/dev/sda1: UUID="6bfb12b9-ccbf-44b4-bd02-fb9b1a845835" TYPE="ext4" PARTUUID="5bffa961-01"
blkid normal image in sdcard
I will check the other one in a moment.
If change to /dev/sda1 error still exist.
Link to post
I was having this issue too, upgrading orangepimini. (A20 board)
Go back and freeze linux-dtb-next-sunxi and linux-image-next-sunxi at 5.67 version.
My system is installed on USB disk. I boot from a SD card and system loads from usb disk, seems that kernel at first stages does not recognise usb devices.
Link to post
So we could face some corruption/troubles with initrd? And so only A20 is affected by this issue.
Link to post
Without the full log, it difficult to see what is happening between these two lines ...
Change /boot/armbianEnv.txt to have "verbosity=7" and "console=serial" and grab the log from a USB-TTL Serial dongle.
Link to post
My log nand sata install on pendrive:
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
Error: no valid bmp image at 66000000
In:    serial
Out:   vga
Err:   vga
230454 bytes read in 21 ms (10.5 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
Scanning mmc 0:1...
204 bytes read in 11 ms (17.6 KiB/s)
7994540 bytes read in 460 ms (16.6 MiB/s)
7323200 bytes read in 423 ms (16.5 MiB/s)
40331 bytes read in 63 ms (625 KiB/s)
5845 bytes read in 90 ms (62.5 KiB/s)
   Image Name:   uInitrd
   Data Size:    7994476 Bytes = 7.6 MiB
   Loading Ramdisk to 49860000, end 49fffc6c ... OK
   Loading Device Tree to 497ed000, end 4985ffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.20-sunxi (root@armbian.com) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5.75 SMP Sat Feb 9 19:02:47 CET 2019
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: LeMaker Banana Pi
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 128 MiB at 0x77c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] random: get_random_bytes called from start_kernel+0x8d/0x3be with crng_init=0
[    0.000000] percpu: Embedded 18 pages/cpu @(ptrval) s41484 r8192 d24052 u73728
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260010
[    0.000000] Kernel command line: root=UUID=515f12b4-4fc8-4bf2-a9b0-5d6d3df82081 rootwait rootfstype=ext4 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=7 ubootpart=bc752536-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 1051048 bytes of page_ext
[    0.000000] Memory: 882688K/1046952K available (8192K kernel code, 984K rwdata, 2516K rodata, 1024K init, 317K bss, 33192K reserved, 131072K cma-reserved, 129448K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 985 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 318 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] ftrace: allocating 38664 entries in 76 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000019] Switching to timer-based delay loop, resolution 41ns
[    0.000371] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000617] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
[    0.000891] Console: colour dummy device 80x30
[    0.000960] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000976] pid_max: default: 32768 minimum: 301
[    0.001273] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001289] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002271] CPU: Testing write buffer coherency: ok
[    0.002723] /cpus/cpu@0 missing clock-frequency property
[    0.002743] /cpus/cpu@1 missing clock-frequency property
[    0.002756] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003391] Setting up static identity map for 0x40100000 - 0x40100054
[    0.003573] rcu: Hierarchical SRCU implementation.
[    0.004647] smp: Bringing up secondary CPUs ...
[    0.015493] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.015649] smp: Brought up 1 node, 2 CPUs
[    0.015667] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.015675] CPU: All CPU(s) started in HYP mode.
[    0.015680] CPU: Virtualization extensions available.
[    0.016978] devtmpfs: initialized
[    0.026007] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.026303] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.026328] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.031540] xor: measuring software checksum speed
[    0.071472]    arm4regs  :  1137.000 MB/sec
[    0.111535]    8regs     :   677.000 MB/sec
[    0.151597]    32regs    :   693.000 MB/sec
[    0.191659]    neon      :  1151.000 MB/sec
[    0.191666] xor: using function: neon (1151.000 MB/sec)
[    0.191757] pinctrl core: initialized pinctrl subsystem
[    0.192979] NET: Registered protocol family 16
[    0.195886] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.196464] audit: initializing netlink subsys (disabled)
[    0.196751] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.197405] cpuidle: using governor ladder
[    0.197455] cpuidle: using governor menu
[    0.198013] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.198024] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.284329] raid6: int32x1  gen()   170 MB/s
[    0.352282] raid6: int32x1  xor()   145 MB/s
[    0.420276] raid6: int32x2  gen()   231 MB/s
[    0.488434] raid6: int32x2  xor()   179 MB/s
[    0.556646] raid6: int32x4  gen()   234 MB/s
[    0.624630] raid6: int32x4  xor()   174 MB/s
[    0.692755] raid6: int32x8  gen()   223 MB/s
[    0.760866] raid6: int32x8  xor()   155 MB/s
[    0.828926] raid6: neonx1   gen()   447 MB/s
[    0.897027] raid6: neonx1   xor()   416 MB/s
[    0.965207] raid6: neonx2   gen()   600 MB/s
[    1.033270] raid6: neonx2   xor()   537 MB/s
[    1.101396] raid6: neonx4   gen()   721 MB/s
[    1.169502] raid6: neonx4   xor()   606 MB/s
[    1.237633] raid6: neonx8   gen()   649 MB/s
[    1.305716] raid6: neonx8   xor()   548 MB/s
[    1.305725] raid6: using algorithm neonx4 gen() 721 MB/s
[    1.305732] raid6: .... xor() 606 MB/s, rmw enabled
[    1.305739] raid6: using neon recovery algorithm
[    1.307648] SCSI subsystem initialized
[    1.308213] usbcore: registered new interface driver usbfs
[    1.308265] usbcore: registered new interface driver hub
[    1.308357] usbcore: registered new device driver usb
[    1.308598] media: Linux media interface: v0.10
[    1.308638] videodev: Linux video capture interface: v2.00
[    1.308776] pps_core: LinuxPPS API ver. 1 registered
[    1.308784] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.308805] PTP clock support registered
[    1.310660] clocksource: Switched to clocksource arch_sys_counter
[    1.426312] VFS: Disk quotas dquot_6.6.0
[    1.426403] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.427211] simple-framebuffer 7fe79000.framebuffer: framebuffer at 0x7fe79000, 0x178e00 bytes, mapped to 0x(ptrval)
[    1.427229] simple-framebuffer 7fe79000.framebuffer: format=x8r8g8b8, mode=656x536x32, linelength=2880
[    1.434854] fbcon_init: disable boot-logo (boot-logo bigger than screen).
[    1.434867] Console: switching to colour frame buffer device 82x33
[    1.441846] simple-framebuffer 7fe79000.framebuffer: fb0: simplefb registered!
[    1.450188] NET: Registered protocol family 2
[    1.451183] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    1.451220] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.451324] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.451450] TCP: Hash tables configured (established 8192 bind 8192)
[    1.451588] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.451656] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.451907] NET: Registered protocol family 1
[    1.452621] RPC: Registered named UNIX socket transport module.
[    1.452634] RPC: Registered udp transport module.
[    1.452641] RPC: Registered tcp transport module.
[    1.452647] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.452921] Trying to unpack rootfs image as initramfs...
[    1.984689] Freeing initrd memory: 7808K
[    1.985422] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.985742] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.987456] Initialise system trusted keyrings
[    1.987738] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.994070] zbud: loaded
[    1.996779] NFS: Registering the id_resolver key type
[    1.996821] Key type id_resolver registered
[    1.996830] Key type id_legacy registered
[    1.996847] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.996856] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.998244] JFS: nTxBlock = 7981, nTxLock = 63848
[    2.009526] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    2.019407] Key type asymmetric registered
[    2.019431] Asymmetric key parser 'x509' registered
[    2.019505] bounce: pool size: 64 pages
[    2.019611] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.019842] io scheduler noop registered
[    2.019852] io scheduler deadline registered
[    2.020101] io scheduler cfq registered (default)
[    2.020113] io scheduler mq-deadline registered
[    2.020121] io scheduler kyber registered
[    2.020275] io scheduler bfq registered
[    2.025083] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    2.086011] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.088817] console [ttyS0] disabled
[    2.108998] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 48, base_baud = 1500000) is a U6_16550A
[    3.020675] console [ttyS0] enabled
[    3.047437] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 49, base_baud = 1500000) is a U6_16550A
[    3.079537] 1c29c00.serial: ttyS2 at MMIO 0x1c29c00 (irq = 50, base_baud = 1500000) is a U6_16550A
[    3.093034] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[    3.103436] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0981614)
[    3.111222] sun4i-backend 1e40000.display-backend: Couldn't find matching frontend, frontend features disabled
[    3.121502] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0981614)
[    3.129686] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    3.137551] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0980594)
[    3.145555] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    3.153413] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0980594)
[    3.161962] sun4i-drm display-engine: bound 1c16000.hdmi (ops 0xc0982020)
[    3.168810] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.175438] [drm] No driver support for vblank timestamp query.
[    3.181375] fb: switching to sun4i-drm-fb from simple
[    3.186545] Console: switching to colour dummy device 80x30
[    3.692511] [drm] Cannot find any crtc or sizes
[    3.697673] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    3.709489] brd: module loaded
[    3.719849] loop: module loaded
[    3.778698] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    3.786246] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
[    3.793419] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    3.802389] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
[    3.812428] scsi host0: ahci-sunxi
[    3.816280] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 36
[    3.827457] libphy: Fixed MDIO Bus: probed
[    3.832265] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    3.838065] sun7i-dwmac 1c50000.ethernet: no reset control found
[    3.845340] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.851903] ehci-platform: EHCI generic platform driver
[    3.857543] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.863784] ohci-platform: OHCI generic platform driver
[    3.869783] usbcore: registered new interface driver usb-storage
[    3.876921] sunxi-rtc 1c20d00.rtc: registered as rtc0
[    3.882025] sunxi-rtc 1c20d00.rtc: RTC enabled
[    3.886673] i2c /dev entries driver
[    3.891269] axp20x-i2c 1-0034: AXP20x variant AXP209 found
[    3.911391] input: axp20x-pek as /devices/platform/soc@1c00000/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0
[    3.922222] ldo1: supplied by regulator-dummy
[    3.926926] ldo2: supplied by regulator-dummy
[    3.932415] ldo3: supplied by regulator-dummy
[    3.937447] ldo4: supplied by regulator-dummy
[    3.942056] ldo5: supplied by regulator-dummy
[    3.947487] dcdc2: supplied by regulator-dummy
[    3.952618] dcdc3: supplied by regulator-dummy
[    3.961436] axp20x-i2c 1-0034: Backup (RTC) battery charging is disabled
[    3.968297] axp20x-i2c 1-0034: AXP20X driver loaded
[    3.975866] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    3.985021] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[    3.991980] ledtrig-cpu: registered to indicate activity on CPUs
[    3.992285] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    3.998157] hidraw: raw HID events driver (C) Jiri Kosina
[    4.008041] usbcore: registered new interface driver usbhid
[    4.013641] usbhid: USB HID core driver
[    4.018740] Initializing XFRM netlink socket
[    4.023785] NET: Registered protocol family 10
[    4.028153] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    4.042967] random: fast init done
[    4.063422] Segment Routing with IPv6
[    4.067263] NET: Registered protocol family 17
[    4.071783] NET: Registered protocol family 15
[    4.076308] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.087330] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.089313] 8021q: 802.1Q VLAN Support v1.8
[    4.100926] mmc0: new high speed SDHC card at address aaaa
[    4.101498] Key type dns_resolver registered
[    4.108295] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    4.111695] Registering SWP/SWPB emulation handler
[    4.117872]  mmcblk0: p1
[    4.121270] registered taskstats version 1
[    4.127277] Loading compiled-in X.509 certificates
[    4.132201] zswap: loaded using pool lzo/zbud
[    4.138584] ata1: SATA link down (SStatus 0 SControl 300)
[    4.139035] Btrfs loaded, crc32c=crc32c-generic
[    4.159460] Key type encrypted registered
[    4.177362] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    4.183195] sun7i-dwmac 1c50000.ethernet: no reset control found
[    4.189322] sun7i-dwmac 1c50000.ethernet: Linked as a consumer to regulator.14
[    4.302970] sun7i-dwmac 1c50000.ethernet: Version ID not available
[    4.309198] sun7i-dwmac 1c50000.ethernet: 	DWMAC1000
[    4.314179] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
[    4.321410] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[    4.327077] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[    4.352872] libphy: stmmac: probed
[    4.356349] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    4.368872] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    4.388459] of_cfs_init
[    4.391130] of_cfs_init: OK
[    4.394158] vcc3v0: disabling
[    4.397171] vcc5v0: disabling
[    4.400169] usb0-vbus: disabling
[    4.403410] usb1-vbus: disabling
[    4.406651] usb2-vbus: disabling
[    4.415213] Freeing unused kernel memory: 1024K
[    4.426864] Run /init as init process
[    5.696926] axp20x-gpio axp20x-gpio: DMA mask not set
[    5.710895] [drm] Cannot find any crtc or sizes
[    5.718145] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
done.
done.
ALERT!  UUID=515f12b4-4fc8-4bf2-a9b0-5d6d3df82081 does not exist.  Dropping to a shell!
[   48.300933] reboot: Restarting system
Link to post
That is the reason for the boot loop !
Boot from SDCard, check the eMMC UUID with "blkid", mount the eMMC to /mnt, edit /mnt/boot/armbianEnv.txt and make sure the line with "rootdev=UUID=" has the good UUID, then check /mnt/etc/fstab to be sure the same good UUID is also there. Then, "umount /mnt", and do halt. Eject the SDCard and recycle the power ...
Link to post
UUID is ok
armbianEnv.txt
verbosity=7
logo=disabled
console=serial
disp_mode=1920x1080p60
overlay_prefix=sun7i-a20
rootdev=UUID=515f12b4-4fc8-4bf2-a9b0-5d6d3df82081
rootfstype=ext4
fstab in pendrive
# <file system>					<mount point>	<type>	<options>							<dump>	<pass>
UUID=515f12b4-4fc8-4bf2-a9b0-5d6d3df82081	/		ext4	defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
Still not working.
Link to post
root@bananapi:~# blkid
/dev/zram0: LABEL="log2ram" UUID="8e9cf7de-199a-4e94-a813-1e62c1eeb35a" TYPE="ext4"
/dev/zram1: UUID="af9b8056-b80f-4704-8dba-d503d4bc33a3" TYPE="swap"
/dev/zram2: UUID="66f3115c-28fc-4227-8352-d62654249790" TYPE="swap"
/dev/sda1: UUID="515f12b4-4fc8-4bf2-a9b0-5d6d3df82081" TYPE="ext4" PARTUUID="971424eb-01"
System installed on sd. Pendrive plugged.
Link to post
How do you know U-boot detects pendrive?
from your log:
Can you get a (verbose) log from successive boot (I would prefer from "Armbian_5.65_Bananapi_Ubuntu_bionic_next_4.14.78.7z - Working")?
I suppose there should be some report in the kernel log about partitions found, similar to mmc:
Link to post
Armbian 5.65 sdcard:
U-Boot SPL 2018.05-armbian (Oct 26 2018 - 12:03:14 +0200)
DRAM: 1024 MiB
U-Boot 2018.05-armbian (Oct 26 2018 - 12:03:14 +0200) Allwinner Technology
I2C:   ready
DRAM:  1 GiB
Failed (-5)
In:    serial
Out:   vga
Err:   vga
Net:   eth0: ethernet@01c50000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
Scanning mmc 0:1...
3708 bytes read in 13 ms (278.3 KiB/s)
8305258 bytes read in 478 ms (16.6 MiB/s)
6984272 bytes read in 405 ms (16.4 MiB/s)
47627 bytes read in 93 ms (500 KiB/s)
5925 bytes read in 32 ms (180.7 KiB/s)
   Image Name:   uInitrd
   Data Size:    8305194 Bytes = 7.9 MiB
   Loading Ramdisk to 49814000, end 49fffa2a ... OK
   reserving fdt memory region: addr=43000000 size=71000
   Loading Device Tree to 497a0000, end 49813fff ... OK
Starting kernel ...
[    0.000000] Linux version 4.14.78-sunxi (root@nightly) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #412 SMP Fri Oct 26 11:37:04 CEST 2018
[    0.000000] random: get_random_bytes called from start_kernel+0x8d/0x36a with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu @ef6b8000 s39884 r8192 d21556 u69632
[    0.000000] Kernel command line: root=UUID=10c0b00f-4815-40fc-8cfd-c0395fd9982c rootwait rootfstype=ext4  console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=7 ubootpart=8bf1b35c-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 882328K/1046952K available (8192K kernel code, 946K rwdata, 2352K rodata, 1024K init, 330K bss, 33552K reserved, 131072K cma-reserved, 129448K highmem)
[    0.000000]       .text : 0xc0008000 - 0xc0900000   (9184 kB)
[    0.000000]       .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
[    0.000000]       .data : 0xc0d00000 - 0xc0dec9cc   ( 947 kB)
[    0.000000]        .bss : 0xc0df5da0 - 0xc0e48840   ( 331 kB)
[    0.000000] ftrace: allocating 37066 entries in 73 pages
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000544] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000789] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns
[    0.001014] Console: colour dummy device 80x30
[    0.001058] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001073] pid_max: default: 32768 minimum: 301
[    0.001285] Security Framework initialized
[    0.001301] AppArmor: AppArmor disabled by boot time parameter
[    0.001373] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001386] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002251] CPU: Testing write buffer coherency: ok
[    0.002691] /cpus/cpu@0 missing clock-frequency property
[    0.002712] /cpus/cpu@1 missing clock-frequency property
[    0.002724] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003191] Setting up static identity map for 0x40100000 - 0x40100054
[    0.003345] Hierarchical SRCU implementation.
[    0.004281] smp: Bringing up secondary CPUs ...
[    0.015098] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.015243] smp: Brought up 1 node, 2 CPUs
[    0.015258] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.015266] CPU: All CPU(s) started in HYP mode.
[    0.015272] CPU: Virtualization extensions available.
[    0.016512] devtmpfs: initialized
[    0.026904] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.027166] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027190] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.032293] xor: measuring software checksum speed
[    0.125041]    arm4regs  :  1135.600 MB/sec
[    0.225098]    8regs     :   676.400 MB/sec
[    0.325162]    32regs    :   692.800 MB/sec
[    0.425218]    neon      :  1150.400 MB/sec
[    0.425226] xor: using function: neon (1150.400 MB/sec)
[    0.425363] pinctrl core: initialized pinctrl subsystem
[    0.426409] NET: Registered protocol family 16
[    0.429548] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.430681] cpuidle: using governor ladder
[    0.430728] cpuidle: using governor menu
[    0.431944] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.431956] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.615891] raid6: int32x1  gen()   171 MB/s
[    0.785886] raid6: int32x1  xor()   145 MB/s
[    0.956070] raid6: int32x2  gen()   231 MB/s
[    1.126032] raid6: int32x2  xor()   178 MB/s
[    1.296222] raid6: int32x4  gen()   233 MB/s
[    1.466279] raid6: int32x4  xor()   174 MB/s
[    1.636623] raid6: int32x8  gen()   223 MB/s
[    1.806588] raid6: int32x8  xor()   155 MB/s
[    1.976661] raid6: neonx1   gen()   447 MB/s
[    2.146841] raid6: neonx1   xor()   417 MB/s
[    2.317003] raid6: neonx2   gen()   600 MB/s
[    2.487110] raid6: neonx2   xor()   537 MB/s
[    2.657226] raid6: neonx4   gen()   721 MB/s
[    2.827356] raid6: neonx4   xor()   606 MB/s
[    2.997539] raid6: neonx8   gen()   649 MB/s
[    3.167646] raid6: neonx8   xor()   548 MB/s
[    3.167653] raid6: using algorithm neonx4 gen() 721 MB/s
[    3.167660] raid6: .... xor() 606 MB/s, rmw enabled
[    3.167667] raid6: using neon recovery algorithm
[    3.168995] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/gmac_power_pin@0, deferring probe
[    3.169491] SCSI subsystem initialized
[    3.170066] usbcore: registered new interface driver usbfs
[    3.170113] usbcore: registered new interface driver hub
[    3.170181] usbcore: registered new device driver usb
[    3.170415] media: Linux media interface: v0.10
[    3.170449] Linux video capture interface: v2.00
[    3.170527] pps_core: LinuxPPS API ver. 1 registered
[    3.170535] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.170555] PTP clock support registered
[    3.172203] clocksource: Switched to clocksource arch_sys_counter
[    3.275120] VFS: Disk quotas dquot_6.6.0
[    3.275222] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    3.276105] simple-framebuffer 7fe79000.framebuffer: framebuffer at 0x7fe79000, 0x178e00 bytes, mapped to 0xf0b00000
[    3.276125] simple-framebuffer 7fe79000.framebuffer: format=x8r8g8b8, mode=656x536x32, linelength=2880
[    3.283815] fbcon_init: disable boot-logo (boot-logo bigger than screen).
[    3.283826] Console: switching to colour frame buffer device 82x33
[    3.290756] simple-framebuffer 7fe79000.framebuffer: fb0: simplefb registered!
[    3.298650] NET: Registered protocol family 2
[    3.299369] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.299469] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.299597] TCP: Hash tables configured (established 8192 bind 8192)
[    3.299722] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.299787] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.300054] NET: Registered protocol family 1
[    3.300663] RPC: Registered named UNIX socket transport module.
[    3.300678] RPC: Registered udp transport module.
[    3.300685] RPC: Registered tcp transport module.
[    3.300691] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.300984] Trying to unpack rootfs image as initramfs...
[    3.845237] Freeing initrd memory: 8112K
[    3.846007] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    3.846347] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    3.847407] audit: initializing netlink subsys (disabled)
[    3.847724] audit: type=2000 audit(3.830:1): state=initialized audit_enabled=0 res=1
[    3.848096] Initialise system trusted keyrings
[    3.848310] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    3.853676] zbud: loaded
[    3.856330] NFS: Registering the id_resolver key type
[    3.856370] Key type id_resolver registered
[    3.856378] Key type id_legacy registered
[    3.856393] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.856402] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.857515] JFS: nTxBlock = 7980, nTxLock = 63844
[    3.868473] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    3.877154] Key type asymmetric registered
[    3.877243] bounce: pool size: 64 pages
[    3.877350] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    3.877554] io scheduler noop registered
[    3.877564] io scheduler deadline registered
[    3.877787] io scheduler cfq registered (default)
[    3.877797] io scheduler mq-deadline registered
[    3.877804] io scheduler kyber registered
[    3.877943] io scheduler bfq registered
[    3.878938] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
[    3.882517] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.938376] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.941833] console [ttyS0] disabled
[    3.962036] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 45, base_baud = 1500000) is a U6_16550A
[    4.899104] console [ttyS0] enabled
[    4.926387] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 46, base_baud = 1500000) is a U6_16550A
[    4.958969] 1c29c00.serial: ttyS2 at MMIO 0x1c29c00 (irq = 47, base_baud = 1500000) is a U6_16550A
[    4.972117] brd: module loaded
[    4.981694] loop: module loaded
[    5.082289] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    5.089808] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
[    5.096990] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    5.105958] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
[    5.115896] scsi host0: ahci-sunxi
[    5.119562] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 33
[    5.129859] libphy: Fixed MDIO Bus: probed
[    5.134701] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    5.140451] sun7i-dwmac 1c50000.ethernet: no reset control found
[    5.147156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.153734] ehci-platform: EHCI generic platform driver
[    5.159310] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.165543] ohci-platform: OHCI generic platform driver
[    5.171176] usbcore: registered new interface driver usb-storage
[    5.177992] mousedev: PS/2 mouse device common for all mice
[    5.184422] sunxi-rtc 1c20d00.rtc: rtc core: registered rtc-sunxi as rtc0
[    5.191207] sunxi-rtc 1c20d00.rtc: RTC enabled
[    5.195808] i2c /dev entries driver
[    5.200278] axp20x-i2c 0-0034: AXP20x variant AXP209 found
[    5.213252] axp20x-gpio axp20x-gpio: AXP209 GPIO driver loaded
[    5.227393] input: axp20x-pek as /devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
[    5.238293] ldo1: supplied by regulator-dummy
[    5.242954] ldo2: supplied by regulator-dummy
[    5.248360] ldo3: supplied by regulator-dummy
[    5.253400] ldo4: supplied by regulator-dummy
[    5.257952] ldo5: supplied by regulator-dummy
[    5.262960] dcdc2: supplied by regulator-dummy
[    5.268038] dcdc3: supplied by regulator-dummy
[    5.275954] random: fast init done
[    5.279781] axp20x-i2c 0-0034: Backup (RTC) battery charging is disabled
[    5.286670] axp20x-i2c 0-0034: AXP20X driver loaded
[    5.295260] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    5.312668] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    5.372821] sunxi-mmc 1c0f000.mmc: base:0xf0ae7000 irq:28
[    5.381071] ledtrig-cpu: registered to indicate activity on CPUs
[    5.387494] hidraw: raw HID events driver (C) Jiri Kosina
[    5.393382] usbcore: registered new interface driver usbhid
[    5.398978] usbhid: USB HID core driver
[    5.405671] NET: Registered protocol family 10
[    5.437458] Segment Routing with IPv6
[    5.441262] NET: Registered protocol family 17
[    5.446011] Key type dns_resolver registered
[    5.450727] Registering SWP/SWPB emulation handler
[    5.456344] registered taskstats version 1
[    5.456385] ata1: SATA link down (SStatus 0 SControl 300)
[    5.465873] Loading compiled-in X.509 certificates
[    5.470787] zswap: loaded using pool lzo/zbud
[    5.477273] Btrfs loaded, crc32c=crc32c-generic
[    5.492534] Key type encrypted registered
[    5.503372] mmc0: host does not support reading read-only switch, assuming write-enable
[    5.514214] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    5.519973] sun7i-dwmac 1c50000.ethernet: no reset control found
[    5.526871] mmc0: new high speed SDHC card at address aaaa
[    5.533090] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    5.539159]  mmcblk0: p1
[    5.642381] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[    5.647982] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
[    5.655279] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[    5.690712] libphy: stmmac: probed
[    5.694155] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    5.706702] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.748460] ehci-platform 1c14000.usb: EHCI Host Controller
[    5.754145] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[    5.767928] ehci-platform 1c14000.usb: irq 30, io mem 0x01c14000
[    5.802221] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[    5.802513] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.802519] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.802525] usb usb1: Product: EHCI Host Controller
[    5.802530] usb usb1: Manufacturer: Linux 4.14.78-sunxi ehci_hcd
[    5.802535] usb usb1: SerialNumber: 1c14000.usb
[    5.808752] hub 1-0:1.0: USB hub found
[    5.808825] hub 1-0:1.0: 1 port detected
[    5.810126] ehci-platform 1c1c000.usb: EHCI Host Controller
[    5.810171] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[    5.810622] ehci-platform 1c1c000.usb: irq 34, io mem 0x01c1c000
[    5.832280] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    5.832729] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.832741] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.832751] usb usb2: Product: EHCI Host Controller
[    5.832760] usb usb2: Manufacturer: Linux 4.14.78-sunxi ehci_hcd
[    5.832769] usb usb2: SerialNumber: 1c1c000.usb
[    5.833728] hub 2-0:1.0: USB hub found
[    5.833810] hub 2-0:1.0: 1 port detected
[    5.835083] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[    5.835126] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[    5.835553] ohci-platform 1c14400.usb: irq 31, io mem 0x01c14400
[    5.906422] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    5.906430] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.906435] usb usb3: Product: Generic Platform OHCI controller
[    5.906440] usb usb3: Manufacturer: Linux 4.14.78-sunxi ohci_hcd
[    5.906445] usb usb3: SerialNumber: 1c14400.usb
[    5.907092] hub 3-0:1.0: USB hub found
[    5.907148] hub 3-0:1.0: 1 port detected
[    5.908060] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    5.908091] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[    5.908351] ohci-platform 1c1c400.usb: irq 35, io mem 0x01c1c400
[    5.976392] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    5.976400] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.976405] usb usb4: Product: Generic Platform OHCI controller
[    5.976410] usb usb4: Manufacturer: Linux 4.14.78-sunxi ohci_hcd
[    5.976415] usb usb4: SerialNumber: 1c1c400.usb
[    5.977043] hub 4-0:1.0: USB hub found
[    5.977089] hub 4-0:1.0: 1 port detected
[    5.977984] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    5.978467] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    5.978479] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    5.978763] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    5.978771] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.978776] usb usb5: Product: MUSB HDRC host driver
[    5.978782] usb usb5: Manufacturer: Linux 4.14.78-sunxi musb-hcd
[    5.978786] usb usb5: SerialNumber: musb-hdrc.1.auto
[    5.979386] hub 5-0:1.0: USB hub found
[    5.979433] hub 5-0:1.0: 1 port detected
[    5.980646] of_cfs_init
[    5.980756] of_cfs_init: OK
[    5.980944] vcc3v0: disabling
[    5.980951] vcc5v0: disabling
[    6.012788] usb0-vbus: disabling
[    6.104561] Freeing unused kernel memory: 1024K
[    6.172922] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    6.378346] usb 1-1: New USB device found, idVendor=090c, idProduct=1000
[    6.385208] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.392375] usb 1-1: Product: USB Flash Disk
[    6.396649] usb 1-1: Manufacturer: General
[    6.400772] usb 1-1: SerialNumber: 0342115060012022
[    6.449881] usb-storage 1-1:1.0: USB Mass Storage device detected
[    6.481450] scsi host1: usb-storage 1-1:1.0
[    6.561301] usbcore: registered new interface driver uas
[    7.840757] scsi 1:0:0:0: Direct-Access     General  USB Flash Disk   1100 PQ: 0 ANSI: 6
[    7.851255] sd 1:0:0:0: [sda] 31490048 512-byte logical blocks: (16.1 GB/15.0 GiB)
[    7.862794] sd 1:0:0:0: [sda] Write Protect is off
[    7.872638] sd 1:0:0:0: Attached scsi generic sg0 type 0
[    7.883052] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Begin: Loading essential drivers ... [    7.920288]  sda: sda1
done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top .[    7.932618] sd 1:0:0:0: [sda] Attached SCSI removable disk
.. done.
done.
Begin: Will now check root file system ... fsck from util-linux 2.31.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 35942/906240 files, 258028/3849616 blocks
done.
[    8.381741] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
done.
[    9.104021] systemd[1]: System time before build time, advancing clock.
[    9.139258] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.181290] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    9.203397] systemd[1]: Detected architecture arm.
Welcome to Ubuntu 18.04.1 LTS!
[    9.257379] systemd[1]: Set hostname to <bananapi>.
[    9.968921] random: systemd: uninitialized urandom read (16 bytes read)
[    9.975762] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[   10.013321] random: systemd: uninitialized urandom read (16 bytes read)
[   10.021825] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary Executab…rmats File System Automount Point.
[   10.072692] random: systemd: uninitialized urandom read (16 bytes read)
[   10.081112] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[   10.133964] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[   10.163158] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[   10.213864] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[   10.243130] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Started ntp-systemd-netif.path.
[  OK  ] Listening on Journal Socket.
         Starting Set the console keyboard layout...
         Starting Remount Root and Kernel File Systems...
         Mounting Kernel Debug File System...
         Starting Nameserver information manager...
[   10.728018] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
         Starting udev Coldplug all Devices...
         Starting Restore / save the current clock...
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Journal Service...
[  OK  ] Reached target Swap.
         Starting Load Kernel Modules...
         Mounting POSIX Message Queue File System...
         Starting Create list of required st…ce nodes for the current kernel...
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Journal Service.
[   11.175620] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Nameserver information manager.
[  OK  ] Reached target Network (Pre).
         Mounting Kernel Configuration File System...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
         Starting Load/Save Random Seed...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Load/Save Random Seed.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Mounted /tmp.
[  OK  ] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Armbian ZRAM config...
         Starting Raise network interfaces...
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting Network Time Synchronization...
         Starting Network Name Resolution...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started Armbian ZRAM config.
[  OK  ] Reached target Sound Card.
         Starting Armbian memory supported logging...
[  OK  ] Started Armbian memory supported logging.
[  OK  ] Reached target System Initialization.
[  OK  ] Started resolvconf-pull-resolved.path.
[  OK  ] Reached target Paths.
[  OK  ] Started Message of the Day.
         Starting Armbian hardware optimization...
         Starting Armbian hardware monitoring...
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Reached target Timers.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Started Armbian hardware optimization.
[  OK  ] Started Armbian hardware monitoring.
[  OK  ] Reached target Basic System.
         Starting Dispatcher daemon for systemd-networkd...
         Starting Login Service...
         Starting Save/Restore Sound Card State...
         Starting LSB: Load kernel modules needed to enable cpufreq scaling...
[  OK  ] Started Set the CPU Frequency Scaling governor.
         Starting resolvconf-pull-resolved.service...
         Starting System Logging Service...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Login Service.
         Starting Network Manager...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started ntp-systemd-netif.service.
         Starting Resets System Activity Data Collector...
         Starting WPA supplicant...
[  OK  ] Started System Logging Service.
[  OK  ] Started resolvconf-pull-resolved.service.
[  OK  ] Started Resets System Activity Data Collector.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started WPA supplicant.
[  OK  ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
         Starting LSB: set CPUFreq kernel parameters...
         Starting Hostname Service...
[  OK  ] Started LSB: set CPUFreq kernel parameters.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[  OK  ] Started Hostname Service.
[  OK  ] Started Network Manager.
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Reached target Network.
         Starting Permit User Sessions...
         Starting OpenBSD Secure Shell server...
[  OK  ] Started Unattended Upgrades Shutdown.
         Starting Network Manager Wait Online...
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Network Manager Script Dispatcher Service.
         Starting Set console scheme...
[  OK  ] Started Set console scheme.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started OpenBSD Secure Shell server.
         Starting Authorization Manager...
[  OK  ] Started Dispatcher daemon for systemd-networkd.
[  OK  ] Started Authorization Manager.
[  OK  ] Started Network Manager Wait Online.
[  OK  ] Reached target Network is Online.
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting /etc/rc.local Compatibility...
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
Ubuntu 18.04.1 LTS bananapi ttyS0
bananapi login:
Armbian 5.65 pendrive installed:
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
Failed (-5)
In:    serial
Out:   vga
Err:   vga
230454 bytes read in 23 ms (9.6 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
Scanning mmc 0:1...
3708 bytes read in 14 ms (257.8 KiB/s)
47627 bytes read in 92 ms (504.9 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
[    0.000000] Kernel command line: root=UUID=25d99046-09fb-42da-93db-340bc1a4632b rootwait rootfstype=ext4  console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=7 ubootpart=8bf1b35c-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    0.000020] Switching to timer-based delay loop, resolution 41ns
[    0.000559] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000805] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns
[    0.001034] Console: colour dummy device 80x30
[    0.001076] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001092] pid_max: default: 32768 minimum: 301
[    0.001304] Security Framework initialized
[    0.001320] AppArmor: AppArmor disabled by boot time parameter
[    0.001391] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001406] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002279] CPU: Testing write buffer coherency: ok
[    0.002714] /cpus/cpu@0 missing clock-frequency property
[    0.002732] /cpus/cpu@1 missing clock-frequency property
[    0.002744] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003205] Setting up static identity map for 0x40100000 - 0x40100054
[    0.003365] Hierarchical SRCU implementation.
[    0.004298] smp: Bringing up secondary CPUs ...
[    0.015109] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.015258] smp: Brought up 1 node, 2 CPUs
[    0.015273] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.015280] CPU: All CPU(s) started in HYP mode.
[    0.015286] CPU: Virtualization extensions available.
[    0.016522] devtmpfs: initialized
[    0.026932] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    0.027198] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027222] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.032341] xor: measuring software checksum speed
[    0.125049]    arm4regs  :  1135.600 MB/sec
[    0.225105]    8regs     :   676.400 MB/sec
[    0.325168]    32regs    :   692.800 MB/sec
[    0.425225]    neon      :  1150.800 MB/sec
[    0.425233] xor: using function: neon (1150.800 MB/sec)
[    0.425370] pinctrl core: initialized pinctrl subsystem
[    0.426415] NET: Registered protocol family 16
[    0.429121] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.430268] cpuidle: using governor ladder
[    0.430315] cpuidle: using governor menu
[    0.431532] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.431543] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.615563] raid6: int32x1  gen()   170 MB/s
[    0.785682] raid6: int32x1  xor()   145 MB/s
[    0.956058] raid6: int32x2  gen()   231 MB/s
[    1.126050] raid6: int32x2  xor()   178 MB/s
[    1.296232] raid6: int32x4  gen()   233 MB/s
[    1.466281] raid6: int32x4  xor()   174 MB/s
[    1.636624] raid6: int32x8  gen()   223 MB/s
[    1.806609] raid6: int32x8  xor()   155 MB/s
[    1.976648] raid6: neonx1   gen()   447 MB/s
[    2.146849] raid6: neonx1   xor()   417 MB/s
[    2.317017] raid6: neonx2   gen()   600 MB/s
[    2.487062] raid6: neonx2   xor()   537 MB/s
[    2.657218] raid6: neonx4   gen()   721 MB/s
[    2.827376] raid6: neonx4   xor()   605 MB/s
[    2.997533] raid6: neonx8   gen()   649 MB/s
[    3.167650] raid6: neonx8   xor()   548 MB/s
[    3.167657] raid6: using algorithm neonx4 gen() 721 MB/s
[    3.167664] raid6: .... xor() 605 MB/s, rmw enabled
[    3.167671] raid6: using neon recovery algorithm
[    3.169020] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/gmac_power_pin@0, deferring probe
[    3.169519] SCSI subsystem initialized
[    3.170082] usbcore: registered new interface driver usbfs
[    3.170139] usbcore: registered new interface driver hub
[    3.170205] usbcore: registered new device driver usb
[    3.170422] media: Linux media interface: v0.10
[    3.170457] Linux video capture interface: v2.00
[    3.170521] pps_core: LinuxPPS API ver. 1 registered
[    3.170528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.170548] PTP clock support registered
[    3.172193] clocksource: Switched to clocksource arch_sys_counter
[    3.275135] VFS: Disk quotas dquot_6.6.0
[    3.275241] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    3.276104] simple-framebuffer 7fe79000.framebuffer: framebuffer at 0x7fe79000, 0x178e00 bytes, mapped to 0xf0b00000
[    3.276122] simple-framebuffer 7fe79000.framebuffer: format=x8r8g8b8, mode=656x536x32, linelength=2880
[    3.283794] fbcon_init: disable boot-logo (boot-logo bigger than screen).
[    3.283803] Console: switching to colour frame buffer device 82x33
[    3.290734] simple-framebuffer 7fe79000.framebuffer: fb0: simplefb registered!
[    3.298618] NET: Registered protocol family 2
[    3.299322] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.299424] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.299551] TCP: Hash tables configured (established 8192 bind 8192)
[    3.299677] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.299745] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.300006] NET: Registered protocol family 1
[    3.300630] RPC: Registered named UNIX socket transport module.
[    3.300644] RPC: Registered udp transport module.
[    3.300650] RPC: Registered tcp transport module.
[    3.300657] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.300952] Trying to unpack rootfs image as initramfs...
[    3.844466] Freeing initrd memory: 8112K
[    3.845229] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    3.845598] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    3.846675] audit: initializing netlink subsys (disabled)
[    3.846989] audit: type=2000 audit(3.830:1): state=initialized audit_enabled=0 res=1
[    3.847385] Initialise system trusted keyrings
[    3.847611] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    3.852981] zbud: loaded
[    3.855627] NFS: Registering the id_resolver key type
[    3.855663] Key type id_resolver registered
[    3.855672] Key type id_legacy registered
[    3.855688] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.855696] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.856809] JFS: nTxBlock = 7980, nTxLock = 63844
[    3.867841] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    3.876688] Key type asymmetric registered
[    3.876780] bounce: pool size: 64 pages
[    3.876896] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    3.877083] io scheduler noop registered
[    3.877093] io scheduler deadline registered
[    3.877308] io scheduler cfq registered (default)
[    3.877318] io scheduler mq-deadline registered
[    3.877326] io scheduler kyber registered
[    3.877467] io scheduler bfq registered
[    3.878454] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
[    3.881883] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.937979] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.941467] console [ttyS0] disabled
[    3.961706] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 45, base_baud = 1500000) is a U6_16550A
[    4.898810] console [ttyS0] enabled
[    4.926096] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 46, base_baud = 1500000) is a U6_16550A
[    4.958682] 1c29c00.serial: ttyS2 at MMIO 0x1c29c00 (irq = 47, base_baud = 1500000) is a U6_16550A
[    4.971844] brd: module loaded
[    4.981402] loop: module loaded
[    5.082274] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
[    5.089791] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
[    5.096974] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    5.105943] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
[    5.115888] scsi host0: ahci-sunxi
[    5.119575] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 33
[    5.129905] libphy: Fixed MDIO Bus: probed
[    5.134723] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    5.140474] sun7i-dwmac 1c50000.ethernet: no reset control found
[    5.147196] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.153776] ehci-platform: EHCI generic platform driver
[    5.159358] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.165593] ohci-platform: OHCI generic platform driver
[    5.171206] usbcore: registered new interface driver usb-storage
[    5.178028] mousedev: PS/2 mouse device common for all mice
[    5.184459] sunxi-rtc 1c20d00.rtc: rtc core: registered rtc-sunxi as rtc0
[    5.191244] sunxi-rtc 1c20d00.rtc: RTC enabled
[    5.195844] i2c /dev entries driver
[    5.200341] axp20x-i2c 0-0034: AXP20x variant AXP209 found
[    5.213365] axp20x-gpio axp20x-gpio: AXP209 GPIO driver loaded
[    5.227479] input: axp20x-pek as /devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
[    5.238372] ldo1: supplied by regulator-dummy
[    5.243005] ldo2: supplied by regulator-dummy
[    5.248444] ldo3: supplied by regulator-dummy
[    5.253462] ldo4: supplied by regulator-dummy
[    5.258035] ldo5: supplied by regulator-dummy
[    5.263028] dcdc2: supplied by regulator-dummy
[    5.268127] dcdc3: supplied by regulator-dummy
[    5.276072] random: fast init done
[    5.279897] axp20x-i2c 0-0034: Backup (RTC) battery charging is disabled
[    5.286773] axp20x-i2c 0-0034: AXP20X driver loaded
[    5.295361] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    5.312655] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    5.372819] sunxi-mmc 1c0f000.mmc: base:0xf0ae7000 irq:28
[    5.381050] ledtrig-cpu: registered to indicate activity on CPUs
[    5.387455] hidraw: raw HID events driver (C) Jiri Kosina
[    5.393360] usbcore: registered new interface driver usbhid
[    5.398960] usbhid: USB HID core driver
[    5.405681] NET: Registered protocol family 10
[    5.439629] Segment Routing with IPv6
[    5.443492] NET: Registered protocol family 17
[    5.448252] Key type dns_resolver registered
[    5.453108] Registering SWP/SWPB emulation handler
[    5.453618] ata1: SATA link down (SStatus 0 SControl 300)
[    5.464229] registered taskstats version 1
[    5.468330] Loading compiled-in X.509 certificates
[    5.473267] zswap: loaded using pool lzo/zbud
[    5.479619] Btrfs loaded, crc32c=crc32c-generic
[    5.491214] mmc0: host does not support reading read-only switch, assuming write-enable
[    5.503657] Key type encrypted registered
[    5.507782] mmc0: new high speed SDHC card at address aaaa
[    5.516434] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    5.519441] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
[    5.519453] sun7i-dwmac 1c50000.ethernet: no reset control found
[    5.534470]  mmcblk0: p1
[    5.632371] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
[    5.637976] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
[    5.645293] sun7i-dwmac 1c50000.ethernet: Normal descriptors
[    5.673003] libphy: stmmac: probed
[    5.676428] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    5.688955] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.731114] ehci-platform 1c14000.usb: EHCI Host Controller
[    5.736809] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
[    5.750940] ehci-platform 1c14000.usb: irq 30, io mem 0x01c14000
[    5.782213] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
[    5.788593] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.795407] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.802641] usb usb1: Product: EHCI Host Controller
[    5.807514] usb usb1: Manufacturer: Linux 4.14.78-sunxi ehci_hcd
[    5.813527] usb usb1: SerialNumber: 1c14000.usb
[    5.825919] hub 1-0:1.0: USB hub found
[    5.829730] hub 1-0:1.0: 1 port detected
[    5.834833] ehci-platform 1c1c000.usb: EHCI Host Controller
[    5.840441] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[    5.848603] ehci-platform 1c1c000.usb: irq 34, io mem 0x01c1c000
[    5.882211] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    5.888559] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.895369] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.902594] usb usb2: Product: EHCI Host Controller
[    5.907466] usb usb2: Manufacturer: Linux 4.14.78-sunxi ehci_hcd
[    5.913477] usb usb2: SerialNumber: 1c1c000.usb
[    5.925828] hub 2-0:1.0: USB hub found
[    5.929637] hub 2-0:1.0: 1 port detected
[    5.934691] ohci-platform 1c14400.usb: Generic Platform OHCI controller
[    5.941337] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
[    5.949428] ohci-platform 1c14400.usb: irq 31, io mem 0x01c14400
[    6.026421] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    6.033240] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.040453] usb usb3: Product: Generic Platform OHCI controller
[    6.046379] usb usb3: Manufacturer: Linux 4.14.78-sunxi ohci_hcd
[    6.052389] usb usb3: SerialNumber: 1c14400.usb
[    6.064749] hub 3-0:1.0: USB hub found
[    6.068570] hub 3-0:1.0: 1 port detected
[    6.073629] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    6.080274] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
[    6.088398] ohci-platform 1c1c400.usb: irq 35, io mem 0x01c1c400
[    6.166449] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    6.173268] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.180481] usb usb4: Product: Generic Platform OHCI controller
[    6.186412] usb usb4: Manufacturer: Linux 4.14.78-sunxi ohci_hcd
[    6.192423] usb usb4: SerialNumber: 1c1c400.usb
[    6.197582] hub 4-0:1.0: USB hub found
[    6.201378] hub 4-0:1.0: 1 port detected
[    6.206268] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    6.217534] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    6.223336] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
[    6.231427] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    6.238240] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.245470] usb usb5: Product: MUSB HDRC host driver
[    6.250429] usb usb5: Manufacturer: Linux 4.14.78-sunxi musb-hcd
[    6.256439] usb usb5: SerialNumber: musb-hdrc.1.auto
[    6.262098] hub 5-0:1.0: USB hub found
[    6.265953] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    6.273004] hub 5-0:1.0: 1 port detected
[    6.278245] of_cfs_init
[    6.280817] of_cfs_init: OK
[    6.283878] vcc3v0: disabling
[    6.286848] vcc5v0: disabling
[    6.289831] usb0-vbus: disabling
[    6.304199] Freeing unused kernel memory: 1024K
Loading, please wait...
starting version 237
[    6.488081] usb 1-1: New USB device found, idVendor=090c, idProduct=1000
[    6.494926] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.502082] usb 1-1: Product: USB Flash Disk
[    6.506439] usb 1-1: Manufacturer: General
[    6.510555] usb 1-1: SerialNumber: 0342115060012022
[    6.517256] usb-storage 1-1:1.0: USB Mass Storage device detected
[    6.526937] scsi host1: usb-storage 1-1:1.0
[    6.537255] usbcore: registered new interface driver uas
[    7.919988] scsi 1:0:0:0: Direct-Access     General  USB Flash Disk   1100 PQ: 0 ANSI: 6
[    7.930285] sd 1:0:0:0: [sda] 31490048 512-byte logical blocks: (16.1 GB/15.0 GiB)
[    7.951698] sd 1:0:0:0: [sda] Write Protect is off
[    7.959786] sd 1:0:0:0: Attached scsi generic sg0 type 0
[    7.968949] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    8.005130]  sda: sda1
[    8.020430] sd 1:0:0:0: [sda] Attached SCSI removable disk
done.
[/sbin/fsck.ext4 (1) -- /dev/sda1] fsck.ext4 -a -C0 /dev/sda1
/dev/sda1: clean, 35769/985424 files, 278765/3936000 blocks
done.
[    8.958458] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
done.
[    9.681726] systemd[1]: System time before build time, advancing clock.
[    9.723733] ip_tables: (C) 2000-2006 Netfilter Core Team
[    9.768715] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    9.790891] systemd[1]: Detected architecture arm.
[    9.844780] systemd[1]: Set hostname to <bananapi>.
[   10.783301] random: systemd: uninitialized urandom read (16 bytes read)
[   10.790049] systemd[1]: Reached target System Time Synchronized.
[   10.822656] random: systemd: uninitialized urandom read (16 bytes read)
[   10.829878] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.873526] random: systemd: uninitialized urandom read (16 bytes read)
[   10.881913] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.933066] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.972866] systemd[1]: Reached target Swap.
[   11.005539] systemd[1]: Created slice System Slice.
[   11.043188] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   11.616484] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[   11.922396] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro
[   12.530618] systemd-journald[234]: Received request to flush runtime journal from PID 1
         Mounting /tmp...
[  OK  ] Found device /dev/disk/by-uuid/10c0b00f-4815-40fc-8cfd-c0395fd9982c.
         Starting File System Check on /dev/…00f-4815-40fc-8cfd-c0395fd9982c...
[  OK  ] Started File System Check Daemon to report status.
[  OK  ] Started File System Check on /dev/d…0b00f-4815-40fc-8cfd-c0395fd9982c.
         Mounting /media/mmcboot...
[  OK  ] Mounted /media/mmcboot.
         Mounting /boot...
[  OK  ] Mounted /boot.
bananapi login:
Link to post
Share on other sites
Here we can see both u-boot and kernel can see the USB drive (pendrive log)
The kernel starts USB initialization at
Absence of this init in the failed case could (imho) be caused by incorrect/damaged device tree.
Device tree is loaded to memory by u-boot (and seems patched after this).
I'm not familiar with u-boot in details, perhaps it uses the same device tree and this explains why it does not see storage device too. Although, this could be less important because u-boot seems load both  kernel and device tree from SD (if I understand this boot process correctly).
So the next step would be checking the device tree and presence of device at 1c14000.
Link to post
I've tried to compare u-boot's Bananapi_defconfig used by ARMBIAN 5.65 vs ARMBIAN 5.75 and there are just few small change which should not affect the boot (imho).
Kernel was changed between 5.65 and 5.75 (the repository location and the version).
My board is running ARMBIAN 5.73, kernel 4.19.20.
It is booting from SSD connected on SATA (but u-boot is on SD, this A20 cannot boot from SATA or USB directly).
An interesting point is: dmesg shows kernel had found and initialized USB hub. That's a little bit confusing as you've said 5.69 is not OK (I assume USB is not initialized).
Unfortunately I cannot get u-boot log (I have only remote access to the board).
Link to post
