Igor Posted May 4, 2017 Posted May 4, 2017 I put them both to build, but haven't test yet - only for building. https://github.com/Kwiboo/u-boot-rockchip/commit/244f8753744eefbd7cd1307c0bd8f7b297486211 2
TonyMac32 Posted May 4, 2017 Posted May 4, 2017 Built, no longer getting the "error, address not set" on the ethernet at boot. Getting late, can't dig in much further but I'd guess it's a success. 1
gkkpch Posted May 4, 2017 Posted May 4, 2017 Something else, I can't get reboot to work, does anyone have an idea where to start looking? Any hint would be appreciated.
TonyMac32 Posted May 4, 2017 Posted May 4, 2017 I'm afraid not, I played with it briefly but couldn't get any meaningful information on where it was getting hung up from logs. It looks like it makes it to shutdown just fine, but hangs on the actual restart as if it's not pointing at the right location on soft reset. [Edit] With some research into the ASUS kernel, determined cause to be power being disabled to the SD card, a somewhat hack-ish workaround is in place, patch merged.
Tido Posted May 4, 2017 Posted May 4, 2017 Yeah, a working reboot while testing would be really useful. When I google'd it I saw that it takes some know-how about working with kernel and or SDK (which I don't have). I would be more than happy to give someone access to my Board via AnyDesk or such. By the way, for Desktop users of Tinker Board, read this: ASUS Tinker Boards Get Linux 4.11 with 3D Graphics Acceleration
Igor Posted May 4, 2017 Posted May 4, 2017 I changed DEV branch to NEXT today ... so you need to switch branches or start with new image. Tomorrow nightly builds will also be branch NEXT. BTW. MiQi with 4.11 and mainline u-boot reboots fine.
gkkpch Posted May 4, 2017 Posted May 4, 2017 FYI: I compiled two Tinkerboard 4.4 kernels today, one from kwiboo's repo, branch "tinkerboard-4.4" and the one I got from Asus directly, they now published it as the TinkerBoard repo Kwiboo's boots and reboots, but so does the one from the Asus TinkerBoard repo. Actually including onboard WLAN and also working as a hotspot. Don't use GCC6 on Kwiboo's, unless you want to spend your time bug fixing (e.g. misleading indentation etc. ), in the end I just disabled the restrictive checking in the Makefile.
TonyMac32 Posted May 4, 2017 Posted May 4, 2017 @Tido Yeah, that's @Myy. I also see it's pointing at beta.armbian.com. @Igor I was going to ask about Miqi rebooting tonight, it slipped my mind, thank you.
TonyMac32 Posted May 5, 2017 Posted May 5, 2017 Uploading patch to fix reboot on Tinker board 4.4 kernel. The miqi must not use vmmc or vqmmc supplies, or else it would also be affected. The shutdown sequence turns the SD card off completely before reboot, and fails to reset to 3.3 volts from 1.8 (for high-speed cards) 1
lucifercipher Posted May 5, 2017 Posted May 5, 2017 Got the tinkers today and fired it up with 4.4.66-rockchip default (no desktop) .I see its a 32bit so far. Noticed the SoC is clocked at 1608 Mhz. Did some quick benchmarks for 20k primes and uploaded here: http://orangepi.cryptoedge.net/SoC Benchmarks.txt http://orangepi.cryptoedge.net/SoC Bemchmarks Multi Threaded.txt Log uploaded: http://sprunge.us/dWic Every 2.0s: cat /proc/sys/kernel/random/entropy_avail Fri May 5 09:51:54 2017 1995 (almost half compared to H5 SoC) :/ First impression. The heat sink should be having more mass than this tiny one. Testing starts now...
tkaiser Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 9:44 AM, lucifercipher said: Did some quick benchmarks for 20k primes Expand No, not that again! Sysbench's cpu 'benchmark' is NOT a hardware test. http://www.cnx-software.com/2017/04/28/cavium-thunderx-based-scaleway-armv8-cloud-servers-go-for-2-99-euros-per-month-and-up/#comment-541962 https://forum.armbian.com/index.php?/topic/1748-sbc-consumptionperformance-comparisons/ https://forum.armbian.com/index.php?/topic/4199-you-have-to-choose/&do=findComment&comment=31095 By looking at your numbers Orange Pi PC 2 is 9.5 times faster than Tinkerboard. Who should believe this? TL;DR: Sysbench doesn't test hardware. 1
lucifercipher Posted May 5, 2017 Posted May 5, 2017 Yeah its not a hardware test but just a comparison with other three SoCs. Is there a nightly 64bit available right now? The idle temps also seem higher compared to Pi3,2 , AWH3 and AWH5.
lucifercipher Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 9:55 AM, tkaiser said: By looking at your numbers Orange Pi PC 2 is 9.5 times faster than Tinkerboard. Who should believe this? Hmm well what i can do is upload screenshots instead of text outputs . Would be something better? Expand
tkaiser Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 9:58 AM, lucifercipher said: Yeah its not a hardware test but just a comparison with other three SoCs. Expand No, it's a comparison with other sysbench binaries running here and there with different compiler settings. Numbers without meaning in this mode unfortunately. And no, Cortex-A17 is 32-bit so not 64-bit capable. But since all affordable 64-bit platforms currently are based on dog-slow Cortex-A53 that doesn't matter at all
constantius Posted May 5, 2017 Posted May 5, 2017 Armbain for Tinkerboard is not stable - system hang on very often..... there is no audio..... i have to use external usb sound card.
tkaiser Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 11:28 AM, constantius said: Armbain for Tinkerboard is not stable - system hang on very often Expand Great report! Has anyone in the meantime figured out how to power this board avoiding Micro USB? To prevent 'Armbian is not stable' findings in the future?
richardk Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 10:01 AM, tkaiser said: But since all affordable 64-bit platforms currently are based on dog-slow Cortex-A53 Expand "All available?" Didn't you see? http://www.96boards.org/product/hikey960/ (notice the "buy" links...) Okay. Some might dispute "affordable".
tkaiser Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 1:43 PM, richardk said: Didn't you see? http://www.96boards.org/product/hikey960/ Expand I've seen this but I won't call this thing affordable and I'm not that crazy (I won't buy overpriced Android phones without enclosures especially not when questionable agencies are responsible for f*cking up product documentation. My opinions on HiKey boards here or there) Back on topic: some homework for you Tinkerboard owners: https://forum.armbian.com/index.php?/topic/4200-pi-fan-control-work-on-tinker-board/&do=findComment&comment=31128
TonyMac32 Posted May 5, 2017 Posted May 5, 2017 I have seen a lot of temperature variation from image to image (not Armbian, I'm talking from ASUS's images, Rockchip-linux build, etc). CPU op points and temperature trip points are moving around a lot, I haven't been taxing mine all that hard, mostly doing quick "did my patch work" checks. I checked my router, the last 3 bytes of my MAC address are still seemingly random, it should be stable between builds/images, correct? As far as powering the tinker board goes, I see no way to bypass the microUSB yet, I need to try to probe "USBIN_VBUS_80" on the board itself, otherwise any solution will be extremely hack. If lucky there is a tespoint somewhere that can be used.
lucifercipher Posted May 5, 2017 Posted May 5, 2017 @TonyMac32I didn't want to be bothered by the power issue so i used a Samsung S7 Edge USB cable with the Aukey certified power brick . I see that the CPU starts to throttle around 71C . In any case, the USB power input seems like a big joke .
TonyMac32 Posted May 5, 2017 Posted May 5, 2017 I'm using some cables I spec'd online, I can' tremember the exact source, however their voltage drop is minimal and so far they've worked well. That said I'd prefer a better solution, if someone were to take care to use adequate protection, it looks like putting 5V on the GPIO (pins 2-3) will supply VCC_SYS, which is what the RK808 uses to get all the system voltages. You'd only be missing the surge suppressor, current limiter, and usb charge detector. (that one might be a sticking point, I think it might signal power OK) 1
tkaiser Posted May 5, 2017 Posted May 5, 2017 On 5/5/2017 at 3:12 PM, TonyMac32 said: it looks like putting 5V on the GPIO (pins 2-3) will supply VCC_SYS, which is what the RK808 uses to get all the system voltages. You'd only be missing the surge suppressor, current limiter, and usb charge detector. Expand Would be great if you can further investigate here since due to RK3288 being quite powerful and powering through Micro USB being such a sh*t show a warning like this might be necessary (but on Pine64 there's no difference between GPIO pins on Euler connector or Micro USB unlike Raspberries or the Tinkerboard now)
Tido Posted May 5, 2017 Posted May 5, 2017 Please take all of this with a grain of salt - I was just collecting information for RPi-Monitor and came across this. @TonyMac32 I tried to read out: cat /sys/class/regulator/regulator.13/microvolts It stays in idle and benchmark at 1000000 (I suppose 1Volt). So I suppose this is hardcoded in DTS ? Because in this thread I read : > + regulator-min-microvolt = <850000>; > + regulator-max-microvolt = <1350000>; Normally the max voltage is 1.4v says this overclocker Overclocking RK3288 Edit, found one more interesting: altghough I still do not support 1,8GHz +&cpu0 { + cpu0-supply = <&vdd_cpu>; + operating-points = < + /* KHz uV */ + 1800000 1400000 + 1608000 1350000 + 1512000 1300000 + 1416000 1200000 + 1200000 1100000 + 1008000 1050000 + 816000 1000000 + 696000 950000 + 600000 900000 + 408000 900000 + 312000 900000 + 216000 900000 + 126000 900000 + >;
TonyMac32 Posted May 6, 2017 Posted May 6, 2017 On 5/5/2017 at 10:16 PM, Tido said: Please take all of this with a grain of salt - I was just collecting information for RPi-Monitor and came across this. @TonyMac32 I tried to read out: cat /sys/class/regulator/regulator.13/microvolts It stays in idle and benchmark at 1000000 (I suppose 1Volt). So I suppose this is hardcoded in DTS ? Because in this thread I read : > + regulator-min-microvolt = <850000>; > + regulator-max-microvolt = <1350000>; Normally the max voltage is 1.4v says this overclocker Overclocking RK3288 Edit, found one more interesting: altghough I still do not support 1,8GHz Expand regulator.13 is vdd10_lcd, you want regulator.4, vdd_arm 1
lucifercipher Posted May 8, 2017 Posted May 8, 2017 @TonyMac32Will you be releasing the NEXT release of tinker with built in wifi support soon?
TonyMac32 Posted May 8, 2017 Posted May 8, 2017 I am going to attempt to put the reboot patch in there tonight and get some more dts work done, I'm afraid none of the rockchip wifi system interface is built into the 4.11 kernel. I'll take a look at 4.12 to see how much work I want to put into it, and of course look at some other rockchip-oriented kernels to see if they have it implemented or not. Remember we don't have working BT in the 4.4 either. And then there's the sound issue, which should just be an ALSA configuration and maybe a PA fix, if someone else wanted to start looking into that. ;-) 1
lucifercipher Posted May 9, 2017 Posted May 9, 2017 On 5/8/2017 at 8:45 PM, TonyMac32 said: I am going to attempt to put the reboot patch in there tonight and get some more dts work done, I'm afraid none of the rockchip wifi system interface is built into the 4.11 kernel. I'll take a look at 4.12 to see how much work I want to put into it, and of course look at some other rockchip-oriented kernels to see if they have it implemented or not. Remember we don't have working BT in the 4.4 either. And then there's the sound issue, which should just be an ALSA configuration and maybe a PA fix, if someone else wanted to start looking into that. ;-) Expand I understand where you are coming from. If it helps, the TinkerOS beta 1.8 release has addressed those problems. Could be a reference perhaps? I did not find the source code for it. 1
