TonyMac32 Posted July 26, 2017 Posted July 26, 2017 Hmmm, no idea, that doesn't actually look like a bluetooth keyboard, to be honest, it's just popping up as a standard generic HID device. [ 1.996363] usb 1-1.3: new low-speed USB device number 3 using dwc2 [ 2.079542] usb 1-1.3: New USB device found, idVendor=046e, idProduct=5577 [ 2.079556] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.079566] usb 1-1.3: Product: USB Multimedia Cordless Keyboard [ 2.079574] usb 1-1.3: Manufacturer: BTC [ 2.083962] input: BTC USB Multimedia Cordless Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0 [ 2.135850] hid-generic 0003:046E:5577.0001: input,hidraw0: USB HID v1.11 Keyboard [BTC USB Multimedia Cordless Keyboard] on usb-ff540000.usb-1.3/input0 [ 2.143143] input: BTC USB Multimedia Cordless Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:046E:5577.0002/input/input1 [ 2.195087] hid-generic 0003:046E:5577.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [BTC USB Multimedia Cordless Keyboard] on usb-ff540000.usb-1.3/input1 perhaps if you could boot the other images that don't recognize it, with it plugged in, and do the same thing? I'm kind of curious now...
bedalus Posted July 26, 2017 Posted July 26, 2017 I would if I could, but I've no way to log into the device on the standard images as this is my only keyboard! Maybe they'd let me borrow one from work. I have to say thanks thanks for all your work and input in this thread. When I got this device I was unaware of armbian, and happened to discover it because you posted a link in the asus forum: https://tinkerboarding.co.uk/forum/thread-330.html I found armbian and its users so interesting I must have read this entire thread two or three times! If you follow the link above you can see how I followed your example with GPIO power and an uprated heatsink and was able to hacksaw a hole into my case and attach a little fan! You can even see my dongle 2
chrisf Posted July 26, 2017 Posted July 26, 2017 On 7/25/2017 at 5:43 AM, RickyTerzis said: external HDD's assuming they won't spin up on the USB alone. I haven't had a problem powering a 2.5" hard drive from the USB port It's much better than my Pine64 boards. They reboot when plugged in and the hard drive refuses to spin up.
Myy Posted July 26, 2017 Posted July 26, 2017 Try to execute lsmod on the working kernel. Since most drivers are compiled modules, that should tell you what is the driver, I think. Then, from the module name, you can retrace the config option required and its dependencies. It might also be possible to determine the driver used using /sys nodes. But I don't know how exactly. udevadm can also help you. But yeah, try lsmod first. 1
TonyMac32 Posted July 26, 2017 Posted July 26, 2017 We could just be overthinking it, the Next download jumped from 4.11 to 4.12.3, could just be an updated module, rather than a new one.
Myy Posted July 26, 2017 Posted July 26, 2017 That too, yeah. But at least, you'll know which one it is.
Myy Posted July 26, 2017 Posted July 26, 2017 But wait... you got Bluetooth working on 4.12 kernels ? Are you using an external Bluetooth dongle or did you just start your Bluetooth keyboard and it worked out the box ? Edit : Ah, didn't read correctly, you're using an external dongle. Well given the bad feedback I got from the tinkering forum on the internal Bluetooth, I guess it's the best choice. 1
TonyMac32 Posted July 26, 2017 Posted July 26, 2017 The BTCOEX and such used by ASUS is several revisions back and, if the Mainline work on the wifi driver any indication, probably buggy.
bedalus Posted July 26, 2017 Posted July 26, 2017 root@tinkerboard:/home/bedalus# lsmod Module Size Used by snd_soc_hdmi_codec 16384 0 r8723bs 552960 0 dw_hdmi_i2s_audio 16384 0 mali_kbase 319488 0 Nothing to see with lsmod. However, udevadm gives me: root@tinkerboard:/home/bedalus# udevadm info --query=all /dev/input/by-id/usb-BTC_USB_Multimedia_Cordless_Keyboard-event-kbd P: /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0/event0 N: input/event0 S: input/by-id/usb-BTC_USB_Multimedia_Cordless_Keyboard-event-kbd S: input/by-path/platform-ff540000.usb-usb-0:1.3:1.0-event-kbd E: BACKSPACE=guess E: DEVLINKS=/dev/input/by-path/platform-ff540000.usb-usb-0:1.3:1.0-event-kbd /dev/input/by-id/usb-BTC_USB_Multimedia_Cordless_Keyboard-event-kbd E: DEVNAME=/dev/input/event0 E: DEVPATH=/devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0/event0 E: ID_BUS=usb E: ID_INPUT=1 E: ID_INPUT_KEY=1 E: ID_INPUT_KEYBOARD=1 E: ID_MODEL=USB_Multimedia_Cordless_Keyboard E: ID_MODEL_ENC=USB\x20Multimedia\x20Cordless\x20Keyboard E: ID_MODEL_ID=5577 E: ID_PATH=platform-ff540000.usb-usb-0:1.3:1.0 E: ID_PATH_TAG=platform-ff540000_usb-usb-0_1_3_1_0 E: ID_REVISION=0310 E: ID_SERIAL=BTC_USB_Multimedia_Cordless_Keyboard E: ID_TYPE=hid E: ID_USB_DRIVER=usbhid E: ID_USB_INTERFACES=:030101:030102: E: ID_USB_INTERFACE_NUM=00 E: ID_VENDOR=BTC E: ID_VENDOR_ENC=BTC E: ID_VENDOR_ID=046e E: MAJOR=13 E: MINOR=64 E: SUBSYSTEM=input E: USEC_INITIALIZED=4130433 E: XKBLAYOUT=us E: XKBMODEL=pc105 So usbhid. I think I'll borrow a keyboard from work then we can find out for sure. IKONFIG is set, so if I'm able to use a different keyboard and log in, I can diff the exact config used against the nightly.
Frostbyte Posted July 27, 2017 Posted July 27, 2017 My tinker board appears to have crashed again after 1.8 weeks of uptime. Power supply is the micro-USB "official" RPi one, and it's rated at 2.5A , the SD card appears to be fine. Symptoms: Only the red led was powered on, I had no green (I/O) or yellow led (heartbeat) activity. When removing the power cord and reinserting it, it would power-on for a couple of seconds and then it would power-off by itself. I left it powered-off for around 2 minutes and then powered it on and it's working ok so far. I checked my graphs and I see that over the course of the last 2 weeks, the CPU was sustaining temps between 61-65.5 °C. Right now I'm noticing a 74°C temperature spike, which is slowly coming down to the previously observed temperatures. (This graph displays the last 24h) I'm not sure why the CPU raises it's temperature if the system has crashed. I've also reviewed the syslog and kernel logs, but I cannot find anything that would point me to the cause of the crash. It also must've refused to start because it was overheated, but why does it always work fine for almost two weeks and then suddenly decides to die? I would appreciate any pointers to help me investigate. Using mainline kernel. root@Tuxbox:~# lsb_release -a && uname -r No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 16.04.2 LTS Release: 16.04 Codename: xenial 4.11.6-rockchip
Tido Posted July 27, 2017 Posted July 27, 2017 IIRC, because of Log2Ram it will not write to SDcard when it crashes. You would have to write the data/logs to another storage device USB-Stick or something externally. Beside with RPi-Monitor you might also be able to collect some data - is WIP. 1
Igor Posted July 27, 2017 Posted July 27, 2017 ... and its completely normal that it crashes when microUSB powering method is used. Its a fail by design and its a double fail when used with such a power hungry chip. Even your PSU gives you 100 A you will still face the same problem. https://forum.armbian.com/index.php?/forum/31-sd-card-and-power-supply/ Power via GPIO.
Frostbyte Posted July 27, 2017 Posted July 27, 2017 17 minutes ago, Igor said: Power via GPIO. Are there any instructions available? Any precautions, etc? Thanks. PS: In the meantime, can I somehow downclock the SoC a little bit? Would that help any?
bedalus Posted July 27, 2017 Posted July 27, 2017 On 2017-7-26 at 5:53 AM, TonyMac32 said: Hmmm, no idea, that doesn't actually look like a bluetooth keyboard, to be honest, it's just popping up as a standard generic HID device. [ 1.996363] usb 1-1.3: new low-speed USB device number 3 using dwc2 [ 2.079542] usb 1-1.3: New USB device found, idVendor=046e, idProduct=5577 [ 2.079556] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.079566] usb 1-1.3: Product: USB Multimedia Cordless Keyboard [ 2.079574] usb 1-1.3: Manufacturer: BTC [ 2.083962] input: BTC USB Multimedia Cordless Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046E:5577.0001/input/input0 [ 2.135850] hid-generic 0003:046E:5577.0001: input,hidraw0: USB HID v1.11 Keyboard [BTC USB Multimedia Cordless Keyboard] on usb-ff540000.usb-1.3/input0 [ 2.143143] input: BTC USB Multimedia Cordless Keyboard as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:046E:5577.0002/input/input1 [ 2.195087] hid-generic 0003:046E:5577.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [BTC USB Multimedia Cordless Keyboard] on usb-ff540000.usb-1.3/input1 perhaps if you could boot the other images that don't recognize it, with it plugged in, and do the same thing? I'm kind of curious now... Well, I was allowed to borrow a USB keyboard from work, and I flashed the standard version with the mainline kernel, and... [ 2.033927] usb 1-1.3: new low-speed USB device number 3 using dwc2 [ 2.116818] usb 1-1.3: New USB device found, idVendor=046e, idProduct=5577 [ 2.116831] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.116841] usb 1-1.3: Product: USB Multimedia Cordless Keyboard [ 2.116850] usb 1-1.3: Manufacturer: BTC [ 2.212636] usb 3-1: config 1 has an invalid interface number: 255 but max is 6 [ 2.212648] usb 3-1: config 1 has no interface number 6 [ 2.214117] usb 3-1: New USB device found, idVendor=0bda, idProduct=481a [ 2.214130] usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2 [ 2.214139] usb 3-1: Product: USB Audio [ 2.214148] usb 3-1: Manufacturer: Generic [ 2.214156] usb 3-1: SerialNumber: 201405280001 ... [ 4.333263] input: Generic USB Audio as /devices/platform/ff500000.usb/usb3/3-1/3-1:1.255/0003:0BDA:481A.0003/input/input1 [ 4.385590] hid-generic 0003:0BDA:481A.0003: input,hiddev0,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-ff500000.usb-1/input255 USB 1-1.3 never gets allocated as an input device, even though it's detected (USB 3-1 later gets a device, which are the bottom two lines after I cut an irrelevant section). So perhaps something to do with some hid options? I took the diff between the configs: > CONFIG_HID_ACCUTOUCH=m ... > CONFIG_HID_CP2112=m ... > CONFIG_HID_NTI=m Not sure if these are relevant, it's difficult for me to guess whether it was a config option that helped, maybe it was just some mainline commit that fixed something between 4.11 and 4.12. Anyway, if you want to pursue the reason, I've attached the output of armbianmonitor -u and the diff between the two kernel configs. I'm out of ideas, but happy and lucky to have a working cordless keyboard! armhwinfo.log config.diff
bedalus Posted July 28, 2017 Posted July 28, 2017 On 16/05/2017 at 7:31 AM, tkaiser said: minerd --benchmark [...] I would recommend testing with cpuminer (minerd --benchmark) since this tool provides a khash/sec output so you're able to detect throttling pretty easy. [...] If you Tinkerboard owners are able to improve heat dissipation that much that you get a constant +8 khash/sec value then you start to test for powering problems on this board. EDIT: I deleted a lot of the results I just posted after re-reading the thread... It's all been done before! I got similar resuls as others who've done the test, around 6.6khash/s followed five minutes later by a decline to around 6.1, caused by thermal throttling to ~1.7GHz. At least I seem to have a stable setup. Any other tests I can run on armbian's behalf? Anything I can do to help, I'm happy to give it a go. 1
Myy Posted July 29, 2017 Posted July 29, 2017 Hmm, given that the BTC Keyboard ID have been added 7 years ago, I guess it's more related to Bluetooth dongles getting detected correctly, indeed. 1
Frostbyte Posted August 12, 2017 Posted August 12, 2017 I've just finished writing my SHT31-D (I2C) Nagios plugin. As promised, it can be found here for anyone else interested. 2
mpmc Posted August 24, 2017 Posted August 24, 2017 Thanks for your hard work getting the Tinkerboard running Armbian guys! On 17/07/2017 at 1:57 PM, lafalken said: Sounds great! Would like to see an clean version without desktop too. I would like to use this card as webb server, but is it stable enough for such use? For that I would use a usb-hdd, network cable and power. All other things like wireless is of no use for me. But a reboot that does not work is not very good ;( I'd like to use it headless as well running Debian instead of Ubuntu, transcoding would be a bonus, but not required! I'm currently not using the board, waiting for things to stabilise a bit more.. I've set it up (with a 3amp PSU) & it's ready to go. I'm more than happy to test some images on it though if needed.
bedalus Posted September 16, 2017 Posted September 16, 2017 I've been waiting for my Sentio Superbook to turn up (I think it will arrive in a month or two) so I haven't had much use for my tiny portable desktop, which has gathered some dust over the last few weeks. I've sneezed it off, and flashed the lastest nightly Armbian_5.32.170916_Tinkerboard_Ubuntu_xenial_dev_4.13.0_desktop.7z (2017-09-15 08:10 589.2 MB) I'm happy to report that my bluetooth keyboard continues to work with the nightlies, and since the last version I tested, I'm extremely pleased to now find that there is a login screen. Also, Chromium now works again. Another thing that had bugged me, being prompted for admin password for wifi reconnect, has now been fixed. I'm well chuffed.
tkaiser Posted September 16, 2017 Posted September 16, 2017 35 minutes ago, bedalus said: Chromium now works again Can you please post the output of 'psd p' please (should look like https://wiki.archlinux.org/index.php/profile-sync-daemon#Preview_.28parse.29_mode and I'm interested in activation mode and overlayfs size)
TonyMac32 Posted September 16, 2017 Posted September 16, 2017 I would recommend using the last 4.12 image for now, there is a bug messing up the thermals so I'm not sure if it's wholly safe. There is a pointer error occurring while initializing the tsadc, and I've not been able to track it down yet. @Igor it would be best to pull the 4.13 images if possible, they don't actually provide any additional functionality, I was hoping to have this cleaned up yesterday, but it wasn't as simple as I thought. With broken thermal zones and this board's garbage heatsink... @Myy can you confirm that the tsadc is working on your 4.13 kernel? I'm working my way through the patches/drivers/etc, but confirmation it is/isn't a 4.13 problem would be great.
Igor Posted September 16, 2017 Posted September 16, 2017 Just now, TonyMac32 said: @Igor it would be best to pull the 4.13 images if possible, they don't actually provide any additional functionality, I was hoping to have this cleaned up yesterday, but it wasn't as simple as I thought. With broken thermal zones and this board's garbage heatsink... True. I removed old nightly builds and their creating until this is not solved.
TonyMac32 Posted September 16, 2017 Posted September 16, 2017 I've uploaded the patch to fix it, @bedalus if you can build it yourself you can try it now.
bedalus Posted September 18, 2017 Posted September 18, 2017 On 9/16/2017 at 9:25 AM, tkaiser said: Can you please post the output of 'psd p' please (should look like https://wiki.archlinux.org/index.php/profile-sync-daemon#Preview_.28parse.29_mode and I'm interested in activation mode and overlayfs size) bedalus@tinkerboard:~$ psd p Profile-sync-daemon v6.31 on Ubuntu 16.04.3 LTS Systemd service is currently inactive. Systemd resync-timer is currently inactive. Overlayfs v23 is currently active. Psd will manage the following per /home/bedalus/.config/psd/psd.conf: browser/psname: chromium/chromium owner/group id: bedalus/1000 sync target: /home/bedalus/.config/chromium tmpfs dir: /run/user/1000/bedalus-chromium profile size: 42M overlayfs size: recovery dirs: none
tkaiser Posted September 18, 2017 Posted September 18, 2017 1 minute ago, bedalus said: Systemd service is currently inactive. Systemd resync-timer is currently inactive. Thank you, then it's not just me. And there is something wrong: https://github.com/armbian/build/blob/8d211eec2c15feb1e77d8dee7bf45ee7ef645eab/packages/bsp/common/etc/profile.d/check_first_login.sh#L13-L32 With psd active your Chromium performance will increase by magnitudes.
mihai.aldea Posted September 28, 2017 Posted September 28, 2017 Guys, does anyone know what's the deal with those 2x2 and 1x2 pin header placeholders? They must have some role yet I found nothing on the internet and the Asus support guys aren't much of a help, they keep referring to the GPIO headers :-)))
TonyMac32 Posted September 28, 2017 Posted September 28, 2017 The "outboard" 2 pins on the 2x2 are the power button inputs. The other two on that connector, I've heard various things but haven't done anything with personally. The 1x2 is S/PDIF I believe.
dragonlost Posted September 29, 2017 Posted September 29, 2017 Hello. I installed armbian on my tinkerboard but when I install packets python with PIP I have problems of access right. I also have problems with the Network Manager where I can not change connection. Everything is grayed out. how to remedy these 2 problems of right of access that I think are related.
TonyMac32 Posted September 29, 2017 Posted September 29, 2017 3 minutes ago, dragonlost said: when I install packets python with PIP I have problems of access right. I also have problems with the Network Manager where I can not change connection. Everything is grayed out. What image did you use, and what did you use to flash it to the SD card? I have not encountered any issues with network manager in my testing/use. For Python I'm afraid I'm not the expert resource.
dragonlost Posted September 29, 2017 Posted September 29, 2017 I use image : Armbian_5.33_Tinkerboard_Ubuntu_xenial_next_4.13.3_desktop . I use etcher for flash sdcard. I have no problem with network manager just permission connection editing problem. What are permission for editing connection in network manger ?
