jernej Posted March 30, 2019 Posted March 30, 2019 4 minutes ago, martinayotte said: Can you bring me some light ? I'm currently digging a whole while been in the fog without any shovel ... Now that I checked changes again, it just about power key connected to PMU, so probably that's not it. So, does reset with PineH64 U-Boot work on OPi or not? If not, then it has to be some peripheral settings...
martinayotte Posted March 30, 2019 Author Posted March 30, 2019 4 minutes ago, jernej said: So, does reset with PineH64 U-Boot work on OPi or not? If not, then it has to be some peripheral settings... Not on fresh boot, as well as original OPi U-Boot, but both work well if the BSP U-Boot handler is still in memory. This is why I've said "Back to SquareOne" when I've investigated the reset_cpu() code from arch/arm/mach-sunxi/board.c ... and I still don't catch why PineH64 U-Boot works fine on PineH64 boards ... 1
lanefu Posted March 30, 2019 Posted March 30, 2019 2 hours ago, martinayotte said: False Victory ... you're still a machine. 1
dolphs Posted March 31, 2019 Posted March 31, 2019 18 hours ago, martinayotte said: This is why I've said "Back to SquareOne" when I've investigated the reset_cpu() code from arch/arm/mach-sunxi/board.c ... and I still don't catch why PineH64 U-Boot works fine on PineH64 boards ... pity, oh well let's hope the best of it honestly had the feeling it was so close to a satisfactory solution, but alas ... thanks for all your efforts though it is appreciated. cheers
megi Posted April 1, 2019 Posted April 1, 2019 I've tried looking into it. Mainline u-boot has a reset command, wich triggers a watchdog based reboot, and it just locks up the machine, when the watchdog timeout expires. The same thing simply happens in kernel. Kernel tells ATF to reset, ATF does the same thing as u-boot (watchdog based reset), and the SoC locks up. Presumably, there's some other setup needed on H6 to make the SoC reset correctly. Maybe CPU resets into an incorrect PC adadress. Who knows? I didn't find anything obvious by looking at the reset code in the BSP u-boot/kernel. It will be something less obvious.
martinayotte Posted April 1, 2019 Author Posted April 1, 2019 12 minutes ago, megi said: there's some other setup needed on H6 to make the SoC reset correctly. 12 minutes ago, megi said: It will be something less obvious. What is even less obvious is that using the same 5.0.y kernel branch and same v2019.01 u-boot, the PineH64 reboot properly while other H6s are freezing. I've compared DTs and defconfigs between PineH64 and other H6s and didn't found any obvious differences... EDIT : I've almost forgot : I've compared also schematics, just in case it been an hardware issue, but didn't find any differences there too ...
megi Posted April 1, 2019 Posted April 1, 2019 Maybe setting the register that controls where the CPU starts executing after reset via RVBARADDR register, before triggering the watchdog may help.
martinayotte Posted April 1, 2019 Author Posted April 1, 2019 10 minutes ago, megi said: PineH64 with how much DRAM? 3GB ... Do you mean others boards, like my OPi3 which have 2GB, would reset in bad DRAM region ?
martinayotte Posted April 1, 2019 Author Posted April 1, 2019 1 hour ago, megi said: Maybe setting the register that controls where the CPU starts executing after reset via RVBARADDR register, before triggering the watchdog may help. Since I wasn't aware of those RVBARADDR registers, I've look at the doc and figure out that those have locations at 0x09010040, 0x09010048, 0x09010050 and 0x09010058. I've used "./devmem2 0x09010040 l" which displayed 0x0000000000104108, and then "./devmem2 0x0000000000104108 l" which displayed 0xF2A618A0D2810600. This is the same on all boards, PineH64, OPi3, OPiOnePlus and OPiLite2 ...
megi Posted April 1, 2019 Posted April 1, 2019 3 hours ago, martinayotte said: Do you mean others boards, like my OPi3 which have 2GB, would reset in bad DRAM region ? Maybe, but clearing (BROM should start at 0) RVBARADDR0 prior to reboot did not help make the u-boot reset command work.
martinayotte Posted April 2, 2019 Author Posted April 2, 2019 4 hours ago, megi said: Maybe, but clearing (BROM should start at 0) RVBARADDR0 prior to reboot did not help make the u-boot reset command work. Since my previous "devmem2" test didn't reveal discrepancy about DRAM region, I'm a bit lost about that ... Can I help to try something else ?
martinayotte Posted April 2, 2019 Author Posted April 2, 2019 BTW, @megi , what H6 boards do you have ? If you need some more to narrow the issue, maybe @Igor could arrange that ?
megi Posted April 2, 2019 Posted April 2, 2019 I have Orange Pi 3. I don't think more boards would help me.
martinayotte Posted April 2, 2019 Author Posted April 2, 2019 3 hours ago, megi said: I don't think more boards would help me. A PineH64 could help narrow the issue ... I've just did the reverse diagnostic, trying to boot an OPi3 images on the PineH64 : the "reboot/reset" are working there.
frozeus Posted April 4, 2019 Posted April 4, 2019 The restart seems to be implemented using the Watchdog sure that the WDOG is running ? https://github.com/ARM-software/arm-trusted-firmware/blob/c8b96e4a17038337f97321335e13612ef91878fc/plat/allwinner/common/sunxi_pm.c#L73
frozeus Posted April 4, 2019 Posted April 4, 2019 Hhmmm doesn't fix the issue :'( [ 3.497925] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) still stuck
NicoD Posted April 4, 2019 Posted April 4, 2019 I'm trying to recreate the bootproblem of the PineH64, but no luck. It misbehaves because it behaves. Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 433.232286] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 I've done it many times now. Spoiler nicod@nanopim4:~$ sudo picocom -b 115200 -r -l /dev/ttyUSB0 picocom v2.2 port is : /dev/ttyUSB0 flowcontrol : none baudrate is : 115200 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : yes nolock is : yes send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, Type [C-a] [C-h] to see available commands Terminal ready nicod@pineh64:~$ logout [ 1128.682296] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 37 ms (697.3 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 896 ms (9.3 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 85.556795] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 10 ms (15.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1470 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: nicod Password: Last login: Thu Apr 4 13:20:28 UTC 2019 on ttyS0 ____ _ _ _ __ _ _ | _ \(_)_ __ ___ | | | |/ /_ | || | | |_) | | '_ \ / _ \ | |_| | '_ \| || |_ | __/| | | | | __/ | _ | (_) |__ _| |_| |_|_| |_|\___| |_| |_|\___/ |_| Welcome to ARMBIAN 5.77 user-built Ubuntu 18.04.2 LTS 5.0.5-sunxi64 System load: 1.53 0.39 0.13 Up time: 0 min Memory usage: 11 % of 3003MB IP: 192.168.1.63 CPU temp: 43��C Usage of /: 21% of 15G nicod@pineh64:~$ logout [ 53.028064] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 896 ms (9.3 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 41.524049] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 10 ms (15.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 39 ms (103.5 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1470 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 40.140048] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 41.928056] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 35 ms (736.3 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 433.232286] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 99.959691] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 9 ms (17.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 159.021013] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 10 ms (15.6 KiB/s) 26423 bytes read in 37 ms (697.3 KiB/s) 4155 bytes read in 40 ms (100.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 896 ms (9.3 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... Ubuntu 18.04.2 LTS pineh64 ttyS0 pineh64 login: [ 245.683460] reboot: Restarting system U-Boot SPL 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):682c307 NOTICE: BL31: Built : 17:03:59, Apr 3 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc06ea70, model: Pine H64 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services WARNING: BL31: cortex_a53: CPU workaround for 819472 was missing! WARNING: BL31: cortex_a53: CPU workaround for 824069 was missing! WARNING: BL31: cortex_a53: CPU workaround for 827319 was missing! INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.01-armbian (Apr 03 2019 - 17:04:42 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: Pine H64 DRAM: 3 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 12 ms (247.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 10 ms (15.6 KiB/s) 26423 bytes read in 36 ms (715.8 KiB/s) 4155 bytes read in 41 ms (98.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 8694611 bytes read in 897 ms (9.2 MiB/s) 14436360 bytes read in 1471 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8694547 Bytes = 8.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 497b5000, end 49fffb13 ... OK reserving fdt memory region: addr=4fa00000 size=6c000 Loading Device Tree to 0000000049746000, end 00000000497b4fff ... OK Starting kernel ... I don't know why, it did it yesterday a few times. The crash moment was right before Starting kernel. Then there's only 1 cursor on the screen, and it stayed there multiple minutes. I'll keep trying. The law of TTL? It only does it when you're not watching...
martinayotte Posted April 4, 2019 Author Posted April 4, 2019 4 minutes ago, NicoD said: The law of TTL? It only does it when you're not watching... BTW, make sure that you have "verbosity=7" as well as "console=serial" to get as much as details possible in case you reproduce it.
rufik Posted April 4, 2019 Posted April 4, 2019 Hhmmm doesn't fix the issue :'( [ 3.497925] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) still stuckMaybe nowayout param should be set to 1? I remember that nowayout=0 on H3 just disables watchdog hardware reset as described here: https://www.kernel.org/doc/Documentation/watchdog/watchdog-api.txtThere is some discussion on forum here with H3 CPU, worth to be read.
NicoD Posted April 4, 2019 Posted April 4, 2019 36 minutes ago, martinayotte said: BTW, make sure that you have "verbosity=7" as well as "console=serial" to get as much as details possible in case you reproduce it. How to do that? My google doesn't seem to know, or I ask it the wrong question. I see something of -v, but where to stick that -v... I also tried using putty before, but I can't copy text in Armbian. Any way to do that?
dreddit Posted April 4, 2019 Posted April 4, 2019 Press both mouse buttons at same time to paste to putty terminal if that is what you mean.
NicoD Posted April 4, 2019 Posted April 4, 2019 41 minutes ago, dreddit said: Press both mouse buttons at same time to paste to putty terminal if that is what you mean. Normally yes, but those things don't work. Normally you just select what you want to copy and it's in the clipboard. But I ain't having that on Armbian...
frozeus Posted April 4, 2019 Posted April 4, 2019 I"m quite sure the issue is comming from SCPI and ATF.
martinayotte Posted April 4, 2019 Author Posted April 4, 2019 2 hours ago, NicoD said: How to do that? It is in /boot/armbianEnv.txt ... 1
NicoD Posted April 4, 2019 Posted April 4, 2019 2 hours ago, martinayotte said: It is in /boot/armbianEnv.txt ... Thank you. I again learned something new. It isn't doing it anymore. I've been rebooting the whole day. Not once. Yesterday is was about 25% of the times. I don't know how it's possible. I did upgrade my eMMC image today, but my sd-card image is still not upgraded. So that's not it. I never hated it so much that a device isn't crashing. From now on I'll keep a 2nd sbc running for serial.
frozeus Posted April 5, 2019 Posted April 5, 2019 "IIRC there are 3 watchdogs on the H6. One is the trusted watchdog, which should be reserved for underlying firmware. The other two are the normal and R-block watchdog. Although they look the same, the "normal" one can't reset the system. That one is actually the one ATF currently uses. So reboot doesn't work on the H6. ChenYu" - https://lkml.org/lkml/2019/4/5/425 If it's true it's strange that the reboot works on PineH64...
martinayotte Posted April 5, 2019 Author Posted April 5, 2019 16 minutes ago, froezus said: If it's true it's strange that the reboot works on PineH64... That is why the issue is so weird ...
dreddit Posted April 5, 2019 Posted April 5, 2019 But reboot does work on legacy so there must be a solution even if it's not an elegant one. The legacy fix involves the PH07 but find no reference on the board unless it refers to a gpio pin?
