  2. This SSD thing has been broken for several months. YY3568 is now one of the Armbian recognized boards. Can someone please provide a fix?
  3. Yes, I know about it, but my intention was whether it would be possible to also upgrade the SBC Orange Pi Zero V1 to the newer version of U-Boot
  5. labwc is available in debian trixie: Start with a minimal armbian install Make sure your /dev/fb0 is DRM, not framebuffer $ sudo apt install seatd labwc foot $ labwc -s foot
  6. I found some sample initramfs hooks that might give you some clues how to achieve your goal: https://github.com/simonschiele/initramfs-hooks
  7. 🤩🤪 super , thanks for the information
  8. Yesterday
  9. hcitool does see something, but bluetoothctl still does not $ hcitool scan Scanning ... 41:BB:00:D0:D3:D8 Baseus Bowie WM02
  10. Sorry I did not provide enough info. I am using Debian bookworm, completely updated as far as I know, and it looks like you might be using Ubuntu. Maybe I needed to use bookworm-backports as you suggested; it looks like a newer version there. I've actually found another way to do what I was trying to do with v4l2loopback and don't need it anymore, but thanks for looking at it. Here is some output that you asked for: _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Renegade running Armbian Linux 6.12.32-current-rockchip64 Packages: Debian stable (bookworm) IPv4: (LAN) 10.0.44.17, 192.168.4.254 (WAN) 107.77.207.5 Performance: Load: 50% Up time: 0 min Memory usage: 13% of 968M CPU temp: 36°C Usage of /: 13% of 30G Commands: Configuration : armbian-config Monitoring : htop Last login: Sat Jul 5 20:21:20 2025 from 10.0.44.1 pburt@gato:~$ cat /etc/debian_version 12.11 pburt@gato:~$ apt-cache policy v4l2loopback-dkms v4l2loopback-dkms: Installed: (none) Candidate: 0.12.7-2 Version table: 0.13.2-1~bpo12+1 100 100 http://deb.debian.org/debian bookworm-backports/main arm64 Packages 100 http://deb.debian.org/debian bookworm-backports/main armhf Packages 0.12.7-2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 500 http://deb.debian.org/debian bookworm/main armhf Packages pburt@gato:~$ sudo apt install v4l2loopback-dkms [sudo] password for pburt: Reading package lists... Done Building dependency tree... Done Reading state information... Done The following additional packages will be installed: dkms Suggested packages: menu Recommended packages: fakeroot The following NEW packages will be installed: dkms v4l2loopback-dkms 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 86.0 kB of archives. After this operation, 308 kB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://deb.debian.org/debian bookworm/main arm64 dkms all 3.0.10-8+deb12u1 [48.7 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 v4l2loopback-dkms all 0.12.7-2 [37.2 kB] Fetched 86.0 kB in 1s (119 kB/s) Selecting previously unselected package dkms. (Reading database ... 71668 files and directories currently installed.) Preparing to unpack .../dkms_3.0.10-8+deb12u1_all.deb ... Unpacking dkms (3.0.10-8+deb12u1) ... Selecting previously unselected package v4l2loopback-dkms. Preparing to unpack .../v4l2loopback-dkms_0.12.7-2_all.deb ... Unpacking v4l2loopback-dkms (0.12.7-2) ... Setting up dkms (3.0.10-8+deb12u1) ... Setting up v4l2loopback-dkms (0.12.7-2) ... Loading new v4l2loopback-0.12.7 DKMS files... Building for 6.12.32-current-rockchip64 Building initial module for 6.12.32-current-rockchip64 Error! Bad return status for module build on kernel: 6.12.32-current-rockchip64 (aarch64) Consult /var/lib/dkms/v4l2loopback/0.12.7/build/make.log for more information. dpkg: error processing package v4l2loopback-dkms (--configure): installed v4l2loopback-dkms package post-installation script subprocess returned error exit status 10 Errors were encountered while processing: v4l2loopback-dkms E: Sub-process /usr/bin/dpkg returned an error code (1) pburt@gato:~$ cat /var/lib/dkms/v4l2loopback/0.12.7/build/make.log DKMS make.log for v4l2loopback-0.12.7 for kernel 6.12.32-current-rockchip64 (aarch64) Sun Jul 6 06:20:57 PM CDT 2025 Building v4l2-loopback driver... make -C /lib/modules/6.12.32-current-rockchip64/build M=/var/lib/dkms/v4l2loopback/0.12.7/build modules make[1]: Entering directory '/usr/src/linux-headers-6.12.32-current-rockchip64' CC [M] /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.o /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.c: In function ‘vidioc_querycap’: /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.c:717:9: error: implicit declaration of function ‘strlcpy’; did you mean ‘strncpy’? [-Werror=implicit-function-declaration] 717 | strlcpy(cap->driver, "v4l2 loopback", sizeof(cap->driver)); | ^~~~~~~ | strncpy cc1: some warnings being treated as errors make[3]: *** [scripts/Makefile.build:229: /var/lib/dkms/v4l2loopback/0.12.7/build/v4l2loopback.o] Error 1 make[2]: *** [/usr/src/linux-headers-6.12.32-current-rockchip64/Makefile:1945: /var/lib/dkms/v4l2loopback/0.12.7/build] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-6.12.32-current-rockchip64' make: *** [Makefile:43: v4l2loopback.ko] Error 2 pburt@gato:~$
  11. Are you trying to copy the rootfs of the system you are currently booted into? That won't work. You need to boot a separate installation, the filesystem you want to dd should not be mounted. You didn't really say what went wrong, by the way.
  12. Okay, so I ran a little experiment to verify that it's not about mocp but rather something about the file or file system: $ cp -a /mnt/music/_INCOMING/Malukah\ -\ The\ Dragonborn\ Comes\ \(2017\)/01\ -\ Awake.flac 01.flac Segmentation fault The resulting file contains 9175040 Bytes instead of the expected 9593429, so is truncated. Consequently I also see the corresponding dmesg output parrots what I showed before. So it's about exfat, it appears. Prior to the upgrade did I move the file over to an ext4 partition as well (as I guessed it would be impossible with the 6.12.30-current-sunxi kernel). Copying that around, including _to_ the USB key doesn't seem to cause any issues. I'll see if I am able to figure out how to get the clusters of that particular file. Perhaps it becomes reproducible elsewhere with a (trimmed down) disk image? 2025-07-06_dmesg.txt
  13. This would be very very hard. Would likely take years and would likely never achieve full functionality. If you have access to the source code for the firmware that comes on the device you would have a chance.
  14. Right, judging by only one instance in the topwise a721 dts: [ 3.446799] sun4i-drm display-engine: No panel or bridge found... RGB output disabled I am inclined to think that is configuring the panel. This can be validated by checking ls /sys/devices/platform/display-engine/drm/card0 or looking for simple-panel in lsmod. I suspect it may be a pin-muxing issue where the pins are not being set. now what these are set depends on the lcd panel type which could be LVDS or a parallel panel. I believe it should be LVDS but just wanted to confirm. Now the A10's pin controller section within the dtsi does not map out as many function compared A20 dtsi, so within the topwise a721 dts under the pio node the display pins need to be declared and their function stated. Secondly attach the pin control handle to tcon0. For example: &pio { lvds0_pins: lvds0-pins@0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9"; function = "lvds0" }; }; &tcon0 { pinctrl-names = "default"; pinctrl-0 = <&lvds0_pins>; };
  15. I can do that but it does not provide any useful information on the subject in my opinion. Is there a way to downgrade to 25.8.0-trunk.313? According to this post, it might be useful to set the kernel option nvme_core.default_ps_max_latency_us resp. the DT overlay parameter pciex1_gen=3. How can the kernel (cmdline) option be set in Armbian? Regarding the DT overlay parameter pciex1_gen, should I follow this part of the documentation?
  16. So, there is nothing more we can do here I think. Wait for rockchip to correct upstream.
  17. The issue appears to be two things. These two patches and the current defconfig(s) being used. drv-rtc-sun6i-support-RTCs-without-external-LOSCs.patch drv-rtc-sun6i-Add-Allwinner-H616-support.patch When I disable those patches and use my own defconfig everything works as it should. https://paste.armbian.com/tixixocubu The hard part here would be figuring out exactly what in the defconfig(s) are either breaking things or missing. Also if I disable those patches, what does it break on other units? I'm under the impression these patches were rejects from the original h616 bring up in mainline. But I could be wrong?
  18. If you need hdmi support use vendor or edge kernel. 6.12 was released with a bare minimum of support for rk3588 so nonworking hdmi is kind a expected.
  19. I added a patch that activates the gpu. https://lore.kernel.org/linux-sunxi/20250706025625.2707073-1-iuncuim@gmail.com A ready to install kernel is available for manjaro. But it's worth realizing that without output it will be useless at the moment.
  20. I've gone round in circles with this one and it seems that there might not be a solution, so will set it up again on the NVME drive. Thanks for all the help offered.
  21. Last week
  22. Pull Request submitted: https://github.com/armbian/build/pull/8360
  23. I hadn't done an upgrade but a fresh install; (v25.5.1 for Raspberry Pi 3 Model B running Armbian Linux 6.12.28-current-bcm2711) Realised that I had the same problem, only channel 2 was present; though I only realised something was missing when I'd tried RaspberryOS on a Pi Zero with the same i2c device. Adding to the /boot/config.txt didn't of itself solve the issue; adding the i2c1 to the armbian-config overlays also didn't see. However I did find the `/boot/firmware/config.txt` that has a lot more settings, and seems to be where armbian-config edits Note the `dtparam-i2c_arm=on` line... which was commented out. Adding that back and it works... (well after figuring out I needed to level shift the i2c device but that's another story) # For more options and information see # http://rptl.io/configtxt # Some settings may impact device functionality. See link above for details # Uncomment some or all of these to enable the optional hardware interfaces dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # .. dtoverlay=dwc2 i2c0 i2c1 i2c-gpio vc4-kms-v3d
  24. Remote backup maybe only as data ... e.g. restic / rsync programs In my opinion it is best to make a backup of the SD card in linux connect miniSD card and make a backup in terminal: fdisk -l if your SD card is: sda / sda1.... then choose sda ! and then make a backup: dd if=/dev/sda of=/path_to_backup.img status=progress Restoring the image to the SD card with the same size: dd bs=4M if=/path_to_copy.img of=/dev/sdb status=progress If you want to burn the image to a smaller capacity SD card because, for example, the system is only 30% occupied, use the program:PiShrink https://github.com/Drewsif/PiShrink it works great for me for Armbian 🙂 sudo pishrink.sh /path_to_backup.img / /new_backup-Pishrink.img
  25. I use the Station M2 image with dtb joined. Adapt fdtfile entry in /boot/armbianEnv.txt as needed. rk3566-box-demo_x96x6_24-custom.dtb
  26. please show the output of "apt policy zfs-dkms" but essentially, this looks the same as your other rodeo/struggle with this board and dkms. As mentioned there, you are much better off with btrfs instead of zfs on your SBC.
  27. I confirm that this repository ffmpeg works for me: * Orange Pi Zero 3 * self built image with Debian Trixie and Xfce desktop * Linux Edge 6.15.0 * Login in Xfce X11 mode * follow all the instructions in original post * mpv plays most mp4s VERY SMOOTHLY * some resolutions will crash mpv with "Segmentation Fault" and cause a kernel crash shortly after Then, to make it work with an ili9488 LCD, I needed to change these: * install LCD DTS, firmware, remove plymouth (see my ili9488 thread) * I can't make X11 work with my LCD driver and panel-mipi-dbi-spi recently... (still investigating why it worked before) * but I can make it work with labwc and sway * install seatd (authorization library), labwc (I only have experience with labwc) and foot (wayland terminal) * Choose labwc instead of xfce in lightdm login * from SSH session: DISPLAY=:0 foot& * in foot: mpv videofile.mpv * it plays most mp4s VERY SMOOTHLY * some resolutions will crash mpv with "Segmentation Fault" and cause a kernel crash shortly after
  28. Whatever garbage ones I can find on ebay for cheap. In this case: KIOXIA 256GB SSD BG5 M.2 2230 NVMe PCIe Gen4 x4 KBG50ZNS256G https://www.ebay.com/itm/176432690192
  29. Good to meet a fellow armbian android tv box fan. We need a logo or shorthand alias for fans 🤣. ZFS - was easy but not clear. Inside armbian-config under System/Storage is a script to install ZFS support. I did this and it didn't work... then undid it and then installed it a second time and it worked. Somewhere in there I also ran the standard commands for install: sudo apt install zfsutils-linux sudo apt install zfs-fuse Probably after the first uninstall... but the commands indicate failure. But then installing the second time seemed to work. Did that on both of these boxes I have working. Thanks for the ethtool command. Here's my results on box1 ports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown netlink error: Operation not permitted Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes Not an expert and first time reading this command but looks like 1000 is the answer. Crazy thing - box 2 does not have the line "MDI-X: Unknown" shown towards the bottom and "Port: MII" instead of "Port: twisted pair" but is otherwise identical. Posting in case it helps anyone else - but these are beyond me. If you confirm that the above = 1000 I will update both my box running posts. By the way - Another favorite is Software/Management/Cockpit. Easy to see how the server is doing. Plus it has a built in terminal and file manager. Add that to Tailscale and you can check on the server or grab a file while out of the house. curl -fsSL https://tailscale.com/install.sh | sh Those are my favorites. What are yours?
