I tried various parameters when mounting and unmounting, such as: sudo umount -f /media/..., but the system still hangs. You can't connect to the device via SSH in a new session. If you force a reboot (or sudo systemctl poweroff ) without unmounting it, it won't happen, and you won't be able to connect via SSH. Physically disconnecting the cable also doesn't help.
@djoness Can you share your MiniArch-20231112-6.6.2-board-h313.x96_q-SD-Image.img on Cloud,or Send me email(lq007lq@gmail.com). Because The owner's github update, The old version has been overwritten.
@iav nice. Yeap. One fixes topology and the other pcie performance. Tested on the BananaPi BPI-CM4
As a reminder: earlier this year, WDR_s had success with the waveshare 9486 LCD, with the ili9341 driver, but that was the fbtft old style driver. https://forum.armbian.com/topic/46824-orange-pi-zero-3-ili9486-tft-lcd/#findComment-213110 I can't remember whether someone used the adafruit ili9341 driver (DRM) for the Waveshare ili9486/9488 LCD... anyone remembers?
Hello: To compare all available use of this so great card, we could share our uses. For me i se it with : -OpenMediaVault for the NAS function; as file copy save and Torrent -Transmission for the torrent sharing -2 HDDs to save files on USB 3 and 2. And you ? I have a Rock64 1Gb with external power station 5A power
The HDMI0(Port next to Headphone Jack) is driven by DP1 on rk3588 via RA620(a dp2hdmi converter). https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/arch/arm64/boot/dts/rockchip?h=v6.18&id=07c53a9e970712b1a479dd0ec4adfe184482c22f ROCKCHIP_DW_DP is needed in order to have working 2nd HDMI port. In menuconfig : Device Drivers ---> Direct Rendering Manager (XFree86 4.Graphics support ---> 1.0 and higher DRI support) ---> Rockchip specific extensions for Synopsys DW DP <pre> │ CONFIG_ROCKCHIP_DW_DP: │ │ │ │ This selects support for Rockchip SoC specific extensions │ │ to enable Synopsys DesignWare Cores based DisplayPort transmit │ │ controller support on Rockchip SoC, If you want to enable DP on │ │ rk3588 based SoC, you should select this option. │ │ │ │ Symbol: ROCKCHIP_DW_DP [=n] │ </pre> https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/arch/arm64/boot/dts/rockchip/rk3588-extra.dtsi?h=v6.18&id=64566e35757faded57a65d65e84b5ca95974ee19
By helping cleaning gigantic Allwinner patchset so we can upgrade it to 6.18.y and merge already prepared Cubie a5e https://github.com/armbian/build/pull/8831 Then it become easier.
how to install armbian on mx10 f3 (tv stick)?
Nick A replied to Maxim Shell's topic in Allwinner CPU Boxes
@Maxim Shell it’s possible to boot using USB OTG. You’ll need the latest u-boot. You can use my mainline build. Not sure if your stick has secure boot enabled. You can remove the secure boot patches if you don't need it. https://github.com/NickAlilovic/build/tree/mainline/patch/u-boot/u-boot-mainline git clone https://github.com/NickAlilovic/build.git --branch mainline cd build ./compile.sh build BOARD=transpeed-8k618-t BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED=browsers DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base EXTRAWIFI=no KERNEL_BTF=no KERNEL_CONFIGURE=no RELEASE=bookworm https://linux-sunxi.org/FEL/USBBoot#Mainline_U-Boot_.28v2015.04_and_newer_versions.29 build/cache/sources/u-boot-worktree/u-boot/v2025.10/spl/u-boot-spl.bin You can mount the compiled image to get the other files. sun50i-h618-transpeed-8k618-t.dtb uImage boot.scr I haven't done this before. Let us know how it works out for you. -
KickPi K2B not booting up: DRAM setup not supported
c0rnelius replied to chuanzz's topic in KickPi K2B
Short of KIckPi opening a contract with Armbian and providing the units they want worked on. I don't see how? -
Hello! I'm so glad you responded! I've been trying to reflash this device for three days. Unfortunately, the behavior after reflashing is always the same: the red LED lights up, goes out after 15-20 seconds, and the device no longer shows any signs of working. I've reflashed the device about 50 times with different settings. And of course, I checked the "Write to address" box. I built the firmware from your git - https://github.com/vidplace7/armbian-build/tree/luckfox-lyra-ultra I also built the firmware from the Armbian office git. There were no errors during the build. I've built the firmware from Debian and Ubuntu. I've also tried various methods (again, I've been trying to reflash the device for three days now). I'm desperate. Would you be so kind as to post the firmware that works 100% for you and tell me how to flash it correctly? I'm pinning all my hopes on you!
There's no problem of course, I just did not have time for testing the built image yet, and was asking if it's not pointless. Thanks for the response so far, I'll try... As far as I understand it, the device tree from the vendor kernel won't work on mainline and I have no clue how to point armbian to the proper one. Maybe I'll just try removing the line about fdtfile from armbianEnv.txt lol
External HDD not detected after reimage
Valentin B replied to Valentin B's topic in Amlogic CPU Boxes
Yeah I ended up ordering a refurbished office mini pc, might repurpose the android box for something else down the line, like a pihole or something. Moved the plex server to my desktop and running it like that atm. That was pretty much all I was using the box for. Thanks a lot for all the help! -
Orange Pi Zero 3 Sound Problem(Lineout-Analog Codec)
Werner replied to Taha YILDIRIM's topic in Allwinner sunxi
moved -
It looks like the training of AI bots is getting to a stall. Anyway, a knowledgeable contributor does not feed the bots. Instead, they judge if the info from the bot can save their life. Will this bot come to my house with food for free and put it into my mouth. Asking the bot to give money first might look a good first thing to do, but it isn't. Even if real coins or paper and not bank transaction.
John Taylor replied to SteeMan's topic in FAQ
Disk genius in my case reveals there is NO FAT32 boot partition, hidden or otherwise, only a root partition. -
Good to know. I'm interested in getting the red LCD's to work as they are cheaper and more available, I purchased the waveshare only to test my SPI, SBC, and DTS formatting were functional. Now that I confirmed how to translate DTS to work with my SBC, I can work on the red ili9486/8 without worrying about it being a formatting issue. - Last week
I downloaded 'Armbian_25.11.2_Odroidc2_trixie_current_6.12.58_minimal.img.xz', flashed it to sdcard, and it booted fine. As a sidenote unrelated to the issue at hand, my first try was with the sdcard on a device with emmc, and in this case the boot process stopped after block-local (?), and dropped to initramfs shell prompt.
Brillant, eselarm! I followed your suggestion to avoid USB-adapter issues and took my quite old laptop with a MCC/SD slot. Run fsck -fn /dev/mmcblk0p1 - no errors! As you suspected, the USB-adapter is at fault! I grabbed all SD-USB adapters I collected over the years and tried them. Different results, fsck without errors using few of them. My lesson lerned is: NEVER TRUST A USB-SD ADAPTER! The strange thing however is, that using this faulty adapter (14cd:1212 Super Top microSD card reader (SY-T18)) some images like Armbian_25.8.1_Rockpi-e_noble_current_6.12.41.img fsck'ed OK. I think all my adapters can cope w/o problems with simple, more or less sequntiell, reads/writes. It's what they do most of the time. I guess, when it comes to more complex I/O operations requested by fsck, some of them give out. What eselarm also suggested. Just for reference, the bad ones: 2 x 14cd:1212 Super Top microSD card reader (SY-T18) 5136:4678 Generic USB2.0 Device aaaa:8816 MXT microSD CardReader The OK ones: two with this inside: 090c:6200 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) microSD card reader and 14cd:127b Super Top SDXC Reader (very old, labeled hama) Thanks and regards, Chris
Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + proton-10.0-3-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/download/proton-10.0-3/wine-proton-10.0-3-amd64-wow64.tar.xz) + DXVK-stripped v2.6.2 >=60fps@1080p Yu-Gi-Oh LOTD Evolution -
@Gavin Munday Try these images. Extract them first before you write to the SD card. https://github.com/NickAlilovic/build/releases/tag/Radxa-a7a-v0.3
@fedes_gl To list USB speeds, do You will get an output like: 480M is the important part, this is is usb2.0. for USB3.0 you will see 5G or 10G for 3.1 Also check your ethernet port speed with: (replace end0 with your ethernet device) And if im not mistaken, those are my 2 issues with this image: only usb2.0 and network speed of 100mbps. Making it similar to a 5 years old device.. Let me know if you found the same speeds. -
@Phi Hùng Nguyễn that link looks nothing like Armbian. You shouldn’t install it on your tv box. Try my build it's unofficial Armbian but I provided source code. So you know what you are installing on your tv box. You can build it yourself if you want to. https://github.com/NickAlilovic/build/releases/tag/20250306
Alright. Trust sacrificed. BTW, I am a 71yo real estate developer, which may explain my stupidity with coding, my not being able to ascertain streams of consciousness, nor plumb huge gaps in information. I would like to get some things done with the N2+, and the answer is Armbian is obviously not the way to do them. I have much bigger things to do than bit-twiddling. PS - NTPd doesn't fix time either.
