  2. Then I don't know why it does not work, and I would assume this combination of SBC and NVME just won't work. Such cases exists, although frustrating that is does not work. You could cross check, but I don't know it you have other brands NVME to try with the OPi5 Ultra. I would also be not surprised if there is simply something wrong of missing in the U-Boot or DTB (all versions, even the one from manufacturer/xunlong). You can look at versions history of U-Boot for example, just to see how much your luck is or would be. And/or until someone with the same combination sees this topic. I only have Samsung NVME's. primarily 970+ in a ROCK5B, is also RK3588 4-lane PCIEv3 and older earlier 970 in an ROCK3A (2-lane PCIEv3). The latter one works but only with a very specific set of U-Boot, BTB and kernel (for my use case).
  3. Introduction This guide describes a tested method for running Android, Armbian, and Ubuntu on the same NVMe SSD of the Orange Pi 5 Plus. This is not an official Orange Pi installation procedure. The entire workflow was developed through extensive real-world testing. The following configuration has been successfully verified: ✅ Android boots from the NVMe SSD. ✅ Armbian boots from the same NVMe SSD via UEFI. ✅ Ubuntu boots from the same NVMe SSD via UEFI. ✅ All three operating systems coexist on a single NVMe SSD. ✅ Armbian and Ubuntu share the same EFI partition. ✅ Android, Armbian, and Ubuntu can share a common data partition. 1. Requirements Hardware Orange Pi 5 Plus. An NVMe SSD (the larger the better, and it must have a larger capacity than the eMMC to provide free space for Armbian and Ubuntu). A 16GB or 32GB eMMC module (16GB recommended). A microSD card for UEFI. A PC/Laptop or an NVMe USB enclosure for partition management. A microSD card can also be used instead of eMMC for Android, but a large-capacity card is not recommended because it reduces the available space for Linux on the NVMe SSD. Software Android ROM (tested and verified; the AGTV ROM can be flashed directly to the eMMC using rkdeveloptool). Armbian. Ubuntu. UEFI image. BalenaEtcher, Rufus, or any software capable of writing IMG files to a microSD card. A partition manager such as GParted, DiskGenius, or MiniTool Partition Wizard. 2. Boot Method Android Android uses the standard Rockchip boot process. Requirements: The SPI flash must be empty or completely erased. Android boots directly from the NVMe SSD. Armbian and Ubuntu Armbian and Ubuntu boot through UEFI. Write the UEFI image to a microSD card. Insert the microSD card whenever you want to boot Linux. Both operating systems share the same EFI partition on the NVMe SSD. 3. NVMe Partition Layout The NVMe SSD contains two groups of partitions. Android Keep all Android system partitions intact, for example: boot vendor_boot dtbo vbmeta super metadata userdata ... Do not modify any Android system partition. Linux Create the following additional partitions: EFI Armbian RootFS Ubuntu RootFS Data The Data partition can be shared between Armbian and Ubuntu. 4. Preparing Android Flash Android to the eMMC. Boot Android and verify that everything works correctly. Boot Armbian or Ubuntu from a microSD card or an external SSD (this Linux installation will later be used to copy its RootFS to the NVMe SSD after partitioning). Back up the entire eMMC using the dd command. Restore the Android image from the eMMC to the NVMe SSD using dd. After this step, the NVMe SSD will contain the complete Android partition layout. Since the NVMe SSD is larger than the eMMC: The beginning of the NVMe SSD will contain all Android partitions. The remaining space will remain Unallocated, which will later be used for the Linux partitions. Next, erase all data on the eMMC and remove the eMMC module from the Orange Pi 5 Plus. Then power on the board and verify that Android boots successfully from the NVMe SSD. This confirms that the system is running entirely from the NVMe drive rather than from the eMMC. 5. Creating Space for Linux Keep all Android partitions unchanged. Using tool on either Windows or Linuxuse the Unallocated space located after the Android partitions, create the following partitions: EFI (used to boot Armbian and Ubuntu through UEFI) Armbian Ubuntu Data 6. Installing Armbian Restore or copy the Armbian RootFS to the Armbian partition on the NVMe SSD. Copy the EFI boot files to the EFI partition. Update the UUIDs if necessary. Verify that Armbian boots successfully through UEFI. 7. Installing Ubuntu Restore or copy the Ubuntu RootFS to the Ubuntu partition on the NVMe SSD. Copy the EFI boot files to the EFI partition. Update the UUIDs if necessary. Verify that Ubuntu boots successfully through UEFI. 8. Booting the Operating Systems Boot Android Remove the microSD card containing the UEFI bootloader. Make sure the SPI flash is empty. [7/10/2026 10:56 AM] Vũ Minh Tâm: The Orange Pi 5 Plus will boot Android directly from the NVMe SSD. Boot Armbian or Ubuntu Insert the microSD card containing the UEFI bootloader. Select the desired operating system from the UEFI boot menu. The selected Linux system will boot from its corresponding partition on the NVMe SSD. 9. Current Status The following configuration has been successfully verified: ✅ Android running from the NVMe SSD. ✅ Armbian running from the NVMe SSD. ✅ Ubuntu running from the NVMe SSD. ✅ Armbian and Ubuntu share the same EFI partition. ✅ Android, Armbian, and Ubuntu can share a common Data partition (NTFS is recommended). ✅ Switching between Android and Linux only requires inserting or removing the microSD card. 10. Notes This method has only been tested on the Orange Pi 5 Plus. It is based entirely on real-world testing and is not an official Orange Pi installation procedure. Some adjustments may be required when using different firmware versions, bootloaders, or hardware revisions. It is strongly recommended to back up both the eMMC and the NVMe SSD before modifying the partition layout. 11. Discussion If you have successfully implemented a similar setup or know of a simpler approach, feel free to share your experience. Any suggestions or improvements are welcome and will help make this guide even better.
  4. Unfortunately, Link Star H68K is not one of the supported boards. Hinlink H68K is Community Maintained and is provided as-is with no guaranteed support and no any maintainer listed. If you can figure out what is different in the bootloader and device tree, you should be able to adapt what is in the Hinlink H68K build configuration.
  5. Yesterday
  6. Or probably the easier way is to edit /etc/default/armbian-zram-config
  7. I want to get an sbc to make personal server running website with backend for me, so basically JS, Python, and other stuff. I also want to connect my microcontrollers like esp32 to make my custom smart home system, by using camera. Maybe i also could use AI to analize the image. I found one Banana pi M3(2gb ram) for under 10$, so i am thinking whether to buy it. I feel like the deal is great since i can't find other sbcs with such hardware, ram to be specific, but i heard that software support is bad. Is that true for now? Or is it usable? I am also thinking of getting Orange pi one plus(1gb ram), but it costs more and also has less ram. What should i do?
  8. I'm getting the same serial output stopping in the same place on my board: https://github.com/yisding/rock-5b-ysp/blob/main/findings/2026-07-09-rock5b-armbian-sd-boot-investigation.md Both zeroed out SPI and working (26.5.1) SPI don't boot. Got it to spin up HDMI by dd-ing over some new 26.5.1 bits over to the SD card but still not quite working. Good news is that 26.5.1 Ubuntu 26.04 does boot, and it also has a package for the 6.1 vendor kernel which boots also. I'm sure there's going to be some kernel/userspace mismatch between 6.1 and 26.04 so I've been "vibe-porting" the hardware encoding/decoding drivers to 6.18. Not quite ready yet for distribution, although it does work with ffmpeg and makes gnome-remote-desktop run silky smooth.
  9. Just managed to distract myself some more in this outrageous heat here in the UK and can confirm that the RELEASE=stable (6.18) build (from compile.sh) boots ok after some tweaking. It got stuck on "Starting Kernel" but when I added these lines to /boot/armbianEnv.txt to see why it failed, then it booted ok - dunno why. I think keep_bootcon was the important bit. extraargs=earlycon=uart8250,mmio32,0x02500000 keep_bootcon ignore_loglevel loglevel=8 The other problem then was getting the ethernet to work which I did by creating a device tree overlay file - much the same as other here is it only seems be working at 100M unlike the 1000M in the 5.15 kernel. The extra problem seemed to be that the wifi driver would periodically crash and cause a kernel-panic. The following DTS file pulls the ethernet down to 100M and disables the wifi to stop it crashing. You then compile this into a .dtbo file, copy it to /boot/overlay-user and reference it in armbianEnv.txt with this line user_overlays=opi4a-network-fix The opi4a-network-fix.dts syntax to create it is as follows ... apart from that I can't get it to do much more, so will go down the 5.15 bookworm route until things change /dts-v1/; /plugin/; / { compatible = "xunlong,orangepi-4a", "allwinner,sun55i-t527"; /* Maintain working Ethernet at 100M address 1 */ fragment@0 { target-path = "/soc/ethernet@4510000"; __overlay__ { phy-mode = "rgmii-id"; phy-handle = <&ext_rgmii_phy>; status = "okay"; mdio { #address-cells = <1>; #size-cells = <0>; ext_rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; max-speed = <100>; }; }; }; }; /* Hard disable the unstable wireless MMC controller block */ fragment@1 { target-path = "/soc/mmc@4021000"; __overlay__ { status = "disabled"; }; }; };
  10. Comprehensive Guide: Installing Armbian on the TX10 PRO (Allwinner H313) Introduction This technical guide documents the complete process for deploying Linux on the TX10 PRO Android TV Box (Allwinner H313). Due to hardware variations and kernel compatibility issues common on these devices, establishing a functional Armbian environment requires specific images, DTBs, and configuration steps. This documentation is designed to streamline the installation process and avoid common hardware compatibility problems. Technical Specifications & Environment The procedures in this guide were validated on a TX10 PRO with the following hardware: Component Specification ---------------- ----------------------------------- SoC Allwinner H313 (sun50iw9p1) CPU Quad-core Cortex-A53 (ARM64) Memory 1 GB LPDDR3 (Samsung eMCP) Storage 8 GB eMMC Board Revision WFTECH_V2.0 Device Codename titan-p1 Product walley Stock OS Android (Modified Build) Bootloader U-Boot Tested Kernel Linux 6.12.64 (bookworm) Tested working image: Armbian-unofficial_26.02.0-trunk_X96q-v1-3_bookworm_current_6.12.64_minimal.img.xz Kernel: Linux 6.12.64 bookworm Base OS: Debian Bookworm Server Target: X96Q DDR3 / Allwinner H313 Although this image is labeled for the X96Q DDR3, it successfully booted on my TX10 PRO with the WFTECH_V2.0 board and Allwinner H313 SoC. Hardware revisions vary, so compatibility with other TX10 PRO units is not guaranteed. ⚠ Crucial Hardware Warning TV box manufacturers frequently change internal components (RAM layout, Wi-Fi chipsets, and board revisions) without changing the product name. Always verify your board revision before proceeding. Using the wrong Device Tree Blob (DTB) can result in an unbootable system. Advantages & Disadvantages of Running Linux Advantages: Cost Efficiency Much cheaper than a Raspberry Pi or other SBC. Enclosure Included Comes with a case and power supply. Low Power Consumption Runs quietly with very low power usage, making it suitable for lightweight servers. Disadvantages: No Official Support Linux support depends entirely on community-maintained images. Thermal Throttling Cheap passive cooling causes overheating during heavy workloads. Weak eMMC Storage Internal storage may wear out under frequent writes. Slow I/O USB ports are usually USB 2.0 only. No SATA, NVMe, or native Gigabit Ethernet. Driver Problems Wi-Fi, Bluetooth, and hardware video acceleration usually require manual setup. Prerequisite Hardwares: MicroSD Card (8GB or larger) MicroSD Card Reader (Cost: 0.45 USD ) HDMI Monitor (Tv) USB Keyboard Ethernet Adapter Integrated Wi-Fi rarely works immediately on bookworm Linux. A wired Ethernet connection is strongly recommended for initial setup. Installation Process Step 1 — Download Armbian Official Armbian images generally do not include all hardware support for the H313. Download a trusted community image designed for Allwinner H313/H616 boards using the 6.12.64 kernel. USE THIS: Armbian-unofficial_26.02.0-trunk_X96q-v1-3_bookworm_current_6.12.64_minimal.img.xz Step 2 — Flash the SD Card ⚠ Warning Avoid using the Linux dd command if you are unfamiliar with it. Selecting the wrong drive can permanently erase your computer. Instead, use BalenaEtcher. Flashing Steps: Install and open BalenaEtcher. Insert your MicroSD card. Click Flash from File. Select the downloaded .img.xz image. Click Select Target. Choose your MicroSD card carefully. Click Flash! Wait until flashing and verification reach 100%. Safely eject the card. Step 3 — Hardware Setup Before powering on: Insert the MicroSD card. Connect HDMI. Connect USB keyboard. Connect USB Ethernet. Connect power. Step 4 — First Boot The first boot performs: Filesystem expansion Initial setup System configuration This may take several minutes. Expected boot sequence: U-Boot ↓ Linux Kernel ↓ Armbian Login Prompt Step 5 — Initial Login Default credentials: Username: root Password: 1234 After logging in you will be required to: Change the root password Create a normal user Configure timezone Configure locale Step 6 — Verify Network Built-in Wi-Fi will probably not work. The board uses the SSV6x5x / SV6256 chipset which requires extra drivers. Verify Ethernet: ip a ping -c 3 1.1.1.1 Step 7 — Update the System Enable network time: sudo timedatectl set-ntp true Then update: sudo apt update sudo apt upgrade -y Step 8 — Install to eMMC (Optional) Once everything works from the SD card: sudo armbian-config Navigate to: System ↓ Install ↓ Boot from eMMC Follow the installer. After completion: Shut down Remove the SD card Boot from internal storage Hardware Compatibility Working - perfectly HDMI Output USB Ports USB Ethernet Known Issues Wi-Fi - Not working Requires manual compilation of the SSV6256 driver. Graphics No hardware acceleration. Software rendering only. DTB Compatibility Boot success depends heavily on selecting the correct DTB. Different board revisions may require different DTBs. Best Practices Test from SD First Never install to eMMC before confirming that everything works. Backup Android Create a backup of the original Android firmware before modifying internal storage. DTB Troubleshooting If the device: Boot loops Shows a black screen Fails to boot Mount the SD card on another computer. Open: armbianEnv.txt Try different H313/H616 DTB files until the system boots successfully.
  11. cal5582
    just need to enable device drivers >graphics support> direct rendering manager> AMD GPU device drivers >graphics support> direct rendering manager> Noveau (nvidia) cards device drivers >graphics support> direct rendering manager> Intel Xe2 Graphics in the config
  12. Last week
  13. Board Enabling PR: https://github.com/armbian/build/pull/10154 Build Log: https://paste.armbian.eu/garowadifa Board Log: https://paste.armbian.com/ijefusiqun
  14. Hello, Same issue with debian trixie and my UPS connected by usb, not working but work on old kernel.
  15. You can try to short the EMMC that wasn't connected, to short the CLK and GND of the soldered EMMC also check this points to:
  16. Is it possible to enable jumbo frame on any ethernet interface of Orange Pi RV2. My attempts to set mtu > 1500 are going to fail. The kernel is not support this. I use Ambian based Debian 13 ( current 6.18.35 ). By the way, network controller support Jumbo up to 18K.
  17. Hi I need assistance with my TV98 box. It is stuck on the android screen. I need firware
  18. Good that your bpi appears to be stable. My did hang again, no reaction on serial console, no reaction on IP networking. So I enabled the watchdog, uncommented the 'ping 192.168.1.1 line' and made it ping 192.168.1.100 and temporarily added that address to another computer: ip addr add dev br0 192.168.1.100/24 Then removing it: ip addr del dev br0 192.168.1.100/24 and after a minute or so: [ 263.929336] systemd-journald[236]: Received SIGTERM from PID 1071 (watchdog). [ 265.185973] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE) [ 265.221538] systemd[1]: Detected architecture arm. [ 269.100327] systemd[1]: Failed to fork off sandboxing environment for executing generators: Protocol error [!!!!!!] Failed to start up manager. [ 269.146571] systemd[1]: Freezing execution. This looks like HW watchdog does not work. Same trick on NanoPi-NEO, so also sunxi kernel although 7.0.12-edge-sunxi, it resets. So appears to work although no proof that it is HW reset. I have not checked live dmesg or so, just noticed it went offline and came back later when I also added that .100 IP address again.
  19. If you use and Armbian image with kernel '6.1.115-vendor-rk35xx' (note there are many builds over time, all same name, but you need to look in config-6.1.115-vendor-rk35xx and maybe also consider the gcc compiler version to have RKMPP based method working. I mean the API is there, you need a special ffmpeg (from jellyfin for example to use it) in order to use RKMPP based decoding and encoding in HW. That is just CLI, server use-case, works on RK3568 and RK3588. RK3576 should have the same speed/ASIC blocks as RK3588 AFAIK, but check yourself. It can do 5x realtime speed 1080p50 HEVC to H264. mpv 'uses open and agreed standards' and RKMPP is not. Also Android is completely different. Same is Windows or Apple iOS. Those are implemented by commercial/paid developers. In fact it is worse, ffmpeg open-source developers have concluded already long time ago the Rockchip downstream kernel code was copied and violates licenses. (Rockchip copied code and put their names in it.). So since a few months, ffmpeg developers requested github to remove access and that happened. So following GPL licensing, that 6.1.115 kernel is essentially illegal. How you want to deal with that is up to you. It is like it is. Anyway, 6.1.x downstream is getting old and might contain several unpatched security holes. So over time the 'problem' will solve itself as people won't trust it anymore despite being able to use every HW block in RK35xx. As already said, decoding generally is implemented as part on mainline kernel, you just need matching latest userspace. Encoding is much more complex. If you want that, only Intel/AMD is more or less viable option. Like N100, so in cheap miniPCs, certainly considering high RAM prices, is just a way better option. Plays all HW accelerated in FireFox (and mpv as well). Does also VP9 encoding for example, is a royalty free codec, so you won't see this 2 decades old patents issues for H264 and HEVC. Also note AV1 HW decoding was the first to be available in mainline kernel for RK3588. There is just not much content I think. And HW AV1 encoding is another level of new silicon, is not really an option to do in software.
  20. # cat /etc/NetworkManager/system-connections/br0.nmconnection [connection] id=br0 uuid=75d54cd2-cdfe-4621-ab45-0bddf3ab4e6c type=bridge interface-name=br0 zone=trusted [ethernet] cloned-mac-address=my eth0 mac address [ipv4] method=auto [ipv6] addr-gen-mode=default method=ignore # cat /etc/NetworkManager/system-connections/eth0-br0_slave.nmconnection [connection] id=eth0-br0_slave uuid=31645756-5c39-4184-a0c2-337ae09422ec type=ethernet interface-name=eth0 master=75d54cd2-cdfe-4621-ab45-0bddf3ab4e6c slave-type=bridge # cat /etc/NetworkManager/system-connections/wlan0-br0_slave.nmconnection [connection] id=wlan0-br0_slave uuid=4ff7f9f2-056e-4836-9bc7-0e77d98a989c type=wifi interface-name=wlan0 master=75d54cd2-cdfe-4621-ab45-0bddf3ab4e6c slave-type=bridge [wifi] band=bg channel=1 mode=ap ssid=mywifissid [wifi-security] key-mgmt=wpa-psk proto=rsn; psk=mypassword template, stripped, optimized, cleaned, untested
  21. The nand-sata-install script is indeed quite old and not very actively maintained anymore. A common modern replacement on Odroid XU4 (and similar boards) is to use the Armbian installer built into armbian-config. You can run: Bash sudo armbian-config Then go to System → Install (or Install to SATA/USB/NVMe depending on your setup). Many people find it more reliable than the old nand-sata-install. Alternatively, you can do it manually with dd for U-Boot + rsync for the rootfs, but armbian-config is usually the easiest route these days. If you run into any issues with it, feel free to share the output and I can help walk you through it.
  22. So i had figured out how to get the root shell access on this specific type of box(fx6), and unfortunately, nope. You cant run any other os than the official firmware linux(buildroot) because of secure boot and locked bootloader(nope, you can't unlock it with fastboot). But, you can use chroot to run ubuntu or another os. Heres some images for proof. So, you cant run armbian, have to stick with buildroot, you can modify it the way you like with root permission, just dont modify the root parttion, if you do, it wont boot and it will be bricked
  23. AI development is shifting from implementing models from scratch to composing powerful capabilities via APIs, enabling developers to integrate speech recognition, language models, and tool execution into useful applications with far less effort. View the full article
  24. This week's cycle emphasizes broad U-Boot modernization, new board and SoC enablement, and kernel and wireless driver consolidation. A large-scale U-Boot bump moves sunxi 32-bit and 64-bit targets from v2024.01 to v2026.07-rc4, with follow-on updates for self-pinned H616/H618 boards (Zero2W, Zero3, Longan Pi 3H), Mixtile Edge2, NanoPi R5S (now patch-less), and the Youyeetoo YY3588 switching to mainline v2026.04. The imx6 line (UDOO, Cubox-i) was modernized to U-Boot v2026.07 with legacy 6.12, current 6.18, and edge 7.1 kernels. Related toolchain work fixes ODROID-C1, ODROID-XU4, Recore, and X96Q builds under Trixie's GCC 14, and resolves errexit failures on Rockchip SPI boards. Platform expansion introduces community support for the Allwinner A733-based Radxa Cubie A7Z and Orange Pi Zero 3W, Rockchip Graperain G3568 v2, and Anbernic RG Vita Pro and Lubancat-5IO image entries. BeagleY-AI gained USB, PCIe, ISP + IMX219, and VPAC patches on the vendor kernel, alongside GPU acceleration fixes for TI K3 targets and TI Wave5 VPU firmware. Rockchip RV1106 support was split into distinct RV1103G and RV1103B families, and new SPI/NVMe boot and Maskrom recovery paths were added. On the kernel and driver side, sunxi received an H3/H5 DVFS RCU-stall fix, MMC/I2C PM deadlock resolution, MGLRU enablement, and LTE modem USB serial support. Meson64 gained a GPIO pinctrl cansleep series and v7.2-rc1 via bleedingedge, while SpacemiT K1 was updated to linux-7.2.y. The RTL8189ES, RTL8189FS, and RTL8192EU wireless drivers were migrated to dedicated forks with 7.2 compatibility and patch cleanup, and an RTW88 SDIO interrupt storm was addressed. User-visible improvements include swapfile creation fixes, useradd-based first-login provisioning, and video-group access to Rockchip MPP codec devices. #Armbian #EmbeddedLinux #UBoot #Rockchip #Allwinner Changesboard: visionfive2: optimize config for modern U-Boot and single-partition booting. by @zevlaoxie2010 in armbian/build#10097Add Anbernic RG Vita Pro board image. by @crackerjacques in armbian/armbian.github.io#351Add Lubancat-5IO board image and vendor logo. by @lch08 in armbian/armbian.github.io#348Add TI Wave5 VPU firmware. by @Grippy98 in armbian/firmware#132beaglebadge: drop vendor-edge u-boot target (not in ti-u-boot-2026.01). by @igorpecovnik in armbian/build#10126BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129board: anbernic-rg-ds: make OTG-C port dual-role so USB hubs work. by @crackerjacques in armbian/build#10124Build-Switches: document KERNEL_DO_STUBBLE. by @iav in armbian/documentation#928Bump/rk uboot swig fleet mkspi 2. by @redrathnure in armbian/build#10122chore(deps): patch vulnerable transitive deps. by @SuperKali in armbian/website#33ci(docs-preview): skip publish/comment steps on fork PRs. by @iav in armbian/documentation#934ci: auto-regenerate build lists when image-info.json changes. by @igorpecovnik in armbian/armbian.github.io#349ci: bump image build cap 30m → 45m. by @igorpecovnik in armbian/os-ci-test#24ci: widen auto-retry budget and the systemic-failure threshold. by @igorpecovnik in armbian/os-ci-test#23clk: sunxi-ng: ccu_common: Replace ktime-dependent lock wait loop with udelay. by @deece in armbian/build#10119config: rockpi-e: change rkbin repository and use spl-blobs. by @chenxmqqqq in armbian/build#10027cubie-a7z: Add community support for Radxa Cubie A7Z (Allwinner A733). by @shkolnik in armbian/build#10036docs: add Datacenter access section (Netbird VPN + board access). by @igorpecovnik in armbian/documentation#936docs: document PREFER_NATIVE_ARMHF and enrich arm64-compat-vdso entry. by @iav in armbian/documentation#921docs: exclude docs/README.md from mkdocs build. by @iav in armbian/documentation#933docs: use unpinned python3-dev in setup instructions. by @igorpecovnik in armbian/documentation#935Drop testing-wireless-performance-test.yml. by @igorpecovnik in armbian/armbian.github.io#350Enable USB and PCIe on BeagleY-AI vendor kernel. by @Grippy98 in armbian/build#10115fake-ubuntu-advantage-tools: provide ubuntu-pro-client. by @Grippy98 in armbian/build#10116family-rv1106: Split RV1103G and RV1103B, cleanup overrides. by @vidplace7 in armbian/build#10011feat(api): serve QDL board metadata and proxy-cache firehose assets. by @SuperKali in armbian/website#31feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix swapfile creation. by @pierg75 in armbian/build#10065Fix TI K3 Suite Matching for Ubuntu Hosts and Enable GPU Acceleration for BeagleBoards. by @Grippy98 in armbian/build#10112fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132Guard config-disabled static helpers to silence -Wunused-function. by @iav in armbian/wifi-rtl8852bs#9Import long-carried armbian/build regd-init fix, with authorship. by @iav in armbian/wifi-rtl8852bs#8imx6 modernization: udoo + cubox-i u-boot v2026.07 + kernel (legacy 6.12 / current 6.18 / edge 7.1). by @igorpecovnik in armbian/build#10098kernel-rust: ship prebuilt Rust crate artifacts in linux-headers. by @iav in armbian/build#10117Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3meson64: add GPIO shared-proxy/pinctrl cansleep series (upstream v3). by @adeepn in armbian/build#10090meson64: enable v7.2-rc1 via bleedingedge. by @EvilOlaf in armbian/build#10079mixtile-edge2: u-boot: main: bump (generic) u-boot to v2026.07-rc5. by @rpardini in armbian/build#10071nanopi-r5s: u-boot: main: bump u-boot to v2026.07-rc5 + make it patch-less. by @rpardini in armbian/build#10072odroidc1: fix u-boot build on trixie (GCC 14) via config.mk -fpermissive. by @igorpecovnik in armbian/build#10111odroidxu4: fix u-boot build on trixie (GCC 14 implicit-decl errors). by @igorpecovnik in armbian/build#10110orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103recore: fix ATF v2.8.0 build - drop -Wl, prefix from LD flag. by @igorpecovnik in armbian/build#10100refactor(api): drop min_imager_version from QDL enrichment. by @SuperKali in armbian/website#32rockchip64: fix errexit build failure on SPI boards (undefined hook). by @igorpecovnik in armbian/build#10101rockchip64_common: add board_uboot postprocess hooks. by @mingzhangqun in armbian/build#10031rockchip: add support for Graperain G3568 v2. by @rbqvq in armbian/build#10056rockchip: udev: grant video group access to MPP codec devices and DMA-heaps. by @yisding in armbian/build#10085rtl8189es: switch fork, clean up patches, bump to 7.2. by @EvilOlaf in armbian/build#10086rtl8189fs: switch to own fork, add 7.2 compatibility, drop patches from misc. by @EvilOlaf in armbian/build#10092rtl8192eu: switch to own fork, add 7.2 compat, remove integrated patches from misc. by @EvilOlaf in armbian/build#10095shellfmt: run lib/tools/shellfmt.sh, no changes. by @rpardini in armbian/build#10087SpacemiT K1: Update EDGE to linux-7.2.y. by @pyavitz in armbian/build#10123sunxi (32+64-bit): bump u-boot v2024.01 -> v2026.07-rc4. by @igorpecovnik in armbian/build#10089sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi-6.18: fix H3/H5 RCU stall / CPU hang during DVFS (current kernel). by @igorpecovnik in armbian/build#10083sunxi64: bump self-pinned H616/H618 boards to v2026.07 (zero2w, zero3, longanpi-3h). by @igorpecovnik in armbian/build#10102sunxi64: enable USB_SERIAL_OPTION (module) for GSM/UMTS/LTE modem support. by @pumuckly in armbian/build#10050sunxi: pin mmc and i2c controllers to active to break circular PM deadlock. by @deece in armbian/build#10120uboot: add SPI/NVMe boot support and Maskrom SD-card/flash fixes. by @mingzhangqun in armbian/build#10030wifi: rtw88: sdio: Fix unhandled RX request interrupt storm. by @deece in armbian/build#10121WifiPerformance: update infrastructure section to autotests framework. by @igorpecovnik in armbian/documentation#931x96q: fix u-boot build hang — add missing CONFIG_DRAM_SUNXI_TPR6. by @igorpecovnik in armbian/build#10114youyeetoo-yy3588: switch to mainline U-Boot v2026.04. by @SuperKali in armbian/build#10125youyeetoo: fix 7" touch with TPC2059 config, add YY3588 display overlays. by @SuperKali in armbian/linux-rockchip#507yy3588: fix eDP video port and timing, document panel requirement. by @SuperKali in armbian/linux-rockchip#508View the full article
  25. This week's cycle emphasizes broad U-Boot modernization, new board and SoC enablement, and kernel and wireless driver consolidation. A large-scale U-Boot bump moves sunxi 32-bit and 64-bit targets from v2024.01 to v2026.07-rc4, with follow-on updates for self-pinned H616/H618 boards (Zero2W, Zero3, Longan Pi 3H), Mixtile Edge2, NanoPi R5S (now patch-less), and the Youyeetoo YY3588 switching to mainline v2026.04. The imx6 line (UDOO, Cubox-i) was modernized to U-Boot v2026.07 with legacy 6.12, current 6.18, and edge 7.1 kernels. Related toolchain work fixes ODROID-C1, ODROID-XU4, Recore, and X96Q builds under Trixie's GCC 14, and resolves errexit failures on Rockchip SPI boards. Platform expansion introduces community support for the Allwinner A733-based Radxa Cubie A7Z and Orange Pi Zero 3W, Rockchip Graperain G3568 v2, and Anbernic RG Vita Pro and Lubancat-5IO image entries. BeagleY-AI gained USB, PCIe, ISP + IMX219, and VPAC patches on the vendor kernel, alongside GPU acceleration fixes for TI K3 targets and TI Wave5 VPU firmware. Rockchip RV1106 support was split into distinct RV1103G and RV1103B families, and new SPI/NVMe boot and Maskrom recovery paths were added. On the kernel and driver side, sunxi received an H3/H5 DVFS RCU-stall fix, MMC/I2C PM deadlock resolution, MGLRU enablement, and LTE modem USB serial support. Meson64 gained a GPIO pinctrl cansleep series and v7.2-rc1 via bleedingedge, while SpacemiT K1 was updated to linux-7.2.y. The RTL8189ES, RTL8189FS, and RTL8192EU wireless drivers were migrated to dedicated forks with 7.2 compatibility and patch cleanup, and an RTW88 SDIO interrupt storm was addressed. User-visible improvements include swapfile creation fixes, useradd-based first-login provisioning, and video-group access to Rockchip MPP codec devices. #Armbian #EmbeddedLinux #UBoot #Rockchip #Allwinner Changesboard: visionfive2: optimize config for modern U-Boot and single-partition booting. by @zevlaoxie2010 in armbian/build#10097Add Anbernic RG Vita Pro board image. by @crackerjacques in armbian/armbian.github.io#351Add Lubancat-5IO board image and vendor logo. by @lch08 in armbian/armbian.github.io#348Add TI Wave5 VPU firmware. by @Grippy98 in armbian/firmware#132beaglebadge: drop vendor-edge u-boot target (not in ti-u-boot-2026.01). by @igorpecovnik in armbian/build#10126BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129board: anbernic-rg-ds: make OTG-C port dual-role so USB hubs work. by @crackerjacques in armbian/build#10124Build-Switches: document KERNEL_DO_STUBBLE. by @iav in armbian/documentation#928Bump/rk uboot swig fleet mkspi 2. by @redrathnure in armbian/build#10122chore(deps): patch vulnerable transitive deps. by @SuperKali in armbian/website#33ci(docs-preview): skip publish/comment steps on fork PRs. by @iav in armbian/documentation#934ci: auto-regenerate build lists when image-info.json changes. by @igorpecovnik in armbian/armbian.github.io#349ci: bump image build cap 30m → 45m. by @igorpecovnik in armbian/os-ci-test#24ci: widen auto-retry budget and the systemic-failure threshold. by @igorpecovnik in armbian/os-ci-test#23clk: sunxi-ng: ccu_common: Replace ktime-dependent lock wait loop with udelay. by @deece in armbian/build#10119config: rockpi-e: change rkbin repository and use spl-blobs. by @chenxmqqqq in armbian/build#10027cubie-a7z: Add community support for Radxa Cubie A7Z (Allwinner A733). by @shkolnik in armbian/build#10036docs: add Datacenter access section (Netbird VPN + board access). by @igorpecovnik in armbian/documentation#936docs: document PREFER_NATIVE_ARMHF and enrich arm64-compat-vdso entry. by @iav in armbian/documentation#921docs: exclude docs/README.md from mkdocs build. by @iav in armbian/documentation#933docs: use unpinned python3-dev in setup instructions. by @igorpecovnik in armbian/documentation#935Drop testing-wireless-performance-test.yml. by @igorpecovnik in armbian/armbian.github.io#350Enable USB and PCIe on BeagleY-AI vendor kernel. by @Grippy98 in armbian/build#10115fake-ubuntu-advantage-tools: provide ubuntu-pro-client. by @Grippy98 in armbian/build#10116family-rv1106: Split RV1103G and RV1103B, cleanup overrides. by @vidplace7 in armbian/build#10011feat(api): serve QDL board metadata and proxy-cache firehose assets. by @SuperKali in armbian/website#31feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix swapfile creation. by @pierg75 in armbian/build#10065Fix TI K3 Suite Matching for Ubuntu Hosts and Enable GPU Acceleration for BeagleBoards. by @Grippy98 in armbian/build#10112fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132Guard config-disabled static helpers to silence -Wunused-function. by @iav in armbian/wifi-rtl8852bs#9Import long-carried armbian/build regd-init fix, with authorship. by @iav in armbian/wifi-rtl8852bs#8imx6 modernization: udoo + cubox-i u-boot v2026.07 + kernel (legacy 6.12 / current 6.18 / edge 7.1). by @igorpecovnik in armbian/build#10098kernel-rust: ship prebuilt Rust crate artifacts in linux-headers. by @iav in armbian/build#10117Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3meson64: add GPIO shared-proxy/pinctrl cansleep series (upstream v3). by @adeepn in armbian/build#10090meson64: enable v7.2-rc1 via bleedingedge. by @EvilOlaf in armbian/build#10079mixtile-edge2: u-boot: main: bump (generic) u-boot to v2026.07-rc5. by @rpardini in armbian/build#10071nanopi-r5s: u-boot: main: bump u-boot to v2026.07-rc5 + make it patch-less. by @rpardini in armbian/build#10072odroidc1: fix u-boot build on trixie (GCC 14) via config.mk -fpermissive. by @igorpecovnik in armbian/build#10111odroidxu4: fix u-boot build on trixie (GCC 14 implicit-decl errors). by @igorpecovnik in armbian/build#10110orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103recore: fix ATF v2.8.0 build - drop -Wl, prefix from LD flag. by @igorpecovnik in armbian/build#10100refactor(api): drop min_imager_version from QDL enrichment. by @SuperKali in armbian/website#32rockchip64: fix errexit build failure on SPI boards (undefined hook). by @igorpecovnik in armbian/build#10101rockchip64_common: add board_uboot postprocess hooks. by @mingzhangqun in armbian/build#10031rockchip: add support for Graperain G3568 v2. by @rbqvq in armbian/build#10056rockchip: udev: grant video group access to MPP codec devices and DMA-heaps. by @yisding in armbian/build#10085rtl8189es: switch fork, clean up patches, bump to 7.2. by @EvilOlaf in armbian/build#10086rtl8189fs: switch to own fork, add 7.2 compatibility, drop patches from misc. by @EvilOlaf in armbian/build#10092rtl8192eu: switch to own fork, add 7.2 compat, remove integrated patches from misc. by @EvilOlaf in armbian/build#10095shellfmt: run lib/tools/shellfmt.sh, no changes. by @rpardini in armbian/build#10087SpacemiT K1: Update EDGE to linux-7.2.y. by @pyavitz in armbian/build#10123sunxi (32+64-bit): bump u-boot v2024.01 -> v2026.07-rc4. by @igorpecovnik in armbian/build#10089sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi-6.18: fix H3/H5 RCU stall / CPU hang during DVFS (current kernel). by @igorpecovnik in armbian/build#10083sunxi64: bump self-pinned H616/H618 boards to v2026.07 (zero2w, zero3, longanpi-3h). by @igorpecovnik in armbian/build#10102sunxi64: enable USB_SERIAL_OPTION (module) for GSM/UMTS/LTE modem support. by @pumuckly in armbian/build#10050sunxi: pin mmc and i2c controllers to active to break circular PM deadlock. by @deece in armbian/build#10120uboot: add SPI/NVMe boot support and Maskrom SD-card/flash fixes. by @mingzhangqun in armbian/build#10030wifi: rtw88: sdio: Fix unhandled RX request interrupt storm. by @deece in armbian/build#10121WifiPerformance: update infrastructure section to autotests framework. by @igorpecovnik in armbian/documentation#931x96q: fix u-boot build hang — add missing CONFIG_DRAM_SUNXI_TPR6. by @igorpecovnik in armbian/build#10114youyeetoo-yy3588: switch to mainline U-Boot v2026.04. by @SuperKali in armbian/build#10125youyeetoo: fix 7" touch with TPC2059 config, add YY3588 display overlays. by @SuperKali in armbian/linux-rockchip#507yy3588: fix eDP video port and timing, document panel requirement. by @SuperKali in armbian/linux-rockchip#508View the full article
  26. Hi Dodeval, so I am having trouble accessing Gemini 3.1 pro chat about this but this sounds vaguely familiar. Things that could be the cause are the "mkfs.ext4 -b 4096" option and "debootstrap --arch=arm64". Try some of these top tier models https://artificialanalysis.ai/leaderboards/models they should be able to crack the code even though you might have to wrestle a bit to get them to produce the right solution. Most things seem to work like magic I guess it is about the device tree, battery management seems fine etc.. touch needs drivers, no audio from internal speakers which is no big deal anyway as bluetooth audio works everything there works as expected. I did get this aliexpress.com/item/1005009649297050.html at a discount but I not completely get the touchpad to work comfortably with a patched input driver, a lot of miss-clicks goosh nice keyboard but still need bluetooth mouse in reality. Rii i4 Mini Bluetooth would be fine but then again it is not quite the desktop experience I was looking for.
  27. Your previous post reminded me that the board supplier changed the BOM of the ODROID-N2+ by using a different SPI flash vendor. He hacked the support for it into his legacy firmware build without making any further note about it. It took some effort of reverse engineering to figure that out. Mainline hasn't picked up this additional driver activation to this day, but I still keep it in my builds anyway. In my latest build for the ODROID-HC4, I also included this driver to see if they might have gone about it in the same way. But your confirmation shows that this is probably not the case. Since I don't have an ODROId-HC4 with the behavior you described on hand, I can't analyze any further what the cause of it is. These days, I also mostly avoid devices with Amlogic SoCs because of their strict closed-source policy and lack of mainline support. And the board manufacturer isn't much more helpful on this point either. Devices powered by Rockchip are much more appealing objects. So you have to help yourself if you want to find a solution.
  28. I don't have a Desktop installed on this device (OrangePi 4LTS). I resorted to using the rtmidi C interface instead, I made a wrapper. The Pipewire documentation is hard to figure out. I guess there should be some sort of session management for Non-Desktop sessions to load stuff?
