  2. @Benedito Portela you are a long term user on this forum to don't know that debugging is a MUST !!!!!!! And you have such WONDERFULL uart pads, even with names ( tx rx gnd) ... why don't you use them and let all of us know what going in your box ??😇 😉
  3. Hello @alg_42 You have only 1 GB of space in /tmp. This is tmpfs, so it uses your RAM. It is not enough to unpack your backup into. You can increase the size but the Pine64 either has only 512MB or 1GB of RAM, so that is not a good idea. I suggest you temporarily deactivate the /tmp mount instead, reboot, complete your backup and then reactivate the /tmp mount and reboot again. Armbian puts /tmp on tmpfs so that the frequent writes to it do not wear out your flash so it is important you reactivated it later on and don't leave it on your main partition indefinitely. Can you share the output of "grep tmp /etc/fstab" with us?
  5. I'm, using one of those CH340 based usb-uart dongles https://www.aliexpress.com/w/wholesale-usb-uart-ch340.html but that normally most usb-uart dongles would work https://www.aliexpress.com/w/wholesale-usb-uart.html just make sure to check that it has / uses 3.3V io levels. Not 5V io levels as that may damage the processor (cpu / soc) for the pins connection review the user manual http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/service-and-support/Orange-Pi-Zero-3.html it is the 3 pins labelled Debug TTL UART on their board photo http://www.orangepi.org/img/zero3/0627-zero3 (6).png --- off-topic: for these small boards, I've basically stopped running them with an LCD monitor and keyboard as I find it a hassle as I'm using a desktop PC and trying to share the monitor. I mostly use them 'headless' using the usb-uart port. And in fact, after you setup the network appropriately e.g. set a static IP address or install avahi, the usb-uart console is no longer needed for static (fixed) IP address it is covered in the networking guide https://docs.armbian.com/User-Guide_Networking/ for avahi (MDNS) > apt install avahi-daemon avahi-utils edit /etc/avahi/avahi-daemon.conf [publish] publish-workstation=yes you can find the board on the ethernet over MDNS e.g. https://github.com/hrzlgnm/mdns-browser and you can ssh into the board over the network, e.g. using putty https://www.putty.org/
  6. Did a lspci and it only returns 1 NIC device on the pci bus...
  7. There is no moonlight-qt packaged in this ppa for noble, you can build from source: https://salsa.debian.org/amazingfate/moonlight-qt
  8. Is there any trick to make use of the integrated fan on Radxa 25W PoE Hat? I'm using 4GB Radxa Rock 5C Lite Armbian_25.5.1_Rock-5c_bookworm_vendor_6.1.115_minimal Some guides mention that one should enable an overlay. I didn't find any relevant overlays in armbian-config. In the Radxa repo I found rock-5a-radxa-25w-poe.dts which specifies that it's also compatible with Rock 5C. I've compiled it and enabled it, but by default the fan is not spinning (on high temps) and I'm not sure how to investigate that.
  9. Yesterday
  10. What build of armbian are you using? Please provide the exact steps you are having problems with, your description of the problem is not clear.
  11. Thank you! I will try it tomorrow. What is spi1_cs0_pin and spi1_cs1_pin equal to, in Orange Pi Zero 2W, and in Opiz3? Is it defined in the spi-spidev dtso, or in the main opiz3/opiz2w dts? I need to have it correctly in the main DTS, because the LCD driver doesn't use spidev (and it would conflict). cs0 matches the pin position in raspberry pi: pin 24.... so it would make sense if cs1 is pin 26. Reference. This is the patch that changes the opiz3/2w DTS https://forum.armbian.com/topic/50418-dont-use-kernel-61216-on-sunxi64/page/2/#findComment-216934
  12. Thats the Plan I just wanted to update my fork first in case any problems occured before submitting. Just wanted to check, seeming as I am covering 2 areas (dts patches and drm patches) would you still prefer this to be in a single commit? The original purposing being to add hdmi support for the Pcduino2 and Pcduino3, but evolved due to the drm breakages.
  13. In collaboration with Inria, the French Institute for Research in Computer Science and Automation, Tathagata Roy shares the progress made over the past year on the CoccinelleForRust project, co-sponsored by Collabora View the full article
  14. nope, just checked.
  15. This is an awesome effort from you all! I purchased a v3. 1 2gb ddr3 version off ebay for 25usd and tried out the mate graphical image and it worked like a charm. Just some feedback for you all and others like me that read this forum. 996mb ram I think it is as reported by other users also. Vulkan graphics seem to be working, WiFi and usb ports all working out of the box. Bluetooth appears but I didn't try to connect to any devices yet. I even tried the tiny stories 656k ollama llm to see if that would work and its pretty fast with some bad stories haha even the 1b parameter model loaded but it's barely working. I will try llama.c next to try get some. Kind of acceleration from the gpu. Supertuxkart runs very smoothly. I installed on a 32gb SanDisk tf card with no worries flashing using etcher. It's quite a capable little machine. I even managed to compile a game I'm building at the moment for Linux + dos called deadseas which runs rather well. I havnt tried sound or anything yet as I'm direct into an old monitor via hdmi > dvi. So much better than the stock Android that the x96q comes with. Anyway thanks for your efforts!
  16. Im currently trying to implement gpu support, but ive been stuck on the same error since a few days. Heres my armbianmonitor -u output: https://paste.armbian.com/uforekotuw root@radxa-cubie-a5e:~# cat /sys/kernel/debug/pm_genpd/pm_genpd_summary domain status children performance /device runtime status managed by ------------------------------------------------------------------------------ pd1_gpu off-0 0 pd1_pcie off-0 0 pd1_nand off-0 0 pd1_de off-0 0 pd1_vo1 off-0 0 4510000.ethernet suspended 0 SW pd1_vo0 off-0 0 pd1_vi off-0 0 pd1_ve off-0 0 pd_riscv off-0 0 pd_sram off-0 0 pd_npu off-0 0 pd_dsp off-0 0 dmesg | grep -i "gpu\|mali" [ 1.836128] panfrost 1800000.gpu: clock rate = 432000000 [ 1.848131] panfrost 1800000.gpu: gpu soft reset timed out, attempting hard reset [ 1.858262] panfrost 1800000.gpu: gpu hard reset timed out [ 1.858486] panfrost 1800000.gpu: Fatal error during GPU init [ 1.858674] panfrost 1800000.gpu: probe with driver panfrost failed with error -110
  17. You need to check the disk space, apparently you are out of space and the daemon is not logging.
  18. Not yet, i'll try to contact him ! Thank you very muych
  19. Success story: https://forums.raspberrypi.com/viewtopic.php?p=2322591#p2322591 with the 3.5 inch ili9488, graphics (wayland) and touch in raspberry pi 3b I hope this helps with making it work in orange pi zero 3 and 2w (only touch missing)
  20. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  21. Last week
  22. And how to compile openvfd with this patch? How to apply this patch to openvfd?
  23. Added instructions for joining your home lab: https://docs.armbian.com/WifiPerformance/#adding-a-new-device
  24. That should make it. You can always try to see if it works and search online if not.
  25. FYI. HDMI out is broken on those board at the moment. Try to access the board remotely. We don't have people to maintain those old boards.
  26. Thank you for that information. From a cursory look, it seems as if that is only binary images, no source (violating GPL).
  27. I will try to make that easier and more automatic with APA, eventually.
  28. Thank you for letting us know as it allows an interested party to more easily bisect the regression.
