Hi everyone. I have this RK3318 chip box running Ubuntu, but I can't enable SSH to reinstall it. It doesn't have a display output port. Is there any way to reinstall the OS without desoldering the eMMC to reflash it? (I don't know how to put it back if I take it off). I've already tried flashing via USB and the RX/TX/GND lines, but neither worked. Model: AROP-01 CPU: Quad-core ARM processor Memory: 2GB System Storage: 64GB eMMC Network Interface: 1 × Ethernet USB Interface: 1 × USB Type-C Power: 5V/2A Dimensions: 103 × 103 × 20 mm Package Contents: 1 × Manual, 1 × Ethernet Cable, 1 × Power Cable Thank you.
What hardware will comfortably run Waydroid?
samlevy0515 replied to dreamlayers's topic in Software, Applications, Userspace
Great question — I’d really like to know too! Have you tried a lightweight Android image like LineageOS-microG inside Waydroid, or tweaked the GPU rendering settings? -
Today I noticed that last Sunday a community version of Armbian was released with Orange Pi 4A support. I tried to flash it in different ways just in case, but it just wouldn't boot. I used BalenaEtcher, Rufus and Armbian Imager and neither of them worked. Im new in this stuff, so I wanted to know if someone could tell me if it is something I'm doing wrong.
Here's lspci -vvv with an older Radeon: https://paste.armbian.com/zisezuqoza.yaml and boot UART log (it boots but no display is visible) https://paste.armbian.com/asizofulux.sql Here's the same with Radeon RX 550: https://paste.armbian.com/ovinibafux.yaml The kernel complained about missing firmware (for polaris11), which actually was not missing. I had to regenerate initramfs using initramfsctl. After regenerating, the board stopped booting with the card connected: https://paste.armbian.com/qitiwiwoge.yaml Not sure how useful lsusb would be. So it's not super stable yet. I saw that you made these modules built-in. This is not necessary, selecting [M] is enough because then they can be loaded or unloaded (to try passing the card through to a VM I need to blacklist the module, which doesn't work for built-in modules). This is something I can try to do to get display output. Oh and WiFi isn't detected at all but that's probably not a surprise.
Hi, I am assuming that you have a standard Q1 TV Box (Allwinner H313 based). 1) Download Armbian Imager here; 2) Install the version for your operating system; 3) After installing, choose "Manufacturer=ALLWINNER", Board="X96Q TV BOX", Operating system="minimal Trixie current" and Storage ( I suggest a good quality Class 10 SD card); 4) After writing the image, insert the SD card into the available SD slot; 5) Insert a wooden toothpick or a Q-tip into AV/Reset input; 6) Click (kindly) and hold the toothpick and connect the TV Box power supply to the power entry; 7) Release the toothpick after 8-10 seconds. if the HDMI connector is plugged you should see the Armbian initial boot process Note: some TV Boxes don't need items 5, 6 and 7. I hope it helps.
Hi. I've also been having issues with my Orange Pi 5. It seems the problem is that the module was removed from the kernel, but I haven't looked into it in detail yet. The folks at NixOS seem to have solved this issue https://github.com/waydroid/waydroid/issues/2094 I have this specific problem waydroid show-full-ui [22:49:14] Starting waydroid session [22:49:14] RuntimeError: Command failed: % /usr/lib/waydroid/data/scripts/waydroid-net.sh start vnic is waydroid0 sudo /usr/lib/waydroid/data/scripts/waydroid-net.sh start modprobe: FATAL: Module ip_tables not found in directory /lib/modules/6.18.10-current-rockchip64 iptables v1.8.11 (legacy): can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded. Failed to setup waydroid-net. My system user@orangepi5:~$ uname -a Linux orangepi5 6.18.10-current-rockchip64 #2 SMP PREEMPT Wed Feb 11 12:42:01 UTC 2026 aarch64 GNU/Linux I'm not a network expert, so I hope someone can help. Are you having the same problem?
Yes, of course, but as you said yourself, there are issues with ethernet on mainline. So you can just use a dongle as a temporary workaround to get a stable (or any) connection.
@iav The kobol dtbs (rk3399-kobol-helios64.dtb) linked in the messages before are patched in the following way having the effect that helios64 is finally stable (see here) : The opp-microvolt values in opp-table-1 are just replaced by the ones given below (for all linux kernel versions). opp-table-1 { compatible = "operating-points-v2"; opp-shared; phandle = <0x0d>; opp00 { opp-hz = <0x00 0x18519600>; opp-microvolt = <0xdbba0 0xdbba0 0x1312d0>; clock-latency-ns = <0x9c40>; }; opp01 { opp-hz = <0x00 0x23c34600>; opp-microvolt = <0xdbba0 0xdbba0 0x1312d0>; }; opp02 { opp-hz = <0x00 0x30a32c00>; opp-microvolt = <0xdbba0 0xdbba0 0x1312d0>; }; opp03 { opp-hz = <0x00 0x3c14dc00>; opp-microvolt = <0xe7ef0 0xe7ef0 0x1312d0>; }; opp04 { opp-hz = <0x00 0x47868c00>; opp-microvolt = <0xfa3e8 0xfa3e8 0x1312d0>; }; opp05 { opp-hz = <0x00 0x54667200>; opp-microvolt = <0x10c8e0 0x10c8e0 0x1312d0>; }; opp06 { opp-hz = <0x00 0x5fd82200>; opp-microvolt = <0x11edd8 0x11edd8 0x1312d0>; }; opp07 { opp-hz = <0x00 0x6b49d200>; opp-microvolt = <0x1312d0 0x1312d0 0x1312d0>; }; };
Oh Thanks, I'll give a try this way.
Join us next week in Utrecht for RustWeek! We'll be running a SuperTuxKart tournament to showcase Tyr, the Rust driver for Arm Mali GPUs. Come and see if you've got what it takes! View the full article
Armbian_community_26.2.0-trunk.886_Yy3568_resolute_current_6.18.28_gnome_desktop.img the nvme ssd does not working, any idea? root@yy3568:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk0 179:0 0 58.2G 0 disk ├─mmcblk0p1 179:1 0 325M 0 part ├─mmcblk0p2 179:2 0 27.6G 0 part └─mmcblk0p3 179:3 0 30.2G 0 part mmcblk0boot0 179:32 0 4M 1 disk mmcblk0boot1 179:64 0 4M 1 disk mmcblk1 179:96 0 29.7G 0 disk └─mmcblk1p1 179:97 0 29.4G 0 part /var/log.hdd / zram0 253:0 0 3.8G 0 disk [SWAP] zram1 253:1 0 50M 0 disk /var/log zram2 253:2 0 0B 0 disk root@yy3568:~# root@yy3568:~# root@yy3568:~#dmesg | grep -E "pcie|nvme|PCIe" | tail -n 30 lsblk -o NAME,SIZE,TYPE,MOUNTPOINTS,TRAN [ 0.098950] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller [ 0.133093] /pcie@fe280000: Fixed dependency cycle(s) with /pcie@fe280000/legacy-interrupt-controller [ 2.745055] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges: [ 2.745105] rockchip-dw-pcie 3c0000000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 2.745125] rockchip-dw-pcie 3c0000000.pcie: MEM 0x00f4200000..0x00f5ffffff -> 0x00f4200000 [ 2.745136] rockchip-dw-pcie 3c0000000.pcie: MEM 0x0300000000..0x033fffffff -> 0x0300000000 [ 2.745348] rockchip-dw-pcie 3c0000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G [ 3.806942] rockchip-dw-pcie 3c0000000.pcie: Phy link never came up [ 3.808269] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00 [ 3.808554] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 PCIe Root Port [ 3.825132] pcieport 0000:00:00.0: PME: Signaling with IRQ 73 [ 3.825508] pcieport 0000:00:00.0: AER: enabled with IRQ 82 [ 5.074343] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110 [ 23.011574] rockchip-pm-domain fdd90000.power-management:power-controller: sync_state() pending due to 3c0800000.pcie NAME SIZE TYPE MOUNTPOINTS TRAN mmcblk0 58.2G disk mmc ├─mmcblk0p1 325M part mmc ├─mmcblk0p2 27.6G part mmc └─mmcblk0p3 30.2G part mmc mmcblk0boot0 4M disk mmc mmcblk0boot1 4M disk mmc mmcblk1 29.7G disk mmc └─mmcblk1p1 29.4G part /var/log.hdd mmc / zram0 3.8G disk [SWAP] zram1 50M disk /var/log zram2 0B disk root@yy3568:~# poweroff
@armfan you start mixing instructions from Xunlong, SpacemiT, and Armbian. That will not work probably. The SoC is able to boot from SD, eMMC, and MTD (in that order). With Armbian started, you can use armbian-install to write u-boot to MTD (which is Memory Technology Device aka the kernel device for SPI flash and other flash mem). That Armbian u-boot is able to indirectly boot from NVME. Or via USB but only with manual u-boot commands you can type into the UART console, see discussion on OpiR2S booting in this thread.
https://github.com/MaverickLong/MLIR-TIM-VX This is an MLIR-based lowering path from the TOSA v1 dialect to TIM-VX, VeriSilicon's OpenVX-based GPU/NPU ML Framework. It includes the lowering from TOSA v1 to a custom timvx dialect (mirrors the TIM-VX C++ semantics) and a full lowering to C++ source. It is currently on par in inference speed with the vendor ACUITY compiler pipeline while still giving you full control on the graph level. In my own testing, on a Radxa Cubie A7Z \w Allwinner A733, ResNet-50 takes 8.0ms to inference, while the ACUITY-compiled baseline takes 7.3ms according to Radxa. It all starts with Radxa/VeriSilicon's false advertisement of the NPU supporting MLIR, but turns out we just don't have it yet, so I made my own. I have only tested the pipeline on the A733, but it should be able to be extended to any other VIP9000 variants as well.
Hello community! I’ve been a lurker for a while and recently flashed the latest Armbian Jammy onto a spare NanoPi NEO I had lying around. I'm currently designing a headless DIY time-tracking kiosk for a small local workshop using an RC522 RFID reader via SPI. Reading the RFID tags and logging the raw Unix timestamps (punch-in/punch-out) to a local SQLite database was the easy part. Where I'm getting a bit stuck is the actual backend calculation logic. I need the system to accurately calculate the daily net working hours, which means automatically deducting mandatory statutory breaks (e.g., 30 mins after 6 hours of work) and tracking daily overtime. To ensure the math is strictly accurate and handles edge cases properly, I am trying to write a Python script that replicates the exact calculation logic used by standard tools like arbeitszeitrechnerprofi.de for the backend processing. Before I completely reinvent the wheel writing complex Python datetime scripts, has anyone here built a similar attendance or punch-clock project on Armbian? What’s the best way to handle this data processing locally? Would it be better to just use Node-RED for easier visual flow and logic management rather than a standalone Python daemon? Also, any tips on GPIO reliability for the RFID reader under the recent Armbian kernels would be highly appreciated. I plan to start wiring the prototype this weekend. Thanks in advance!
Enable ethernet port on expansion board for OrangePi zero 2w
Werner replied to Golecom's topic in Allwinner sunxi
Try with this commit:https://github.com/armbian/build/commit/b880d98b07090b0b59bb3096c508e5123b224037 Seems like Micha had to cleanup my mess -
@meco works perfectly and passes stress-ng. Thanks!
And same on odroid m2
Hello. I installed armbian trixie on orangepzero 2w. OK. I'd like to install Homeassistant on this machine. I went to armbian-config -> Software -> HomeAutomation -> Home Assistant. Installation went smooth< as far as I see. Then I asked to reboot system to enable AppArmor. I did that. After reboot I tried to connect to the machine via Firefox http://192.168.1.16:8123 Nothing happened. Should I issue some commands or do some actions to continue installation? Thanks you you advance. Alexei
This week's work centers on release and CI infrastructure, board and U-Boot updates, and build framework hardening. On the release pipeline, asset manifest JSON is now emitted alongside uploads, third-party armbian-images.json sources are merged into the main download index, and dispatch chains were rewired so that build completion fans out cleanly to download-index regeneration and website sync. Ubuntu resolute (26.04) entered the daily build matrix, with corresponding prepare-host adjustments for its qemu-user packaging and a targeted blacklist for boards failing resolute plus GNOME. The new Armbian SDK images are now surfaced on the website and ship preloaded with the build framework, code-server, and developer tooling. On the platform side, U-Boot v2026.04 lands for Helios4, Rock-5B-Plus, Rock-5T, and NanoPi-M5 (with mainline UFS via a vendor-SPL hybrid), while new bleedingedge branches were introduced for rockchip64 and meson64. Initial support arrived for the Photonicat2 board, new RK3576 SPL and RK3588 DDR blobs were added, Panthor firmware expanded to cover additional Mali GPUs, and a PCIe LTSSM timeout fix improves cold-boot NVMe detection on Rockchip. NanoPC-T6 LTS Plus was renamed, panther-x2 moved from CSC to EOS, and odroidxu4-current advanced to 6.6.138. In the build framework, an unsafe eval was replaced with declare -g and namerefs, destructive commands were properly quoted, and Docker --privileged is now gated behind an explicit DOCKER_PRIVILEGED toggle. The desktop configuration tree migrated to the armbian-config module_desktops system, kernel build failures now propagate exit codes correctly, missing BOOT_FDT_FILE surfaces as an error alert, and SysRq-via-BREAK was restored on dw-apb-uart for mvebu-6.18 and rockchip64-7.0 kernels. #Armbian #EmbeddedLinux #UBoot #Rockchip #SBC #LinuxKernel Changes(#9400 P1b) Replace unsafe eval with declare -g and nameref. by @iav in armbian/build#9461action: emit assets manifest JSON alongside release uploads. by @igorpecovnik in armbian/build#9772action: leave torrent URLs empty in per-image asset manifests. by @igorpecovnik in armbian/build#9792Add expect-dev to package dependencies. by @igorpecovnik in armbian/configng#904Add support for Photonicat2 board with USB hub watchdog. by @HackingGate in armbian/build#9765arm64: dts: rockchip: rename NanoPC-T6 LTS Plus to NanoPC-T6 Plus. by @igorpecovnik in armbian/linux-rockchip#478Build-Switches: document DOCKER_PRUNE opt-in. by @igorpecovnik in armbian/documentation#920build: misc cleanup — DEBUG-gated mmdebstrap verbosity, DOCKER_PRUNE opt-in. by @igorpecovnik in armbian/build#9704chore(config/common): remove dead FAST_CREATE_IMAGE variable. by @iav in armbian/build#9756ci/maintenance-unit-tests: skip draft PRs. by @igorpecovnik in armbian/configng#910ci: add Maintenance: Watchdog workflow. by @igorpecovnik in armbian/docker-armbian-build#23ci: add Ubuntu resolute to the build matrix. by @igorpecovnik in armbian/sdk#22ci: aggregate per-cell asset manifests into armbian-sdk-images.json. by @igorpecovnik in armbian/sdk#13ci: cancel in-flight download-index runs when a new one starts. by @igorpecovnik in armbian/armbian.github.io#313ci: dispatch armbian.github.io download-index regen after green build. by @igorpecovnik in armbian/sdk#21ci: dispatch armbian/website sync after web-directory generation. by @igorpecovnik in armbian/armbian.github.io#310ci: fix dispatch chain — download-index fan-out + redirector ends with directory regen. by @igorpecovnik in armbian/armbian.github.io#311ci: rename build workflow to 'Docker Images For Automation'. by @igorpecovnik in armbian/docker-armbian-build#24Community: blacklist xpressreal-t3 (resolute desktops failing). by @igorpecovnik in armbian/armbian.github.io#308Community: enable Ubuntu minimal CLI for all boards (not just headless). by @igorpecovnik in armbian/armbian.github.io#309desktops: migrate from config/desktop/ tree to armbian-config module_desktops. by @igorpecovnik in armbian/build#9683Disable UDev Rule for Radxa Display 10 FHD. by @FlorianKohn in armbian/build#9503docker: gate --privileged behind DOCKER_PRIVILEGED toggle (default yes). by @iav in armbian/build#9733docs: add extensions reference list. by @iav in armbian/documentation#881feat(boards/helios4): enable watchdog extension by default. by @iav in armbian/build#9757Fix cmdline fsck argument. by @QwaSeeK in armbian/build#9779Fix rk3528 nanopi zero2 snps reset gpio property. by @EvilOlaf in armbian/build#9770fix(config): skip host filesystem compatibility check for ROOTFS_TYPE=nfs. by @iav in armbian/build#9759fix(kernel/mvebu-6.18): restore SysRq-via-BREAK on dw-apb-uart (8250_dw). by @iav in armbian/build#9760fix(kernel/rockchip64-7.0): restore SysRq-via-BREAK on dw-apb-uart (8250_dw). by @iav in armbian/build#9750framework: add resolute (Ubuntu 26.04) image to the daily matrix. by @igorpecovnik in armbian/docker-armbian-build#26helios4: bump u-boot to v2026.04. by @iav in armbian/build#9786image/compress-checksum: maximize CPU + memory use. by @igorpecovnik in armbian/build#9758Introduce bleedingedge BRANCH for rockchip64. by @EvilOlaf in armbian/build#9738kernel-dtb: surface missing BOOT_FDT_FILE as err alert (fixes #8083). by @iav in armbian/build#9700kernel: fix process not exit with kernel build failure. by @amazingfate in armbian/build#9771manage_zsh → module_zsh: align with current module style. by @igorpecovnik in armbian/configng#911Merge third-party armbian-images.json sources into the main download index. by @igorpecovnik in armbian/armbian.github.io#306meson64: introduce bleedingedge BRANCH with 7.1-rc2. by @EvilOlaf in armbian/build#9761nanopi-m5: mainline U-Boot v2026.04 + UFS (vendor-SPL hybrid). by @SuperKali in armbian/build#9788Nightly: blacklist 16 boards failing resolute+gnome_desktop. by @igorpecovnik in armbian/armbian.github.io#307panther-x2: move from CSC to EOS. by @igorpecovnik in armbian/build#9778panthor: Add firmware for more Mali GPUs. by @nyanmisaka in armbian/firmware#124pci: pcie_dw_rockchip: increase PCIe LTSSM timeout for cold boot NVMe. by @rpahle in armbian/build#9751Pre-load SDK images with build framework, code-server, Python + Claude Code, and SSH keys. by @igorpecovnik in armbian/sdk#16prepare-host: support Ubuntu resolute's qemu-user packaging changes. by @igorpecovnik in armbian/build#9790Quote variables in destructive commands (#9400 P0). by @iav in armbian/build#9401README: cover both image families this repo publishes. by @igorpecovnik in armbian/docker-armbian-build#25reporting-release-summary: prepend 'Armbian' to digest titles. by @igorpecovnik in armbian/armbian.github.io#305Revert zsh integration from SDK image. by @igorpecovnik in armbian/sdk#23rk3576: Add SPL v1.08 blob. by @SuperKali in armbian/rkbin#44RK3588: Add v1.20 DDR blob. by @HeyMeco in armbian/rkbin#43Rock-5B-Plus and Rock-5T: Move to u-boot 2026.04. by @HeyMeco in armbian/build#9773SpacemiT: Update EDGE branch to linux-7.1. by @pyavitz in armbian/build#9784Surface armbian-sdk images in Dedicated Applications. by @igorpecovnik in armbian/website#19Update odroidxu4-current to 6.6.137. by @belegdol in armbian/build#9768Update odroidxu4-current to 6.6.138. by @belegdol in armbian/build#9793Update README to clarify Armbian SDK purpose. by @igorpecovnik in armbian/sdk#18Update USB version in odroidhc4.conf. by @igorpecovnik in armbian/build#9754userpatches: install zsh via armbian-config --api, not direct apt. by @igorpecovnik in armbian/sdk#20userpatches: pre-install gh + first-boot provisioning stub. by @igorpecovnik in armbian/sdk#14userpatches: pre-install tig, nodejs and Claude Code CLI host-side. by @igorpecovnik in armbian/sdk#17userpatches: pre-install zsh in the chroot. by @igorpecovnik in armbian/sdk#19userpatches: switch pre-install from gh to git. by @igorpecovnik in armbian/sdk#15View the full article
I just checked and Orange Pi 5 is capable of DP mode over usb-c. I assume that patch has been tested and if it works (I might test it myself some time in near future) it is worth to keep.
- 6 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
Quite a while ago I added GPIO names to the rock-3a. Perhaps you can get an idea how to do this. Source: https://docs.radxa.com/en/rock3/rock3a/hardware-design/hardware-interface#gpio-interface Implementation: https://github.com/armbian/build/pull/7403/changes
Has anyone managed to get armbian to work on the HK1 Rbox K8s H618?
Nick A replied to Gwainer's topic in Allwinner CPU Boxes
@Gwainer try these images https://github.com/NickAlilovic/build/releases/tag/20250306
