  2. Yesterday I flashed a new sd card (more space) for my rockpi-4b but after switching to the stable channel `armbian-config --cmd STABLE` the update keeps failing: $ sudo apt update Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://security.debian.org trixie-security InRelease Get:3 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB] Hit:4 http://deb.debian.org/debian trixie-backports InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 http://armbian.lv.auroradev.org/apt trixie InRelease [39.4 kB] Get:7 http://armbian.lv.auroradev.org/apt trixie/trixie-utils arm64 Packages [21.4 kB] Get:8 http://armbian.lv.auroradev.org/apt trixie/trixie-desktop arm64 Packages [68 33 B] Fetched 115 kB in 2s (69.5 kB/s) 1 package can be upgraded. Run 'apt list --upgradable' to see it. $ sudo dpkg --configure -a $ sudo apt --fix-broken install Summary: Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 1 $ sudo apt upgrade Upgrading: armbian-firmware Summary: Upgrading: 1, Installing: 0, Removing: 0, Not Upgrading: 0 Download size: 0 B / 141 MB Space needed: 99.3 MB / 59.9 GB available Continue? [Y/n] y (Reading database ... 26869 files and directories currently installed.) Preparing to unpack .../armbian-firmware_26.2.1_all.deb ... Unpacking armbian-firmware (26.2.1) over (26.2.0-trunk.703) ... dpkg: error processing archive /var/cache/apt/archives/armbian-firmware_26.2.1_all.deb (--unpack): unable to open '/lib/firmware/qcom/sm8550/ayn/odin2mini/a740_zap.mbn.dpkg-new': No such file or directory Errors were encountered while processing: /var/cache/apt/archives/armbian-firmware_26.2.1_all.deb Error: Sub-process /usr/bin/dpkg returned an error code (1) For now I am doing `sudo apt-mark hold armbian-firmware`. Switching to rolling, updating there works (26.2.0-trunk.722). But the issue persists when switching back to stable. As there have been recent changes https://github.com/armbian/firmware/pull/117 and https://github.com/armbian/firmware/pull/119 and I couldn't find other error reports on the forum, I guess this is an issue of the image packaging. I also plugged back in the old sd card and that system updated without issues.
  3. Good morning. root_key.pem (after compilation) is located in not in u-boot* (root directory). Is that right? Thanks in advance.
  4. @tim zeng sure, but that's not - directly - related, since the Orange PI5 and the Orange Pi3 are different SOCs/SBCs. The only common trait is the poor SW support offered by the vendor.
  5. I am experiencing an issue where the Intel BE200 Wi-Fi module stops working on the NanoPi R5C after upgrading to the latest Armbian v26.2.1 with newer kernels. The iwlwifi driver fails to initialize the device due to a missing configuration profile. Environment: Board: NanoPi R5C OS Version: Armbian v26.2.1 Wi-Fi Module: Intel BE200 Failing Kernels: v6.19.0-edge-rockchip64, v6.18.10-current-rockchip64 Working Kernel: 6.12.58-current-rockchip64 Actual Behavior & Logs: When booting with v6.18.10-current-rockchip64 or v6.19.0-edge-rockchip64, the Wi-Fi interface does not show up. Checking dmesg reveals the following iwlwifi probe failure (error -22): [ +0.001360] iwlwifi 0000:01:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000 [ +0.000070] iwlwifi 0000:01:00.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200 [ +0.000012] No config found for PCI dev 272b/00f4, rev=0x472, rfid=0x112200 [ +0.026664] iwlwifi 0000:01:00.0: probe with driver iwlwifi failed with error -22 pi@nanopi-r5c:~$ ls /lib/firmware/iwlwifi-gl-c0-fm-c0* /lib/firmware/iwlwifi-gl-c0-fm-c0-100.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-96.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-100.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-96.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-101.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-97.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-101.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-97.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-83.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-98.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-83.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-98.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-86.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-c101.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-86.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-c101.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-90.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-c102.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-90.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-c102.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-92.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-c103.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0-92.ucode.zst /lib/firmware/iwlwifi-gl-c0-fm-c0.pnvm /lib/firmware/iwlwifi-gl-c0-fm-c0-94.ucode /lib/firmware/iwlwifi-gl-c0-fm-c0.pnvm.zst /lib/firmware/iwlwifi-gl-c0-fm-c0-94.ucode.zst Workaround: Downgrading the kernel to 6.12.58-current-rockchip64 via armbian-config completely resolves the issue, and the BE200 module works as expected. It seems there might be a regression or missing iwlwifi config definitions for the BE200 in the recent rockchip64 kernel builds. I would appreciate it if you could look into this. Thank you!
  6. Hello, I have H96 Max TV box with RK3528 chip (4GB RAM, 64GB eMMC, Android 13, build RZX.V01.20240924). Board: RK3528_DDR3_8X4_V12. Problem: Box does not boot from TF card at all. No HDMI output, no DHCP lease, nothing. What I have: TF card slot on the box 1x USB 2.0 port, 1x USB 3.0 port No serial/UART adapter (DEBUG header visible on PCB but not connected) Android 13 still working on EMMC ADB access with root What I tried: Built Armbian with BOARD=rk3528-tvbox BRANCH=legacy BUILD_MINIMAL=yes RELEASE=trixie Extracted DTB from Android boot partition, added to image Wrote image to TF card with dd Verified RKNS header at sector 64 - correct Tried replacing idbloader with one from our custom U-Boot build Original U-Boot on EMMC appears to ignore TF card completely Question: How to make original U-Boot boot from TF card? Or is there a way to install Armbian to EMMC safely while keeping ability to recover? Device AIDA64 info: Model: H96_Max_RK3528 Device: rk3528_box Hardware: rk30board Thank you!
  7. Support for rotation is better in modern 6.18.y Linux. Fastest is to download image and try https://www.armbian.com/boards/roc-rk3399-pc But VPU acceleration in rotated screen might be a problem ... and you will need to generate Gnome desktop image to facilitate Wayland or no fun.
  8. This week saw significant development activity across the Armbian ecosystem, with numerous enhancements to desktop environment support, including the addition of KDE Neon, KDE Plasma, MATE, and i3-wm, as well as improved branding and menu documentation. The desktop module was refactored for greater modularity and YAML-driven configuration, alongside fixes for theming and package removal tracking. Hardware support expanded with new device trees for NanoPC-T6 LTS Plus and Gateway DK, plus initial support for Arduino UNO Q (Qualcomm QRB2210) and additional USB Ethernet drivers. The build system received updates for kernel versions and distribution releases, notably bumping Ubuntu from plucky/noble to resolute. Automation and audit scripts were improved for reliability and scope, and documentation was updated to reflect the new tier model and branding. Overall, these changes strengthen Armbian's usability, hardware compatibility, and developer tooling. ChangesAdd board_introduced field to reusable boards and JSON output. by @igorpecovnik in armbian/armbian.github.io#272Add desktop descriptions and disable host check. by @igorpecovnik in armbian/configng#802Add Desktops menu header documentation. by @igorpecovnik in armbian/configng#803Add Gateway DK board image and Mono vendor logo. by @igorpecovnik in armbian/armbian.github.io#273Add i3-wm desktop support with branding. by @igorpecovnik in armbian/configng#811Add INTRODUCED property to all board configs. by @igorpecovnik in armbian/build#9634Add KDE Neon desktop support (Ubuntu only). by @igorpecovnik in armbian/configng#814Add KDE Plasma desktop support. by @igorpecovnik in armbian/configng#812Add MATE desktop support with branding and menu. by @igorpecovnik in armbian/configng#810add more special extensions. by @efectn in armbian/actions#16Add python3-yaml to package dependencies. by @igorpecovnik in armbian/configng#816Add support for Arduino UNO Q (Qualcomm QRB2210). by @SuperKali in armbian/build#9623arduino-uno-q: fix CI build by fetching qcombin at image creation time. by @SuperKali in armbian/build#9642arduino-uno-q: install USB gadget scripts unconditionally in BSP. by @SuperKali in armbian/build#9649arm64: dts: rockchip: add NanoPC-T6 LTS Plus device tree. by @igorpecovnik in armbian/linux-rockchip#462audit: allow Claude to write edits + stash execution log. by @igorpecovnik in armbian/configng#836audit: fix git-dir error and path references for claude-code-action. by @igorpecovnik in armbian/configng#832audit: fix git-dir, output ref, and bump max-turns to 30. by @igorpecovnik in armbian/configng#833audit: scope bot PR to YAML changes only. by @igorpecovnik in armbian/configng#835audit: skip status:unsupported DEs + relocate audit scripts. by @igorpecovnik in armbian/configng#826audit: switch to claude-code-action with OAuth token. by @igorpecovnik in armbian/configng#831audit_apply: handle calls larger than the per-minute budget. by @igorpecovnik in armbian/configng#828audit_apply: throttle + retry around the per-minute rate limit. by @igorpecovnik in armbian/configng#827bianbu: bump noble snapshot from v2.2 to v2.3. by @igorpecovnik in armbian/configng#839Bump rockchip armhf edge kernel to 7.0.0. by @paolosabatino in armbian/build#9635config/distributions: plucky -> eos, resolute -> supported. by @igorpecovnik in armbian/build#9657desktops: disable cinnamon on armhf. by @igorpecovnik in armbian/configng#823desktops: enable armhf for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#820desktops: enable riscv64 for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#822desktops: optional APT pin preferences in repo block. by @igorpecovnik in armbian/configng#838desktops: ship YAML/parser/branding assets in the .deb. by @igorpecovnik in armbian/configng#817desktops: tier system, install/remove correctness, and a pile of small fixes. by @igorpecovnik in armbian/configng#824docs: rewrite Desktops-header.md for the tier model. by @igorpecovnik in armbian/configng#825extensions: skip git fetches during config-dump-json. by @igorpecovnik in armbian/build#9648feat: add device tree editor module. by @igorpecovnik in armbian/configng#797feat: add QDL flash support for Qualcomm EDL devices. by @SuperKali in armbian/imager#127feat: track desktop packages for clean removal. by @igorpecovnik in armbian/configng#799Fix desktop module variable scoping and cleanup. by @igorpecovnik in armbian/configng#796gateway-dk-ask: build kernel modules in-tree for CI compatibility. by @tomazzaman in armbian/build#9650Increase timeout for unit tests from 15 to 30 minutes. by @igorpecovnik in armbian/configng#800initialize: add script-wide debug_log and --debug flag. by @igorpecovnik in armbian/configng#818json-generation: fix some app edge cases. by @efectn in armbian/armbian.github.io#276mainline: bump to 7.0-rc7. by @EvilOlaf in armbian/build#9637Mono gateway dk. by @tomazzaman in armbian/build#9640nightly: bump Ubuntu release from plucky/noble to resolute. by @igorpecovnik in armbian/armbian.github.io#278Optimize Cinnamon desktop and fix theming. by @igorpecovnik in armbian/configng#805Refactor desktop module: YAML-driven, modular architecture. by @igorpecovnik in armbian/configng#815rockchip: add rtl8152 and dm9601 usb ethernet. by @netrunnereve in armbian/build#9638rockchip: RK3506: Increase DMA coherent pool. by @vidplace7 in armbian/build#9636SLO: fixing few sentences in Slo language that sounds weird. by @igorpecovnik in armbian/website#1u-boot: v2026.04 (final) fixes and bumps for some boards. by @rpardini in armbian/build#9654Update Desktops header: add Imager URL and auto-login note. by @igorpecovnik in armbian/configng#804Update theme colors and fonts to match armbian.com. by @igorpecovnik in armbian/documentation#902View the full article
  9. This week saw significant development activity across the Armbian ecosystem, with numerous enhancements to desktop environment support, including the addition of KDE Neon, KDE Plasma, MATE, and i3-wm, as well as improved branding and menu documentation. The desktop module was refactored for greater modularity and YAML-driven configuration, alongside fixes for theming and package removal tracking. Hardware support expanded with new device trees for NanoPC-T6 LTS Plus and Gateway DK, plus initial support for Arduino UNO Q (Qualcomm QRB2210) and additional USB Ethernet drivers. The build system received updates for kernel versions and distribution releases, notably bumping Ubuntu from plucky/noble to resolute. Automation and audit scripts were improved for reliability and scope, and documentation was updated to reflect the new tier model and branding. Overall, these changes strengthen Armbian's usability, hardware compatibility, and developer tooling. ChangesAdd board_introduced field to reusable boards and JSON output. by @igorpecovnik in armbian/armbian.github.io#272Add desktop descriptions and disable host check. by @igorpecovnik in armbian/configng#802Add Desktops menu header documentation. by @igorpecovnik in armbian/configng#803Add Gateway DK board image and Mono vendor logo. by @igorpecovnik in armbian/armbian.github.io#273Add i3-wm desktop support with branding. by @igorpecovnik in armbian/configng#811Add INTRODUCED property to all board configs. by @igorpecovnik in armbian/build#9634Add KDE Neon desktop support (Ubuntu only). by @igorpecovnik in armbian/configng#814Add KDE Plasma desktop support. by @igorpecovnik in armbian/configng#812Add MATE desktop support with branding and menu. by @igorpecovnik in armbian/configng#810add more special extensions. by @efectn in armbian/actions#16Add python3-yaml to package dependencies. by @igorpecovnik in armbian/configng#816Add support for Arduino UNO Q (Qualcomm QRB2210). by @SuperKali in armbian/build#9623arduino-uno-q: fix CI build by fetching qcombin at image creation time. by @SuperKali in armbian/build#9642arduino-uno-q: install USB gadget scripts unconditionally in BSP. by @SuperKali in armbian/build#9649arm64: dts: rockchip: add NanoPC-T6 LTS Plus device tree. by @igorpecovnik in armbian/linux-rockchip#462audit: allow Claude to write edits + stash execution log. by @igorpecovnik in armbian/configng#836audit: fix git-dir error and path references for claude-code-action. by @igorpecovnik in armbian/configng#832audit: fix git-dir, output ref, and bump max-turns to 30. by @igorpecovnik in armbian/configng#833audit: scope bot PR to YAML changes only. by @igorpecovnik in armbian/configng#835audit: skip status:unsupported DEs + relocate audit scripts. by @igorpecovnik in armbian/configng#826audit: switch to claude-code-action with OAuth token. by @igorpecovnik in armbian/configng#831audit_apply: handle calls larger than the per-minute budget. by @igorpecovnik in armbian/configng#828audit_apply: throttle + retry around the per-minute rate limit. by @igorpecovnik in armbian/configng#827bianbu: bump noble snapshot from v2.2 to v2.3. by @igorpecovnik in armbian/configng#839Bump rockchip armhf edge kernel to 7.0.0. by @paolosabatino in armbian/build#9635config/distributions: plucky -> eos, resolute -> supported. by @igorpecovnik in armbian/build#9657desktops: disable cinnamon on armhf. by @igorpecovnik in armbian/configng#823desktops: enable armhf for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#820desktops: enable riscv64 for XFCE, MATE, i3-wm, Xmonad, Enlightenment, Cinnamon. by @igorpecovnik in armbian/configng#822desktops: optional APT pin preferences in repo block. by @igorpecovnik in armbian/configng#838desktops: ship YAML/parser/branding assets in the .deb. by @igorpecovnik in armbian/configng#817desktops: tier system, install/remove correctness, and a pile of small fixes. by @igorpecovnik in armbian/configng#824docs: rewrite Desktops-header.md for the tier model. by @igorpecovnik in armbian/configng#825extensions: skip git fetches during config-dump-json. by @igorpecovnik in armbian/build#9648feat: add device tree editor module. by @igorpecovnik in armbian/configng#797feat: add QDL flash support for Qualcomm EDL devices. by @SuperKali in armbian/imager#127feat: track desktop packages for clean removal. by @igorpecovnik in armbian/configng#799Fix desktop module variable scoping and cleanup. by @igorpecovnik in armbian/configng#796gateway-dk-ask: build kernel modules in-tree for CI compatibility. by @tomazzaman in armbian/build#9650Increase timeout for unit tests from 15 to 30 minutes. by @igorpecovnik in armbian/configng#800initialize: add script-wide debug_log and --debug flag. by @igorpecovnik in armbian/configng#818json-generation: fix some app edge cases. by @efectn in armbian/armbian.github.io#276mainline: bump to 7.0-rc7. by @EvilOlaf in armbian/build#9637Mono gateway dk. by @tomazzaman in armbian/build#9640nightly: bump Ubuntu release from plucky/noble to resolute. by @igorpecovnik in armbian/armbian.github.io#278Optimize Cinnamon desktop and fix theming. by @igorpecovnik in armbian/configng#805Refactor desktop module: YAML-driven, modular architecture. by @igorpecovnik in armbian/configng#815rockchip: add rtl8152 and dm9601 usb ethernet. by @netrunnereve in armbian/build#9638rockchip: RK3506: Increase DMA coherent pool. by @vidplace7 in armbian/build#9636SLO: fixing few sentences in Slo language that sounds weird. by @igorpecovnik in armbian/website#1u-boot: v2026.04 (final) fixes and bumps for some boards. by @rpardini in armbian/build#9654Update Desktops header: add Imager URL and auto-login note. by @igorpecovnik in armbian/configng#804Update theme colors and fonts to match armbian.com. by @igorpecovnik in armbian/documentation#902View the full article
  10. Yesterday
  11. @Nick A Thank you! That would be very helpful.⭐
  12. Nice @Kevin su. my results with the eth0 working was similar to yours. but after an "ip link set down dev eth0" got those lower. whatever. Its alive after all!
  13. Kernel 7.0 is out with broad hardware enablement and performance updates. Collabora contributed 227 patches from 24 developers, spanning major graphics work, multimedia fixes, and substantial enablement for Rockchip and MediaTek. View the full article
  14. Good afternoon. I bought a NanoPi R76s rev. 2 (3GB RAM + 0 EMMC). It works fine with the manufacturer's firmware. However, it doesn't boot on Armbian (26.02.1). I assume rev. 2 isn't supported. Is it possible to add support? Armbian_26.2.1_Nanopi-r76s_noble_vendor_6.1.115_gnome_desktop.img.xz --- my build from tag 26.02.1: (log https://paste.armbian.com/poduzitifu ) --- vendor ubuntu boot log https://drive.google.com/file/d/1OZqZk48LsbSzFz63fcqMKVp5YkhyNOoT/view?usp=drive_link (rk3576-sd-ubuntu-noble-gnome-desktop-6.1-arm64-20260403.img.gz)
  15. What's new in armbian-config desktops Pick how much desktop you want — at install time and after Three tiers (minimal / mid / full) instead of one monolithic install. Minimal = DE + display manager + a terminal (~500 MB). Mid adds a browser and everyday apps (~1 GB). Full adds office + creative tools (~2.5 GB). And you can move between tiers later — armbian-config knows the delta and only adds or removes what changed, no reinstall. Clean uninstall, every time Every install records a manifest of exactly which packages it added. Removal undoes only those — packages that were already on the system before you installed the desktop stay put. No more "I uninstalled XFCE and lost half my system." One YAML per desktop, no per-distro hacks Each DE is a single declarative file in tools/modules/desktops/yaml/. Adding or maintaining a desktop no longer means editing scripts; you describe what you want and the engine figures out releases, arches, browsers, and overrides. Adding a new desktop is a YAML edit and a parser smoke test, not a hunt through bash. Same desktop, every supported distro and arch Per-release and per-arch overrides handle the awkward edges: missing packages on armhf, the riscv64 ports that lag behind, the package that got renamed in Ubuntu noble. Same YAML works on Debian bookworm/trixie and Ubuntu noble across amd64 / arm64 / armhf / riscv64. Smart browser selection The literal token browser resolves to the right package per platform automatically — Chromium where it exists, Epiphany on platforms where Chromium is broken, Firefox-ESR on Debian riscv64. No more bug reports about "Chromium won't install on RISC-V." Custom vendor archives, done right Optional repo: block per DE with full support for: signed-by GPG keyring (no apt-key), per-release suite paths (e.g. SpacemiT's per-snapshot bianbu archive), multi-suite fan-out (one archive, six deb lines for security/updates/customization channels), wider component lists than main, and APT pin preferences in the same place. Removed cleanly on uninstall. Auto-login that doesn't trash your config Enable / disable autologin for gdm3, sddm, or lightdm via in-place sed edits — your WaylandEnable=false and other customizations stay intact. Branches on ID=ubuntu from /etc/os-release, so it writes to the right file (Debian's daemon.conf vs Ubuntu's custom.conf) without guessing from the codename. A weekly AI driven self-audit catches drift A scheduled workflow scans the YAML matrix against armbian/build's supported releases and the live Debian/Ubuntu archives — flags releases not yet covered, flags packages that no longer exist upstream — then opens a draft PR with proposed YAML fixes. Dead packages and missing releases stop accumulating silently. armbian-config --api module_desktops User documentation: https://docs.armbian.com/User-Guide_Armbian-Config/System/#desktop
  16. This was discussed some time ago. Everybody has the same problem with the 2.5Gb interface. The best you can do is to switch to linux 6.6.xx, replace the dtb, update the firmware in /lib/firmware/rtl_nic and run a script in /etc/rc.local (see here).
  17. use balena etcher or rufus, would work just fine! also you can use Hqnicolas have provided earlier, use a USB to TTL converter. works great if nothing works
  18. After over five years of development and collaboration across the Open Source community, mainline Linux support for Rockchip RK3588's video capture hardware has finally landed. View the full article
  19. Last week
  20. @Jugo Slaven it seems you are running Android not Armbian. These forums are for Armbian Linux not Android. You should ask your question at a site that deals with Android.
  21. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  22. The only thing I could manage to get information from was this: I had to rewrite the SPI-flash and now I see: Not sure if this helps: Btw, this is the output when I was using the official OrangePI Ubuntu distro:
  23. Problem solved. Rather than using an electrical connection I overcame the issue mechanically. When the board was mounted in the box I drilled a hole directly opposite the switch and inserted an old self propelling biro which I cut down to the right length. I left the spting in place but removed the latching mechanism in the lid. Pressing the top of the biro activated the switch🤪
  24. Looks like you are right. Did not want to modify uboot to make it understand f2fs , so i had to move /boot to ext4 and keep rest of / on f2fs. Now it boots. Thx for help.
  25. Hello, good afternoon. I'm using a translator, so I apologize if it's not clear. I have an Orange Pi 5 Plus SBC which I have Android installed on the m2 drive. I install Armbian on a microSD card. I don't remember what problem I was having, but I had to format the SPI Flash. After that, the Armbian version worked fine. Also, after formatting the SPI Flash, my microphone stopped working on Android (it works on Armbian). Could this be due to formatting the SPI Flash? Thank you.
  26. It will only work for h265, as that is the only hardware decoder available in the Pi 5. So it won't help you with for instance YouTube, as they use VP9 and AV1 (or you can force h264 with a browser plugin). You can try Firefox. https://bugzilla.mozilla.org/show_bug.cgi?id=1833354 Or change some of the flags in Chromium, but it feels as if they keep changing, so you might find other suggested flags all over the internet. You can set the mentioned flags in: chrome://flags/ https://bbs.archlinux.org/viewtopic.php?id=244031
  27. savznkvo
    @sven-ola it works with official ubuntu image and with debian 13 image from romanrm, so this ssd is 100% works
  28. Then it should not be an issue to find somebody from the community to come up with support. From official POV we do not add new boards without some sort of funding. Our resources are simply too limited.
