sorry for the delay, @mvpwar for RK3566 NPU https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/page/16/#findComment-211031 I think you will take fragments from ancient builds like this: https://github.com/hqnicolas/ubuntu-rockchip-joshua/tree/h96-max-v56-board-add https://github.com/Joshua-Riek/ubuntu-rockchip/compare/main...hqnicolas:ubuntu-rockchip-joshua:h96-max-v56-board-add I don't know what the status is in version 6.17 but we are still required to use vendor 6.1
Thank you for the nudge. But who are you nudging? It isn't up to the PR author (me) to get this accepted. It's been rotting away since nobody actually tested it. And that could only be done by people who have the device, including @The Tall Man, I believe or others. I do not have access to the device(s) in question. And then one of the other devs needs to accept it. I'm happy to rebase or respond to reviews, but that hadn't happened, so we are now going in circles. So, the question is really who you are nudging.
Hi, Werner and Tallman. The slow update did seem a bit odd to me - its why I mentioned my good network connection. I'll try again later and see what happens. I am in eastern europe, and we don't normally get this kind of problem. I used to have a network connection of only 6 Mbit/s until about a year ago, and even that worked OK at the time. (948 Mbit/s as we have now is great). Normally my Linux Mint apt-update is usually less than a minute. Tallman:- we seem to have common likes and dislikes!. First, Firefox is definitely not installed on my Armbian, so I'll have a look at trying to install it later. Like you, I also dislike Snap and Flatpak packages. My first experience with a computer was back in the early 1960's with a Honeywell 803 - it had 1K x 18bit word magnetic memory, so any program written to run on it (usually Algol 63 - more or less machine code) had to be *tiny*. A colleague wrote a successful program to play whist on it - it rather makes the bloat associated with snap/flatpak packages look very silly to someone like me. My programming experience ended some years ago for various reasons, but I am firmly convinced that modern machines could be far faster and more efficient than they are if modern programmers had to use much less memory. We had to be very careful how we used space, and spent time optimizing anything we wrote. (actually not written - it was mostly hand-punched paper tape. (whats a keyboard)? I believe if modern programmers had to do this, we would not hear so much about the insecurity of software/networks - and I won't even go into how much companies like Microsoft appear to contribute to this bloat. I would have thought that an OS should contain all the elements (dependency files) necessary to run any software compatible with the hardware, so therefore it should only be necessary to install 'system' packages, instead of snap/flatpak with all the attendant dependencies (bloat). - Sorry - rant over. Finally, another question, which is driving me nuts. While I was playing with Armbian, I accidentally dragged the LibreOffice Write icon over the Armbian Config Icon, and got a new 'unnamed icon' folder - and I can find no way to get rid of it. I assumed this created a similarly named folder somewhere, so all I had to do was delete it but extensive file searching hasn't traced it so far - any pointers please? Thanks again, Keith Edit: thanks for that Torz77 - should be able to find it, I guess.
Recently, when I run `armbian-upgrade`, I was greeted with an update to raspi-firmware. However, this version of firmware doesn't seem to work with the corresponding intramfs with kernel 6.12.44. sudo armbian-upgrade Hit:1 https://mirrors.ustc.edu.cn/armbian trixie InRelease Hit:2 https://mirrors.ustc.edu.cn/debian trixie InRelease Hit:3 https://mirrors.ustc.edu.cn/debian trixie-updates InRelease Hit:4 https://mirrors.ustc.edu.cn/debian-security trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 https://apt.syncthing.net syncthing InRelease [24.2 kB] Fetched 24.2 kB in 2s (14.8 kB/s) 2 packages can be upgraded. Run 'apt list --upgradable' to see them. The following packages will be upgraded: armbian-config raspi-firmware Summary: Upgraded: 2, Newly installed: 0, To remove: 0, Not upgraded: 0 Download size: 13.2 MB Space required/available: 272 kB / 553 GB Get:1 https://mirrors.ustc.edu.cn/armbian trixie/trixie-utils arm64 raspi-firmware all 1:1.20250915-1~bookworm [13.0 MB] Get:2 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.11.0-trunk.234.0923.175957 [157 kB] Fetched 13.2 MB in 2s (5,967 kB/s) (Reading database ... 46602 files and directories currently installed.) Preparing to unpack .../raspi-firmware_1%3a1.20250915-1~bookworm_all.deb ... Unpacking raspi-firmware (1:1.20250915-1~bookworm) over (1:1.20250430-4~bookworm) ... Preparing to unpack .../armbian-config_25.11.0-trunk.234.0923.175957_all.deb ... Unpacking armbian-config (25.11.0-trunk.234.0923.175957) over (25.11.0-trunk.192.0915.191809) ... Setting up armbian-config (25.11.0-trunk.234.0923.175957) ... Setting up raspi-firmware (1:1.20250915-1~bookworm) ... Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ... Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ... WARNING: Unsupported kernel version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Processing triggers for initramfs-tools (0.148.3) ... update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711 WARNING: Unsupported initramfs version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Summary: Upgraded: 0, Newly installed: 0, To remove: 0, Not upgraded: 0 How exactly should I do in this case? In the past, I normally invoke update-intramfs to perform the the intramfs update. Thanks,
jock replied to Hqnicolas's topic in Rockchip CPU Boxes
You're welcome @Hqnicolas 👍 -
We support Armbian software but not random software from the internet. RKdevtool is as far as I know a tool from Radxa, not Armbian, either. CPU boxes are cheap and cheap for a reason. Nobody really supports them. We give some very limited community support here. With your current random software this is not the right spot for you. Best of luck to you.
HW (features are determined by kernel used in the image) related issues are shared among all variants, desktop, cli, minimal, Debian or Ubuntu.
Hello, I have an Android M98-Y6 HDMI stick that reportedly has an Allwiner H313 processor with 2GB of RAM and 16GB of storage. When I opened the case, I identified the emcp memory module KMQNW000SM-B316. I don't have access to console mode. I can only access adb commands as root.The RAM type DDR3 seems LPDDR3 ( version ??) I've tried different Armbian images without success. Unfortunately, Secure Boot is enabled. I read this post and test Armbian-20240716-unofficial_24.5.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_xfce_desktop_Secure_Boot.img.tar.xz from Nick, without success I have an Android image named M96-Y6.img. Attached is the "dts" file devicetree.dts device_tree_dump.txt
@Fredrik thank you for the reply. I wonder what's Gnome doing to initialize the audio that's different from a regular (non-graphical) boot. FWIW I installed also Pipewire/Wireplumber and tried to test the audio through the PW ALSA emulation, but that didn't work either. Just out of curiosity, does speaker-test work from the CLI once booted into Gnome or is it just the sound test in Gnome settings that's working ?
I troubleshooted my problem! So for some reason (I'm not sure if this is for all x88 pro 10's), the SD card needed to be under pressure on it to read Multitool. So, throughout the entire Multitool process, I needed to hold down the SD card with my thumb. I did hurt a bit, but it flashed to the EMMC - Yesterday
I retried that image now but with a different installation method, booting into OOWOW (?) via the Function+Reset button, control via serial debug console. I then wget the image from my local server and dd out to /dev/mmcblock0. Subsequent boot was indeed successful.
The three holes could be access to a serial console if necessary. Ground Transmit Receive. If you want to try this, baudrate is most likely 115200 like all Allwinner SoCs.
I think the easiest would be to get/build an image with mesa-vpu extension enabled. Unfortunately there is no automated way to do the stuff this extension does while building, in a live system. In general there are two ways to get hw acceleration: panthor or proprietary mali blobs. Former is from my feels better for general desktop usage and latter for hw encoding/decoding. Both cannot co-exist, no idea why. Latter needs vendor kernel branch. This would give you a Noble Gnome desktop image with Panthor driver enabled: ./compile.sh BOARD=youyeetoo-r1-v3 BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers desktop_tools internet multimedia' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base ENABLE_EXTENSIONS=mesa-vpu KERNEL_CONFIGURE=no RELEASE=noble Feel free to test: https://testing.armbian.de/Armbian-unofficial_25.11.0-trunk_Youyeetoo-r1-v3_noble_vendor_6.1.115_gnome_desktop.img.xz
the current filogic kernel has no info [in github] for where it was forked from, and trying to apply incremental patches from kernel.org I found it contains pieces of 6.14 in an ostensibly 6.12 branch. @chainsx might you be able to divulge where you forked it from?
PR Has been merged. I rebuilt on commit 1cf20837d27a3c09d93395f075cc305c81b4663f and things look good. Build instructions remain the same as my last post on this /_\ _ _ _ __ | |__(_)__ _ _ _ ___ _ _ _ _ ___ / _|/ _(_)__(_)__ _| | / _ \| '_| ' \| '_ \ / _` | ' \___| || | ' \/ _ \ _| _| / _| / _` | | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \_,_|_||_\___/_| |_| |_\__|_\__,_|_| v25.11 rolling for Odroid C1 running Armbian Linux 6.12.49-current-meson Packages: Debian stable (trixie) Support: DIY (custom image) IPv4: (LAN) 192.168.1.95, 10.8.0.1, 10.10.0.1 (WAN) ww.xx.yy.zz IPv6: 0000:1111:2222:3333:444:555:6666:7777 Performance: Load: 2% Uptime: 23:36 Memory usage: 8% of 986M CPU temp: 49°C Usage of /: 15% of 6.9G
Has anyone here configured armbian with a Wayland desktop, and completely free of X11? How did you do it? I have compiled labwc and it works great with my orange pi zero 3, with bookworm or trixie... but I can't figure out how to configure a wayland greeter. I need to do this because my LCD driver can't work with X11 (panel-mipi-dbi-spi).
Helios64 - Armbian 23.08 Bookworm issues (solved)
TDCroPower replied to ebin-dev's topic in Rockchip
@ebin-dev could you perhaps update your post 1 and post your latest instructions and upload the files there? That would make it much easier to find the stable files. -
hexdump replied to pochopsp's topic in Amlogic CPU Boxes
@pochopsp - you can buy two tv-boxes of the same type at once from the same seller and they might have different hardware internally still - that is the reason why it is not prossible to provide really good images for tv boxes: the hardware is simply too random and often also low quality -
@emor acid could be your gpio settings for mmc0. Try the x98h image. If that doesn’t work you need to extract your android dts or use the one from the working Ubuntu.
The kernel 6.17 release benefits from improvements in the graphics subsystem, hardware enablement, and more! See where Collabora's kernel team contributed to this release. View the full article
leave a link for other users like @John Taylor to continue your work, also @fedes_gl could give a hand -
I know an expert in rk3528, his name is @fensoft we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request I would like to buy this board and join the fun that you have, but my country has literally started an embargo on all TV boxes -
Radxa-cubie-a5e second Ethernet port not work after update
Samixa replied to Samixa's topic in Allwinner sunxi
Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti
