Did you check already merged PRs which were adding new boards? Like https://github.com/armbian/build/pull/8754/files Should give some clues.
Lowest price is what makes it popular. But software is the biggest key of the package and there they are among the worst. On this SoC, we will be cooperating with SoC maker's board directly - working with Orangepi is too damaging for us: https://www.cnx-software.com/2025/04/27/muse-pi-pro-feature-packed-credit-card-sized-spacemit-m1-risc-v-sbc/ This will probably be done in a couple of weeks, so you can follow that and adjust accordingly.
Thank you for your quick answer, Jimbolaya. Yes, I did try different cables all with the same result. I wonder if there is another way to access the serial console, J13 perhaps? Albeit with some required soldering, I suppose. Then remains the question of which headers exactly relate to GND, TX and RX.
I noticed this problem a long time ago, but now I feel it is important to fix it: I get a slim black bar on the left side, and a portion of the pixels on the right get "cropped" because they don't fit in the LCD display area? Do you get the same in your LCD? Do you know a way to fix it? I am talking about this LCD: RED PCB LCD https://www.aliexpress.us/item/3256802847521952.html? -
Hi @Nick A I tried build your fork repository and facing the following error, Can you please help me to fix this error? Source code: https://github.com/NickAlilovic/build/ $ git remote -v origin git@github.com:NickAlilovic/build.git (fetch) origin git@github.com:NickAlilovic/build.git (push) $ git branch main * v20250306 Build command: ./compile.sh build BOARD=x96q-lpddr3-v1-3 BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=yes RELEASE=trixie Error: [π³|π±] git: Fetch from remote completed, rev-parsing... [ 'debootstrap-debian-devel' 'master' 'FETCH_HEAD' ] [π³|π±] Debootstrap version [ '1.0.142' for /armbian/cache/sources/debootstrap-debian-devel/debootstrap ] [π³|π±] Installing base system with 5 packages [ Stage 1/2 ] [π³|π¨] I: Retrieving InRelease [π³|π¨] I: Checking Release signature [π³|π¨] E: Release signed by unknown key (key id 762F67A0B2C39DE4) [π³|π¨] The specified keyring /usr/share/keyrings/debian-archive-keyring.gpg may be incorrect or out of date. [π³|π¨] You can find the latest Debian release key at https://ftp-master.debian.org/keys.html [π³|π₯] error! [ Debootstrap first stage failed /armbian/cache/sources/debootstrap-debian-devel/debootstrap trixie yes ] [π³|π₯] Cleaning up [ please wait for cleanups to finish ]
@jock Tested this and got a 1mim watchdog crash. I dont know if it helps to track this issue but with: "rk322x_tee_1.0.1-72-gf230aa2.bin" it goes to a 30mim. Like i said before, im kinda new to this. so i might have done something wrong when building armbian. If anyone here has a working build that does not trigger this watchdog, please let me know.
Update: It works now, however the power LED doesn't seem to light up, but the video card is detected in /dev
Wyse 3040 (N10D) can't boot UEFI USB image ?
Sonikku replied to MarkA007's topic in UEFI x86 / qemu x86 / arm64
I have managed to successfully install Armbian onto the DELL Wyse3040 As mentioned above, the way to do this is to use a PE environment that works on these devices. I used an old version of Hiren's BootCD and booted from it. Then I used a NTFS formatted flash drive with the unzipped image and used Roadkill's Disk Image to write it to the eMMC And it works, beautifully -
GmP replied to Jean-Francois Lessard's topic in Amlogic meson
Hi - thank you for the nice driver. Here is my contrbute: Device under test : T9_RK3318 (T9 Sunwell 3318 version 4+32 GB) Running: v25.11 rolling for RK3318 Box running Armbian Linux 6.12.55-current-rockchip64 Packages: Debian stable (trixie) Support: for advanced users (rolling release) Some info: RK3318:~# lsmod | grep tm tm16xx 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 28672 1 stmmac lsmod | grep i2c i2c_gpio 16384 0 i2c_algo_bit 12288 1 i2c_gpio ls /sys/bus/i2c/devices/ 5-0024 i2c-4 i2c-5 ls /sys/class/leds/display brightness device digits map_seg7 max_brightness num_digits num_segments power segments subsystem trigger uevent value ls -l /sys/class/leds/ total 0 lrwxrwxrwx 1 root root 0 Oct 26 11:53 display -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::alarm -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::alarm lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::colon -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::colon lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::lan -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::lan lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::pause -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::pause lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::play -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::play lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::usb -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::usb lrwxrwxrwx 1 root root 0 Oct 26 11:53 display::wlan -> ../../devices/platform/i2c-display/i2c-5/5-0024/leds/display::wlan lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::capslock -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::capslock lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::compose -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::compose lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::kana -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::kana lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::numlock -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::numlock lrwxrwxrwx 1 root root 0 Jan 1 1970 input3::scrolllock -> ../../devices/platform/ff600000.usb/xhci-hcd.0.auto/usb2/2-1/2-1:1.1/0003:248A:8208.0002/input/input3/input3::scrolllock lrwxrwxrwx 1 root root 0 Jan 1 1970 working -> ../../devices/platform/gpio-leds/leds/working Testing... echo "1234" > /sys/class/leds/display/value echo 1 > /sys/class/leds/display\:\:lan/brightness echo 1 > /sys/class/leds/display\:\:usb/brightness All the 7 functions and 4 digits are working and correctly associated. Also trigges are working. I still have this small bug which is stopping rolling messages: display-service -c [INFO] all digits and leds on /usr/sbin/display-service: 116: cannot create /sys/class/leds/display/message: Permission denied All the function leds reacts well (all on) but the four clock digits do not switch, most likey because of the message permission denied. However they do work writing directly in the "value" as above and in the picture. Edit: I have investigated a little and it seems that I am still using the tm16xx which came with the distribution, as depmod was failng. After a fresh recompile all your module load but nodes under "leds" are not there, it seems that the dtso/dtbo is not read - nothing appears in dmesg. Attached the working dtso file. rk3318-t9.dtso - Last week
It appears that the system control was not configured properly. In the default DTS the binding is "sun8i-a83t-system-controller" which appears to have been deprecated in favor of the suffix "system-control" from what I could find. So tested with "sun8i-a83t-system-control" and "sun8-h3-system-control" as a fall back option. This time we no complaints from Cedrus: ryzer@cubietruckplus:~$ sudo dmesg | grep cedrus [ 10.624985] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 10.652836] cedrus 1c0e000.video-codec: Device registered as /dev/video0 Second test was to ensure that the video-engine clocks are set correctly, which can be done by temporarily disabling driver suspension. ryzer@cubietruckplus:/sys/kernel$ sudo cat debug/clk/bus-ve/clk_enable_count 1 ryzer@cubietruckplus:/sys/kernel$ sudo cat debug/clk/ve/clk_enable_count 1 ryzer@cubietruckplus:/sys/kernel$ sudo cat debug/clk/dram-ve/clk_enable_count 1 Next test trying to get working which should be using the version of ffmpeg as detailed here: This is the current output of ffmpeg: ffmpeg version 5.1.7-0+deb12u1 Copyright (c) 2000-2025 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --arch=arm --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libv4l2 --enable-v4l2-request --enable-v4l2-m2m --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared libavutil 57. 28.100 / 57. 28.100 libavcodec 59. 37.100 / 59. 37.100 libavformat 59. 27.100 / 59. 27.100 libavdevice 59. 7.100 / 59. 7.100 libavfilter 8. 44.100 / 8. 44.100 libswscale 6. 7.100 / 6. 7.100 libswresample 4. 7.100 / 4. 7.100 libpostproc 56. 6.100 / 56. 6.100 Hardware acceleration methods: vdpau vaapi drm opencl vulkan It is also worth mention that as there is no support for the SGX544 GPU, we are limited to a CLI only interface for which MPV can only be launched full-screen. MPV fails to use hardware decoding and falls back to using software. MPV version is reported as 0.35.1 [ 3.639][v][vo/gpu-next/opengl] Initializing GPU context 'drm' [ 3.643][e][vo/gpu-next] Can't handle VT release - signal already used [ 3.647][w][vo/gpu-next/opengl] Failed to set up VT switcher. Terminal switching will be unavailable. [ 3.651][v][vo/gpu-next/opengl] Initializing KMS [ 3.657][v][vo/gpu-next/opengl] Picked DRM card 0, primary node /dev/dri/card0 as the default. [ 3.662][v][vo/gpu-next/opengl] Driver: sun4i-drm 1.0.0 (0) [ 3.666][v][vo/gpu-next/opengl/kms] Connector 63 currently connected to encoder 62 [ 3.670][v][vo/gpu-next/opengl/kms] Selected Encoder 62 with CRTC 61 [ 3.675][v][vo/gpu-next/opengl/kms] Selected mode: 1920x1200 (1920x1200@60.00Hz) [ 3.679][v][vo/gpu-next/opengl] DRM Atomic support found [ 3.684][v][vo/gpu-next/opengl/kms] Using overlay plane 51 as draw plane [ 3.689][v][vo/gpu-next/opengl/kms] Using primary plane 57 as drmprime plane [ 3.693][v][vo/gpu-next] GBM_FORMAT_ARGB8888 not supported by draw plane: Falling back to GBM_FORMAT_XRGB8888. [ 3.697][v][vo/gpu-next] Supported modifier: 0x0 [ 3.702][v][vo/gpu-next] Creating GBM device [ 4.915][v][vo/gpu-next] Initializing GBM surface (1920 x 1200) [ 4.920][e][vo/gpu-next] Failed to create GBM surface. [ 4.924][e][vo/gpu-next] Failed to setup GBM. [ 5.397][v][vd] Container reported FPS: 30.000000 [ 5.405][v][vd] Codec list: [ 5.409][v][vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 5.414][v][vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [ 5.418][v][vd] Opening decoder h264 [ 5.424][v][vd] Looking at hwdec h264-drm... [ 5.428][v][vd] Could not create device. [ 5.433][v][vd] No hardware decoding available for this codec. [ 5.437][v][vd] Using software decoding. [ 5.445][v][vd] Detected 8 logical cores.
KickPi K2B not booting up: DRAM setup not supported
chuanzz replied to chuanzz's topic in KickPi K2B
Iβve sent the URL and details here, hoping they can take a look -
I recently noticed my ODroid XU4 was reporting weird temperature readings: cat /sys/class/thermal/thermal_zone0/temp -22000 Is this a software issue or maybe hardware failing? Also, I would like to upgrade, is there another board I could just transfer my EMMC to and be up and running? Thanks
Armbian with preinstalled OpenMediaVault (OMV)
usual user replied to Igor's topic in Software, Applications, Userspace
Out of curiosity, does it work if you drop my firmware build in place? dd bs=512 seek=1 conv=notrunc,fsync if=u-boot-meson.bin of=/dev/${entire-device-to-be-used} u-boot-meson.bin.tgz -
Hey @Adrienne, Github thread talks about two to three ways to so solve the issue. Did you apply the one that removes the symlinks ?
A phandle is a magical number assigned during DTB assembly, whose value is irrelevant as long as it references the same node with the phandle property. The magic value can change when the structure changes because it is assigned arbitrarily; for example, by inserting an additional node.
@BipBip1981, can you please share again your feedback on fancontrol running on Trixie ? The site can't display the image.
He works as ili9341 and as ili9486. I use it now as ili9486. I`ll go further to make it work as native device. DRM frambuffer its something what needs to be kernel recompiled... as i know? And if i want to use it natively, i must edit or recompile u-boot.... DRM support for ILI9486 display panels modulename: ili9486.ko configname: CONFIG_TINYDRM_ILI9486 Linux Kernel Configuration ββ>Device Drivers ββ>Graphics support ββ>Direct Rendering Manager (XFree86 4.1.0 and higher DRI support) ββ>SPI support ββ>DRM support for ILI9486 display panels In linux kernel since version 4.14.326 (release Date: 2023-09-23) DRM driver for the following Ilitek ILI9486 panels: * PISCREEN 3.5" 320x480 TFT (Ozzmaker 3.5") * RPILCD 3.5" 320x480 TFT (Waveshare 3.5") If M is selected the module will be called ili9486. I will use it for KlipperScreen π But as i se how hard is working that orangePi PC,i`ll doubt if i need this... Any way i`ll try )) Yes. But HDMI not connected. On OrangePiOne image its switching. If HDMI is connected its use it with no output to SPI. But if no HDMI present its use SPI as basic overlay On the same board. Because OPiOne had only 1 usb, OPiPC work only 1 usb ))) if whey work all 3, i`ll didnt open up a topic π ili9486.dts
Hello, has anyone managed to get this camera to work on zero 3?
Request to update distro: park heads of hard disk(s) before shutdown....
ean365 replied to ean365's topic in Odroid XU4
Hmmm. Never mind, maybe. I see that Armbian has it included here, but for some reason it was not installed automatically. https://github.com/armbian/build/tree/main/packages/bsp/odroid -
Sorry for the late feedback. I was waiting for a new kernel update (6.12.54-bcm2711) to confirm it was all right. Just as what @Werner said, in the `/etc/initramfs/post-update.d/z50-raspi-firmware` contains snippets of the code that prints out the error. And it's indeed no actual harm. Also, without setting on-hold of the `raspi-firmware`, kernel updates works just fine. We are good. Thank you all!
