  2. Update: sicXnull/armbian-build (H96q) + "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" and "secure-boot.patch" solved the problem. Now, the ethernet interface is fully functional. Thank you Nick & sicXnull.
  3. Yesterday
  4. I downloaded the image. And yes, of course, I needed to set up the wifi connection when armbian asked me to.
  5. Hi there. I just got my hands on a brand new 5T with 24GB of RAM and installed Armbian 26.04 minimal on it (on an SD card - no eMMC on this board). I immediately put it to use running CI jobs, however started seeing segfaults and things almost straight away. Current power source is the Radxa 60W power supply. Currently passively cooled (with the Radxa heat sink). Hasn't gone over 70º in the last 24 hours, even when maxxed out compiling rust packages. Here's information about the board: james@kassandra:~$ cat /proc/device-tree/model Radxa ROCK 5Tjames@kassandra:~$ james@kassandra:~$ dpkg -l | grep '^ii linux-' ii linux-base 4.15ubuntu5 all Linux image base package ii linux-dtb-current-rockchip64 26.2.5 arm64 Armbian Linux current DTBs in /boot/dtb-6.18.24-current-rockchip64 ii linux-image-current-rockchip64 26.2.5 arm64 Armbian Linux current kernel image 6.18.24-current-rockchip64 ii linux-libc-dev:arm64 7.0.0-15.15 arm64 Linux Kernel Headers for development ii linux-u-boot-rock-5t-current 26.2.5 arm64 Das U-Boot for rock-5t james@kassandra:~$ sudo dd if=/dev/mmcblk1 bs=512 count=8192 2> /dev/null | strings | grep '^DDR' DDR 9fa84341ce typ 24/09/06-09:51:11,fwver: v1.18 I can reliably recreate the segfault by running `claude`: Bun v1.3.14 (0a466a11) Linux arm64 Linux Kernel v6.18.24 | glibc v2.43 CPU: neon fp aes crc32 atomics Args: "claude" Features: Bun.stderr(2) Bun.stdin(2) Bun.stdout(2) abort_signal(5) fetch(35) jsc spawn(8) standalone_executable yaml_parse claude_code Builtins: "bun:main" "node:assert" "node:async_hooks" "node:buffer" "node:child_process" "node:constants" "node:crypto" "node:dns" "node:events" "node:fs" "node:fs/promises" "node:http" "node:https" "node:module" "node:net" "node:os" "node:path" "node:path/posix" "node:path/win32" "node:perf_hooks" "node:process" "node:readline" "node:stream" "node:stream/consumers" "node:string_decoder" "node:timers/promises" "node:tls" "node:tty" "node:url" "node:util" "node:vm" "node:zlib" "ws" "node:http2" Elapsed: 9886ms | User: 3200ms | Sys: 775ms RSS: 72.61MB | Peak: 0.32GB | Commit: 72.61MB | Faults: 993 | Machine: 24.72GB panic(main thread): Segmentation fault at address 0x7300A749AD00 dmesg output: [54442.949901] 2.1.128: claude: potentially unexpected fatal signal 5. [54442.949933] CPU: 5 UID: 1000 PID: 540517 Comm: claude Not tainted 6.18.24-current-rockchip64 #2 PREEMPT [54442.949952] Hardware name: Radxa ROCK 5T (DT) [54442.949959] pstate: 00001000 (nzcv daif -PAN -UAO -TCO -DIT +SSBS BTYPE=--) [54442.949973] pc : 00000000031cb264 [54442.949980] lr : 00000000031cb264 [54442.949986] sp : 0000ffffece87fd0 [54442.949992] x29: 0000ffffece88070 x28: 000000000059aabe x27: 0000ffffb267f740 [54442.950016] x26: 0000000000000004 x25: 0000ffffece884c8 x24: 0000ffffece887b8 [54442.950035] x23: 0000ffffece88850 x22: 000000000691c000 x21: 0000ffffece88540 [54442.950055] x20: 000000000691c000 x19: 0000ffffece886d0 x18: 0000000000000000 [54442.950073] x17: 0000ffffb28386a0 x16: 0000000006a12ff0 x15: 0000000000000034 [54442.950092] x14: 0000000000000032 x13: 0000000000000003 x12: aaaaaaaaaaaaaaaa [54442.950111] x11: 0101010101010101 x10: 0000000000000000 x9 : 0000000000000000 [54442.950130] x8 : 0000000000000086 x7 : 0000000000000000 x6 : 0000000000000000 [54442.950148] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000 [54442.950165] x2 : 0000000000000000 x1 : 0000ffffb2a3bc90 x0 : 0000000000000000 I tried running stress-ng and saw thousands of failures leading to a hard lockup: stress-ng: info: [542138] setting to a 10 mins run per stressor stress-ng: info: [542138] dispatching hogs: 8 vm stress-ng: info: [542139] vm: using 1.35GB per stressor instance (total 10.79GB of 13.48GB available memory) stress-ng: fail: [542153] checkerboard: detected 4 memory errors stress-ng: fail: [542149] galpat-one: detected 2437 memory errors stress-ng: fail: [542148] flip: detected 32 memory errors stress-ng: fail: [542147] flip: detected 96 memory errors stress-ng: fail: [542152] galpat-one: detected 5632 memory errors stress-ng: fail: [542148] galpat-one: detected 818 memory errors stress-ng: fail: [542147] fwdrev: detected 48 memory errors stress-ng: fail: [542149] gray code (flip): detected 96 memory errors stress-ng: fail: [542150] flip: detected 96 memory errors stress-ng: fail: [542147] galpat-one: detected 1980 memory errors stress-ng: fail: [542148] gray code: detected 160 memory errors stress-ng: fail: [542150] fwdrev: detected 112 memory errors stress-ng: fail: [542149] incdec code: detected 160 memory errors stress-ng: fail: [542150] galpat-one: detected 1740 memory errors stress-ng: fail: [542149] inc-nybble: detected 32 memory errors stress-ng: fail: [542148] incdec code: detected 16 memory errors stress-ng: fail: [542152] incdec code: detected 16 memory errors stress-ng: fail: [542151] flip: detected 288 memory errors stress-ng: fail: [542154] flip: detected 288 memory errors stress-ng: fail: [542153] flip: detected 144 memory errors stress-ng: fail: [542151] galpat-one: detected 256 memory errors stress-ng: fail: [542153] galpat-one: detected 871 memory errors stress-ng: fail: [542149] modulo X: detected 2 memory errors stress-ng: fail: [542149] info: 5 failures reached, aborting stress process stress-ng: fail: [542144] vm: detected 2727 bit errors while stressing memory stress-ng: error: [542138] vm: [542144] terminated with an error, exit status=2 (stressor failed) stress-ng: fail: [542148] modulo X: detected 4 memory errors stress-ng: fail: [542148] info: 5 failures reached, aborting stress process stress-ng: fail: [542142] vm: detected 1030 bit errors while stressing memory stress-ng: error: [542138] vm: [542142] terminated with an error, exit status=2 (stressor failed) stress-ng: fail: [542152] modulo X: detected 3 memory errors stress-ng: fail: [542150] modulo X: detected 8 memory errors stress-ng: fail: [542147] modulo X: detected 1 memory error stress-ng: fail: [542150] moving inversion: detected 12 memory errors stress-ng: fail: [542150] info: 5 failures reached, aborting stress process stress-ng: fail: [542139] vm: detected 1968 bit errors while stressing memory stress-ng: error: [542138] vm: [542139] terminated with an error, exit status=2 (stressor failed) stress-ng: fail: [542151] modulo X: detected 5 memory errors stress-ng: fail: [542152] one-zero: detected 7881 memory errors stress-ng: fail: [542151] moving inversion: detected 168 memory errors stress-ng: fail: [542153] modulo X: detected 37 memory errors stress-ng: fail: [542146] vm: detected 13532 bit errors while stressing memory stress-ng: error: [542138] vm: [542146] terminated with an error, exit status=2 (stressor failed) stress-ng: fail: [542147] mscan: detected 640 memory errors stress-ng: fail: [542147] info: 5 failures reached, aborting stress process stress-ng: fail: [542143] vm: detected 2765 bit errors while stressing memory stress-ng: error: [542138] vm: [542143] terminated with an error, exit status=2 (stressor failed) stress-ng: fail: [542153] moving inversion: detected 32 memory errors stress-ng: fail: [542153] info: 5 failures reached, aborting stress process stress-ng: fail: [542141] vm: detected 1088 bit errors while stressing memory stress-ng: error: [542138] vm: [542141] terminated with an error, exit status=2 (stressor failed) Anyone have any advice on how to fix this? Is it faulty DDR or a firmware issue?
  6. Has anyone found a working gpiolib implementation for Armbian on Orange Pi 5? I'm aware of wiringPi and it sort of works. However, being able to use the "real stuff" so to speak would make my life easier.
  7. Hi @falbriard, I don't know where your image is from and to what RISC-V build of Chrome browser you are referring. Anyhow, you are free to test my latest image build from current main commit 3ce7dec74. Go to https://privat-in.de/ follow Downloads and flash Armbian-unofficial_26.05.0-trunk_Orangepirv2_trixie_current_6.18.26_minimal.img from there. You will find a script in /root which installs Gnome with GPU and Chromium. Any GPU stuff is from a mirror of the Bianbu Linux (Chinese Ubuntu variant from SpacemiT). Be warned: You may get a kernel downgrade if you install current Armbian upgrades. The image comes with 6.18.26-current-spacemit (from main) but Armbian repos may deliver 6.6 until that main-current-6.18 makes it to the update repos. HTH // Sven-Ola
  8. Okay slight update, I have successfully booted https://forum.armbian.com/topic/56130-radxa-cubie-a7aa7z-allwinner-a733 linux 6.6.98-vendor-sun60iw2 kernel and debootstrapped Bookworm (Debian 12) on it using userdata as root fs. Basically I got in using: aliexpress.com/item/1005009243708714.html Micro SD Sniffer aliexpress.com/item/1005010529282186.html in 1.8v mode(important!) And fiddling with the u-boot endlessly after i first sabotaged the auto-boot process. Display is alive, usb subsystem does not work, does not probe. Wifi would be next so I can ditch the tf uart. All your bases belong to us, resistance is futile!
  9. Collabora brought Bluetooth Auracast broadcasting to MediaTek Genio 700 for Embedded World 2026. Here's the complete, fully Open Source setup featuring Debian, BlueZ, PipeWire, with all the code and configs from our live booth demo. View the full article
  10. I am not using WOL on any of my devices, I have no personal experience with the software on the Helios or any other platform.
  11. Hi @Ross Cawston I've been using your patch for a few months on Orange Pi 5 Plus/Max SBCs with Linux kernels from 6.19 to 7.0.3 and it works well encoding H.264 streams (didn't try H.265, though) Thank you for your contribution. There's still no support for `rkvenc` in edge kernels (as of 7.1rc2).
  12. This week's work centers on release pipeline modernization, desktop and userland refinements, and board and kernel platform maintenance. On the release and CI side, the build matrix gained codename parameterisation with Ubuntu 26.04 "resolute" set as default, a dedicated Bianbu target, and exposed map overrides, while standard-support targets now include UEFI desktops and a plain cloud variant. The KDE fast-HDMI matrix was switched from kde-neon to kde-plasma, mesa-vpu was dropped from auto-attached extensions, and external CI now skips slots with a warning when upstream sources break. Supporting fixes route forky/loong64 base-files lookups to the main archive and add AI cover image generation to the blog workflow. Desktop and userland changes focus on the Bianbu environment, where PVR DRI was enabled, detection corrected, menu entries added, systemd suspend re-enabled on K1, and gnome-initial-setup purged post-install. Broader fixes pass --allow-downgrades on pinned package installs, align LAN/WAN labels across IPv4 and IPv6 rows in the MOTD, harden console-width handling against invalid COLUMNS values, and correct output to /etc/armbian-image-release. Platform support sees explicit ARCH=arm64 declarations on five inheriting boards, validate-board-config now following inheritance from ${SRC}/config/boards, and targeted fixes for imx8m binman hooks and rockchip family tweaks under forky (addgroup → groupadd). Kernel and DTS work restores 6.18.y on sm8550, syncs CAINIAO CNIoT-CORE DTS from 6.18 to 6.12, disables broken drm/xe patches under uefi-loong64-7.0, and improves the SMART AM40 and Retroid Pocket board definitions. AX210 firmware lands for mainline, and Seeed Studio reComputer images join the catalogue. #Armbian #EmbeddedLinux #ARM64 #Rockchip #Ubuntu #KDE #Mainline ChangesAdd AX210 firmware for mainline kernel. by @ginkage in armbian/firmware#126Add Seeed Studio reComputer board images and vendor logo. by @baorepo in armbian/armbian.github.io#297boards: declare ARCH=arm64 explicitly on five inheriting boards. by @igorpecovnik in armbian/build#9747ci/external: skip slot with warning when upstream source breaks. by @igorpecovnik in armbian/armbian.github.io#301ci/maintenance-unit-tests: list docker state on the runner. by @igorpecovnik in armbian/configng#903desktops/bianbu: enable PVR DRI, fix detection, add menu entries. by @igorpecovnik in armbian/configng#897desktops/bianbu: purge gnome-initial-setup after install. by @igorpecovnik in armbian/configng#902desktops/bianbu: re-enable systemd suspend on K1. by @igorpecovnik in armbian/configng#900desktops: pass --allow-downgrades on pinned package install. by @igorpecovnik in armbian/configng#899DTS: Sync CAINIAO CNIoT-CORE from 6.18 to 6.12. by @retro98boy in armbian/build#9736Fix workflow bugs and add AI cover image generation. by @igorpecovnik in armbian/armbian.github.io#298fix: rename imx8m bare hook so binman pkg_resources patch can run. by @igorpecovnik in armbian/build#9752fix: rockchip family_tweaks fails on forky — addgroup → groupadd. by @igorpecovnik in armbian/build#9753fix: route forky/loong64 base-files lookups to the main archive. by @igorpecovnik in armbian/armbian.github.io#299fixing output to /etc/armbian-image-release. by @dittodhole in armbian/build#9729Handle invalid data in COLUMNS env var when determining console width. by @scollinson in armbian/build#9631kernel: add linux-initramfs-tool as dep of linux-image package. by @amazingfate in armbian/build#9731motd/20-ip-info: align (LAN)/(WAN) labels across IPv4 + IPv6 rows. by @igorpecovnik in armbian/build#9728os-info: add Ubuntu 26.04 (resolute). by @igorpecovnik in armbian/imager#134patch: disable broken drm/xe patches under uefi-loong64-7.0. by @igorpecovnik in armbian/build#9745release-targets/standard-support.manual: add UEFI desktops + plain cloud. by @igorpecovnik in armbian/armbian.github.io#304release-targets: codename parameterisation, resolute default, Bianbu target, exposed.map overrides. by @igorpecovnik in armbian/armbian.github.io#295release-targets: drop mesa-vpu from auto-attached extensions. by @igorpecovnik in armbian/armbian.github.io#302release-targets: switch fast-HDMI KDE matrix from kde-neon to kde-plasma. by @igorpecovnik in armbian/armbian.github.io#303Retroidpocket: fix current and add edge as target. by @EvilOlaf in armbian/build#9724sm8550: Restore kernel 6.18.y for current and edge branch. by @kasimling in armbian/build#9737SMART AM40 improve. by @retro98boy in armbian/build#9735userpatches: skip jammy in items-from-inventory. by @igorpecovnik in armbian/os#460validate-board-config: follow source ${SRC}/config/boards inheritance. by @igorpecovnik in armbian/build#9748View the full article
  13. This week's work centers on release pipeline modernization, desktop and userland refinements, and board and kernel platform maintenance. On the release and CI side, the build matrix gained codename parameterisation with Ubuntu 26.04 "resolute" set as default, a dedicated Bianbu target, and exposed map overrides, while standard-support targets now include UEFI desktops and a plain cloud variant. The KDE fast-HDMI matrix was switched from kde-neon to kde-plasma, mesa-vpu was dropped from auto-attached extensions, and external CI now skips slots with a warning when upstream sources break. Supporting fixes route forky/loong64 base-files lookups to the main archive and add AI cover image generation to the blog workflow. Desktop and userland changes focus on the Bianbu environment, where PVR DRI was enabled, detection corrected, menu entries added, systemd suspend re-enabled on K1, and gnome-initial-setup purged post-install. Broader fixes pass --allow-downgrades on pinned package installs, align LAN/WAN labels across IPv4 and IPv6 rows in the MOTD, harden console-width handling against invalid COLUMNS values, and correct output to /etc/armbian-image-release. Platform support sees explicit ARCH=arm64 declarations on five inheriting boards, validate-board-config now following inheritance from ${SRC}/config/boards, and targeted fixes for imx8m binman hooks and rockchip family tweaks under forky (addgroup → groupadd). Kernel and DTS work restores 6.18.y on sm8550, syncs CAINIAO CNIoT-CORE DTS from 6.18 to 6.12, disables broken drm/xe patches under uefi-loong64-7.0, and improves the SMART AM40 and Retroid Pocket board definitions. AX210 firmware lands for mainline, and Seeed Studio reComputer images join the catalogue. #Armbian #EmbeddedLinux #ARM64 #Rockchip #Ubuntu #KDE #Mainline ChangesAdd AX210 firmware for mainline kernel. by @ginkage in armbian/firmware#126Add Seeed Studio reComputer board images and vendor logo. by @baorepo in armbian/armbian.github.io#297boards: declare ARCH=arm64 explicitly on five inheriting boards. by @igorpecovnik in armbian/build#9747ci/external: skip slot with warning when upstream source breaks. by @igorpecovnik in armbian/armbian.github.io#301ci/maintenance-unit-tests: list docker state on the runner. by @igorpecovnik in armbian/configng#903desktops/bianbu: enable PVR DRI, fix detection, add menu entries. by @igorpecovnik in armbian/configng#897desktops/bianbu: purge gnome-initial-setup after install. by @igorpecovnik in armbian/configng#902desktops/bianbu: re-enable systemd suspend on K1. by @igorpecovnik in armbian/configng#900desktops: pass --allow-downgrades on pinned package install. by @igorpecovnik in armbian/configng#899DTS: Sync CAINIAO CNIoT-CORE from 6.18 to 6.12. by @retro98boy in armbian/build#9736Fix workflow bugs and add AI cover image generation. by @igorpecovnik in armbian/armbian.github.io#298fix: rename imx8m bare hook so binman pkg_resources patch can run. by @igorpecovnik in armbian/build#9752fix: rockchip family_tweaks fails on forky — addgroup → groupadd. by @igorpecovnik in armbian/build#9753fix: route forky/loong64 base-files lookups to the main archive. by @igorpecovnik in armbian/armbian.github.io#299fixing output to /etc/armbian-image-release. by @dittodhole in armbian/build#9729Handle invalid data in COLUMNS env var when determining console width. by @scollinson in armbian/build#9631kernel: add linux-initramfs-tool as dep of linux-image package. by @amazingfate in armbian/build#9731motd/20-ip-info: align (LAN)/(WAN) labels across IPv4 + IPv6 rows. by @igorpecovnik in armbian/build#9728os-info: add Ubuntu 26.04 (resolute). by @igorpecovnik in armbian/imager#134patch: disable broken drm/xe patches under uefi-loong64-7.0. by @igorpecovnik in armbian/build#9745release-targets/standard-support.manual: add UEFI desktops + plain cloud. by @igorpecovnik in armbian/armbian.github.io#304release-targets: codename parameterisation, resolute default, Bianbu target, exposed.map overrides. by @igorpecovnik in armbian/armbian.github.io#295release-targets: drop mesa-vpu from auto-attached extensions. by @igorpecovnik in armbian/armbian.github.io#302release-targets: switch fast-HDMI KDE matrix from kde-neon to kde-plasma. by @igorpecovnik in armbian/armbian.github.io#303Retroidpocket: fix current and add edge as target. by @EvilOlaf in armbian/build#9724sm8550: Restore kernel 6.18.y for current and edge branch. by @kasimling in armbian/build#9737SMART AM40 improve. by @retro98boy in armbian/build#9735userpatches: skip jammy in items-from-inventory. by @igorpecovnik in armbian/os#460validate-board-config: follow source ${SRC}/config/boards inheritance. by @igorpecovnik in armbian/build#9748View the full article
  14. Last week
  15. You aren't telling us much, like what software you are using. I would expect you to need to give it something like smb://10.10.2.101/NAME_OF_SHARE/ or sftp://10.10.2.101:/path/to/folder You will also need to give it a username and password somehow. But first; have you checked you can reach it on the network?
  16. On my Debian13 VM that I use to build images for my boards, I have started to notice new errors that I have not seen before after this part of the logs... [🐳|🌱] After updating and cleaning image apt list cache [ 30 files ] [🐳|🌱] Image installed package hash [ ✅ base-files = 1-trixie-1armbian1-Bb095-U13.8--deb13u4-R55fa ] [🐳|🌱] Image installed package hash [ ✅ linux-image-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ] [🐳|🌱] Image installed package hash [ ✅ armbian-firmware = 1-SAa38b-B96c8-R448a ] [🐳|🌱] Image installed package hash [ ✅ armbian-bsp-cli-rockpro64-current = 1-PC1e15-V9ab0-H3400-Bd2e9-Rf36a ] [🐳|🌱] Image installed package hash [ ✅ linux-u-boot-rockpro64-current = 2025.01-S6d41-P6e2c-Hbf76-V6f3c-Be4e9-R448a ] [🐳|🌱] Image installed package hash [ ✅ linux-dtb-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ] [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/etc/resolv.conf' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/initctl' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/start-stop-daemon' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/sbin/policy-rc.d' [🐳|🌱] Removing qemu-user-static binary from chroot [ qemu-aarch64-static during image ] [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/bin/qemu-aarch64-static' [🐳|🌱] Unmounting [ /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210 ] Once the unmounting of rootfs-nouuidgen-yet begins I notice the following errors spam in the logs, 1000+ lines, and finally the target unmounts successfully and the image finishes building. The images still boot fine. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy. [🐳|🔨] tmpfs /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev tmpfs rw,nosuid,size=65536k,mode=755,inode64 0 0 umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev/pts: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/proc: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sys: not mounted umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/tmp: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/var/tmp: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/run/user/0: not mounted. Is there a way to adjust some kind of timeout for this to prevent the massive amount of "target is busy" outputs in the logs? Thank you for any help or insights!
  17. I don't own that box so I can only give you generic help. You really would need to hook up a usb-uart adapter to access the uboot debug output to see what is happening. The second thing I would say is that I have no idea what ophub builds do as they are not Armbian builds, ophub is a fork, they don't contribute to Armbian development nor do they participate in these forums. So per the Armbian amlogic TV box instructions, the boot environment must be a clean android boot environment. Installing or running any other distribution may cause Armbian to not boot. So I'd recommend either reinstalling a clean Android image to test from, or investigate any differences in boot scripts to see what might be going on. But again getting access to the new boot serial console would help a lot.
  18. Hi Everyone! I'm trying to install it on a TV Box with an Allwinner IK316 SOC and a NANYA 1303 eMMC, but Armbian can't find the eMMC at all... has anyone found a solution for this NAND?
  19. Has anyone installed Waydroid on Armbian 26.2.4? Are there any manual for this?
  20. Good morning. Is there any means of writing an Armbian image to Allwinner H313 emmc? Phoenixsuit does not allow Armbiam images to be written. I have tried to compile (Make) Livesuit, but I gave up due to several incompatibilities (kernel, libraries, etc.). Thanks in advance.
  21. You need to provide more informations. I wasn't able to repreoduce. I works here.
  22. What you’re seeing is open-source maintenance in practice. It’s not centrally orchestrated. We only manage to do this for some key features while DVB support is present in some kernels, but it’s not guaranteed to be consistently enabled across all targets unless someone explicitly maintains this functionality. -> https://github.com/armbian/build/pulls
  23. $ grep -i error /var/log/armbian-hardware-monitor.log [ 2.990779] rockchip-pcie f8000000.pcie: probe with driver rockchip-pcie failed with error -110 Looking at this I see the following: https://patchwork.ozlabs.org/project/linux-pci/patch/20210421083115.30213-1-jinsiyu940203@163.com/ "In function rockchip_pcie_host_init_port(), it defines a timeout value of 500ms to wait for pcie training. However, it is not enough for samsung PM953 SSD drive and realtek RTL8111F network adapter, which leads to the following errors: [ 0.879663] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 0.880284] rockchip-pcie f8000000.pcie: deferred probe failed [ 0.880932] rockchip-pcie: probe of f8000000.pcie failed with error -110 The pcie spec only defines the min time of training, not the max one. So set a proper timeout value is important. Change the value to 1000ms will fix this bug." Is it possible for team to add patch such as ../patch/kernel/rockchip64-current/0002-rockchip-pcie-increase-timeout.patch which contains the fix specified in the patchwork.ozlabs.org link above? A humble thank you for any more help and consideration on this!
  24. @well0nez I didn't even think about that. When I made the original post almost two years ago, AI was much less capable than today. You just gave me a few ideas for different projects. As I said, unfortunately I don't have the HY300 anymore, but I do have a Magcubic L018(same chip I think), though it's in use every day as a bedroom TV. I don't think my girlfriend would appreciate if I started to hack it 😉 Especially if core functions like projecting the things coming through the HDMI port to the wall. The L018 has worse software than the HY300, in my opinion, so I've connected it to a certified Android TV 14 Box.
  25. Hello, I updated to Armbian 26.2.1 trixie installaed on emmc. If I poweroff the nas and power on again it does't work, but if I attach an usb cable to the console it works. I think the problem must be related to the u-boot part.
  26. It worked seamlessly! Thanks!
  27. Hi everyone! I tried installing hardware decoding from this link - https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/ , but it didn't work for me. My board version is 5.1. Has anyone been able to fix this?
