hey @jock Bullseye builded flawlessly! [π³|π±] Done building [ Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img ] [π³|π±] SHA256 calculating [ Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img ] [π³|π±] Fast-moving file to output/images [ -> Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img (1.01GiB) ] [π³|π±] Fast-moving file to output/images [ -> Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img.sha (202.00B) ] [π³|π±] Fast-moving file to output/images [ -> Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img.txt (19.32KiB) ] [π³|πΏ] Unmounting recursively [ SDCARD rootfs finished - be patient ] [π³|πΏ] Done building image [ rk322x-box ] [π³|π±] Runtime [ 56:25 min ] [π³|β¨] Repeat Build Options [ ./compile.sh BOARD=rk322x-box BRANCH=legacy BUILD_DESKTOP=no BUILD_MINIMAL=yes INSTALL_HEADERS=yes KERNEL_CONFIGURE=yes KERNEL_KEEP_CONFIG=yes RELEASE=bullseye ] [π³|π±] Cleaning up [ please wait for cleanups to finish ] [π³|πΏ] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-fed9ae1d-0478-4643-a1de-606d2a7197e5.log.ans ] [π³|πΏ] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-fed9ae1d-0478-4643-a1de-606d2a7197e5.log.ans https://paste.armbian.com/log ls output/images/ -lah total 896M drwxr-xr-x 2 root root 4.0K May 8 16:23 . drwxr-xr-x 7 root root 4.0K May 8 15:31 .. -rw-rw-r-- 1 root root 1.1G May 8 16:23 Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img -rw-rw-r-- 1 root root 202 May 8 16:23 Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img.sha -rw-rw-r-- 1 root root 20K May 8 16:23 Armbian-unofficial_24.2.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img.txt So I guess there is a problem with focal release?
Refer to https://docs.armbian.com/User-Guide_Allwinner_overlays/ The file sun50i-h616-w1-gpio.dtbo should be copied to /boot/overlay-user/ and /boot/armbinaEnv.txt should be to contain for DS18B20 connected to GPIO 74/PC10 user_overlays=w1-gpio param_w1_pin=PC10 param_w1_pin_int_pullup=1
I found information that this is a dtc issue. The error can be suppressed with -W no-unit_address_vs_reg, for example: dtc -W no-unit_address_vs_reg -O dtb -o sun50i-h616-w1-gpio.dtbo sun50i-h616-w1-gpio.dts or warning can be squashed by adding #address-cells and #size-cells
You need to Mount the boot partition to edit it. ββmmcblk0p1 179:97 0 256M 0 part /boot Put the SD card on a x86 linux and edit the DTB file
@ag123 @OttawaHacker I saw community builds already generated here. I could check that they have u-boot DRAM patch, so I tried both of them in my board, and they boot normally π also minimal one having HDMI output.
Thank you! https://github.com/armbian/os/pull/184 In case anyone can verify if this works / test this assembly, before end of this month, it would be awesome! -
Armbian for TX3 Amlogic S905X3 with SP6330-X Bluetooth module
SteeMan replied to Nandini Ajay's topic in Amlogic CPU Boxes
https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first/ -
type id and look at the groups you are in then ls -l and/or ls -ld and look at the owners and permissions for the files in your home folder the owners and group should match that in id otherwise you can probably change them using chown , chown -R , chmod etc. for rsync, scp etc, you probably need to use a same username across different hosts in a sense that it should remote login to your Orange Pi host using ssh with that username.
Much better, but still warning: sun50i-h616-w1-gpio.dts:20.35-26.27: Warning (unit_address_vs_reg): /fragment@1/__overlay__/onewire@0: node has a unit name, but no reg or ranges property
nyok replied to Igor's topic in Software, Applications, Userspace
Tested on Rock5b: Needed to solve apparmor warning : Check that extraargs=systemd.unified_cgroup_hierarchy=0 apparmor=1 security=apparmor in /boot/armbianEnv.txt Then update-initramfs -u reboot -
Armbian team has very limited resources, we can't pick this up, and I doubt there will be a pileup of people from community doing this. If you (or anyone reading this) is interested to maintain CB1 and/or CB2, sent me PM, and I will ask Bigtreetech for help.
@Stephen Graf i see that if i use the original kernel source i want to build patched linux-image and linux-header for armbian jammy 6.6.26. It seems to include support for analog audio. I compile and install these using . **************** i have already tested all my components on jammy 6.6.26 thats why I would prefer using it ========================= Here are my cheat sheets: wget https://cdn.kernel.org/pub/linux/kernel/v6.x/linux-6.6.26.tar.xz tar -xvf linux-6.6.26.tar.xz cd ~/src/kernel-source/linux-6.6.26 copy all patches into ~/src/kernel-source/linux-6.6.26 cp /boot/config-$(uname -r) .config patch -p1 < 0606-dma-sun6i-dma-add-h616-support.patch patch -p1 < 0608-sound-soc-sunxi-add-codec-driver-for-h616.patch patch -p1 < 0609-sound-soc-add-sunxi_v2-for-h616-ahub.patch patch -p1 < 0630-arm64-dts-allwinner-h616.dtsi-add-ths-audio-hdmi.patch patch -p1 < 0631-arm64-dts-allwinner-h616-OrangePI-Zero23-enable-ths-hdmi-audio.patch patch -p1 < 0639-arm64-dts-allwinner-h616.dtsi-add-spdif.patch yes "y" | make oldconfig sudo make prepare sudo make clean cd ~/src/kernel-source/linux-6.6.26 sudo make -j$(nproc) bindeb-pkg LOCALVERSION=-custom cd ~/src/kernel-source/ sudo dpkg -i linux-image-6.6.26-custom_6.6.26-gbbc005ee4185-6_arm64.deb sudo dpkg -i linux-headers-6.6.26-custom_6.6.26-gbbc005ee4185-6_arm64.deb sudo dpkg -i linux-libc-dev_6.6.26-gbbc005ee4185-6_arm64.deb ls -l /boot/Image ls -l /boot/uInitrd ln -sf /boot/vmlinuz-6.6.26-custom /boot/Image ln -sf /boot/initrd.img-6.6.26-custom /boot/uInitrd cd ~/src/kernel-source/linux-6.6.26 make dtbs sudo mkdir /boot/dtb-6.6.26-custom/allwinner sudo cp /root/src/kernel-source/linux-6.6.26/arch/arm64/boot/dts/allwinner/*.dtb /boot/dtb-6.6.26-custom/allwinner/ sudo ln -sfn /boot/dtb-6.6.26-custom /boot/dtb sudo reboot now however my board doesnt boot. Do you have any suggestions? maybe u-boot? I have created the needed symlink which I though would be enough for u-boot. Maybe my approach is completely wrong
- 6 replies
- Banana Pi M4 Zero
- Orange Pi Zero 2
(and 1 more)
Β Tagged with:
Ver 20240503 kernel 5.10.198 , 6.2 and 6.8 add wifi
Bigtreetech CB2 and Pi 2 released somewhat recently (April 20th). They use RK3566 and have a lot of nice features. The board and module are intended for 3d printer use but can be used just like any other pi. There is an official linux image on bigtreetech github, and it seems it's a slightly customized armbian. I propose copying that configuration and adding it as a supported board. This is a bit of a personal tangent, but I was also thinking of how I can submit the device tree files to the mainline linux kernel, would that be a good idea? I'm planning to use or at least try Alpine on the board and it would be nice to have the needed files in the linux package already.
I have an Amlogic S905X3 board with an Armbian image in it, there is a module chip of SP6330-X attached to it, I can connect wifi to it and it works properly but when I try to connect Bluetooth it doesn't detect Bluetooth but when i install android in the device it works perfectly. Can anyone help me out, Please?
Never heard of a service like this. If you want persistent iptables rules install code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } iptables-persistent package via apt. iptables is active already once the kernel module is loaded which most likely is by default.
Yes, use docker... xD I don't think there is any problem achieving that, I think it just takes a few entries in a docker-compose.yml where you set up the networking. Not multiple ip:s though, not sure how you would achieve that on anything, but you use different ports and define what can communicate with what, bridging and so on. With docker you have to open up, it is completely containerized by default, even between other docker containers on the same machine. Futher reading here: https://docs.docker.com/network/ And for docker compose: https://docs.docker.com/compose/networking/ I highly recommend you familiarize yourself with docker compose, it makes everything sooo much easier.
Using apt, sudo is needed, but you having to use sudo in your USERSPACE sounds like something has gone horribly wrong. AFAIK if you write an armbian image, then boot, log in with root and follow the installation script that should start (I think) it will ASK you to create your username etc and set up everything for you. You do NOT do the userconf.txt thing like you would do with a headless rpi setup, you log in as root and run the setup script. It sounds like you did not do that, so your userspace (your ~/) never got created correctly with correct credentials. Or maybe you did not reboot and login as your user after the script created your user, but instead kept running as root and setting everything up on your system, witch then means it is all owned by root (sudo is needed). If this is the case, yes, you can take ownership easily by using a few commands, but that might not solve everything. I would recommend you restart from scratch, making sure everything is set up correctly.
@OttawaHacker This is a minimal build, probably it has no HDMI output. As @ag123 said, you need a serial cable to see output. Or you could access via SSH, looking at your router for DHCP address. Other option would be to use a build with desktop like this one, and apply patch the same way. Any way, pull request was already merged, so you can wait for next community release in a few days.
Hi @compent you're right, I'll try to write what I did to solve the problem. After these commands run sudo armbian-install - option 7 to flash mtdblock0 (bootloader install) - option 4 (to install system and boot from mtdblock0) choose nvme0n1p2 partition to install system After checking that when I rebooted it didn't start from nvme I did this I deleted the nvme ssd partitions with fdisk I copied the armbian image with SCP from another PC into a currently working installation folder on Microsd Finally with the DD command I copied the image to nvme Rebooted without micro sd and started from nvme with the fresh armbian image. At this point for future installations on nvme with the new armbian images I will only delete with fdisk and copy with the dd command using an image on microsd. I hope I was helpful. I'm sorry to say but the installation part of armbian-config is very confusing to me
Hello, I need your expert help to resolve an issue on my newly purchased orange pi 5b. I was able to install armbian xfce desktop os on emmc but am unable to correctly run a purchased csi mipi camera module (OV13850). Attached are some screen grabs, I do see rk3588-ov13850-c1 appear in overlays row of armbianEnv.txt upon toggling the selection in the armbian-config. Cheese application shows message "There was an error playing video from the webcam" upon opening the application (i also installed flatpak cheese as per some comment in a forum to test). I also tested connecting camera on rk3588-ov13850-c3 but face the same issue. Is there anything I am missing here? Appreciate your feedback, thank you.
@OttawaHacker connect to the board using a usb-uart (debug) serial dongle. the boot messages would normally show up there, or that if it booted to the prompt, you could login as root and run dmesg to see what goes wrong try also the other u-boot https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/ to see if that helps. there is a sequence of patches that needs to be applied and I've done that with my implementation. Unfortunately, in my case I hardcoded the 1.5GB memory as I found that for 1.5GB boards, the mainline u-boot incorrectly detected memory as 2GB or 4GB inconsistently. For once it says 2GB, then 4GB, then 2GB, and the algorithm would probe into the wrong memory size. so 'hardcoding' it ensures that it is 1.5GB no more / no less. you can use the distributed Armbian images https://www.armbian.com/orange-pi-zero-3/ and subsequently apply the u-boot patch from my repository. If you don't use dd , you can try using the python script that I've provided in my respository to patch u-boot into the image. Checkout instructions in my repository.
I found another example dtoverlay support for 1-wire subsystem on H616 devices https://github.com/orangepi-xunlong/linux-orangepi/pull/21 /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h616"; fragment@0 { target = <&pio>; __overlay__ { w1_pins: w1_pins { pins = "PC10"; function = "gpio_in"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { onewire@0 { compatible = "w1-gpio"; pinctrl-names = "default"; pinctrl-0 = <&w1_pins>; gpios = <&pio 2 10 0>; /* PC10 */ status = "okay"; }; }; }; }; I will try used
