Christos Posted October 1, 2016 Posted October 1, 2016 Ok, A new build has been done Ubuntu 16.04 with 4.7.6, it looks working. I answered the default answer to all the build (NEW) questions. C:\Documents and Settings\Christos>ssh christos@192.168.1.9 christos@192.168.1.9's password: setsockopt IP_TOS 16: Invalid argument: _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) | \ | | ___ ___ | \| |/ _` | '_ \ / _ \| |_) | | | \| |/ _ \/ _ \ | |\ | (_| | | | | (_) | __/| | | |\ | __/ (_) | |_| \_|\__,_|_| |_|\___/|_| |_| |_| \_|\___|\___/ Welcome to ARMBIAN Ubuntu 16.04.1 LTS 4.7.6-sun8i System load: 0.46 Up time: 3 min Memory usage: 4 % of 495Mb IP: 192.168.1.9 CPU temp: 31Β°C Usage of /: 8% of 15G Last login: Sat Oct 1 08:41:38 2016 from 192.168.1.6 christos@nanopineo:~$ As tk said, the USB obviously needs modification as the connector in NEO is not enabled in this build. Lets see now what can be done with dtc..
Christos Posted October 1, 2016 Posted October 1, 2016 Ok, Did some 'cheating' here and instead of going into device tree and change the USB1 to USB3 (I admit I got quite a few gaps still in the dtc/btb/bts thing..) I just connected the USB1 from the pinheader expansion on NEO and now the wifi device is visible C:\Christos>ssh christos@192.168.1.9 christos@192.168.1.9's password: setsockopt IP_TOS 16: Invalid argument: _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) | \ | | ___ ___ | \| |/ _` | '_ \ / _ \| |_) | | | \| |/ _ \/ _ \ | |\ | (_| | | | | (_) | __/| | | |\ | __/ (_) | |_| \_|\__,_|_| |_|\___/|_| |_| |_| \_|\___|\___/ Welcome to ARMBIAN Ubuntu 16.04.1 LTS 4.7.6-sun8i System load: 0.32 Up time: 27 sec Memory usage: 4 % of 495Mb IP: 192.168.1.9 CPU temp: 23Β°C Usage of /: 8% of 15G Last login: Sat Oct 1 12:38:33 2016 from 192.168.1.6 christos@nanopineo:~$ lsmod (Before plug-in of WiFi donlge) Module Size Used by sun8i_ths 3668 0 cpufreq_dt 3887 0 uio_pdrv_genirq 3591 0 uio 8953 1 uio_pdrv_genirq thermal_sys 48267 2 sun8i_ths,cpufreq_dt christos@nanopineo:~$ lsmod (After plug-in of WiFi donlge) Module Size Used by rtl8192cu 60341 0 rtl_usb 9530 1 rtl8192cu rtl8192c_common 40018 1 rtl8192cu rtlwifi 58627 3 rtl_usb,rtl8192c_common,rtl8192cu mac80211 396612 3 rtl_usb,rtlwifi,rtl8192cu cfg80211 237274 2 mac80211,rtlwifi rfkill 12189 2 cfg80211 sun8i_ths 3668 0 cpufreq_dt 3887 0 uio_pdrv_genirq 3591 0 uio 8953 1 uio_pdrv_genirq thermal_sys 48267 2 sun8i_ths,cpufreq_dt christos@nanopineo:~$ sudo ifconfig -a [sudo] password for christos: eth0 Link encap:Ethernet HWaddr 02:20:d2:9c:0b:2b inet addr:192.168.1.9 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: 2a02:582:d2e:1100:20:d2ff:fe9c:b2b/64 Scope:Global inet6 addr: fe80::20:d2ff:fe9c:b2b/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:254 errors:0 dropped:0 overruns:0 frame:0 TX packets:220 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:28086 (28.0 KB) TX bytes:28700 (28.7 KB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:1 errors:0 dropped:0 overruns:0 frame:0 TX packets:1 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:49 (49.0 TX bytes:49 (49.0 wlxe84e0626ba70 Link encap:Ethernet HWaddr e8:4e:06:26:ba:70 BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 christos@nanopineo:~$ There is a "wlxe84e0626ba70" wifi device now, but I could get some help here since I know how to set it up in Debian but I'm not so good in Ubuntu, so any hint on how to enable the wifi in this situation is welcome! so, how can I set this up? is there any how-to to read? Christos P.S. Here is attached the little patchwork
Christos Posted October 2, 2016 Posted October 2, 2016 Ok, Finally I did a Debian latest kernel build and now it works just fine with WiFi C:\Christos>ssh christos@192.168.1.131 christos@192.168.1.131's password: setsockopt IP_TOS 16: Invalid argument: _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) | \ | | ___ ___ | \| |/ _` | '_ \ / _ \| |_) | | | \| |/ _ \/ _ \ | |\ | (_| | | | | (_) | __/| | | |\ | __/ (_) | |_| \_|\__,_|_| |_|\___/|_| |_| |_| \_|\___|\___/ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.7.6-sun8i System load: 0.94 Up time: 30 sec Memory usage: 9 % of 495Mb IP: 192.168.1.131 CPU temp: 33Β°C Usage of /: 8% of 15G Last login: Sun Oct 2 09:24:13 2016 from 192.168.1.6 christos@nanopineo:~$ su root Password: root@nanopineo:/home/christos# iwconfig wlan0 IEEE 802.11 ESSID:"OTEf0b338" Mode:Managed Frequency:2.442 GHz Access Point: A4:7E:39:F0:B3:38 Bit Rate=150 Mb/s Tx-Power=20 dBm Retry short limit:7 RTS thr=2347 B Fragment thr:off Encryption key:off Power Management:off Link Quality=64/70 Signal level=-46 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:7 Missed beacon:0 lo no wireless extensions. eth0 no wireless extensions. root@nanopineo:/home/christos# ifconfig -a eth0 Link encap:Ethernet HWaddr 02:20:d2:9c:0b:2b UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:8 errors:0 dropped:0 overruns:0 frame:0 TX packets:8 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:1104 (1.0 KiB) TX bytes:1104 (1.0 KiB) wlan0 Link encap:Ethernet HWaddr e8:4e:06:26:ba:70 inet addr:192.168.1.131 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::ea4e:6ff:fe26:ba70/64 Scope:Link inet6 addr: 2a02:582:d2e:1100:ea4e:6ff:fe26:ba70/64 Scope:Global UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:150 errors:0 dropped:0 overruns:0 frame:0 TX packets:151 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:15920 (15.5 KiB) TX bytes:26776 (26.1 KiB) root@nanopineo:/home/christos# root@nanopineo:/home/christos# ping www.ubuntu.com -c 3 PING www.ubuntu.com (91.189.90.59) 56(84) bytes of data. 64 bytes from www-ubuntu-com.jujube.canonical.com (91.189.90.59): icmp_seq=1 ttl =52 time=71.5 ms 64 bytes from www-ubuntu-com.jujube.canonical.com (91.189.90.59): icmp_seq=2 ttl =52 time=74.7 ms 64 bytes from www-ubuntu-com.jujube.canonical.com (91.189.90.59): icmp_seq=3 ttl =52 time=72.7 ms --- www.ubuntu.com ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2001ms rtt min/avg/max/mdev = 71.594/73.046/74.773/1.312 ms root@nanopineo:/home/christos# This build, Armbian 5.21, Debian jessie, kernel 4.7.6, has been build with armbian's build system choosing choose an option -> "Full OS image for writing to SD card" choose a board -> "nanopineo" choose a kernel -> "dev" choose a release -> "jessie" choose image type -> "Image with console interface" and all (NEW) prompts were answered as per their default value Used with the USB1 exported pins via the DIY board and connector shown above (until of course a proper USB3 image comes) Modifications to wifi related files are as described here -> http://forum.armbian.com/index.php/topic/1237-tutorial-opi-one-wireless-success/. Hope that will be useful to anyone interested. Christos
Christos Posted October 2, 2016 Posted October 2, 2016 A question to the Armbian gurus here for the new armbian builds with 4.x kernel. Do these builds take into consideration the DDR frequency for the NanoPi-NEO RAM? or is that too from the OPi board and thus poses a risk factor for us with NEOs? Should we avoid making armbian builds with kernel 4.x on NEO?
tkaiser Posted October 2, 2016 Posted October 2, 2016 Do these builds take into consideration the DDR frequency for the NanoPi-NEO RAM? They do. This is done entirely in u-boot and mainline/vanilla kernel doesn't touch these settings. So unlike legacy kernel where you can control DRAM clockspeed from userspace (h3consumption tool) with vanilla kernel you stay with the fixed value set in u-boot. BTW: I'm currently testing 'add_usb_ports_to_small_h3-boards.patch', if this succeeds I will commit it within the next hour. As a result all USB ports on the small H3 boards should be useable without further tweaks. Edit: Tested, works and commited: https://github.com/igorpecovnik/lib/commit/14fa719934d38f579eb0ded346f448b6b0fda6bc 2
Christos Posted October 2, 2016 Posted October 2, 2016 Good! Thanks Thomas, Fresh build, Armbian 5.21, Ubuntu 16.04.1 LTS, kernel 4.7.6 C:\Christos>ssh christos@192.168.1.131 christos@192.168.1.131's password: setsockopt IP_TOS 16: Invalid argument: _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) | \ | | ___ ___ | \| |/ _` | '_ \ / _ \| |_) | | | \| |/ _ \/ _ \ | |\ | (_| | | | | (_) | __/| | | |\ | __/ (_) | |_| \_|\__,_|_| |_|\___/|_| |_| |_| \_|\___|\___/ Welcome to ARMBIAN Ubuntu 16.04.1 LTS 4.7.6-sun8i System load: 0.36 Up time: 1 min Memory usage: 5 % of 495Mb IP: 192.168.1.131 CPU temp: 35Β°C Usage of /: 8% of 15G Last login: Sun Oct 2 20:08:54 2016 from 192.168.1.6 christos@nanopineo:~$ sudo ifconfig -a [sudo] password for christos: eth0 Link encap:Ethernet HWaddr 02:20:d2:9c:0b:2b UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 TX bytes:0 (0.0 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:1 errors:0 dropped:0 overruns:0 frame:0 TX packets:1 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1 RX bytes:49 (49.0 TX bytes:49 (49.0 wlxe84e0626ba70 Link encap:Ethernet HWaddr e8:4e:06:26:ba:70 inet addr:192.168.1.131 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::ea4e:6ff:fe26:ba70/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:139 errors:0 dropped:0 overruns:0 frame:0 TX packets:134 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:16333 (16.3 KB) TX bytes:20986 (20.9 KB) christos@nanopineo:~$ ping www.ubuntu.com -c 3 PING www.ubuntu.com (91.189.89.118) 56(84) bytes of data. 64 bytes from www-ubuntu-com.nuno.canonical.com (91.189.89.118): icmp_seq=1 ttl= 52 time=70.2 ms 64 bytes from www-ubuntu-com.nuno.canonical.com (91.189.89.118): icmp_seq=2 ttl= 52 time=69.0 ms 64 bytes from www-ubuntu-com.nuno.canonical.com (91.189.89.118): icmp_seq=3 ttl= 52 time=67.9 ms --- www.ubuntu.com ping statistics --- 3 packets transmitted, 3 received, 0% packet loss, time 2002ms rtt min/avg/max/mdev = 67.914/69.075/70.291/1.017 ms christos@nanopineo:~$ works like a charm, board USB connector enabled, WiFi up and running. Thanks again Christos P.S. The only strange thing is the wifi device with weird name wlxe84e0626ba70..
martinayotte Posted October 3, 2016 Posted October 3, 2016 The only strange thing is the wifi device with weird name wlxe84e0626ba70 You can force older naming scheme by adding rule in /etc/udev/rules.d
Christos Posted October 3, 2016 Posted October 3, 2016 You can force older naming scheme by adding rule in /etc/udev/rules.d ..if I only knew how to do that. And as they say, if its not broken, dont try to fix it, I'll live with it. It works just fine as it is, it just has a ..strong character of its own!! Thanks for the hint though, appreciated and I might dive into udev rules someday to see how it can be done. Christos
martinayotte Posted October 3, 2016 Posted October 3, 2016 There are some explanations there : http://forum.armbian.com/index.php/topic/2173-can-not-build-wireless-driver/#entry16630 In fact, this new naming behaviour isn't new, it is the new naming convention that Systemd had introduced awhile ago : https://www.freedesktop.org/wiki/Software/systemd/PredictableNetworkInterfaceNames/ http://askubuntu.com/questions/689070/network-interface-name-changes-after-update-to-15-10-udev-changes http://askubuntu.com/questions/628217/use-of-predictable-network-interface-names-with-alternate-kernels
Adam Anderson Posted October 7, 2016 Posted October 7, 2016 Hi All, I have a Nanopi Neo: Welcome to ARMBIAN Ubuntu 16.04.1 LTS 3.4.112-sun8iSystem load: 0.24 Up time: 2 days Memory usage: 5 % of 494Mb IP: 192.168.0.241CPU temp: 42°C Usage of /: 28% of 7.2G I've installed Linphone on it but it's complaining: adam@nanopineo:~$ linphonelinphone: error while loading shared libraries: libavcodec-ffmpeg.so.56: cannot open shared object file: No such file or directory I've got this installed/usr/lib/arm-linux-gnueabihf/libavcodec-ffmpeg.so.57.48.101/usr/lib/arm-linux-gnueabihf/libavcodec-ffmpeg.so.57 I've tried adding an alternative linphone ppa and updating and installing linphone, but the problem persists. Google isn't helping me much unfortunately. Any tips or pointers?
zador.blood.stained Posted October 7, 2016 Posted October 7, 2016 I've got this installed /usr/lib/arm-linux-gnueabihf/libavcodec-ffmpeg.so.57.48.101 /usr/lib/arm-linux-gnueabihf/libavcodec-ffmpeg.so.57 I've tried adding an alternative linphone ppa and updating and installing linphone, but the problem persists. Google isn't helping me much unfortunately. Any tips or pointers? This is an issue with 5.20 images, this will be fixed with new release.
Pieter Posted October 7, 2016 Posted October 7, 2016 linphone: error while loading shared libraries: libavcodec-ffmpeg.so.56: cannot open shared object file: No such file or directory I've got this installed /usr/lib/arm-linux-gnueabihf/libavcodec-ffmpeg.so.57.48.101 /usr/lib/arm-linux-gnueabihf/libavcodec-ffmpeg.so.57 You are probably better of waiting for the fix zador.blood.stained is talking about but... What you could try in the mean time is by creating a symbolic link as libavcodec-ffmpeg.so.56 to libavcodec-ffmpeg.so.57, sometimes that works :-) cd /usr/lib/arm-linux-gnueabihf/ ln -s libavcodec-ffmpeg.so.57 libavcodec-ffmpeg.so.56 No guaranties, that it will work :-)
Carlos Posted October 10, 2016 Posted October 10, 2016 Hi Linux imbecile here. Do any of the Armbian distros have the USB port operational? I want to use my Neo as a NAA device for HQPlayer. I don't know if I have not installed HQPlayer NAA correctly onto my Neo or if the NAA is not seeing my DAC because the USB port is disabled. I am currently using ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i. Any help greatly appreciated. Regards Carl
Christos Posted October 10, 2016 Posted October 10, 2016 Hi Linux imbecile here. Do any of the Armbian distros have the USB port operational? I want to use my Neo as a NAA device for HQPlayer. I don't know if I have not installed HQPlayer NAA correctly onto my Neo or if the NAA is not seeing my DAC because the USB port is disabled. I am currently using ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i. Any help greatly appreciated. Regards Carl Hi Carl, Yes, if you build yourself a new image now, either legacy or vanilla, it will have USB working ok. See above posts 213 & 216 Christos
tkaiser Posted October 10, 2016 Posted October 10, 2016 I am currently using ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i. In this image all 3 USB host ports are defined as active: https://github.com/igorpecovnik/lib/blob/master/config/fex/nanopineo.fex#L523-L551 Check output of lsusb (-v) and dmesg after connecting USB devices and if that does not help get back to us with the output from 'sudo armbianmonitor -u'.
Carlos Posted October 10, 2016 Posted October 10, 2016 Thanks Christos and Thomas Up and running with my USB Dac The problem was that HQPlayer NAA would not install with the Jessie build because it requires libstdc++6 greater than 5.1 The Xenial build allowed HQPlayer NAA to be installed properly Thanks for your help.
XTL Posted October 12, 2016 Posted October 12, 2016 I finally got one of these as well. I'll see how long it takes for me to find time to get a card, a console, and bootup.
Slawek Posted October 13, 2016 Posted October 13, 2016 Hi, I just started my quest with NanoPi NEO (rev 1.1). I'm quite old guy ;-) with my roots in Pleistocene Delphi time so I would like to program it using Lazarus/Pascal. On Raspberry Pi 2/3 I can install and access Lazarus without any problem using Putty/Xming team (on standard Rasbian). I'm using the popular guide from here: http://otapi.com/2015/02/10/raspberry-pi-2-freepascal-lazarus-and-delphi/ but I have small problems with my NanoPi NEO. with FriendlyARM default image I can access NanoPi with Putty/Xming (after installing some g??? application for example gedit) But I can't compile Lazarus IDE. with Armbian (every version dedicated to NanoPi NEO) I can install Lazarus without any problems, but I cant access it via X11 forwarding Putty/Xming. I get error: Unable to init server: Could not connect: Connection refused (galculator:2743): Gtk-WARNING **: cannot open display" probably the problem is with the X11 authorisation but I have little experience. Could you please give me some idea what I should reconfigure to gain X11 access. Tanks in advance.
Christos Posted October 13, 2016 Posted October 13, 2016 Hi Slawek, There are no old guys, just some others are too young!! (I myself am a '65 model..) Not sure if that applies to you, but the two images in the armbian nanopineo specific download page are headless (no GUI) so they might lack some of the X11 features you require. Take a shot and try to build one for yourself via the https://github.com/igorpecovnik/lib in the page there are instructions for a custom build so you might have luck building a desktop build instead of a console/terminal only. Christos
tkaiser Posted October 13, 2016 Posted October 13, 2016 I just started my quest with NanoPi NEO (rev 1.1). Christos is right, NEO images are headless (no HDMI, no X11 -- maybe too shortsighted). You could either install X11 on an existing image or choose the Desktop image for Orange Pi One and then execute there just 'h3consumption -g off -d 408' (on PCB rev 1.1 it should be save to allow 1200 MHz cpufreq -- on our NEO images this is limited to 912 MHz currently)
Slawek Posted October 13, 2016 Posted October 13, 2016 Thanks, I will try both, but on Monday, an will let you know the results. Now I'm preparing myself and my crew for last sailing trip this season :D Have nice weekend. Slawek
bzfrp Posted October 13, 2016 Posted October 13, 2016 Hello, Thanks for your excellent distribution! I have NanoPi NEO + heatsink + box (all official from friendlyarm). I installed Jessie legacy because I need the USB audio output. I installed the mpd package + upmpdcli ( http://www.lesbonscomptes.com/upmpdcli/) + shairport -sync. This SBC is perfect for creating a UPnP audio player and airplay audio player. Here the load during playback of FLAC files root@nanopineo:~/shairport-sync# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 15:32:27: 912MHz 0.01 2% 0% 1% 0% 0% 0% 49°C 15:32:32: 240MHz 0.00 2% 0% 1% 0% 0% 0% 49°C 15:32:38: 240MHz 0.00 2% 0% 1% 0% 0% 0% 49°C 15:32:43: 240MHz 0.00 2% 0% 1% 0% 0% 0% 49°C 15:32:48: 240MHz 0.00 2% 0% 1% 0% 0% 0% 49°C 15:32:53: 240MHz 0.00 2% 0% 1% 0% 0% 0% 50°C 15:32:59: 240MHz 0.00 2% 0% 1% 0% 0% 0% 49°C 15:33:04: 240MHz 0.08 2% 0% 1% 0% 0% 0% 49°C 15:33:09: 240MHz 0.08 2% 0% 1% 0% 0% 0% 49°C 15:33:14: 240MHz 0.07 2% 0% 1% 0% 0% 0% 49°C 15:33:20: 240MHz 0.06 2% 0% 1% 0% 0% 0% 49°C 15:33:25: 240MHz 0.06 2% 0% 1% 0% 0% 0% 49°C 15:33:30: 240MHz 0.05 2% 0% 1% 0% 0% 0% 49°C 15:33:36: 240MHz 0.05 2% 0% 1% 0% 0% 0% 49°C 15:33:41: 240MHz 0.05 2% 0% 1% 0% 0% 0% 49°C 15:33:46: 912MHz 0.04 2% 0% 1% 0% 0% 0% 49°C 15:33:51: 240MHz 0.04 2% 0% 1% 0% 0% 0% 49°C 15:33:56: 240MHz 0.04 2% 0% 1% 0% 0% 0% 49°C 15:34:02: 240MHz 0.03 2% 0% 1% 0% 0% 0% 49°C 15:34:07: 240MHz 0.10 2% 0% 1% 0% 0% 0% 50°C 15:34:12: 240MHz 0.09 2% 0% 1% 0% 0% 0% 49°C 15:34:18: 240MHz 0.09 2% 0% 1% 0% 0% 0% 49°C 15:34:23: 240MHz 0.08 2% 0% 1% 0% 0% 0% 49°C 15:34:28: 240MHz 0.07 2% 0% 1% 0% 0% 0% 49°C 15:34:33: 240MHz 0.07 2% 0% 1% 0% 0% 0% 49°C 15:34:39: 240MHz 0.06 2% 0% 1% 0% 0% 0% 49°C 15:34:44: 240MHz 0.06 2% 0% 1% 0% 0% 0% 49°C 15:34:49: 240MHz 0.05 2% 0% 1% 0% 0% 0% 49°C 15:34:54: 912MHz 0.05 2% 0% 1% 0% 0% 0% 49°C 15:35:00: 240MHz 0.04 2% 0% 1% 0% 0% 0% 49°C 15:35:05: 240MHz 0.04 2% 0% 1% 0% 0% 0% 50°C 15:35:10: 240MHz 0.04 2% 0% 1% 0% 0% 0% 49°C 15:35:15: 240MHz 0.03 2% 0% 1% 0% 0% 0% 49°C 15:35:21: 240MHz 0.03 2% 0% 1% 0% 0% 0% 49°C 15:35:26: 240MHz 0.03 2% 0% 1% 0% 0% 0% 49°C 15:35:31: 240MHz 0.03 2% 0% 1% 0% 0% 0% 50°C 15:35:37: 240MHz 0.02 2% 0% 1% 0% 0% 0% 49°C 15:35:42: 240MHz 0.02 2% 0% 1% 0% 0% 0% 49°C 15:35:47: 912MHz 0.09 2% 0% 1% 0% 0% 0% 49°C 15:35:52: 240MHz 0.09 2% 0% 1% 0% 0% 0% 49°C 15:35:58: 240MHz 0.08 2% 0% 1% 0% 0% 0% 49°C 15:36:03: 240MHz 0.07 2% 0% 1% 0% 0% 0% 49°C 15:36:08: 240MHz 0.23 2% 0% 1% 0% 0% 0% 49°C 15:36:13: 240MHz 0.21 2% 0% 1% 0% 0% 0% 49°C ... kernel 4.6.7, with schedutil cpufreq governor: root@nanopineo:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 20:59:30: 240MHz 0.13 0% 0% 0% 0% 0% 0% 36.7°C 20:59:36: 120MHz 0.12 0% 0% 0% 0% 0% 0% 36.8°C 20:59:41: 120MHz 0.11 0% 0% 0% 0% 0% 0% 36.9°C 20:59:47: 120MHz 0.10 0% 0% 0% 0% 0% 0% 37.1°C 20:59:52: 120MHz 0.09 0% 0% 0% 0% 0% 0% 36.7°C 20:59:58: 120MHz 0.09 0% 0% 0% 0% 0% 0% 37.1°C 21:00:04: 120MHz 0.08 0% 0% 0% 0% 0% 0% 36.8°C 21:00:09: 120MHz 0.07 0% 0% 0% 0% 0% 0% 36.9°C 21:00:15: 240MHz 0.07 0% 0% 0% 0% 0% 0% 37.1°C 21:00:20: 1200MHz 0.06 0% 0% 0% 0% 0% 0% 37.8°C 21:00:25: 1200MHz 0.06 0% 0% 0% 0% 0% 0% 37.8°C 21:00:30: 1200MHz 0.05 0% 0% 0% 0% 0% 0% 38.5°C 21:00:35: 1200MHz 0.13 0% 0% 0% 0% 0% 0% 38.5°C 21:00:40: 1200MHz 0.20 0% 0% 0% 0% 0% 0% 38.5°C 21:00:45: 1200MHz 0.18 0% 0% 0% 0% 0% 0% 38.5°C 21:00:50: 1200MHz 0.15 0% 0% 0% 0% 0% 0% 38.8°C 21:00:56: 1200MHz 0.14 0% 0% 0% 0% 0% 0% 39.1°C 21:01:01: 120MHz 0.13 0% 0% 0% 0% 0% 0% 38.6°C 21:01:06: 1200MHz 0.12 0% 0% 0% 0% 0% 0% 38.6°C 21:01:11: 1200MHz 0.11 0% 0% 0% 0% 0% 0% 38.8°C 21:01:16: 1200MHz 0.18 0% 0% 0% 0% 0% 0% 38.9°C 21:01:21: 1200MHz 0.17 0% 0% 0% 0% 0% 0% 38.9°C 21:01:27: 1200MHz 0.15 0% 0% 0% 0% 0% 0% 38.3°C 21:01:32: 1200MHz 0.14 0% 0% 0% 0% 0% 0% 38.9°C 21:01:37: 1200MHz 0.13 0% 0% 0% 0% 0% 0% 38.8°C 21:01:42: 240MHz 0.12 0% 0% 0% 0% 0% 0% 38.8°C 21:01:47: 1200MHz 0.11 0% 0% 0% 0% 0% 0% 38.8°C 21:01:52: 1200MHz 0.10 0% 0% 0% 0% 0% 0% 38.6°C 21:01:57: 120MHz 0.09 0% 0% 0% 0% 0% 0% 39.0°C 21:02:03: 1200MHz 0.08 0% 0% 0% 0% 0% 0% 38.9°C 21:02:08: 1200MHz 0.08 0% 0% 0% 0% 0% 0% 39.2°C 21:02:13: 1200MHz 0.07 0% 0% 0% 0% 0% 0% 39.1°C 21:02:18: 1200MHz 0.06 0% 0% 0% 0% 0% 0% 38.8°C 21:02:23: 1200MHz 0.06 0% 0% 0% 0% 0% 0% 38.8°C 21:02:28: 1200MHz 0.05 0% 0% 0% 0% 0% 0% 39.1°C 21:02:33: 1200MHz 0.05 0% 0% 0% 0% 0% 0% 39.4°C 21:02:38: 1200MHz 0.05 0% 0% 0% 0% 0% 0% 39.4°C 21:02:43: 1200MHz 0.04 0% 0% 0% 0% 0% 0% 39.5°C 21:02:49: 1200MHz 0.04 0% 0% 0% 0% 0% 0% 39.2°C 21:02:54: 1200MHz 0.03 0% 0% 0% 0% 0% 0% 39.1°C 21:02:59: 1200MHz 0.03 0% 0% 0% 0% 0% 0% 39.2°C 21:03:04: 1200MHz 0.03 0% 0% 0% 0% 0% 0% 39.5°C 21:03:09: 1200MHz 0.03 0% 0% 0% 0% 0% 0% 39.2°C 21:03:14: 1200MHz 0.02 0% 0% 0% 0% 0% 0% 39.4°C 21:03:19: 120MHz 0.02 0% 0% 0% 0% 0% 0% 39.1°C 21:03:25: 1200MHz 0.02 0% 0% 0% 0% 0% 0% 38.6°C 21:03:30: 1200MHz 0.02 0% 0% 0% 0% 0% 0% 39.4°C 21:03:35: 816MHz 0.02 0% 0% 0% 0% 0% 0% 39.2°C 21:03:40: 1200MHz 0.02 0% 0% 0% 0% 0% 0% 39.1°C 21:03:45: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.4°C 21:03:50: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.6°C 21:03:55: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.6°C 21:04:00: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.5°C 21:04:05: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.5°C 21:04:10: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.5°C 21:04:15: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.1°C 21:04:21: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.7°C 21:04:26: 1200MHz 0.01 0% 0% 0% 0% 0% 0% 39.7°C 21:04:31: 1200MHz 0.00 0% 0% 0% 0% 0% 0% 39.7°C 21:04:36: 816MHz 0.00 0% 0% 0% 0% 0% 0% 39.9°C 21:04:41: 1200MHz 0.08 0% 0% 0% 0% 0% 0% 39.9°C 21:04:46: 1200MHz 0.07 0% 0% 0% 0% 0% 0% 39.5°C 21:04:51: 120MHz 0.07 0% 0% 0% 0% 0% 0% 39.5°C 21:04:57: 1200MHz 0.06 0% 0% 0% 0% 0% 0% 39.5°C 21:05:02: 1200MHz 0.06 0% 0% 0% 0% 0% 0% 40.0°C 21:05:07: 1200MHz 0.05 0% 0% 0% 0% 0% 0% 39.4°C 21:05:12: 1200MHz 0.05 0% 0% 0% 0% 0% 0% 39.7°C root@nanopineo:~# cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state 120000 8016033 240000 12243 312000 2445 480000 6209 624000 1322 816000 1738 1008000 432 1200000 978525 root@nanopineo:~# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 244 us. hardware limits: 120 MHz - 1.20 GHz available frequency steps: 120 MHz, 240 MHz, 312 MHz, 480 MHz, 624 MHz, 816 MHz, 1.01 GHz, 1.20 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 120 MHz and 1.20 GHz. The governor "schedutil" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 120 MHz:88.88%, 240 MHz:0.14%, 312 MHz:0.03%, 480 MHz:0.07%, 624 MHz:0.01%, 816 MHz:0.02%, 1.01 GHz:0.00%, 1.20 GHz:10.85% (31937) analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 244 us. hardware limits: 120 MHz - 1.20 GHz available frequency steps: 120 MHz, 240 MHz, 312 MHz, 480 MHz, 624 MHz, 816 MHz, 1.01 GHz, 1.20 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 120 MHz and 1.20 GHz. The governor "schedutil" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 120 MHz:88.88%, 240 MHz:0.14%, 312 MHz:0.03%, 480 MHz:0.07%, 624 MHz:0.01%, 816 MHz:0.02%, 1.01 GHz:0.00%, 1.20 GHz:10.85% (31937) analyzing CPU 2: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 244 us. hardware limits: 120 MHz - 1.20 GHz available frequency steps: 120 MHz, 240 MHz, 312 MHz, 480 MHz, 624 MHz, 816 MHz, 1.01 GHz, 1.20 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 120 MHz and 1.20 GHz. The governor "schedutil" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 120 MHz:88.88%, 240 MHz:0.14%, 312 MHz:0.03%, 480 MHz:0.07%, 624 MHz:0.01%, 816 MHz:0.02%, 1.01 GHz:0.00%, 1.20 GHz:10.85% (31937) analyzing CPU 3: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 244 us. hardware limits: 120 MHz - 1.20 GHz available frequency steps: 120 MHz, 240 MHz, 312 MHz, 480 MHz, 624 MHz, 816 MHz, 1.01 GHz, 1.20 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 120 MHz and 1.20 GHz. The governor "schedutil" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 120 MHz:88.88%, 240 MHz:0.14%, 312 MHz:0.03%, 480 MHz:0.07%, 624 MHz:0.01%, 816 MHz:0.02%, 1.01 GHz:0.00%, 1.20 GHz:10.85% (31937) root@nanopineo:~# cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state 1
trewq Posted October 15, 2016 Posted October 15, 2016 Ok, so, I went a little overboard with this but here is my current NanoPi Neo setup. They are all running the latest Ubuntu build, if anyone wants the output of anything let me know. 20 units in total. 2
webbbn Posted October 15, 2016 Posted October 15, 2016 Got a couple of NanoPi NEO Airs today. Anyone tried Armbian on them yet? I imagine the standard NEO image will work, but how hard will it be to install it onto the internal flash?
tkaiser Posted October 15, 2016 Posted October 15, 2016 Anyone tried Armbian on them yet? Nope, but we added support for AIR based on available information recently and already built test images (more or less by accident): Armbian_5.20_Nanopiair_Debian_jessie_3.4.112.7z Armbian_5.20_Nanopiair_Ubuntu_xenial_3.4.112.7z Unless you are able to attach a serial console to the 4-pin header it's useless to even try them out. Two questions from our side: is the 4-pin header to provide power and attach a serial console populated or not? if the eMMC pre-flashed? Please get back to us with this information first, we will then update the NanoPi Air thread and might ask potential Air users a few questions. Thanks!
tkaiser Posted October 15, 2016 Posted October 15, 2016 kernel 4.6.7, with schedutil cpufreq governor: root@nanopineo:~# cat /sys/devices/system/cpu/cpu0/cpufreq/stats/time_in_state 120000 8016033 240000 12243 312000 2445 480000 6209 624000 1322 816000 1738 1008000 432 1200000 978525 Ok, so you modified /etc/defaults/cpufrequtils to 'activate' all available dvfs operating points. In fact your use case implies 'almost idle all the time' so it doesn't make that much of a difference at all. It only gets interesting when throttling starts to jump in since then I observed that the new ths settings are not optimal (eg. constantly jumping between 816 MHz and 1200 MHz and not using the 1008 MHz in between which leads to lower performance under full load with vanilla kernel compared to legacy currently). With @trewq's 20 node cluster I would've already started to tweak settings. 20 NEO running in identical conditions would be great to test through a bunch of different DT settings in less time. BTW: I believe I adopted installation of RPi-Monitor also for vanilla images already. Do you get reasonable output after installation (sudo armbianmonitor -r)?
tkaiser Posted October 15, 2016 Posted October 15, 2016 However, very little joy with WIFI - it works with a fairly standard WIFI USB plug but range is AWFUL which is the wrong approach anyway. First choose the distro, then choose the device -- that's how Armbian is supposed to work. This is a NEO with a TP-Link TL-WN823N 2.4GHz dongle in an area where 2.4 GHz band is simply dead (+60 networks in the meantime): root@nanopineo:~# lsusb Bus 001 Device 004: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter And this is what this thingie 'sees': root@nanopineo:~# nmcli dev wifi list * SSID MODE CHAN RATE SIGNAL BARS SECURITY EasyBox-116D28 Infra 9 16 Mbit/s 75 ▂▄▆_ WPA1 WPA2 Snort-Honeynet Infra 13 2 Mbit/s 60 ▂▄▆_ WPA2 -- Infra 6 16 Mbit/s 57 ▂▄▆_ WPA2 FRITZ!Box Fon WLAN 7360 Infra 1 44 Mbit/s 49 ▂▄__ WPA1 WPA2 DISTORTEDPEOPLE Infra 9 44 Mbit/s 47 ▂▄__ WPA1 WPA2 Wolf 7360 Infra 1 16 Mbit/s 45 ▂▄__ WPA1 WPA2 UBNT2 Infra 3 54 Mbit/s 45 ▂▄__ EasyBox-290502 Infra 1 44 Mbit/s 44 ▂▄__ WPA1 WPA2 FRITZ!Box 7490 Infra 1 44 Mbit/s 44 ▂▄__ WPA2 EasyBox-188632 Infra 10 44 Mbit/s 44 ▂▄__ WPA1 WPA2 DISTORTEDPEOPLE_EXT Infra 9 16 Mbit/s 39 ▂▄__ WPA1 WPA2 Wonder Woman Infra 1 44 Mbit/s 30 ▂___ WPA1 WPA2 WLAN-341381 Infra 1 16 Mbit/s 30 ▂___ WPA2 Karen_Range Extender Infra 5 44 Mbit/s 30 ▂___ WPA1 WPA2 Eichkatzenkind Infra 5 44 Mbit/s 30 ▂___ WPA2 WLAN-ABD446 Infra 10 16 Mbit/s 30 ▂___ WPA2 WLAN-A29657 Infra 1 16 Mbit/s 29 ▂___ WPA2 Brain Exit = Brexit Infra 7 44 Mbit/s 29 ▂___ WPA1 WPA2 See the signal strength? Now switching over to Orange Pi Lite with onboard 8189FTV (also RealTek, also cheap crap but... different). Same position, crappy mini antenna connected, device being at exactly the same position. root@orangepilite:~# nmcli dev wifi list * SSID MODE CHAN RATE SIGNAL BARS SECURITY 5c618d Infra 6 16 Mbit/s 100 ▂▄▆█ WPA1 WPA2 FRITZ!Box 7490 Infra 6 16 Mbit/s 100 ▂▄▆█ WPA2 EasyBox-116D28 Infra 9 16 Mbit/s 100 ▂▄▆█ WPA1 WPA2 Snort-Honeynet Infra 13 2 Mbit/s 100 ▂▄▆█ WPA2 DISTORTEDPEOPLE Infra 9 44 Mbit/s 72 ▂▄▆_ WPA1 WPA2 WLAN-3C3379 Infra 11 16 Mbit/s 68 ▂▄▆_ WPA2 WLAN-341381 Infra 1 16 Mbit/s 64 ▂▄▆_ WPA2 Wonder Woman Infra 1 44 Mbit/s 62 ▂▄▆_ WPA1 WPA2 -- Infra 6 16 Mbit/s 62 ▂▄▆_ WPA2 FRITZ!Box 6490 Cable Infra 11 16 Mbit/s 62 ▂▄▆_ WPA2 FRITZ!Box Fon WLAN 7360 Infra 1 44 Mbit/s 60 ▂▄▆_ WPA1 WPA2 UBNT2 Infra 3 54 Mbit/s 60 ▂▄▆_ EasyBox-290502 Infra 1 44 Mbit/s 58 ▂▄▆_ WPA1 WPA2 WLAN-A29657 Infra 1 16 Mbit/s 58 ▂▄▆_ WPA2 Horst Infra 3 16 Mbit/s 58 ▂▄▆_ WPA1 WPA2 Karen_Range Extender Infra 5 44 Mbit/s 58 ▂▄▆_ WPA1 WPA2 VC-WLAN Gastzugang Infra 6 16 Mbit/s 58 ▂▄▆_ WPA1 WPA2 EasyBox-188632 Infra 10 44 Mbit/s 58 ▂▄▆_ WPA1 WPA2 Hasenhirn01 Infra 11 16 Mbit/s 58 ▂▄▆_ WPA2 FRITZ!Box 7490 Infra 1 44 Mbit/s 56 ▂▄▆_ WPA2 FRITZ!Box Fon WLAN 7360 Infra 1 44 Mbit/s 56 ▂▄▆_ WPA1 WPA2 Eichkatzenkind Infra 5 44 Mbit/s 56 ▂▄▆_ WPA2 FRITZ!Box Fon WLAN 7113 Infra 6 54 Mbit/s 56 ▂▄▆_ WPA1 WPA2 VC on Air Infra 6 16 Mbit/s 56 ▂▄▆_ WPA1 WPA2 11-Dominik Infra 11 44 Mbit/s 56 ▂▄▆_ WPA1 WPA2 FRITZ!Box Fon WLAN 7360 Infra 1 44 Mbit/s 48 ▂▄__ WPA1 WPA2 UnserInternet4.0 Infra 1 16 Mbit/s 48 ▂▄__ WPA2 Wireless1 Infra 4 16 Mbit/s 48 ▂▄__ WPA1 WPA2 DISTORTEDPEOPLE_EXT Infra 9 16 Mbit/s 48 ▂▄__ WPA1 WPA2 FRITZ!Box 7362 SL Infra 1 44 Mbit/s 47 ▂▄__ WPA2 Wolf 7360 Infra 1 16 Mbit/s 47 ▂▄__ WPA1 WPA2 walterfranz Infra 4 16 Mbit/s 47 ▂▄__ WPA2 Piratensender Infra 7 2 Mbit/s 47 ▂▄__ WPA1 WPA2 David Infra 11 54 Mbit/s 47 ▂▄__ WPA1 FRITZ!Box 7490 Infra 3 44 Mbit/s 46 ▂▄__ WPA2 ffg_02 Infra 4 44 Mbit/s 46 ▂▄__ WPA2 Brain Exit = Brexit Infra 7 44 Mbit/s 46 ▂▄__ WPA1 WPA2 MASSIMO Infra 11 44 Mbit/s 44 ▂▄__ WPA1 WPA2 devolo-bcf2afb1d5ce Infra 6 44 Mbit/s 43 ▂▄__ WPA2 Antigonus Infra 11 16 Mbit/s 43 ▂▄__ WPA1 WPA2 lotta Infra 11 54 Mbit/s 42 ▂▄__ WEP if you need Wi-Fi stop buying devices that lack Wi-Fi. An OrangePi Lite behaves almost the same as a NEO since from an Armbian point of view it's 'just another H3 device', it's just faster under full load (better throttling behaviour), consumes less energy and regarding GPIO everything that applies for Orange Pi PC applies here too. Armbian supports ~10 boards with onboard Wi-Fi and Armbian feels (and more or less acts) identical on all of them. We don't have the ressources to fiddle around with every random Wi-Fi stick available. Or lets better say with the count of team members we have it's an insane waste of ressources to try to support this cheap and unreliable crap instead of doing important things. We try at least to give best out of the box support for the various onboard Wi-Fis, as far as I can tell situation with 8189CU and 8188CUS is quite fine so the best idea is to choose the appropriate device for the specific use case (and to be honest: If I have to choose between a NEO with Wi-Fi dongle and an Orange Pi Lite it's pretty easy to choose the latter. And if I would use both reliable Wi-Fi and Ethernet then it's an Orange Pi PC Plus that gets ordered).
tkaiser Posted October 15, 2016 Posted October 15, 2016 Does the Orange Pi lite have audio? Review says no.... (Neo does) ?? Orange Pi Lite has Audio through HDMI and analog stuff on solder points (accessing them can be considered PITA ). For Audio + Wi-Fi clearly NanoPi Air will be the board of choice (different Audio stuff on the pin headers just as they did when switching from NEO PCB rev. 1.0 to 1.1)
webbbn Posted October 15, 2016 Posted October 15, 2016 Nope, but we added support for AIR based on available information recently and already built test images (more or less by accident): Armbian_5.20_Nanopiair_Debian_jessie_3.4.112.7z Armbian_5.20_Nanopiair_Ubuntu_xenial_3.4.112.7z Unless you are able to attach a serial console to the 4-pin header it's useless to even try them out. Two questions from our side: is the 4-pin header to provide power and attach a serial console populated or not? if the eMMC pre-flashed? Please get back to us with this information first, we will then update the NanoPi Air thread and might ask potential Air users a few questions. Thanks! None of the headers are populated. The box comes with the headers, but they're not soldered on. I populated all the headers, connected a USB-serial adapter to the serial console and tried powering it up. I don't see anything on the console, and no LEDs blink, so I don't think there is anything installed on the eMMC. I'll try your images and see what they do. Where is the NanoPi air thread? I didn't see it. Edit: It turns out that my USB-serial adapter must not provide enough current to boot. I powered from USB without an sdcard, and now the blue LED is flashing. I'm not seeing anything over the serial console, but there could be a problem with the configuration of my USB-serial. I'm not sure what the baud rate is for starters... Edit2: I'm an idiot! I soldered a dual row 90 degree header on the console pins and the other (single) row, then a single row along the rest of the row. The back (console) row aligns with the single row, and I had the USB-uart on the wrong pins. Now I am able to power the board from my USB-uart, and it boots from eMMC with the console at 115200, so it does come pre-installed with FriendlyArm Ubuntu on the eMMC. Edit3: The provided Ubuntu image works perfectly. It appears to be finding the wireless correctly, but I haven't tried configuring it yet.
arox Posted October 15, 2016 Posted October 15, 2016 None of the headers are populated. The box comes with the headers, but they're not soldered on. I populated all the headers, connected a USB-serial adapter to the serial console and tried powering it up. I don't see anything on the console, and no LEDs blink, so I don't think there is anything installed on the eMMC. I'll try your images and see what they do. Where is the NanoPi air thread? I didn't see it. Edit: It turns out that my USB-serial adapter must not provide enough current to boot. I powered from USB without an sdcard, and now the blue LED is flashing. I'm not seeing anything over the serial console, but there could be a problem with the configuration of my USB-serial. I'm not sure what the baud rate is for starters... Edit2: I'm an idiot! I soldered a dual row 90 degree header on the console pins and the other (single) row, then a single row along the rest of the row. The back (console) row aligns with the single row, and I had the USB-uart on the wrong pins. Now I am able to power the board from my USB-uart, and it boots from eMMC with the console at 115200, so it does come pre-installed with FriendlyArm Ubuntu on the eMMC. Edit3: The provided Ubuntu image works perfectly. It appears to be finding the wireless correctly, but I haven't tried configuring it yet. Do they load g_ether and provide a config for usb0 ?
