1339 -
Other groups
Management
Contributor/Maintainer
Profile Information
Gender
Male
Location
Richmond, VA
Interests
ARMBIAN!!!! Also Linux, Docker, Ansible, HashiStack, Horizontal Scaling, Jeeps, Subarus, V8s, home improvement, home security and automation.
Contact Methods
IRC
lanefu
Website URL
https://www.lane-fu.com
Github
lanefu
30974 profile views
That should be resolved as of this PR https://github.com/armbian/build/pull/6580
does Armbian image use same DDR blobs as Joshua's?
I believe so. The other Armbian user space tools for networking do.
There are rk3588 edge overlays available for SATA https://github.com/armbian/build/tree/main/patch/kernel/rockchip-rk3588-edge/overlay
don't know if this method still works but thought i'd share it https://github.com/armbian/documentation/issues/116
Try using Armbian builder to build an image there is a 4se config in there I added it after helping some one in irc one night. I don't recall the state. I don't have a 4se https://github.com/armbian/build/blob/main/config/boards/rock-4se.csc
I believe those accelerations are only available on rklinux using the legacy/vendor kernel. Armbian's Odroid M1 does not support rklinux only mainline linux. https://github.com/armbian/build/blob/main/config/boards/odroidm1.conf#L6
nope that's from the rockchip 6.1 vendor kernel. It's not compatible with mainline linux
LiX's Nanopi-R5C CSC stuff is in the Armbian build tree, but no automated community images are being published currently. Unofficial unsupported R5C builds here: https://refuge.armsurvivors.icu/lanefu/lanefu_24.2.0-trunk_Nanopi-r5c_bookworm_current_6.6.13/ https://refuge.armsurvivors.icu/lanefu/lanefu_24.2.0-trunk_Nanopi-r5c_sid_edge_6.7.1/
This won't feel very helpful, but basically you'll need to make a device tree for the cm3588 nas board. I've yet to find a good read on introducing people to device tree and how to navigate but hopefully you can find something. Example: https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/rockchip/rk3588-nanopc-t6.dts
User here had similar issues with EVO 860 Weirdest coincidental solution ever. Guessing early console some how gave more time for the drive to init in time? https://github.com/armbian/build/pull/6031
Okay new discovery.. seem's to be a drive-specific issue.... Experiencing Issue with no init on boot issue on -- Samsung SSD 860 PRO 256GB I have another device working fine on boot.. no issue. -- Samsung SSD 860 EVO 500GB even tried moving both drives around different slots. Behavior was consistent
Another me too Drives don't initialize on boot.. ATA ports show down... if i hot plug a drive, it comes right up. Observed issue on fresh kernel builds of 6.1.62 6.6.1 Tried fresh uboot from edge as well.
Building for orangepi5 kernel 6.6.rc1
lanefu replied to markbox's topic in Advanced users - Development
Make sure you're building with EXPERT=yes The rk3588 edge kernel is already 6.6 rc1 https://github.com/armbian/build/blob/dd5fb3e3f8659e2a502808a7e10b5aeed8ffb18f/config/boards/orangepi5.conf#L3 https://github.com/armbian/build/blob/main/config/sources/families/rockchip-rk3588.conf#L32
