AzuriAdore Posted June 21, 2020 Posted June 21, 2020 Hi everyone, I would like to ask for some help please. I'm using a Nexbox A95X s905x 2g/16g (model b7n) (using gxl dtb) I think I messed up my firmware with CoreELEC and now everything is weird. Initially I couldn't boot back into armbian as stated in red at the top of the 1st thread. So I re-flashed the firmware using the aml usb burning tool as indicated (erase all) and now when I boot, it always goes into emergency mode(?) Errors were showing "failed to create static device nodes in /dev" etc, much more errors than this, and can't boot normally. I do not really understand "the new activation of the universal multi-boot, which is used in all new systems" from the latter part. Can I get some elaboration on how to fix the CoreELEC changes to revert back to being able to use armbian please? Really appreciate the work btw!
balbes150 Posted June 22, 2020 Author Posted June 22, 2020 On 6/21/2020 at 6:52 AM, AzuriAdore said: revert back to being able to use armbian please? Expand Write in more detail what steps you are taking and what results you get from them.
AzuriAdore Posted June 22, 2020 Posted June 22, 2020 On 6/22/2020 at 10:05 AM, balbes150 said: Write in more detail what steps you are taking and what results you get from them. Expand Thanks for showing interest in helping. I have fixed my problem by trying another build of Armbian. I was using the headless(server) bionic build 20200619 and this was giving me errors on boot-up. When I changed to desktop focal 20200619, it was fine. Every daemon launched with OK status. Until now I am still not sure why bionic doesn't work, but no worries because I will use focal. Thanks for your awesome work and providing a new life for my old TV box. Your Armbian build is amazing!
Juanbel Posted June 23, 2020 Posted June 23, 2020 On 6/10/2020 at 11:08 PM, Turgus said: So it seems that the (native) resolution of screen is not detected properly..could you set the command via terminal to change resolution? Maybe you could add the desired res via commands for testing(will not be permanent and only for the session, but perfect to test..): xrandr --newmode "1368x768_60.00" 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync xrandr --addmode HDMI-1 1368x768_60.00 xrandr --output HDMI-1 --mode 1368x768_60.00 Expand Thanks for your answer. I had just tried this method, but not run. The resolution of my TV is 1366x768, not 1368x768, however when I write: cvt 1366 768 the system answer with 1368x768 resolution, that is not the same exactly. I don't know if it is the problem homeserver@arm-64:~$ cvt 1366 768 # 1368x768 59.88 Hz (CVT) hsync: 47.79 kHz; pclk: 85.25 MHz Modeline "1368x768_60.00" 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync Another solution? Thanks in advance
esdcmc Posted June 23, 2020 Posted June 23, 2020 Hi everyone, I am trying to install homeassistant on an X96 box (think it is S905X). I am kind of new to Linux and Python but I have got a good deal of experience with computers and programming languages in general. I followed the instructions from this forum and successfully installed armbian on an SD card (using Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img and pinpointing the right dtb) and managed to boot on it. Then I successfully installed homeassistant too... great then... except that the same homeassistant complained that Pthon3.6 is deprecated and it should be updated. I tried to install latest Python (3.8.3) in parallel to 3.6 but there was no way of making homeassistant build correctly then. Then I purged 3.6 and reinstalled 3.8.3 from scratch... and eventually I got the correct home assistant installation. Fine... not quite.... because, after rebooting the box, I now have a black screen with a cursor on top left and nothing else. The boot scrolls quickly with a list of OKs (in green so everything seems normal for a while) until it gets to the black screen and the process halts there... very annoying: 4 days of debugging and it now looks like I have to start it all again from scratch. Any idea what could have caused the boot to fail after Python update (for example I noticed that Python3.6 disappeared from usr/bin and 3.8 went into a ...local directory: could that be the cause?... or is it because at one point I did, I think, apt-get upgrade?)
jeanrhum Posted June 24, 2020 Posted June 24, 2020 On 6/23/2020 at 5:51 PM, esdcmc said: except that the same homeassistant complained that Pthon3.6 is deprecated and it should be updated. Expand Maybe the best way to use HA is to use docker: https://www.home-assistant.io/docs/installation/docker/ I tested that on several tv boxes and it works nice and no more worry about python errors. Docker is available through armbian-config.
SteeMan Posted June 24, 2020 Posted June 24, 2020 On 6/23/2020 at 5:51 PM, esdcmc said: I followed the instructions from this forum and successfully installed armbian on an SD card (using Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img and pinpointing the right dtb) and managed to boot on it. Then I successfully installed homeassistant too... great then... except that the same homeassistant complained that Pthon3.6 is deprecated and it should be updated. I tried to install latest Python (3.8.3) in parallel to 3.6 but there was no way of making homeassistant build correctly then. Expand From the information you provided you are running Ubuntu 18.04 (bionic) which has python 3.6. I believe that Ubuntu 20.04 (focal) has python 3.8. So the easiest thing to do would likely be to use the armbian focal build instead of the bionic build.
Armin Posted June 26, 2020 Posted June 26, 2020 (edited) Hello @balbes150, I do not find any AML version with kernel 5.6.1 (5.6.0. in 4th-April and 5.6.2 in 8th-April). Please to indicate me that if there is an AML version with kernel 5.6.1 ! Thanks in advance Edited June 26, 2020 by Armin
balbes150 Posted June 27, 2020 Author Posted June 27, 2020 On 6/26/2020 at 4:02 PM, Armin said: I do not find any AML version with kernel 5.6.1 (5.6.0. in 4th-April and 5.6.2 in 8th-April). Please to indicate me that if there is an AML version with kernel 5.6.1 ! Expand All available versions are located on the links from the first message (space is limited).
Reddwarf Posted June 27, 2020 Posted June 27, 2020 On 6/26/2020 at 4:02 PM, Armin said: Hello @balbes150, I do not find any AML version with kernel 5.6.1 (5.6.0. in 4th-April and 5.6.2 in 8th-April). Please to indicate me that if there is an AML version with kernel 5.6.1 ! Thanks in advance Expand I'v looked through my downloads and I don't have any 5.6.1, the closest is 5.6.0-rc6, I don't think I'v seen a 5.6.1 version.
Armin Posted June 27, 2020 Posted June 27, 2020 On 6/27/2020 at 10:56 AM, Reddwarf said: I'v looked through my downloads and I don't have any 5.6.1, the closest is 5.6.0-rc6, I don't think I'v seen a 5.6.1 version. Expand Thanks to have look ! Yes, I've searched and same result. After 5.6.0, the next version is directly 5.6.2. So, this is not my eyes !
esdcmc Posted June 27, 2020 Posted June 27, 2020 Thank-you all for the kind support. It's unbelievable how ignorant I can be on the matter. My story continues as follows: - I restarted from scratch using the same image (Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img), reason being that in the s9xxx directory (https://mega.nz/folder/j9QSDQSQ#6WpasOlbZYIInfw6yo4phQ/folder/35ACSCjQ) there is no "Ubuntu 20.04 (focal)", as suggested by Steeman, so I don't quite know if any other image is actually compatible with my box - I managed to install Python 3.8.3 in parallel with 3.6 and I built a virtual environment from 3.8.3 - then I installed HomeAssistant within that virtual environment and all seemed to work... except that the same Home Assistant did not install the Hass.io tab... and that's when I found out that Home Assistant and Hass.io are NOT the same thing (gosh! what a mess I put myself into!) - plus I have got a bunch of other errors, inconsistently popping up (lack of Cloud, lack of Alexa, etc etc) every now and then So here I am, I will be zapping the card for the third time and try the Docker solution as suggested by jeanrhum... minor problem though: I have no idea what Docker is, and how it works and (unlike Python) I struggle to find good documentation. Any suggestion for where I should start to learn this Docker thing?
SteeMan Posted June 27, 2020 Posted June 27, 2020 On 6/27/2020 at 2:12 PM, esdcmc said: I restarted from scratch using the same image (Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img), reason being that in the s9xxx directory (https://mega.nz/folder/j9QSDQSQ#6WpasOlbZYIInfw6yo4phQ/folder/35ACSCjQ) there is no "Ubuntu 20.04 (focal)", as suggested by Steeman, so I don't quite know if any other image is actually compatible with my box Expand The AML specific builds are no longer maintained (thus why you are seeing no focal build and nothing current in the location you are looking). The current builds are now "universal" builds that support Amlogic, Rockchip and Allwinner CPUs for android TV boxes. Look at the first post in this thread: The instructions for installing are basically the same as the build you are using, but with additional options for the various CPU families. These builds are being regularly updated and is where you should be looking for installation images.
dsh Posted June 29, 2020 Posted June 29, 2020 On 6/29/2020 at 10:04 AM, balbes150 said: ver 20200629-dev kernel 5.8-rc3 Expand Hi, I've tested Forsa Desktop with Amlogic P281. It won't load Desktop environment. On 5.8 RC2 it was working. When can we expect h265/hevc hardware video decoding?
Lexx Posted June 29, 2020 Posted June 29, 2020 Hello. No one will tell you where to get brcmfmac4356-sdio for chip BCM4356/2 and clm_blob for it. The wifi driver and bluetooth do not get up. brcmfmac: F1 signature read @0x18000000=0x17224356 [ 3688.213438] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio for chip BCM4356/2 [ 3688.215800] usbcore: registered new interface driver brcmfmac [ 3688.302869] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio for chip BCM4356/2 [ 3688.302925] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 3688.303168] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4356/2 wl0: Sep 9 2018 22:04:16 version 7.35.349.62 (r707733 CY) FWID 01-5fd4a6ce
Turgus Posted June 29, 2020 Posted June 29, 2020 On 6/29/2020 at 3:23 PM, dsh said: with Amlogic P281 It won't load Desktop environment. Expand For me rc3 works with desktop on x96mini 2/16G p281 hardware. Because I stick on bionic to use camorama I did just a quick test(localize, install some stuff..) from card, but it also reboots several times as expected and brings always the focal system WITH desktop up. Maybe try it again!?..
Pank007 Posted June 30, 2020 Posted June 30, 2020 (edited) Hi, I am new to this forum and have been trying to follow the instruction to install Armbian on my Mecool K1 Pro. I have tried different dtb's but still no luck in booting into Armbian below is the link to the message that I keep getting. https://ibb.co/4P51vXc No sure if i am going about it the right way, may be someone in the forum can help me. The current firmware on the box is the stock firmware provided by Videostrong the manufactures of the box. https://mega.nz/#F!3FkWlSRZ!JqsJfSg---koYN8y4ZdFbw I noticed in the image provided by Videostrong there is a DTB.img file, could this file be used to boot Armbian correctly? If Armbian works on the the box, I would like to use it to run Hassio server to control my smart devices at home. Many Thanks for your help in advance. Edited June 30, 2020 by Pank007
balbes150 Posted June 30, 2020 Author Posted June 30, 2020 A test version of the image for evaluating the correct operation of GPU controllers for Amlogic. Please everyone who has the ability to check the launch of one of these images and write the result (the chip AML used by DTB, the result of verification). https://yadi.sk/d/uMgn3hLTa-J1Iw
jeanrhum Posted June 30, 2020 Posted June 30, 2020 On 6/30/2020 at 12:00 PM, balbes150 said: A test version of the image for evaluating the correct operation of GPU controllers for Amlogic. Please everyone who has the ability to check the launch of one of these images and write the result (the chip AML used by DTB, the result of verification). https://yadi.sk/d/uMgn3hLTa-J1Iw Expand Excelvan T2 (s912) using q201 dtb started from a slow usb key: http://ix.io/2qzp The system seems usable. It is slow but I think it comes from my usb key. EDIT: same test with an H96pro+ using vim2 dtb using a uhs1 sd card : http://ix.io/2qzv. The system is faster than my previous test and desktop is reactive. On both config video playback was smooth.
dbsharpe Posted June 30, 2020 Posted June 30, 2020 On 6/29/2020 at 7:38 PM, Lexx said: Hello. No one will tell you where to get brcmfmac4356-sdio for chip BCM4356/2 and clm_blob for it. The wifi driver and bluetooth do not get up. Expand Would this help (for wifi, not BT):
Turgus Posted June 30, 2020 Posted June 30, 2020 @balbes150GPU-Test-Image launches properly(also testvideo from desktop plays fluent in windowmode&fullscreen) on s905w p281 x96 mini 2/16 (4.x PCB with working bt/wifi) as usual with the meson-gxl-s905w-p281.dtb
dbsharpe Posted June 30, 2020 Posted June 30, 2020 On 6/30/2020 at 11:41 AM, Pank007 said: Hi, I am new to this forum and have been trying to follow the instruction to install Armbian on my Mecool K1 Pro. I have tried different dtb's but still no luck in booting into Armbian below is the link to the message that I keep getting. Expand Initially after watching some recent youtube videos about Armbian, you need to check you've commented out all the lines FDT= * APPEND above # rk-3399 at the top of /uEnv.txt You will need to try all (amlogic) dtbs (I assume, don't have Mecool K1 Pro). Also check this page. Personally, I boot into (sdcard) Armbian by issuing the command reboot update in a shell from android (app).
vikoadi Posted June 30, 2020 Posted June 30, 2020 On 6/30/2020 at 12:00 PM, balbes150 said: A test version of the image for evaluating the correct operation of GPU controllers for Amlogic. Please everyone who has the ability to check the launch of one of these images and write the result (the chip AML used by DTB, the result of verification). https://yadi.sk/d/uMgn3hLTa-J1IwDevice : Fiberhome HG680-P S905X mali-450Image : focal_current_5.7.6Dtb:meson-gxl-s905x-p212.dtbOn LXDE, LLVM driver is still being used.https://pastebin.com/k02E5upPhttps://pastebin.com/dgAXMXpHTried on Sway, lima is detected, but glxgears is glitchy and stutters. Also lima echo a lot of pp pp2 reset time out when running glxgearshttps://pastebin.com/6CJGrjUVhttps://pastebin.com/HXBN0sYXMpv plays Test.mp4 with no problem in windowed size. When fullscreened, the outputs dropping frames like crazy either with default vo or with --vo=wlshmSent from my ASUS_X00TD using Tapatalk
tediwildan Posted June 30, 2020 Posted June 30, 2020 On 6/30/2020 at 2:57 PM, vikoadi said: Device : Fiberhome HG680-P S905X mali-450Image : focal_current_5.7.6Dtb:meson-gxl-s905x-p212.dtbOn LXDE, LLVM driver is still being used.https://pastebin.com/k02E5upPhttps://pastebin.com/dgAXMXpHTried on Sway, lima is detected, but glxgears is glitchy and stutters. Also lima echo a lot of pp pp2 reset time out when running glxgearshttps://pastebin.com/6CJGrjUVhttps://pastebin.com/HXBN0sYXMpv plays Test.mp4 with no problem in windowed size. When fullscreened, the outputs dropping frames like crazy either with default vo or with --vo=wlshmSent from my ASUS_X00TD using TapatalkJosss, mantapSent from my SM-C9000 using Tapatalk
Pank007 Posted June 30, 2020 Posted June 30, 2020 On 6/30/2020 at 2:21 PM, dbsharpe said: Initially after watching some recent youtube videos about Armbian, you need to check you've commented out all the lines FDT= * APPEND above # rk-3399 at the top of /uEnv.txt You will need to try all (amlogic) dtbs (I assume, don't have Mecool K1 Pro). Also check this page. Personally, I boot into (sdcard) Armbian by issuing the command reboot update in a shell from android (app). Expand @dbsharpe i have deleted the lines that are not relevant in the u Env,txt file and below is what i am left with. LINUX=/zImage INITRD=/uInitrd # aml s9xxx FDT=/dtb/amlogic/meson-gxl-s905d-p230.dtb APPEND=root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 I will give all the (amlogic) dtb's a try again, and also see if the reboot update in shell works for me. Thanks, i will let you know how it goes.
amirul Posted June 30, 2020 Posted June 30, 2020 On 6/30/2020 at 12:00 PM, balbes150 said: A test version of the image for evaluating the correct operation of GPU controllers for Amlogic. Please everyone who has the ability to check the launch of one of these images and write the result (the chip AML used by DTB, the result of verification). https://yadi.sk/d/uMgn3hLTa-J1Iw Expand TX9 Pro s912 Armbian_20.06.0_Arm-64_focal_current_5.7.6_desktop-TEST-GPU meson-gxm-q200 boots OK to desktop glxinfo OpenGL vendor string: VMware, Inc. OpenGL renderer string: llvmpipe (LLVM 9.0.1, 128 bits) OpenGL core profile version string: 3.3 (Core Profile) Mesa 20.0.4 OpenGL core profile shading language version string: 3.30 /etc/X11/xorg.conf.d/01-armbian-defaults.conf -> Option "AccelMethod" "glamor" glxinfo OpenGL vendor string: Panfrost OpenGL renderer string: Mali T820 (Panfrost) OpenGL version string: 2.1 Mesa 20.0.4 OpenGL shading language version string: 1.20 mouse pointer flicker & artifact
