mantouboji Posted November 16, 2018 Posted November 16, 2018 After upgrade to Ubuntu 18.04,I can’t read my two DS18B20 devices for weeks. I use OrangePi One. 0 Quote
martinayotte Posted November 16, 2018 Posted November 16, 2018 On 11/16/2018 at 8:59 AM, mantouboji said: After upgrade to Ubuntu 18.04,I can’t read my two DS18B20 devices for weeks. Expand Are you using w1-gpio overlay ? Are you defining the param_w1_pin parameter properly (without it, default is PD14 pin) ? 0 Quote
mantouboji Posted November 17, 2018 Posted November 17, 2018 On 11/16/2018 at 2:11 PM, martinayotte said: Are you using w1-gpio overlay ? Are you defining the param_w1_pin parameter properly (without it, default is PD14 pin) ? Expand I used its config for a long time. It works very well in 16.04 . overlays=pps-gpio uart1 usbhost0 w1-gpio param_w1_pin=PA10 #param_w1_pin_int_pullup=1 param_pps_pin=PA7 now: 11月 17 20:35:03 opione2 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 80.d2c000430010 crc fb 11月 17 20:35:03 opione2 kernel: w1_master_driver w1_bus_master1: Family 80 for 80.d2c000430010.fb is not registered. 11月 17 20:35:18 opione2 kernel: w1_master_driver w1_bus_master1: Attaching one wire slave 80.32c000430010 crc 12 11月 17 20:35:18 opione2 kernel: w1_master_driver w1_bus_master1: Family 80 for 80.32c000430010.12 is not registered. 1 0 Quote
martinayotte Posted November 17, 2018 Posted November 17, 2018 On 11/17/2018 at 12:37 PM, mantouboji said: #param_w1_pin_int_pullup=1 Expand Why the pullup is commented out ? Do you have an external one ? On 11/17/2018 at 12:37 PM, mantouboji said: Family 80 for 80.d2c000430010.fb is not registered. Expand This doesn't come from Armbian patches, maybe a bug have been introduced upstream ... On my side, my DS18B20 is registering properly on my OPi_2E under 4.19.2 : [ 20.168937] w1_master_driver w1_bus_master1: Attaching one wire slave 28.000005a2fac5 crc ea 0 Quote
mantouboji Posted November 18, 2018 Posted November 18, 2018 On 11/17/2018 at 1:20 PM, martinayotte said: Why the pullup is commented out ? Do you have an external one ? Expand whether commented or not, no any difference. I use a 5.1K pullup external. 16 hours ago, martinayotte said: This doesn't come from Armbian patches, maybe a bug have been introduced upstream ... On my side, my DS18B20 is registering properly on my OPi_2E under 4.19.2 : [ 20.168937] w1_master_driver w1_bus_master1: Attaching one wire slave 28.000005a2fac5 crc ea Expand Welcome to ARMBIAN 5.61 user-built Ubuntu 18.04.1 LTS 4.14.72-sunxi 0 Quote
gounthar Posted January 19, 2020 Posted January 19, 2020 Hi, would anyone have a recommendation for an I2C temperature sensor working with OrangePi Zero? I thought of I2C because it should be pretty straightforward, but if you ever have another setup that works flawlessly, I'm all ears. 0 Quote
Igor Posted January 19, 2020 Posted January 19, 2020 On 1/19/2020 at 3:51 PM, gounthar said: I2C temperature sensor working with OrangePi Zero? Expand https://www.adafruit.com/product/1603 ... and similar ones. 1 Quote
martinayotte Posted January 19, 2020 Posted January 19, 2020 On 1/19/2020 at 3:51 PM, gounthar said: I2C temperature sensor Expand I've used the NXP SA56004 in the past, but not necessarily on OPi ... 1 Quote
vlad59 Posted January 19, 2020 Posted January 19, 2020 I've successfully used BMP180 (Igor gave you a link), BME280, SI7021 based devices (search on aliexpress, you'll find plenty). 1 Quote
Zamana Posted October 8, 2020 Posted October 8, 2020 (edited) Dear Sirs, I read every topic in this thread (what helped me a lot), but now I'm stucked and need more help. I did buy this sensor and I need to use it on my Orange Pi PC. After following the instructions from this site together with the instruction of this thread, I wired the 3 cables like this: RED -> 2 (5V) BLACK -> 6 (GND) YELLOW -> 35 (PA10) My files are like this: root@orangepipc:/sys/bus/w1# cat /etc/modules-load.d/modules.conf # /etc/modules: kernel modules to load at boot time. # # This file contains the names of kernel modules that should be loaded # at boot time, one per line. Lines beginning with "#" are ignored. w1-sunxi w1-gpio w1-therm #sunxi-cir ##xradio_wlan g_serial ##xradio_wlan root@orangepipc:/sys/bus/w1# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=usbhost2 usbhost3 w1-gpio rootdev=UUID=88adacec-2194-4cfc-abc4-67cd6ef7fdf4 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@orangepipc:/sys/bus/w1/devices/w1_bus_master1# cat /etc/default/cpufrequtils ENABLE=true MIN_SPEED=480000 MAX_SPEED=1200000 GOVERNOR=interactive The loaded modules are these: root@orangepipc:/sys/bus/w1# lsmod Module Size Used by rfkill 20480 1 snd_soc_hdmi_codec 20480 1 sch_fq_codel 20480 2 dw_hdmi_i2s_audio 16384 0 dw_hdmi_cec 16384 0 sunxi_cir 20480 0 lima 45056 0 sun4i_gpadc_iio 16384 0 gpu_sched 28672 1 lima industrialio 53248 1 sun4i_gpadc_iio usb_f_acm 20480 1 sun8i_thermal 16384 0 u_serial 24576 1 usb_f_acm g_serial 16384 0 sun8i_ce 24576 0 libcomposite 45056 2 g_serial,usb_f_acm sunxi_cedrus 32768 0 sun8i_di 20480 0 crypto_engine 16384 1 sun8i_ce evdev 20480 1 uio_pdrv_genirq 16384 0 display_connector 20480 0 uio 16384 1 uio_pdrv_genirq cpufreq_dt 20480 0 zram 24576 2 w1_therm 24576 0 w1_gpio 16384 0 wire 32768 2 w1_gpio,w1_therm cn 16384 1 wire ip_tables 24576 0 x_tables 24576 1 ip_tables autofs4 36864 2 sy8106a_regulator 16384 1 sunxi 20480 0 phy_generic 20480 2 sunxi gpio_keys 20480 0 dmesg: root@orangepipc:~# dmesg | grep -i wire [ 6.506017] Driver for 1-wire Dallas network protocol. [ 6.523698] gpio-110 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file (...) [ 1232.791932] w1_master_driver w1_bus_master1: Family 0 for 00.980000000000.d3 is not registered. [ 1278.638733] w1_master_driver w1_bus_master1: Attaching one wire slave 00.580000000000 crc 19 [ 1278.650463] w1_master_driver w1_bus_master1: Family 0 for 00.580000000000.19 is not registered. [ 1326.305393] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d80000000000 crc 95 [ 1326.316126] w1_master_driver w1_bus_master1: Family 0 for 00.d80000000000.95 is not registered. [ 1350.471284] w1_master_driver w1_bus_master1: Attaching one wire slave 00.380000000000 crc 7c [ 1350.481274] w1_master_driver w1_bus_master1: Family 0 for 00.380000000000.7c is not registered. [ 1396.431767] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b80000000000 crc f0 [ 1396.439186] w1_master_driver w1_bus_master1: Family 0 for 00.b80000000000.f0 is not registered. It seems that I have 2 sensors: root@orangepipc:~# cat /sys/devices/w1_bus_master1/w1_master_slave_count 2 But it seems that I don't have any files where to read the data... Example: root@orangepipc:/sys/bus/w1/devices/w1_bus_master1# tree -L 10 . ├── 00-200000000000 │ ├── driver -> ../../../bus/w1/drivers/w1_slave_driver │ ├── id │ ├── name │ ├── power │ │ ├── autosuspend_delay_ms │ │ ├── control │ │ ├── runtime_active_time │ │ ├── runtime_status │ │ └── runtime_suspended_time │ ├── rw │ ├── subsystem -> ../../../bus/w1 │ └── uevent ├── 00-a00000000000 │ ├── driver -> ../../../bus/w1/drivers/w1_slave_driver │ ├── id │ ├── name │ ├── power │ │ ├── autosuspend_delay_ms │ │ ├── control │ │ ├── runtime_active_time │ │ ├── runtime_status │ │ └── runtime_suspended_time │ ├── rw │ ├── subsystem -> ../../../bus/w1 │ └── uevent ├── driver -> ../../bus/w1/drivers/w1_master_driver ├── power │ ├── autosuspend_delay_ms │ ├── control │ ├── runtime_active_time │ ├── runtime_status │ └── runtime_suspended_time ├── subsystem -> ../../bus/w1 ├── uevent ├── w1_master_add ├── w1_master_attempts ├── w1_master_max_slave_count ├── w1_master_name ├── w1_master_pointer ├── w1_master_pullup ├── w1_master_remove ├── w1_master_search ├── w1_master_slave_count ├── w1_master_slaves ├── w1_master_timeout └── w1_master_timeout_us 11 directories, 36 files That's my system: ___ ____ _ ____ ____ / _ \| _ \(_) | _ \ / ___| | | | | |_) | | | |_) | | | |_| | __/| | | __/| |___ \___/|_| |_| |_| \____| Welcome to Armbian 20.08.7 Focal with Linux 5.8.13-sunxi System load: 8% Up time: 6 min Memory usage: 8% of 998M IP: 192.168.0.69 CPU temp: 45°C Usage of /: 14% of 7.2G [ General system configuration (beta): armbian-config ] Does anybody knows what I'm doing wrong? Any help is appreciated. Thanks. Regards. Edited October 8, 2020 by Zamana 0 Quote
martinayotte Posted October 8, 2020 Posted October 8, 2020 On 10/8/2020 at 2:26 PM, Zamana said: overlays=usbhost2 usbhost3 w1-gpio Expand While adding w1-gpio in /boot/armbianEnv.txt, you don't need to add it in /etc/modules-load.d/modules.conf ... But you need to add "param_w1_pin=PD10" in /boot/armbianEnv.txt as well, otherwise it is defaulted to PD14. 2 Quote
Zamana Posted October 9, 2020 Posted October 9, 2020 On 10/8/2020 at 5:25 PM, martinayotte said: While adding w1-gpio in /boot/armbianEnv.txt, you don't need to add it in /etc/modules-load.d/modules.conf ... But you need to add "param_w1_pin=PD10" in /boot/armbianEnv.txt as well, otherwise it is defaulted to PD14. Expand Hello martinayotte! Minutes after I posted my question, I found your first reply in another thread that lead me to the right path. I just don't replied here yesterday due to the limit of one post per day. Beyond this, one of the pins was wrong. With Orange Pi PC and that sensor, the correct is use 3.3V, and not 5V. So, for the red wire, PIN 1, and not 2. Now my temperature monitor system is alive and kicking! Thank you very much! 1 Quote
ahermann86 Posted October 31, 2020 Posted October 31, 2020 Hello, I know that this is about Armbian but maybe someone can help me anyway. The orangepi forum doesn't seem to accept new registrations ... I try to activate one wire communication with my Orange Pi One with kernel version 5.3.5+. I use the Debian image. I just want to read out a DS18B20 sensor. I modified the /boot/orangepiEnv.txt as descibed in http://linux-sunxi.org/1-Wire and above with this items: --- root@OrangePi:~# cat /boot/orangepiEnv.txt verbosity=1 logo=disabled console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=w1-gpio usbhost0 param_w1_pin=PA10 param_w1_pin_int_pullup=0 --- If I make "ls /sys/bus/w1/devices/" there is no w1 directory. where is the mistake? Does debian not support w1? Greetings Axel 0 Quote
Werner Posted October 31, 2020 Posted October 31, 2020 On 10/31/2020 at 11:58 AM, ahermann86 said: 5.3.5+ Expand On 10/31/2020 at 11:58 AM, ahermann86 said: /boot/orangepiEnv.txt Expand You are not using Armbian. This bugtracker is only for boards running Armbian. You should state your question at OrangePi forums. 0 Quote
martinayotte Posted October 31, 2020 Posted October 31, 2020 On 10/31/2020 at 11:58 AM, ahermann86 said: overlays=w1-gpio usbhost0 param_w1_pin=PA10 param_w1_pin_int_pullup=0 Expand Those settings should be in /boot/armbianEnv.txt using an Armbian image ... 0 Quote
ahermann86 Posted November 1, 2020 Posted November 1, 2020 On 10/31/2020 at 1:26 PM, martinayotte said: Those settings should be in /boot/armbianEnv.txt using an Armbian image ... Expand Hello, yes, that's how I understood it. I thought that Debian also works.... If it makes sense, I'll switch to armbian. Is armbian the better choice for hardware-related applications? 0 Quote
ahermann86 Posted November 3, 2020 Posted November 3, 2020 Hello, I have set up my system again. Now I am using armbian 5.8.5-sunxi. Now 1 wire also works, as described... Thanks for pointing out that I noticed that the image I used before is not longer maintained ... Greetings Axel 0 Quote
Satyr Posted September 5, 2021 Posted September 5, 2021 Hello How to create more then one w1-gpio bus ? "overlays=w1-gpio param_w1_pin=PA11,PA12,PA13" doesn't work. 0 Quote
martinayotte Posted September 6, 2021 Posted September 6, 2021 On 9/5/2021 at 8:23 AM, Satyr said: How to create more then one w1-gpio bus ? Expand Why do you need more than one bus ? You can have multiple devices on the same bus ... 0 Quote
martinayotte Posted September 24, 2021 Posted September 24, 2021 On 9/19/2021 at 3:30 PM, Satyr said: So, nobody knows ? Expand The DT overlay isn't written to support multiple buses ... But, again, why do you need more than one bus, since OneWire support multiple devices on the same bus ? 0 Quote
Zoltan Posted November 3, 2021 Posted November 3, 2021 On 9/24/2021 at 3:05 PM, martinayotte said: The DT overlay isn't written to support multiple buses ... But, again, why do you need more than one bus, since OneWire support multiple devices on the same bus ? Expand To respond on your question - I have 50x DS18B20 on breadboard with OPiZ (don't ask why). Out of these 50, max 24 works at the same time. If I connect more to the bus they randomly drop out and/or give false readings. I would also like to know how to configure more than one w1 bus. 0 Quote
