Romber Posted May 19, 2020 Posted May 19, 2020 I run this command I saw that my system clock is not synchronized. destructor@orangepiplus:~$ timedatectl Local time: Mon 2020-05-18 14:05:45 EEST Universal time: Mon 2020-05-18 11:05:45 UTC RTC time: Tue 1970-01-06 15:48:55 Time zone: Europe/Kiev (EEST, +0300) System clock synchronized: no NTP service: inactive RTC in local TZ: no So how can I active ntp server? I undestand that is common Linux OS question but when I installed Linux OS on PC devices it never disturb me because there it worked as default
xwiggen Posted May 20, 2020 Posted May 20, 2020 On 5/19/2020 at 9:06 PM, Romber said: I run this command I saw that my system clock is not synchronized. destructor@orangepiplus:~$ timedatectl Local time: Mon 2020-05-18 14:05:45 EEST Universal time: Mon 2020-05-18 11:05:45 UTC RTC time: Tue 1970-01-06 15:48:55 Time zone: Europe/Kiev (EEST, +0300) System clock synchronized: no NTP service: inactive RTC in local TZ: no So how can I active ntp server? I undestand that is common Linux OS question but when I installed Linux OS on PC devices it never disturb me because there it worked as default Expand You'll need to check your chrony config (https://chrony.tuxfamily.org/index.html) which is enabled by default.
Igor Posted May 20, 2020 Posted May 20, 2020 On 5/19/2020 at 9:06 PM, Romber said: because there it worked as default Expand Time is sync by default just by using a different app as @xwiggen pointed out.
Romber Posted May 20, 2020 Author Posted May 20, 2020 On 5/20/2020 at 6:38 AM, Werner said: armbianmonitor -u Expand destructor@orangepiplus:~$ armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually
guidol Posted May 20, 2020 Posted May 20, 2020 On 5/19/2020 at 9:06 PM, Romber said: I run this command I saw that my system clock is not synchronized. destructor@orangepiplus:~$ timedatectl So how can I active ntp server? I undestand that is common Linux OS question but when I installed Linux OS on PC devices it never disturb me because there it worked as default Expand timedatectl belongs to the timesyncd - which is normally used on the ubuntu-desktop. If you use armbian then normally ntpd or chronyd is used. To enable ntp for timesyncd ( see also https://askubuntu.com/questions/1058593/how-to-sync-the-time-to-network-with-timedatectl-on-ubuntu-18-04 ) use sudo timedatectl set-ntp true or timedatectl set-ntp 1 then check id it does work via systemctl status systemd-timesyncd.service check also if the ntp-servers in /etc/systemd/timesyncd.conf are reachable (german: https://www.dinotools.de/2015/01/12/zeit-per-systemd-mit-timesyncd-synchronisieren/ ) or use chronyd
guidol Posted May 20, 2020 Posted May 20, 2020 On 5/20/2020 at 7:18 PM, Romber said: destructor@orangepiplus:~$ armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually Expand Ahhh if you cant upload the log maybe you also cant reach the ntp server - so no sychonisation!
guidol Posted May 20, 2020 Posted May 20, 2020 For a test I deinstalled chrony on my armbian and armbian did automatically install/activate me timesyncd as replacement: Reveal hidden contents root@npi-neo2-24(192.168.6.24):~# apt remove chrony Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: systemd-timesyncd The following packages will be REMOVED: chrony The following NEW packages will be installed: systemd-timesyncd 0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded. Need to get 123 kB of archives. After this operation, 314 kB disk space will be freed. Do you want to continue? [Y/n] Get:1 http://httpredir.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 245.5-3 [123 kB] Fetched 123 kB in 1s (244 kB/s) dpkg: chrony: dependency problems, but removing anyway as you requested: systemd depends on systemd-timesyncd | time-daemon; however: Package systemd-timesyncd is not installed. Package time-daemon is not installed. Package chrony which provides time-daemon is to be removed. (Reading database ... 37771 files and directories currently installed.) Removing chrony (3.5-8) ... Selecting previously unselected package systemd-timesyncd. (Reading database ... 37741 files and directories currently installed.) Preparing to unpack .../systemd-timesyncd_245.5-3_arm64.deb ... Unpacking systemd-timesyncd (245.5-3) ... Setting up systemd-timesyncd (245.5-3) ... Created symlink /etc/systemd/system/sysinit.target.wants/systemd-timesyncd.service → /lib/systemd/system/systemd-timesyncd.service. Processing triggers for dbus (1.12.16-2) ... Processing triggers for man-db (2.9.1-1) ... and timedatectl is working fine root@npi-neo2-24(192.168.6.24):~# timedatectl Local time: Wed 2020-05-20 22:29:21 +03 Universal time: Wed 2020-05-20 19:29:21 UTC RTC time: Wed 2020-05-20 19:29:23 Time zone: Asia/Istanbul (+03, +0300) System clock synchronized: yes NTP service: active RTC in local TZ: no
Romber Posted May 20, 2020 Author Posted May 20, 2020 On 5/20/2020 at 7:31 PM, guidol said: For a test I deinstalled chrony on my armbian and armbian did automatically install/activate me timesyncd as replacement: Reveal hidden contents root@npi-neo2-24(192.168.6.24):~# apt remove chrony Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: systemd-timesyncd The following packages will be REMOVED: chrony The following NEW packages will be installed: systemd-timesyncd 0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded. Need to get 123 kB of archives. After this operation, 314 kB disk space will be freed. Do you want to continue? [Y/n] Get:1 http://httpredir.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 245.5-3 [123 kB] Fetched 123 kB in 1s (244 kB/s) dpkg: chrony: dependency problems, but removing anyway as you requested: systemd depends on systemd-timesyncd | time-daemon; however: Package systemd-timesyncd is not installed. Package time-daemon is not installed. Package chrony which provides time-daemon is to be removed. (Reading database ... 37771 files and directories currently installed.) Removing chrony (3.5-8) ... Selecting previously unselected package systemd-timesyncd. (Reading database ... 37741 files and directories currently installed.) Preparing to unpack .../systemd-timesyncd_245.5-3_arm64.deb ... Unpacking systemd-timesyncd (245.5-3) ... Setting up systemd-timesyncd (245.5-3) ... Created symlink /etc/systemd/system/sysinit.target.wants/systemd-timesyncd.service → /lib/systemd/system/systemd-timesyncd.service. Processing triggers for dbus (1.12.16-2) ... Processing triggers for man-db (2.9.1-1) ... and timedatectl is working fine root@npi-neo2-24(192.168.6.24):~# timedatectl Local time: Wed 2020-05-20 22:29:21 +03 Universal time: Wed 2020-05-20 19:29:21 UTC RTC time: Wed 2020-05-20 19:29:23 Time zone: Asia/Istanbul (+03, +0300) System clock synchronized: yes NTP service: active RTC in local TZ: no But not in my server Expand
guidol Posted May 21, 2020 Posted May 21, 2020 On 5/20/2020 at 9:13 PM, Romber said: But not in my server Expand firstly you need to get your network running (incl. internet-access) to complete - armbianmonitor -u - systemctl status systemd-timesyncd.service and - timedatectl to check if you can connect to the internet/ntp-servers and what kind of armbian you run Without that information is mostly impossible to help
Romber Posted May 21, 2020 Author Posted May 21, 2020 On 5/21/2020 at 5:26 AM, guidol said: to check if you can connect to the internet/ntp-servers and what kind of armbian you run Expand _,met$$$$$gg. @orangepiplus ,g$$$$$$$$$$$$$$$P. OS: Debian 10 buster ,g$$P"" """Y$$.". Kernel: armv7l Linux 5.4.35-sunxi ,$$P' `$$$. Uptime: 2d 28m ',$$P ,ggs. `$$b: Packages: 961 `d$$' ,$P"' . $$$ Shell: 21642 $$P d$' , $$P CPU: ARMv7 rev 5 (v7l) @ 4x 1.368GHz $$: $$. - ,d$$' GPU: $$\; Y$b._ _,d$P' RAM: 172MiB / 2012MiB Y$$. `.`"Y$$$$P"' `$$b "-.__ `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `"""" @orangepiplus:~$ armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually @orangepiplus:~$ systemctl status systemd-timesyncd.service ● systemd-timesyncd.service - Network Time Synchronization Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled) Drop-In: /lib/systemd/system/systemd-timesyncd.service.d └─disable-with-time-daemon.conf Active: inactive (dead) Condition: start condition failed at Tue 2020-05-19 12:33:35 EEST; 24h ago Docs: man:systemd-timesyncd.service(8) May 18 12:56:57 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped. May 19 12:33:01 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped. May 19 12:33:35 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped. @orangepiplus:~$ timedatectl Local time: Wed 2020-05-20 13:26:14 EEST Universal time: Wed 2020-05-20 10:26:14 UTC RTC time: Thu 1970-01-08 15:09:11 Time zone: Europe/Kiev (EEST, +0300) System clock synchronized: no NTP service: inactive RTC in local TZ: no
Heisath Posted May 21, 2020 Posted May 21, 2020 What @guidol is saying is that without internet connectivity you won't be able to NTP sync your clock (as NTP = network time protocol). The fact that 'armbianmonitor -u' is unable to upload you debug info indicates there's a problem with your network. Please use 'armbianmonitor -U' (notice capital U, see also note given in your output) and upload the results manually or post them here (try using a codebox). If this does not work for you atleast try something like 'ping google.com' to make sure your board can even connect to the internet. Otherwise NTP will not work.
guidol Posted May 21, 2020 Posted May 21, 2020 On 5/21/2020 at 8:18 PM, Romber said: Network/firewall problem detected. Not able to upload debug info. May 18 12:56:57 orangepiplus systemd[1]: Condition check resulted in Network Time Synchronization being skipped. Local time: Wed 2020-05-20 13:26:14 EEST Universal time: Wed 2020-05-20 10:26:14 UTC RTC time: Thu 1970-01-08 15:09:11 System clock synchronized: no NTP service: inactive Expand All these messages show us, that you network isnt working or isnt working correct. How did you configure your network? Network-Manager? /etc/network/interfaces? armbian-config? Can you ping 8.8.8.8? Can you ping armbian.com? What says ifconfig for eth0 or wlan0? whats the IP of your gateway/DNS? what is the content of /etc/resolv.conf (when not using network-manager) 2
xwiggen Posted May 22, 2020 Posted May 22, 2020 motd seems weird. did you start with a debian image (i.e. not coming from www.armbian.com/download) and pulled armbian repositories afterwards?
Romber Posted May 22, 2020 Author Posted May 22, 2020 On 5/21/2020 at 9:40 PM, Heisath said: What @guidol is saying is that without internet connectivity you won't be able to NTP sync your clock (as NTP = network time protocol). The fact that 'armbianmonitor -u' is unable to upload you debug info indicates there's a problem with your network. Please use 'armbianmonitor -U' (notice capital U, see also note given in your output) and upload the results manually or post them here (try using a codebox). If this does not work for you atleast try something like 'ping google.com' to make sure your board can even connect to the internet. Otherwise NTP will not Expand Network is connected. ping Google.com is executing good. armbianmonitor -U shows very much text.
Romber Posted May 22, 2020 Author Posted May 22, 2020 On 5/21/2020 at 10:10 PM, guidol said: All these messages show us, that you network isnt working or isnt working correct. How did you configure your network? Network-Manager? /etc/network/interfaces? armbian-config? Can you ping 8.8.8.8? Can you ping armbian.com? What says ifconfig for eth0 or wlan0? whats the IP of your gateway/DNS? what is the content of /etc/resolv.conf (when not using network-manager) Expand destructor@orangepiplus:~$ cat /etc/network/interfaces source /etc/network/interfaces.d/* # Network is managed by Network manager auto lo iface lo inet loopback All ping work :28:19 2020 from destructor@orangepiplus:~$ sudo ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.104 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fe80::8e0:7c3e:c125:9a2a prefixlen 64 scopeid 0x20<link> ether 02:81:7d:85:f6:f7 txqueuelen 1000 (Ethernet) RX packets 117227 bytes 98206563 (93.6 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 68716 bytes 8157760 (7.7 MiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 32 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 302 bytes 15100 (14.7 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 302 bytes 15100 (14.7 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether e0:b9:4d:1e:8e:3f txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 destructor@orangepiplus:~$ cat /etc/resolv.conf # Generated by NetworkManagernameserver 8.8.8.8 nameserver 192.168.0.1
xwiggen Posted May 23, 2020 Posted May 23, 2020 On 5/22/2020 at 11:06 PM, Romber said: Network is connected. ping Google.com is executing good. armbianmonitor -U shows very much text. Expand # sudo ufw reset # armbianmonitor -u # ntpdate -vd <ntpserver>
Romber Posted May 23, 2020 Author Posted May 23, 2020 On 5/23/2020 at 3:49 PM, xwiggen said: # sudo ufw reset # armbianmonitor -u # ntpdate -vd <ntpserver> Expand sudo: ufw: command not found Ok, I've installed it. @orangepiplus:~$ sudo ufw reset Resetting all rules to installed defaults. This may disrupt existing ssh connections. Proceed with operation (y|n)? y Backing up 'user.rules' to '/etc/ufw/user.rules.20200522_144043' Backing up 'before.rules' to '/etc/ufw/before.rules.20200522_144043' Backing up 'after.rules' to '/etc/ufw/after.rules.20200522_144043' Backing up 'user6.rules' to '/etc/ufw/user6.rules.20200522_144043' Backing up 'before6.rules' to '/etc/ufw/before6.rules.20200522_144043' Backing up 'after6.rules' to '/etc/ufw/after6.rules.20200522_144043' @orangepiplus:~$ armbianmonitor -u Network/firewall problem detected. Not able to upload debug info. Please fix this or use "-U" instead and upload whole output manually What is next? I think that I more and more break my system
Werner Posted May 24, 2020 Posted May 24, 2020 If in doubt start over with a clean image and then make sure your internet connectivity works.
Heisath Posted May 24, 2020 Posted May 24, 2020 Can you tell us which image you installed? MOTD really does seem weird.
xwiggen Posted May 24, 2020 Posted May 24, 2020 On 5/23/2020 at 9:39 PM, Romber said: What is next? I think that I more and more break my system Expand I'm pretty sure you started with a debian img and migrated to armbian: # fping armbian.com yields command not find, right? Anyhow, looks like fake hwclock failed to retain at least the datetime after last package install/reboot/shutdown. That's bad cause pretty much anything in userspace assumes datetime only moves forward. Start with a clean armbian image for your board (https://www.armbian.com/download) and come back if ntp is still not working.
xwiggen Posted May 24, 2020 Posted May 24, 2020 On 5/24/2020 at 11:16 AM, xwiggen said: I'm pretty sure you started with a debian img and migrated to armbian: # fping armbian.com yields command not find, right? Anyhow, looks like fake hwclock failed to retain at least the datetime after last package install/reboot/shutdown, maybe because /var is optimized in armbian (ram sync) and possibly not in debian resulting in an empty hwclock file. That's bad cause pretty much anything in userspace assumes datetime only moves forward. Start with a clean armbian image for your board (https://www.armbian.com/download) and come back if ntp is still not working. Expand
guidol Posted May 24, 2020 Posted May 24, 2020 On 5/22/2020 at 10:22 PM, xwiggen said: motd seems weird. did you start with a debian image Expand this seems to be an optional systeminfo-"tool" named neofetch:https://github.com/dylanaraps/neofetch Quote Neofetch is a command-line system information tool written in bash 3.2+. Neofetch displays information about your operating system, software and hardware in an aesthetic and visually pleasing way. Expand Installation: https://github.com/dylanaraps/neofetch/wiki/Installation 2 examples: root@npi-neo2-24(192.168.6.24):/home/guido/neofetch# neofetch _,met$$$$$gg. root@npi-neo2-24 ,g$$$$$$$$$$$$$$$P. ---------------- ,g$$P" """Y$$.". OS: Debian GNU/Linux bullseye/sid aarch64 ,$$P' `$$$. Host: FriendlyARM NanoPi NEO 2 ',$$P ,ggs. `$$b: Kernel: 5.6.12-sunxi64 `d$$' ,$P"' . $$$ Uptime: 4 days, 1 hour, 49 mins $$P d$' , $$P Packages: 534 (dpkg) $$: $$. - ,d$$' Shell: bash 5.0.16 $$; Y$b._ _,d$P' Terminal: /dev/pts/0 Y$$. `.`"Y$$$$P"' CPU: sun50iw1p1 (4) @ 1.008GHz `$$b "-.__ Memory: 124MiB / 987MiB `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `""" root@fox-g20(192.168.6.15):/home/guido/neofetch# neofetch _,met$$$$$gg. root@fox-g20 ,g$$$$$$$$$$$$$$$P. ------------ ,g$$P" """Y$$.". OS: Debian GNU/Linux 9 (stretch) armv5tejl ,$$P' `$$$. Host: Acme Systems FOX Board G20 ',$$P ,ggs. `$$b: Kernel: 4.9.124+ `d$$' ,$P"' . $$$ Uptime: 1 day, 11 hours, 22 mins $$P d$' , $$P Packages: 442 (dpkg) $$: $$. - ,d$$' Shell: bash 4.4.12 $$; Y$b._ _,d$P' Terminal: /dev/pts/0 Y$$. `.`"Y$$$$P"' CPU: Atmel AT91SAM9 (1) `$$b "-.__ Memory: 10MiB / 56MiB `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `""" see also: https://www.omgubuntu.co.uk/2016/11/neofetch-terminal-system-info-app
xwiggen Posted May 24, 2020 Posted May 24, 2020 On 5/24/2020 at 9:23 PM, guidol said: this seems to be an optional systeminfo-"tool" named neofetch:https://github.com/dylanaraps/neofetch Installation: https://github.com/dylanaraps/neofetch/wiki/Installation 2 examples: root@npi-neo2-24(192.168.6.24):/home/guido/neofetch# neofetch _,met$$$$$gg. root@npi-neo2-24 ,g$$$$$$$$$$$$$$$P. ---------------- ,g$$P" """Y$$.". OS: Debian GNU/Linux bullseye/sid aarch64 ,$$P' `$$$. Host: FriendlyARM NanoPi NEO 2 ',$$P ,ggs. `$$b: Kernel: 5.6.12-sunxi64 `d$$' ,$P"' . $$$ Uptime: 4 days, 1 hour, 49 mins $$P d$' , $$P Packages: 534 (dpkg) $$: $$. - ,d$$' Shell: bash 5.0.16 $$; Y$b._ _,d$P' Terminal: /dev/pts/0 Y$$. `.`"Y$$$$P"' CPU: sun50iw1p1 (4) @ 1.008GHz `$$b "-.__ Memory: 124MiB / 987MiB `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `""" root@fox-g20(192.168.6.15):/home/guido/neofetch# neofetch _,met$$$$$gg. root@fox-g20 ,g$$$$$$$$$$$$$$$P. ------------ ,g$$P" """Y$$.". OS: Debian GNU/Linux 9 (stretch) armv5tejl ,$$P' `$$$. Host: Acme Systems FOX Board G20 ',$$P ,ggs. `$$b: Kernel: 4.9.124+ `d$$' ,$P"' . $$$ Uptime: 1 day, 11 hours, 22 mins $$P d$' , $$P Packages: 442 (dpkg) $$: $$. - ,d$$' Shell: bash 4.4.12 $$; Y$b._ _,d$P' Terminal: /dev/pts/0 Y$$. `.`"Y$$$$P"' CPU: Atmel AT91SAM9 (1) `$$b "-.__ Memory: 10MiB / 56MiB `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `""" see also: https://www.omgubuntu.co.uk/2016/11/neofetch-terminal-system-info-app Expand Ah thx, didn't know about this packagw.
Romber Posted May 27, 2020 Author Posted May 27, 2020 On 5/24/2020 at 7:46 AM, Heisath said: Can you tell us which image you installed? MOTD really does seem weird. Expand destructor@orangepiplus:~$ screenfetch _,met$$$$$gg. destructor@orangepiplus ,g$$$$$$$$$$$$$$$P. OS: Debian 10 buster ,g$$P"" """Y$$.". Kernel: armv7l Linux 5.4.35-sunxi ,$$P' `$$$. Uptime: 1m ',$$P ,ggs. `$$b: Packages: 963 `d$$' ,$P"' . $$$ Shell: 1583 $$P d$' , $$P CPU: ARMv7 rev 5 (v7l) @ 4x 1.368GHz $$: $$. - ,d$$' GPU: $$\; Y$b._ _,d$P' RAM: 169MiB / 2012MiB Y$$. `.`"Y$$$$P"' `$$b "-.__ `Y$$ `Y$$. `$$b. `Y$$b. `"Y$b._ `""""
Romber Posted May 27, 2020 Author Posted May 27, 2020 On 5/24/2020 at 11:16 AM, xwiggen said: I'm pretty sure you started with a debian img and migrated to armbian: Expand You're wrong. I installed clean armbian image.
martinayotte Posted May 28, 2020 Posted May 28, 2020 On 5/27/2020 at 6:37 PM, Romber said: You're wrong. I installed clean armbian image. Expand I doubt since even "screenfetch" isn't part of Armbian images ...
xwiggen Posted May 29, 2020 Posted May 29, 2020 On 5/27/2020 at 6:37 PM, Romber said: You're wrong. I installed clean armbian image. Expand You miss fping which is installed by default and used by armbianmonitor to check network availability (uploading). Go ahead, install it and try armbianmonitor -u. The only other possible explanation I can think of not reaching NTP servers is that your ISP is blocking remote NTP servers (DDOS mitigation), that happens rarely, is easily checked by 'ntpdate -vd pool.ntp.org' (non privileged port, so not blocked), or even simpler, use your gateway ip as most routers broadcast it anyway.
Romber Posted May 29, 2020 Author Posted May 29, 2020 On 5/29/2020 at 6:45 PM, xwiggen said: Go ahead, install it and try armbianmonitor -u. Expand destructor@orangepiplus:~$ sudo apt install fping [sudo] password for destructor: Reading package lists... Done Building dependency tree Reading state information... Done fping is already the newest version (4.2-1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
