Werner Posted September 5, 2020 Posted September 5, 2020 I also noticed that the subforums SD card and PSU issues and the garbage collector Board doesn't start are kind of redundant. Should those be merged too? 1
Tido Posted September 5, 2020 Posted September 5, 2020 13 hours ago, Werner said: Should those be merged too? Not really. If you face one or the other problem you look for a section in the forum to search or place your question. If you merge it anyway, how will you cover all 3?
Werner Posted September 6, 2020 Author Posted September 6, 2020 7 hours ago, Tido said: how will you cover all 3? Basically doing the same thing as I did before when merging common issues and p2p. Merge their names too.
Tido Posted September 6, 2020 Posted September 6, 2020 8 hours ago, Werner said: merging common issues and p2p Like this: SD card and PSU issues / Board does not start ? by the way, both are garbage collectors
chwe Posted September 6, 2020 Posted September 6, 2020 sd card and PSU issues was once thought to be a subforum where stuff gets moved to once we know it's a psu issue.. to point people at it in case they don't believe their shitty setup is the reason things don't go as expected.. kinda hall of ....
Werner Posted September 7, 2020 Author Posted September 7, 2020 17 hours ago, Tido said: Like this: SD card and PSU issues / Board does not start ? Yep, something like this. Quote by the way, both are garbage collectors Another reason to get rid of one of those Quote sd card and PSU issues was once thought to be a subforum where stuff gets moved to once we know it's a psu issue.. to point people at it in case they don't believe their shitty setup is the reason things don't go as expected.. kinda hall of .... Understand. But it seems to me it is kind a mixed at the moment because there was not much such "movement". 1
Igor Posted September 9, 2020 Posted September 9, 2020 ... while "board doesn't start" should be exclusively used - which is why each needs a approval - for most critical things. If someone breaks the board or uses XYZ hw which doesn't boot, its (usually/should be) moved elsewhere. Both are sub forums and are at least clear or much clearer what is their purpose (contrary to P2P / common issues). Cause of bad powering one could boot the board and have problems, but also not boot the board. Powering is responsible for not booting the board, its most possible but not the only reason why things doesn't boot. However we are working on to have a full control over the hardware with our automated testings. Then, this forum really becomes obsolete and can be unified. We will remove - or at least will be able to know which board doesn't boot. We would not seek that information from users anymore. If they f* the system up, topics goes elsewhere in any case. I would say merge should be prepared once our automated testing becomes fully automated?
Werner Posted September 10, 2020 Author Posted September 10, 2020 Bad or badly written sd card could be also a reason indeed, though for that case there is no specific sub-forum. But for PSU issues only . Anyway there are no hurries. We can leave this here open and wait for proper feedback from automated testings. As for me however I still think it is not worth keeping at this stage . Merge itself can be done in no time.
Werner Posted September 12, 2020 Author Posted September 12, 2020 The link behind "Your board doesn't work?" needs to be adjusted when this merge is complete since it points to the PSU issue forum.
