Armbian v20.11 (Tamandua) Planning Thread
Go to solution Solved by Werner,
41 minutes ago, balbes150 said:
latest night version on NanoPC T4 and found that the system does not start from the SD card
Can you post the log of the boot process captured with serial?
Can you also try if booting with "BOOT" button pressed is successful? - to rule out any incompatibilities between the u-boot in eMMC and SD
Только что, piter75 сказал:
Specify which button you are writing about.
Sori, it seems the reason is in a different patch. I had to remove all patches (except changing the order of SD \ eMMC). And now you need to check all the patches to find which one breaks the download from the SD card.
Strange behavior. If you use the latest night image T4 from the site (from the download page from 17 10 2020), the SD card does not work. If I start building an image for T4 from the latest Master, and then take the u-boot files from the received package and manually write them to the SD card, everything starts working.
Replaced the SD cards and all images from the site worked. For some reason, only Sandisk works, other cards  give do not predictable behavior. On my builds with u-boot-20.10, all cards work without problems.
Is anybody interested in doing a kind of hackathon in irc on a weekend for testing and bug fixes?
I assume the upcoming 7th one?
Are we able to sqeeze upgrade to 5.9.y ... 5.8.y just got EOL-ed.
I could imagine this weekends saturday night (saturday night in UTC so afternoon for Americans). Would try to get 5.9 for mvebu.
Not sure if it is worth it to try squeezing all boards in. Depends on ppl. participating w/ testing.
All boards received test - build - from trunk - for testing. This is the last bug hunting release candidate. We will fix what we can and write down what we have found and what we were not been able to fix.
Bugs yet do be fixed or documented (will be added later):
Machine / reporter
Pinebook - no screen @martinayotte @Igor
Opi3 - networking issues  @lanefu
Orangepi R1 freezing under certain condition
Odroid C2 - sd card corruption happen pretty quickly
U-Boot 2020.04-armbian (Nov 15 2020 - 17:56:12 +0100) odroid-c2
Model: Hardkernel ODROID-C2
SoC:   Amlogic Meson GXBB (S905) Revision 1f:b (0:1)
DRAM:  2 GiB
MMC:   mmc@72000: 0, mmc@74000: 1
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@c9410000
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
7146 bytes read in 3 ms (2.3 MiB/s)
## Executing script at 08000000
161 bytes read in 2 ms (78.1 KiB/s)
16040424 bytes read in 1412 ms (10.8 MiB/s)
 ** fs_devread read error - block
Failed to mount ext2 filesystem...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Data Size:    16040360 Bytes = 15.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
   Loading Ramdisk to 7d014000, end 7df601a8 ... OK
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
Nanopi Neo3 @Igor
Odroid N2 hangs on reboot sometimes
Orangepi Win sometimes powers off on stress @Igor
Ubuntu Bionic Allwinner H6 doesn't boot @Igor
Mvebu and mvebu family will stay at 5.8.y @Heisath and will be moved up after.
Other boards are surviving stressing https://beta.armbian.com/autotest.html
There is a general idea to make this release with kernel 5.8.y where we have troubles with the kernel. Otherwise we will not catch this train.
DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 249
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15223MB
FwPartOffset=2000 , 0
StorageInit ok = 20181
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x337a9f0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xa5d24
RunBL31 0x40000
INFO:    Preloader serial: 2
NOTICE:  BL31: v1.3(debug):403e0b816
NOTICE:  BL31: Built : 14:13:08, Aug 11 2020
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Oct 19 2020 - 17:50:06 +0200)
Model: FriendlyElec NanoPi R2S
DRAM:  2 GiB
PMIC:  RK8050 (on=0x40, off=0x00)
MMC:   mmc@ff500000: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
reboot
[  OK  ] Finished Reboot.
[  OK  ] Reached target Reboot.
[   38.959088] watchdog: watchdog0: watchdog did not stop!
[   39.325684] reboot: Restarting system
INFO:    PSCI Power Domain Map:
INFO:      Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO:      Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO:      Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO:      CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x1, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x2, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x3, parent_node 1, State ON (0x0)
During my latest tests for Pinebook-a64, if I remember correctly, I've took from latest working build 5.7.6 the DTB and I tried to boot in either 5.8.0 or 5.9.1 images, screen is working during first phase of the boot, but then it switch to blank screen, either if it is a desktop or plain text image. So, it is not a DTB issue, but probably a kernel issue ... I tried to compare ".config" between 5.7.6 and other builds, but I didn't figure out what is missing, It maybe also be in the kernel code itself too...
BTW, I've found another glitch :
I've built a 5.9.8 DEV Pinebook-Pro Desktop image and I didn't have WiFi working. I've figured out that no firmware were present in the image, I've copied them from previous 5.8.1 image...
Yeah. Firmware was broken .... but it should be fixed now.
12.11.2020 в 20:43, Igor сказал:
I tried the latest night image of Focal 5.9.8 from November 13, running from an SD card. In startup mode with SD \ emmc, I didn't find any problems with rebooting (I rebooted many times).
I am getting kernel panic on my Rockpi-4b legacy, both with the images I build and also when I switch to nightly from a 20.8 image. Am I the only one?
Welcome to minicom 2.7.1
OPCIONES: I18n
Compilado en Dec 23 2019, 02:06:26.
Port /dev/ttyUSB0, 20:56:35
Using character set conversion
Presione CTRL-A Z para obtener ayuda sobre teclas especiales
�DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 250
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14930MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68417
SecureMode = 0
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xa91f8
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    boot cpu mask: 0
INFO:    If lpddr4 need support multi frequency,
INFO:    please update loader!
INFO:    Current ctl index[0] freq=400MHz
INFO:    Current ctl index[1] freq=800MHz
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Sep 03 2020 - 17:16:23 +0200)
SoC: Rockchip rk3399
Reset cause: POR
Model: Radxa ROCK Pi 4
DRAM:  2 GiB
PMIC:  RK808
MMC:   mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Net:   eth0: ethernet@fe300000
Card did not respond to voltage select!
mmc0(part 0) is current device
Scanning mmc 0:1...
3185 bytes read in 19 ms (163.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
227 bytes read in 15 ms (14.6 KiB/s)
11551080 bytes read in 1117 ms (9.9 MiB/s)
22181896 bytes read in 2132 ms (9.9 MiB/s)
93424 bytes read in 48 ms (1.9 MiB/s)
535 bytes read in 21 ms (24.4 KiB/s)
Applying user provided DT overlay cpufreq.dtbo
2698 bytes read in 37 ms (70.3 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Data Size:    11551016 Bytes = 11 MiB
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 7d41b000, end 7df1f128 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Loading Device Tree to 000000007d39b000, end 000000007d41afff ... OK
Starting kernel ...
[    2.720026] Internal error: Oops: 96000005 [#1] SMP
[    2.720538] Modules linked in:
[    2.720865] CPU: 4 PID: 1 Comm: swapper/0 Not tainted 4.4.213-rockchip64 #6
[    2.721563] Hardware name: ROCK PI 4B (DT)
[    2.721978] task: ffffffc0789e8000 task.stack: ffffffc078aa0000
[    2.722585] PC is at rockchip_spi_probe+0x2b0/0x43c
[    2.723078] LR is at rockchip_spi_probe+0x224/0x43c
[    2.723569] pc : [<ffffff800879c22c>] lr : [<ffffff800879c1a0>] pstate: 80000
045
[    2.724308] sp : ffffffc078aa3bd0
[    2.724646] x29: ffffffc078aa3bd0 x28: 0000000000000000
[    2.725200] x27: 0000000000000000 x26: ffffff80093f2488
[    2.725754] x25: ffffffc07d7d0200 x24: ffffffc077c19800
[    2.726306] x23: ffffffc0781fd200 x22: ffffffc077c19810
[    2.726859] x21: ffffffc07d67e800 x20: ffffffc07d67ee10
[    2.727412] x19: 0000000000000000 x18: 0000000000000010
[    2.727964] x17: 000000000000000c x16: 0000000000001000
[    2.728517] x15: 0000000000000000 x14: ffffffffffffffff
[    2.729069] x13: 0000000000000008 x12: 00000000ffffffff
[    2.729621] x11: ffffffc07d6199b4 x10: 0000000000000001
[    2.730174] x9 : 0000000000000050 x8 : ffffffc07d619c00
[    2.730726] x7 : 0000000000000050 x6 : 0000000000000010
[    2.731278] x5 : 0000000000000008 x4 : 0000000000000001
[    2.731831] x3 : 0000000000000200 x2 : 0000000000001a01
[    2.732383] x1 : ffffff8008fc2dbc x0 : 0000000000000000
[    2.732937]
[    2.732937] PC: 0xffffff800879c1ac:
[    2.733437] c1ac  b4000060 97fabbd5 f900669f f9400280 d0004121 91366821 97fda
900 f9406680
[    2.734347] c1cc  b4000280 f9405a80 b4000240 f94002e0 91100000 f9006e80 f9400
2e0 91200000
[    2.735257] c1ec  f9006280 52800020 b900d280 52800040 b900ba80 f0ffffe0 910d7
000 f901eaa0
[    2.736165] c20c  f9406680 f902faa0 f9405a80 f902fea0 f9400280 d0004121 9136f
021 f9412000
[    2.737074] c22c  f9400000 97f93b68 f9007280 b4000060 b140041f 540000c9 aa160
3e0 d0004121
[    2.737984] c24c  91371c21 97fda8dd f900729f aa1503e1 aa1603e0 97fff3ac 2a000
3f3 34ffec80
[    2.738892] c26c  aa1603e0 d0004121 91379021 97fda89c aa1603e0 52800021 97fde
7f1 f9406680
[    2.739800] c28c  b4000040 97fabb9d f9405a80 b40005a0 97fabb9a 1400002b 2a000
3f3 14000029
[    2.740710]
[    2.740710] LR: 0xffffff800879c120:
[    2.741209] c120  b9034aa0 f0ffffe0 913bf000 f90272a0 f0ffffe0 9108e000 f9026
aa0 f0ffffe0
[    2.742117] c140  910c8000 f9026ea0 f0ffffe0 91242000 f90276a0 f0ffffe0 9109d
000 f9027aa0
[    2.743025] c160  f9400280 97fab998 f9006680 b40000a0 b140041f 540000e9 b1081
41f 54000940
[    2.743934] c180  f9400280 d0004121 9135e021 97fda90e f9400280 b0003fc1 91301
821 97fab98a
[    2.744842] c1a0  f9005a80 b5000120 f9406680 b4000060 97fabbd5 f900669f f9400
280 d0004121
[    2.745751] c1c0  91366821 97fda900 f9406680 b4000280 f9405a80 b4000240 f9400
2e0 91100000
[    2.746659] c1e0  f9006e80 f94002e0 91200000 f9006280 52800020 b900d280 52800
040 b900ba80
[    2.747567] c200  f0ffffe0 910d7000 f901eaa0 f9406680 f902faa0 f9405a80 f902f
ea0 f9400280
[    2.748477]
[    2.748477] SP: 0xffffffc078aa3b50:
[    2.748975] 3b50  77c19810 ffffffc0 781fd200 ffffffc0 77c19800 ffffffc0 7d7d0
200 ffffffc0
[    2.749884] 3b70  093f2488 ffffff80 00000000 00000000 00000000 00000000 78aa3
bd0 ffffffc0
[    2.753132] 3b90  0879c1a0 ffffff80 78aa3bd0 ffffffc0 0879c22c ffffff80 80000
045 00000000
[    2.756393] 3bb0  78aa3bd0 ffffffc0 0879c1a0 ffffff80 ffffffff ffffffff 7d67e
e10 ffffffc0
[    2.759640] 3bd0  78aa3c30 ffffffc0 0870c098 ffffff80 fffffffe 00000000 77c19
810 ffffffc0
[    2.762851] 3bf0  094edaa8 ffffff80 094edaa8 ffffff80 09777658 ffffff80 00000
000 00000000
[    2.766064] 3c10  094df2d0 ffffff80 0870c07c ffffff80 00000000 00000000 77c19
810 ffffffc0
[    2.769272] 3c30  78aa3c60 ffffffc0 0870a1a0 ffffff80 77c19810 ffffffc0 00000
000 00000000
[    2.772524]
[    2.772524] X1: 0xffffff8008fc2d3c:
[    2.777680] 2d3c  73207465 705f6970 0a6b6c63 69614600 2064656c 67206f74 66207
465 206f6669
[    2.780947] 2d5c  676e656c 000a6874 72262826 6c3e2d73 296b636f 6c723e2d 006b6
36f 6c696146
[    2.784245] 2d7c  74206465 6572206f 73657571 58542074 414d4420 61686320 6c656
e6e 6146000a
[    2.787580] 2d9c  64656c69 206f7420 75716572 20747365 44205852 6320414d 6e6e6
168 000a6c65
[    2.790966] 2dbc  68676968 6570735f 6e006465 6968206f 735f6867 64656570 6e697
020 6c727463
[    2.794404] 2ddc  61747320 000a6574 6c696146 74206465 6572206f 74736967 6d207
265 65747361
[    2.797870] 2dfc  46000a72 656c6961 6f742064 616e6520 20656c62 5f697073 0a6b6
c63 2d787200
[    2.801395] 2e1c  706d6173 642d656c 79616c65 00736e2d 6c696146 74206465 6e652
06f 656c6261
[    2.804971]
[    2.804971] X8: 0xffffffc07d619b80:
[    2.810907] 9b80  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.814564] 9ba0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.818207] 9bc0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.821844] 9be0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.825475] 9c00  00000000 00000000 00000000 00000000 7d619828 ffffffc0 7d630
000 00000000
[    2.829107] 9c20  097de000 ffffff80 00000000 00000000 7d630100 00000000 097de
100 ffffff80
[    2.832740] 9c40  00000000 00000000 00000001 ffffffff 00000001 00000001 00000
000 00000000
[    2.836403] 9c60  7d619828 ffffffc0 7d630200 00000000 097de200 ffffff80 00000
000 00000000
[    2.840046]
[    2.840046] X11: 0xffffffc07d619934:
[    2.846032] 9934  ffffff80 0864e1a8 ffffff80 001d0100 00000000 00000000 00000
000 75b0e000
[    2.849682] 9954  ffffffc0 75b0ebb8 ffffffc0 00010001 dead4ead ffffffff 00000
000 ffffffff
[    2.853319] 9974  ffffffff 00000200 00000000 097e8000 ffffff80 00241330 00000
001 29020040
[    2.856954] 9994  000fffff 00000010 0000ffff 00020002 dead4ead ffffffff 00000
000 ffffffff
[    2.860576] 99b4  ffffffff 00000000 00000001 ffffffff ffffffff ffffffff fffff
fff ffffffff
[    2.864171] 99d4  ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff fffff
fff ffffffff
[    2.867711] 99f4  ffffffff 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.871294] 9a14  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.874820]
[    2.874820] X20: 0xffffffc07d67ed90:
[    2.880537] ed90  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.884047] edb0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.887498] edd0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.890904] edf0  77e42bc8 ffffffc0 77e42cc0 ffffffc0 00000000 00000000 00000
000 00000000
[    2.894292] ee10  77c19810 ffffffc0 7d67e800 ffffffc0 7d7d0200 ffffffc0 7d7d0
040 ffffffc0
[    2.897669] ee30  0a0dc000 ffffff80 00000020 02faf080 00000000 00000000 00000
000 00000000
[    2.901028] ee50  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.904391] ee70  00000000 00000000 00000000 00000000 00000000 dead4ead fffff
fff 00000000
[    2.907701]
[    2.907701] X21: 0xffffffc07d67e780:
[    2.913023] e780  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.916346] e7a0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.919648] e7c0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.922899] e7e0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.926108] e800  77c19810 ffffffc0 00000000 00000000 00000000 00000000 7d67e
818 ffffffc0
[    2.929305] e820  7d67e818 ffffffc0 00000000 00000000 78065180 ffffffc0 094df
0b0 ffffff80
[    2.932461] e840  00000000 00000000 00000001 00000001 00000000 00000000 00000
000 00000000
[    2.935648] e860  00000001 00000000 00000000 dead4ead ffffffff 00000000 fffff
fff ffffffff
[    2.938800]
[    2.938800] X22: 0xffffffc077c19790:
[    2.943770] 9790  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.946899] 97b0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.949966] 97d0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.952973] 97f0  00000000 00000000 00000000 00000000 781fa500 ffffffc0 fffff
fff 00000000
[    2.955939] 9810  094df3f0 ffffff80 781f7900 ffffffc0 781fa500 ffffffc0 77c19
c28 ffffffc0
[    2.958883] 9830  77c19428 ffffffc0 094df400 ffffff80 78065180 ffffffc0 094df
0b0 ffffff80
[    2.961791] 9850  781ff708 ffffffc0 00000003 00000007 00000000 00000000 00000
000 00000000
[    2.964734] 9870  00000000 00000000 00000000 dead4ead ffffffff 00000000 fffff
fff ffffffff
[    2.967657]
[    2.967657] X23: 0xffffffc0781fd180:
[    2.972352] d180  ff1a0000 00000000 ff1a00ff 00000000 7ff875d0 ffffffc0 00000
200 00000000
[    2.975436] d1a0  00000000 00000000 00000000 00000000 00000000 00000000 00000
026 00000000
[    2.978527] d1c0  00000026 00000000 7ff875d0 ffffffc0 00000404 00000000 00000
000 00000000
[    2.981602] d1e0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.984653] d200  ff1d0000 00000000 ff1d0fff 00000000 7ff88ae8 ffffffc0 00000
200 00000000
[    2.987685] d220  00000000 00000000 00000000 00000000 00000000 00000000 00000
027 00000000
[    2.990677] d240  00000027 00000000 7ff88ae8 ffffffc0 00000404 00000000 00000
000 00000000
[    2.993678] d260  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    2.996631]
[    2.996631] X24: 0xffffffc077c19780:
[    3.001251] 9780  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    3.004229] 97a0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    3.007174] 97c0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    3.010102] 97e0  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    3.012974] 9800  781fa500 ffffffc0 ffffffff 00000000 094df3f0 ffffff80 781f7
900 ffffffc0
[    3.015888] 9820  781fa500 ffffffc0 77c19c28 ffffffc0 77c19428 ffffffc0 094df
400 ffffff80
[    3.018765] 9840  78065180 ffffffc0 094df0b0 ffffff80 781ff708 ffffffc0 00000
003 00000007
[    3.021660] 9860  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 dead4ead
[    3.024540]
[    3.024540] X25: 0xffffffc07d7d0180:
[    3.029149] 0180  7d7d0100 ffffffc0 77c19ae8 ffffffc0 080bc87c ffffff80 08f45
c96 ffffff80
[    3.032156] 01a0  00000018 00000000 09437af8 ffffff80 ff1d0000 00000000 00001
000 00000000
[    3.035179] 01c0  64316666 30303030 6970732e dead0000 00000003 00000000 77c65
000 ffffffc0
[    3.038200] 01e0  781fa500 ffffffc0 0000002a 00000000 77c66780 ffffffc0 00000
001 00000000
[    3.041259] 0200  788f3700 ffffffc0 781fa500 ffffffc0 08fc2d2a ffffff80 00000
000 00000000
[    3.044334] 0220  ffffffff ffffffff 788f2c28 ffffffc0 788f37b8 ffffffc0 00000
000 00000000
[    3.047361] 0240  7d7d0280 ffffffc0 00000000 00000000 00000000 00000000 00000
000 00000000
[    3.050412] 0260  00000000 00000000 00000000 00000000 00000000 00000000 00000
000 00000000
[    3.053406]
[    3.053406] X26: 0xffffff80093f2408:
[    3.058250] 2408  0933a4e8 ffffff80 0933b050 ffffff80 0933b0cc ffffff80 0933b
254 ffffff80
[    3.061405] 2428  0933b2ac ffffff80 0933bf1c ffffff80 0933bf44 ffffff80 0933b
f64 ffffff80
[    3.064542] 2448  0933c0b0 ffffff80 0933c0f4 ffffff80 0933c128 ffffff80 0933c
144 ffffff80
[    3.067666] 2468  0933c168 ffffff80 0933c188 ffffff80 0933c4d8 ffffff80 0933c
5a4 ffffff80
[    3.070753] 2488  0933c630 ffffff80 0933c75c ffffff80 0933c77c ffffff80 0933c
79c ffffff80
[    3.073818] 24a8  0933ca58 ffffff80 0933ca78 ffffff80 0933ca98 ffffff80 089b7
e90 ffffff80
[    3.076829] 24c8  0933caf4 ffffff80 0933cb1c ffffff80 0933cb44 ffffff80 0933c
b80 ffffff80
[    3.079838] 24e8  0933cdc0 ffffff80 0933d3a8 ffffff80 0933d3c8 ffffff80 0933d
3e8 ffffff80
[    3.082794]
[    3.082794] X29: 0xffffffc078aa3b50:
[    3.087553] 3b50  77c19810 ffffffc0 781fd200 ffffffc0 77c19800 ffffffc0 7d7d0
200 ffffffc0
[    3.090647] 3b70  093f2488 ffffff80 00000000 00000000 00000000 00000000 78aa3
bd0 ffffffc0
[    3.093741] 3b90  0879c1a0 ffffff80 78aa3bd0 ffffffc0 0879c22c ffffff80 80000
045 00000000
[    3.096854] 3bb0  78aa3bd0 ffffffc0 0879c1a0 ffffff80 ffffffff ffffffff 7d67e
e10 ffffffc0
[    3.099960] 3bd0  78aa3c30 ffffffc0 0870c098 ffffff80 fffffffe 00000000 77c19
810 ffffffc0
[    3.103038] 3bf0  094edaa8 ffffff80 094edaa8 ffffff80 09777658 ffffff80 00000
000 00000000
[    3.106093] 3c10  094df2d0 ffffff80 0870c07c ffffff80 00000000 00000000 77c19
810 ffffffc0
[    3.109178] 3c30  78aa3c60 ffffffc0 0870a1a0 ffffff80 77c19810 ffffffc0 00000
000 00000000
[    3.112232]
[    3.114578] Process swapper/0 (pid: 1, stack limit = 0xffffffc078aa0000)
[    3.117471] Stack: (0xffffffc078aa3bd0 to 0xffffffc078aa4000)
[    3.120306] 3bc0:                                   ffffffc078aa3c30 ffffff80
0870c098
[    3.123384] 3be0: 00000000fffffffe ffffffc077c19810 ffffff80094edaa8 ffffff80
094edaa8
[    3.126480] 3c00: ffffff8009777658 0000000000000000 ffffff80094df2d0 ffffff80
0870c07c
[    3.129595] 3c20: 0000000000000000 ffffffc077c19810 ffffffc078aa3c60 ffffff80
0870a1a0
[    3.132734] 3c40: ffffffc077c19810 0000000000000000 ffffff8009777000 ffffff80
094edaa8
[    3.135850] 3c60: ffffffc078aa3cb0 ffffff800870a2d8 ffffffc077c19810 ffffff80
094edaa8
[    3.138979] 3c80: ffffffc077c19870 ffffff800870a284 ffffff80094df1c0 ffffff80
092f2660
[    3.142057] 3ca0: ffffff8009300358 ffffff800870a284 ffffffc078aa3ce0 ffffff80
08708550
[    3.145163] 3cc0: 0000000000000000 ffffff80094df720 ffffff80094edaa8 ffffff80
08c564d0
[    3.148306] 3ce0: ffffffc078aa3d20 ffffff8008709c50 ffffff80094edaa8 ffffffc0
7d7cf240
[    3.151479] 3d00: 0000000000000000 ffffff80094df720 ffffffc0780b40d0 ffffffc0
781f7978
[    3.154641] 3d20: ffffffc078aa3d40 ffffff80087098a4 ffffff80094edaa8 ffffffc0
7d7cf240
[    3.157809] 3d40: ffffffc078aa3d80 ffffff800870ae44 ffffff80094edaa8 00000000
00000000
[    3.160958] 3d60: ffffff800942dce0 ffffff800942dce0 0000000000000000 00000000
00000000
[    3.164086] 3d80: ffffffc078aa3da0 ffffff800870bfdc ffffff80094eda80 00000000
00000000
[    3.167175] 3da0: ffffffc078aa3dc0 ffffff800933c5bc ffffffc07d7cad80 ffffff80
0933c5a4
[    3.170276] 3dc0: ffffffc078aa3dd0 ffffff8008083120 ffffffc078aa3e50 ffffff80
09300da8
[    3.173327] 3de0: 0000000000000174 ffffff80095ab000 ffffff8009367888 00000000
00000006
[    3.176369] 3e00: ffffff8009367870 ffffff80093f1cf0 0000000000000000 00000000
00000000
[    3.179399] 3e20: ffffff800943a510 ffffff80092f6080 0000000600000006 00000000
00000000
[    3.182382] 3e40: ffffff8008cece78 ffffff8009016e9c ffffffc078aa3ea0 ffffff80
08c52110
[    3.185377] 3e60: ffffff8008c520f8 0000000000000000 0000000000000000 00000000
00000000
[    3.188392] 3e80: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.191379] 3ea0: 0000000000000000 ffffff8008082ef0 ffffff8008c520f8 00000000
00000000
[    3.194380] 3ec0: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.197337] 3ee0: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.200277] 3f00: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.203146] 3f20: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.205999] 3f40: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.208835] 3f60: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.211657] 3f80: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.214467] 3fa0: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.217259] 3fc0: 0000000000000000 0000000000000005 0000000000000000 00000000
00000000
[    3.220036] 3fe0: 0000000000000000 0000000000000000 0000000000000000 00000000
00000000
[    3.222796] Call trace:
[    3.225025] Exception stack(0xffffffc078aa3a00 to 0xffffffc078aa3b30)
[    3.227683] 3a00: 0000000000000000 0000008000000000 ffffffc078aa3bd0 ffffff80
0879c22c
[    3.230461] 3a20: ffffffc077e42cc0 ffffffc07d619828 0000000000000000 ffffffc0
7d619850
[    3.233251] 3a40: 0000000000000002 ffffff8008fa1b7e ffffffc078aa3a80 ffffff80
0864a588
[    3.236035] 3a60: ffffffc078aa3a80 ffffff800864a54c ffffffc077e42cc0 ffffff80
094cf448
[    3.238811] 3a80: ffffffc078aa3ab0 ffffff8008982b4c ffffffc07ff73928 ffffffc0
7ff88a38
[    3.241586] 3aa0: 0000000000000000 ffffff8008fc2dbc 0000000000001a01 00000000
00000200
[    3.244366] 3ac0: 0000000000000001 0000000000000008 0000000000000010 00000000
00000050
[    3.247125] 3ae0: ffffffc07d619c00 0000000000000050 0000000000000001 ffffffc0
7d6199b4
[    3.249876] 3b00: 00000000ffffffff 0000000000000008 ffffffffffffffff 00000000
00000000
[    3.252607] 3b20: 0000000000001000 000000000000000c
[    3.255038] [<ffffff800879c22c>] rockchip_spi_probe+0x2b0/0x43c
[    3.257564] [<ffffff800870c098>] platform_drv_probe+0x5c/0xb0
[    3.260027] [<ffffff800870a1a0>] driver_probe_device+0x184/0x268
[    3.262501] [<ffffff800870a2d8>] __driver_attach+0x54/0xa0
[    3.264912] [<ffffff8008708550>] bus_for_each_dev+0x88/0x98
[    3.267316] [<ffffff8008709c50>] driver_attach+0x30/0x3c
[    3.269673] [<ffffff80087098a4>] bus_add_driver+0x198/0x1dc
[    3.272054] [<ffffff800870ae44>] driver_register+0xa0/0xd8
[    3.274425] [<ffffff800870bfdc>] __platform_driver_register+0x58/0x64
[    3.276905] [<ffffff800933c5bc>] rockchip_spi_driver_init+0x18/0x20
[    3.279371] [<ffffff8008083120>] do_one_initcall+0x178/0x180
[    3.281785] [<ffffff8009300da8>] kernel_init_freeable+0x210/0x214
[    3.284236] [<ffffff8008c52110>] kernel_init+0x18/0xfc
[    3.286576] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[    3.288939] Code: f9400280 d0004121 9136f021 f9412000 (f9400000)
[    3.291406] ---[ end trace 7724c130b2ce0c7f ]---
[    3.293849] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00
00000b
[    3.293849]
[    3.298606] CPU5: stopping
[    3.300800] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G      D         4.4.213-r
ockchip64 #6
[    3.303545] Hardware name: ROCK PI 4B (DT)
[    3.305934] Call trace:
[    3.308151] [<ffffff8008088040>] dump_backtrace+0x0/0x1bc
[    3.310648] [<ffffff8008088220>] show_stack+0x24/0x30
[    3.313124] [<ffffff80085ad6b4>] dump_stack+0xa0/0xc8
[    3.315581] [<ffffff800808c298>] handle_IPI+0x1c8/0x258
[    3.318054] [<ffffff8008080f28>] gic_handle_irq+0x17c/0x180
[    3.320586] Exception stack(0xffffffc078affe10 to 0xffffffc078afff40)
[    3.323257] fe00:                                   ffffff80093f4000 00000040
76b62000
[    3.326129] fe20: 0000000000000000 ffffff8009441600 0100000000000000 00000000
0eca8507
[    3.329057] fe40: 0000000000000644 000000000000000c ffffffc078ae5090 ffffffc0
78affee0
[    3.332033] fe60: 0000000000000a30 0000000000000644 000000000000028c 00000004
00000000
[    3.335047] fe80: 0000000000000004 00000000efe4b99a 0000000000000000 00000000
4917d1a8
[    3.338086] fea0: 0000000000000000 0000000000000000 ffffff80093f4000 ffffff80
09599c78
[    3.341159] fec0: ffffff80093f4000 ffffffc078ae4600 ffffff8008c7d000 ffffff80
09425738
[    3.344269] fee0: 0000000003795000 0000000002c5c244 0000000000000000 ffffffc0
78afff40
[    3.347360] ff00: ffffff80080849d8 ffffffc078afff40 ffffff80080849dc 00000000
60000045
[    3.350459] ff20: ffffff80093f4000 ffffff80093f4000 ffffffffffffffff ffffff80
08c7d000
[    3.353546] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[    3.356353] [<ffffff80080849dc>] arch_cpu_idle+0x90/0x100
[    3.359192] [<ffffff80080fc650>] default_idle_call+0x2c/0x30
[    3.362048] [<ffffff80080fc8e4>] cpu_startup_entry+0x21c/0x2b4
[    3.364926] [<ffffff800808bd20>] secondary_start_kernel+0x124/0x140
[    3.367829] [<0000000002c5c188>] 0x2c5c188
[    3.370546] CPU0: stopping
[    3.376055] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.4.213-r
ockchip64 #6
[    3.382145] Hardware name: ROCK PI 4B (DT)
[    3.387805] Call trace:
[    3.393235] [<ffffff8008088040>] dump_backtrace+0x0/0x1bc
[    3.399036] [<ffffff8008088220>] show_stack+0x24/0x30
[    3.404777] [<ffffff80085ad6b4>] dump_stack+0xa0/0xc8
[    3.410478] [<ffffff800808c298>] handle_IPI+0x1c8/0x258
[    3.416187] [<ffffff8008080f28>] gic_handle_irq+0x17c/0x180
[    3.421941] Exception stack(0xffffff8009423de0 to 0xffffff8009423f10)
[    3.427861] 3de0: ffffff80093f4000 0000004076afe000 0000000000000000 ffffff80
09441600
[    3.434029] 3e00: 0100000000000000 0000000000000000 0000000000000642 00000000
00000001
[    3.440198] 3e20: ffffff800942e9a0 ffffff8009423eb0 0000000000000a30 00000000
00000191
[    3.446357] 3e40: 0000000000000191 0000000000000001 0000000000000001 00000000
e5b906e6
[    3.452518] 3e60: 0000000000001000 000000000000000d 0000000000000010 00000000
00000000
[    3.458638] 3e80: ffffff80093f4000 ffffff8009599c78 ffffff80093f4000 ffffff80
0942df10
[    3.464818] 3ea0: ffffff8008c7d000 ffffff8009425738 0000000003795000 00000000
02c5c23c
[    3.471026] 3ec0: 000000000330001c ffffff8009423f10 ffffff80080849d8 ffffff80
09423f10
[    3.477241] 3ee0: ffffff80080849dc 0000000060000045 ffffff80093f4000 ffffff80
093f4000
[    3.483433] 3f00: ffffffffffffffff ffffff8008c7d000
[    3.489276] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[    3.495064] [<ffffff80080849dc>] arch_cpu_idle+0x90/0x100
[    3.500951] [<ffffff80080fc650>] default_idle_call+0x2c/0x30
[    3.506806] [<ffffff80080fc8e4>] cpu_startup_entry+0x21c/0x2b4
[    3.512609] [<ffffff8008c520f0>] rest_init+0x74/0x7c
[    3.518331] [<ffffff8009300b74>] start_kernel+0x3c8/0x3ec
[    3.524075] [<ffffff80093001c4>] __primary_switched+0x30/0x6c
[    3.529858] CPU1: stopping
[    3.535378] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D         4.4.213-r
ockchip64 #6
[    3.541582] Hardware name: ROCK PI 4B (DT)
[    3.547398] Call trace:
[    3.552957] [<ffffff8008088040>] dump_backtrace+0x0/0x1bc
[    3.558810] [<ffffff8008088220>] show_stack+0x24/0x30
[    3.564558] [<ffffff80085ad6b4>] dump_stack+0xa0/0xc8
[    3.570227] [<ffffff800808c298>] handle_IPI+0x1c8/0x258
[    3.575891] [<ffffff8008080f28>] gic_handle_irq+0x17c/0x180
[    3.581597] Exception stack(0xffffffc078aefe10 to 0xffffffc078aeff40)
[    3.587453] fe00:                                   ffffff80093f4000 00000040
76b12000
[    3.593530] fe20: 0000000000000000 ffffff8009441600 0100000000000000 00000000
0ec90e07
[    3.599617] fe40: 0000000000000642 ffffffc078aefee0 0000000000000040 ffffffc0
7ff0b3c8
[    3.605642] fe60: 0000000000000a30 0000000000000191 000000000000010b 00000000
00000000
[    3.611662] fe80: 0000000000000001 0000000000000000 0000000000000000 00000000
00000000
[    3.617545] fea0: 0000000000000001 0000000000000000 ffffff80093f4000 ffffff80
09599c78
[    3.623429] fec0: ffffff80093f4000 ffffffc078ae0e00 ffffff8008c7d000 ffffff80
09425738
[    3.629333] fee0: 0000000003795000 0000000002c5c244 0000000000000000 ffffffc0
78aeff40
[    3.635280] ff00: ffffff80080849d8 ffffffc078aeff40 ffffff80080849dc 00000000
60000045
[    3.641286] ff20: ffffff80093f4000 ffffff80093f4000 ffffffffffffffff ffffff80
08c7d000
[    3.647277] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[    3.653019] [<ffffff80080849dc>] arch_cpu_idle+0x90/0x100
[    3.658760] [<ffffff80080fc650>] default_idle_call+0x2c/0x30
[    3.664463] [<ffffff80080fc8e4>] cpu_startup_entry+0x21c/0x2b4
[    3.670193] [<ffffff800808bd20>] secondary_start_kernel+0x124/0x140
[    3.675953] [<0000000002c5c188>] 0x2c5c188
[    3.681518] CPU2: stopping
[    3.686967] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.213-r
ockchip64 #6
[    3.693099] Hardware name: ROCK PI 4B (DT)
[    3.698840] Call trace:
[    3.704326] [<ffffff8008088040>] dump_backtrace+0x0/0x1bc
[    3.710101] [<ffffff8008088220>] show_stack+0x24/0x30
[    3.715805] [<ffffff80085ad6b4>] dump_stack+0xa0/0xc8
[    3.721463] [<ffffff800808c298>] handle_IPI+0x1c8/0x258
[    3.727101] [<ffffff8008080f28>] gic_handle_irq+0x17c/0x180
[    3.732804] Exception stack(0xffffffc078af3e10 to 0xffffffc078af3f40)
[    3.738615] 3e00:                                   ffffff80093f4000 00000040
76b26000
[    3.744645] 3e20: 0000000000000000 ffffff8009441600 0100000000000000 00000000
0ec90e07
[    3.750681] 3e40: 0000000000000642 0000000000000000 ffffffc078ae2690 ffffffc0
78af3ee0
[    3.756732] 3e60: 0000000000000a30 0000000000000191 000000000000010b 00000001
00000000
[    3.762730] 3e80: 0000000000000001 0000000000000000 0000000000000000 00000000
00000000
[    3.768670] 3ea0: 0000000000000001 0000000000000000 ffffff80093f4000 ffffff80
09599c78
[    3.774608] 3ec0: ffffff80093f4000 ffffffc078ae1c00 ffffff8008c7d000 ffffff80
09425738
[    3.780559] 3ee0: 0000000003795000 0000000002c5c244 0000000000000000 ffffffc0
78af3f40
[    3.786564] 3f00: ffffff80080849d8 ffffffc078af3f40 ffffff80080849dc 00000000
60000045
[    3.792625] 3f20: ffffff80093f4000 ffffff80093f4000 ffffffffffffffff ffffff80
08c7d000
[    3.798710] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[    3.804553] [<ffffff80080849dc>] arch_cpu_idle+0x90/0x100
[    3.810416] [<ffffff80080fc650>] default_idle_call+0x2c/0x30
[    3.816250] [<ffffff80080fc8e4>] cpu_startup_entry+0x21c/0x2b4
[    3.822027] [<ffffff800808bd20>] secondary_start_kernel+0x124/0x140
[    3.827877] [<0000000002c5c188>] 0x2c5c188
[    3.833486] CPU3: stopping
[    3.838955] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D         4.4.213-r
ockchip64 #6
[    3.845128] Hardware name: ROCK PI 4B (DT)
[    3.850916] Call trace:
[    3.856518] [<ffffff8008088040>] dump_backtrace+0x0/0x1bc
[    3.862422] [<ffffff8008088220>] show_stack+0x24/0x30
[    3.868206] [<ffffff80085ad6b4>] dump_stack+0xa0/0xc8
[    3.873898] [<ffffff800808c298>] handle_IPI+0x1c8/0x258
[    3.879598] [<ffffff8008080f28>] gic_handle_irq+0x17c/0x180
[    3.885305] Exception stack(0xffffffc078af7e10 to 0xffffffc078af7f40)
[    3.891220] 7e00:                                   ffffff80093f4000 00000040
76b3a000
[    3.897381] 7e20: 0000000000000000 ffffff8009441600 0100000000000000 00000000
0ec90e07
[    3.903576] 7e40: 0000000000000642 0000000000000002 ffffffc078ae3490 ffffffc0
78af7ee0
[    3.909772] 7e60: 0000000000000a30 0000000000000191 000000000000010b 00000000
00000001
[    3.915913] 7e80: 0000000000000001 0000000000000000 0000000000000000 00000000
00000000
[    3.921987] 7ea0: 0000000000000030 0000000000000000 ffffff80093f4000 ffffff80
09599c78
[    3.927975] 7ec0: ffffff80093f4000 ffffffc078ae2a00 ffffff8008c7d000 ffffff80
09425738
[    3.933986] 7ee0: 0000000003795000 0000000002c5c244 0000000000000000 ffffffc0
78af7f40
[    3.940038] 7f00: ffffff80080849d8 ffffffc078af7f40 ffffff80080849dc 00000000
60000045
[    3.946169] 7f20: ffffff80093f4000 ffffff80093f4000 ffffffffffffffff ffffff80
08c7d000
[    3.952311] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[    3.958169] [<ffffff80080849dc>] arch_cpu_idle+0x90/0x100
[    3.964081] [<ffffff80080fc650>] default_idle_call+0x2c/0x30
[    3.969968] [<ffffff80080fc8e4>] cpu_startup_entry+0x21c/0x2b4
[    3.975795] [<ffffff800808bd20>] secondary_start_kernel+0x124/0x140
[    3.981694] [<0000000002c5c188>] 0x2c5c188
[    3.987356] CRU:
[    3.989881] 00000000: 00000044 00001201 80000000 00000108 00000007 00007f00 0
0000000 00000000
[    3.993124] 00000020: 00000044 00001201 80000000 00000108 00000007 00007f00 0
0000000 00000000
[    3.996340] 00000040: 00000064 00001301 8000031f 00000108 00000007 00007f00 0
0000000 00000000
[    3.999534] 00000060: 00000040 00002201 8000031f 00000108 00000007 00007f00 0
0000000 00000000
[    4.002678] 00000080: 00000064 00001301 80000000 00000108 00000007 00007f00 0
0000000 00000000
[    4.005771] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 0
0000000 00000000
[    4.008811] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 0
0000000 00000000
[    4.011811] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.014789] 00000100: 00000100 00000404 00000140 00006404 00000083 00008581 0
0008320 00000141
[    4.017783] 00000120: 00000181 00008181 00000141 00000141 00004141 00008362 0
0003185 00000500
[    4.020779] 00000140: 0000010f 00000300 00004a87 0000033f 00009381 00008387 0
0001103 00005282
[    4.023766] 00000160: 00008247 00000187 00001743 000002dc 00000300 00000300 0
0000300 00000000
[    4.026735] 00000180: 00006300 00009200 00000200 00000200 00000200 00000200 0
0003f3f 00000081
[    4.029669] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 0
0000004 00000381
[    4.032584] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 0
0000141 00008181
[    4.035460] 000001e0: 00008323 00000007 00008f1f 00008f8f 00008f8f 00008787 0
0008787 00008787
[    4.038338] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.041221] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.044083] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.046907] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.049684] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0
bb8ea60 0bb8ea60
[    4.052486] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 0
0000000 00000000
[    4.055257] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.057993] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.060699] 00000300: 00000000 00000000 00000202 00000000 00000030 00000000 0
0000004 00000000
[    4.063373] 00000320: 00000000 00000000 00000000 00000000 00000000 000000f0 0
0000000 00000000
[    4.066031] 00000340: 00000000 00000000 00000000 00000000 00000c04 00000000 0
0000001 00000000
[    4.068681] 00000360: 00000000 00000020 00000000 00000000 00000000 00000000 0
0000000 00000038
[    4.071312] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.073922] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.076475] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.078964] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.081397] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.083782] 00000420: 00000000 00007070 00000000 00000014 00000000 00000000 0
0000000 00000000
[    4.086133] 00000440: 00000000 00000000 00000000 00000000 00003000 00000000 0
0000000 00000000
[    4.088478] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.090795] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.093074] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.095303] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.097466] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.099588] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 0
0000000 00000000
[    4.101648] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.103689] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.105698] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.107676] 00000580: 00000004 00000000 00000004 00000000 00000004
[    4.109411] PMU CRU:
[    4.110765] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 0
0000000 00000000
[    4.112791] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.114754] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.116716] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.118672] 00000080: 0000060d 00001986 00000302 00000003 000002dc 00000600 0
bb8ea60 00040050
[    4.120649] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.122641] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.124629] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.126608] 00000100: 00000100 00004018 00000000 00000000 00000024 00000000 0
0000000 00000000
[    4.128577] 00000120: 00000000 00000000 00000000 00000000 00000003
[    4.130318] PMU:
[    4.131661] 00000000: 00000000 00000000 00000000 00000000 00000000 00000300 0
0000300 00000000
[    4.133708] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.135725] 00000040: 00000000 00000000 00000000 00000000 00000000 0000033e 0
0000000 00000000
[    4.137718] 00000060: 00000000 00000000 00000000 00000010 00000000 00007e00 0
0000000 28800000
[    4.139696] 00000080: 000003c0 00011940 00005dc0 000003c0 00005dc0 00000060 0
000000f 00000018
[    4.141672] 000000a0: 00000018 00000018 00000018 00000006 00000006 00005dc0 0
0005dc0 00005dc0
[    4.143652] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 3
fffffff 00000000
[    4.145621] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 0
0000000 00000000
[    4.147585] Kernel Offset: disabled
[    4.149126] Memory Limit: none
[    4.150650] ---[ end Kernel panic - not syncing: Attempted to kill init! exit
code=0x0000000b
[    4.150650]
2 minutes ago, JMCC said:
Okay, kernel panic also happens with 20.08.14. But board boots perfectly with 20.08.1
What revision of the board you have?
Is it 1.4 with SPI or 1.3 without it?
12 minutes ago, piter75 said:
I will build and share an image
If you don't mind, Buster would be best for the image, so I can test also the multimedia stuff on it.
26 minutes ago, piter75 said:
to assess if the panic on boot is gone)
Perfect, thank you very much. (EDIT: I mean, I tested it and works)
Let me know when you push the fix, so I can tinker with the kernel. I discovered that VPU was failing, and it will probably need some patch.
I took a shortcut and enabled SPI by default for ROCK Pi 4.
I verified it with SPI CLK shorted on v1.4 but obviously it was not enough :(
The fix is in master.
Pinebook A64 - no screen
Do we have solution, patch or workaround for any of? Probably pushing out new build by the next weekend? Reordered by priority.
10 часов назад, Igor сказал:
In the message log from u-boot-2015. I am testing C2 with the latest nightly builds (u-boot-2020.04) and have not found the specified failures yet.
If your sample has been used extensively, is it possible that the card reader or SD card may have worn out ?
Thank you for testing. I can easily reproduce by upgrading stable build to nightly. Probably the same if you just reinstall kernels and u-boot.
I will re-do testing again to make sure.
3 минуты назад, Igor сказал:
Write down what order of steps you need to check, and I'll try to reproduce it myself. By the way, with intensive use of the system, SD cards get very hot and when they cool down (if the card reader is worn out), failures may occur (contacts are broken not predictably).
Its easy. Download latest stable image for C2. Change apt.armbian.com to beta.armbian.com /etc/apt/sources.list.d/armbian.list ... apt update , apt upgrade, reboot ... this fails for me.
when updating, the uInitrd is not generated (it is completely absent). There may be an error in the kernel package.
The SD card is fine, I used Desktop and updating a large number of packages did not cause problems. Which kernel package is currently used for the upgrade ?
