balbes150 Posted January 30, 2022 Posted January 30, 2022 1 час назад, Igor сказал: Since you have brought up Pine64. A question about Quartz64. Can I create a PR for CSC or do we not support it in any form ? 1 Quote
lanefu Posted January 30, 2022 Posted January 30, 2022 28 minutes ago, balbes150 said: A question about Quartz64. Can I create a PR for CSC or do we not support it in any form ? CSC is fine 0 Quote
balbes150 Posted January 30, 2022 Author Posted January 30, 2022 6 минут назад, lanefu сказал: Pinenote def more work. If I'm not confused, it's not a phone, it's a tablet 10 минут назад, lanefu сказал: CSC is fine If the other developers have no objections, I will create a PR Especially for this device, I have already put together a test version with the main kernel and the main u-boot. 0 Quote
Igor Posted January 30, 2022 Posted January 30, 2022 25 minutes ago, balbes150 said: A question about Quartz64. Can I create a PR for CSC or do we not support it in any form ? CSC is something we officially not associate with, but since you are asking - reasons for pro and con should be formed in the table. That will help to decide what to do without much additional thinking. Once we get some overview on the situation for particular hardware it's much easier and safer - to decide. 0 Quote
balbes150 Posted January 30, 2022 Author Posted January 30, 2022 2 часа назад, Igor сказал: We have to be united no matter how much time someone spent and what role one plays in this project. To have some basic conditions ... Everything necessary for CSC is already there and I can send PR to the general build system (I have all the necessary changes in the build system to get working images with the main kernel and the main u-boot for quartz64). I have not published these changes anywhere in the build system, only one ready-made test image to check how it works. My question was related to having a common position on supporting this model. 0 Quote
TRS-80 Posted January 31, 2022 Posted January 31, 2022 Above posts were split from here, hopefully that explains any disjointed conversation. 0 Quote
balbes150 Posted March 13, 2022 Author Posted March 13, 2022 I recently received a sample of Quartz64. I have added CSC level support for Quartz64a to the ArmbianTV build system, after checking and testing, I plan to send a PR with these changes to the official Armbian build system. The first test images for Quartz64 can be found at the link. https://disk.yandex.ru/d/xMVoaZXFFcWuog 1 Quote
thc013 Posted March 14, 2022 Posted March 14, 2022 yeah that is just mainline kernel would be weird if it need testing after so long time where is the dowmstream kernel ? 0 Quote
balbes150 Posted March 14, 2022 Author Posted March 14, 2022 1 час назад, thc013 сказал: yeah that is just mainline kernel would be weird if it need testing after so long time where is the dowmstream kernel ? you contradict yourself if the main kernel (as you claim) is working and tested, therefore there is no need for an old BSP kernel for Quartz64. 0 Quote
thc013 Posted March 16, 2022 Posted March 16, 2022 It works even the graphics damn how i as noob gonna without asking compare dts ,defconfig against a proper downstream one from a sensei for a quartz64 , mainstream is no issue lot of sensei for that . 0 Quote
balbes150 Posted March 17, 2022 Author Posted March 17, 2022 Updating images 20220317 (edge 5.17 and current 5.16). The operation of the standard procedure for installing the system on eMMC via armbian-config has been verified (i.e. you can install the system on eMMC directly on the Quartz64 itself, no additional adapter is needed to write the eMMC module via USB). Added support for starting the system from USB media. This greatly simplifies and expands the possibilities of running different systems (for example, during testing). Now you can use not only SD cards, but also any USB media to start (and/or work). For example, I installed and configured the Armbian working system on eMMC (with support for launching from USB) and now I easily launch other Armbian test images from ordinary USB flash drives, which is much easier to handle (no card readers are needed to write SD cards, the cost of USB flash drives is much lower and the choice of which models to use \ buy is much wider). 3 Quote
balbes150 Posted April 1, 2022 Author Posted April 1, 2022 New versions 20220331 with core 5.16.18 and 5.17.1 0 Quote
balbes150 Posted April 4, 2022 Author Posted April 4, 2022 https://forum.pine64.org/showthread.php?tid=16312&pid=108778#pid108778 0 Quote
balbes150 Posted April 8, 2022 Author Posted April 8, 2022 New version 20220408-edge with kernel 5.18-rc1 1 Quote
balbes150 Posted April 20, 2022 Author Posted April 20, 2022 Version 20220419-edge with a 5.18-rc3 kernel and new version of u-boot-2022.04. 1 Quote
balbes150 Posted April 21, 2022 Author Posted April 21, 2022 Version 20220419-current with 5.17.3 kernel and new version of u-boot-2022.04. 1 Quote
balbes150 Posted April 30, 2022 Author Posted April 30, 2022 version 20220428 with kernel 5.18-rc4 (edge) and 5.17.5 (current) 1 Quote
mxr662 Posted May 23, 2022 Posted May 23, 2022 Installed 20220511 edge and current on a couple quartz64 model A 8GB. Running headless. 0 Quote
balbes150 Posted July 14, 2022 Author Posted July 14, 2022 Alpha version 20220714 of Armbian images with EFI\GRUB support. Tested on Quartz64 A. If there are users of other models here, it is interesting to check the work of UEFI\GRUB on other Quartz64 models. https://forum.pine64.org/showthread.php?tid=16312&pid=111453#pid111453 0 Quote
balbes150 Posted September 13, 2022 Author Posted September 13, 2022 Armbian test version 20220913 kernel 6.0-rc5 and u-boot-2022.10-rc4. It is important that u-boot has changed. various bugs are possible in the new version. https://disk.yandex.ru/d/t-DZd-DWOWMEiA 0 Quote
balbes150 Posted November 29, 2022 Author Posted November 29, 2022 Good news. A test version of the Armbian+EDK2 system (UEFI\grub) is available. To use this option. Download the EDK2 image. https://disk.yandex.ru/d/kK6KIqHShRHLyw Unpack and burn to SD card. Download the Armbian image (kernel 6.1.0-rc7), https://disk.yandex.ru/d/n_LneErcHLCQGg unpack and burn it to a USB drive (8-16GB flash drives are recommended, I haven't checked other options). Connect the SD card (eMMC should be disabled), connect the USB flash drive to the lower USB 2.0 port (other ports may work, I have not tested). Turn on the power. If the system does not start immediately, go to settings and select the device to start. On the EDK2 boot screen saver, select "Maintaining Manager boot" in the menu item and configure the device used for startup in it (change "none" to "UEFI ...."). Select Reset. If you did everything correctly, after restarting EDK2, you will receive a GRUB menu with a choice of system\kernel. If you do not select anything, the default system will be started in 5 seconds, and in 10-20 seconds (depending on the type of USB flash drive) there will be a standard Armbian customizer for the first launch. If desired, you can place the entire system on an SD card, but additional steps will be required at startup. Please note, according to the documentation, the UART console in this version of EDK2 runs at a speed of 155200n8 At startup, the kernel switches the UART console to the correct value for RK (1500000) and you can monitor the kernel startup process and control the system through the UART console. That is, the parameters 115200 can only be useful for viewing the primary output from EDK2 itself, but this is only necessary for developers, for ordinary users, kernel output and system management are more useful, so I recommend using the standard value for Rockchip of 150000. https://github.com/150balbes/edk2_uefi 0 Quote
balbes150 Posted November 30, 2022 Author Posted November 30, 2022 The system startup control is performed as on a regular PC - through the menu on the monitor screen, therefore, to fully use all the features of selective startup, you need to have a connected monitor and keyboard 0 Quote
balbes150 Posted December 1, 2022 Author Posted December 1, 2022 See all the news on the development of EDK2 support in this topic. There are new options for bootloader images. 0 Quote
acj_ Posted December 13, 2022 Posted December 13, 2022 I am attempting to run Armbian on a Pine64 Quartz64. I understand it is not officially supported so I'm hoping a kind community member might be able to help me. Here's where I am at... I found: https://forum.pine64.org/showthread.php?tid=16312 which links to https://users.armbian.com/balbes150/quartz64/ from there, there are a number of relatively recent disk images Quartz64 model A boards. I am able to get just about any of them functioning; e.g. burned to emmc or sd, and the board is able to boot. The two issues that I have noticed are: The board is an 8GB mem board, but for some of the images, it appears to the system to only have 2GB General performance for any of the images is abysmal From balbes150's images: using, Armbian_22.11.0-trunk_Quartz64a_sid_current_5.19.17.img.xz, GeekBench produces... https://browser.geekbench.com/v5/cpu/19280197 Even forcing the board to run at max Mhz (1800), the performance is still the same. Thanks in advance for the help... 0 Quote
balbes150 Posted January 22, 2023 Author Posted January 22, 2023 Alpha version 20230122-EDK-EFI Armbian for SOQuartz + SOQuartz Model-A Baseboard. Kernel 6.2-rc4. https://disk.yandex.ru/d/Oq5yvBkuIK4R3A 0 Quote
balbes150 Posted January 24, 2023 Author Posted January 24, 2023 Alpha version 20230124-edge Armbian for Quartz64-B Kernel 6.2-rc5. https://disk.yandex.ru/d/u0ioJbqtXqvJ6w 0 Quote
balbes150 Posted January 28, 2023 Author Posted January 28, 2023 Ver 20230128-EDK2-EFI for Quartz64-B Added EDK2-EFI support for Quartz64-B, 0 Quote
jeanrhum Posted January 29, 2023 Posted January 29, 2023 Hi, I confirm that EDK2-EFI works well on quartz64-a. I burnt the latest image on sd card, then I used armbian-config to install it on emmc. After reboot I saw efi screen and grub menu and it starts well directly from emmc. Well done!👏 I'll make additional testing now, but don't hesitate to ask if you need more feedbacks. 0 Quote
balbes150 Posted January 30, 2023 Author Posted January 30, 2023 10 часов назад, jeanrhum сказал: I'll make additional testing now, but don't hesitate to ask if you need more feedbacks. Do you have an NVMe module ? It is advisable to check the system startup from all USB ports of the system with EDK2 (if Ubuntu is installed on eMMC, write it to a Debian USB flash drive or vice versa, so that it would be easier to determine which system is starting). After starting the system from USB, update the grub menu in the startup menu, the system on eMMC should appear and then check the selection and launch of systems with eMMC. 0 Quote
