Samples arrived ♥️ HW looks fascinating, Armbian is yet to be ported so can't comment how good this is in realworld. Its shipped with stock Khadas Ubuntu, kernel 5.4.y, which is good to boot something ...
Technical specs at CNX.
Judging by the photo, they did not change the placement of the elements (it remained as it was on vim3), so there will be a hardware problem of not being able to work properly USB 3.0 and WiFi at the same time.
ps Using the aml bsp kernel is  very bad idea, their kernel, for security, is full shit.
48 минут назад, Igor сказал:
Only option for some time
add here closed blobs for u-boot (in which there are hidden modules of full control for aml), which are strictly controlled and the sources are not provided to anyone,  disgusting mixture turns out. I would not risk connecting such  device to any network where there is Internet access. :)
I'm not familiar with that.  What causes and issue with the wifi and USB 3?
1 час назад, lanefu сказал:
Presumably this is a crosstalk problem, USB 3.0 uses a high frequency that interferes with WiFi (the chips are too close to each other). Details are available on the khadas official forum.
I was testing Armbian support for the Rock 5B board a few weeks ago, and although it is still early it looks very promising.
So i thought i should test how it works for my Vim4 board too.. To my surprise it does not seem to supported by armbian.
Could you help explain a bit What causes this? Is it some lack of support from Amlogic and / or Khadas or What is missing for the Khadas Vim4 boards to be supported by Armbian? (Maybe link to somewhere where a discussion on the subject is ongoing?)
Hello! Can you share the instructions and sources code, how to assemble a U-boot for an Amlogic A311D2? Ready u-boot from Khadas does not work on this board.
U-Boot 2019.01-gae8012faf05-dirty (May 19 2024 - 19:21:34 +0000)
DRAM: 8 GiB
Relocation Offset is: dfd51000
Relocating to dfd51000, new gd at d9d405c0, sp at d9d405b0
board init
watchdog disable
gpio: pin GPIOT_15 (gpio 106) value is 1
It includes a pin that cannot be turned on, the board hangs on this moment.
