I have a 2 port USB hub. It works on my laptop with Ubuntu 20.04 and on my laptop with Ubuntu 22.04, but not on my Lichee RV Dock D1 with Ubuntu 22.04: a USB keyboard connected via the USB hub is not working.
On my D1, syslog says:
Jun 25 14:56:40 nezha kernel: [ 3036.734170] usb 4-1: New USB device found, idVendor=058f, idProduct=9254, bcdDevice= 3.12
Jun 25 14:56:40 nezha kernel: [ 3036.734190] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 25 14:56:40 nezha kernel: [ 3036.734201] usb 4-1: Product: Generic USB Hub
Jun 25 14:56:40 nezha kernel: [ 3036.734209] usb 4-1: Manufacturer: ALCOR
Jun 25 14:56:40 nezha kernel: [ 3036.741616] hub 4-1:1.0: USB hub found
Jun 25 14:56:40 nezha kernel: [ 3036.745592] hub 4-1:1.0: config failed, hub doesn't have any ports! (err -19)
When I google "config failed, hub doesn't have any ports! (err -19)" there are a few hits, but very low level tech talk, often related to Raspberry Pi CM4, which didn't help me.
On my Ubuntu 20.04 laptop, syslog says
Jun 25 15:11:30 witte2004 kernel: [87916.031446] usb 1-1: new full-speed USB device number 14 using xhci_hcd
Jun 25 15:11:30 witte2004 kernel: [87916.180513] usb 1-1: New USB device found, idVendor=058f, idProduct=9254, bcdDevice= 3.12
Jun 25 15:11:30 witte2004 kernel: [87916.180521] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 25 15:11:30 witte2004 kernel: [87916.180526] usb 1-1: Product: Generic USB Hub
Jun 25 15:11:30 witte2004 kernel: [87916.180531] usb 1-1: Manufacturer: ALCOR
Jun 25 15:11:30 witte2004 kernel: [87916.181829] hub 1-1:1.0: USB hub found
Jun 25 15:11:30 witte2004 kernel: [87916.181921] hub 1-1:1.0: 4 ports detected
Tips how to solve this and make the USB hub working on my D1?
Edited by Superkoning
11 минут назад, Superkoning сказал:
After booting the system, if the USB does not work, disconnect the device (hub) and reconnect. Sometimes you have to do this several times in order for the USB to be determined and work. When connected via the hub, some of the devices may not work, they need to be disconnected and reconnected. If the UART console is connected, disconnect it, this may also be the reason that USB devices do not start. Check the power supply, there may not be enough power for USB.
Oh, wow ... just replugging worked. Keyboard and ethernet USB adapter are working. Thanks.
FWIW: the USB hub is unpowered. So impressive the Dock can power the hub plus keyboard plus ethernet adapter.
Jun 25 15:40:18 nezha kernel: [ 5654.678714] usb 4-1: new full-speed USB device number 16 using ohci-platform
Jun 25 15:40:18 nezha kernel: [ 5654.907759] usb 4-1: New USB device found, idVendor=058f, idProduct=9254, bcdDevice= 3.12
Jun 25 15:40:18 nezha kernel: [ 5654.907780] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 25 15:40:18 nezha kernel: [ 5654.907791] usb 4-1: Product: Generic USB Hub
Jun 25 15:40:18 nezha kernel: [ 5654.907800] usb 4-1: Manufacturer: ALCOR
Jun 25 15:40:18 nezha kernel: [ 5654.916213] hub 4-1:1.0: USB hub found
Jun 25 15:40:18 nezha kernel: [ 5654.917858] hub 4-1:1.0: 4 ports detected
with output of usb-devices
T:  Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 16 Spd=12  MxCh= 4
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=058f ProdID=9254 Rev=03.12
S:  Manufacturer=ALCOR
S:  Product=Generic USB Hub
C:  #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
I:  If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   1 Ivl=255ms
FYI / FWIW:
my syslog was full with hostapd logging like below. Annoying.
I "solved" that by using armbian-config -> set up the AP ... which failed, but the logging disappeared from my syslog.
Jun 25 15:29:34 nezha systemd[1]: hostapd.service: Scheduled restart job, restart counter is at 2195.
Jun 25 15:29:34 nezha systemd[1]: Stopped Access point and authentication server for Wi-Fi and Ethernet.
Jun 25 15:29:34 nezha systemd[1]: Starting Access point and authentication server for Wi-Fi and Ethernet...
Jun 25 15:29:34 nezha hostapd[4725]: Could not open configuration file '/etc/hostapd/hostapd.conf' for reading.
Jun 25 15:29:34 nezha hostapd[4725]: Failed to set up interface with /etc/hostapd/hostapd.conf
Jun 25 15:29:34 nezha hostapd[4725]: Failed to initialize interface
Jun 25 15:29:34 nezha systemd[1]: hostapd.service: Control process exited, code=exited, status=1/FAILURE
Jun 25 15:29:34 nezha systemd[1]: hostapd.service: Failed with result 'exit-code'.
Jun 25 15:29:34 nezha systemd[1]: Failed to start Access point and authentication server for Wi-Fi and Ethernet.
Version 20220710 for SfarFive.
Important change, Ubuntu\Armbian switched to using UEFI. Debian\Armbian will be switched to using UEFI in the near future, while several packages necessary for UEFI are missing in Debian network repositories for riscv64, with the release of these packages in Debian network repositories or I will temporarily use DEB EFI packages from Ubuntu, Debian images will also be completely switched to the UEFI startup system (grub). It is welcome if there are participants who are ready to help with porting the necessary DEB EFI packages for Debian. By the way, Rick is actively working on adding new DE for RISC-V in Armbian, several new DE will be ready soon, if you are interested in specific DE, write to this topic, it will help determine which direction to do first.
Package `gcc-riscv64-linux-gnu` should be added as a dependency for usage in Docker, else it errors out with it missing.
Based on how the depends are configured, it seems as if the intention was that this package would be provided by the distro or built by the user? Is Docker intended to build this toolchain itself?
1 час назад, Nexus сказал:
This is the initial development version and I have not tested its use with Docker. There may be errors\missing necessary settings\dependencies. If you have the information and you have checked what is missing to run the build in Docker, you can send a PR or write your steps, what and where you added.
I can NOT confirm: I can just run
apt install docker.io -y
and then
docker run -it ubuntu:22.04 /bin/bash
and it all works
root@nezha:~# docker run -it ubuntu:22.04 /bin/bash
Unable to find image 'ubuntu:22.04' locally
22.04: Pulling from library/ubuntu
1edfbf9ed16b: Pull complete
Digest: sha256:b6b83d3c331794420340093eb706a6f152d9c1fa51b262d9bf34594887c2c7ac
Status: Downloaded newer image for ubuntu:22.04
root@130be7978c79:/# uname -a
Linux 130be7978c79 5.19.0-rc1-d1 #trunk Thu Jun 23 10:42:46 MSK 2022 riscv64 riscv64 riscv64 GNU/Linux
So ... how/when did you get an error?
Kudos for all the work Balbes. I just received my MangoPI MQ Pro and I'm having some issues booting. Could you please give me hint on:
- how to plug in the uart gpio pins?
- what's the baud rate?
- should i send uart jumper to 3.3 or 5V?
- is it possible to power the board without usb-c but only with uart?
- is micro hdmi required for first boot? (I don't have one)
Thanks in advance.
Baud rate will be 115200.  If that does not work then try 38400 and 9600.
Set the jumper to 3.3v.  If you try to use 5v you may end up destroying the board.
You should be able to use a HDMI monitor and USB keyboard. For my (Lemaker Banana Pro) board that didn't work so I had to use an USB to RS232 converter to start and complete the initial set-up.
Power the board using USB-C and do not use the 5V pin on the USB to RS232 converter?
Not sure about which gpio pins to use.  I advise you look-up the required documentation that should be available on Mango's web-site.
https://mangopi.cc/mangopi_mqpro says "mini HDMI connector", so not micro.
I would get one (including USB-C power); much easier than going the UART way. That's the great thing about balbes150's image: HDMI and keyboard and mouse just work.
I had to create a new image, and afterwards discovered I had the debian not ubuntu version.
So for people like me, I've created an overview:
$ lynx --dump 'https://disk.yandex.ru/d/da8qJ8wyE1hhcQ/Nezha_D1/ArmbianTV/20220722' | grep xz
   Armbian_22.08.0-trunk_Nezha_jammy_current_5.19.0.img.xz
   Armbian_22.08.0-trunk_Nezha_jammy_current_5.19.0_icewm_desktop.img.xz
   Armbian_22.08.0-trunk_Nezha_jammy_current_5.19.0_xfce_desktop.img.xz
   Armbian_22.08.0-trunk_Nezha_sid_current_5.19.0.img.xz
   Armbian_22.08.0-trunk_Nezha_sid_current_5.19.0_icewm_desktop.img.xz
   Armbian_22.08.0-trunk_Nezha_sid_current_5.19.0_xfce_desktop.img.xz
So:
  • jammy (Ubuntu) versus sid (Debian)
  • ... each with text-only versus icewm versus xfce
@balbes150 Why is the directory called ArmbianTV? Does TV stand for Television, or something else?
18 часов назад, riscvboy сказал:
This model does not have a built-in LAN port (which can be automatically configured at the first start via DHCP, so that you can connect via SSH from a PC and perform the initial configuration of the system and WiFi). Therefore, for the first launch and setup, you need either an HDMI and USB keyboard, or a USB-LAN.
1 час назад, Superkoning сказал:
It doesn't make any difference, it's just a historically established name for my development branch.
From https://www.cnx-software.com/2022/08/01/linux-5-19-release-main-changes-arm-risc-v-and-mips-architectures/ "Linux 5.19 Release – Main changes, Arm, RISC-V and MIPS architectures"
I guess we can expect the 5.19 release on our board?
RISC-V updates
Allwinner D1
DMA and LRADC drivers
Implementation of page-based memory attributes
Device tree – Enables display engine 2.0 with two mixers, a TCON TOP (with DSI and HDMI), one TCON LCD, and one TCON TV.
Support for the Svpbmt extension, which allows memory attributes to be encoded in pages
Support for running rv32 binaries on rv64 systems, via the compat subsystem
Support for kexec_file()
Support for the new generic ticket-based spinlocks, which allows us to also move to qrwlock. These should have already gone in through the asm-geneic tree as well
A handful of cleanups and fixes, including some larger ones around atomics and XIP
Upstream Linux release document is just a formality.
All features are already present.
Non RC builds will be out when people return from well deserved holidays.
I'm new to the thread, I got a Lychee RV D1 with the dock.
I've downloaded and flashed the latest armbian (Armbian_22.08.0-trunk_Nezha_jammy_current_5.19.0.img) and it always gets stuck on boot:
Loading Linux 5.19.0-rc1-d1 ...
Loading initial ramdisk ...
Loading device tree blob...
/boot/dtb
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
I've tried to format into FAT32 that same card and put the uEnv.txt mentioned before. It didn't work.
I get the terminal output through the TTL output on the GPIO header, just in case is relevant.
Can I get some help?
10 hours ago, yuzhaogoogle said:
Are we expecting an official release for VisionFive? I
ATM there are no plannings to make support for RISC-V official.
04.08.2022 в 01:19, kbm15 сказал:
The system is running, see the topic above, there is no output to UART after that, everything goes to HDMI. Therefore, for the first setup, you need an HDMI and USB keyboard.
I mean, yeah, big problem here.  Arm-RISC-V-Bian just doesn't have the same ring to it.  :D
