AZ8 Posted September 22, 2022 Posted September 22, 2022 Requests to yandex blocked by most providers in Ukraine. So, apt failed to pull new updates when roundrobin returns yandex as a mirror 0 Quote
going Posted September 22, 2022 Posted September 22, 2022 You can manually edit the source list file and specify there the mirror closest to your location or the best in speed. In this case, apt will pull updates only from this mirror. The list of mirrors for Debian and Ubuntu is published. 0 Quote
Igor Posted September 23, 2022 Posted September 23, 2022 16 hours ago, AZ8 said: Requests to yandex blocked by most providers in Ukraine. OMG We have one mirror in Ukraine. Is that blocked in Russia? 16 hours ago, AZ8 said: when roundrobin returns yandex as a mirror Here is the code. I have asked author to check what would best to deal with such exceptions that we resolve this problem at server side and users don't need to tackle this. Adding some sort of "international-relations.db " ? 0 Quote
lanefu Posted September 23, 2022 Posted September 23, 2022 The quickest fix for the user will be to use armbian-config to select a mirror. The redirector dev may be able to add some exceptions but geoiop data will never be 100% accurate 0 Quote
TheLinuxBug Posted September 23, 2022 Posted September 23, 2022 I have disabled Yandex mirror for now for APT repo, it will still be enabled for Downloads, etc but until we know it is stable again there are plenty of mirrors to be used other than it. Hopefully that solves this issue for now. Cheers! 0 Quote
going Posted September 24, 2022 Posted September 24, 2022 23.09.2022 в 17:10, TheLinuxBug сказал: Hopefully that solves this issue for now. No! The problem is on the side of the provider of another country! And it should be solved in a different way. There are no problems with the Yandex service. 0 Quote
going Posted September 24, 2022 Posted September 24, 2022 23.09.2022 в 11:06, Igor сказал: We have one mirror in Ukraine. Is that blocked in Russia? No! These are some popular services in Russia that are blocked in some other countries for users who try to reach them. Conversely, I have no problems getting through to anywhere in the world. 0 Quote
Igor Posted September 24, 2022 Posted September 24, 2022 apt service was disabled temporally until some solution is implemented in re-director service. This way people, which might be blocked, doesn't have troubles, while main download remain unchanged - manual selection of another mirror. IMO this is good solution for now. 0 Quote
Voha Posted November 18, 2022 Posted November 18, 2022 23.09.2022 в 13:57, lanefu сказал: armbian-config to select a mirror I have the same problem. Its the solution? 0 Quote
Roman Khudobei Posted January 10, 2023 Posted January 10, 2023 (edited) Hi, I am facing the same issue. I am from Ukraine and our government blocked russian services for reasonable reason. I've read, that one of the sources redirecting me to this blocked mirror and I couldn't do anything with it on my side. Is it true? How can I fix it? user@rockpi-4b:~$ sudo apt update && apt install -yq --no-install-recommends gcc libgirepository1.0-dev python3.6 python3-setuptools python3-pip python3-openssl python3.6-dev python-gi python-gobject-2 python-gi-cairo python3-gi python3-gi-cairo gir1.2-gtk-3.0 gir1.2-nm-1.0 librsvg2-dev libglib2.0-dev openssh-server net-tools musl-dev ttf-dejavu adwaita-icon-theme dbus-x11 x11-xserver-utils xinit xserver-xorg xserver-xorg-legacy xserver-xorg-input-libinput xserver-xorg-video-fbdev xterm libgtk-3-dev libgtk2.0-0 libgles2-mesa-dev libnss3 libxss1 libxtst6 libgconf-2-4 xfonts-base qemu-user-static network-manager-gnome alsa-utils pulseaudio xvfb chromium-browser xdotool v4l-utils portaudio19-dev python3.6-distutils cmake xdg-utils netcat Hit:1 http://ports.ubuntu.com jammy InRelease Hit:2 http://ports.ubuntu.com jammy-security InRelease Hit:3 https://ppa.launchpadcontent.net/deadsnakes/ppa/ubuntu jammy InRelease Hit:4 http://ports.ubuntu.com jammy-updates InRelease Hit:5 http://ports.ubuntu.com jammy-backports InRelease Get:6 http://mirror.yandex.ru/mirrors/armbian/apt jammy InRelease [2,294 B] Err:6 http://mirror.yandex.ru/mirrors/armbian/apt jammy InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?) Reading package lists... Done E: Failed to fetch http://apt.armbian.com/dists/jammy/InRelease Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?) E: The repository 'http://apt.armbian.com jammy InRelease' is no longer signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. Edited January 10, 2023 by Roman Khudobei hiding sensitive info; providing more information; improve explanation; 0 Quote
Werner Posted January 10, 2023 Posted January 10, 2023 Well you cannot tell Armbian's redirector to choose a different mirror. However you can adjust the sources.list by hand and add a (packages) mirror that you like from this list manually: https://github.com/armbian/mirror 0 Quote
Roman Khudobei Posted January 12, 2023 Posted January 12, 2023 (edited) I was able to fix the issue with the help of this topic, in case anyone searching I am also experiencing problems surfing Armbian website here. I tried to look for Rock Pi 4 B images and also for the archive. It also redirected me to "mirror.yandex.ru". Today I could access these pages, because I was redirected to another source. Edited January 12, 2023 by Roman Khudobei 1 Quote
alexondi Posted February 8, 2023 Posted February 8, 2023 /etc/hosts ... 192.168.0.254 mirror.yandex.ru ... 0 Quote
alexondi Posted February 20, 2023 Posted February 20, 2023 (edited) Temporary solution: In file /share/python-apt/templates/Ubuntu.mirrors delete lines after #LOC:RU Edited February 20, 2023 by alexondi 1 Quote
hex_messer Posted February 8 Posted February 8 (edited) my "5 cents"... correct way, as it was noticed already, to choose region in apt sources file, like in this forum post and corresponding docs page https://docs.armbian.com/User-Guide_Fine-Tuning/#choosing-an-apt-mirror And about armbian-config... For now, 08 feb 2024, image Armbian_23.11.1_Uefi-x86_bookworm_current_6.1.63_xfce_desktop.img armbian-config in my case shows only one line in mirrors selection list: "0 - Automated" This is because for now url http://apt.armbian.com/regions is defunct, and, consequently, in armbian-config code in file /usr/lib/armbian-config/jobs.sh part of code for acquiring mirrors can be (temporarily) corrected like this: ....... "Mirrors") # Default automated mirror url="http://apt.armbian.com" LIST=( "0" "Automated" ) mirrors=( "${url}" ) ## Mirrors for each region #for region in $(wget -qO- "${url}/regions" | jq -r '.[]' | sort | grep -v default); do # LIST+=( "${#mirrors[@]}" "Region ${region}" ) # mirrors+=( "${url}/region/${region}/" ) #done # Individual mirrors for mirror in $(wget -qO- "${url}/mirrors" | jq -r '.[] | .[]' | sort | uniq); do LIST+=( "${#mirrors[@]}" "${mirror}" ) mirrors+=( "${mirror}" ) done ...... this way mirrors extracted from http://apt.armbian.com/mirrors and displayed correctly. Edited February 8 by hex_messer 0 Quote
hex_messer Posted February 8 Posted February 8 oh, I figured out, how it should be coded to select regions : # Mirrors for each region for region in $(wget -qO- "${url}/mirrors" | jq -r 'keys' | jq -r '.[]' | sort | grep -v default); do LIST+=( "${#mirrors[@]}" "Region ${region}" ) mirrors+=( "${url}/region/${region}/" ) done And now it looks like this in armbian-config: Configuration utility, Armbian 23.11.1 stable, 10.0.2.15 ───────────────────────────────────────────────────────────────────────────────── ┌──────────────────── Select APT mirror ──────────────────────┐ │ Select mirror │ │ ┌─────────────────────────────────────────────────────────┐ │ │ │ 0 Automated │ │ │ │ 1 Region AS │ │ │ │ 2 Region EU │ │ │ │ 3 Region NA │ │ │ │ 4 Region OC │ │ │ │ 5 http://armbian.chi.auroradev.org/apt/ │ │ │ │ 6 http://armbian.hosthatch.com/apt/ │ │ │ │ 7 http://armbian.lv.auroradev.org/apt/ │ │ │ │ 8 http://armbian.systemonachip.net/apt/ │ │ │ │ 9 http://armbian.tnahosting.net/apt/ │ │ │ │ 10 http://au.sbcmirror.org/armbian/apt/ │ │ │ │ 11 http://fastmirror.pp.ua/armbian/ │ │ │ └────↓(+)─────────────────────────────────────────30%─────┘ │ ├─────────────────────────────────────────────────────────────┤ │ < OK > <Cancel> │ └─────────────────────────────────────────────────────────────┘ I hope, this should be posted somewhere to be corrected in mainstream code, how and where to do it? 0 Quote
SteeMan Posted February 8 Posted February 8 @hex_messer submit a PR. https://docs.armbian.com/Process_Contribute 0 Quote
Igor Posted February 10 Posted February 10 I have also disabled both mirrors from rotation until we develop & implement a proper solution to our router. 0 Quote
