Nofan Tasi Posted August 25, 2017 Posted August 25, 2017 On 8/25/2017 at 1:55 PM, balbes150 said: Image Yocto with kernel 4.12 (for S905X). (v20170825) [...] Expand Thanks! Does Yocto image also include support for running Kodi smoothly?
balbes150 Posted August 25, 2017 Author Posted August 25, 2017 On 8/25/2017 at 7:47 PM, Nofan Tasi said: Thanks! Does Yocto image also include support for running Kodi smoothly? Expand Perhaps in the future it will be. Now it is not. 1
balbes150 Posted August 28, 2017 Author Posted August 28, 2017 New image 20170828 kernel 4.12.9. In this way there is support for USB on the platform S905X. You can run the system from SD cards and USB flash drives. Changed the activation system monitor, now it is built into the kernel itself. To change the screen resolution, you need to use standard tools from control monitor on a desktop. The resolution changes on the fly (directly on desktop). Not working yet WiFi. There are problems with the dtb files (requires the edit and debug under different models). For s905x recommend to use a file meson-gxl-s905x-nexbox-a95x or meson-gxl-s905x-khadas-vim1. For the model s905 - meson-gxbb-odroidc2. 1
balbes150 Posted September 1, 2017 Author Posted September 1, 2017 New image 20170901 kernel 4.13.0-rc6 and next-4.13.0-rc7 for S905X. Working USB. 1
martinayotte Posted September 1, 2017 Posted September 1, 2017 @balbes150, could you please provide links when you've new images, I've always issues to find them, couldn't on https://yadi.sk/d/srrtn6kpnsKz2/Linux ... Thanks in advance,
balbes150 Posted September 2, 2017 Author Posted September 2, 2017 The test images are the same link, in the directory Armbin/Test. Here's a direct link to the catalog. https://yadi.sk/d/kZHc0uQE34z5jR
belaid38 Posted September 2, 2017 Posted September 2, 2017 i tested Armbian_5.32_S9xxx_Ubuntu_xenial_4.13.0-rc7-next-20170901_mate.img.xz in wetek play 2 and work booting after add boot.ini 1
balbes150 Posted September 5, 2017 Author Posted September 5, 2017 Update TEST images kernel 4.13.0-next_20170905. In these images there is USB support for S905X and S912. 1
balbes150 Posted September 7, 2017 Author Posted September 7, 2017 Version update TEST kernel 4.13.0_next_20170907. Added support for sound for all models S905X and S912. Pay attention to one feature of the work of sound - on the desktop has to be set 1920x1080 resolution. Not clear to me yet why the sound only works in this screen resolution. For some recent images to use these additions, you can only download the kernel and dtb files (deb packages are in the directory TEST\deb) to install in the existing system (don't forget to update the file "dtb.img" to a new version). 1
fossxplorer Posted September 9, 2017 Posted September 9, 2017 On 9/1/2017 at 7:54 PM, balbes150 said: New image 20170901 kernel 4.13.0-rc6 and next-4.13.0-rc7 for S905X. Working USB. Expand Since i got a couple of S905X boxes at home, i gave Nexbox A95X S905X a try, boots with multiple DTB, but only meson-gxbb-nexbox-a95x.dtb seems to be able to boot into ldm/mate. But there is no response from USB mouse nor keyboard. As USB is supported now, what could this be? EDIT: images being tested are from 20170907.
intelmarico Posted September 11, 2017 Posted September 11, 2017 Armbian_5.32_S9xxx_Ubuntu_xenial_4.13.0-next-20170908_mate.img.xz successfully boots into a green textured mate on my X96 (1+16) box. USB wired mouse and USB keyboard both work fine. I can play the movie and access folders but little else. The settings file (config) opens but there are few options, and I have not discovered how to access the console or enable wifi yet. I assume HDMI is working at 720p. Have not checked audio. Am using the A95x dtb file.
balbes150 Posted September 11, 2017 Author Posted September 11, 2017 On 9/9/2017 at 6:48 PM, fossxplorer said: Since i got a couple of S905X boxes at home, i gave Nexbox A95X S905X a try, boots with multiple DTB, but only meson-gxbb-nexbox-a95x.dtb seems to be able to boot into ldm/mate. But there is no response from USB mouse nor keyboard. As USB is supported now, what could this be? Expand 1. If the system runs with file gxbb , then this is the version with the chip S905 (no X). 2. Try all the dtb files, the title of which is "gxbb". On 9/11/2017 at 12:31 AM, intelmarico said: enable wifi yet Expand WiFi in this kernel version is not supported. On 9/11/2017 at 12:31 AM, intelmarico said: I assume HDMI is working at 720p Expand Sound only works with 1080p resolution (you can switch the screen resolution on the fly in a working system, via the settings menu of the monitor group Settings).
MOHAMMAD HADI Posted September 12, 2017 Posted September 12, 2017 @balbes150 how can i configure uboot ethernet connection to boot through tftp ? i have a Kii pro S905 box, tried to set the ip address and gateway in u-boot but still whenever i ping a host in the network it says the host is not alive? is this a bug or i'm missing a setting ?my u-boot version is 2015.01-g3fb479f-dirty (Oct 13 2016 - 19:22:50)
balbes150 Posted September 12, 2017 Author Posted September 12, 2017 On 9/12/2017 at 1:05 AM, MOHAMMAD HADI said: how can i configure uboot ethernet connection to boot through tftp ? i have a Kii pro S905 box, tried to set the ip address and gateway in u-boot but still whenever i ping a host in the network it says the host is not alive? is this a bug or i'm missing a setting ?my u-boot version is 2015.01-g3fb479f-dirty (Oct 13 2016 - 19:22:50) Expand Have you read this information ? http://docs.khadas.com/develop/SetupTFTPServer/
pro777 Posted September 12, 2017 Posted September 12, 2017 balbes150, thank you very much for your excellent work! I have a KM8P S912 - on firmware at the 20170908 with the kernel 4.13 works USB-mouse and the keyboard, there is a sound at the resolution of the screen 1920х1080. As I understand it, there a problem when installing this firmware on EMMC?
balbes150 Posted September 12, 2017 Author Posted September 12, 2017 In the test builds (with the kernel 4.x) there are many things not completed and there are errors, these images and dtb data changes frequently. So I have not tested the installation to the internal memory.
pro777 Posted September 12, 2017 Posted September 12, 2017 Can you please tell me how to install the firmware on EMMC? Is there any way to install the GPU Mali drivers? Are there any advantages of the 4.13 kernel compared to the 3.14 kernel?
MOHAMMAD HADI Posted September 12, 2017 Posted September 12, 2017 On 9/12/2017 at 6:23 AM, balbes150 said: Have you read this information ? http://docs.khadas.com/develop/SetupTFTPServer/ Expand Yes i have but it's not working on my box. my box and my laptop are connected to the same router the router ip is 172.16.1.1 running dhcp server i tried to setup a tftp server in my main os (arch linux) and then tried it in a ubuntu 16.04.2 vm and still can't get it to work. gxb_p20x#setenv ipaddr 172.16.1.44 gxb_p20x#setenv serverip 172.16.1.241 gxb_p20x#setenv gatewayip 172.16.1.1 gxb_p20x#saveenv Saving Environment to aml-storage... mmc env offset: 0x27400000 Writing to MMC(1)... done gxb_p20x#ping 172.16.1.1 Amlogic Ethernet Init Success: reset mac OK!(0) ETH PHY hardware reset OK find net phy id=0x2430c54, phyad=0 set_mac_mode(2) final_addr[rx-tx]: 0000000073efe8e0-0000000073efeee0 Ethernet reset OK MAC address is 00:15:18:01:81:31 duplex 100m Using Meson_Ethernet device ping failed; host 172.16.1.1 is not alive gxb_p20x#tftp 1080000 Image Using Meson_Ethernet device TFTP from server 172.16.1.241; our IP address is 172.16.1.44 Filename 'Image'. Load address: 0x1080000 Loading: T T T T T T T T T T Retry count exceeded; starting again Using Meson_Ethernet device TFTP from server 172.16.1.241; our IP address is 172.16.1.44 Filename 'Image'. Load address: 0x1080000 Loading: * Abort This might be a bug in u-boot of the box that was fixed in kvim u-boot ? have you ever tried this on a box and worked ?
balbes150 Posted September 16, 2017 Author Posted September 16, 2017 Update test image kernel 4.13.0-next_20170915. 1
balbes150 Posted September 17, 2017 Author Posted September 17, 2017 On 9/17/2017 at 4:28 PM, purplepumkin said: Would the S905W work? I'm seeing S905W devices going quite cheap. Less than $20 for a Tanix TX3 mini with 1GB RAM and 16GB eMMC. Expand I have no such models, so until the owner of such a model itself will not check, we do not know.
pro777 Posted September 18, 2017 Posted September 18, 2017 On 9/16/2017 at 4:22 PM, balbes150 said: Update test image kernel 4.13.0-next_20170915 Expand What's new in this firmware?
MOHAMMAD HADI Posted September 20, 2017 Posted September 20, 2017 @balbes150 how to get fw_printenv and fw_setenv working in mainline kernel images ? when running a 3.14 kernel the tools works fine by using /dev/env which doesn't exist in mainline kernel. looking at dmesg in 3.14 kernel it output the environment offsets [ 2.369744@2] [mmcblk0p04] env offset 0x000027400000, size 0x000000800000 u-boot also report the same offsets name offset size flag =================================================================================== 0: bootloader 0 400000 0 1: reserved 2400000 4000000 0 2: cache 6c00000 20000000 2 3: env 27400000 800000 0 4: logo 28400000 2000000 1 5: recovery 2ac00000 2000000 1 6: rsv 2d400000 800000 1 7: tee 2e400000 800000 1 8: crypt 2f400000 2000000 1 9: misc 31c00000 2000000 1 10: instaboot 34400000 20000000 1 11: boot 54c00000 2000000 1 12: system 57400000 40000000 1 13: data 97c00000 30c200000 4 i tried to put these offsets in /etc/fw_en.config file but still the fw_printenv tools is printing the default environment
balbes150 Posted September 22, 2017 Author Posted September 22, 2017 On 9/20/2017 at 7:29 AM, MOHAMMAD HADI said: how to get fw_printenv and fw_setenv working in mainline kernel images ? Expand I haven't tested these utilities on core 4.x On 9/20/2017 at 7:30 PM, purplepumkin said: It seems "arm-none-eabi-cpp" is missing. Expand I hope you are using a 64 bit system and installed the 32 bit multilib ? To all Update test image 4.14.0-rc1-next-20170922.
hillz Posted September 23, 2017 Posted September 23, 2017 Do you guys plan to support S905W ? I just ordered Tanix TX3 Mini with S905W chipset, it'd be great to be able to install a linux distro in it.
balbes150 Posted September 23, 2017 Author Posted September 23, 2017 On 9/23/2017 at 9:57 AM, purplepumkin said: Can confirm that installing above mentioned package resolves the issue. Should apply to both Debian and Ubuntu. Expand What system are you using to build ?
