With dtb.img from @xXx i can boot the Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_mate_20170323.img.xz , but i got No Signal on Boot time... its gone when it ask to login.
So the Framebuffer on Boot time it make my Samsung TV out of range, so it give No Signal..... or there is something else....
To @balbes150 , i have a question:
1. I got Error when proses boot, how to disable it, can i just delete boot.bmp in BOOT Partition to disable it?
2. I Got Trash Error in Mate Desktop, this is not happening back then when i try with Armbian 5.21 - it just like these error mentioned by xXx in here -
3. Where is Auto Mount ? in Odroid Ubuntu Mate, i can auto mout when i plug flashdisk or usb harddisk?
Thanks alot for Balbes150 and xXx
1. The first start takes more than 5-8 minutes on a slow or large media. No signal when you start with external drives is fine. After launch and is ready, she will turn on the monitor.
2. The file "boot.bmp" have no effect (it is not yet used), you can delete it.
3. Automount in Ubuntu works.
@sukanime
For the trash error in mate you need to install mate-applets package.
Auto mount of usb drives should be working on mate desktop out of the box ( you see the icons it in Desktop, and click - click ).
In CLI though ( no GUI ) there is no auto-mounting.
1. I'am sory if i'am not clear with my question, my Problem is i have "No Signal" on the process off booting, i delete the boot.bmp but its not helping it, so how to make the process of booting to see the log of boot process ? i go to https://docs.armbian.com/User-Guide_Fine-Tuning/
there is no info about /boot/armbianEnv.txt in Boot Folder, i try to change verbosity
what about amlogics905x_init.sh , where i can get the reference information to edit this file?
What it is Blank fb ? do this setting couse "No Signal" on My Samsung TV Screen ?
2. Yup, it doesn't have any effect.
3. Its strange, it not automounted when i plug usb harddisk Hitachi Touro 2TB with ext4 filesystem ,
but if i plug usb flashdisk it auto mounted, but it's ask to choose whats apps to open, but no CAJA filemanager to choose.
and i got new problem, playing Video with VLC.
its will make soundcard module driver tainted.
here the log when i run VLC in console to see debug info, why its asking libvdpau_sunxi.so :
sukanime@Mini-M8S-s905:~$ vlc
VLC media player 2.2.2 Weatherwax (revision 2.2.2-0-g6259d80)
[0000000028175160] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
Failed to open VDPAU backend libvdpau_sunxi.so: cannot open shared object file: No such file or directory
Here Module Driver Taintent log:
[ 1302.217719] hdmitx tx_aud_src = 0 [ 1302.217748] hdmitx: fs = 2, cd = 4, tmds_clk = 148500 [ 1302.217753] hdmitx aud_n_para = 6272 [ 1302.217773] hdmitx set channel status [ 1302.217835] hdmitx: audio: Audio Type: PCM [ 1302.217839] hdmitx: audio: set audio param [ 1302.217850] aml_snd_m8_card aml_m8_snd.45: i2s/958 same source [ 1302.217935] aml_snd_card: audio speaker on [ 1302.225442] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, same source mode(1) [ 1302.225450] aml_spdif_dai: share the same clock [ 1302.225457] aml_spdif_dai: iec958 mode PCM16 [ 1302.225466] aml_audio_hw: IEC958 16bit [ 1302.225472] hdmitx: audio: aout notify rate 44100 [ 1302.225476] hdmitx: audio: aout notify size 16 [ 1302.225480] hdmitx: audio: no update [ 1302.225490] aml_snd_m8_card aml_m8_snd.45: i2s/958 same source [ 1302.225731] aml_snd_m8_card aml_m8_snd.45: I2S playback enable [ 1302.225739] aml_snd_m8_card aml_m8_snd.45: IEC958 playback enable [ 1305.103938] Unable to handle kernel paging request at virtual address ffffff8003200ff0 [ 1305.107079] pgd = ffffffc053868000 [ 1305.109916] [ffffff8003200ff0] *pgd=00000000538ba003, *pmd=0000000000000000 [ 1305.133424] Internal error: Oops: 96000047 [#1] PREEMPT SMP [ 1305.133675] Modules linked in: fuse 8723bs cfg80211 bonding joydev aml_nftl_dev(P) mali wifi_dummy autofs4 [ 1305.143425] CPU: 2 PID: 3942 Comm: alsa-sink-I2S.3 Tainted: P             3.14.29-amlogics905x-g9e20280-dirty #10 [ 1305.153772] task: ffffffc063af1000 ti: ffffffc065764000 task.ti: ffffffc065764000 [ 1305.161371] PC is at aml_i2s_copy_playback.isra.6+0x310/0x470 [ 1305.167230] LR is at aml_i2s_copy_playback.isra.6+0x25c/0x470 [ 1305.173092] pc : [<ffffffc0018ed344>] lr : [<ffffffc0018ed290>] pstate: 20000145 [ 1305.180594] sp : ffffffc065767aa0 [ 1305.184044] x29: ffffffc065767aa0 x28: 0000000000000010 [ 1305.189477] x27: 0000000000000100 x26: ffffffc063e80000 [ 1305.194911] x25: ffffffc064260800 x24: ffffffc073b7ba00 [ 1305.200345] x23: 0000000000000800 x22: 0000007fa42e0010 [ 1305.205778] x21: fffffffffffffff0 x20: 0000000000000010 [ 1305.211213] x19: ffffff8003200ff0 x18: 0000000000000014 [ 1305.216646] x17: 0000007fad3e50c0 x16: ffffffc0011dbd1c [ 1305.222080] x15: 003b9aca00000000 x14: 0000000000000000 [ 1305.227513] x13: 0000000000000000 x12: 0000000000000000 [ 1305.232947] x11: 0000000000000000 x10: 0000000000000000 [ 1305.238381] x9 : 002495cfbd862a4f x8 : 0000000000000010 [ 1305.243815] x7 : 0000000000020000 x6 : ffffffc0018ed4a4 [ 1305.249249] x5 : 0000000000000020 x4 : ffffffc063e80000 [ 1305.254683] x3 : ffffff8003201010 x2 : 0000000000000000 [ 1305.260116] x1 : ffffffc063e80004 x0 : 0000000000000000 [ 1305.265550]                PC: 0xffffffc0018ed2c4: [ 1305.270811] d2c4  aa0303e4 aa1a03e2 aa0503e1 b8408440 13087c00 b8004420 b85fc040 eb03003f [ 1305.279091] d2e4  13087c00 b8004480 54ffff21 910100a5 9101035a 4b1300a0 91010063 6b00037f [ 1305.287371] d304  54fffe0c 17ffffb5 f9403ba1 aa1c03e2 aa1a03e0 f90037a8 97ef7841 f94037a8 [ 1305.295651] d324  17ffffd7 6b1f037f aa1a03e4 54fff56d 91008263 aa0403e1 d2800000 78c04422 [ 1305.303931] d344  78206a62 78dfe022 78206862 91000800 f100801f 54ffff41 91010084 91010273 [ 1305.312210] d364  4b1a0080 6b1b001f 54fffe4b 17ffff9b 90006a00 b942e800 7100081f 54fff2e1 [ 1305.320491] d384  6b1f037f 91008264 aa1303e5 54fff26d aa0403e2 aa1a03e1 aa0503e0 b8408423 [ 1305.328770] d3a4  b8004403 b85fc023 eb04001f b8004443 54ffff61 910100a5 9101035a 4b1300a0 [ 1305.337052]                LR: 0xffffffc0018ed210: [ 1305.342312] d210  f9403ba3 aa0303e0 17ffffc1 a94153f3 a9425bf5 a94363f7 a9446bf9 a94573fb [ 1305.350592] d230  128001a0 a8d97bfd d65f03c0 90006a00 f9015815 17ffffd2 93407e88 910243a0 [ 1305.358872] d250  cb080061 aa0803e2 8b010341 f90037a8 97ef7870 4b170362 aa1a03e1 8b1c0340 [ 1305.367152] d270  93407c42 97ef7883 f94037a8 35000497 f9403ba0 aa0803e2 910243a1 97ef7865 [ 1305.375432] d290  17ffffba f9403ba1 aa1c03e2 aa1a03e0 97ef7860 17ffffb5 b9406b20 91008263 [ 1305.383712] d2b0  7100201f 54000900 6b1f037f aa1303e5 54fff8ed aa0303e4 aa1a03e2 aa0503e1 [ 1305.391992] d2d0  b8408440 13087c00 b8004420 b85fc040 eb03003f 13087c00 b8004480 54ffff21 [ 1305.400272] d2f0  910100a5 9101035a 4b1300a0 91010063 6b00037f 54fffe0c 17ffffb5 f9403ba1 [ 1305.408552]                SP: 0xffffffc065767a20: [ 1305.413813] 7a20  00000010 00000000 fffffff0 ffffffff a42e0010 0000007f 00000800 00000000 [ 1305.422093] 7a40  73b7ba00 ffffffc0 64260800 ffffffc0 63e80000 ffffffc0 00000100 00000000 [ 1305.430373] 7a60  00000010 00000000 65767aa0 ffffffc0 018ed290 ffffffc0 65767aa0 ffffffc0 [ 1305.438653] 7a80  018ed344 ffffffc0 20000145 00000000 407aef60 ffffff80 5e366900 ffffffc0 [ 1305.444436] 7aa0 [ 1305.444437]  65767c30 [ 1305.444438]  ffffffc0 [ 1305.444439]  018ed5ac [ 1305.444440]  ffffffc0 [ 1305.444440]  73b7b600 [ 1305.444441]  ffffffc0 [ 1305.444442]  00000040 [ 1305.444443]  00000000 [ 1305.444444] 7ac0 [ 1305.444450]  a42dff10 0000007f 00000000 00000000 a42df040 0000007f 018caf3c ffffffc0 [ 1305.444455] 7ae0  00000001 00000000 000003b4 00000000 00000000 00000000 64260800 ffffffc0 [ 1305.444462] 7b00  538259a0 ffffffc0 00000010 00000000 73b7ba0c ffffffc0 65764000 ffffffc0 [ 1305.444464]                X1: 0xffffffc063e7ff84: [ 1305.444470] ff84  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444475] ffa4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444481] ffc4  00000000 00000000 00000000 00000000 00000000 00000005 00000000 00000000 [ 1305.444486] ffe4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444491] 0004  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444497] 0024  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444502] 0044  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444508] 0064  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444510]                X4: 0xffffffc063e7ff80: [ 1305.444516] ff80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444521] ffa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444526] ffc0  00000000 00000000 00000000 00000000 00000000 00000000 00000005 00000000 [ 1305.444532] ffe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444537] 0000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444542] 0020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444548] 0040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444553] 0060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444555]                X6: 0xffffffc0018ed424: [ 1305.444561] d424  b85e8001 13087c21 b80044a1 b85ec001 13087c21 b80044c1 b85f0001 13087c21 [ 1305.444567] d444  b80044e1 b85f4001 13087c21 b8004501 b85f8001 13087c21 b8004521 b85fc001 [ 1305.444573] d464  13087c21 b8004541 54fffcc1 9104016b 9104035a 4b130160 91040063 6b00037f [ 1305.444579] d484  54fffaec 17ffff55 b0002961 2a1403e2 91074021 97f204f3 128001a0 17ffff50 [ 1305.444584] d4a4  a9bb7bfd 910003fd a90153f3 a9025bf5 a90363f7 f90023f9 aa0003f3 aa1e03e0 [ 1305.444590] d4c4  aa0203f6 aa0303f5 aa0403f4 d503201f b9403e61 f9409e60 340005e1 b9409804 [ 1305.444597] d4e4  910003e1 f9400262 9272c437 f9409265 aa1503e1 9b147c83 f9400042 eb1f007f [ 1305.444602] d504  91001c73 9a83b263 f9416418 f9413459 9343fc73 f94006e2 f94000b4 ab130021 [ 1305.444607]                X16: 0xffffffc0011dbc9c: [ 1305.444613] bc9c  17ffff3c 528b0500 72a80600 6b00027f 54000080 11000800 6b00027f 54fff161 [ 1305.444620] bcbc  aa1403e1 aa1503e0 97fffe7e 17ffff31 128002a0 17ffff2f 910003e0 9272c401 [ 1305.444626] bcdc  aa1403e0 f9400421 b1001000 fa413002 9a9f27e2 b4ffed02 f9402ac1 52800000 [ 1305.444631] bcfc  f9403aa2 4b020021 b9000281 17ffff21 12800bc0 17ffff1f 2a1303e0 17ffff1d [ 1305.444637] bd1c  a9bc7bfd 910003fd a90153f3 a9025bf5 a90363f7 aa0003f6 aa1e03e0 aa0103f7 [ 1305.444643] bd3c  aa0203f8 d503201f 2a1603e0 94002bf8 f27ef415 aa0003f4 54000320 aa1803e2 [ 1305.444649] bd5c  2a1703e1 aa1503e0 9409d766 2a0003f3 34000160 370000f4 93407e60 a94153f3 [ 1305.444655] bd7c  a9425bf5 a94363f7 a8c47bfd d65f03c0 aa1503e0 97ffba41 17fffff8 aa1803e3 [ 1305.444658]                X24: 0xffffffc073b7b980: [ 1305.444664] b980  00000000 00000000 73b7b968 ffffffc0 63a1d6c0 ffffffc0 00000000 00000000 [ 1305.444670] b9a0  00020802 00000000 00000000 00000000 00000000 00000000 73870780 ffffffc0 [ 1305.444675] b9c0  73870a80 ffffffc0 73870d80 ffffffc0 64c156c0 ffffffc0 64c159c0 ffffffc0 [ 1305.444681] b9e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444686] ba00  63e80000 ffffffc0 00080000 00000000 00000000 00000000 00000000 00000000 [ 1305.444692] ba20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444697] ba40  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444702] ba60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444704]                X25: 0xffffffc064260780: [ 1305.444710] 0780  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444715] 07a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444720] 07c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444726] 07e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444731] 0800  00000000 00000000 00000516 00000000 0d23d731 00000000 00000000 00000000 [ 1305.444737] 0820  00003820 00000000 00022000 00000000 00022800 00000000 000188be 00000001 [ 1305.444742] 0840  00000009 00000000 00000000 00000000 00000000 00000000 00000003 00000002 [ 1305.444747] 0860  00000000 0000ac44 00000002 00000000 00000400 00000000 00000004 00000000 [ 1305.444749]                X26: 0xffffffc063e7ff80: [ 1305.444754] ff80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444759] ffa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444764] ffc0  00000000 00000000 00000000 00000000 00000000 00000000 00000005 00000000 [ 1305.444769] ffe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444775] 0000  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444780] 0020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444785] 0040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444790] 0060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.444792]                X29: 0xffffffc065767a20: [ 1305.444798] 7a20  00000010 00000000 fffffff0 ffffffff a42e0010 0000007f 00000800 00000000 [ 1305.444804] 7a40  73b7ba00 ffffffc0 64260800 ffffffc0 63e80000 ffffffc0 00000100 00000000 [ 1305.444810] 7a60  00000010 00000000 65767aa0 ffffffc0 018ed290 ffffffc0 65767aa0 ffffffc0 [ 1305.444815] 7a80  018ed344 ffffffc0 20000145 00000000 407aef60 ffffff80 5e366900 ffffffc0 [ 1305.444821] 7aa0  65767c30 ffffffc0 018ed5ac ffffffc0 73b7b600 ffffffc0 00000040 00000000 [ 1305.444827] 7ac0  a42dff10 0000007f 00000000 00000000 a42df040 0000007f 018caf3c ffffffc0 [ 1305.444832] 7ae0  00000001 00000000 000003b4 00000000 00000000 00000000 64260800 ffffffc0 [ 1305.444838] 7b00  538259a0 ffffffc0 00000010 00000000 73b7ba0c ffffffc0 65764000 ffffffc0 [ 1305.444842] Process alsa-sink-I2S.3 (pid: 3942, stack limit = 0xffffffc065764058) [ 1305.444845] Stack: (0xffffffc065767aa0 to 0xffffffc065768000) [ 1305.444851] 7aa0: 65767c30 ffffffc0 018ed5ac ffffffc0 73b7b600 ffffffc0 00000040 00000000 [ 1305.444855] 7ac0: a42dff10 0000007f 00000000 00000000 a42df040 0000007f 018caf3c ffffffc0 [ 1305.444859] 7ae0: 00000001 00000000 000003b4 00000000 00000000 00000000 64260800 ffffffc0 [ 1305.444863] 7b00: 538259a0 ffffffc0 00000010 00000000 73b7ba0c ffffffc0 65764000 ffffffc0 [ 1305.444867] 7b20: 00000040 00000000 53401f00 ffffffc0 00000000 00000000 00000000 00000000 [ 1305.444872] 7b40: a4100000 0000007f 000000a9 00000000 5e366900 ffffffc0 63b95000 ffffffc0 [ 1305.444876] 7b60: 538259a0 ffffffc0 000001fe 00000000 01fdc000 ffffffc0 65764000 ffffffc0 [ 1305.444880] 7b80: 53867000 ffffffc0 00000120 00000000 65767bb0 ffffffc0 011b985c 00000000 [ 1305.444884] 7ba0: 1b18cf53 02e00000 00000000 00000000 65767bd0 ffffffc0 018ef284 ffffffc0 [ 1305.444889] 7bc0: 53401f28 ffffffc0 407aef60 ffffff80 65767be0 ffffffc0 018ec504 ffffffc0 [ 1305.444893] 7be0: 65767c00 ffffffc0 018e1d04 ffffffc0 65767c00 ffffffc0 01101228 ffffffc0 [ 1305.444897] 7c00: 65767c40 ffffffc0 018cce28 ffffffc0 64260800 ffffffc0 000003f4 00000000 [ 1305.444901] 7c20: 00000040 00000000 0001f040 00000000 65767c80 ffffffc0 018cafac ffffffc0 [ 1305.444905] 7c40: 000003b4 00000000 73b7b600 ffffffc0 00000040 00000000 00000000 00000000 [ 1305.444909] 7c60: a42df040 0000007f 018caf3c ffffffc0 00000001 00000000 018caf3c ffffffc0 [ 1305.444914] 7c80: 65767cc0 ffffffc0 018cd3a4 ffffffc0 73b7b600 ffffffc0 00000040 00000000 [ 1305.444918] 7ca0: 73b7b768 ffffffc0 0262c000 ffffffc0 a42df040 0000007f 00000000 00000000 [ 1305.444922] 7cc0: 65767d60 ffffffc0 018cd594 ffffffc0 73b7b600 ffffffc0 a42df040 0000007f [ 1305.444927] 7ce0: 000003f4 00000000 acb60730 0000007f 00000027 00000000 acb60730 0000007f [ 1305.444931] 7d00: 00000117 00000000 0000001d 00000000 01fc7000 ffffffc0 65764000 ffffffc0 [ 1305.444935] 7d20: 00000117 00000000 65767d58 ffffffc0 00020000 00000000 00000040 00000000 [ 1305.444940] 7d40: 000003b4 00000000 0262cfa0 ffffffc0 73b7b600 ffffffc0 00000040 00000000 [ 1305.444944] 7d60: 65767d90 ffffffc0 018c85ec ffffffc0 40184150 00000000 54808e00 ffffffc0 [ 1305.444948] 7d80: 73b7b600 ffffffc0 01216ab8 ffffffc0 65767de0 ffffffc0 018c8648 ffffffc0 [ 1305.444953] 7da0: 54808e00 ffffffc0 40184150 00000000 acb60730 0000007f 73af9998 ffffffc0 [ 1305.444957] 7dc0: 65767e50 ffffffc0 00000000 00000000 a42df040 0000007f 000003f4 00000000 [ 1305.444961] 7de0: 65767e10 ffffffc0 011dbb00 ffffffc0 40184150 00000000 acb60730 0000007f [ 1305.444965] 7e00: 54808e00 ffffffc0 011e6c24 ffffffc0 65767e90 ffffffc0 011dbdac ffffffc0 [ 1305.444969] 7e20: 00000000 00000000 54808e01 ffffffc0 54808e00 ffffffc0 00000027 00000000 [ 1305.444974] 7e40: 40184150 00000000 ad39e9fc 0000007f 65767e60 ffffffc0 01451b3c ffffffc0 [ 1305.444978] 7e60: 65767e90 ffffffc0 011dbd68 ffffffc0 ac243000 0000007f 54808e01 ffffffc0 [ 1305.444982] 7e80: 54808e00 ffffffc0 00000015 00000000 acb60700 0000007f 0108426c ffffffc0 [ 1305.444986] 7ea0: ac243000 0000007f a8002260 0000007f ffffffff ffffffff ad3e50cc 0000007f [ 1305.444991] 7ec0: 60000000 00000000 00000015 00000000 00000027 00000000 40184150 00000000 [ 1305.444995] 7ee0: acb60730 0000007f acb60730 0000007f 00000000 00000000 00000000 00000000 [ 1305.445000] 7f00: 00009924 00000000 00007fff 00000000 0000001d 00000000 00000000 00000000 [ 1305.445003] 7f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1305.445007] 7f40: 00000000 00000000 00000000 003b9aca ac2444b0 0000007f ad3e50c0 0000007f [ 1305.445011] 7f60: 00000014 00000000 ac243000 0000007f a8002260 0000007f a8000f70 0000007f [ 1305.445016] 7f80: ac143a38 0000007f 34a807c0 00000000 00000001 00000000 00000001 00000000 [ 1305.445020] 7fa0: 34a80978 00000000 00000000 00000000 00000fd0 00000000 acb60700 0000007f [ 1305.445024] 7fc0: ac1b7f7c 0000007f acb60700 0000007f ad3e50cc 0000007f 60000000 00000000 [ 1305.445028] 7fe0: 00000027 00000000 0000001d 00000000 154230b2 89195576 0872e9a1 7b528b44 [ 1305.445029] Call trace: [ 1305.445038] [<ffffffc0018ed344>] aml_i2s_copy_playback.isra.6+0x310/0x470 [ 1305.445042] [<ffffffc0018ed5a8>] aml_i2s_copy+0x104/0x1dc [ 1305.445049] [<ffffffc0018cafa8>] snd_pcm_lib_write_transfer+0x6c/0x114 [ 1305.445052] [<ffffffc0018cd3a0>] snd_pcm_lib_write1+0x1fc/0x384 [ 1305.445055] [<ffffffc0018cd590>] snd_pcm_lib_write+0x68/0x98 [ 1305.445058] [<ffffffc0018c85e8>] snd_pcm_playback_ioctl1+0x2f8/0x310 [ 1305.445061] [<ffffffc0018c8644>] snd_pcm_playback_ioctl+0x44/0x70 [ 1305.445068] [<ffffffc0011dbafc>] do_vfs_ioctl+0x35c/0x57c [ 1305.445071] [<ffffffc0011dbda8>] SyS_ioctl+0x8c/0xa4 [ 1305.445075] Code: 91008263 aa0403e1 d2800000 78c04422 (78206a62) [ 1305.455065] ---[ end trace 4e719128e7419d44 ]---
Please Help me with this VLC Bug... i like to play movie with VLC.
Thanks @balbes150
10 hours ago, xXx said:
@sukanime
Thanks for the reply, i already reads the solution from your post in page 25 and i do what you write in there, thanks again.
I just want to give more report about it to Balbes, so in the future release this problem will be fixed.
When i plug my Hitachi Touro 2TB, i don't have the icon.
Btw, do you have "No Signal" after Google TV Logo? or you can see the text of log progres ?
@balbes150  I think I've just discovered a bug in the booting sequence.
Trying to boot from a USB disk while another USB drive is connected, ends up booting Android from eMMC. Booting from an SD card works as expected, and the USB drive can be left connected.
To get the output in the startup process - you need to rebuild the initrd script to enable activation of the monitor in the beginning of the system start (with the addition of the utility fbset part of the initrd). I tried to discuss this issue with the developers Armbian, but I was advised not to change the scripts generating the initrd, do not get the problem in the future. Maybe I'll return to this question later (I don't have time for this).
I don't have a free USB drive with 2 TB to check.
Whenever possible I will try to check.
This is not a bug. It is a feature of the poll the USB ports and destination numbers in u-boot. Reversed the discs. Every model TV of the boxes in u-boot has its order assign a name to the USB. In the script add the ability to run on all ports (when connected to multiple ports), but this will increase startup time. For those who need it can advise to collect your own version of the two scripts activate and launch, with the addition of a survey of USB ports 1 , USB 2 etc (add the lines with these descriptions in both script and preactivate-multiboot with the new settings).
On 12.04.2017 at 6:06 PM, umiddelb said:
I'm using mainline with some additional patches related to the ODROID-C2, but a common config for both the C2 and the KVIM (make gx_defconfig).
I looked at Your kernel sources, but there's a lot of changes to my branch. You can specify which patches imposed on the source ? I want to try to compare the behavior of the kernel (with the patches and without them) when working with the network.
6 hours ago, balbes150 said:
1. To get the output in the startup process - you need to rebuild the initrd script to enable activation of the monitor in the beginning of the system start (with the addition of the utility fbset part of the initrd). I tried to discuss this issue with the developers Armbian, but I was advised not to change the scripts generating the initrd, do not get the problem in the future. Maybe I'll return to this question later (I don't have time for this).
2. I don't have a free USB drive with 2 TB to check.
3. Whenever possible I will try to check.
1. So the problem is, Video out is turned off, Thanks for the info, i hope its will get better.
2. Never mind, lookslike the problem on Ext4 FS in my Usb Harddisk.
3. Thanks, do you think there is vdpau sunxi stuff in your Armbian.
I have new problem, i want to make the Mate Desktop much better, and i want to install the Desktop Manager.
After i check the packages installed in Ubuntu Mate Odroid , i install it.
on the install process, initramfs change the /boot/initrd.img-3.14.29
Processing triggers for libc-bin (2.23-0ubuntu7) ...
Processing triggers for systemd (229-4ubuntu16) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for initramfs-tools (0.122ubuntu8.8) ...
ln: failed to create hard link '/boot/initrd.img-3.14.29.dpkg-bak' => '/boot/initrd.img-3.14.29': Operation not permitted
update-initramfs: Generating /boot/initrd.img-3.14.29
update-initramfs: Converting to u-boot format
Processing triggers for dbus (1.10.6-1ubuntu3.3) ...
But after it, i got Glitches on my Desktop, i have to re install Armbian to my Samsung EVO 32GB Micro SDCard to solve it.
i have try it, two times install the packages and i will get glitches so i do two time re install Armbian.
and why Lightdm failed to start.... but not much info showed in console, just lightdm stopped [OK] see sysctl status lightdm.status but when i type thoose command, there no info.
here the packages install log:
root@Mini-M8S-s905:/home/sukanime# apt-get install -y mate-tweak mate-themes mate-sensors-applet-common mate-sensors-applet mate-optimus mate-netspeed-common mate-netspeed mate-netbook-common mate-netbook mate-menu mate-indicator-applet-common mate-indicator-applet mate-icon-theme-faenza mate-gnome-main-menu-applet mate-dock-applet mesa-utils menu ubuntu-mate-lightdm-theme ubuntu-mate-wallpapers ubuntu-mate-wallpapers-xenial ubuntu-mate-welcome lightdm light-themes lightdm-gtk-greeter lightdm-gtk-greeter-settings imagemagick gimp inkscape caja-extensions-common caja-gksu caja-open-terminal caja-sendto caja-wallpaper filezilla
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  console-data
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  compton dconf-cli filezilla-common gawk gimp-data gir1.2-javascriptcoregtk-3.0 gir1.2-soup-2.4 gir1.2-webkit-3.0 gir1.2-wnck-1.0 imagemagick-6.q16 imagemagick-common inxi
  libamd2.4.1 libbabl-0.1-0 libblas-common libblas3 libcamd2.4.1 libccolamd2.9.1 libcdr-0.1-1 libcholmod3.0.6 libconfig9 libcupsfilters1 libcupsimage2 libfakekey0 libfilezilla0
  libgc1c2 libgegl-0.3-0 libgfortran3 libgimp2.0 libgs9 libgs9-common libgsl2 libgssdp-1.0-3 libgtkspell0 libgupnp-1.0-4 libido3-0.1-0 libijs-0.35 libilmbase12 libjasper1
  libjavascriptcoregtk-3.0-0 libjbig2dec0 liblapack3 liblightdm-gobject-1-0 liblqr-1-0 libmagick++-6.q16-5v5 libmagickcore-6.q16-2 libmagickwand-6.q16-2
  libmate-sensors-applet-plugin0 libnm-glib4 libnm-util2 libnotify-bin libopenexr22 libpaper1 libplymouth4 libpoppler-glib8 libpoppler58 libpugixml1v5 libraw15 libumfpack5.7.1
  libvisio-0.1-1 libwebkitgtk-3.0-0 libwebkitgtk-3.0-common libwebpmux1 libwmf0.2-7 mozo plymouth poppler-data python-configobj python-glade2 python-gobject python-mate-menu
  python-six python-wnck python-xdg python-xlib python3-decorator python3-numpy python3-pil python3-polib python3-psutil python3-scipy python3-xdg ubuntu-mate-wallpapers-common
  xdg-utils
Suggested packages:
  pidgin | gajim python-dbus gawk-doc gimp-help-en | gimp-help gimp-data-extras imagemagick-doc autotrace cups-bsd | lpr | lprng enscript ffmpeg gnuplot grads graphviz hp2xx html2ps
  libwmf-bin mplayer povray radiance sane-utils texlive-base-bin transfig ufraw-batch pstoedit dia | dia-gnome libsvg-perl libxml-xql-perl python-uniconvertor ruby fonts-droid
  texlive-lang-cjk gsl-ref-psdoc | gsl-doc-pdf | gsl-doc-info | gsl-ref-html libjasper-runtime libmagickcore-6.q16-2-extra libwmf0.2-7-gtk bindfs software-center
  mate-sensors-applet-nvidia menu-l10n desktop-base plymouth-themes poppler-utils ghostscript fonts-japanese-mincho | fonts-ipafont-mincho fonts-japanese-gothic
  | fonts-ipafont-gothic fonts-arphic-ukai fonts-arphic-uming fonts-nanum python-configobj-doc python-gtk2-doc gfortran python-numpy-doc python3-dev python3-nose python3-numpy-dbg
  python-pil-doc python3-pil-dbg python-polib-doc python-psutil-doc python-scipy-doc hexchat
Recommended packages:
  ghostscript libmagickcore-6.q16-2-extra netpbm libgnomevfs2-extra libimage-magick-perl libwmf-bin python-lxml python-numpy transfig dmidecode lm-sensors gsfonts libpaper-utils
  gstreamer1.0-plugins-base gstreamer1.0-plugins-good desktop-base gnome-icon-theme-symbolic dmz-cursor-theme plymouth-theme-ubuntu-text | plymouth-theme update-manager
  libfile-mimeinfo-perl libnet-dbus-perl libx11-protocol-perl
The following packages will be REMOVED:
  console-common
The following NEW packages will be installed:
  caja-extensions-common caja-gksu caja-open-terminal caja-sendto caja-wallpaper compton dconf-cli filezilla filezilla-common gawk gimp gimp-data gir1.2-javascriptcoregtk-3.0
  gir1.2-soup-2.4 gir1.2-webkit-3.0 gir1.2-wnck-1.0 imagemagick imagemagick-6.q16 imagemagick-common inkscape inxi libamd2.4.1 libbabl-0.1-0 libblas-common libblas3 libcamd2.4.1
  libccolamd2.9.1 libcdr-0.1-1 libcholmod3.0.6 libconfig9 libcupsfilters1 libcupsimage2 libfakekey0 libfilezilla0 libgc1c2 libgegl-0.3-0 libgfortran3 libgimp2.0 libgs9 libgs9-common
  libgsl2 libgssdp-1.0-3 libgtkspell0 libgupnp-1.0-4 libido3-0.1-0 libijs-0.35 libilmbase12 libjasper1 libjavascriptcoregtk-3.0-0 libjbig2dec0 liblapack3 liblightdm-gobject-1-0
  liblqr-1-0 libmagick++-6.q16-5v5 libmagickcore-6.q16-2 libmagickwand-6.q16-2 libmate-sensors-applet-plugin0 libnm-glib4 libnm-util2 libnotify-bin libopenexr22 libpaper1
  libplymouth4 libpoppler-glib8 libpoppler58 libpugixml1v5 libraw15 libumfpack5.7.1 libvisio-0.1-1 libwebkitgtk-3.0-0 libwebkitgtk-3.0-common libwebpmux1 libwmf0.2-7 light-themes
  lightdm lightdm-gtk-greeter lightdm-gtk-greeter-settings mate-dock-applet mate-gnome-main-menu-applet mate-icon-theme-faenza mate-indicator-applet mate-indicator-applet-common
  mate-menu mate-netbook mate-netbook-common mate-netspeed mate-netspeed-common mate-optimus mate-sensors-applet mate-sensors-applet-common mate-themes mate-tweak menu mesa-utils
  mozo plymouth poppler-data python-configobj python-glade2 python-gobject python-mate-menu python-six python-wnck python-xdg python-xlib python3-decorator python3-numpy python3-pil
  python3-polib python3-psutil python3-scipy python3-xdg ubuntu-mate-lightdm-theme ubuntu-mate-wallpapers ubuntu-mate-wallpapers-common ubuntu-mate-wallpapers-xenial
  ubuntu-mate-welcome xdg-utils
0 upgraded, 118 newly installed, 1 to remove and 18 not upgraded.
Need to get 126 MB of archives.
After this operation, 526 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com xenial/main arm64 gawk arm64 1:4.1.3+dfsg-0.1 [344 kB]
Get:2 http://ports.ubuntu.com xenial-security/main arm64 imagemagick-common all 8:6.8.9.9-7ubuntu5.6 [41.4 kB]
Get:3 http://ports.ubuntu.com xenial/universe arm64 libfakekey0 arm64 0.1-8.1 [5,768 B]
Get:4 http://ports.ubuntu.com xenial/main arm64 liblqr-1-0 arm64 0.4.2-2 [20.2 kB]
Get:5 http://ports.ubuntu.com xenial-security/main arm64 libmagickcore-6.q16-2 arm64 8:6.8.9.9-7ubuntu5.6 [1,344 kB]
Get:6 http://ports.ubuntu.com xenial-security/main arm64 libmagickwand-6.q16-2 arm64 8:6.8.9.9-7ubuntu5.6 [225 kB]
Get:7 http://ports.ubuntu.com xenial-updates/main arm64 libplymouth4 arm64 0.9.2-3ubuntu13.1 [68.9 kB]
Get:8 http://ports.ubuntu.com xenial-updates/main arm64 plymouth arm64 0.9.2-3ubuntu13.1 [94.6 kB]
Get:9 http://ports.ubuntu.com xenial-security/main arm64 lightdm arm64 1.18.3-0ubuntu1.1 [103 kB]
Get:10 http://ports.ubuntu.com xenial/main arm64 poppler-data all 0.4.7-7 [1,495 kB]
Get:11 http://ports.ubuntu.com xenial-updates/universe arm64 gir1.2-javascriptcoregtk-3.0 arm64 2.4.11-0ubuntu0.1 [12.7 kB]
Get:12 http://ports.ubuntu.com xenial-security/main arm64 gir1.2-soup-2.4 arm64 2.52.2-1ubuntu0.1 [24.7 kB]
Get:13 http://ports.ubuntu.com xenial-updates/universe arm64 libjavascriptcoregtk-3.0-0 arm64 2.4.11-0ubuntu0.1 [1,029 kB]
Get:14 http://ports.ubuntu.com xenial-updates/universe arm64 libwebkitgtk-3.0-common all 2.4.11-0ubuntu0.1 [367 kB]
Get:15 http://ports.ubuntu.com xenial-updates/universe arm64 libwebkitgtk-3.0-0 arm64 2.4.11-0ubuntu0.1 [6,191 kB]
Get:16 http://ports.ubuntu.com xenial-updates/universe arm64 gir1.2-webkit-3.0 arm64 2.4.11-0ubuntu0.1 [60.4 kB]
Get:17 http://ports.ubuntu.com xenial/universe arm64 inxi all 2.2.35-0ubuntu1 [126 kB]
Get:18 http://ports.ubuntu.com xenial/main arm64 libnotify-bin arm64 0.7.6-2svn1 [6,670 B]
Get:19 http://ports.ubuntu.com xenial/main arm64 python3-polib all 1.0.7-1 [19.8 kB]
Get:20 http://ports.ubuntu.com xenial-updates/universe arm64 ubuntu-mate-welcome all 16.04.9.1 [8,837 kB]
Get:21 http://ports.ubuntu.com xenial/universe arm64 caja-extensions-common all 1.12.0-1 [79.3 kB]
Get:22 http://ports.ubuntu.com xenial/universe arm64 caja-gksu arm64 1.12.0-1 [8,228 B]
Get:23 http://ports.ubuntu.com xenial/universe arm64 caja-open-terminal arm64 1.12.0-1 [10.6 kB]
Get:24 http://ports.ubuntu.com xenial/universe arm64 libgssdp-1.0-3 arm64 0.14.14-1ubuntu1 [24.7 kB]
Get:25 http://ports.ubuntu.com xenial/universe arm64 libgupnp-1.0-4 arm64 0.20.16-1 [58.1 kB]
Get:26 http://ports.ubuntu.com xenial/universe arm64 caja-sendto arm64 1.12.0-1 [40.7 kB]
Get:27 http://ports.ubuntu.com xenial/universe arm64 caja-wallpaper arm64 1.12.0-1 [7,598 B]
Get:28 http://ports.ubuntu.com xenial/main arm64 dconf-cli arm64 0.24.0-2 [21.7 kB]
Get:29 http://ports.ubuntu.com xenial/universe arm64 filezilla-common all 3.15.0.2-1ubuntu1 [2,036 kB]
Get:30 http://ports.ubuntu.com xenial/universe arm64 libfilezilla0 arm64 0.4.0.1-1 [29.2 kB]
Get:31 http://ports.ubuntu.com xenial/universe arm64 libpugixml1v5 arm64 1.7-2 [74.2 kB]
Get:32 http://ports.ubuntu.com xenial/universe arm64 filezilla arm64 3.15.0.2-1ubuntu1 [1,316 kB]
Get:33 http://ports.ubuntu.com xenial-security/universe arm64 libgimp2.0 arm64 2.8.16-1ubuntu1.1 [703 kB]
Get:34 http://ports.ubuntu.com xenial-security/universe arm64 gimp-data all 2.8.16-1ubuntu1.1 [7,712 kB]
Get:35 http://ports.ubuntu.com xenial/universe arm64 libbabl-0.1-0 arm64 0.1.16-1 [234 kB]
Get:36 http://ports.ubuntu.com xenial/main arm64 libjasper1 arm64 1.900.1-debian1-2.4ubuntu1 [110 kB]
Get:37 http://ports.ubuntu.com xenial/main arm64 libilmbase12 arm64 2.2.0-11ubuntu2 [77.2 kB]
Get:38 http://ports.ubuntu.com xenial/main arm64 libopenexr22 arm64 2.2.0-10ubuntu2 [549 kB]
Get:39 http://ports.ubuntu.com xenial/main arm64 libraw15 arm64 0.17.1-1 [215 kB]
Get:40 http://ports.ubuntu.com xenial/main arm64 libamd2.4.1 arm64 1:4.4.6-1 [18.9 kB]
Get:41 http://ports.ubuntu.com xenial/main arm64 libblas-common arm64 3.6.0-2ubuntu2 [5,338 B]
Get:42 http://ports.ubuntu.com xenial/main arm64 libblas3 arm64 3.6.0-2ubuntu2 [87.5 kB]
Get:43 http://ports.ubuntu.com xenial/main arm64 libcamd2.4.1 arm64 1:4.4.6-1 [17.2 kB]
Get:44 http://ports.ubuntu.com xenial/main arm64 libccolamd2.9.1 arm64 1:4.4.6-1 [18.8 kB]
Get:45 http://ports.ubuntu.com xenial-security/main arm64 libgfortran3 arm64 5.4.0-6ubuntu1~16.04.4 [190 kB]
Get:46 http://ports.ubuntu.com xenial/main arm64 liblapack3 arm64 3.6.0-2ubuntu2 [1,268 kB]
Get:47 http://ports.ubuntu.com xenial/main arm64 libcholmod3.0.6 arm64 1:4.4.6-1 [241 kB]
Get:48 http://ports.ubuntu.com xenial/main arm64 libumfpack5.7.1 arm64 1:4.4.6-1 [174 kB]
Get:49 http://ports.ubuntu.com xenial/universe arm64 libgegl-0.3-0 arm64 0.3.4-1ubuntu2 [901 kB]
Get:50 http://ports.ubuntu.com xenial-updates/main arm64 libcupsfilters1 arm64 1.8.3-2ubuntu3.1 [71.2 kB]
Get:51 http://ports.ubuntu.com xenial/main arm64 libcupsimage2 arm64 2.1.3-4 [14.3 kB]
Get:52 http://ports.ubuntu.com xenial/main arm64 libijs-0.35 arm64 0.35-12 [14.1 kB]
Get:53 http://ports.ubuntu.com xenial/main arm64 libjbig2dec0 arm64 0.12+20150918-1 [48.7 kB]
Get:54 http://ports.ubuntu.com xenial/main arm64 libpaper1 arm64 1.1.24+nmu4ubuntu1 [13.1 kB]
Get:55 http://ports.ubuntu.com xenial-security/main arm64 libgs9-common all 9.18~dfsg~0-0ubuntu2.3 [2,981 kB]
Get:56 http://ports.ubuntu.com xenial-security/main arm64 libgs9 arm64 9.18~dfsg~0-0ubuntu2.3 [1,711 kB]
Get:57 http://ports.ubuntu.com xenial-updates/main arm64 libpoppler58 arm64 0.41.0-0ubuntu1.1 [628 kB]
Get:58 http://ports.ubuntu.com xenial-updates/main arm64 libpoppler-glib8 arm64 0.41.0-0ubuntu1.1 [85.5 kB]
Get:59 http://ports.ubuntu.com xenial/main arm64 libwmf0.2-7 arm64 0.2.8.4-10.5ubuntu1 [123 kB]
Get:60 http://ports.ubuntu.com xenial-security/universe arm64 gimp arm64 2.8.16-1ubuntu1.1 [3,012 kB]
Get:61 http://ports.ubuntu.com xenial-updates/universe arm64 gir1.2-wnck-1.0 arm64 1:2.30.7-5ubuntu1.1 [33.0 kB]
Get:62 http://ports.ubuntu.com xenial-security/main arm64 imagemagick-6.q16 arm64 8:6.8.9.9-7ubuntu5.6 [388 kB]
Get:63 http://ports.ubuntu.com xenial-security/main arm64 imagemagick arm64 8:6.8.9.9-7ubuntu5.6 [44.9 kB]
Get:64 http://ports.ubuntu.com xenial/main arm64 libcdr-0.1-1 arm64 0.1.2-2ubuntu2 [328 kB]
Get:65 http://ports.ubuntu.com xenial-security/main arm64 libgc1c2 arm64 1:7.4.2-7.3ubuntu0.1 [70.9 kB]
Get:66 http://ports.ubuntu.com xenial/main arm64 libgsl2 arm64 2.1+dfsg-2 [691 kB]
Get:67 http://ports.ubuntu.com xenial/main arm64 libgtkspell0 arm64 2.0.16-1.1ubuntu1 [9,770 B]
Get:68 http://ports.ubuntu.com xenial-security/main arm64 libmagick++-6.q16-5v5 arm64 8:6.8.9.9-7ubuntu5.6 [131 kB]
Get:69 http://ports.ubuntu.com xenial/main arm64 libvisio-0.1-1 arm64 0.1.5-1ubuntu1 [179 kB]
Get:70 http://ports.ubuntu.com xenial/main arm64 inkscape arm64 0.91-7ubuntu2 [11.0 MB]
Get:71 http://ports.ubuntu.com xenial/universe arm64 libconfig9 arm64 1.5-0.2 [18.9 kB]
Get:72 http://ports.ubuntu.com xenial-updates/main arm64 libido3-0.1-0 arm64 13.10.0+16.04.20161028-0ubuntu1 [38.6 kB]
Get:73 http://ports.ubuntu.com xenial-security/main arm64 liblightdm-gobject-1-0 arm64 1.18.3-0ubuntu1.1 [29.6 kB]
Get:74 http://ports.ubuntu.com xenial/universe arm64 libmate-sensors-applet-plugin0 arm64 1.12.1-1 [6,820 B]
Get:75 http://ports.ubuntu.com xenial-updates/main arm64 libnm-util2 arm64 1.2.6-0ubuntu0.16.04.1 [97.5 kB]
Get:76 http://ports.ubuntu.com xenial-updates/main arm64 libnm-glib4 arm64 1.2.6-0ubuntu0.16.04.1 [66.8 kB]
Get:77 http://ports.ubuntu.com xenial-updates/main arm64 light-themes all 14.04+16.04.20161024-0ubuntu1 [153 kB]
Get:78 http://ports.ubuntu.com xenial/universe arm64 lightdm-gtk-greeter arm64 2.0.1-2ubuntu4 [73.7 kB]
Get:79 http://ports.ubuntu.com xenial/universe arm64 lightdm-gtk-greeter-settings all 1.2.1-0ubuntu1 [85.5 kB]
Get:80 http://ports.ubuntu.com xenial/universe arm64 mate-gnome-main-menu-applet arm64 1.8.0-5build1 [162 kB]
Get:81 http://ports.ubuntu.com xenial/universe arm64 mate-icon-theme-faenza all 1.12.0+dfsg1-1 [18.7 MB]
Get:82 http://ports.ubuntu.com xenial/universe arm64 mate-indicator-applet-common all 1.12.1-1 [64.5 kB]
Get:83 http://ports.ubuntu.com xenial/universe arm64 mate-indicator-applet arm64 1.12.1-1 [28.4 kB]
Get:84 http://ports.ubuntu.com xenial/universe arm64 python-gobject all 3.20.0-0ubuntu1 [2,544 B]
Get:85 http://ports.ubuntu.com xenial/universe arm64 python-mate-menu arm64 1.12.0-1 [12.7 kB]
Get:86 http://ports.ubuntu.com xenial/universe arm64 mozo all 1.12.0-1 [74.4 kB]
Get:87 http://ports.ubuntu.com xenial/main arm64 python-six all 1.10.0-3 [10.9 kB]
Get:88 http://ports.ubuntu.com xenial/main arm64 python-configobj all 5.0.6-2 [34.2 kB]
Get:89 http://ports.ubuntu.com xenial/main arm64 python-glade2 arm64 2.24.0-4ubuntu1 [7,892 B]
Get:90 http://ports.ubuntu.com xenial/universe arm64 python-xdg all 0.25-4 [31.4 kB]
Get:91 http://ports.ubuntu.com xenial/universe arm64 python-xlib all 0.14+20091101-5 [101 kB]
Get:92 http://ports.ubuntu.com xenial-updates/main arm64 xdg-utils all 1.1.1-1ubuntu1.16.04.1 [59.7 kB]
Get:93 http://ports.ubuntu.com xenial/universe arm64 mate-menu all 5.7.1-1 [170 kB]
Get:94 http://ports.ubuntu.com xenial/universe arm64 mate-netbook-common all 1.12.0-1 [19.5 kB]
Get:95 http://ports.ubuntu.com xenial/universe arm64 mate-netbook arm64 1.12.0-1 [27.5 kB]
Get:96 http://ports.ubuntu.com xenial/universe arm64 mate-netspeed-common all 1.12.0-1 [266 kB]
Get:97 http://ports.ubuntu.com xenial/universe arm64 mate-netspeed arm64 1.12.0-1 [25.0 kB]
Get:98 http://ports.ubuntu.com xenial/universe arm64 mate-optimus all 1.0.0-1 [8,026 B]
Get:99 http://ports.ubuntu.com xenial/universe arm64 mate-sensors-applet-common all 1.12.1-1 [74.2 kB]
Get:100 http://ports.ubuntu.com xenial/universe arm64 mate-sensors-applet arm64 1.12.1-1 [41.2 kB]
Get:101 http://ports.ubuntu.com xenial/universe arm64 mate-themes all 1.12.2+gtk3.18-1 [4,119 kB]
Get:102 http://ports.ubuntu.com xenial/universe arm64 compton arm64 0.1~beta2-1 [93.5 kB]
Get:103 http://ports.ubuntu.com xenial/universe arm64 mesa-utils arm64 8.3.0-1 [29.1 kB]
Get:104 http://ports.ubuntu.com xenial/main arm64 python3-psutil arm64 3.4.2-1 [54.3 kB]
Get:105 http://ports.ubuntu.com xenial/universe arm64 mate-tweak all 3.5.10-1 [87.3 kB]
Get:106 http://ports.ubuntu.com xenial/universe arm64 menu arm64 2.1.47ubuntu1 [345 kB]
Get:107 http://ports.ubuntu.com xenial/universe arm64 python-wnck arm64 2.32.0+dfsg-3 [19.7 kB]
Get:108 http://ports.ubuntu.com xenial/universe arm64 python3-decorator all 4.0.6-1 [9,388 B]
Get:109 http://ports.ubuntu.com xenial/main arm64 python3-numpy arm64 1:1.11.0-1ubuntu1 [1,590 kB]
Get:110 http://ports.ubuntu.com xenial/main arm64 libwebpmux1 arm64 0.4.4-1 [13.0 kB]
Get:111 http://ports.ubuntu.com xenial-security/main arm64 python3-pil arm64 3.1.2-0ubuntu1.1 [287 kB]
Get:112 http://ports.ubuntu.com xenial/main arm64 python3-xdg all 0.25-4 [31.5 kB]
Get:113 http://ports.ubuntu.com xenial-updates/universe arm64 ubuntu-mate-wallpapers-common all 16.04.7 [11.0 MB]
Get:114 http://ports.ubuntu.com xenial-updates/universe arm64 ubuntu-mate-wallpapers-xenial all 16.04.7 [21.5 MB]
Get:115 http://ports.ubuntu.com xenial-updates/universe arm64 ubuntu-mate-wallpapers all 16.04.7 [12.1 kB]
Get:116 http://ports.ubuntu.com xenial-updates/universe arm64 ubuntu-mate-lightdm-theme all 16.04.7 [13.0 kB]
Get:117 http://ports.ubuntu.com xenial/universe arm64 python3-scipy arm64 0.17.0-1 [7,690 kB]
Get:118 http://ports.ubuntu.com xenial/universe arm64 mate-dock-applet arm64 0.70-1build1 [43.7 kB]
Fetched 126 MB in 2h 20min 19s (14.9 kB/s)
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 171643 files and directories currently installed.)
Removing console-common (0.7.89) ...
Processing triggers for man-db (2.7.5-1) ...
Selecting previously unselected package gawk.
(Reading database ... 171585 files and directories currently installed.)
Preparing to unpack .../gawk_1%3a4.1.3+dfsg-0.1_arm64.deb ...
Unpacking gawk (1:4.1.3+dfsg-0.1) ...
Selecting previously unselected package imagemagick-common.
Preparing to unpack .../imagemagick-common_8%3a6.8.9.9-7ubuntu5.6_all.deb ...
Unpacking imagemagick-common (8:6.8.9.9-7ubuntu5.6) ...
Selecting previously unselected package libfakekey0:arm64.
Preparing to unpack .../libfakekey0_0.1-8.1_arm64.deb ...
Unpacking libfakekey0:arm64 (0.1-8.1) ...
Selecting previously unselected package liblqr-1-0:arm64.
Preparing to unpack .../liblqr-1-0_0.4.2-2_arm64.deb ...
Unpacking liblqr-1-0:arm64 (0.4.2-2) ...
Selecting previously unselected package libmagickcore-6.q16-2:arm64.
Preparing to unpack .../libmagickcore-6.q16-2_8%3a6.8.9.9-7ubuntu5.6_arm64.deb ...
Unpacking libmagickcore-6.q16-2:arm64 (8:6.8.9.9-7ubuntu5.6) ...
Selecting previously unselected package libmagickwand-6.q16-2:arm64.
Preparing to unpack .../libmagickwand-6.q16-2_8%3a6.8.9.9-7ubuntu5.6_arm64.deb ...
Unpacking libmagickwand-6.q16-2:arm64 (8:6.8.9.9-7ubuntu5.6) ...
Selecting previously unselected package libplymouth4:arm64.
Preparing to unpack .../libplymouth4_0.9.2-3ubuntu13.1_arm64.deb ...
Unpacking libplymouth4:arm64 (0.9.2-3ubuntu13.1) ...
Selecting previously unselected package plymouth.
Preparing to unpack .../plymouth_0.9.2-3ubuntu13.1_arm64.deb ...
Unpacking plymouth (0.9.2-3ubuntu13.1) ...
Selecting previously unselected package lightdm.
Preparing to unpack .../lightdm_1.18.3-0ubuntu1.1_arm64.deb ...
Unpacking lightdm (1.18.3-0ubuntu1.1) ...
Selecting previously unselected package poppler-data.
Preparing to unpack .../poppler-data_0.4.7-7_all.deb ...
Unpacking poppler-data (0.4.7-7) ...
Selecting previously unselected package gir1.2-javascriptcoregtk-3.0:arm64.
Preparing to unpack .../gir1.2-javascriptcoregtk-3.0_2.4.11-0ubuntu0.1_arm64.deb ...
Unpacking gir1.2-javascriptcoregtk-3.0:arm64 (2.4.11-0ubuntu0.1) ...
Selecting previously unselected package gir1.2-soup-2.4.
Preparing to unpack .../gir1.2-soup-2.4_2.52.2-1ubuntu0.1_arm64.deb ...
Unpacking gir1.2-soup-2.4 (2.52.2-1ubuntu0.1) ...
Selecting previously unselected package libjavascriptcoregtk-3.0-0:arm64.
Preparing to unpack .../libjavascriptcoregtk-3.0-0_2.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libjavascriptcoregtk-3.0-0:arm64 (2.4.11-0ubuntu0.1) ...
Selecting previously unselected package libwebkitgtk-3.0-common.
Preparing to unpack .../libwebkitgtk-3.0-common_2.4.11-0ubuntu0.1_all.deb ...
Unpacking libwebkitgtk-3.0-common (2.4.11-0ubuntu0.1) ...
Selecting previously unselected package libwebkitgtk-3.0-0:arm64.
Preparing to unpack .../libwebkitgtk-3.0-0_2.4.11-0ubuntu0.1_arm64.deb ...
Unpacking libwebkitgtk-3.0-0:arm64 (2.4.11-0ubuntu0.1) ...
Selecting previously unselected package gir1.2-webkit-3.0:arm64.
Preparing to unpack .../gir1.2-webkit-3.0_2.4.11-0ubuntu0.1_arm64.deb ...
Unpacking gir1.2-webkit-3.0:arm64 (2.4.11-0ubuntu0.1) ...
Selecting previously unselected package inxi.
Preparing to unpack .../inxi_2.2.35-0ubuntu1_all.deb ...
Unpacking inxi (2.2.35-0ubuntu1) ...
Selecting previously unselected package libnotify-bin.
Preparing to unpack .../libnotify-bin_0.7.6-2svn1_arm64.deb ...
Unpacking libnotify-bin (0.7.6-2svn1) ...
Selecting previously unselected package python3-polib.
Preparing to unpack .../python3-polib_1.0.7-1_all.deb ...
Unpacking python3-polib (1.0.7-1) ...
Selecting previously unselected package ubuntu-mate-welcome.
Preparing to unpack .../ubuntu-mate-welcome_16.04.9.1_all.deb ...
Unpacking ubuntu-mate-welcome (16.04.9.1) ...
Selecting previously unselected package caja-extensions-common.
Preparing to unpack .../caja-extensions-common_1.12.0-1_all.deb ...
Unpacking caja-extensions-common (1.12.0-1) ...
Selecting previously unselected package caja-gksu.
Preparing to unpack .../caja-gksu_1.12.0-1_arm64.deb ...
Unpacking caja-gksu (1.12.0-1) ...
Selecting previously unselected package caja-open-terminal.
Preparing to unpack .../caja-open-terminal_1.12.0-1_arm64.deb ...
Unpacking caja-open-terminal (1.12.0-1) ...
Selecting previously unselected package libgssdp-1.0-3:arm64.
Preparing to unpack .../libgssdp-1.0-3_0.14.14-1ubuntu1_arm64.deb ...
Unpacking libgssdp-1.0-3:arm64 (0.14.14-1ubuntu1) ...
Selecting previously unselected package libgupnp-1.0-4:arm64.
Preparing to unpack .../libgupnp-1.0-4_0.20.16-1_arm64.deb ...
Unpacking libgupnp-1.0-4:arm64 (0.20.16-1) ...
Selecting previously unselected package caja-sendto.
Preparing to unpack .../caja-sendto_1.12.0-1_arm64.deb ...
Unpacking caja-sendto (1.12.0-1) ...
Selecting previously unselected package caja-wallpaper.
Preparing to unpack .../caja-wallpaper_1.12.0-1_arm64.deb ...
Unpacking caja-wallpaper (1.12.0-1) ...
Selecting previously unselected package dconf-cli.
Preparing to unpack .../dconf-cli_0.24.0-2_arm64.deb ...
Unpacking dconf-cli (0.24.0-2) ...
Selecting previously unselected package filezilla-common.
Preparing to unpack .../filezilla-common_3.15.0.2-1ubuntu1_all.deb ...
Unpacking filezilla-common (3.15.0.2-1ubuntu1) ...
Selecting previously unselected package libfilezilla0.
Preparing to unpack .../libfilezilla0_0.4.0.1-1_arm64.deb ...
Unpacking libfilezilla0 (0.4.0.1-1) ...
Selecting previously unselected package libpugixml1v5:arm64.
Preparing to unpack .../libpugixml1v5_1.7-2_arm64.deb ...
Unpacking libpugixml1v5:arm64 (1.7-2) ...
Selecting previously unselected package filezilla.
Preparing to unpack .../filezilla_3.15.0.2-1ubuntu1_arm64.deb ...
Unpacking filezilla (3.15.0.2-1ubuntu1) ...
Selecting previously unselected package libgimp2.0.
Preparing to unpack .../libgimp2.0_2.8.16-1ubuntu1.1_arm64.deb ...
Unpacking libgimp2.0 (2.8.16-1ubuntu1.1) ...
Selecting previously unselected package gimp-data.
Preparing to unpack .../gimp-data_2.8.16-1ubuntu1.1_all.deb ...
Unpacking gimp-data (2.8.16-1ubuntu1.1) ...
Selecting previously unselected package libbabl-0.1-0:arm64.
Preparing to unpack .../libbabl-0.1-0_0.1.16-1_arm64.deb ...
Unpacking libbabl-0.1-0:arm64 (0.1.16-1) ...
Selecting previously unselected package libjasper1:arm64.
Preparing to unpack .../libjasper1_1.900.1-debian1-2.4ubuntu1_arm64.deb ...
Unpacking libjasper1:arm64 (1.900.1-debian1-2.4ubuntu1) ...
Selecting previously unselected package libilmbase12:arm64.
Preparing to unpack .../libilmbase12_2.2.0-11ubuntu2_arm64.deb ...
Unpacking libilmbase12:arm64 (2.2.0-11ubuntu2) ...
Selecting previously unselected package libopenexr22:arm64.
Preparing to unpack .../libopenexr22_2.2.0-10ubuntu2_arm64.deb ...
Unpacking libopenexr22:arm64 (2.2.0-10ubuntu2) ...
Selecting previously unselected package libraw15:arm64.
Preparing to unpack .../libraw15_0.17.1-1_arm64.deb ...
Unpacking libraw15:arm64 (0.17.1-1) ...
Selecting previously unselected package libamd2.4.1:arm64.
Preparing to unpack .../libamd2.4.1_1%3a4.4.6-1_arm64.deb ...
Unpacking libamd2.4.1:arm64 (1:4.4.6-1) ...
Selecting previously unselected package libblas-common.
Preparing to unpack .../libblas-common_3.6.0-2ubuntu2_arm64.deb ...
Unpacking libblas-common (3.6.0-2ubuntu2) ...
Selecting previously unselected package libblas3.
Preparing to unpack .../libblas3_3.6.0-2ubuntu2_arm64.deb ...
Unpacking libblas3 (3.6.0-2ubuntu2) ...
Selecting previously unselected package libcamd2.4.1:arm64.
Preparing to unpack .../libcamd2.4.1_1%3a4.4.6-1_arm64.deb ...
Unpacking libcamd2.4.1:arm64 (1:4.4.6-1) ...
Selecting previously unselected package libccolamd2.9.1:arm64.
Preparing to unpack .../libccolamd2.9.1_1%3a4.4.6-1_arm64.deb ...
Unpacking libccolamd2.9.1:arm64 (1:4.4.6-1) ...
Selecting previously unselected package libgfortran3:arm64.
Preparing to unpack .../libgfortran3_5.4.0-6ubuntu1~16.04.4_arm64.deb ...
Unpacking libgfortran3:arm64 (5.4.0-6ubuntu1~16.04.4) ...
Selecting previously unselected package liblapack3.
Preparing to unpack .../liblapack3_3.6.0-2ubuntu2_arm64.deb ...
Unpacking liblapack3 (3.6.0-2ubuntu2) ...
Selecting previously unselected package libcholmod3.0.6:arm64.
Preparing to unpack .../libcholmod3.0.6_1%3a4.4.6-1_arm64.deb ...
Unpacking libcholmod3.0.6:arm64 (1:4.4.6-1) ...
Selecting previously unselected package libumfpack5.7.1:arm64.
Preparing to unpack .../libumfpack5.7.1_1%3a4.4.6-1_arm64.deb ...
Unpacking libumfpack5.7.1:arm64 (1:4.4.6-1) ...
Selecting previously unselected package libgegl-0.3-0:arm64.
Preparing to unpack .../libgegl-0.3-0_0.3.4-1ubuntu2_arm64.deb ...
Unpacking libgegl-0.3-0:arm64 (0.3.4-1ubuntu2) ...
Selecting previously unselected package libcupsfilters1:arm64.
Preparing to unpack .../libcupsfilters1_1.8.3-2ubuntu3.1_arm64.deb ...
Unpacking libcupsfilters1:arm64 (1.8.3-2ubuntu3.1) ...
Selecting previously unselected package libcupsimage2:arm64.
Preparing to unpack .../libcupsimage2_2.1.3-4_arm64.deb ...
Unpacking libcupsimage2:arm64 (2.1.3-4) ...
Selecting previously unselected package libijs-0.35:arm64.
Preparing to unpack .../libijs-0.35_0.35-12_arm64.deb ...
Unpacking libijs-0.35:arm64 (0.35-12) ...
Selecting previously unselected package libjbig2dec0.
Preparing to unpack .../libjbig2dec0_0.12+20150918-1_arm64.deb ...
Unpacking libjbig2dec0 (0.12+20150918-1) ...
Selecting previously unselected package libpaper1:arm64.
Preparing to unpack .../libpaper1_1.1.24+nmu4ubuntu1_arm64.deb ...
Unpacking libpaper1:arm64 (1.1.24+nmu4ubuntu1) ...
Selecting previously unselected package libgs9-common.
Preparing to unpack .../libgs9-common_9.18~dfsg~0-0ubuntu2.3_all.deb ...
Unpacking libgs9-common (9.18~dfsg~0-0ubuntu2.3) ...
Selecting previously unselected package libgs9:arm64.
Preparing to unpack .../libgs9_9.18~dfsg~0-0ubuntu2.3_arm64.deb ...
Unpacking libgs9:arm64 (9.18~dfsg~0-0ubuntu2.3) ...
Selecting previously unselected package libpoppler58:arm64.
Preparing to unpack .../libpoppler58_0.41.0-0ubuntu1.1_arm64.deb ...
Unpacking libpoppler58:arm64 (0.41.0-0ubuntu1.1) ...
Selecting previously unselected package libpoppler-glib8:arm64.
Preparing to unpack .../libpoppler-glib8_0.41.0-0ubuntu1.1_arm64.deb ...
Unpacking libpoppler-glib8:arm64 (0.41.0-0ubuntu1.1) ...
Selecting previously unselected package libwmf0.2-7:arm64.
Preparing to unpack .../libwmf0.2-7_0.2.8.4-10.5ubuntu1_arm64.deb ...
Unpacking libwmf0.2-7:arm64 (0.2.8.4-10.5ubuntu1) ...
Selecting previously unselected package gimp.
Preparing to unpack .../gimp_2.8.16-1ubuntu1.1_arm64.deb ...
Unpacking gimp (2.8.16-1ubuntu1.1) ...
Selecting previously unselected package gir1.2-wnck-1.0.
Preparing to unpack .../gir1.2-wnck-1.0_1%3a2.30.7-5ubuntu1.1_arm64.deb ...
Unpacking gir1.2-wnck-1.0 (1:2.30.7-5ubuntu1.1) ...
Selecting previously unselected package imagemagick-6.q16.
Preparing to unpack .../imagemagick-6.q16_8%3a6.8.9.9-7ubuntu5.6_arm64.deb ...
Unpacking imagemagick-6.q16 (8:6.8.9.9-7ubuntu5.6) ...
Selecting previously unselected package imagemagick.
Preparing to unpack .../imagemagick_8%3a6.8.9.9-7ubuntu5.6_arm64.deb ...
Unpacking imagemagick (8:6.8.9.9-7ubuntu5.6) ...
Selecting previously unselected package libcdr-0.1-1:arm64.
Preparing to unpack .../libcdr-0.1-1_0.1.2-2ubuntu2_arm64.deb ...
Unpacking libcdr-0.1-1:arm64 (0.1.2-2ubuntu2) ...
Selecting previously unselected package libgc1c2:arm64.
Preparing to unpack .../libgc1c2_1%3a7.4.2-7.3ubuntu0.1_arm64.deb ...
Unpacking libgc1c2:arm64 (1:7.4.2-7.3ubuntu0.1) ...
Selecting previously unselected package libgsl2:arm64.
Preparing to unpack .../libgsl2_2.1+dfsg-2_arm64.deb ...
Unpacking libgsl2:arm64 (2.1+dfsg-2) ...
Selecting previously unselected package libgtkspell0.
Preparing to unpack .../libgtkspell0_2.0.16-1.1ubuntu1_arm64.deb ...
Unpacking libgtkspell0 (2.0.16-1.1ubuntu1) ...
Selecting previously unselected package libmagick++-6.q16-5v5:arm64.
Preparing to unpack .../libmagick++-6.q16-5v5_8%3a6.8.9.9-7ubuntu5.6_arm64.deb ...
Unpacking libmagick++-6.q16-5v5:arm64 (8:6.8.9.9-7ubuntu5.6) ...
Selecting previously unselected package libvisio-0.1-1:arm64.
Preparing to unpack .../libvisio-0.1-1_0.1.5-1ubuntu1_arm64.deb ...
Unpacking libvisio-0.1-1:arm64 (0.1.5-1ubuntu1) ...
Selecting previously unselected package inkscape.
Preparing to unpack .../inkscape_0.91-7ubuntu2_arm64.deb ...
Unpacking inkscape (0.91-7ubuntu2) ...
Selecting previously unselected package libconfig9:arm64.
Preparing to unpack .../libconfig9_1.5-0.2_arm64.deb ...
Unpacking libconfig9:arm64 (1.5-0.2) ...
Selecting previously unselected package libido3-0.1-0:arm64.
Preparing to unpack .../libido3-0.1-0_13.10.0+16.04.20161028-0ubuntu1_arm64.deb ...
Unpacking libido3-0.1-0:arm64 (13.10.0+16.04.20161028-0ubuntu1) ...
Selecting previously unselected package liblightdm-gobject-1-0:arm64.
Preparing to unpack .../liblightdm-gobject-1-0_1.18.3-0ubuntu1.1_arm64.deb ...
Unpacking liblightdm-gobject-1-0:arm64 (1.18.3-0ubuntu1.1) ...
Selecting previously unselected package libmate-sensors-applet-plugin0.
Preparing to unpack .../libmate-sensors-applet-plugin0_1.12.1-1_arm64.deb ...
Unpacking libmate-sensors-applet-plugin0 (1.12.1-1) ...
Selecting previously unselected package libnm-util2:arm64.
Preparing to unpack .../libnm-util2_1.2.6-0ubuntu0.16.04.1_arm64.deb ...
Unpacking libnm-util2:arm64 (1.2.6-0ubuntu0.16.04.1) ...
Selecting previously unselected package libnm-glib4:arm64.
Preparing to unpack .../libnm-glib4_1.2.6-0ubuntu0.16.04.1_arm64.deb ...
Unpacking libnm-glib4:arm64 (1.2.6-0ubuntu0.16.04.1) ...
Selecting previously unselected package light-themes.
Preparing to unpack .../light-themes_14.04+16.04.20161024-0ubuntu1_all.deb ...
Unpacking light-themes (14.04+16.04.20161024-0ubuntu1) ...
Selecting previously unselected package lightdm-gtk-greeter.
Preparing to unpack .../lightdm-gtk-greeter_2.0.1-2ubuntu4_arm64.deb ...
Unpacking lightdm-gtk-greeter (2.0.1-2ubuntu4) ...
Selecting previously unselected package lightdm-gtk-greeter-settings.
Preparing to unpack .../lightdm-gtk-greeter-settings_1.2.1-0ubuntu1_all.deb ...
Unpacking lightdm-gtk-greeter-settings (1.2.1-0ubuntu1) ...
Selecting previously unselected package mate-gnome-main-menu-applet.
Preparing to unpack .../mate-gnome-main-menu-applet_1.8.0-5build1_arm64.deb ...
Unpacking mate-gnome-main-menu-applet (1.8.0-5build1) ...
Selecting previously unselected package mate-icon-theme-faenza.
Preparing to unpack .../mate-icon-theme-faenza_1.12.0+dfsg1-1_all.deb ...
Unpacking mate-icon-theme-faenza (1.12.0+dfsg1-1) ...
Selecting previously unselected package mate-indicator-applet-common.
Preparing to unpack .../mate-indicator-applet-common_1.12.1-1_all.deb ...
Unpacking mate-indicator-applet-common (1.12.1-1) ...
Selecting previously unselected package mate-indicator-applet.
Preparing to unpack .../mate-indicator-applet_1.12.1-1_arm64.deb ...
Unpacking mate-indicator-applet (1.12.1-1) ...
Selecting previously unselected package python-gobject.
Preparing to unpack .../python-gobject_3.20.0-0ubuntu1_all.deb ...
Unpacking python-gobject (3.20.0-0ubuntu1) ...
Selecting previously unselected package python-mate-menu.
Preparing to unpack .../python-mate-menu_1.12.0-1_arm64.deb ...
Unpacking python-mate-menu (1.12.0-1) ...
Selecting previously unselected package mozo.
Preparing to unpack .../archives/mozo_1.12.0-1_all.deb ...
Unpacking mozo (1.12.0-1) ...
Selecting previously unselected package python-six.
Preparing to unpack .../python-six_1.10.0-3_all.deb ...
Unpacking python-six (1.10.0-3) ...
Selecting previously unselected package python-configobj.
Preparing to unpack .../python-configobj_5.0.6-2_all.deb ...
Unpacking python-configobj (5.0.6-2) ...
Selecting previously unselected package python-glade2.
Preparing to unpack .../python-glade2_2.24.0-4ubuntu1_arm64.deb ...
Unpacking python-glade2 (2.24.0-4ubuntu1) ...
Selecting previously unselected package python-xdg.
Preparing to unpack .../python-xdg_0.25-4_all.deb ...
Unpacking python-xdg (0.25-4) ...
Selecting previously unselected package python-xlib.
Preparing to unpack .../python-xlib_0.14+20091101-5_all.deb ...
Unpacking python-xlib (0.14+20091101-5) ...
Selecting previously unselected package xdg-utils.
Preparing to unpack .../xdg-utils_1.1.1-1ubuntu1.16.04.1_all.deb ...
Unpacking xdg-utils (1.1.1-1ubuntu1.16.04.1) ...
Selecting previously unselected package mate-menu.
Preparing to unpack .../mate-menu_5.7.1-1_all.deb ...
Unpacking mate-menu (5.7.1-1) ...
Selecting previously unselected package mate-netbook-common.
Preparing to unpack .../mate-netbook-common_1.12.0-1_all.deb ...
Unpacking mate-netbook-common (1.12.0-1) ...
Selecting previously unselected package mate-netbook.
Preparing to unpack .../mate-netbook_1.12.0-1_arm64.deb ...
Unpacking mate-netbook (1.12.0-1) ...
Selecting previously unselected package mate-netspeed-common.
Preparing to unpack .../mate-netspeed-common_1.12.0-1_all.deb ...
Unpacking mate-netspeed-common (1.12.0-1) ...
Selecting previously unselected package mate-netspeed.
Preparing to unpack .../mate-netspeed_1.12.0-1_arm64.deb ...
Unpacking mate-netspeed (1.12.0-1) ...
Selecting previously unselected package mate-optimus.
Preparing to unpack .../mate-optimus_1.0.0-1_all.deb ...
Unpacking mate-optimus (1.0.0-1) ...
Selecting previously unselected package mate-sensors-applet-common.
Preparing to unpack .../mate-sensors-applet-common_1.12.1-1_all.deb ...
Unpacking mate-sensors-applet-common (1.12.1-1) ...
Selecting previously unselected package mate-sensors-applet.
Preparing to unpack .../mate-sensors-applet_1.12.1-1_arm64.deb ...
Unpacking mate-sensors-applet (1.12.1-1) ...
Selecting previously unselected package mate-themes.
Preparing to unpack .../mate-themes_1.12.2+gtk3.18-1_all.deb ...
Unpacking mate-themes (1.12.2+gtk3.18-1) ...
Selecting previously unselected package compton.
Preparing to unpack .../compton_0.1~beta2-1_arm64.deb ...
Unpacking compton (0.1~beta2-1) ...
Selecting previously unselected package mesa-utils.
Preparing to unpack .../mesa-utils_8.3.0-1_arm64.deb ...
Unpacking mesa-utils (8.3.0-1) ...
Selecting previously unselected package python3-psutil.
Preparing to unpack .../python3-psutil_3.4.2-1_arm64.deb ...
Unpacking python3-psutil (3.4.2-1) ...
Selecting previously unselected package mate-tweak.
Preparing to unpack .../mate-tweak_3.5.10-1_all.deb ...
Unpacking mate-tweak (3.5.10-1) ...
Selecting previously unselected package menu.
Preparing to unpack .../menu_2.1.47ubuntu1_arm64.deb ...
Unpacking menu (2.1.47ubuntu1) ...
Selecting previously unselected package python-wnck.
Preparing to unpack .../python-wnck_2.32.0+dfsg-3_arm64.deb ...
Unpacking python-wnck (2.32.0+dfsg-3) ...
Selecting previously unselected package python3-decorator.
Preparing to unpack .../python3-decorator_4.0.6-1_all.deb ...
Unpacking python3-decorator (4.0.6-1) ...
Selecting previously unselected package python3-numpy.
Preparing to unpack .../python3-numpy_1%3a1.11.0-1ubuntu1_arm64.deb ...
Unpacking python3-numpy (1:1.11.0-1ubuntu1) ...
Selecting previously unselected package libwebpmux1:arm64.
Preparing to unpack .../libwebpmux1_0.4.4-1_arm64.deb ...
Unpacking libwebpmux1:arm64 (0.4.4-1) ...
Selecting previously unselected package python3-pil:arm64.
Preparing to unpack .../python3-pil_3.1.2-0ubuntu1.1_arm64.deb ...
Unpacking python3-pil:arm64 (3.1.2-0ubuntu1.1) ...
Selecting previously unselected package python3-xdg.
Preparing to unpack .../python3-xdg_0.25-4_all.deb ...
Unpacking python3-xdg (0.25-4) ...
Selecting previously unselected package ubuntu-mate-wallpapers-common.
Preparing to unpack .../ubuntu-mate-wallpapers-common_16.04.7_all.deb ...
Unpacking ubuntu-mate-wallpapers-common (16.04.7) ...
Selecting previously unselected package ubuntu-mate-wallpapers-xenial.
Preparing to unpack .../ubuntu-mate-wallpapers-xenial_16.04.7_all.deb ...
Unpacking ubuntu-mate-wallpapers-xenial (16.04.7) ...
Selecting previously unselected package ubuntu-mate-wallpapers.
Preparing to unpack .../ubuntu-mate-wallpapers_16.04.7_all.deb ...
Unpacking ubuntu-mate-wallpapers (16.04.7) ...
Selecting previously unselected package ubuntu-mate-lightdm-theme.
Preparing to unpack .../ubuntu-mate-lightdm-theme_16.04.7_all.deb ...
Unpacking ubuntu-mate-lightdm-theme (16.04.7) ...
Selecting previously unselected package python3-scipy.
Preparing to unpack .../python3-scipy_0.17.0-1_arm64.deb ...
Unpacking python3-scipy (0.17.0-1) ...
Selecting previously unselected package mate-dock-applet.
Preparing to unpack .../mate-dock-applet_0.70-1build1_arm64.deb ...
Unpacking mate-dock-applet (0.70-1build1) ...
Processing triggers for fontconfig (2.11.94-0ubuntu1.1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for libglib2.0-0:armhf (2.48.2-0ubuntu1) ...
Processing triggers for libglib2.0-0:arm64 (2.48.2-0ubuntu1) ...
Processing triggers for mate-icon-theme (1.12.0-1) ...
Setting up gawk (1:4.1.3+dfsg-0.1) ...
Setting up imagemagick-common (8:6.8.9.9-7ubuntu5.6) ...
Setting up libfakekey0:arm64 (0.1-8.1) ...
Setting up liblqr-1-0:arm64 (0.4.2-2) ...
Setting up libmagickcore-6.q16-2:arm64 (8:6.8.9.9-7ubuntu5.6) ...
Setting up libmagickwand-6.q16-2:arm64 (8:6.8.9.9-7ubuntu5.6) ...
Setting up libplymouth4:arm64 (0.9.2-3ubuntu13.1) ...
Setting up plymouth (0.9.2-3ubuntu13.1) ...
update-initramfs: deferring update (trigger activated)
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Setting up lightdm (1.18.3-0ubuntu1.1) ...
Adding group `lightdm' (GID 118) ...
Done.
Adding system user `lightdm' (UID 112) ...
Adding new user `lightdm' (UID 112) with group `lightdm' ...
Creating home directory `/var/lib/lightdm' ...
usermod: no changes
usermod: no changes
usermod: no changes
Adding group `nopasswdlogin' (GID 119) ...
Done.
Setting up poppler-data (0.4.7-7) ...
Setting up gir1.2-javascriptcoregtk-3.0:arm64 (2.4.11-0ubuntu0.1) ...
Setting up gir1.2-soup-2.4 (2.52.2-1ubuntu0.1) ...
Setting up libjavascriptcoregtk-3.0-0:arm64 (2.4.11-0ubuntu0.1) ...
Setting up libwebkitgtk-3.0-common (2.4.11-0ubuntu0.1) ...
Setting up libwebkitgtk-3.0-0:arm64 (2.4.11-0ubuntu0.1) ...
Setting up gir1.2-webkit-3.0:arm64 (2.4.11-0ubuntu0.1) ...
Setting up inxi (2.2.35-0ubuntu1) ...
Setting up libnotify-bin (0.7.6-2svn1) ...
Setting up python3-polib (1.0.7-1) ...
Setting up ubuntu-mate-welcome (16.04.9.1) ...
Setting up caja-extensions-common (1.12.0-1) ...
Setting up caja-gksu (1.12.0-1) ...
Setting up caja-open-terminal (1.12.0-1) ...
Setting up libgssdp-1.0-3:arm64 (0.14.14-1ubuntu1) ...
Setting up libgupnp-1.0-4:arm64 (0.20.16-1) ...
Setting up caja-sendto (1.12.0-1) ...
Setting up caja-wallpaper (1.12.0-1) ...
Setting up dconf-cli (0.24.0-2) ...
Setting up filezilla-common (3.15.0.2-1ubuntu1) ...
Setting up libfilezilla0 (0.4.0.1-1) ...
Setting up libpugixml1v5:arm64 (1.7-2) ...
Setting up filezilla (3.15.0.2-1ubuntu1) ...
Setting up libgimp2.0 (2.8.16-1ubuntu1.1) ...
Setting up gimp-data (2.8.16-1ubuntu1.1) ...
Setting up libbabl-0.1-0:arm64 (0.1.16-1) ...
Setting up libjasper1:arm64 (1.900.1-debian1-2.4ubuntu1) ...
Setting up libilmbase12:arm64 (2.2.0-11ubuntu2) ...
Setting up libopenexr22:arm64 (2.2.0-10ubuntu2) ...
Setting up libraw15:arm64 (0.17.1-1) ...
Setting up libamd2.4.1:arm64 (1:4.4.6-1) ...
Setting up libblas-common (3.6.0-2ubuntu2) ...
Setting up libblas3 (3.6.0-2ubuntu2) ...
update-alternatives: using /usr/lib/libblas/libblas.so.3 to provide /usr/lib/libblas.so.3 (libblas.so.3) in auto mode
Setting up libcamd2.4.1:arm64 (1:4.4.6-1) ...
Setting up libccolamd2.9.1:arm64 (1:4.4.6-1) ...
Setting up libgfortran3:arm64 (5.4.0-6ubuntu1~16.04.4) ...
Setting up liblapack3 (3.6.0-2ubuntu2) ...
update-alternatives: using /usr/lib/lapack/liblapack.so.3 to provide /usr/lib/liblapack.so.3 (liblapack.so.3) in auto mode
Setting up libcholmod3.0.6:arm64 (1:4.4.6-1) ...
Setting up libumfpack5.7.1:arm64 (1:4.4.6-1) ...
Setting up libgegl-0.3-0:arm64 (0.3.4-1ubuntu2) ...
Setting up libcupsfilters1:arm64 (1.8.3-2ubuntu3.1) ...
Setting up libcupsimage2:arm64 (2.1.3-4) ...
Setting up libijs-0.35:arm64 (0.35-12) ...
Setting up libjbig2dec0 (0.12+20150918-1) ...
Setting up libpaper1:arm64 (1.1.24+nmu4ubuntu1) ...
Creating config file /etc/papersize with new version
Setting up libgs9-common (9.18~dfsg~0-0ubuntu2.3) ...
update-alternatives: using /usr/share/ghostscript/9.18 to provide /usr/share/ghostscript/current (ghostscript-current) in auto mode
Setting up libgs9:arm64 (9.18~dfsg~0-0ubuntu2.3) ...
Setting up libpoppler58:arm64 (0.41.0-0ubuntu1.1) ...
Setting up libpoppler-glib8:arm64 (0.41.0-0ubuntu1.1) ...
Setting up libwmf0.2-7:arm64 (0.2.8.4-10.5ubuntu1) ...
Setting up gimp (2.8.16-1ubuntu1.1) ...
Setting up gir1.2-wnck-1.0 (1:2.30.7-5ubuntu1.1) ...
Setting up imagemagick-6.q16 (8:6.8.9.9-7ubuntu5.6) ...
Setting up imagemagick (8:6.8.9.9-7ubuntu5.6) ...
update-alternatives: using /usr/bin/compare-im6 to provide /usr/bin/compare (compare) in auto mode
update-alternatives: using /usr/bin/animate-im6 to provide /usr/bin/animate (animate) in auto mode
update-alternatives: using /usr/bin/convert-im6 to provide /usr/bin/convert (convert) in auto mode
update-alternatives: using /usr/bin/composite-im6 to provide /usr/bin/composite (composite) in auto mode
update-alternatives: using /usr/bin/conjure-im6 to provide /usr/bin/conjure (conjure) in auto mode
update-alternatives: using /usr/bin/import-im6 to provide /usr/bin/import (import) in auto mode
update-alternatives: using /usr/bin/identify-im6 to provide /usr/bin/identify (identify) in auto mode
update-alternatives: using /usr/bin/stream-im6 to provide /usr/bin/stream (stream) in auto mode
update-alternatives: using /usr/bin/display-im6 to provide /usr/bin/display (display) in auto mode
update-alternatives: using /usr/bin/montage-im6 to provide /usr/bin/montage (montage) in auto mode
update-alternatives: using /usr/bin/mogrify-im6 to provide /usr/bin/mogrify (mogrify) in auto mode
Setting up libcdr-0.1-1:arm64 (0.1.2-2ubuntu2) ...
Setting up libgc1c2:arm64 (1:7.4.2-7.3ubuntu0.1) ...
Setting up libgsl2:arm64 (2.1+dfsg-2) ...
Setting up libgtkspell0 (2.0.16-1.1ubuntu1) ...
Setting up libmagick++-6.q16-5v5:arm64 (8:6.8.9.9-7ubuntu5.6) ...
Setting up libvisio-0.1-1:arm64 (0.1.5-1ubuntu1) ...
Setting up inkscape (0.91-7ubuntu2) ...
Setting up libconfig9:arm64 (1.5-0.2) ...
Setting up libido3-0.1-0:arm64 (13.10.0+16.04.20161028-0ubuntu1) ...
Setting up liblightdm-gobject-1-0:arm64 (1.18.3-0ubuntu1.1) ...
Setting up libmate-sensors-applet-plugin0 (1.12.1-1) ...
Setting up libnm-util2:arm64 (1.2.6-0ubuntu0.16.04.1) ...
Setting up libnm-glib4:arm64 (1.2.6-0ubuntu0.16.04.1) ...
Setting up light-themes (14.04+16.04.20161024-0ubuntu1) ...
Setting up lightdm-gtk-greeter (2.0.1-2ubuntu4) ...
update-alternatives: using /usr/share/xgreeters/lightdm-gtk-greeter.desktop to provide /usr/share/xgreeters/lightdm-greeter.desktop (lightdm-greeter) in auto mode
Setting up lightdm-gtk-greeter-settings (1.2.1-0ubuntu1) ...
Setting up mate-gnome-main-menu-applet (1.8.0-5build1) ...
Setting up mate-icon-theme-faenza (1.12.0+dfsg1-1) ...
Setting up mate-indicator-applet-common (1.12.1-1) ...
Setting up mate-indicator-applet (1.12.1-1) ...
Setting up python-gobject (3.20.0-0ubuntu1) ...
Setting up python-mate-menu (1.12.0-1) ...
Setting up mozo (1.12.0-1) ...
Setting up python-six (1.10.0-3) ...
Setting up python-configobj (5.0.6-2) ...
Setting up python-glade2 (2.24.0-4ubuntu1) ...
Setting up python-xdg (0.25-4) ...
Setting up python-xlib (0.14+20091101-5) ...
Setting up xdg-utils (1.1.1-1ubuntu1.16.04.1) ...
Setting up mate-menu (5.7.1-1) ...
Setting up mate-netbook-common (1.12.0-1) ...
Setting up mate-netbook (1.12.0-1) ...
Setting up mate-netspeed-common (1.12.0-1) ...
Setting up mate-netspeed (1.12.0-1) ...
Setting up mate-optimus (1.0.0-1) ...
Setting up mate-sensors-applet-common (1.12.1-1) ...
Setting up mate-sensors-applet (1.12.1-1) ...
Setting up mate-themes (1.12.2+gtk3.18-1) ...
Setting up compton (0.1~beta2-1) ...
Setting up mesa-utils (8.3.0-1) ...
Setting up python3-psutil (3.4.2-1) ...
Setting up mate-tweak (3.5.10-1) ...
Setting up menu (2.1.47ubuntu1) ...
Setting up python-wnck (2.32.0+dfsg-3) ...
Setting up python3-decorator (4.0.6-1) ...
Setting up python3-numpy (1:1.11.0-1ubuntu1) ...
Setting up libwebpmux1:arm64 (0.4.4-1) ...
Setting up python3-pil:arm64 (3.1.2-0ubuntu1.1) ...
Setting up python3-xdg (0.25-4) ...
Setting up ubuntu-mate-wallpapers-common (16.04.7) ...
Setting up ubuntu-mate-wallpapers-xenial (16.04.7) ...
Setting up ubuntu-mate-wallpapers (16.04.7) ...
Setting up ubuntu-mate-lightdm-theme (16.04.7) ...
Setting up python3-scipy (0.17.0-1) ...
Setting up mate-dock-applet (0.70-1build1) ...
Processing triggers for menu (2.1.47ubuntu1) ...
Thanks, I completely forgot the s905_autoscript was hardcoded to query just usb 0:1
@sukanime
In the interest of readability, please use the spoiler tag when pasting huge walls of log output. Look here for a neat example:
- I have collected some patches for the KVIM, but all of them have been merged into mainline, so no patches regarded to the KVIM.
- This is the patchset for the C2, mostly related to reliable ethernet operations, USB and cpufreq support.
- I've started to edit a common kernel config for both the ODROID-C2 and the Khadas VIM
That's all, the rest of the patches are related to freescale/nxp imx6 devices, like the CuBox-i and the Utilite.
Hi All,
Is there anyone in here using Armbian for Desktop use with Login Manager, and fully Desktop not the Limited Mate.
I try the to make it with Login Manager lightdm but not working, any sugestion for Login Manager?
the strange thing, the way Lightdm Init to start is just like in Odroid Ubuntu Mate,
Lightdm starting sesion with user c1, Lightdm starting sesion with user c2, etc.
And is anyone have tried Update it, and I try to install alot of packages and its make Armbian Desktop usable with glitches.
I want to have a Desktop for Editing Audio, Editing Video, a working VLC, Image editing (Gimp, Inkscape, ImageMagick)
so, Is Armbian is for me or not ?
Thanks....
@sukanime
Everything you said is working ( except login manager i believe ) but not as you would expect from an amd64 or x86 Desktop machine.
So my short answer to your question would be: Why not?
You can watch videos with mpv ( not HD ), edit or create images with gimp,
create vector graphics with inkscape, watch youtube, listen to music, etc etc etc
and have all the power of linux for plenty of other uses, with minimum power consumption.
All you need to have is some patience at times.
Also these little boxes can make great thin clients ( that's my main use, but i have successfully created subtitles with subtitlekomposer using only my MiniM8S box ).
37 minutes ago, xXx said:
@sukanime
Thanks for the reply....
Actually, i already have comfortable with Odroid Ubuntu Mate from Koxx release, i think its based Odroid Ubuntu Mate v 1.2
It's have Login Manager (lightdm), i can watch video with VLC, of course MPV too, but i like VLC. even i can watch with Kodi in Mate Desktop.
Gimp, ImageMagick, Inkscape work like a charm, make DLNA Server for sharing Video, Audio and Pictures.
Installing Update will not make the system strange ( i disable apt sourcelist for Odroid, just using Ubuntu apt sourcelist)
but... for editing Audio.... Audacity stuck when initializing Soundcard with PulseAudio, so Audacity will hang.
In Armbian, i can make Audacity to work like a charm.... that what i don't understand.... Armbian use Pulse Audio doesn't it? So Why in Armbian it could initilizing Soundcard. @.@
But, VLC will make the module driver to crash.... T_T
And Installing packages from Ubuntu cause Graphics Glitches..... i dont know which packages that make the Graphics glitches...
I will try out to play with Odroid Ubuntu Mate v2.3, and i will see how the thing going on.
Btw, i love this Little Box, it can do all the thing i need , so right now i rarely using my laptop anymore.
Thanks a lot.....
You will also now find cheap (less than 100e) x86 (intel atom) boxes which will be able to have anything you want, they are basically regular PC that will run windows or linux....
_-------------------
What is a diference between a intel box and android box?
Hard disc & mmc??
Is it posibile for me to buy a external hdd, and use this hardware, like "regular pc", with normal linux mint, or ubuntu, or windows, when i must use windows for somethig..
I think about one ssd, to buy, for my documents, and when I can have some normal os with ssd, Ill buy one.
The hardware and the operating systems supported.
Android boxes are usually arm based and can run Android or Linux ( at least for  now ).
Intel boxes are usually atom based and can run Windows, Linux, Android and possibly others.
On "arm" devices will newer be a posibile "to install linux mint" (or ubuntu for pc, or laptop), only armbian and similar os, for "arm devices"?
20 hours ago, etona said:
A diference is in motherboard?
Hdd will NOT help?
The diference on CPU Architecture , see here about it - https://en.wikipedia.org/wiki/List_of_CPU_architectures
You can install Armbian, Debian for Arm, Ubuntu for Arm to HDD.
It's what i did, i install Ubuntu Mate from Odroid ( http://odroid.com/dokuwiki/doku.php?id=en:c2_ubuntu_release_note_v2.3 ) to USB Harddisk. its make the system lag free.
I think, it's not possible , Linux Mint doesnt have Arm version they only have x86.
Arm Devices/SBC only for OS Based Arm.
Ex, if you have Odroid C2 SBC or Raspberry Pi 3, you can install Linux OS for Arm like Ubuntu, Debian, Arch Linux, etc.
Cpu...
I have a nexbox, with 2.0ghz cpu, and need 4 os, inside.
Android is part of shit, nothing work corect, becouse that isnt a mobile phone with touch screen...
Libreelec is just for kodi and kodi work like on android, 2% better.
On armbian grafic and video are....
People said this odroid is better, but on my nexbox odroid  dont work..
linux mint it's debian with mate DE and testing repo... You can build you own os mint, *buntu etc. But you can't use arm tv box like x86 pc, if you need some specific option like wine etc. If armbian from balbes150 don't enough for you, image from odroid will not change situation significult.
13 hours ago, etona said:
Cpu...
What do you need to do with your Android TV Box Arm ?
For me , My Mini M8S with S905 using Odroid Ubuntu Mate image but with custom kernel is the best for me, i can install Ubuntu Mate, Xubuntu (based ubuntu odroid) and Kubuntu (based ubuntu odroid)
Install it on USB Harddisk and it will smooth, i use it for every day use, like watch video with VLC (no fullscreen), browsing the internet with Firefox and Chromium Web Browser (its have 3D acclerated), editing pictures with gimp, imagemagick and inkscape, creating Epub with Sigil, playing with Kernel Source and other apps source code And make it as DLNA server with MiniDLNA so i can watch video throug wifi and lan on DLNA Devices.
About Ubuntu Odroid, You can try my build in here http://www.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/others-ac/602739-mini-m8s-s905-ubuntu-mate-64-bit-with-x-and-kodi-and-vlc-on-sdcard
Or Koxx release in here http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/beelink-ac/568654-minimx-s905-ubuntu-16-04-64bits-with-kodi-and-x-on-sdcard
Image update 20170421.
Added to the library libMali (for fbdev). Please check the Firefox browser with file playback at resolution of 1080p. I have to check we have an odd situation, tried full screen youtube videos , like playable, but only if choose the 720p (screen resolution is set to 1080p). The temperature in armbianmonitor shows about 50 Degrees. I'm not well versed in matters of videoscoralie. I'm not clear whether acceleration is working, whether this effect is from something else. For work acceleration in the video (mpv vlc etc) it is necessary to recompile with support for Mali r5p1-01rel0 . I have not yet figured out how this is done in Ubuntu (something to build the package). I would be very grateful if you could drop links to instructions on how to do it.
test link
I found a video which offers a 1080p
Everytime you do an image update, can I do a "apt-get update" or something like that, or do I have to burn the image onto my micorSD card again?  Right now, I download your newest image and burn it onto my microSD card using Rufus.
3 hours ago, thc013 said:
Cannot find the serial port
it is a x96 board with pcb version s905x v 1.1
I cannot find it too....
but there is something make me curious, i saw two audio port jack 3,5" in the corner right bellow.
is that Audio Jack 3,5" to connect to Headphone or Eksternal Speaker?
It's for the IR receiver which is not integrated on the board.
I got this box too and I can confirm that it works well with balbes150 image (just test with mate, but downloaded latest with xfce). I just modified lowest freq to 250MHz instead of 100, since I found it not very responsive for a desktop usage.
