5 hours ago, balbes150 said:
Image Yocto with kernel 4.12 (for S905X).  (v20170825)
Thanks!
Does Yocto image also include support for running Kodi smoothly?
35 minutes ago, Nofan Tasi said:
Thanks!
Perhaps in the future it will be. Now it is not.
New image 20170828  kernel 4.12.9.
In this way there is support for USB on the platform S905X. You can run the system from SD cards and USB flash drives. Changed the activation system monitor, now it is built into the kernel itself. To change the screen resolution, you need to use standard tools from control monitor on a desktop. The resolution changes on the fly (directly on desktop). Not working yet WiFi. There are problems with the dtb files (requires the edit and debug under different models). For s905x recommend to use a file meson-gxl-s905x-nexbox-a95x or meson-gxl-s905x-khadas-vim1. For the model s905 - meson-gxbb-odroidc2.
Version update TEST kernel 4.13.0_next_20170907. Added support for sound for all models S905X and S912. Pay attention to one feature of the work of sound - on the desktop has to be set 1920x1080 resolution. Not clear to me yet why the sound only works in this screen resolution.
For some recent images to use these additions, you can only download the kernel and dtb files (deb packages are in the directory TEST\deb) to install in the existing system (don't forget to update the file "dtb.img" to a new version).
On 9/1/2017 at 9:54 PM, balbes150 said:
New image 20170901  kernel 4.13.0-rc6 and next-4.13.0-rc7 for S905X.  Working USB.
Since i got a couple of S905X boxes at home, i gave Nexbox A95X S905X a try, boots with multiple DTB, but only meson-gxbb-nexbox-a95x.dtb seems to be able to boot into ldm/mate.
But there is no response from USB mouse nor keyboard.  As USB is supported now, what could this be?
EDIT: images being tested are from 20170907.
Armbian_5.32_S9xxx_Ubuntu_xenial_4.13.0-next-20170908_mate.img.xz successfully boots into a green textured mate on my X96 (1+16) box. USB wired mouse and USB keyboard both work fine. I can play the movie and access folders but little else. The settings file (config) opens but there are few options, and I have not discovered how to access the console or enable wifi yet.  I assume HDMI is working at 720p. Have not checked audio. Am using the A95x dtb file.
1. If the system runs with file gxbb , then this is the version with the chip S905 (no X).
2. Try all the dtb files, the title of which is "gxbb".
7 hours ago, intelmarico said:
enable wifi yet
WiFi in this kernel version is not supported.
Sound only works with 1080p resolution (you can switch the screen resolution on the fly in a working system, via the settings menu of the monitor group Settings).
@balbes150 how can i configure uboot ethernet connection to boot through tftp ? i have a Kii pro S905 box, tried to set the ip address and gateway in u-boot but still whenever i ping a host in the network it says the host is not alive? is this a bug or i'm missing a setting ?my u-boot version is 2015.01-g3fb479f-dirty (Oct 13 2016 - 19:22:50)
Have you read this information ?
http://docs.khadas.com/develop/SetupTFTPServer/
balbes150
thank you very much for your excellent work!
I have a KM8P S912 - on firmware at the 20170908 with the kernel 4.13 works USB-mouse and the keyboard, there is a sound at the resolution of the screen 1920х1080.
As I understand it, there a problem when installing this firmware on EMMC?
In the test builds (with the kernel 4.x) there are many things not completed and there are errors, these images and dtb data changes frequently. So I have not tested the installation to the internal memory.
Can you please tell me how to install the firmware on EMMC? Is there any way to install the GPU Mali drivers? Are there any advantages of the 4.13 kernel compared to the 3.14 kernel?
Yes i have but it's not working on my box.
my box and my laptop are connected to the same router the router ip is 172.16.1.1 running dhcp server i tried to setup a tftp server in my main os (arch linux) and then tried it in a ubuntu 16.04.2 vm and still can't get it to work.
gxb_p20x#setenv ipaddr 172.16.1.44
gxb_p20x#setenv serverip 172.16.1.241
gxb_p20x#setenv gatewayip 172.16.1.1
gxb_p20x#saveenv
Saving Environment to aml-storage...
mmc env offset: 0x27400000
Writing to MMC(1)... done
gxb_p20x#ping 172.16.1.1
Amlogic Ethernet Init
Success: reset mac OK!(0)
ETH PHY hardware reset OK
find net phy id=0x2430c54, phyad=0
set_mac_mode(2)
final_addr[rx-tx]: 0000000073efe8e0-0000000073efeee0
Ethernet reset OK
MAC address is 00:15:18:01:81:31
duplex
100m
Using Meson_Ethernet device
ping failed; host 172.16.1.1 is not alive
gxb_p20x#tftp 1080000 Image
TFTP from server 172.16.1.241; our IP address is 172.16.1.44
Filename 'Image'.
Load address: 0x1080000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
Filename 'Image'.
Loading: *
Abort
This might be a bug in u-boot of the box that was fixed in kvim u-boot ? have you ever tried this on a box and worked ?
56 minutes ago, purplepumkin said:
Would the S905W work? I'm seeing S905W devices going quite cheap. Less than $20 for a Tanix TX3 mini with 1GB RAM and 16GB eMMC.
I have no such models, so until the owner of such a model itself will not check, we do not know.
@balbes150 how to get fw_printenv and fw_setenv working in mainline kernel images ?
when running a 3.14 kernel the tools works fine by using /dev/env which doesn't exist in mainline kernel.
looking at dmesg in 3.14 kernel it output the environment offsets
[    2.369744@2] [mmcblk0p04]                  env  offset 0x000027400000, size 0x000000800000
u-boot also report the same offsets
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          20000000                  2
   3: env                         27400000            800000                  0
   4: logo                        28400000           2000000                  1
   5: recovery                    2ac00000           2000000                  1
   6: rsv                         2d400000            800000                  1
   7: tee                         2e400000            800000                  1
   8: crypt                       2f400000           2000000                  1
   9: misc                        31c00000           2000000                  1
  10: instaboot                   34400000          20000000                  1
  11: boot                        54c00000           2000000                  1
  12: system                      57400000          40000000                  1
  13: data                        97c00000         30c200000                  4
i tried to put these offsets in /etc/fw_en.config file but still the fw_printenv tools is printing the default environment
I haven't tested these utilities on core 4.x
On 20.09.2017 at 10:30 PM, purplepumkin said:
It seems "arm-none-eabi-cpp" is missing.
I hope you are using a 64 bit system and installed the 32 bit multilib ?
To all
Update test image  4.14.0-rc1-next-20170922.
Do you guys plan to support S905W ? I just ordered Tanix TX3 Mini with S905W chipset, it'd be great to be able to install a linux distro in it.
8 hours ago, purplepumkin said:
Can confirm that installing above mentioned package resolves the issue. Should apply to both Debian and Ubuntu.
What system are you using to build ?
