Odroid C2 and Opi PC, latest beta.
I was already looking if we produced this problem and where ...
How I can install this Desktop over Orange Pi PC beta?
Ans also I suppose I need to install VNC or Xrdp to see the desktop because I don't have a working HDMI.
I'm using it on a Orange Pi One and I don't have temperature or cpufreq-info, is there any way to have it?
Thanks.
To get cpufreq-info, temperature and throttling you need a kernel that has the patches for these drivers. The beta currently is still build with a kernel that doesn't have these patches. You can build your own kernel / image which do include these patches. https://github.com/megous/linux
I've build my own image with this kernel and it's running nicely, with throttling, temperature/cpufreq readout and btrfs. When these patches either get mainline, or integrated in the armbian build system for the beta the One/Zero boards can run 4.9 kernel as well.
Why isn't the root account locked out after the creation of a user account? I know it's convenient, but not quite safe this way.
Second: Could the welcome message also showt the IPv6 address(es) of the board? I've got IPv6 next to my IPv4 network and it would be nice to also now the IPv6 addresses of the board.
Currently it's up to end user. Adding a normal account on first boot is relatively new procedure and there are some possible issues with it. Until these issues are fixed forced root locking should not be added IMO.
Thanks for the info, is to much for me by now.
I can wait for a mainline kernel with patches for the Orange Pi One.
Ok, I can understand that point of view. Maybe it's something that could be asked after the user account has been made: Do you want to lock out root from ssh? There are a lot of users who simple connect these baby's to the internet and don't give it much thought. Helping them a little doesn't hurt.
Last test for pine64 does not boot. (Checked also last week-end and same result, but no time to take usb2serial).
I made a test with 2 different psu and 2 different sdcards that works with other img and other cards.
Here is UART output:
HELLO! BOOT0 is starting!
boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
DRAM driver version: V1.1
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM zq value: 003b3bbb
DRAM single rank full DQ OK
DRAM size = 1024 MB
DRAM init ok
dram size =1024
card boot number = 0, boot0 copy = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 30528 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000e4000.
sum=c8b77107
src_sum=c8b77107
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x0000a200 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019a00 success
set arisc reset to de-assert state
Ready to disable icache.
Jump to secend Boot.
r=Q%
Configuring SPC Controller
NOTICE: BL3-1: v1.0(debug):e9fc343
NOTICE: BL3-1: Built : 19:08:14, Dec 4 2016
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x4a000000
INFO: BL3-1: Next image spsr = 0x1d3
U-Boot 2014.07-4-pine64-gf1d5b11-dirty (Dec 04 2016 - 19:08:15) Allwinner Technology
uboot commit : f1d5b11a5aa3d399543bb36dd6438c2f3fa143da
rsb: secure monitor exist
[ 0.361]pmbus: ready
[ 0.364][ARISC] :arisc initialize
[ 0.690][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[sCP] :sunxi-arisc driver begin startup 2
[sCP] :arisc_para size:1a8
[sCP] :arisc version: [v0.1.76]
[sCP] :sunxi-arisc driver v1.10 is starting
[ 0.816][ARISC] :sunxi-arisc driver startup succeeded
[ 0.849]PMU: AXP81X
[ 0.851]PMU: AXP81X found
bat_vol=321, ratio=100
[ 0.857]PMU: dcdc2 1100
[ 0.861]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
device_type = 3253, onoff=1
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1100, onoff=1
dcdc6_vol = 1100, onoff=1
aldo1_vol = 2800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dldo1_vol = 3300, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 3300, onoff=1
eldo1_vol = 1800, onoff=1
eldo2_vol = 1800, onoff=0
eldo3_vol = 1800, onoff=0
fldo1_vol = 1200, onoff=0
fldo2_vol = 1100, onoff=1
gpio0_vol = 3100, onoff=0
vbus not exist
no battery, limit to dc
run key detect
no key found
no uart input
DRAM: 1008 MiB
fdt addr: 0x76ebf500
Relocation Offset is: 35f11000
In: serial
Out: serial
Err: serial
gic: sec monitor mode
[ 1.670]start
drv_disp_init
init_clocks: finish init_clocks.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
boot_disp.output_disp=0
boot_disp.output_type=3
boot_disp.output_mode=10
fetch script data boot_disp.auto_hpd fail
disp0 device type(4) enable
attched ok, mgr0<-->device1, type=4, mode=10
[ 2.043]end
workmode = 0,storage type = 1
[ 2.048]MMC: 0
[mmc]: mmc driver ver 2015-06-03 13:50:00
WARNING: Unimplemented Standard Service Call: 0x8000ff05
WARNING: Unimplemented Standard Service Call: 0x8000ff06
SUNXI SD/MMC: 0
[mmc]: start mmc_calibrate_delay_unit, don't access device...
[mmc]: delay chain cal done, sample: 192(ps)
[mmc]: media type 0x0
[mmc]: ************Try SD card 0************
[mmc]: host caps: 0x27
[mmc]: MID 1b PSN f4d85382
[mmc]: PNM 00000 -- 0x30-30-30-30-30
[mmc]: PRV 1.0
[mmc]: MDT m-1 y-2016
[mmc]: speed mode : HSSDR52/SDR25
[mmc]: clock : 50000000 Hz
[mmc]: bus_width : 4 bit
[mmc]: user capacity : 30528 MB
[mmc]: ************SD/MMC 0 init OK!!!************
[mmc]: erase_grp_size : 0x1WrBlk*0x200=0x200 Byte
[mmc]: secure_feature : 0x0
[mmc]: secure_removal_type : 0x0
[ 2.271]sunxi flash init ok
[mmc]: Has init
[ 2.305]---drivers/mmc/mmc.c 2733 mmc_init
** Unable to use mmc 0:1 for loading the env **
Using default environment
--------fastboot partitions--------
mbr not exist
base bootcmd=run mmcbootcmd
bootcmd set setargs_mmc
key 0
recovery key high 12, low 10
fastboot key high 6, low 4
no misc partition is found
to be run cmd=run mmcbootcmd
update dtb dram start
update dtb dram end
serial is: ffffffffffffffffffff
get Pine64 model from DRAM size
DRAM >512M
Pine64 model: pine64-plus
no battery exist
sunxi_bmp_logo_display
[mmc]: Has init
[ 2.528]---drivers/mmc/mmc.c 2733 mmc_init
sunxi bmp info error : unable to open logo file bootlogo.bmp
[ 2.542]inter uboot shell
Hit any key to stop autoboot: 3 2 1 0
[mmc]: Has init
[ 5.657]---drivers/mmc/mmc.c 2733 mmc_init
26 bytes read in 13 ms (2 KiB/s)
Loading boot environment ...
[mmc]: Has init
[ 5.685]---drivers/mmc/mmc.c 2733 mmc_init
4696 bytes read in 11 ms (416 KiB/s)
Booting with script ...
## Executing script at 41000000
[mmc]: Has init
[ 5.723]---drivers/mmc/mmc.c 2733 mmc_init
140 bytes read in 8 ms (16.6 KiB/s)
[mmc]: Has init
[ 5.751]---drivers/mmc/mmc.c 2733 mmc_init
67970 bytes read in 16 ms (4.1 MiB/s)
[mmc]: Has init
[ 5.779]---drivers/mmc/mmc.c 2733 mmc_init
4785819 bytes read in 264 ms (17.3 MiB/s)
[mmc]: Has init
[ 6.055]---drivers/mmc/mmc.c 2733 mmc_init
11931672 bytes read in 628 ms (18.1 MiB/s)
Image lacks image_size field, assuming 16MiB
## Loading init Ramdisk from Legacy Image at 45300000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 4785755 Bytes = 4.6 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 45000000
Booting using the fdt blob at 0x45000000
reserving fdt memory region: addr=41010000 size=10000
reserving fdt memory region: addr=41020000 size=800
reserving fdt memory region: addr=40100000 size=4000
reserving fdt memory region: addr=40104000 size=1000
reserving fdt memory region: addr=40105000 size=1000
reserving fdt memory region: addr=45000000 size=11000
Loading Ramdisk to 76a2a000, end 76eba65b ... OK
Loading Device Tree to 44feb000, end 44ffefff ... OK
Starting kernel ...
[mmc]: MMC Device 2 not found
[mmc]: mmc 2 not find, so not exit
INFO: BL3-1: Next image address = 0x41080000
INFO: BL3-1: Next image spsr = 0x3c9
Loading, please wait...
starting version 229
done.
Begin: Will now check root file system ... fsck from util-linux 2.27.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: recovering journal
/dev/mmcblk0p1: clean, 141920/1933920 files, 715896/7736504 blocks
done.
done.
Welcome to [1mUbuntu 16.04.1 LTS[0m!
[[0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe.
[[0;32m OK [0m] Listening on fsck to fsckd communication Socket.
[[0;32m OK [0m] Listening on udev Control Socket.
[[0;32m OK [0m] Set up automount Arbitrary Executab...ats File System Automount Point.
[[0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch.
[[0;32m OK [0m] Listening on Syslog Socket.
[[0;32m OK [0m] Listening on Journal Socket (/dev/log).
[[0;32m OK [0m] Reached target User and Group Name Lookups.
[[0;32m OK [0m] Reached target Encrypted Volumes.
[[0;32m OK [0m] Listening on Journal Socket.
[[0;32m OK [0m] Reached target Remote File Systems (Pre).
[[0;32m OK [0m] Created slice User and Session Slice.
[[0;32m OK [0m] Created slice System Slice.
Starting Create list of required st... nodes for the current kernel...
Mounting Debug File System...
[[0;32m OK [0m] Created slice system-serial\x2dgetty.slice.
Starting Load Kernel Modules...
Mounting POSIX Message Queue File System...
Starting Set console keymap...
Starting Remount Root and Kernel File Systems...
Mounting Huge Pages File System...
[[0;32m OK [0m] Reached target Remote File Systems.
[[0;32m OK [0m] Reached target Slices.
Starting Restore / save the current clock...
[[0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch.
Starting Nameserver information manager...
[[0;32m OK [0m] Listening on udev Kernel Socket.
[[0;32m OK [0m] Mounted Debug File System.
[[0;32m OK [0m] Mounted POSIX Message Queue File System.
[[0;32m OK [0m] Mounted Huge Pages File System.
[[0;32m OK [0m] Started Create list of required sta...ce nodes for the current kernel.
[[0;32m OK [0m] Started Remount Root and Kernel File Systems.
[[0;32m OK [0m] Started Restore / save the current clock.
[[0;32m OK [0m] Started Nameserver information manager.
[[0;32m OK [0m] Started Set console keymap.
[[0;32m OK [0m] Started Load Kernel Modules.
Mounting Configuration File System...
Mounting FUSE Control File System...
Starting Apply Kernel Variables...
Starting Load/Save Random Seed...
Activating swap /var/swap...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
[[0;32m OK [0m] Mounted FUSE Control File System.
[[0;32m OK [0m] Mounted Configuration File System.
[[0;32m OK [0m] Activated swap /var/swap.
[[0;32m OK [0m] Started Apply Kernel Variables.
[[0;32m OK [0m] Started Load/Save Random Seed.
[[0;32m OK [0m] Started Create Static Device Nodes in /dev.
[[0;32m OK [0m] Reached target Local File Systems (Pre).
Mounting /tmp...
Starting udev Kernel Device Manager...
[[0;32m OK [0m] Reached target Swap.
[[0;32m OK [0m] Mounted /tmp.
[[0;32m OK [0m] Started udev Coldplug all Devices.
[[0;32m OK [0m] Started Entropy daemon using the HAVEGE algorithm.
Starting Journal Service...
[[0;32m OK [0m] Reached target Local File Systems.
Starting Raise network interfaces...
Starting Set console font and keymap...
[[0;32m OK [0m] Started udev Kernel Device Manager.
[[0;32m OK [0m] Started Journal Service.
[[0;32m OK [0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Flush Journal to Persistent Storage...
Starting Load/Save RF Kill Switch Status...
[[0;32m OK [0m] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[[0;32m OK [0m] Started Load/Save RF Kill Switch Status.
[[0;32m OK [0m] Started Create Volatile Files and Directories.
[[0;32m OK [0m] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[[0;32m OK [0m] Found device /dev/ttyS0.
[[0;32m OK [0m] Started Update UTMP about System Boot/Shutdown.
[[0;32m OK [0m] Reached target System Initialization.
[[0;32m OK [0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[[0;32m OK [0m] Reached target Paths.
[[0;32m OK [0m] Started Daily Cleanup of Temporary Directories.
[[0;32m OK [0m] Listening on D-Bus System Message Bus Socket.
[[0;32m OK [0m] Reached target Sockets.
[[0;32m OK [0m] Reached target Basic System.
Starting Login Service...
Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Starting Accounts Service...
Starting System Logging Service...
Starting LSB: Starts LIRC daemon....
Starting LSB: Start/stop sysstat's sadc...
Starting LSB: Armbian gathering hardware information...
Starting Permit User Sessions...
Starting LSB: No Display Manager...
[[0;32m OK [0m] Started Regular background program processing daemon.
[[0;32m OK [0m] Started D-Bus System Message Bus.
[ 15.856702] Call trace:
[ 15.859777] Call trace:
Starting Network Manager...
[[0;32m OK [0m] Started Daily apt activities.
[[0;32m OK [0m] Reached target Timers.
Starting Save/Restore Sound Card State...
Starting Avahi mDNS/DNS-SD Stack...
[[0;32m OK [0m] Started System Logging Service.
[[0;32m OK [0m] Started Set console font and keymap.
[[0;32m OK [0m] Started Permit User Sessions.
[ 16.371927] Call trace:
[ 16.375010] Call trace:
[[0;32m OK [0m] Started Save/Restore Sound Card State.
[[0;32m OK [0m] Started LSB: Starts LIRC daemon..
[[0;32m OK [0m] Started LSB: Start/stop sysstat's sadc.
[[0;32m OK [0m] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[[0;32m OK [0m] Started LSB: No Display Manager.
[[0;32m OK [0m] Started Raise network interfaces.
[[0;32m OK [0m] Started Avahi mDNS/DNS-SD Stack.
[[0;32m OK [0m] Started Login Service.
Starting Authenticate and Authorize Users to Run Privileged Tasks...
Stopping LSB: Starts LIRC daemon....
Starting LSB: set CPUFreq kernel parameters...
[[0;32m OK [0m] Started ifup for eth0.
[[0;32m OK [0m] Reached target Sound Card.
Starting Set console scheme...
[[0;32m OK [0m] Created slice system-getty.slice.
[[0;32m OK [0m] Started Set console scheme.
[[0;32m OK [0m] Started Network Manager.
[[0;32m OK [0m] Started Authenticate and Authorize Users to Run Privileged Tasks.
[[0;32m OK [0m] Stopped LSB: Starts LIRC daemon..
[[0;32m OK [0m] Started LSB: set CPUFreq kernel parameters.
[[0;32m OK [0m] Started Accounts Service.
Starting LSB: Set sysfs variables from /etc/sysfs.conf...
Starting Network Manager Script Dispatcher Service...
[[0;32m OK [0m] Reached target Network.
Starting OpenBSD Secure Shell server...
Starting Network Manager Wait Online...
[[0;32m OK [0m] Started Network Manager Script Dispatcher Service.
Starting Hostname Service...
[[0;32m OK [0m] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[[0;32m OK [0m] Started Hostname Service.
[[0;32m OK [0m] Started OpenBSD Secure Shell server.
Starting WPA supplicant...
[[0;32m OK [0m] Started WPA supplicant.
[[0;32m OK [0m] Started LSB: Armbian gathering hardware information.
[[0m[0;31m* [0m] A start job is running for Network ...ger Wait Online (11s / no limit)
[K[[0;32m OK [0m] Started Network Manager Wait Online.
[[0;32m OK [0m] Reached target Network is Online.
Starting /etc/rc.local Compatibility...
Starting LSB: disk temperature monitoring daemon...
Starting LSB: Start NTP daemon...
Starting LSB: Advanced IEEE 802.11 management daemon...
[[0;32m OK [0m] Started /etc/rc.local Compatibility.
[[0;32m OK [0m] Started LSB: Advanced IEEE 802.11 management daemon.
[[0;32m OK [0m] Started LSB: disk temperature monitoring daemon.
[[0;32m OK [0m] Started Getty on tty1.
[[0;32m OK [0m] Started Serial Getty on ttyS0.
[[0;32m OK [0m] Reached target Login Prompts.
[[0;32m OK [0m] Started LSB: Start NTP daemon.
[[0;32m OK [0m] Reached target Multi-User System.
[[0;32m OK [0m] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[[0;32m OK [0m] Started Update UTMP about System Runlevel Changes.
Ubuntu 16.04.1 LTS pine64 ttyS0
pine64 login:
You're right, in fact it boots by without hdmi output whereas it is desktop img.
I also had a strange behavior. I was able to login via serial communication, but it reboots after I change root password and after that I can just login as root. I was also able to ssh via ethernet, but it was difficult to do anything (I try a dmesg but my terminal froze). I don't know if it comes from my local network or the pine64 with this beta armbian img. I will take time to investigate more this evening. My board works well with an older beta img.
I use uart again and here is what I get after root login:
pine64 login: root
Password:
Last login: Mon Dec 5 19:02:57 UTC 2016 from 192.168.0.7 on pts/0
Traceback (most recent call last):
File "/etc/update-motd.d/40-updates", line 145, in
updates = int(file.read())
ValueError: invalid literal for int() with base 10: ''
run-parts: /etc/update-motd.d/40-updates exited with return code 1
[0;31mThank you for choosing Armbian! Support: [1m[39mwww.armbian.com[0m
Creating new account. Please provide a username (eg. your forename): adduser: Only one or two names allowed.
Starting Unattended Upgrades Shutdown...
[[0;32m OK [0m] Stopped target Timers.
[[0;32m OK [0m] Stopped Daily apt activities.
Stopping Authenticate and Authorize Users to Stopping LSB: No Display Manager...
Stopping OpenBSD Secure Shell server...
Stopping LSB: Start/stop sysstat's sadc...
Stopping LSB: Armbian gathering hardware information...
Stopping LSB: Set sysfs variables from /etc/sysfs.conf...
Stopping Accounts Service...
Stopping LSB: Start NTP daemon...
[[0;32m OK [0m] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Save/Restore Sound Card State...
Stopping LSB: Advanced IEEE 802.11 management daemon...
[[0;32m OK [0m] Stopped Daily Cleanup of Temporary Directories.
Stopping User Manager for UID 0...
[[0;32m OK [0m] Stopped Avahi mDNS/DNS-SD Stack.
[[0;32m OK [0m] Stopped System Logging Service.
[[0;32m OK [0m] Stopped Accounts Service.
[[0;32m OK [0m] Stopped Regular background program processing daemon.
[[0;32m OK [0m] Stopped OpenBSD Secure Shell server.
[[0;32m OK [0m] Stopped Authenticate and Authorize Users to Run Privileged Tasks.
[[0;32m OK [0m] Stopped Serial Getty on ttyS0.
[[0;32m OK [0m] Stopped Getty on tty1.
[[0;32m OK [0m] Stopped User Manager for UID 0.
[[0;32m OK [0m] Stopped Session c1 of user root.
[[0;32m OK [0m] Stopped Save/Restore Sound Card State.
[[0;32m OK [0m] Started Unattended Upgrades Shutdown.
[[0;32m OK [0m] Stopped LSB: Advanced IEEE 802.11 management daemon.
[[0;32m OK [0m] Stopped LSB: disk temperature [ 64.740871] Call trace:
monitoring daemon.
[[0;32m OK [0m] Stopped LSB: No Display Manager.
[[0;32m OK [0m] Stopped LSB: Start/stop sysstat's sadc.
[[0;32m OK [0m] Stopped LSB: Set sysfs variables from /etc/sysfs.conf.
[[0;32m OK [0m] Stopped LSB: Start NTP daemon.
Stopping LSB: set CPUFreq kernel parameters...
[[0;32m OK [0m] Removed slice User Slice of root.
Stopping Login Service...
[[0;32m OK [0m] Removed slice system-getty.slice.
[[0;32m OK [0m] Stopped /etc/rc.local Compatibility.
[ 65.222609] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.239174] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.255513] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped targ[ 65.272674] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.290217] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m[ 65.307030] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
] Stopped Network Manager Wait O[ 65.324217] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
nline.
[ 65.340071] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.354154] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Removed slic[ 65.369430] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.384599] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.399592] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.411819] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
Stopping Permit User Se[ 65.423778] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
ssions...
[ 65.440418] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.451832] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped target Network.
[ 65.463160] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.476518] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.487660] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
Stopping Raise network interfaces...
[ 65.501674] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
Stopping WPA supplicant...
[ 65.513332] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.525637] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
Stopping Network Manager...
[ 65.535729] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.548844] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.559920] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped Login Service.
[ 65.570552] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.582483] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m[ 65.593400] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
] Stopped Permit User Sessions.
[ 65.604496] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.614449] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.624300] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.634212] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.644026] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.653816] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.663557] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.673208] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.682864] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.692513] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.702309] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.711984] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.721632] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.731249] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.740831] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.750394] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.759924] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.769449] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.778901] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m[ 65.788344] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
] Stopped LSB: set CPUFreq kerne[ 65.797942] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
l parameters.
[ 65.808041] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.817411] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.826609] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.835646] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.845120] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.854532] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.863938] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.873362] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.882772] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.892177] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.901606] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.911019] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.920411] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.929809] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.939230] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.948718] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.958237] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.967727] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 65.977214] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
Stopping LSB: Load kernel module[ 65.986703] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
s needed to enable cpufreq scali[ 65.998056] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
ng...
[ 66.008111] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.017456] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped LSB: Starts LIRC daemo[ 66.026849] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
n..
[ 66.038897] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.047356] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped target User and Group Na[ 66.056747] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
me Lookups.
[ 66.068916] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.078391] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.087801] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.096581] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.105977] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.115381] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.124786] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.134248] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.143854] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.153305] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.162728] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m[ 66.172472] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
] Stopped LSB: Load kernel modul[ 66.182908] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
es needed to enable cpufreq scal[ 66.192709] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
ing.
[ 66.202760] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.212120] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.221545] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.230972] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.239530] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.249036] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.258483] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.267890] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped target Remote File Sys[ 66.277313] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
tems.
[ 66.289247] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.298611] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[[0;32m OK [0m] Stopped target Remote File Sys[ 66.308051] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
tems (Pre).
[ 66.319880] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.329252] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.337826] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.346717] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.356166] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.365573] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.374943] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.384320] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.393665] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.403019] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.411435] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.420794] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.430188] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.437575] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.444963] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.452360] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.459722] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.467104] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.474482] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.481898] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.489259] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.496649] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.504027] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.513383] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.522735] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.532106] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.541455] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.550802] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.560147] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.568876] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.578220] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.587584] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.596959] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.606312] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.615687] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.625043] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.634452] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.643812] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.653178] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.662547] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.671908] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.681275] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.691016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.700439] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.710624] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.720010] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.729421] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.738816] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.748226] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.757604] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.766993] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.775516] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.784899] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.794310] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.803698] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.813493] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.822959] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.832853] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.842280] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.851709] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.861150] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.870583] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.880021] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.889451] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.898873] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.908314] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.917738] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.927181] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.936603] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.946465] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.955974] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.966398] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.975866] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.985334] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 66.994814] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.004286] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.013756] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.023219] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.032675] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.041201] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.050660] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.060150] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.069617] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.079080] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.088562] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.098023] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.107501] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.116963] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.126480] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.135945] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.145417] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.154894] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.164605] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.174190] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.183732] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.193315] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.202930] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.212509] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.222076] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.231645] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.241222] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.250784] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.260356] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.269942] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.279500] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.289463] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.299150] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.309147] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.318813] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.328446] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.338096] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.347729] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.357376] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.367015] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.375781] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.385420] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.395080] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.404728] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.414379] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.424020] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.433882] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.443527] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.453183] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.462841] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.470782] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.478957] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.487325] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.496442] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.505800] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.514396] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.523709] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.533268] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.533346] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.533373] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.533387] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.536181] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.536209] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.536224] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.536280] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.536303] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.536318] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.536370] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.536393] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.536406] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.536457] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.536479] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.536494] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.536546] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.536568] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.536582] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.536637] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.536701] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.536756] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.536807] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.538850] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.540888] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.542925] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.544977] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.547016] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.549053] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.551089] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.552956] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.554996] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.557033] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.559070] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.561106] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.562777] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.564817] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.566854] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.568890] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.572941] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.574962] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.576963] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.578965] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.580965] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.582390] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.584390] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.586391] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.588391] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.590391] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.592226] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.594227] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.596228] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.598228] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.600227] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.602091] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.604095] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.606101] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.608105] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.610110] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.612118] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.614123] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.616128] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.618132] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.620137] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.622144] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.624148] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.626153] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.628159] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.630164] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.632170] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.634174] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.636184] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.638190] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.640195] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.642202] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.644208] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.646213] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.648217] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.650221] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.652228] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.654233] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.656237] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.658242] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.660248] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.662253] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.664257] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.666262] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.668266] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.670271] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.672277] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.674282] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.676287] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.678292] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.680297] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.682302] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.684306] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.686311] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.688315] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.690320] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.692326] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.694332] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.696336] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.698341] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.700346] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.702352] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.704356] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.706361] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.708366] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.710371] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.712371] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.714371] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.716371] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.718372] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.720152] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.722152] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.724152] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.726153] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.728153] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.730020] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.732022] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.734023] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.736023] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.738023] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.739841] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.739869] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.739896] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.739922] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.739948] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.739974] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740002] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740027] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740052] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740079] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740105] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740130] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740155] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740182] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740206] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740231] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.740256] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.742262] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.744266] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.746269] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.748275] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.750281] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.752285] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.754288] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.756292] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.758296] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.760302] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.762306] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.764310] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.766313] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.768316] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.770322] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.772326] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.774329] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.776334] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.778338] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.780345] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.782349] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.784352] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.786356] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.788359] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.790363] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.792368] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.794372] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.796376] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.798379] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.800385] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.802389] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.804392] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.806395] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.808400] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.810407] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.812411] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.814414] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.816418] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.818421] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.820428] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.822431] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.824436] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.826440] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.828445] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.830449] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.832453] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.834456] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.836468] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.838473] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.840478] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.842483] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.844486] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.846490] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.848495] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.850499] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.852502] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.854505] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.856511] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.858516] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.860520] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.862523] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.864527] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.866532] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.868538] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.870542] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.872545] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.874550] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.876554] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.878560] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.880563] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.882566] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.884570] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.886574] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.888579] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.890584] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.892589] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.894592] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.896596] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.898602] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.900605] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.902609] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.904612] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.906617] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.908622] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.910626] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.912629] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.914632] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.916636] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.918641] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.920645] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.922650] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.924654] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.926658] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.928662] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.930665] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.932669] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.934672] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.936678] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.938683] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.940687] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 67.942703] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.942720] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.942730] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 67.942763] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 53, WR RTO !!
[ 67.942775] sunxi-mmc 1c10000.sdmmc: data error, sending stop command
[ 67.942785] sunxi-mmc 1c10000.sdmmc: send stop command failed
[ 68.010236] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.017854] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.017885] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.277848] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.277904] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.278057] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 68.278080] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 68.278101] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 68.278123] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 7, RTO !!
[ 68.324276] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.331558] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 68.346177] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[ 68.353521] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 68.360817] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 68.368113] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 68.375369] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 68.382621] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 68.389877] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 68.397133] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 68.404384] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 68.411643] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[[0;32m OK [0m] Stopped Raise network interfaces.
[[0;32m OK [0m] Stopped Network Manager.
[[0;32m OK [0m] Stopped WPA supplicant.
[[0;32m OK [0m] Stopped LSB: Armbian gathering hardware information.
Stopping D-Bus System Message Bus...
[[0;32m OK [0m] Stopped D-Bus System Message Bus.
[[0;32m OK [0m] Stopped target Basic System.
[[0;32m OK [0m] Stopped target Sockets.
[[0;32m OK [0m] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[[0;32m OK [0m] Closed Syslog Socket.
[[0;32m OK [0m] Stopped target Slices.
[[0;32m OK [0m] Removed slice User and Session Slice.
[[0;32m OK [0m] Stopped target Paths.
[[0;32m OK [0m] Stopped Forward Password Requests to Wall Directory Watch.
[[0;32m OK [0m] Stopped Dispatch Password Requests to Console Directory Watch.
[[0;32m OK [0m] Closed D-Bus System Message Bus Socket.
[[0;32m OK [0m] Stopped target System Initialization.
[[0;32m OK [0m] Stopped target Encrypted Volumes.
Stopping Entropy daemon using the HAVEGE algorithm...
[[0;32m OK [0m] Stopped Apply Kernel Variables.
Stopping Restore / save the current clock...
[[0;32m OK [0m] Stopped Create Volatile Files and Directories.
[[0;32m OK [0m] Stopped target Local File Systems.
Unmounting /run/user/0...
[[0;32m OK [0m] Stopped target Swap.
Deactivating swap /var/swap...
[[0;32m OK [0m] Stopped Load Kernel Modules.
[[0;32m OK [0m] Stopped Entropy daemon using the HAVEGE algorithm.
[[0;32m OK [0m] Stopped Restore / save the current clock.
[[0;32m OK [0m] Unmounted /run/user/0.
[[0;32m OK [0m] Deactivated swap /var/swap.
Stopping Load/Save Random Seed...
Unmounting /tmp...
[[0;32m OK [0m] Stopped Load/Save Random Seed.
[[0;32m OK [0m] Unmounted /tmp.
[[0;32m OK [0m] Reached target Unmount All Filesystems.
[[0;32m OK [0m] Stopped target Local File Systems (Pre).
[[0;32m OK [0m] Stopped Create Static Device Nodes in /dev.
[[0;32m OK [0m] Stopped Remount Root and Kernel File Systems.
[[0;32m OK [0m] Reached target Shutdown.
[ 70.770850] Restarting system.
INFO: PSCI Affinity Map:
INFO: AffInst: Level 0, MPID 0x0, State ON
INFO: AffInst: Level 0, MPID 0x1, State OFF
INFO: AffInst: Level 0, MPID 0x2, State OFF
INFO: AffInst: Level 0, MPID 0x3, State OFF
I success to login with the user I add via ssh and I saw this output:
  File "/etc/update-motd.d/40-updates", line 145, in <module>
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
I was able to launch dmesg:
raphael@pine64:~$ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.104-pine64 (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #9 SMP PREEMPT Sun Dec 4 19:08:46 CET 2016
[ 0.000000] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000] Machine: sun50iw1p1
[ 0.000000] cma: CMA: reserved 64 MiB at 7c000000
[ 0.000000] On node 0 totalpages: 258048
[ 0.000000] DMA zone: 3528 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 258048 pages, LIFO batch:31
[ 0.000000] script_init enter!
[ 0.000000] script buffer is NULL!
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc03af99000 s19136 r8192 d21824 u49152
[ 0.000000] pcpu-alloc: s19136 r8192 d21824 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 254520
[ 0.000000] Kernel command line: root=UUID=69b144e9-56b4-4393-a834-f17af4848de5 rootfstype=ext4 rootwait console=tty1 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr=aa:bd:c5:36:27:07 panic=10 consoleblank=0 enforcing=0 loglevel=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1008MB = 1008MB total
[ 0.000000] Memory: 932924k/932924k available, 99268k reserved
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
vmemmap : 0xffffffbc00e38000 - 0xffffffbc01c00000 ( 13 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc03f000000 ( 1008 MB)
.init : 0xffffffc000a02000 - 0xffffffc000a85ac0 ( 527 kB)
.text : 0xffffffc000080000 - 0xffffffc000a01bc4 ( 9735 kB)
.data : 0xffffffc000a86000 - 0xffffffc000be1018 ( 1389 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty1] enabled
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 8.815400] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 8.815408] pid_max: default: 32768 minimum: 301
[ 8.815503] Security Framework initialized
[ 8.815548] AppArmor: AppArmor initialized
[ 8.815585] Mount-cache hash table entries: 256
[ 8.825757] Initializing cgroup subsys memory
[ 8.825800] Initializing cgroup subsys devices
[ 8.825810] Initializing cgroup subsys freezer
[ 8.825816] Initializing cgroup subsys blkio
[ 8.825821] Initializing cgroup subsys perf_event
[ 8.825832] Initializing cgroup subsys hugetlb
[ 8.825893] ftrace: allocating 27755 entries in 109 pages
[ 8.858270] CPU0: update cpu_power 1968128
[ 8.858287] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 8.859281] virtual base = 0xffffff800000a000.
[ 8.859297] gicd_base = 0xffffff800000c000.
[ 8.859301] gicc_base = 0xffffff800000e000.
[ 8.859905] CPU1: Booted secondary processor
[ 8.859928] CPU1: update cpu_power 1968128
[ 8.862530] CPU2: Booted secondary processor
[ 8.862542] CPU2: update cpu_power 1968128
[ 8.866647] CPU3: Booted secondary processor
[ 8.866658] CPU3: update cpu_power 1968128
[ 8.866744] Brought up 4 CPUs
[ 8.866765] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 8.867357] devtmpfs: initialized
[ 8.872112] atomic64 test passed
[ 8.872120] pinctrl core: initialized pinctrl subsystem
[ 8.874580] NET: Registered protocol family 16
[ 8.874857] script_sysfs_init success
[ 8.875062] dump_class_init,806, success
[ 8.875361] vdso: 2 pages (1 code, 1 data) at base ffffffc000a8d000
[ 8.875382] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 8.876633] software IO TLB [mem 0x79c00000-0x7a000000] (4MB) mapped at [ffffffc038c00000-ffffffc038ffffff]
[ 8.877646] DMA: preallocated 256 KiB pool for atomic allocations
[ 8.877770] Serial: AMBA PL011 UART driver
[ 8.877869] axp81x_board_init: axp regl_devs num = 23
[ 8.878000] pll_audio-set_default_rate=24576000 success!
[ 8.878023] pll_video0-set_default_rate=297000000 success!
[ 8.878093] pll_video1-set_default_rate=297000000 success!
[ 8.878151] pll_de-set_default_rate=297000000 success!
[ 8.878873] de-set_default_source=pll_de success!
[ 8.878879] de-set_default_rate=297000000 success!
[ 8.878922] tcon0-set_default_source=pll_mipi success!
[ 8.878954] tcon1-set_default_source=pll_video0 success!
[ 8.879178] hdmi-set_default_source=pll_video0 success!
[ 8.881383] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 8.881544] [sun50iw1p1_pinctrl_probe][838]
[ 8.883169] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 8.883816] sunxi hwspinlock vbase:0xffffff800005c000
[ 8.889352] sunxi_chipid_probe,150: soc bin:0
[ 8.889358] chipid-sunxi serial 000000000000
[ 8.894258] bio: create slab at 0
[ 8.894600] pwm module init!
[ 8.895772] SCSI subsystem initialized
[ 8.895908] usbcore: registered new interface driver usbfs
[ 8.895938] usbcore: registered new interface driver hub
[ 8.896006] usbcore: registered new device driver usb
[ 8.896718] Linux video capture interface: v2.00
[ 8.897140] [ARISC] :sunxi-arisc driver v1.10
[ 8.903567] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[ 8.903786] Advanced Linux Sound Architecture Driver Initialized.
[ 8.904122] NetLabel: Initializing
[ 8.904127] NetLabel: domain hash size = 128
[ 8.904131] NetLabel: protocols = UNLABELED CIPSOv4
[ 8.904173] NetLabel: unlabeled traffic allowed by default
[ 8.904324] [pm]aw_pm_init!
[ 8.904378] rtc physical base = 0x0000000001f00000 .
[ 8.904410] np name = /soc@01c00000/rtc@01f00000.
[ 8.904416] base = ffffff8000070100, len = 4.
[ 8.904421] pmu name: pmu0 .
[ 8.904451] pmu0_enable = 0x1.
[ 8.904457] pmux_id = 0x6.
[ 8.904464] pmux_twi_id = 0x1.
[ 8.904469] pmux_twi_addr = 0x34.
[ 8.904474] pmu name: pmu1 .
[ 8.904517] Warning: can not find np for pmu1.
[ 8.904731] add_sys_pwr_dm: get ldo name for id: vcc-lpddr failed
[ 8.904884] after inited: sys_mask config = 0x4a55.
[ 8.904906] Warning: can not find np for dynamic_standby_para.
[ 8.905017] [pm]valid
[ 8.905021] [pm]valid
[ 8.905025] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby.
[ 8.905264] Switching to clocksource arch_sys_counter
[ 8.915833] AppArmor: AppArmor Filesystem Enabled
[ 8.922607] NET: Registered protocol family 2
[ 8.923305] TCP established hash table entries: 8192 (order: 5, 131072 bytes)
[ 8.923433] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 8.923573] TCP: Hash tables configured (established 8192 bind 8192)
[ 8.923644] TCP: reno registered
[ 8.923654] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 8.923682] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 8.923876] NET: Registered protocol family 1
[ 8.924156] RPC: Registered named UNIX socket transport module.
[ 8.924161] RPC: Registered udp transport module.
[ 8.924166] RPC: Registered tcp transport module.
[ 8.924171] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 8.924325] Trying to unpack rootfs image as initramfs...
[ 9.154706] Freeing initrd memory: 4672K (ffffffc035a2a000 - ffffffc035eba000)
[ 9.155245] kvm [1]: Using HYP init bounce page @78d6a000
[ 9.155690] kvm [1]: interrupt-controller@1c84000 IRQ25
[ 9.156078] kvm [1]: timer IRQ27
[ 9.156093] kvm [1]: Hyp mode initialized successfully
[ 9.157886] lock super standby defaultly!
[ 9.157899] lookup_scene_lock_name: new scene lock super_standby
[ 9.157904] scene_lock_init name=super_standby
[ 9.157911] scene_lock: super_standby, type 5, count 1
[ 9.158295] audit: initializing netlink socket (disabled)
[ 9.158344] type=2000 audit(0.330:1): initialized
[ 9.158920] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 9.159378] VFS: Disk quotas dquot_6.5.2
[ 9.159487] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 9.159891] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 9.160422] NFS: Registering the id_resolver key type
[ 9.160468] Key type id_resolver registered
[ 9.160473] Key type id_legacy registered
[ 9.160484] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 9.160627] NTFS driver 2.1.30 [Flags: R/W].
[ 9.160787] fuse init (API version 7.22)
[ 9.160978] msgmni has been set to 1959
[ 9.162024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 9.162115] io scheduler noop registered
[ 9.162121] io scheduler deadline registered
[ 9.162146] io scheduler cfq registered (default)
[ 9.162657] [DISP]disp_module_init
[ 9.163060] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[ 9.163067] [DISP] boot_disp:0x0
[ 9.163636] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[ 9.163774] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[ 9.163911] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[ 9.164981] [DISP] disp_boot_para_parse,line:301:of_property_read disp.fb_base fail
[ 9.164987] [DISP] fb_base:0x0
[ 9.181884] Console: switching to colour frame buffer device 160x45
[ 9.194773] [DISP]disp_module_init finish
[ 9.195142] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 9.195161] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[ 9.195541] console [ttyS0] enabled
[ 9.195955] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[ 9.196189] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[ 9.196511] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[ 9.196817] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[ 9.197147] misc dump reg init
[ 9.197282] [drm] Initialized drm 1.1.0 20060810
[ 9.199529] brd: module loaded
[ 9.201839] loop: module loaded
[ 9.202070] sunxi-bt bt.26: Missing bt_power.
[ 9.202078] sunxi-bt bt.26: bt_power_name ((null))
[ 9.202086] sunxi-bt bt.26: io_regulator_name (vcc-wifi-io)
[ 9.202118] sunxi-bt bt.26: bt_rst gpio=356 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 9.202157] sunxi-bt bt.26: clk not config
[ 9.202237] sunxi-bt bt.26: block state already is 1
[ 9.202411] sunxi-wlan wlan.25: wlan_busnum (1)
[ 9.202418] sunxi-wlan wlan.25: Missing wlan_power.
[ 9.202425] sunxi-wlan wlan.25: wlan_power_name ((null))
[ 9.202433] sunxi-wlan wlan.25: io_regulator_name (vcc-wifi-io)
[ 9.202450] sunxi-wlan wlan.25: wlan_regon gpio=354 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 9.202470] sunxi-wlan wlan.25: wlan_hostwake gpio=355 mul-sel=6 pull=-1 drv_level=-1 data=0
[ 9.202486] sunxi-wlan wlan.25: clk not config
[ 9.203049] tun: Universal TUN/TAP device driver, 1.6
[ 9.203054] tun: © 1999-2004 Max Krasnyansky
[ 9.203635] WARNING: Get ephy clock is failed
[ 9.203923] PPP generic driver version 2.4.2
[ 9.204031] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.204135] get ehci0-controller drv_vbus_gpio is fail
[ 9.204141] get ehci0-controller, regulator_io is no nocare
[ 9.204188] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c8cba8, 0x:ffffff80000aa000, irq_no:68
[ 9.204236] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.204255] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 9.204605] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0004fc3dc
[ 9.220196] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 9.220581] hub 1-0:1.0: USB hub found
[ 9.220597] hub 1-0:1.0: 1 port detected
[ 9.220732] scene_lock_init name=ehci_standby
[ 9.220814] get ehci1-controller drv_vbus_gpio is fail
[ 9.220820] get ehci1-controller, regulator_io is no nocare
[ 9.220862] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000c8cdf8, 0x:ffffff80000b2000, irq_no:6a
[ 9.220905] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 9.220922] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[ 9.221200] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc0004fc3dc
[ 9.239911] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[ 9.240264] hub 2-0:1.0: USB hub found
[ 9.240279] hub 2-0:1.0: 1 port detected
[ 9.240402] scene_lock_init name=ehci_standby
[ 9.240572] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 9.240714] get ohci0-controller drv_vbus_gpio is fail
[ 9.240720] get ohci0-controller, regulator_io is no nocare
[ 9.240760] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c8c708
[ 9.240806] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 9.240822] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[ 9.240850] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x652c6a626e6b61ff
[ 9.303155] hub 3-0:1.0: USB hub found
[ 9.303169] hub 3-0:1.0: 1 port detected
[ 9.303290] scene_lock_init name=ohci_standby
[ 9.303347] get ohci1-controller drv_vbus_gpio is fail
[ 9.303352] get ohci1-controller, regulator_io is no nocare
[ 9.303386] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000c8c958
[ 9.303424] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 9.303440] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[ 9.303465] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x652c6a626e6b61ff
[ 9.362212] hub 4-0:1.0: USB hub found
[ 9.362229] hub 4-0:1.0: 1 port detected
[ 9.362350] scene_lock_init name=ohci_standby
[ 9.362623] usbcore: registered new interface driver usb-storage
[ 9.362654] usbcore: registered new interface driver ums-alauda
[ 9.362679] usbcore: registered new interface driver ums-cypress
[ 9.362705] usbcore: registered new interface driver ums-datafab
[ 9.362728] usbcore: registered new interface driver ums_eneub6250
[ 9.362752] usbcore: registered new interface driver ums-freecom
[ 9.362777] usbcore: registered new interface driver ums-isd200
[ 9.362802] usbcore: registered new interface driver ums-jumpshot
[ 9.362825] usbcore: registered new interface driver ums-karma
[ 9.362852] usbcore: registered new interface driver ums-onetouch
[ 9.362885] usbcore: registered new interface driver ums-realtek
[ 9.362910] usbcore: registered new interface driver ums-sddr09
[ 9.362935] usbcore: registered new interface driver ums-sddr55
[ 9.362959] usbcore: registered new interface driver ums-usbat
[ 9.363037] usbcore: registered new interface driver usbserial
[ 9.363066] usbcore: registered new interface driver usbserial_generic
[ 9.363090] usbserial: USB Serial support registered for generic
[ 9.363303] mousedev: PS/2 mouse device common for all mice
[ 9.363710] input: sunxi-keyboard as /devices/virtual/input/input0
[ 9.364484] get ctp_para failed, -1
[ 9.364511] get_detect_list name = sc7a30
[ 9.364517] get_detect_list name = lsm303d
[ 9.364524] get_detect_list name = fxos8700
[ 9.364530] get_detect_list name = mxc622x
[ 9.364536] get_detect_list name = dmard06
[ 9.364543] get_detect_list name = dmard10
[ 9.364548] get_detect_list name = kxtik
[ 9.364553] get_detect_list name = lis3dh_acc
[ 9.364560] get_detect_list name = lis3de_acc
[ 9.364566] get_detect_list name = afa750
[ 9.364571] get_detect_list name = mc32x0
[ 9.364576] get_detect_list: script_get_item err.support_number = 6.
[ 9.364581] get_detect_list name = mma865x
[ 9.364586] get_detect_list name = mma7660
[ 9.364591] get_detect_list name = mma8452
[ 9.364596] get_detect_list name = stk831x
[ 9.364601] get_detect_list: script_get_item err.support_number = 2.
[ 9.364606] get_detect_list name = bma250
[ 9.364610] get_detect_list name = lsm9ds0_acc_mag
[ 9.364636] sw_get_write_info:open error ....IS(filp):1
[ 9.364647] sw_set_write_info:open error ....IS(filp):1
[ 9.364652] get write info erro!
[ 9.364728] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[ 9.364748] sunxi-rtc 1f00000.rtc: RTC enabled
[ 9.364810] twi_start()370 - [i2c1] START can't sendout!
[ 9.364912] i2c /dev entries driver
[ 9.365057] twi_start()370 - [i2c1] START can't sendout!
[ 9.365302] twi_start()370 - [i2c1] START can't sendout!
[ 9.377788] twi_start()370 - [i2c1] START can't sendout!
[ 9.378035] twi_start()370 - [i2c1] START can't sendout!
[ 9.378281] twi_start()370 - [i2c1] START can't sendout!
[ 9.397451] twi_start()370 - [i2c1] START can't sendout!
[ 9.397697] twi_start()370 - [i2c1] START can't sendout!
[ 9.397890] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[ 9.397944] twi_start()370 - [i2c1] START can't sendout!
[ 9.401339] sunxi budget cooling probe start !
[ 9.401364] CPU freq cooling register Success
[ 9.401382] CPU hotplug cooling register Success
[ 9.401460] thermal thermal_zone0: binding zone soc_thermal with cdev sunxi-budget failed:-22
[ 9.401468] CPU budget cooling register Success
[ 9.401668] sunxi gpu cooling probe start !
[ 9.401678] CPU gpu cooling register Success
[ 9.402224] cpuidle: using governor ladder
[ 9.402231] cpuidle: using governor menu
[ 9.402996] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Dec 4 2016 at 19:08:30
[ 9.403021] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[ 9.403031] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[ 9.403039] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[ 9.403090] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[ 9.403097] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[ 9.403549] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[ 9.403651] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.403672] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[ 9.417012] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.417154] twi_start()370 - [i2c1] START can't sendout!
[ 9.417401] twi_start()370 - [i2c1] START can't sendout!
[ 9.417647] twi_start()370 - [i2c1] START can't sendout!
[ 9.436694] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000d8000 irq:92
[ 9.436815] twi_start()370 - [i2c1] START can't sendout!
[ 9.437061] twi_start()370 - [i2c1] START can't sendout!
[ 9.437130] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Dec 4 2016 at 19:08:30
[ 9.437155] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[ 9.437163] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[ 9.437170] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[ 9.437174] get() with no identifier
[ 9.437178] get() with no identifier
[ 9.437181] get() with no identifier
[ 9.437188] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[ 9.437194] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[ 9.437200] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[ 9.437330] twi_start()370 - [i2c1] START can't sendout!
[ 9.437650] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.437669] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[ 9.456391] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.456506] twi_start()370 - [i2c1] START can't sendout!
[ 9.456752] twi_start()370 - [i2c1] START can't sendout!
[ 9.456998] twi_start()370 - [i2c1] START can't sendout!
[ 9.476087] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000e0000 irq:93
[ 9.476182] twi_start()370 - [i2c1] START can't sendout!
[ 9.476406] hidraw: raw HID events driver © Jiri Kosina
[ 9.476430] twi_start()370 - [i2c1] START can't sendout!
[ 9.476516] usbcore: registered new interface driver usbhid
[ 9.476521] usbhid: USB HID core driver
[ 9.476676] twi_start()370 - [i2c1] START can't sendout!
[ 9.477439] usbcore: registered new interface driver snd-usb-audio
[ 9.479495] sndhdmi sound.7: sndhdmi <-> 1c22800.daudio mapping ok
[ 9.480264] gre: GRE over IPv4 demultiplexor driver
[ 9.480335] TCP: cubic registered
[ 9.480342] Initializing XFRM netlink socket
[ 9.480425] NET: Registered protocol family 10
[ 9.481134] mip6: Mobile IPv6
[ 9.481142] sit: IPv6 over IPv4 tunneling driver
[ 9.481496] NET: Registered protocol family 17
[ 9.481515] NET: Registered protocol family 15
[ 9.481560] 8021q: 802.1Q VLAN Support v1.8
[ 9.481603] Key type dns_resolver registered
[ 9.481836] Registering SWP/SWPB emulation handler
[ 9.482142] registered taskstats version 1
[ 9.493521] Key type encrypted registered
[ 9.493540] AppArmor: AppArmor sha1 policy hashing enabled
[ 9.493924] [DISP] disp_boot_para_parse,line:301:of_property_read disp.boot_disp fail
[ 9.493932] [DISP] boot_disp:0x0
[ 9.494693] [HDMI] power vcc-hdmi-33
[ 9.495215] [HDMI] cec support = 0
[ 9.495902] twi_start()370 - [i2c1] START can't sendout!
[ 9.496149] twi_start()370 - [i2c1] START can't sendout!
[ 9.496395] twi_start()370 - [i2c1] START can't sendout!
[ 9.515537] twi_start()370 - [i2c1] START can't sendout!
[ 9.515784] twi_start()370 - [i2c1] START can't sendout!
[ 9.516029] twi_start()370 - [i2c1] START can't sendout!
[ 9.535240] twi_start()370 - [i2c1] START can't sendout!
[ 9.535487] twi_start()370 - [i2c1] START can't sendout!
[ 9.535734] twi_start()370 - [i2c1] START can't sendout!
[ 9.535924] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 9.536745] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[ 9.536767] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.539165] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.541295] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.542109] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.542920] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.543732] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[ 9.544362] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.544405] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.546780] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 9.554903] twi_start()370 - [i2c1] START can't sendout!
[ 9.555150] twi_start()370 - [i2c1] START can't sendout!
[ 9.555395] twi_start()370 - [i2c1] START can't sendout!
[ 9.571290] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 9.572990] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 9.573035] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 9.573138] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 9.573162] mmc0: new high speed SDHC card at address 0001
[ 9.573546] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 9.574489] mmcblk0: p1
[ 9.574584] twi_start()370 - [i2c1] START can't sendout!
[ 9.574830] twi_start()370 - [i2c1] START can't sendout!
[ 9.575076] twi_start()370 - [i2c1] START can't sendout!
[ 9.575583] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 9.576394] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 9.576414] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.578801] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.580621] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[ 9.581430] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.582239] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.583046] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.583853] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 9.584663] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.585472] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.586281] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.587091] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[ 9.587109] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 9.587946] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[ 9.587965] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 9.594260] twi_start()370 - [i2c1] START can't sendout!
[ 9.594507] twi_start()370 - [i2c1] START can't sendout!
[ 9.594753] twi_start()370 - [i2c1] START can't sendout!
[ 9.595747] input: sunxi-ths as /devices/virtual/input/input2
[ 9.595890] thermal thermal_zone0: failed to read out thermal zone 0
[ 9.596247] ALSA device list:
[ 9.596253] #0: sndhdmi
[ 9.596660] Freeing unused kernel memory: 524K (ffffffc000a02000 - ffffffc000a85000)
[ 9.613982] twi_start()370 - [i2c1] START can't sendout!
[ 9.614234] twi_start()370 - [i2c1] START can't sendout!
[ 9.614481] twi_start()370 - [i2c1] START can't sendout!
[ 9.633694] twi_start()370 - [i2c1] START can't sendout!
[ 9.633954] twi_start()370 - [i2c1] START can't sendout!
[ 9.634203] twi_start()370 - [i2c1] START can't sendout!
[ 9.653389] twi_start()370 - [i2c1] START can't sendout!
[ 9.653641] twi_start()370 - [i2c1] START can't sendout!
[ 9.653887] twi_start()370 - [i2c1] START can't sendout!
[ 9.673024] twi_start()370 - [i2c1] START can't sendout!
[ 9.673275] twi_start()370 - [i2c1] START can't sendout!
[ 9.673521] twi_start()370 - [i2c1] START can't sendout!
[ 9.692728] twi_start()370 - [i2c1] START can't sendout!
[ 9.692980] twi_start()370 - [i2c1] START can't sendout!
[ 9.693226] twi_start()370 - [i2c1] START can't sendout!
[ 9.712395] twi_start()370 - [i2c1] START can't sendout!
[ 9.712647] twi_start()370 - [i2c1] START can't sendout!
[ 9.712893] twi_start()370 - [i2c1] START can't sendout!
[ 9.732033] twi_start()370 - [i2c1] START can't sendout!
[ 9.732285] twi_start()370 - [i2c1] START can't sendout!
[ 9.732531] twi_start()370 - [i2c1] START can't sendout!
[ 9.751784] twi_start()370 - [i2c1] START can't sendout!
[ 9.752034] twi_start()370 - [i2c1] START can't sendout!
[ 9.752280] twi_start()370 - [i2c1] START can't sendout!
[ 9.771435] twi_start()370 - [i2c1] START can't sendout!
[ 9.771691] twi_start()370 - [i2c1] START can't sendout!
[ 9.771940] twi_start()370 - [i2c1] START can't sendout!
[ 9.791107] twi_start()370 - [i2c1] START can't sendout!
[ 9.791359] twi_start()370 - [i2c1] START can't sendout!
[ 9.791606] twi_start()370 - [i2c1] START can't sendout!
[ 9.810877] twi_start()370 - [i2c1] START can't sendout!
[ 9.811131] twi_start()370 - [i2c1] START can't sendout!
[ 9.811377] twi_start()370 - [i2c1] START can't sendout!
[ 9.830476] twi_start()370 - [i2c1] START can't sendout!
[ 9.830728] twi_start()370 - [i2c1] START can't sendout!
[ 9.830974] twi_start()370 - [i2c1] START can't sendout!
[ 9.850159] twi_start()370 - [i2c1] START can't sendout!
[ 9.850414] twi_start()370 - [i2c1] START can't sendout!
[ 9.850660] twi_start()370 - [i2c1] START can't sendout!
[ 9.869824] twi_start()370 - [i2c1] START can't sendout!
[ 9.870079] twi_start()370 - [i2c1] START can't sendout!
[ 9.870325] twi_start()370 - [i2c1] START can't sendout!
[ 9.889504] twi_start()370 - [i2c1] START can't sendout!
[ 9.889757] twi_start()370 - [i2c1] START can't sendout!
[ 9.890003] twi_start()370 - [i2c1] START can't sendout!
[ 9.909225] twi_start()370 - [i2c1] START can't sendout!
[ 9.909501] twi_start()370 - [i2c1] START can't sendout!
[ 9.909747] twi_start()370 - [i2c1] START can't sendout!
[ 9.928879] twi_start()370 - [i2c1] START can't sendout!
[ 9.929132] twi_start()370 - [i2c1] START can't sendout!
[ 9.929378] twi_start()370 - [i2c1] START can't sendout!
[ 9.948542] twi_start()370 - [i2c1] START can't sendout!
[ 9.948795] twi_start()370 - [i2c1] START can't sendout!
[ 9.949041] twi_start()370 - [i2c1] START can't sendout!
[ 9.968266] twi_start()370 - [i2c1] START can't sendout!
[ 9.968519] twi_start()370 - [i2c1] START can't sendout!
[ 9.968765] twi_start()370 - [i2c1] START can't sendout!
[ 9.987883] twi_start()370 - [i2c1] START can't sendout!
[ 9.988135] twi_start()370 - [i2c1] START can't sendout!
[ 9.988381] twi_start()370 - [i2c1] START can't sendout!
[ 10.007547] twi_start()370 - [i2c1] START can't sendout!
[ 10.007796] twi_start()370 - [i2c1] START can't sendout!
[ 10.008042] twi_start()370 - [i2c1] START can't sendout!
[ 10.027238] twi_start()370 - [i2c1] START can't sendout!
[ 10.027484] twi_start()370 - [i2c1] START can't sendout!
[ 10.027730] twi_start()370 - [i2c1] START can't sendout!
[ 10.046900] twi_start()370 - [i2c1] START can't sendout!
[ 10.047146] twi_start()370 - [i2c1] START can't sendout!
[ 10.047392] twi_start()370 - [i2c1] START can't sendout!
[ 10.066617] twi_start()370 - [i2c1] START can't sendout!
[ 10.066871] twi_start()370 - [i2c1] START can't sendout!
[ 10.067117] twi_start()370 - [i2c1] START can't sendout!
[ 10.086290] twi_start()370 - [i2c1] START can't sendout!
[ 10.086542] twi_start()370 - [i2c1] START can't sendout!
[ 10.086788] twi_start()370 - [i2c1] START can't sendout!
[ 10.105943] twi_start()370 - [i2c1] START can't sendout!
[ 10.106190] twi_start()370 - [i2c1] START can't sendout!
[ 10.106435] twi_start()370 - [i2c1] START can't sendout!
[ 10.125611] twi_start()370 - [i2c1] START can't sendout!
[ 10.125858] twi_start()370 - [i2c1] START can't sendout!
[ 10.126104] twi_start()370 - [i2c1] START can't sendout!
[ 10.145307] twi_start()370 - [i2c1] START can't sendout!
[ 10.145554] twi_start()370 - [i2c1] START can't sendout!
[ 10.145800] twi_start()370 - [i2c1] START can't sendout!
[ 10.164989] twi_start()370 - [i2c1] START can't sendout!
[ 10.165236] twi_start()370 - [i2c1] START can't sendout!
[ 10.165483] twi_start()370 - [i2c1] START can't sendout!
[ 10.184692] twi_start()370 - [i2c1] START can't sendout!
[ 10.184938] twi_start()370 - [i2c1] START can't sendout!
[ 10.185184] twi_start()370 - [i2c1] START can't sendout!
[ 10.194376] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device1, type=4, mode=5
[ 10.204338] twi_start()370 - [i2c1] START can't sendout!
[ 10.204585] twi_start()370 - [i2c1] START can't sendout!
[ 10.204831] twi_start()370 - [i2c1] START can't sendout!
[ 10.224026] twi_start()370 - [i2c1] START can't sendout!
[ 10.224273] twi_start()370 - [i2c1] START can't sendout!
[ 10.224519] twi_start()370 - [i2c1] START can't sendout!
[ 10.243610] raid6: int64x1 289 MB/s
[ 10.243706] twi_start()370 - [i2c1] START can't sendout!
[ 10.243953] twi_start()370 - [i2c1] START can't sendout!
[ 10.244199] twi_start()370 - [i2c1] START can't sendout!
[ 10.263378] twi_start()370 - [i2c1] START can't sendout!
[ 10.263624] twi_start()370 - [i2c1] START can't sendout!
[ 10.263870] twi_start()370 - [i2c1] START can't sendout!
[ 10.283058] twi_start()370 - [i2c1] START can't sendout!
[ 10.283305] twi_start()370 - [i2c1] START can't sendout!
[ 10.283551] twi_start()370 - [i2c1] START can't sendout!
[ 10.302738] twi_start()370 - [i2c1] START can't sendout!
[ 10.302984] twi_start()370 - [i2c1] START can't sendout!
[ 10.303230] twi_start()370 - [i2c1] START can't sendout!
[ 10.322417] twi_start()370 - [i2c1] START can't sendout!
[ 10.322663] twi_start()370 - [i2c1] START can't sendout!
[ 10.322909] twi_start()370 - [i2c1] START can't sendout!
[ 10.342117] twi_start()370 - [i2c1] START can't sendout!
[ 10.342363] twi_start()370 - [i2c1] START can't sendout!
[ 10.342609] twi_start()370 - [i2c1] START can't sendout!
[ 10.361777] twi_start()370 - [i2c1] START can't sendout!
[ 10.362024] twi_start()370 - [i2c1] START can't sendout!
[ 10.362270] twi_start()370 - [i2c1] START can't sendout!
[ 10.381469] twi_start()370 - [i2c1] START can't sendout!
[ 10.381715] twi_start()370 - [i2c1] START can't sendout!
[ 10.381961] twi_start()370 - [i2c1] START can't sendout!
[ 10.401137] twi_start()370 - [i2c1] START can't sendout!
[ 10.401384] twi_start()370 - [i2c1] START can't sendout!
[ 10.401629] twi_start()370 - [i2c1] START can't sendout!
[ 10.410823] raid6: int64x2 474 MB/s
[ 10.420817] twi_start()370 - [i2c1] START can't sendout!
[ 10.421063] twi_start()370 - [i2c1] START can't sendout!
[ 10.421309] twi_start()370 - [i2c1] START can't sendout!
[ 10.440498] twi_start()370 - [i2c1] START can't sendout!
[ 10.440744] twi_start()370 - [i2c1] START can't sendout!
[ 10.440990] twi_start()370 - [i2c1] START can't sendout!
[ 10.460177] twi_start()370 - [i2c1] START can't sendout!
[ 10.460423] twi_start()370 - [i2c1] START can't sendout!
[ 10.460669] twi_start()370 - [i2c1] START can't sendout!
[ 10.479857] twi_start()370 - [i2c1] START can't sendout!
[ 10.480103] twi_start()370 - [i2c1] START can't sendout!
[ 10.480349] twi_start()370 - [i2c1] START can't sendout!
[ 10.499537] twi_start()370 - [i2c1] START can't sendout!
[ 10.499783] twi_start()370 - [i2c1] START can't sendout!
[ 10.500029] twi_start()370 - [i2c1] START can't sendout!
[ 10.519217] twi_start()370 - [i2c1] START can't sendout!
[ 10.519463] twi_start()370 - [i2c1] START can't sendout!
[ 10.519709] twi_start()370 - [i2c1] START can't sendout!
[ 10.538911] twi_start()370 - [i2c1] START can't sendout!
[ 10.539158] twi_start()370 - [i2c1] START can't sendout!
[ 10.539403] twi_start()370 - [i2c1] START can't sendout!
[ 10.558577] twi_start()370 - [i2c1] START can't sendout!
[ 10.558824] twi_start()370 - [i2c1] START can't sendout!
[ 10.559070] twi_start()370 - [i2c1] START can't sendout!
[ 10.578110] raid6: int64x4 750 MB/s
[ 10.578267] twi_start()370 - [i2c1] START can't sendout!
[ 10.578514] twi_start()370 - [i2c1] START can't sendout!
[ 10.578760] twi_start()370 - [i2c1] START can't sendout!
[ 10.597942] twi_start()370 - [i2c1] START can't sendout!
[ 10.598188] twi_start()370 - [i2c1] START can't sendout!
[ 10.598434] twi_start()370 - [i2c1] START can't sendout!
[ 10.617625] twi_start()370 - [i2c1] START can't sendout!
[ 10.617872] twi_start()370 - [i2c1] START can't sendout!
[ 10.618118] twi_start()370 - [i2c1] START can't sendout!
[ 10.637306] twi_start()370 - [i2c1] START can't sendout!
[ 10.637553] twi_start()370 - [i2c1] START can't sendout!
[ 10.637799] twi_start()370 - [i2c1] START can't sendout!
[ 10.656983] twi_start()370 - [i2c1] START can't sendout!
[ 10.657230] twi_start()370 - [i2c1] START can't sendout!
[ 10.657476] twi_start()370 - [i2c1] START can't sendout!
[ 10.676654] twi_start()370 - [i2c1] START can't sendout!
[ 10.676901] twi_start()370 - [i2c1] START can't sendout!
[ 10.677147] twi_start()370 - [i2c1] START can't sendout!
[ 10.696334] twi_start()370 - [i2c1] START can't sendout!
[ 10.696581] twi_start()370 - [i2c1] START can't sendout!
[ 10.696827] twi_start()370 - [i2c1] START can't sendout!
[ 10.716018] twi_start()370 - [i2c1] START can't sendout!
[ 10.716264] twi_start()370 - [i2c1] START can't sendout!
[ 10.716510] twi_start()370 - [i2c1] START can't sendout!
[ 10.735567] get node lightsensor failed
[ 10.735573] get sysconfig para erro!
[ 10.735583] get node gyroscopesensor failed
[ 10.735587] get sysconfig para erro!
[ 10.735597] get node compasssensor failed
[ 10.735600] get sysconfig para erro!
[ 10.745460] raid6: int64x8 549 MB/s
[ 10.745465] raid6: using algorithm int64x4 (750 MB/s)
[ 10.745470] raid6: using intx1 recovery algorithm
[ 10.746044] xor: measuring software checksum speed
[ 10.735622] wakeup gpio set err!get node ctp failed
[ 10.794616] get sysconfig para erro!
[ 10.843800] 8regs : 1813.200 MB/sec
[ 10.942188] 8regs_prefetch: 1626.000 MB/sec
[ 11.040582] 32regs : 2271.600 MB/sec
[ 11.138982] 32regs_prefetch: 1874.400 MB/sec
[ 11.138988] xor: using function: 32regs (2271.600 MB/sec)
[ 11.152406] bio: create slab at 1
[ 11.153861] Btrfs loaded
[ 11.499781] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[ 11.824568] systemd[1]: System time before build time, advancing clock.
[ 11.850716] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 11.851010] systemd[1]: Detected architecture arm64.
[ 11.877756] systemd[1]: Set hostname to .
[ 12.168066] systemd[1]: Reached target User and Group Name Lookups.
[ 12.192534] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.211656] systemd[1]: Reached target Encrypted Volumes.
[ 12.231501] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.251142] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.270752] systemd[1]: Listening on Syslog Socket.
[ 12.290448] systemd[1]: Listening on udev Control Socket.
[ 12.310377] systemd[1]: Created slice User and Session Slice.
[ 12.329821] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.349394] systemd[1]: Reached target Remote File Systems (Pre).
[ 12.369053] systemd[1]: Reached target Remote File Systems.
[ 12.388825] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.408695] systemd[1]: Created slice System Slice.
[ 12.428124] systemd[1]: Reached target Slices.
[ 12.448089] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.467749] systemd[1]: Listening on udev Kernel Socket.
[ 12.487280] systemd[1]: Listening on Journal Socket.
[ 12.510145] systemd[1]: Starting Load Kernel Modules...
[ 12.528501] systemd[1]: Starting Set console keymap...
[ 12.539401] sunxi-codec-machine sound.6: codec-aif1 <-> 1c22c00.i2s0-controller mapping ok
[ 12.539655] sunxi-codec-machine sound.6: codec-aif2 <-> bb-dai mapping ok
[ 12.539917] sunxi-codec-machine sound.6: codec-aif2 <-> bb-dai mapping ok
[ 12.540054] sunxi-codec-machine sound.6: codec-aif3 <-> bb-dai mapping ok
[ 12.541231] input: audiocodec sunxi Audio Jack as /devices/soc.0/sound.6/sound/card1/input3
[ 12.542034] SUNXI_HMIC_STS:8,225
[ 12.546170] plugout_end:switch:0
[ 12.548027] systemd[1]: Starting Nameserver information manager...
[ 12.568019] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.587509] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.607780] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 12.611138] cfg80211: Calling CRDA to update world regulatory domain
[ 12.627937] systemd[1]: Mounting Debug File System...
[ 12.646556] systemd[1]: Mounting Huge Pages File System...
[ 12.751109] systemd[1]: Starting Restore / save the current clock...
[ 12.783928] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[ 12.784093] RTL871X: module init start
[ 12.784100] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[ 12.784106] RTL871X: build time: Dec 4 2016 19:08:37
[ 12.784111] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[ 12.784124] sunxi-wlan wlan.25: bus_index: 1
[ 12.784259] sunxi-wlan wlan.25: check wlan io_regulator voltage: 1800000
[ 12.788503] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 12.816019] systemd[1]: Mounted Debug File System.
[ 12.831742] systemd[1]: Mounted POSIX Message Queue File System.
[ 12.851304] systemd[1]: Mounted Huge Pages File System.
[ 12.870846] [ehci0-controller]: sunxi_usb_disable_ehci
[ 12.870860] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c8cba8
[ 12.870879] scene_lock_destroy name=ehci_standby
[ 12.870891] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[ 12.870910] usb usb1: USB disconnect, device number 1
[ 12.871395] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[ 12.871429] [ohci0-controller]: sunxi_usb_disable_ohci
[ 12.871437] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c8c708
[ 12.871442] scene_lock_destroy name=ohci_standby
[ 12.871450] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[ 12.871467] usb usb3: USB disconnect, device number 1
[ 12.871826] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[ 12.871857] [ehci0-controller]: sunxi_usb_enable_ehci
[ 12.871865] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000c8cba8, 0x:ffffff80000aa000, irq_no:68
[ 12.871907] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 12.871929] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 12.873743] systemd[1]: Started Remount Root and Kernel File Systems.
[ 12.874684] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0x5568b4e000
[ 12.890553] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 12.891101] hub 1-0:1.0: USB hub found
[ 12.891122] hub 1-0:1.0: 1 port detected
[ 12.891276] scene_lock_init name=ehci_standby
[ 12.891284] [ohci0-controller]: sunxi_usb_enable_ohci
[ 12.891292] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000c8c708
[ 12.891338] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 12.891357] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[ 12.891393] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x000000d2
[ 12.892227] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 12.892687] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.892778] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[ 12.892869] RTL871X: module init ret=0
[ 12.910238] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.911232] systemd[1]: Started Load Kernel Modules.
[ 12.930722] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 12.930862] systemd[1]: Started Set console keymap.
[ 12.931545] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 12.931567] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.933974] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 12.935797] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[ 12.936143] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[ 12.945574] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 12.945621] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[ 12.945692] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[ 12.946325] mmc1: new high speed SDIO card at address 0001
[ 12.951046] systemd[1]: Started Restore / save the current clock.
[ 12.953959] hub 3-0:1.0: USB hub found
[ 12.953976] hub 3-0:1.0: 1 port detected
[ 12.954120] scene_lock_init name=ohci_standby
[ 12.971076] systemd[1]: Started Nameserver information manager.
[ 12.981820] RTL871X: rtw_ndev_init(wlan0)
[ 12.982645] RTL871X: rtw_ndev_init(wlan1)
[ 12.997824] systemd[1]: Time has been changed
[ 13.078092] systemd[1]: Mounting Configuration File System...
[ 13.099148] systemd[1]: Mounting FUSE Control File System...
[ 13.118911] systemd[1]: Starting Apply Kernel Variables...
[ 13.138676] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 13.157919] systemd[1]: Activating swap /var/swap...
[ 13.179052] systemd[1]: Starting udev Coldplug all Devices...
[ 13.197711] systemd[1]: Starting Load/Save Random Seed...
[ 13.217399] systemd[1]: Mounted FUSE Control File System.
[ 13.235300] systemd[1]: Mounted Configuration File System.
[ 13.250388] Adding 131068k swap on /var/swap. Priority:-1 extents:3 across:606204k SS
[ 13.255013] systemd[1]: Activated swap /var/swap.
[ 13.276143] systemd[1]: Started Apply Kernel Variables.
[ 13.294866] systemd[1]: Started Create Static Device Nodes in /dev.
[ 13.316327] systemd[1]: Started Load/Save Random Seed.
[ 13.393159] systemd[1]: Starting udev Kernel Device Manager...
[ 13.412228] systemd[1]: Reached target Local File Systems (Pre).
[ 13.434446] systemd[1]: Mounting /tmp...
[ 13.451656] systemd[1]: Reached target Swap.
[ 13.473911] systemd[1]: Mounted /tmp.
[ 13.491895] systemd[1]: Started udev Coldplug all Devices.
[ 13.511996] systemd[1]: Started udev Kernel Device Manager.
[ 13.685492] systemd[1]: Reached target Sound Card.
[ 13.697664] systemd[1]: Reached target Local File Systems.
[ 13.719572] systemd[1]: Starting Set console font and keymap...
[ 13.747582] systemd[1]: Starting Raise network interfaces...
[ 13.809428] systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
[ 13.828286] systemd[1]: Starting Journal Service...
[ 14.000406] RTL871X: module init start
[ 14.000424] RTL871X: rtl8723bs-vq0 v4.3.16_13854.20150410_BTCOEX20150119-5844
[ 14.000429] RTL871X: build time: Dec 4 2016 19:08:36
[ 14.000434] RTL871X: rtl8723bs-vq0 BT-Coex version = BTCOEX20150119-5844
[ 14.000449] sunxi-wlan wlan.25: bus_index: 1
[ 14.010812] cfg80211: World regulatory domain updated:
[ 14.010829] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 14.010836] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 14.010842] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 14.010848] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 14.010853] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 14.010859] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 14.010864] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 14.010870] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 14.010876] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 14.088758] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 14.117713] systemd[1]: Starting Load/Save RF Kill Switch Status...
[ 14.122149] RTL871X: module init ret=0
[ 14.149107] systemd[1]: Started Journal Service.
[ 14.170783] sunxi-bt bt.26: block state already is 1
[ 14.303969] systemd-journald[309]: Received request to flush runtime journal from PID 1
[ 14.352124] ------------[ cut here ]------------
[ 14.352156] WARNING: at drivers/clk/clk.c:781 __clk_disable+0x40/0x78()
[ 14.352162] Modules linked in: 8723bs_vq0 8723bs cfg80211 sunxi_sndcodec sunxi_i2s sunxi_codec btrfs xor raid6_pq
[ 14.352190] CPU: 3 PID: 287 Comm: alsactl Not tainted 3.10.104-pine64 #9
[ 14.352196] Call trace:
[ 14.354952] [] dump_backtrace+0x0/0x118
[ 14.354959] [] show_stack+0x24/0x30
[ 14.354970] [] dump_stack+0x20/0x28
[ 14.354978] [] warn_slowpath_common+0x80/0xa8
[ 14.354986] [] warn_slowpath_null+0x3c/0x4c
[ 14.354993] [] __clk_disable+0x40/0x78
[ 14.355001] [] clk_disable+0x28/0x3c
[ 14.355018] [] $x+0x100/0x198 [sunxi_codec]
[ 14.355027] [] snd_ctl_elem_write+0xd4/0x148
[ 14.355034] [] snd_ctl_ioctl+0x3b4/0x708
[ 14.355044] [] vfs_ioctl+0x4c/0x6c
[ 14.355051] [] do_vfs_ioctl+0x4a4/0x538
[ 14.355057] [] SyS_ioctl+0x68/0x98
[ 14.355063] ---[ end trace 090ab137063ed21d ]---
[ 14.355069] ------------[ cut here ]------------
[ 14.355076] WARNING: at drivers/clk/clk.c:690 __clk_unprepare+0x34/0x84()
[ 14.355080] Modules linked in: 8723bs_vq0 8723bs cfg80211 sunxi_sndcodec sunxi_i2s sunxi_codec btrfs xor raid6_pq
[ 14.355100] CPU: 3 PID: 287 Comm: alsactl Tainted: G W 3.10.104-pine64 #9
[ 14.355104] Call trace:
[ 14.358137] [] dump_backtrace+0x0/0x118
[ 14.358151] [] show_stack+0x24/0x30
[ 14.358160] [] dump_stack+0x20/0x28
[ 14.358168] [] warn_slowpath_common+0x80/0xa8
[ 14.358175] [] warn_slowpath_null+0x3c/0x4c
[ 14.358182] [] __clk_unprepare+0x34/0x84
[ 14.358188] [] clk_unprepare+0x24/0x34
[ 14.358203] [] $x+0x108/0x198 [sunxi_codec]
[ 14.358212] [] snd_ctl_elem_write+0xd4/0x148
[ 14.358222] [] snd_ctl_ioctl+0x3b4/0x708
[ 14.358230] [] vfs_ioctl+0x4c/0x6c
[ 14.358237] [] do_vfs_ioctl+0x4a4/0x538
[ 14.358243] [] SyS_ioctl+0x68/0x98
[ 14.358249] ---[ end trace 090ab137063ed21e ]---
[ 14.420618] sunxi cedar version 0.1
[ 14.420771] [cedar]: install start!!!
[ 14.420860] ycy the get irq is 90
[ 14.421159] ycy clk_bass_vir 0x18 is ffffff80015d6018, the value:3006207
[ 14.421168] ycy clk_bass_vir 0x13c is ffffff80015d613c, the value:0
[ 14.421174] ycy clk_bass_vir 0x64 is ffffff80015d6064, the value:601810
[ 14.421180] ycy clk_bass_vir 0x2c4 is ffffff80015d62c4, the value:601c10
[ 14.421185] ycy clk_bass_vir 0x100 is ffffff80015d6100, the value:0
[ 14.421189] [cedar]: install end!!!
[ 14.497628] [VFE]cci probe end cci_sel = 0!
[ 14.497870] [VFE]cci_init end
[ 14.505755] Registered IR keymap rc_map_sunxi
[ 14.506390] input: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0/input4
[ 14.506601] rc0: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0
[ 14.516821] IR NEC protocol handler initialized
[ 14.517775] IR RC5(x) protocol handler initialized
[ 14.530020] IR RC6 protocol handler initialized
[ 14.530575] IR JVC protocol handler initialized
[ 14.542291] [VFE]Welcome to Video Front End driver
[ 14.546270] IR Sony protocol handler initialized
[ 14.546273] IR SANYO protocol handler initialized
[ 14.549005] [VFE]csi probe end csi_sel = 0!
[ 14.549229] [VFE]csi_init end
[ 14.549587] [VFE]isp probe start isp_sel = 0!
[ 14.551539] [iSP] isp platform_id = 3!
[ 14.551560] [VFE]isp probe end isp_sel = 0!
[ 14.551641] [VFE]sunxi_isp_platform_register end
[ 14.552002] [VFE]mipi probe start mipi_sel = 0!
[ 14.552026] [VFE]mipi probe end mipi_sel = 0!
[ 14.552078] [VFE]mipi_init end
[ 14.552085] [VFE]flash_init end
[ 14.552358] [VFE]vfe_init end
[ 14.555389] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input5
[ 14.555695] IR MCE Keyboard/mouse protocol handler initialized
[ 14.572579] lirc_dev: IR Remote Control driver registered, major 248
[ 14.574877] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
[ 14.574893] IR LIRC bridge handler initialized
[ 14.647633] ------------[ cut here ]------------
[ 14.647663] WARNING: at drivers/clk/clk.c:781 __clk_disable+0x40/0x78()
[ 14.647669] Modules linked in: ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sanyo_decoder ir_sony_decoder vfe_v4l2 ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder ir_nec_decoder sunxi_ir_rx videobuf2_dma_contig videobuf2_memops vfe_io videobuf2_core ss cedar_ve 8723bs_vq0 8723bs cfg80211 sunxi_sndcodec sunxi_i2s sunxi_codec btrfs xor raid6_pq
[ 14.647735] CPU: 1 PID: 599 Comm: alsactl Tainted: G W 3.10.104-pine64 #9
[ 14.647740] Call trace:
[ 14.652219] [] dump_backtrace+0x0/0x118
[ 14.652230] [] show_stack+0x24/0x30
[ 14.652241] [] dump_stack+0x20/0x28
[ 14.652251] [] warn_slowpath_common+0x80/0xa8
[ 14.652259] [] warn_slowpath_null+0x3c/0x4c
[ 14.652269] [] __clk_disable+0x40/0x78
[ 14.652277] [] clk_disable+0x28/0x3c
[ 14.652298] [] $x+0x100/0x198 [sunxi_codec]
[ 14.652311] [] snd_ctl_elem_write+0xd4/0x148
[ 14.652319] [] snd_ctl_ioctl+0x3b4/0x708
[ 14.652329] [] vfs_ioctl+0x4c/0x6c
[ 14.652336] [] do_vfs_ioctl+0x4a4/0x538
[ 14.652343] [] SyS_ioctl+0x68/0x98
[ 14.652348] ---[ end trace 090ab137063ed21f ]---
[ 14.653722] ------------[ cut here ]------------
[ 14.653750] WARNING: at drivers/clk/clk.c:690 __clk_unprepare+0x34/0x84()
[ 14.653756] Modules linked in: ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sanyo_decoder ir_sony_decoder vfe_v4l2 ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder ir_nec_decoder sunxi_ir_rx videobuf2_dma_contig videobuf2_memops vfe_io videobuf2_core ss cedar_ve 8723bs_vq0 8723bs cfg80211 sunxi_sndcodec sunxi_i2s sunxi_codec btrfs xor raid6_pq
[ 14.653819] CPU: 1 PID: 599 Comm: alsactl Tainted: G W 3.10.104-pine64 #9
[ 14.653825] Call trace:
[ 14.656619] [] dump_backtrace+0x0/0x118
[ 14.656630] [] show_stack+0x24/0x30
[ 14.656641] [] dump_stack+0x20/0x28
[ 14.656650] [] warn_slowpath_common+0x80/0xa8
[ 14.656658] [] warn_slowpath_null+0x3c/0x4c
[ 14.656664] [] __clk_unprepare+0x34/0x84
[ 14.656671] [] clk_unprepare+0x24/0x34
[ 14.656696] [] $x+0x108/0x198 [sunxi_codec]
[ 14.656708] [] snd_ctl_elem_write+0xd4/0x148
[ 14.656716] [] snd_ctl_ioctl+0x3b4/0x708
[ 14.656727] [] vfs_ioctl+0x4c/0x6c
[ 14.656734] [] do_vfs_ioctl+0x4a4/0x538
[ 14.656741] [] SyS_ioctl+0x68/0x98
[ 14.656747] ---[ end trace 090ab137063ed220 ]---
[ 15.274531] ------------[ cut here ]------------
[ 15.274563] WARNING: at drivers/clk/clk.c:781 __clk_disable+0x40/0x78()
[ 15.274568] Modules linked in: ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sanyo_decoder ir_sony_decoder vfe_v4l2 ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder ir_nec_decoder sunxi_ir_rx videobuf2_dma_contig videobuf2_memops vfe_io videobuf2_core ss cedar_ve 8723bs_vq0 8723bs cfg80211 sunxi_sndcodec sunxi_i2s sunxi_codec btrfs xor raid6_pq
[ 15.274632] CPU: 2 PID: 683 Comm: alsactl Tainted: G W 3.10.104-pine64 #9
[ 15.274637] Call trace:
[ 15.277393] [] dump_backtrace+0x0/0x118
[ 15.277402] [] show_stack+0x24/0x30
[ 15.277412] [] dump_stack+0x20/0x28
[ 15.277421] [] warn_slowpath_common+0x80/0xa8
[ 15.277428] [] warn_slowpath_null+0x3c/0x4c
[ 15.277439] [] __clk_disable+0x40/0x78
[ 15.277447] [] clk_disable+0x28/0x3c
[ 15.277466] [] $x+0x100/0x198 [sunxi_codec]
[ 15.277476] [] snd_ctl_elem_write+0xd4/0x148
[ 15.277483] [] snd_ctl_ioctl+0x3b4/0x708
[ 15.277493] [] vfs_ioctl+0x4c/0x6c
[ 15.277499] [] do_vfs_ioctl+0x4a4/0x538
[ 15.277506] [] SyS_ioctl+0x68/0x98
[ 15.277512] ---[ end trace 090ab137063ed221 ]---
[ 15.277518] ------------[ cut here ]------------
[ 15.277525] WARNING: at drivers/clk/clk.c:690 __clk_unprepare+0x34/0x84()
[ 15.277529] Modules linked in: ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sanyo_decoder ir_sony_decoder vfe_v4l2 ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder ir_nec_decoder sunxi_ir_rx videobuf2_dma_contig videobuf2_memops vfe_io videobuf2_core ss cedar_ve 8723bs_vq0 8723bs cfg80211 sunxi_sndcodec sunxi_i2s sunxi_codec btrfs xor raid6_pq
[ 15.277574] CPU: 2 PID: 683 Comm: alsactl Tainted: G W 3.10.104-pine64 #9
[ 15.277578] Call trace:
[ 15.280311] [] dump_backtrace+0x0/0x118
[ 15.280319] [] show_stack+0x24/0x30
[ 15.280327] [] dump_stack+0x20/0x28
[ 15.280333] [] warn_slowpath_common+0x80/0xa8
[ 15.280340] [] warn_slowpath_null+0x3c/0x4c
[ 15.280347] [] __clk_unprepare+0x34/0x84
[ 15.280353] [] clk_unprepare+0x24/0x34
[ 15.280367] [] $x+0x108/0x198 [sunxi_codec]
[ 15.280375] [] snd_ctl_elem_write+0xd4/0x148
[ 15.280382] [] snd_ctl_ioctl+0x3b4/0x708
[ 15.280388] [] vfs_ioctl+0x4c/0x6c
[ 15.280395] [] do_vfs_ioctl+0x4a4/0x538
[ 15.280402] [] SyS_ioctl+0x68/0x98
[ 15.280406] ---[ end trace 090ab137063ed222 ]---
[ 15.576050] libphy: 1c30000.eth: probed
[ 15.576182] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00)
[ 15.856324] CPU Budget:update CPU 0 cpufreq max to 1152000 min to 480000
[ 15.859307] CPU Budget:update CPU 0 cpufreq max to 1152000 min to 480000
[ 15.862318] CPU Budget:update CPU 0 cpufreq max to 1152000 min to 480000
[ 15.865586] CPU Budget:update CPU 0 cpufreq max to 1152000 min to 480000
[ 17.609273] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 17.624989] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
@qualcomm.com>
I got this lsmod output:
Module                  Size  Used by
ir_lirc_codec          13350  0
lirc_dev               18895  1 ir_lirc_codec
ir_mce_kbd_decoder     13330  0
ir_sanyo_decoder       12869  0
ir_sony_decoder        12786  0
vfe_v4l2              772828  0
ir_jvc_decoder         12811  0
ir_rc6_decoder         12871  0
ir_rc5_decoder         12757  0
ir_nec_decoder         12892  0
sunxi_ir_rx            14684  0
videobuf2_dma_contig    20341  1 vfe_v4l2
videobuf2_memops       12600  1 videobuf2_dma_contig
vfe_io                 44013  1 vfe_v4l2
videobuf2_core         35245  1 vfe_v4l2
ss                     41661  0
cedar_ve               20392  0
8723bs_vq0           1505876  0
8723bs               1500960  0
cfg80211              430729  2 8723bs_vq0,8723bs
sunxi_sndcodec         19661  1
sunxi_i2s              13702  2
sunxi_codec            64741  1
btrfs                 819998  0
xor                    17197  1 btrfs
raid6_pq               90985  1 btrfs
Since for me SD card is not detected by kernel anymore (both with legacy and mainline, tried compiling images and using the latest beta, tried 3 different SD cards) it (the board) probably goes back to the drawer or to the trash bin after additional tests.
Please drop me a note in case you need/want a replacement. I've 2 Pine64+ here right now but wanted to keep them for some camera and also BT LE experiments.
If it's ok for you I could also ask TL Lim to send you a board directly when you allow me to share address details (I would go for SoPine then -- they plan an interesting product around). Just drop me a PM, I'll write to TL Lim in the meantime.
BTW: I fixed / built semi automatic testing procedure for folks who will conduct tests for upcoming release or per request. It's working but need more tests and fine tuning before introduction ...
And.
Download pages are now refreshed on cron with data from here:
https://github.com/igorpecovnik/lib/tree/master/config/boards
There is a parameter:
BOARDRATING=""
which results in x/10 stars below title if defined  :P
Hmm... I don't get it. Let's take a look at https://www.armbian.com/orange-pi-zero/
Images linked to are for Nano Pi Air, remarks also and no one gets the idea that 'latest and greatest' stuff is contained in http://image.armbian.com/betaimages/
While I would assume linking to Air is a simple mistake (that can only be fixed by you?) the new 'structure' unfortunately hides information. And I also don't get why we don't advertise beta images where available especially for brand new boards like OPi Zero. Essential fixes are in beta image but not on download page and time gets wasted dealing with already resolved issues on the forum.
And I also don't understand why 'nmtui' was removed on remarks. But hey...
Yes. I would prefer to have a basic info about releases (and kernels) in the first tab above the download buttons (maybe call it "stable releases"), then link to beta images (maybe call it "nightly releases" since usually "beta" associales with something that was tested at least a little bit and "nightly" associates with automated untested builds), and then have board specific documentation in the 3rd tab
BTW: This also prevents me contributing to any documentation in the meantime. Since writing documentation that is not accessible afterwards doesn't make any sense.
We still fail horribly to look at Armbian from the outside. We know that the average users hates to read stuff (instructions, documentation, whatever). He gets a new toy and wants it up and running. Or he gets annoyed by the vendor offerings and wants to try out an Armbian image.
Eg. a Pine64 user has been told to try out Armbian to make use of the LCD (nightly image!). Most probably the journey is like this:
  • Arriving at https://www.armbian.com (text, images, nothing he's interested in except of the next link)
  • https://www.armbian.com/download/ -- aha, spotted Pine64
  • https://www.armbian.com/pine64/ -- aha, 'legacy' and 'vanilla' (WTF?!) and 'Jessie/Xenial server', so let's try out vanilla (sounds nice) and of course Jessie since that's what I know from Raspbian and the featured Lenny-builds from pine64.pro
  • Let's take that crappy 4GB SD card flying around and use WinDiskimager since this tool ensures that I don't get notified when burning fails
  • Ok, Armbian is crap, doesn't even boot, back to Jessie from pine64.pro
  • One week later: Let's try out this Armbian stuff again since I realized that the crappy SD card I used is really broken
  • So let's burn Armbian Jessie (5.20) again, this time it boots but there's no HDMI output (vanilla!) and no way to activate the LCD as described in their 'Hardware info' tab (there they're talking about 5.21, 5.24 and 5.25 but they only provide 5.20. WTF?!)
  • Ok, Armbian sucks, back to the pine64.pro offerings
@Igor: Currently no one who is not an Armbian developer or is guided by responsible guys like @pfeerick is able to find the nightly build for Pine64 and can benefit from all the great stuff we include. It's simply unaccessible and really a mess. And it won't change unless we start to look at this here from the outside.
I second Zador's suggestion: there have to be maximum 3 sentences that outline the most important stuff directly. Users start to read the fine print later if at all. When they want to download an image they need just a little information but that has to be easily accessible.
Also I think it would be a great idea to not link to an image with static version information (Armbian_5.20_Pine64_Debian_jessie_3.10.102.7z) but to a symlink that always resolves to latest version (Armbian_stable_Pine64_Debian_jessie_legacy.7z). Currently people link to OS images below http://http://image.armbian.com that get outdated automagically with Armbian improving. That's bad.
And as soon as Etcher 1.0 is released we should completely switch to .etch format (download checksum integrated, using Etcher guaranteed, no more hassles with broken download/burning processes. Saves our users and us a lot of time and frustration).
IMO archive file name should still include $REVISION, kernel version and build date (for nightly images). So symlink brobably won't work, but redirect at CMS or web server level should still allow linking to "latest nightly image download" from anywhere (linux-sunxi wiki, this forum or any other forums) but users who downloaded the image will know at least basic info without unpacking the archive
Images linked to are for Nano Pi Air, remarks also and no one gets the idea that 'latest and greatest' stuff is contained in http://image.armbian.com/betaimages/ While I would assume linking to Air is a simple mistake (that can only be fixed by you?) the new 'structure' unfortunately hides information. And I also don't get why we don't advertise beta images where available especially for brand new boards like OPi Zero. Essential fixes are in beta image but not on download page and time gets wasted dealing with already resolved issues on the forum.
Wrong images are error which I haven't notice. Will be fixed asap. Beta images are advertised exactly where and if available, currently under section "Developement".
It was mentioned only twice I think, while it should be on all boards with wifi ... I am solving this generally.
This is not the final version, but one step further - now it builds things from commonly available data set, UX design is still needed, but it's much easier from now on.
How do you mean this? How to solve?
I don't get it. What is not accessible? You mean it's better that we have one long page without menus? Or something else?
What should he gets here. A board selector?
OK. Let's go here with Zador's proposal.
stable releases | nighty releases | xxxxxxx | xxxxxx | xxxxxx
Still, we have legacy and vanilla kernels. Almost everywhere. How to solve this then? Adding kernel number won't change much I guess?
"Make sure you use good card" with link to more info below the download icon?
I mean that outside links should not contain exact kernel and release versions, they should look like
http://image.armbian.com/betaimages/Armbian_Nightly_Orangepizero_Ubuntu_xenial_default.7z
or
http://armbian.com/download?type=nightly&board=orangepizero&release=xenial&kernel=default
that should get HTTP 302 redirect to actual image file Armbian_5.24.161208_Orangepizero_Ubuntu_xenial_3.4.113.7z
Meaning of "legacy" or "vanilla" depends on board family/SoC and it needs to be stated on the download page (like it was before, but it should be shorter)
I don't have a better word to replace "legacy", but "vanilla" should probably be changed to "mainline"
For example in case of sun4i/sun7i it would be good to have at least this:
  • Legacy kernel - optimal for multimedia and desktop usage scenarios
  • Mainline kernel - optimal for headless server usage
  • See "Status matrix" for detailed comparison
and we could have a table (I'm assuming Markdown tables are supported) that would show that currently HDMI audio, VE accelerated video decoding, DRM video driver and Mali are not available on mainline
Maybe nightly tab should also have "buttons" instead of links for consistency, and images buttons/links should be on top and repository info/instructions should be lower
OK, will try to fix this in the evening. If any other ideas come up, please add them.
This is a good idea. Everybody heard about Vanilla Kernel, but what is it. Mainline is a good expression.
I also like the short explanation behind each word.
You have the icon that shows a Desktop and if I hover it says 'server', 'desktop'.  Why not leave the icon and write, Server, Desktop ?
Or the buttons are much bigger that I look at the icon.
Also a nice approach, once you choose a release: https://ubuntu-mate.org/download/
How did you manage to install Chromium? I'm using Jessie on Cubieboard and couldn't install chromium.
Firefox plays HTML5 videos choppily – stutters and low resolution.
  • Firefox running OK. Chromium installed and running OK. Both play html5 OK.
Some progress ... to be continued.
Examples, where special text related to board or family comes out:
https://www.armbian.com/cubietruck/
https://www.armbian.com/clearfog/
I like the cubietruck better, because it is more a general explanation, wereas with clearfog you go into a detail and with each update you might forget to change this wahtsorever.
I would move this valuable information above the buttons (in green):
Legacy 3.4.112
Optimal for multimedia and desktop usage scenarios.
"" now the buttons ""
