Test version of images 20230622-legacy for star64.
https://disk.yandex.ru/d/eEC4riP1jBWCeg
Important. For the system to work correctly, you need to update the bootloader once. To do this, download the image from the link
https://disk.yandex.ru/d/zsqznfa1ySI2gw
 burn it to the SD card, connect it to Star64 and turn on the power, wait 2 minutes and turn off the power.
After that, you can write an ArmbianTV image to the SD card, connect it to Star64 and the system will start automatically. The next steps are usually the initial setup of Armbian. In versions with DE (IceWM XFCE). even video playback in the window works (fullscreen mode does not work) through the Parole player. Analog audio output is enabled by default, to switch to HDMI audio, use the settings via Volume Control as usual.
root@192.168.1.51's password:
 ____  _              __   _  _
/ ___|| |_ __ _ _ __ / /_ | || |
\___ \| __/ _` | '__| '_ \| || |_
 ___) | || (_| | |  | (_) |__   _|
|____/ \__\__,_|_|   \___/   |_|
Welcome to Armbian 23.06 Jammy with Linux 5.15.115-star64
System load:   3%           	Up time:       3 min
Memory usage:  3% of 3.80G  	IP:	       192.168.1.51
CPU temp:      39°C           	Usage of /:    17% of 7.1G
RX today:      19.4 KiB
[ 10 security updates available, 12 updates total: apt upgrade ]
Last check: 2023-06-22 12:32
[ General system configuration (beta): armbian-config ]
Last login: Thu Jun 22 12:32:24 2023
root@star64:~# cat /proc/cpuinfo
processor	: 0
hart		: 1
isa		: rv64imafdc
mmu		: sv39
isa-ext		:
uarch		: sifive,u74-mc
processor	: 1
hart		: 2
isa		: rv64imafdc
mmu		: sv39
isa-ext		:
processor	: 2
hart		: 3
isa		: rv64imafdc
mmu		: sv39
isa-ext		:
processor	: 3
hart		: 4
isa		: rv64imafdc
mmu		: sv39
isa-ext		:
root@star64:~# neofetch
            .-/+oossssoo+/-.               root@star64
        `:+ssssssssssssssssss+:`           -----------
      -+ssssssssssssssssssyyssss+-         OS: Ubuntu 22.04.2 LTS riscv64
    .ossssssssssssssssssdMMMNysssso.       Host: Pine64 Star64
   /ssssssssssshdmmNNmmyNMMMMhssssss/      Kernel: 5.15.115-star64
  +ssssssssshmydMMMMMMMNddddyssssssss+     Uptime: 4 mins
 /sssssssshNMMMyhhyyyyhmNMMMNhssssssss/    Packages: 509 (dpkg)
.ssssssssdMMMNhsssssssssshNMMMdssssssss.   Shell: bash 5.1.16
+sssshhhyNMMNyssssssssssssyNMMMysssssss+   Resolution: 1920x1080
ossyNMMMNyMMhsssssssssssssshmmmhssssssso   Terminal: /dev/pts/0
ossyNMMMNyMMhsssssssssssssshmmmhssssssso   CPU: (4) @ 1.500GHz
+sssshhhyNMMNyssssssssssssyNMMMysssssss+   Memory: 118MiB / 3893MiB
 /sssssssshNMMMyhhyyyyhdNMMMNhssssssss/
  +sssssssssdmydMMMMMMMMddddyssssssss+
   /ssssssssssshdmNNNNmyNMMMMhssssss/
      -+sssssssssssssssssyyyssss+-
            .-/+oossssoo+/-.
root@star64:~#
Version 20230628 is legacy. (lunar and sid)
Important. A significant change in the composition of the system, now it corresponds to a similar composition of other platforms. Added images with DE for Debian.
I checked the installation of the system in SD\eMMC + NVMe mode. The system works noticeably faster. For example, launching the LibreOffice Writer application takes only 3 seconds, which is very good for entry-level support. :)
ver 20230721-edge kernel 6.5-rc2
work SD\eMMC and LAN (USB HDMI etc - not work)
user@192.168.1.12's password:
 ____  _              __   _  _
Welcome to Armbian 23.06 Lunar with bleeding edge Linux 6.5.0-rc2-next-20230721-star64
No end-user support: built from trunk
System load:   20%           	Up time:       1 min
Memory usage:  1% of 7.76G  	IP:	       192.168.1.12
CPU temp:      46°C           	Usage of /:    18% of 7.2G
RX today:      24.6 KiB
[ 4 security updates available, 5 updates total: apt upgrade ]
Last check: 2023-07-21 13:57
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
user@star64:~$ neofetch
                                 user@star64
      █ █ █ █ █ █ █ █ █ █ █      OS: Armbian (23.06) riscv64
     ███████████████████████     Host: Pine64 Star64
   ▄▄██                   ██▄▄   Kernel: 6.5.0-rc2-next-20230721-star64
   ▄▄██    ███████████    ██▄▄   Uptime: 1 min
   ▄▄██   ██         ██   ██▄▄   Packages: 535 (dpkg)
   ▄▄██   ██         ██   ██▄▄   Shell: bash 5.2.15
   ▄▄██   ██         ██   ██▄▄   Terminal: /dev/pts/0
   ▄▄██   █████████████   ██▄▄   CPU: (4)
   ▄▄██   ██         ██   ██▄▄   Memory: 136MiB / 7948MiB
user@star64:~$
06.08.2023 в 03:09, garyd сказал:
where are the download links to these newer images?
see the first message of the topic, there are all links to directories with images.
ver 20230814-legacy the kernel configuration has changed - simultaneous operation of the standard HDMI output and an additional video card on the PCIe bus (NVIDIA) is supported.
ver 20230816-edge kernel 6.5.0-rc5
work SD NVMe\PCIe LAN
user@192.168.1.14's password:
 ____  _              __   _  _
Welcome to Armbian 23.06 Lunar with bleeding edge Linux 6.5.0-rc5-next-20230809-star64
System load:   12%           	Up time:       2 min
Memory usage:  2% of 7.76G  	IP:	       192.168.1.14
CPU temp:      47°C           	Usage of /:    19% of 7.2G
RX today:      25.8 KiB
[ 25 security updates available, 31 updates total: apt upgrade ]
Last check: 2023-08-15 17:50
Last login: Tue Aug 15 17:45:10 2023 from 192.168.1.121
user@star64:~$ su -
Password:
processor	: 0
hart		: 1
isa		: rv64imafdc_zicntr_zicsr_zifencei_zihpm_zba_zbb
mmu		: sv39
mvendorid	: 0x489
marchid		: 0x8000000000000007
mimpid		: 0x4210427
processor	: 1
hart		: 2
mmu		: sv39
mvendorid	: 0x489
mimpid		: 0x4210427
processor	: 2
hart		: 3
mmu		: sv39
mvendorid	: 0x489
mimpid		: 0x4210427
processor	: 3
hart		: 4
mmu		: sv39
mvendorid	: 0x489
mimpid		: 0x4210427
root@star64:~# fdisk -l
Disk /dev/mmcblk1: 7.44 GiB, 7985954816 bytes, 15597568 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 11263ADD-611C-134B-8785-8268A57AB6D9
Device         Start      End  Sectors  Size Type
/dev/mmcblk1p1 65536 15269888 15204353  7.3G Linux filesystem
Disk /dev/nvme0n1: 119.24 GiB, 128035676160 bytes, 250069680 sectors
Disk model: NE-128
Disklabel type: dos
Disk identifier: 0xbba63fe5
Device         Boot Start       End   Sectors   Size Id Type
/dev/nvme0n1p1       2048 250068991 250066944 119.2G 83 Linux
root@star64:~# free -m
               total        used        free      shared  buff/cache   available
Mem:            7948         267        7615          11         151        7680
Swap:              0           0           0
                                 root@star64
   ▄▄██                   ██▄▄   Kernel: 6.5.0-rc5-next-20230809-star64
   ▄▄██    ███████████    ██▄▄   Uptime: 3 mins
   ▄▄██   ██         ██   ██▄▄   CPU: (4)
   ▄▄██   █████████████   ██▄▄   Memory: 199MiB / 7948MiB
root@star64:~#
Version 20230817-current with a 6.5 kernel in which HDMI works (partially). There is little practical use, because there is no USB and you cannot use a keyboard or mouse, but you can at least see the system startup process on the monitor screen. To display the color correctly, you need to remove two parameters at the end of the append (splash plymouth...) line in the /boot/extlinux/extlinux.conf file
the practical benefits of output to the monitor, even if USB does not work) and there is no UART connection:
1. you can immediately see the IP address for SSH connection and system settings without accessing the router.
2. you can immediately see if there is a problem at startup, for example, an error mounting the root system, or a failure when starting a file system check (when the system is waiting for a reaction from the user)
Version 20230824-legacy with kernel 5.15.127.
Expanded the list of Wi-Fi modules (USB\PCIe).
Added DTB for models with 4 GB of RAM (for use on 4GB models - rename the DTB file or edit /boot/extlinux/extlinux.conf with a 4 GB indication).
Check micro sd sandisk a1 which is recommend. Ok. Chceck integrity and sha its ok. Power is ok. Dietpi starts. I donthave uart debug cable. Should armbian img starts directly from micro sd? I download also noble 24.04 trunk and img from archive. I also download some old images from balbes yandex site. Still black screen.
16 hours ago, constantius said:
no armbian image works
Noting unusual as this hardware is community maintained. If nobody maintains it, it will stop working at one point. We provide images but these builds are provided by the Armbian project as a service to the community. Some HW works, some don't.
Dietpi works
They are competing with us, but we don't compete with them. In past 10 years, since they start to use Armbian as their starting point of re-branding, there were few fixes (<5) from their side, but all were very carefully egoistic weighted even they had balls to come here and humiliate developers with demands to fix this and that for them (their users). So you can understand how they think ...
For this hardware you need to be a developer as support is immature. Whatever OS you will us. Its not just cable.
On yandex there are a lot of images made by Balbes. All of them dont works? Nobody check them? According to the topic some of them works . Maybe not with all devices or something like that. I cant even update bootloader. My star64 revision is 1.1. i dont suppose there are more revisions.
They may have been tests.  Or they could have worked at one time.  But Linux kernel (and other hardware) is always moving forward and everything needs constant maintenance.
