First of all, credits goes to https://4pda.ru/forum/lofiversion/index.php?t750921-2560.html
Device that I used for this guide: https://www.aliexpress.com/item/3-5-Inch-TFT-LCD-Moudle-For-Raspberry-Pi-2-Model-B-RPI-B-raspberry-pi/32707058182.html
Pinout: http://www.waveshare.com/3.5inch-rpi-lcd-a.htm (Yes, the device is a waveshare knockoff)
How to place the device? For Orange pi lite/one it is reversed. For the rest, it should be normal.
Refer to https://forum.armbian.com/index.php?/topic/724-quick-review-of-orange-pi-one/ for more info.
There are two sections to this guide.
Legacy / Mainline
Legacy Kernel [You can only EITHER use touch or LCD due to issues with spi chip select]
LCD
1) Load fbtft and fbtft_device on boot
sudo nano /etc/modules-load.d/fbtft.conf
fbtft
fbtft_device
2) Load fbtft_device options
nano /etc/modprobe.d/fbtft.conf
options fbtft_device rotate=90 name=piscreen speed=16000000 gpios=reset:2,dc:71 txbuflen=32768 fps=25
3) Make sure X11 loads to the correct framebuffer (fb8 for legacy)
nano /etc/X11/xorg.conf.d/50-fbturbo.conf
find fb0 and change to fb8
4) Reboot your device (sudo reboot) and you screen should be lit up
TOUCH
1) Download ads7846 touch driver (compatible with xpt2046)
mkdir ds7846
cd ds7846
wget https://raw.githubusercontent.com/raspberrypi/linux/rpi-3.6.y/drivers/input/touchscreen/ads7846.c
2) Create a makefile (Take note that it is TABS instead of spaces before the $(MAKE))
nano Makefile
Insert the below in without the -----
obj-m := ads7846.o
KDIR := /lib/modules/$(shell uname -r)/build
PWD := $(shell pwd)
all:
	$(MAKE) -C $(KDIR) M=$(PWD) modules
clean:
	$(MAKE) -C $(KDIR) M=$(PWD) clean
install:
	$(MAKE) -C $(KDIR) M=$(PWD) modules_install
3) Exit nano and run the following
sudo make
sudo make install
sudo depmod
4) Download and compile and install ads7846_device
cd ..
git clone https://github.com/notro/fbtft_tools/
cd fbtft_tools/ads7846_device
make
sudo make install
sudo depmod
5) Load ads7846 and ads7846_device on boot
sudo nano /etc/modules-load.d/ads7846.conf
ads7846
ads7846_device
6) Load ads7846_device options
nano /etc/modprobe.d/ads7846_device.conf
options ads7846_device model=7846 cs=0 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
7) Reboot your device and run evtest
sudo reboot
sudo evtest
Find your touch device and happy touching. Every touch should generate an event.
Mainline Kernel [You can use BOTH LCD and TOUCH]
1) Enable overlays for spi and cs1
sudo nano /boot/armbianEnv.txt
add the following to the bottom
overlays=spi-spidev spi-add-cs1
param_spidev_spi_bus=0
param_spidev_spi_cs=1
2) Reboot your device
LCD
fbtft
fbtft_device
3) Since there is no GUI in mainline, lets enable the console to be displayed to LCD instead
sudo nano /etc/rc.local
con2fbmap 1 1
For some others, you may wish to try con2fbmap 1 0 [If your device has no AVout]
TOUCH
mkdir ds7846
cd ds7846
wget https://sourceforge.net/p/openipmi/linux-ipmi/ci/master/tree/drivers/input/touchscreen/ads7846.c?format=raw
mv ads7846.c?format=raw ads7846.c
nano Makefile
obj-m := ads7846.o
PWD := $(shell pwd)
all:
clean:
install:
sudo make
sudo make install
sudo depmod
cd ..
make
sudo make install
sudo depmod
ads7846
ads7846_device
options ads7846_device model=7846 cs=1 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
FAQ / Personal Experiences
Q1) If you wish to do manual testing, without rebooting, we have to rmmod and then modprobe manually [Make sure you have already done all the steps till depmod
sudo rmmod fbtft_device
sudo rmmod fbtft
sudo rmmod ads7846_device
sudo rmmod ads7846
sudo modprobe ads7846
sudo modprobe ads7846_device model=7846 cs=1 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
sudo modprobe fbtft
sudo modprobe fbtft_device rotate=90 name=piscreen speed=16000000 gpios=reset:2,dc:71 txbuflen=32768 fps=25
Q2) My mainline kernel suddenly doesn't show me that my device is touchable through evtest. I experienced this and i did the following
Remove all on boot loading for ads7846 and fbtft
sudo rm /etc/modules-load.d/ads7846.conf
sudo rm /etc/modprobe.d/ads7846_device.conf
sudo rm /etc/modprobe.d/fbtft.conf
sudo rm /etc/modules-load.d/fbtft.conf
After which, lets manually 'automatically' load them through rc.local
nano /etc/rc.local
modprobe ads7846
modprobe fbtft
con2fbmap 1 0
Take note that con2fbmap is either 1 0 or 1 1 for mainline (1 0 --> orange pi lite or devices without AVOUT, 1 1 --> for devices with AVOUT like orange pi zero)
For advanced users, check /dev/ and see what is your fbX
Q3) I have installed a GUI for my mainline kernel but touch stops at times.
I experience this too and I have no idea on how to fix it.
Q4) I need to calibrate it
Yes, me too. However, my device isn't working very well. You need tslib and stuff to do the calibration.
LCD
fbtft
fbtft_device
con2fbmap 1 1
TOUCH
mkdir ds7846
cd ds7846
nano Makefile
obj-m := ads7846.o
PWD := $(shell pwd)
all:
clean:
install:
sudo make
sudo make install
sudo depmod
cd ..
make
sudo make install
sudo depmod
ads7846
ads7846_device
Thanks for your guide
Could you please tell how could I install fbtft on Armbian. The first step is installing fbtft but I do not know how could I do that.
Edited by Tido
unnecessary large Quote, added spoiler
I was able to get everything working on mainline kernel w/ mate installed, but somehow the touchscreen's left-to-right is acting weird.  The cursor moves opposite to how I'm moving the pen, but only in the x-direction. It follows the pen up and down still. If I change the rotate option in to 270 instead of 90, the y-direction gets mirrored instead of the x. Is there an option to only mirror one axis?
hi. i have orange pi lite and  http://www.waveshare.com/3.5inch-rpi-lcd-a.htm lcd .
i do all things you say . but i see a light white page. please help meeee. please
I have a problem when i show screen in lcd touch screen do not work. in other hand if i dont screen on lcd orange pi lite reconginiz touch screen. please help me . i think this problem become from spi.
Thanks for the guide! I tried this, only for the touch screen since I am using an HDMI monitor, but it's not working.
It is a 5" waveshare clone (v2)
I scoped the spi bus and the interrupt pin. I see some strange characteristics.
SCLK is fine:
sclk
MOSI is only driven to ~1v
MOS
MISO is less than a volt:
MISO
And the interrupt on PA1 is ~0.5v
INT
I am using an orange pi pc plus on 4.14.84
Anyone have some idea of what might be going on?
On 7/31/2017 at 4:33 PM, kutysam said:
Hey, when I run sudo nano /etc/modules-load.d/fbtft.conf command a blank page will be open on terminal what should I do?:(
Hi everyone, I was able to get my lcd https://www.amazon.com/gp/product/B01IGBDT02/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 to work Im running on Orange Pi zero H2 Armbian Bionic mainline based kernel 4.19.y. Ive tried everything here several times, but for some reason my touchscreen still doesnt work. Ive noticed that when Im running sudo make install in the ads7846 part Im getting something saying " WARNING: modules_install: missing 'System.map' file. missing Skipping depmod" . Is this normal? Other than that I dont understand what Im doing wrong. Also tried sudo modprobe ads7846_device model=7846 cs=1 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900 . Gives me an error " modprobe: ERROR: could not insert 'ads7846_device': invalid arguement"  Im greatfull for any help.
  ___  ____  _    ___
 / _ \|  _ \(_)  / _ \ _ __   ___
| | | | |_) | | | | | | '_ \ / _ \
| |_| |  __/| | | |_| | | | |  __/
 \___/|_|   |_|  \___/|_| |_|\___|
Welcome to Armbian 21.02.1 Focal with Linux 5.10.12-sunxi
System load:   29%              Up time:       0 min
Memory usage:  23% of 491M      IP:            192.168.101.15
CPU temp:      63°C             Usage of /:    11% of 30G
[ General system configuration (beta): armbian-config ]
root@orangepione:~/ds7846# ls
ads7846.c  Makefile
root@orangepione:~/ds7846# cat Makefile
obj-m := ads7846.o
PWD := $(shell pwd)
all:
clean:
install:
root@orangepione:~/ds7846# sudo make
make -C /lib/modules/5.10.12-sunxi/build  M=/root/ds7846  modules
make[1]: *** /lib/modules/5.10.12-sunxi/build: No such file or directory.  Stop.
make: *** [Makefile:5: all] Error 2
I am ending on this error, how to fix it? :( When my arm distro dont have this module loaded?
And what is correct wiring? I did this one: https://www.waveshare.com/3.5inch-rpi-lcd-a.htm screen is white os its look ok ...
28 minutes ago, locki said:
how to fix it?
For start, you might need to install kernel headers.
armbian-config -> software -> install headers
Then try again. Regarding display connection or if the method is proper - no idea.
after install drivers:
all works but my touch screen is inverted :( i tryex invert swap axes etc ...
I tryed all also some tips from @olehs but no luck... any other tips?
root@orangepione:~# cat /etc/X11/xorg.conf.d/99-calibration.conf-35
Section "InputClass"
        Identifier      "calibration"
        MatchProduct    "ADS7846 Touchscreen"
        Option  "Calibration"   "200 3933 170 3869"
        Option "SwapAxes" "0"
        Option "TransformationMatrix" "1 0 0 0 -1 1 0 0 1" # tip from olehs but also not working
EndSection
Edited by locki
new update
