On 2/13/2018 at 4:45 AM, Tido said:
I can confirm the green = Link is dead.  Ethernet 10/100M (ETH MDI diff x 2)
Ethernet-Port on the schematic is on sheet 7,
GPIOZ_14 (SPDIF_IN // ETH_LINK_LED)  -  P20 -
GPIOZ_15 (PWM_C // ETH_ACT_LED)  -  P19 -
not really, I think they forgot to connect the green LED :rolleyes:,  the part 5J1 is the Single Port Connector with Magnetics Module and LED and refers to:
HY911105H  https://aw-som.com/product_info.php?products_id=54
HR911105A  http://www.datasheetmeta.com/search.php?q=HR911105A
@Da Xue, can you check whether the green LED (pin 9+10) is only missing in the schematics or did you forget to connect it ?
They weren't connected due to an placement issue we had. This will be addressed in the next manufacturing batch.
From the Facebook users group, a general hardware note, when using expansion boards with Le Potato, be certain to use nylon standoffs.  One of the A/V connector pads is encroaching on the space for the mounting hole, creating a potential risk of a short if using metal ones, depending on the expansion board (By spec they should have a large keep-out zone as well, but it can't be assumed).
I just got my lepotato up and running with Armbian and I have a noobish question. Does this board need a heatsink or fan or am I ok to run it without? Does the board automatically throttle performance if it starts getting too hot to allow itself to cool down?
The ARM Trusted Firmware will automatically throttle the cores if the chip gets too hot to prevent damage. However, it is recommended to have a heatsink for best performance.
Aside from the difference in memory (1GB/2GB), are there any other hardware differences between the two LePotato models?
If I am using the LePotato for CPU intensive work that is not at all memory intensive can I expect similar performance between the two boards?
I'm finding that my LePotato is resetting it's IP address on reboot. Is this normal behavior for this board and/or Armbian? Is there a way to stop that from happening?
This is normal in the way, that ARM chips do not come with a MAC-Address. If you want to set your MAC-Address go to /etc/network/interfaces and 'uncomment' hwaddress. Ask google for more details ;-)
I was able to source some info from googling but it's for other linux distros. The total contents of my interfaces file looks like this now:
source /etc/network/interfaces.d/*
auto eth0
iface eth0 inet manual
hwaddress ether DE:DE:DE:DE:DE:01
After my first reboot if I scan for IPs I do get one with that MAC address. Then when I connect to it and reboot again I end up with a new MAC address and IP. My goal is to permanently set the MAC address and get a consistent IP address to connect to as well. If the IP changes occasionally that isn't a problem but I don't want it to reset on every reboot.
For my application, my LePotato is outperforming my raspberry pi 3bs and 3b+ by a very large margin. All my pis are running pi64 lite so maybe some of the gains are being realized by running armbian instead but I am very impressed with the LePotato so far. Is there any other SBC that does even better around the $35 price point or is the LePotato leading the pack right now? My application is CPU intensive and not memory intensive.
The Pi has bottlenecks on RAM, storage access, and network, I'd look at that as the problem first.
Also, your name just makes me think
Yeah my name is definitely a reference to Datsun vehicles. I own several of them and a few Nissan's too.
Based on your posts around the forum you seem like you're a fan of the Amlogic stuff.  Is Le Potato at the forefront power-wise around the $35 price point or is there something comparable? The rockchip devices all seem to be significantly above that price.
http://www.friendlyarm.com/index.php?route=product/product&path=69&product_id=206 (read the reviews there, especially from Willy Tarreau who explains how to get all 8 cores running at 1.6 GHz. He's also the one who discovered Amlogic cheating on us wrt fake clockspeeds 2 years ago)
With Amlogic there's nothing comparable at the moment (the S912 is an 1.2 GHz SoC) and also as usual they cheat on us wrt clockspeeds (it's not related to throttling or thermal protection, it's just a firmware blob loaded on the embedded M3 core controlling cpufreq/DVFS and doing 'magic things' not under our control using whatever clockspeeds it wants and reporting bogus values back to the kernel)
Wow this board looks really promising. And the form-factor is so tiny! I will definitely order one for testing - thanks so much for the info!
auto eth0
Eventually the changes above to my interfaces file did have the effect of setting the MAC address and getting a consistent IP address upon reboot of the device. For the first couple of reboots it was inconsistent but now it is. I can't explain this specific behavior but I'm happy it is working now.
38 minutes ago, constantius said:
someone had written about it but i cant find it
normally such threads ends here
due to crappy PSU, crappy SD-Card or crappy way of writing the image to the SD-Card...
i have build armbian 5.46 ubuntu bionic. I have one issue.  System is running till next boot. On the next boot i have black screen. Sd-card is good. I build debian 9 armbian 5.46 and its working.  Power supplied  also is good.
@Igor can you verify that an image you build today for Le Potato Next will boot?  I'm hanging on dvfs, I tried with and without that scpi regression patch, no change.
Starting kernel ...
domain-0 init dvfs: 4
It works for me http://ix.io/1fQ8 sometimes. As you can see there are many cpufreq: __target_index: Failed to change cpu frequency: -5 in the logs.
One possible solution is to disable dvfs for now?
That did the trick, and is applied to next.  @Igor take a look, I don't know if that other patch is necessary or not now, I did some general cleanup as well if you want to try it out.
Not sure if we are there yet. This still shows up and sometimes it just hangs there:
scpi_regression_hangs_the_board_possible_fix.patch doesn't have any effect. I don't recall if we had this problem before ... rebooting (sometimes) takes a lot of time. Boot log: http://ix.io/1fY9
:-/.   I had an oops while the system tried to set the I2S clock while DVFS was disabled, and noticed a short hang there a couple times during startup (hang at simple sound card).  I saw (I think), a patch about that, going digging....
Yep, just checked the potato I left running overnight, I have general sound core failure, I'd say to be conservative I have about 197 billion errors pertaining to not being able to set the I2S clock rates and a trace.
[   81.012704] WARNING: CPU: 1 PID: 3412 at drivers/gpu/drm/meson/meson_crtc.c:140 meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[   81.012715] Modules linked in: snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_meson_aiu_i2s_dma snd_soc_meson_i2s_dai snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer meson_dw_hdmi snd dw_hdmi meson_drm soundcore cec drm_kms_helper drm drm_panel_orientation_quirks meson_rng rng_core meson_ir lz4 rc_core lz4_compress snd_soc_meson_audio_core scpi_hwmon meson_gxbb_wdt zram zsmalloc ip_tables x_tables
[   81.012826] CPU: 1 PID: 3412 Comm: Xorg Not tainted 4.17.4-meson64 #7
[   81.012830] Hardware name: Libre Technology CC (DT)
[   81.012838] pstate: 40000005 (nZcv daif -PAN -UAO)
[   81.012854] pc : meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[   81.012868] lr : meson_crtc_atomic_begin+0x20/0x70 [meson_drm]
[   81.012872] sp : ffff00000ffbba30
[   81.012877] x29: ffff00000ffbba30 x28: ffff800070492e00
[   81.012886] x27: ffff80006ab60000 x26: ffff800070498878
[   81.012896] x25: ffff800070498818 x24: ffff80006cc73000
[   81.012905] x23: 0000000000000030 x22: 0000000000000000
[   81.012914] x21: 0000000000000000 x20: 0000000000000001
[   81.012923] x19: ffff800070498818 x18: 00000000000070d8
[   81.012932] x17: 00000000000070d0 x16: 00000000000070c8
[   81.012941] x15: 0000000000000000 x14: 000002710000024a
[   81.012950] x13: 0000024500000271 x12: 0000024000000240
[   81.012960] x11: 0000000000000360 x10: 0000031c000002dc
[   81.012969] x9 : 00000360000002d0 x8 : 0000000000000000
[   81.012977] x7 : 0000000000000000 x6 : ffff8000704b07f8
[   81.012986] x5 : 0000000000000000 x4 : 0000000000000000
[   81.012994] x3 : 0000000000000000 x2 : 000000000000001c
[   81.013003] x1 : ffff80006ab60000 x0 : 00000000ffffffea
[   81.013013] Call trace:
[   81.013029]  meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[   81.013108]  drm_atomic_helper_commit_planes+0x70/0x208 [drm_kms_helper]
[   81.013169]  drm_atomic_helper_commit_tail+0x30/0x70 [drm_kms_helper]
[   81.013232]  commit_tail+0x74/0x78 [drm_kms_helper]
[   81.013293]  drm_atomic_helper_commit+0xe8/0x168 [drm_kms_helper]
[   81.013451]  drm_atomic_commit+0x48/0x58 [drm]
[   81.013512]  drm_atomic_helper_set_config+0x84/0xc0 [drm_kms_helper]
[   81.013638]  __drm_mode_set_config_internal+0x64/0xf8 [drm]
[   81.013759]  drm_mode_setcrtc+0x2c0/0x538 [drm]
[   81.013877]  drm_ioctl_kernel+0x6c/0xe8 [drm]
[   81.013996]  drm_ioctl+0x1a4/0x3e8 [drm]
[   81.014010]  do_vfs_ioctl+0xb8/0x8d8
[   81.014016]  ksys_ioctl+0x80/0xb8
[   81.014022]  sys_ioctl+0xc/0x18
[   81.014031]  el0_svc_naked+0x30/0x34
[   81.014037] ---[ end trace 68cf73f46dc18927 ]---
[   81.032307] WARNING: CPU: 0 PID: 0 at drivers/gpu/drm/drm_vblank.c:1026 drm_vblank_put+0xa0/0xb8 [drm]
[   81.032316] Modules linked in: snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_meson_aiu_i2s_dma snd_soc_meson_i2s_dai snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer meson_dw_hdmi snd dw_hdmi meson_drm soundcore cec drm_kms_helper drm drm_panel_orientation_quirks meson_rng rng_core meson_ir lz4 rc_core lz4_compress snd_soc_meson_audio_core scpi_hwmon meson_gxbb_wdt zram zsmalloc ip_tables x_tables
[   81.032426] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G        W         4.17.4-meson64 #7
[   81.032431] Hardware name: Libre Technology CC (DT)
[   81.032438] pstate: 20000085 (nzCv daIf -PAN -UAO)
[   81.032566] pc : drm_vblank_put+0xa0/0xb8 [drm]
[   81.032692] lr : drm_crtc_vblank_put+0x18/0x20 [drm]
[   81.032696] sp : ffff000008003df0
[   81.032700] x29: ffff000008003df0 x28: ffff000008e42580
[   81.032709] x27: 0000000000000001 x26: ffff000008caf9e8
[   81.032718] x25: ffff000008ebe38a x24: ffff8000712afa00
[   81.032727] x23: 000000000000001f x22: 0000000000000080
[   81.032736] x21: ffff800070498818 x20: ffff000008e39000
[   81.032745] x19: ffff800070645e18 x18: 0000000000008090
[   81.032754] x17: 0000ffff7f805a00 x16: ffff00000823fe20
[   81.032763] x15: 0000000000000000 x14: 0000000000000400
[   81.032772] x13: 00000000000001c3 x12: 0000000000000001
[   81.032781] x11: 0000000000008f0b x10: 0000000000000040
[   81.032790] x9 : ffff000008e53728 x8 : 0000000040000000
[   81.032798] x7 : 0000000000210d00 x6 : 0000000000000004
[   81.032807] x5 : ffff000000b29e48 x4 : 0000000000000001
[   81.032816] x3 : 0000000000000160 x2 : 0000000000000000
[   81.032824] x1 : ffff800070924600 x0 : ffff80006f29e000
[   81.032834] Call trace:
[   81.032958]  drm_vblank_put+0xa0/0xb8 [drm]
[   81.033081]  drm_crtc_vblank_put+0x18/0x20 [drm]
[   81.033100]  meson_crtc_irq+0x70/0x188 [meson_drm]
[   81.033114]  meson_irq+0x20/0x30 [meson_drm]
[   81.033130]  __handle_irq_event_percpu+0x5c/0x148
[   81.033138]  handle_irq_event_percpu+0x34/0x88
[   81.033146]  handle_irq_event+0x48/0x78
[   81.033153]  handle_fasteoi_irq+0xa8/0x180
[   81.033161]  generic_handle_irq+0x24/0x38
[   81.033168]  __handle_domain_irq+0x5c/0xb0
[   81.033175]  gic_handle_irq+0x58/0xa8
[   81.033181]  el1_irq+0xb0/0x128
[   81.033190]  arch_cpu_idle+0x10/0x18
[   81.033197]  do_idle+0x1d4/0x288
[   81.033203]  cpu_startup_entry+0x20/0x28
[   81.033214]  rest_init+0xcc/0xd8
[   81.033225]  start_kernel+0x3d4/0x400
[   81.033231] ---[ end trace 68cf73f46dc18928 ]---
[   83.732138] fuse init (API version 7.26)
[   84.821673] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.821684] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.821839] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.821847] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.821965] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.821971] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.822071] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.822076] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.822156] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.822161] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.823244] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.823254] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.823383] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.823390] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.823494] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.823500] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.823589] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.823594] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.823667] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.823672] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.833181] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.833192] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.833541] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.833548] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.833849] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.833858] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.834139] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.834146] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.834378] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.834385] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.836160] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.836170] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.852203] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.852213] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.852725] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.852733] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.853109] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.853118] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.853429] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   84.853438] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.885301] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.885312] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.885429] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.885434] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.890567] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.890577] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.890695] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.890700] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.904790] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.904801] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.906586] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.906596] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.906758] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.906763] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.906931] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.906938] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.907060] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.907065] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.907146] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.907151] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.908696] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.908705] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.909072] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.909081] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.909394] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.909402] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.909675] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.909682] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.909911] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.909917] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.911647] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.911658] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.912084] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.912092] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.912470] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.912477] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.914550] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.914561] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   84.914883] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   84.914893] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.304962] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.304972] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.305085] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.305090] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.305180] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.305184] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.305267] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.305271] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.305343] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.305347] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.306313] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.306323] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.306440] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.306447] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.306541] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.306546] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.306628] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.306632] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.306705] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.306710] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.308063] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.308073] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.308393] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.308400] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.330717] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.330728] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.331004] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.331010] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.331221] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.331226] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.345080] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.345091] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.345545] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.345554] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.345950] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.345959] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.346331] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.346340] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.346636] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.346644] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.355939] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.355949] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.356093] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.356100] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.360704] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.360714] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.360889] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.360895] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.360979] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.360984] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.362059] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.362069] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.362194] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.362200] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.362292] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.362296] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.362379] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.362384] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.362458] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.362462] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.363893] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.363903] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.364264] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.364273] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.364567] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.364573] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.380514] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.380524] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.380858] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.380867] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.382703] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.382713] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.383170] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.383179] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.383553] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.383561] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.383888] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.383896] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.384200] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.384209] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.423621] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.423631] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.423765] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.423772] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.423884] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.423889] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.423982] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.423988] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.424067] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.424072] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.435531] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.435542] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.435680] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.435687] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.435797] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.435803] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.435899] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.435904] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.435986] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.435992] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.437575] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.437586] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.440311] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.440321] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.440758] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.440768] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.441090] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.441100] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.441370] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.441377] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.443160] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.443170] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.443612] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.443621] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.444026] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.444034] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.444385] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.444393] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.444795] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.444803] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.463167] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.463178] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.463328] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.463337] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.463465] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.463471] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.463559] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.463563] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.463643] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.463647] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.485640] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.485651] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.485791] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.485797] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.485901] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.485906] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.485994] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.485998] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.486070] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.486074] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.487532] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.487543] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.487886] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.487893] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.488192] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.488201] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.488481] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.488490] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.493356] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.493366] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.495267] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.495277] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.495718] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.495726] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.496119] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.496130] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.496488] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.496495] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.501645] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.501654] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.592198] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.592209] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.592325] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.592330] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.592419] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.592423] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.592503] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.592507] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.592578] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.592582] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.594297] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.594308] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.594447] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.594454] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.594565] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.594578] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.594677] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.594682] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.594764] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.594769] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.596831] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.596840] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.597203] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.597212] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.610187] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.610199] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.610505] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.610514] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.610777] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.610786] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.612498] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.612507] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.613066] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.613075] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.613462] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.613470] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.613804] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.613811] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.614095] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.614102] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.618789] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.618801] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.618934] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.618940] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.619040] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.619044] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.619133] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.619138] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.619214] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.619218] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.620225] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.620235] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.620360] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.620365] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.620461] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.620466] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.620551] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.620557] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.621012] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.621023] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.630774] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.630784] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.631136] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.631145] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.631450] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.631458] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.631735] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.631742] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.631991] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.632000] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.639511] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.639521] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.639958] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.639965] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.640355] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.644522] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.645300] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.645308] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.645626] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.645633] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.694873] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.694883] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.695033] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.695041] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.695153] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.695159] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.695250] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.695255] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.695329] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.695334] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.696445] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.696454] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.698546] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.698558] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.698741] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.698748] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.698877] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.698884] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.699291] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.699302] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.708193] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.708203] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.708558] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.708566] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.708938] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.708948] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.709241] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.709249] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.709503] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.709510] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.711201] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.711210] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.711635] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.711643] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.712029] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.712036] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.712374] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.712383] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.715297] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.715307] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.732884] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.732893] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.733017] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.733022] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.733113] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.733118] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.733198] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.733203] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.733272] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.733276] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.734211] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.734219] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.734329] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.734333] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.734418] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.734422] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.734502] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.734506] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.734576] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.734580] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.735930] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.735939] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.736290] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.736299] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.736693] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.736706] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.737019] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.737030] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.737300] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.737309] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.746058] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.746068] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.746490] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.746497] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.746871] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.746879] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.747216] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.747223] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.747510] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.747518] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.785387] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.785398] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.785549] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.785558] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.785689] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.785697] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.785812] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.785818] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.785915] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.785920] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.787038] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.787048] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.787197] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.787205] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.787332] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.787338] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.787446] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.787452] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.787551] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.787556] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.789751] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.789761] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.790128] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.790138] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.790465] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.790473] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.790829] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.790838] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.791101] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.791109] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.792985] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.792995] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.793438] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.793447] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.793850] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.793857] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.794211] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.794219] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.794528] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to the i2s clock rates
[   85.794535] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.801954] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.801965] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.802086] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.802091] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.802184] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.802190] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.802270] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.802275] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.802345] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.802349] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.805597] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.805608] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.805754] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.805762] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.805870] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.805877] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.805970] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.805976] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.806066] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.806071] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.807670] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.807679] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.808034] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.808044] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.811383] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.811394] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.811704] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.811713] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.811969] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.811978] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.816028] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.816038] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.816483] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.816492] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.817368] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.817380] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.817744] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.817753] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[   85.818064] meson-i2s-dai meson-i2s-dai.1.auto: Unable set to set i2s description
[   85.818073] meson-i2s-dai meson-i2s-dai.1.auto: ASoC: can't set meson-i2s-dai.1.auto hw params: -22
[  132.791755] WARNING: CPU: 1 PID: 3412 at drivers/gpu/drm/meson/meson_crtc.c:140 meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[  132.791765] Modules linked in: fuse snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_meson_aiu_i2s_dma snd_soc_meson_i2s_dai snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer meson_dw_hdmi snd dw_hdmi meson_drm soundcore cec drm_kms_helper drm drm_panel_orientation_quirks meson_rng rng_core meson_ir lz4 rc_core lz4_compress snd_soc_meson_audio_core scpi_hwmon meson_gxbb_wdt zram zsmalloc ip_tables x_tables
[  132.791879] CPU: 1 PID: 3412 Comm: Xorg Tainted: G        W         4.17.4-meson64 #7
[  132.791884] Hardware name: Libre Technology CC (DT)
[  132.791891] pstate: 40000005 (nZcv daif -PAN -UAO)
[  132.791907] pc : meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[  132.791922] lr : meson_crtc_atomic_begin+0x20/0x70 [meson_drm]
[  132.791926] sp : ffff00000ffbba30
[  132.791930] x29: ffff00000ffbba30 x28: ffff800070492e00
[  132.791940] x27: ffff80006ab60000 x26: ffff800070498878
[  132.791950] x25: ffff800070498818 x24: ffff80006cddb100
[  132.791959] x23: 0000000000000030 x22: 0000000000000000
[  132.791968] x21: 0000000000000000 x20: 0000000000000001
[  132.791977] x19: ffff800070498818 x18: 00000000000070d8
[  132.791986] x17: 00000000000070d0 x16: 00000000000070c8
[  132.791995] x15: 0000000000000000 x14: 0000046500000441
[  132.792004] x13: 0000043c00000465 x12: 0000043800000438
[  132.792013] x11: 0000000000000898 x10: 00000804000007d8
[  132.792022] x9 : 0000089800000780 x8 : 0000000000000000
[  132.792031] x7 : 0000000000000000 x6 : ffff8000704b07f8
[  132.792039] x5 : 0000000000000000 x4 : 0000000000000000
[  132.792048] x3 : 0000000000000000 x2 : 0000000000000028
[  132.792057] x1 : ffff80006ab60000 x0 : 00000000ffffffea
[  132.792066] Call trace:
[  132.792082]  meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[  132.792159]  drm_atomic_helper_commit_planes+0x70/0x208 [drm_kms_helper]
[  132.792222]  drm_atomic_helper_commit_tail+0x30/0x70 [drm_kms_helper]
[  132.792283]  commit_tail+0x74/0x78 [drm_kms_helper]
[  132.792344]  drm_atomic_helper_commit+0xe8/0x168 [drm_kms_helper]
[  132.792501]  drm_atomic_commit+0x48/0x58 [drm]
[  132.792561]  drm_atomic_helper_set_config+0x84/0xc0 [drm_kms_helper]
[  132.792685]  __drm_mode_set_config_internal+0x64/0xf8 [drm]
[  132.792806]  drm_mode_setcrtc+0x2c0/0x538 [drm]
[  132.792925]  drm_ioctl_kernel+0x6c/0xe8 [drm]
[  132.793043]  drm_ioctl+0x1a4/0x3e8 [drm]
[  132.793057]  do_vfs_ioctl+0xb8/0x8d8
[  132.793063]  ksys_ioctl+0x80/0xb8
[  132.793069]  sys_ioctl+0xc/0x18
[  132.793078]  el0_svc_naked+0x30/0x34
[  132.793084] ---[ end trace 68cf73f46dc18929 ]---
[  132.808458] WARNING: CPU: 0 PID: 0 at drivers/gpu/drm/drm_vblank.c:1026 drm_vblank_put+0xa0/0xb8 [drm]
[  132.808470] Modules linked in: fuse snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_meson_aiu_i2s_dma snd_soc_meson_i2s_dai snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer meson_dw_hdmi snd dw_hdmi meson_drm soundcore cec drm_kms_helper drm drm_panel_orientation_quirks meson_rng rng_core meson_ir lz4 rc_core lz4_compress snd_soc_meson_audio_core scpi_hwmon meson_gxbb_wdt zram zsmalloc ip_tables x_tables
[  132.808585] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G        W         4.17.4-meson64 #7
[  132.808589] Hardware name: Libre Technology CC (DT)
[  132.808597] pstate: 20000085 (nzCv daIf -PAN -UAO)
[  132.808725] pc : drm_vblank_put+0xa0/0xb8 [drm]
[  132.808849] lr : drm_crtc_vblank_put+0x18/0x20 [drm]
[  132.808852] sp : ffff000008003df0
[  132.808856] x29: ffff000008003df0 x28: ffff000008e42580
[  132.808866] x27: 0000000000000001 x26: ffff000008caf9e8
[  132.808875] x25: ffff000008ebe38a x24: ffff8000712afa00
[  132.808884] x23: 000000000000001f x22: 0000000000000080
[  132.808893] x21: ffff800070498818 x20: ffff000008e39000
[  132.808902] x19: ffff800070645e18 x18: 0000000000008090
[  132.808911] x17: 0000ffff7f805a00 x16: ffff00000823fe20
[  132.808920] x15: 0000000000000000 x14: 0000000000000400
[  132.808929] x13: 00000000000001c3 x12: 0000000000000001
[  132.808938] x11: 000000000000b759 x10: 0000000000000040
[  132.808947] x9 : ffff000008e53728 x8 : 0000000040000000
[  132.808956] x7 : 0000000000210d00 x6 : 0000000000000004
[  132.808964] x5 : ffff000000b29e48 x4 : 0000000000000001
[  132.808973] x3 : 0000000000000160 x2 : 0000000000000000
[  132.808982] x1 : ffff800070924600 x0 : ffff80006f29e000
[  132.808991] Call trace:
[  132.809118]  drm_vblank_put+0xa0/0xb8 [drm]
[  132.809242]  drm_crtc_vblank_put+0x18/0x20 [drm]
[  132.809261]  meson_crtc_irq+0x70/0x188 [meson_drm]
[  132.809275]  meson_irq+0x20/0x30 [meson_drm]
[  132.809291]  __handle_irq_event_percpu+0x5c/0x148
[  132.809298]  handle_irq_event_percpu+0x34/0x88
[  132.809306]  handle_irq_event+0x48/0x78
[  132.809314]  handle_fasteoi_irq+0xa8/0x180
[  132.809321]  generic_handle_irq+0x24/0x38
[  132.809328]  __handle_domain_irq+0x5c/0xb0
[  132.809335]  gic_handle_irq+0x58/0xa8
[  132.809342]  el1_irq+0xb0/0x128
[  132.809350]  arch_cpu_idle+0x10/0x18
[  132.809357]  do_idle+0x1d4/0x288
[  132.809363]  cpu_startup_entry+0x24/0x28
[  132.809374]  rest_init+0xcc/0xd8
[  132.809385]  start_kernel+0x3d4/0x400
[  132.809390] ---[ end trace 68cf73f46dc1892a ]---
[  817.938936] WARNING: CPU: 3 PID: 3412 at drivers/gpu/drm/meson/meson_crtc.c:140 meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[  817.938947] Modules linked in: fuse snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_meson_aiu_i2s_dma snd_soc_meson_i2s_dai snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer meson_dw_hdmi snd dw_hdmi meson_drm soundcore cec drm_kms_helper drm drm_panel_orientation_quirks meson_rng rng_core meson_ir lz4 rc_core lz4_compress snd_soc_meson_audio_core scpi_hwmon meson_gxbb_wdt zram zsmalloc ip_tables x_tables
[  817.939093] CPU: 3 PID: 3412 Comm: Xorg Tainted: G        W         4.17.4-meson64 #7
[  817.939099] Hardware name: Libre Technology CC (DT)
[  817.939109] pstate: 40000005 (nZcv daif -PAN -UAO)
[  817.939130] pc : meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[  817.939150] lr : meson_crtc_atomic_begin+0x20/0x70 [meson_drm]
[  817.939155] sp : ffff00000ffbba30
[  817.939161] x29: ffff00000ffbba30 x28: ffff800070492e00
[  817.939174] x27: ffff80006ab60000 x26: ffff800070498878
[  817.939187] x25: ffff800070498818 x24: ffff80005fede100
[  817.939199] x23: 0000000000000030 x22: 0000000000000000
[  817.939211] x21: 0000000000000000 x20: 0000000000000001
[  817.939223] x19: ffff800070498818 x18: 0000000000000000
[  817.939235] x17: 0000ffffb383bea0 x16: ffff000008255c40
[  817.939247] x15: 0000000000000000 x14: 0000046500000441
[  817.939259] x13: 0000043c00000465 x12: 0000043800000438
[  817.939271] x11: 0000000000000898 x10: 00000804000007d8
[  817.939283] x9 : ffff000008e39d08 x8 : ffff000000b6c000
[  817.939295] x7 : 0000000000000000 x6 : ffff800070924758
[  817.939307] x5 : 00000000000039de x4 : 0000000000000000
[  817.939318] x3 : 0000000000000000 x2 : 0000000000000030
[  817.939330] x1 : ffff80006ab60000 x0 : 00000000ffffffea
[  817.939343] Call trace:
[  817.939364]  meson_crtc_atomic_begin+0x64/0x70 [meson_drm]
[  817.939463]  drm_atomic_helper_commit_planes+0x70/0x208 [drm_kms_helper]
[  817.939543]  drm_atomic_helper_commit_tail+0x30/0x70 [drm_kms_helper]
[  817.939625]  commit_tail+0x74/0x78 [drm_kms_helper]
[  817.939705]  drm_atomic_helper_commit+0xe8/0x168 [drm_kms_helper]
[  817.939907]  drm_atomic_commit+0x48/0x58 [drm]
[  817.939987]  drm_atomic_helper_set_config+0x84/0xc0 [drm_kms_helper]
[  817.940151]  __drm_mode_set_config_internal+0x64/0xf8 [drm]
[  817.940311]  drm_mode_setcrtc+0x2c0/0x538 [drm]
[  817.940469]  drm_ioctl_kernel+0x6c/0xe8 [drm]
[  817.940628]  drm_ioctl+0x1a4/0x3e8 [drm]
[  817.940644]  do_vfs_ioctl+0xb8/0x8d8
[  817.940652]  ksys_ioctl+0x80/0xb8
[  817.940660]  sys_ioctl+0xc/0x18
[  817.940672]  el0_svc_naked+0x30/0x34
[  817.940678] ---[ end trace 68cf73f46dc1892b ]---
[  817.941190] WARNING: CPU: 0 PID: 1868 at drivers/gpu/drm/drm_vblank.c:1026 drm_vblank_put+0xa0/0xb8 [drm]
[  817.941202] Modules linked in: fuse snd_soc_hdmi_codec dw_hdmi_i2s_audio dw_hdmi_cec snd_soc_meson_aiu_i2s_dma snd_soc_meson_i2s_dai snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer meson_dw_hdmi snd dw_hdmi meson_drm soundcore cec drm_kms_helper drm drm_panel_orientation_quirks meson_rng rng_core meson_ir lz4 rc_core lz4_compress snd_soc_meson_audio_core scpi_hwmon meson_gxbb_wdt zram zsmalloc ip_tables x_tables
[  817.941349] CPU: 0 PID: 1868 Comm: in:imklog Tainted: G        W         4.17.4-meson64 #7
[  817.941354] Hardware name: Libre Technology CC (DT)
[  817.941364] pstate: 20000085 (nzCv daIf -PAN -UAO)
[  817.941548] pc : drm_vblank_put+0xa0/0xb8 [drm]
[  817.941716] lr : drm_crtc_vblank_put+0x18/0x20 [drm]
[  817.941740] sp : ffff000008003df0
[  817.941745] x29: ffff000008003df0 x28: ffff800070222880
[  817.941758] x27: 0000000000000001 x26: ffff000008caf9e8
[  817.941771] x25: ffff000008ebe38a x24: ffff8000712afa00
[  817.941783] x23: 000000000000001f x22: 0000000000000080
[  817.941794] x21: ffff800070498818 x20: ffff000008e39000
[  817.941806] x19: ffff800070645e18 x18: ffffffffffffffff
[  817.941818] x17: 0000ffffb4b52b60 x16: ffff000008258da8
[  817.941830] x15: ffff000008e39d08 x14: ffff8000ea86dc02
[  817.941842] x13: ffff80006a86dc10 x12: 302b6e696765625f
[  817.941854] x11: 0000000005f5e0ff x10: 0000000000000040
[  817.941866] x9 : ffff000008e53728 x8 : 0000000040000000
[  817.941877] x7 : 0000000000210d00 x6 : 0000000000000004
[  817.941889] x5 : ffff000000b29e48 x4 : 0000000000000001
[  817.941900] x3 : 0000000000000160 x2 : 0000000000000000
[  817.941912] x1 : ffff800070924600 x0 : ffff80006f29e000
[  817.941925] Call trace:
[  817.942093]  drm_vblank_put+0xa0/0xb8 [drm]
[  817.942260]  drm_crtc_vblank_put+0x18/0x20 [drm]
[  817.942292]  meson_crtc_irq+0x70/0x188 [meson_drm]
[  817.942311]  meson_irq+0x20/0x30 [meson_drm]
[  817.942330]  __handle_irq_event_percpu+0x5c/0x148
[  817.942341]  handle_irq_event_percpu+0x34/0x88
[  817.942351]  handle_irq_event+0x48/0x78
[  817.942360]  handle_fasteoi_irq+0xa8/0x180
[  817.942370]  generic_handle_irq+0x24/0x38
[  817.942379]  __handle_domain_irq+0x5c/0xb0
[  817.942389]  gic_handle_irq+0x58/0xa8
[  817.942397]  el1_irq+0xb0/0x128
[  817.942406]  do_syslog+0x2b8/0x550
[  817.942418]  kmsg_read+0x48/0x60
[  817.942428]  proc_reg_read+0x5c/0x90
[  817.942439]  __vfs_read+0x18/0x38
[  817.942447]  vfs_read+0x90/0x168
[  817.942456]  ksys_read+0x60/0xd8
[  817.942465]  sys_read+0xc/0x18
[  817.942474]  el0_svc_naked+0x30/0x34
[  817.942480] ---[ end trace 68cf73f46dc1892c ]---
Disabling the sound card for now then as well.
OK, found a relevant error I think:
[    1.589945] gxbb-clkc c883c000.clock-controller: failed to get HHI regmap - Trying obsolete regs
@Neil Armstrong I'm looking through patches to see if something is pending for this regmap area, but won't have a ton of time today.
12 minutes ago, Neil Armstrong said:
@TonyMac32 this one is just a warning, it will disappear on 4.18 (4.19 ?) by itself, don't worry
Hmmm ok, it pops up before all the clock-related errors is all.  Any guidance as to what is causing that?
